    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • L lustig29
    @armilar
    Ahh.:man-facepalming:
    lustig29
    schrieb am zuletzt editiert von lustig29
    #5599
    Ich bekomme den Abfallkalender nicht angezeigt. Woran kann das liegen?
    let Abfall: PageType =
        "type": "cardEntities",
        "heading": "Abfallkalender",
        "useColor": true,
        "subPage": false,
        "parent": undefined,
        "items": [
            { id: AliasPath + '0_userdata.0.Abfallkalender.1.event',icon: 'trash-can'},
            { id: AliasPath + '0_userdata.0.Abfallkalender.2.event',icon: 'trash-can'},
            { id: AliasPath + '0_userdata.0.Abfallkalender.3.event',icon: 'trash-can'},
            { id: AliasPath + '0_userdata.0.Abfallkalender.4.event',icon: 'trash-can'}
      <variables>
        <variable id="h}CE-n1l`S|gRf(0K%./">i</variable>
        <variable id="j5C=K+Z.E:im1#q:;A=6">Muell_JSON</variable>
        <variable id="^:v=Yb?;aM;Z[}4jCF3-">Event</variable>
        <variable id="9^)S?J=tLkC7cUWc-u9w">Color</variable>
      </variables>
      <block type="on_ext" id="aFeZac36,?)=rfMg%3T|" x="38" y="-287">
        <value name="OID0">
          <shadow type="field_oid" id="GSzQ}epUa))me3m8yyuD">
            <field name="oid">ical.0.data.table</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="controls_for" id="wduAM(OBPzLJ@bfYAK5%">
            <field name="VAR" id="h}CE-n1l`S|gRf(0K%./">i</field>
            <value name="FROM">
              <shadow type="math_number" id="HK~R2U|`xb$U5W+tsHpN">
                <field name="NUM">0</field>
              </shadow>
            </value>
            <value name="TO">
              <shadow type="math_number" id="Ed[L/:1e9-cwxrRaZiIv">
                <field name="NUM">3</field>
              </shadow>
            </value>
            <value name="BY">
              <shadow type="math_number" id="o@5kngFiPpvl5dGo@Q$9">
                <field name="NUM">1</field>
              </shadow>
            </value>
            <statement name="DO">
              <block type="variables_set" id="0T)vK0k8aikvg7mF6XHo">
                <field name="VAR" id="j5C=K+Z.E:im1#q:;A=6">Muell_JSON</field>
                <value name="VALUE">
                  <block type="get_value" id="1~kG;UHn$nw2zzbfOIT]">
                    <field name="OID">ical.1.data.table</field>
                  </block>
                </value>
                <next>
                  <block type="control_ex" id="UAu,2OBRJp9~Nzyxouyu">
                    <field name="TYPE">false</field>
                    <value name="OID">
                      <shadow type="field_oid" id="J_|uu;{e44n5Z-;qE+hP">
                        <field name="oid">Object ID</field>
                      </shadow>
                      <block type="text_join" id="8/|eHqk))j9Po-O*mK`e">
                        <value name="ADD0">
                          <block type="text" id="Zp8GRfdfXujkeM41=PeZ">
                            <field name="TEXT">0_userdata.0.Abfallkalender.</field>
                          </block>
                        </value>
                        <value name="ADD1">
                          <block type="math_arithmetic" id="$!!l@[eJ~4Kdb5/Imo.X">
                            <field name="OP">ADD</field>
                            <value name="A">
                              <shadow type="math_number" id="zaU15{yD43xkuY@?)RY(">
                              </shadow>
                              <block type="variables_get" id="o3pJ(+3KE~Co%u-dy.:W">
                              </block>
                            </value>
                            <value name="B">
                              <shadow type="math_number" id="_LBb[#z%M$n0~1Y}~8w+">
                              </shadow>
                            </value>
                          </block>
                        </value>
                        <value name="ADD2">
                          <block type="text" id="Vt#-b{iDzusQQx]#0%0,">
                            <field name="TEXT">.date</field>
                          </block>
                        </value>
                      </block>
                    </value>
                      <shadow type="logic_boolean" id="/y1w}eely@o.gl$]#)o=">
                      </shadow>
                      <block type="get_attr" id="p~0A1{eb$lD~.9`9R4K)">
                        <value name="PATH">
                          <shadow type="text" id="kC1+sgB#n4jkZjaeCAi:">
                            <field name="TEXT">0.date</field>
                          </shadow>
                          <block type="text_join" id="DDs!.^n(V7=A_TK}DFQt">
                            <value name="ADD0">
                              <block type="variables_get" id="k1+Dybgb:u2y9v57OrCg">
                              </block>
                            </value>
                            <value name="ADD1">
                              <block type="text" id="EXgB=?B}IKiUdQ.2tKoa">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="OBJECT">
                          <block type="variables_get" id="dzLb1f^T!(MM,d=cYU9y">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="DELAY_MS">
                      <shadow type="math_number" id="f8q~r@+q|8Kov#3EufsI">
