  4. JS Instanz startet nicht mehr
    1.0k
    6.1k
15 Beiträge 6 Kommentatoren 1.2k Aufrufe 5 Beobachtet
  • P Offline
    Pistus
    schrieb am zuletzt editiert von Pistus
    Ich habe in der JS Instanz ein zusätzliches npm Modul suncalc hinzugefügt.
    Jetzt lässt sich JS nicht mehr starten.
    Das steht in der LOG Datei, ein Auszug, der sich immer wiederholt
    2024-03-20 15:48:36.376 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
    2024-03-20 15:49:06.461 - info: host.iobroker instance system.adapter.javascript.0 started with pid 2544
    2024-03-20 15:49:06.820 - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.javascript/node_modules/tough-cookie/lib/cookie.js:1144
    2024-03-20 15:49:06.820 - error: host.iobroker Caught by controller[0]: // The cookie's host-only-flag is false and the cano
    2024-03-20 15:49:06.820 - error: host.iobroker Caught by controller[0]: SyntaxError: Unexpected end of input
    2024-03-20 15:49:06.820 - error: host.iobroker Caught by controller[0]: at internalCompileFunction (node:internal/vm:73:18)
    2024-03-20 15:49:06.821 - error: host.iobroker Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1274:20)
    2024-03-20 15:49:06.821 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1320:27)
    2024-03-20 15:49:06.821 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-03-20 15:49:06.821 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-03-20 15:49:06.821 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-03-20 15:49:06.821 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-03-20 15:49:06.822 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
    2024-03-20 15:49:06.822 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/cookies.js:3:13)
    2024-03-20 15:49:06.822 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-03-20 15:49:06.822 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-03-20 15:49:06.822 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-03-20 15:49:06.822 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-03-20 15:49:06.822 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-03-20 15:49:06.823 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
    2024-03-20 15:49:06.823 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:18:15)
    2024-03-20 15:49:06.823 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-03-20 15:49:06.823 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-03-20 15:49:06.823 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-03-20 15:49:06.823 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-03-20 15:49:06.823 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-03-20 15:49:06.824 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
    2024-03-20 15:49:06.824 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-03-20 15:49:06.824 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-03-20 15:49:06.824 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-03-20 15:49:06.824 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-03-20 15:49:06.824 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-03-20 15:49:06.824 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
    2024-03-20 15:49:06.824 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/main.js:44:23)
    2024-03-20 15:49:06.825 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-03-20 15:49:06.825 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-03-20 15:49:06.825 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-03-20 15:49:06.825 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-03-20 15:49:06.825 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2024-03-20 15:49:06.825 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:28:49
    2024-03-20 15:49:06.825 - error: host.iobroker Caught by controller[0]: Node.js v18.19.1
    2024-03-20 15:49:06.826 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-03-20 15:49:06.826 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
    iob stop
    iob fix
    iob start
    habe ich gemacht. Hilft aber nicht. Was kann ich noch machen?``
    DJMarc75D haus-automatisierungH 2 Antworten Letzte Antwort
    • P Pistus
      iob stop
      iob fix
      iob start
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @pistus sagte in JS Instanz startet nicht mehr:
      mach das erst mal raus und versuche danach suncalc2
      Lehrling seit 1975 !!!
      • P Pistus
        iob stop
        iob fix
        iob start
        haus-automatisierungH Offline
        Warum auch immer - suncalc2 ist im Standard JavaScript-Adpater ja schon als Abhängigkeit enthalten. Kann man direkt verwenden ohne es in die Liste der zusätzlichen Module einzutragen.
        Und eigentlich stellt der JavaScript-Adapter ja schon alle berechneten Datenpunkte und Funktionen bereit, sodass man damit (hoffentlich) nix mehr selbst machen muss.
        📚 Meine Dokumentation
        P 1 Antwort Letzte Antwort
          Pistus
          @haus-automatisierung
          @DJMarc75
          Alle Skripte, die ich im Forum zu diesem Thema gesehen haben fingen mit dieser Codezeile an
          var suncalc = require('suncalc'),
          Die Fehlermeldung lautete dann `'Cannnot find suncalc'
          Wie wird der Befehl in suncalc2 geschrieben?
          Zunächst hatte ich suncalc mittels Putty installiert.
          Weil der Fehler immer noch angezeigt wurde, habe ich suncalc über die Instanzeinstellungen in JS installiert. Jetzt startete JS nicht mehr.