                      </shadow>
                    </value>
                    <next>
                      <block type="variables_set" id="E[W-)N[vKeufX{v$B[]p">
                        <field name="VAR" id="^:v=Yb?;aM;Z[}4jCF3-">Event</field>
                          <block type="text_getSubstring" id="YU_Q05y^+I.IzV[c9h9B" inline="false">
                            <mutation at1="true" at2="false"></mutation>
                            <field name="WHERE1">FROM_START</field>
                            <field name="WHERE2">LAST</field>
                            <value name="STRING">
                              <block type="get_attr" id=":/^m9o]3:=L%$4[9$f]7">
                                <value name="PATH">
                                  <shadow type="text" id="MU-+yX*B5FZDno+$EU{S">
                                    <field name="TEXT">0.event</field>
                                  </shadow>
                                  <block type="text_join" id="*MaT-W83R/Y5`?QCQNec">
                                    <value name="ADD0">
                                      <block type="variables_get" id="l5d$/glqMm3~+YA`5]wg">
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      <block type="text" id="$+g0XH}$`2`+{B}s3ID@">
                                        <field name="TEXT">.event</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                  <block type="variables_get" id="nSDdx_!gO45lc4.$`wI`">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="AT1">
                              <block type="math_number" id="ic:P:#_w68q^w]#/;w+K">
                                <field name="NUM">9</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="control_ex" id="^[032{A//-EpUE6lh7ml">
                            <value name="OID">
                              <shadow type="field_oid" id="^DV3eb94-na)vn;h1?K)">
                              </shadow>
                              <block type="text_join" id="`@U%x4KdNV~Y0I`#+,BB">
                                <value name="ADD0">
                                  <block type="text" id="Rk[N`gae|lr/9FXmY!no">
                                  </block>
                                </value>
                                <value name="ADD1">
                                  <block type="math_arithmetic" id="=RY5pU%/0M!J;{^z81qr">
                                    <value name="A">
                                      <shadow type="math_number" id="e_P.rgX|_vD-$%(:T-|I">
                                      </shadow>
                                      <block type="variables_get" id="TbkkwM2BKh^+;KTQY3C]">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <shadow type="math_number" id="e,-Pz1Hy!V:=8S,tHo`:">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                                <value name="ADD2">
                                  <block type="text" id="SApnes6}k9wDi243W2xp">
                                  </block>
                                </value>
                              </block>
                            </value>
                              <shadow type="logic_boolean" id="70uxCt~?y`hOTCs:tJ^~">
                              </shadow>
                              <block type="variables_get" id="}@7(YP=fmA0l@:FJS$v#">
                              </block>
                            </value>
                              <shadow type="math_number" id="@JEhP_3fysDQ6a_x:ILm">
                              </shadow>
                            </value>
                            <next>
                              <block type="controls_if" id="r,.`4GPI|(([[.76Cft~">
                                <mutation elseif="3"></mutation>
                                <value name="IF0">
                                  <block type="logic_compare" id="d4g.Ts.`^;_R!bu)T_~|">
                                    <field name="OP">EQ</field>
                                    <value name="A">
                                      <block type="variables_get" id="tC!eDI_BV-hGgDc@kuPc">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="text" id="?3tZotX[hHq9HGFsA(x|">
                                        <field name="TEXT">Restmüll</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <statement name="DO0">
                                  <block type="variables_set" id="FXPSk]#;ZliNOBw7bVC8">
                                    <field name="VAR" id="9^)S?J=tLkC7cUWc-u9w">Color</field>
                                      <block type="math_number" id="-6AJ8U932(j5LuWN@Sp,">
                                        <field name="NUM">33840</field>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <value name="IF1">
                                  <block type="logic_compare" id=":{8uXg8tzuFNCxedDJ:F">
                                    <value name="A">
                                      <block type="variables_get" id="0A}m@W~711B2u){_B8uP">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="text" id="x,Cz(O2e|co^a7rJEdO7">
                                        <field name="TEXT">Biomüll</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <statement name="DO1">
                                  <block type="variables_set" id="Y#|WXlt|w+`5h3B`VI]*">
                                      <block type="math_number" id="BVnWo|iSfirB?Vw*M7;o">
                                        <field name="NUM">2016</field>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <value name="IF2">
                                  <block type="logic_compare" id="Q0ejJ+ovU#35l7SaPd`7">
                                    <value name="A">
                                      <block type="variables_get" id="/EhoIt{trOOc3*+k5m4C">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="text" id="BVzI8#S#S*Yqk5v;$?kD">
                                        <field name="TEXT">Altpapier</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <statement name="DO2">
                                  <block type="variables_set" id="R7DF(c~|*~pR_D]JqW7c">
                                      <block type="math_number" id="#A]b|UX(@QPk*SM_q)RZ">
                                        <field name="NUM">31</field>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <value name="IF3">
                                  <block type="logic_compare" id="MjEHt,7LG#}DST*Iuc.R">
                                    <value name="A">
                                      <block type="variables_get" id="(WzO?43I0:YSK;VgFmnX">
                                      </block>
                                    </value>
                                    <value name="B">
                                      <block type="text" id="![3nA.95iLG[3]m5%GYS">
                                        <field name="TEXT">Gelbe Tonne</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <statement name="DO3">
                                  <block type="variables_set" id="959t9eG^*uj2c;pF^HGP">
                                      <block type="math_number" id="{*68t/i/Q7}6cb+0$`6Y">
                                        <field name="NUM">65504</field>
                                      </block>
                                    </value>
                                  </block>
                                </statement>
                                <next>
                                  <block type="control_ex" id="^c0LOh0WChe-1QNTGVAy">
                                    <value name="OID">
                                      <shadow type="field_oid" id="7gi,zaI;54L/Ek{e9,I@">
                                      </shadow>
                                      <block type="text_join" id="J|nD$KZ,I6q=mt,xW@:X">
                                        <value name="ADD0">
                                          <block type="text" id="kwm[DP}25YD]Te=}p`S0">
                                          </block>
                                        </value>
                                        <value name="ADD1">
                                          <block type="math_arithmetic" id="pj~|`_~%6}=?B^fK4@;L">
                                            <value name="A">
                                              <shadow type="math_number" id="z/gzD=CFU?L9V-DBj@n;">
                                              </shadow>
                                              <block type="variables_get" id="To0?Cg*f2pZ(Z`zK|=?M">
                                              </block>
                                            </value>
                                            <value name="B">
                                              <shadow type="math_number" id="=Q|k5qeOIy1ya}{CVNF@">
                                              </shadow>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="ADD2">
                                          <block type="text" id="If6$$63npGW3OazEE^46">
                                            <field name="TEXT">.color</field>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                      <shadow type="logic_boolean" id=")+b01E8B2-c#vcsGmA+Y">
                                      </shadow>
                                      <block type="variables_get" id="/5*6z@-R5w^1i2*XphN|">
                                      </block>
                                    </value>
                                      <shadow type="math_number" id="79qt?j;aoK%i)roQkfoE">
                                      </shadow>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    • L lustig29
          "useColor": true,
          "subPage": false,
          "items": [
        <variables>
        </variables>
          <value name="OID0">
            </shadow>
          </value>
              <value name="FROM">
                </shadow>
              </value>
              <value name="TO">
                </shadow>
              </value>
              <value name="BY">
                </shadow>
              </value>
                    </block>
                  </value>
                  <next>
                      <value name="OID">
                        </shadow>
                          <value name="ADD0">
                            </block>
                          </value>
                          <value name="ADD1">
                              <value name="A">
                                </shadow>
                                </block>
                              </value>
                              <value name="B">
                                </shadow>
                              </value>