          Dann habe ich in den Instanzeinstellungen sunkalc entfernt.
          Wie bekomme ich JS wieder funktionsfähig?
          HomoranH haus-automatisierungH 2 Antworten Letzte Antwort
          • P Pistus
            @DJMarc75
            wie und wo?
              wie und wo?
              Pistus
              In ioBroker, mittels
              sudo npm -g install suncalc
              DJMarc75D HomoranH 2 Antworten Letzte Antwort
              • P Pistus
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                ernsthaft? man fügt Module hier ein:
                aber wie schon @haus-automatisierung geschrieben hat ist suncalc2 schon integriert
                • P Pistus
                  dazu sollte es dann auch einen Befehl geben das global wieder zu enfernen.
                  Wie alt waren die denn?
                  Da gab's wohl noch kein suncalc2
                    Pistus
                    @DJMarc75
                    ernsthaft! Ich bin in ioBroker noch nichi so fit und muss alles was ich tue erst lesen und dann probieren. Dass hinzufügen von Modulen auch über die Instanzeinstellungen fuktioniet, habe ich später gelesen.
                    Den uninstall Befehl
                    npm uninstall /full/path/to/node_modules/module-name
                    werde ich testen
                    • P Pistus
                      @DJMarc75
                      werde ich testen
                      das ist ja auch gut so
                      https://www.iobroker.net/#de/documentation
                      • P Pistus
                        @DJMarc75
                        @pistus Die Frage ist ja: Wozu und was hast Du vor?
                          Pistus
                          Ich habe ein Flachdach in Ost West Richtung.
                          Auf diesem Dach ist eine 10KW Solaranlage installiert, auch in Ost West Richtung ausgerichtet.
                          Jetzt wollte ich je nach Sonnenstand die Leistung in VIS2 ablesen können.
                          Die Sonne geht im Osten (dargestellt mittels kleines Bild) um 7Uhr auf und und wandert im Halbkreis Richtung Westen wo sie dann um 19Uhr unter geht. Hintergrundbild ist das Solardach. Aus dem SMA Wechselrichter steht mittels Modbus die Leistung zur Verfügung.
                          Ob das überhaupt funktioniert weiß ich noch nicht, will es aber versuchen.
                          Der uninstall Befehl hat nichts gebracht.
                          iobroker@iobroker:~ $ sudo npm uninstall /full/path/to/node_modules/suncalc
                          [sudo] password for iobroker:
                          up to date, audited 2 packages in 1s
                          found 0 vulnerabilities
                          npm notice
                          npm notice New minor version of npm available! 10.2.4 -> 10.5.0
                          npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.0
                          npm notice Run npm install -g npm@10.5.0 to update!
                          npm notice
                          Kann ich JS löschen und neu installieren? Oder hat noch Jemand eine Idee?
                          • P Pistus
                            npm notice
                            npm notice
                            Das muss ja auch von dir auf den vollen Pfad geändert werden.
                            Und grundsätzlich wird npm tunlichst NICHT mit sudo eingeleitet.
                            In dem Fall aber:
                            sudo npm -g uninstall suncalc
                            Und allgemein lässt man die Finger von 'npm'. Das Tool ist zu 'gefährlich', wenn man nicht genau weiß was man damit wo und warum anstellt.
                              In dem Fall aber:
                              Pistus
                              Ich habe mir mein System leider kaputt gemacht. Jetzt will das System nur noch ein ioBroker Setup durchführen.
                              Da der Raspi 4 erst 1 Monat alt ist, möchte ich noch einmal alles neu installieren. So, als hätte ich einen jungfräulichen RaspberryPi 4. Ich mache als Anfänger noch sehr viel falsch.
                              Bis auf VIS 2 habe ich noch Backup's von meinem Raspberry 3 auf einer USB Festplatte an der Fritzbox.
                              Wie kann man bei der ioBroker Installation erreichen, dass die gleiche IP Adresse wie vor eingestellt ist?
                              • P Pistus
                                CodierknechtC Online
                                Codierknecht
                                Das hat mit ioBroker nix zu tun.
                                Üblicherweise vergibt Dein Router die IP-Adressen per DHCP. Dort kannst Du sie auch ändern.
                                Wenn Du den Pi neu aufsetzt, sollte er (normalerweise) seine IP behalten. Die MAC-Adresse ändert sich ja nicht.
                                HmIP|ZigBee|Tasmota|Unifi
                                Zabbix Certified Specialist