                            </block>
                          </value>
                          <value name="ADD2">
                            </block>
                          </value>
                        </block>
                      </value>
                        </shadow>
                          <value name="PATH">
                            </shadow>
                              <value name="ADD0">
                                </block>
                              </value>
                              <value name="ADD1">
                                </block>
                              </value>
                            </block>
                          </value>
                            </block>
                          </value>
                        </block>
                      </value>
                        </shadow>
                      </value>
                      <next>
                                  <value name="PATH">
                                    </shadow>
                                      <value name="ADD0">
                                        </block>
                                      </value>
                                      <value name="ADD1">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="AT1">
                                </block>
                              </value>
                            </block>
                          </value>
                          <next>
                              <value name="OID">
                                </shadow>
                                  <value name="ADD0">
                                    </block>
                                  </value>
                                  <value name="ADD1">
                                      <value name="A">
                                        </shadow>
                                        </block>
                                      </value>
                                      <value name="B">
                                        </shadow>
                                      </value>
                                    </block>
                                  </value>
                                  <value name="ADD2">
                                    </block>
                                  </value>
                                </block>
                              </value>
                                </shadow>
                                </block>
                              </value>
                                </shadow>
                              </value>
                              <next>
                                  <value name="IF0">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <value name="IF1">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <value name="IF2">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <value name="IF3">
                                      <value name="A">
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                  <next>
                                      <value name="OID">
                                        </shadow>
                                          <value name="ADD0">
                                            </block>
                                          </value>
                                          <value name="ADD1">
                                              <value name="A">
                                                </shadow>
                                                </block>
                                              </value>
                                              <value name="B">
                                                </shadow>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="ADD2">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                        </shadow>
                                        </block>
                                      </value>
                                        </shadow>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
          </statement>
        </block>
      </xml>
      TT-Tom
      #5600
      @lustig29
      Der Pfad hinter id: ist falsch.
      Hier mal eine Beschreibung https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen#4-abfallkalender
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      L 1 Antwort Letzte Antwort
      • L Offline
        Lokverführer
        #5601
        ich bin neu im Thema und habe schon erfolgreich eine Abfallkalender-Seite eingebunden. Nun würde mich mich gerne an die cardPower wagen. Meine Skriptversion ist 4.3.3.43.
        Ich habe aus dem Wiki eine Beispielkarte kopiert und bei den pages hinzugefügt (mehr sollte für die Demo ja nicht notwendig sein?):
        let CardPowerExample: PageType =
            'type': 'cardPower',
            'heading': 'Energiefluss',
            'useColor': true,
            'items': [
        Beim Compilieren wird aber direkt dieser Fehler ausgegeben:
        [error]: javascript.0 (1572800) script.js.common.NSPanel.NSPanel1: TypeScript compilation failed: 'useColor': true,
        ERROR: Object literal may only specify known properties, and ''useColor'' does not exist in type 'PagePower'.
        Wird die Zeile 'useColor" entfernt, tritt der Fehler nicht mehr auf, es wird aber auch keine Karte angezeigt.
        • L Lokverführer
              'useColor': true,
              'items': [
          T Nicht stören
          T Nicht stören
          ticaki
          #5602
          @lokverführer
          hast du sie unten in pages aufgenommen? Btw. wie kommst du auf useColor - in der Wiki steht es ohne.
          https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-‐-Typen_How-2_Beispiele#page-beispiele
          Spenden
          • L Offline
            Lokverführer
            #5603
            @ticaki
            Und hier steht es mit useColor :
            https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)#cardpower-ab-ts-script-v341
            In Pages habe ich die CardPowerExample mit aufgenommen
            • L Lokverführer
              @ticaki
              T Nicht stören
              T Nicht stören
              ticaki
              #5604
              @lokverführer sagte in SONOFF NSPanel mit Lovelace UI:
              @ticaki
              Danke dann muß das noch korrigiert werden.
              Beim eigentlichen Problem kann ich dir leider nicht helfen.
              Spenden
              • T ticaki
                @ticaki
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                Most Active Forum Testing
                #5605
                @ticaki
                @Lokverführer
                    'items': [
                Habe das useColor bei der cardPower aus dem Wiki entfernt, da es sich mit den Types beißt und in der Card auch keinen Sinn macht...
                Der Rest sollte so funktionieren... 😊
                • ArmilarA Armilar
                  @ticaki
                  @Lokverführer
                      'items': [
                  TT-Tom
                  #5606
                  @armilar
                  @Lokverführer
                  der Demomodus wird nicht funktionieren. suche bitte im script diese Stelle
                  function GeneratePowerPage(page: NSPanel.PagePower): NSPanel.Payload[] {
                      try {
                          if (!page.items[0].id) throw new Error ('Missing pageItem.id for PowerPage!');
                          let obj:object = {};
                          let demoMode = false;
                          if (page.items[0].id == undefined){
                              log('No PageItem defined - cardPower demo mode active', 'info');
                              demoMode = true;
                  und lösche diese Zeile.
                  dann sollte der Demomodus laufen.
                  Gruß Tom
                  Public Transport
                  • patricknitschP Online
                    patricknitsch
                    #5607
                    Hallo, ich habe ein kleines Problem mit meinen Hardwaretasten. Ich habe Rule 1 eingefügt, um nach oben und auf Home springen zu können. Die Home Funktion auf Button 2 funktioniert problemlos. Bei Button 1 springt das Panel aber nicht in die übergeordnete Seite.
                    In Tasmota wird der Befehl richtig ausgegeben. Topic passt dabei auch:
                    21:18:20.859 RUL: BUTTON1#STATE performs "Publish Sonoff/NSPanelOG/tele/RESULT {"CustomRecv":"event,buttonPress1,hwbtn,bUp"}"
                    21:18:20.871 MQT: Sonoff/NSPanelOG/tele/RESULT = {"CustomRecv":"event,buttonPress1,hwbtn,bUp"}
                    In IOBroker erhalte ich aber folgende Fehlermeldung:
                    script.js.common.NSPanel_OG.NSPanel_OG_0_1: Please report to developer: Unknown NSPanel.EventMethod: buttonPress1
                    Hat hierzu jemand eine Idee, woran es liegen könnte?
                    Systeme:
                    • Proxmox 1 mit ioBroker, HomeAssistant, piHole
                    • Proxmox 2 mit SOLECTRUS, Mosquitto, piHole und Frigate
                    • RPi4 mit Octoprint
                    Eigene Adapter: grohe-smarthome, solectrus-influxdb, schlueter-thermostat
                    • patricknitschP patricknitsch
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #5608
                      @patricknitsch sagte in SONOFF NSPanel mit Lovelace UI:
                      ja - es gibt kein buttonPress1, sondern ausschließlich die Methode buttonPress2 und auch wenn man es vermutet, so gibt es keinen Zusammenhang mit den Hardware-Buttons
                      ein bUp wird ebenfalls per buttonPress2 gesendet:
                      https://github.com/joBr99/nspanel-lovelace-ui/tree/main/HMI#messages-from-nextion-display
                      patricknitschP 1 Antwort Letzte Antwort
                      • ArmilarA Armilar
                        patricknitsch
                        #5609
                        @armilar Dann funktioniert die Anleitung Rule 1 mit den Hardware Buttons gar nicht mehr?
                        Systeme:
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #5610
                          @patricknitsch
                          Doch klar funktioniert die noch... ist nur ein Fehler drin.
                          dürfte eher so aussehen:
                          Rule1 on Button1#state do Publish %topic%/tele/RESULT {"CustomRecv":"event,buttonPress2,hwbtn,bUp"} endon on Button2#state do Publish %topic%/tele/RESULT {"CustomRecv":"event,buttonPress2,hwbtn,bHome"} endon
                          Rule1 1
                          EDIT: Habe es im Wiki ebenfalls korrigiert.
                          • ArmilarA Armilar
                            @patricknitsch
                            Rule1 1
                            patricknitsch
                            #5611
                            @armilar Funktioniert! Danke :)
                            Systeme:
                              maik5066
                              #5612
                              Hallo Leute, ich würde gern WLED nutzen, ich habe mir alle Anleitungen durchgelesen leider funktioniert es bei mir nicht.
                              Wenn es jemand, funktionierend umgesetzt hat, könnt ihr mir das Skript und die CARD zuschicken oder am besten posten.
                              Vielen Dank
                                TT-Tom
                                #5613
                                @maik5066
                                Was funktioniert denn nicht bei dir??
                                Welche Fehlermeldungen hast du bekommen??
                                Gruß Tom
                                Public Transport
                                • T TT-Tom
                                  @maik5066
                                  maik5066
                                  #5614
                                  @TT-Tom , danke für deine Rückmeldung. Ich habe das js Skript genutzt und die drei hilfsdatenpunkte angelegt. Wenn ich, wie in der Anleitung das Card Grip kopiere findet er die variable index01 nicht.
                                  Wäre es nicht möglich, direkt die Effekte datenpunkte des WLED Adapter zu nutzen z. Bsp. fx.
                                  Habt ihr ein funktionierendes bespiel was ich mir kopieren kann.
                                  • N Offline
                                    N Offline
                                    nono87
                                    #5615
                                    Guten Morgen,
                                    ich habe meine Mähroboter wieder aus dem Winterschlaf geholt und wollte diesen gleich einbinden.
                                    Bisher klappt auch alles wie gewünscht nur leider stoße ich jetzt an meine Grenzen.
                                    Der Worx gibt als Status eine Zahl mit den States dahinter mit. Diese Zahlen kann ich mittels Info Alias anzeigen. Schöner wäre es natürlich wenn dort als Text steht was gerade passiert. Sei es als Wert oder als Text unter dem Wert.
                                    Ich hoffe dazu gibt es bereits eine Lösung
                                    • M maik5066
                                      TT-Tom
                                      #5616
                                      @maik5066 sagte in SONOFF NSPanel mit Lovelace UI:
                                      Das "parent": Index01, kannst du weglassen. Wenn deine Seite eine SubPage ist, dann solltest du folgende Parameter setzen
                                      'subPage': true,
                                          'parent': Seite von wo du gesprungen bist ,
                                          'home': 'Startseite',
                                      Das Zusatzscript nutzt die Effekte auf dem Datenpunkt, leider kann das Panel nur einen Index aus der Liste zurücksenden. Deswegen dieser Umweg mit den Hilfsdatenpunkten und Script.
                                      Das Beispiel aus dem Wiki läuft, wenn sich der Adapter/WLED nicht so stark geändert hat.
                                      Gruß Tom
                                      Public Transport
                                      M 2 Antworten Letzte Antwort
                                      • N nono87
                                        Guten Morgen,
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        #5617
                                        @nono87
                                        Habe da ein paar Datenpunkte angelegt, weil ich den Landroid ausschließlich per Script steuere und lasse u.a. die Texte von Status und Error ebenfalls einfließen. Man könnte jetzt einfach die Objektdaten nehmen, die sind aber lediglich in englisch und ich wollte die in deutsch. Somit habe ich die übersetzt.
                                        let serial = '2021302673020008XXXX'
                                        //Datenpunkte anlegen
                                        createState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode');
                                        createState('0_userdata.0.WorxLandroid.' + serial + '.Status');
                                        createState('0_userdata.0.WorxLandroid.' + serial + '.Betriebsstunden_Maeher');
                                        createState('0_userdata.0.WorxLandroid.' + serial + '.Betriebszeit_Maeher');
                                        createState('0_userdata.0.WorxLandroid.' + serial + '.Betriebsstunden_Klingen');
                                        createState('0_userdata.0.WorxLandroid.' + serial + '.Betriebszeit_Klingen');
                                        createState('0_userdata.0.WorxLandroid.' + serial + '.Betriebsstrecke_km');
                                        on({id: [].concat(['worx.0.' + serial + '.mower.error']), change: "any"}, async function (obj) {
                                          switch (obj.state.val) {
                                              case 0:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Kein Fehler');
                                                break;
                                              case 1:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Gefangen');
                                                break;
                                              case 2:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Angehoben');
                                                break;
                                              case 3:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Draht nicht angeschlossen');
                                                break;
                                              case 4:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Außerhalb der Begrenzung');
                                                break;
                                              case 5:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Regen');
                                                break;
                                              case 6:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Schließe Akku-Klappe');
                                                break;
                                              case 7:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Akku-Klappe offen');
                                                break;
                                              case 8:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Klingen-Motor blockiert');
                                                break;
                                              case 9:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Antrieb blockiert');
                                                break;
                                              case 10:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Eingeschlossen Timeout');
                                                break;
                                              case 11:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Upside down');
                                                break;
                                              case 12:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Akku niedrig');
                                                break;
                                              case 13:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Drahtpolung falsch');
                                                break;
                                              case 14:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Ladefehler');
                                                break;
                                              case 15:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Timeout finding home');
                                                break;
                                              case 16:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Mower locked');
                                                break;
                                              case 17:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Akku zu heiß');
                                                break;
                                              case 18:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Dummy Model');
                                                break;
                                              case 19:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'Akku-Klappe Timeout');
                                                break;
                                              case 20:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'wire sync');
                                                break;
                                              case 21:
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.ErrorCode', 'msg num');
                                                break;
                                        on({id: [].concat(['worx.0.' + serial + '.mower.batteryState']), change: "any"}, async function (obj) {
                                            console.log("Batteriestatus: " + obj.state.val + "%");
                                            console.log("Status: " + getState('worx.0.' + serial + '.mower.status').val);
                                            if (obj.state.val < 100 && parseInt(getState('worx.0.' + serial + '.mower.status').val) == 1) {
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Akku wird aufgeladen');
                                            if (obj.state.val = 100 && parseInt(getState('worx.0.' + serial + '.mower.status').val) == 1) {
                                                setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Ausgangsposition');
                                        on({id: [].concat(['worx.0.' + serial + '.mower.status']), change: "any"}, async function (obj) {
                                                case 0:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Leerlauf');
                                                    break;
                                                case 1:
                                                    if (getState('worx.0.' + serial + '.mower.batteryState').val <= 10) {
                                                        setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Ladestation');
                                                    } else {
                                                    break;
                                                case 2:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Start Sequence');
                                                    break;
                                                case 3:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Verlasse Ladestation');
                                                    break;
                                                case 4:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Folge Draht');
                                                    break;
                                                case 5:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Suche Ladestation');
                                                    break;
                                                case 6:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Suche Draht');
                                                    break;
                                                case 7:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Mähen');
                                                    break;
                                                case 8:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Angehoben');
                                                    break;
                                                case 9:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Eingeschlossen');
                                                    break;
                                                case 10:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Messer blockiert');
                                                    break;
                                                case 11:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Debug');
                                                    break;
                                                case 12:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Remote control');
                                                    break;
                                                case 13:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'escape from off limits');
                                                    break;
                                                case 30:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Fahrt zur Ladestation');
                                                    break;
                                                case 30:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Zonen Training');
                                                    break;
                                                case 30:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Rasenkantenschnitt');
                                                    break;
                                                case 30:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Suche Zone');
                                                    break;
                                                case 30:
                                                    setState('0_userdata.0.WorxLandroid.' + serial + '.Status', 'Pause');
                                                    break;
                                        on({id: [].concat(['worx.0.' + serial + '.mower.totalTime']), change: "any"}, async function (obj) {
                                            setState('0_userdata.0.WorxLandroid.' + serial + '.Betriebsstunden_Maeher', Math.round((parseFloat((obj.state ? obj.state.val : "")) / 60)*100)/100);
                                            let diff = obj.state.val;
                                            console.log("Minuten gesamt: " + diff);
                                            let days = Math.floor(diff / 60 / 24);
                                            diff = diff - (days * 60 * 24)
                                            let hours = Math.floor(diff / 60)
                                            diff = diff - (hours * 60)
                                            console.log("Betriebszeit Mäher: " + days + " Tage, " +  hours + " Stunden, " + diff + " Minuten")
                                            setState('0_userdata.0.WorxLandroid.' + serial + '.Betriebszeit_Maeher', days + " T. " +  hours + " Std. " + diff + " Min.");
                                        on({id: [].concat(['worx.0.' + serial + '.mower.totalBladeTime']), change: "any"}, async function (obj) {
                                            setState('0_userdata.0.WorxLandroid.' + serial + '.Betriebsstunden_Klingen', Math.round((parseFloat((obj.state ? obj.state.val : "")) / 60)*100)/100);
                                            console.log("Minuten Klingen: " + diff);
                                            console.log("Betriebszeit Klingen: " + days + " Tage, " +  hours + " Stunden, " + diff + " Minuten")
                                            setState('0_userdata.0.WorxLandroid.' + serial + '.Betriebszeit_Klingen', days + " T. " +  hours + " Std. " + diff + " Min.");
                                        on({id: [].concat(['worx.0.' + serial + '.mower.totalDistance']), change: "any"}, async function (obj) {
                                          setState('0_userdata.0.WorxLandroid.' + serial + '.Betriebsstrecke_km', (parseFloat((obj.state ? obj.state.val : "")) / 1000));
                                        Falls du das Script im Spoiler gebrauchen kannst? Ein JS-Script anlegen, die Seriennummer aus dem Worx Adapter einfügen und starten.
                                        Die Infos kannst du dann per Alias info in die Card bringen 😊
                                        • N Offline
                                          N Offline
                                          nono87
                                          #5618
                                          @armilar said in SONOFF NSPanel mit Lovelace UI:
                                          Die Daten habe ich soweit schon aufbereitet, aber mir fehlt es dann noch das ich diese im Panel anzeigen lassen kann.
                                          Ich versuche es mal anders.
                                          Wie in dem Bild zu sehen werden die Zustände nur als Zahlen dargestellt. Da hätte ich gern das es in Wörtern steht 😊
                                          oder von mir aus auch unter der Zahl.
