  4. Test Adapter TrashSchedule
    6.1k
adaptercalendaricalkalendermülltrash
1.4k Beiträge 186 Kommentatoren 681.0k Aufrufe 171 Beobachtet
  • Virus2K12V Offline
    Virus2K12V Offline
    Virus2K12
    #1373
    zusammenfassung iob_diag
    			v.2023-10-25
     Static hostname: raspberrypi
           Icon name: computer
    Operating System: Raspbian GNU/Linux 12 (bookworm)
              Kernel: Linux 5.10.103-v7l+
        Architecture: arm
    Installation: 		native
    Kernel: 		armv7l
    Userland: 		armhf
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		multi-user.target
    Pending OS-Updates: 	0
    Pending iob updates: 	1
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.1
    			/usr/bin/node 		v18.19.1
    			/usr/bin/npm 		10.2.4
    			/usr/bin/npx 		10.2.4
    			/usr/bin/corepack 	0.22.0
    Recommended versions are nodejs 18.19.1 and npm 10.2.4
    MEMORY:
    Mem:            4.0G        2.7G        223M        4.8M        1.3G        1.3G
    Swap:           104M          0B        104M
    Total:          4.1G        2.7G        328M
    Active iob-Instances: 	34
    Active repo(s): Beta (latest)
    ioBroker Core: 		js-controller 		5.0.19
    			admin 			6.15.2
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 		21668
    States: 		14569
    Size of iob-Database:
    32M	/opt/iobroker/iobroker-data/objects.jsonl
    112M	/opt/iobroker/iobroker-data/states.jsonl
    • Virus2K12V Virus2K12
      Desktop aus und reinstall nodejs gemacht.
      Hier jetzt erst einmal die lange Fassung von iob diag
      Skript v.2023-10-25
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm
      Model		: Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       11:46:10 up 4 min,  1 user,  load average: 4.35, 2.76, 1.17
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-03-08 11:46:10 CET
                 Universal time: Fri 2024-03-08 10:46:10 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Mem:            4.0G        2.4G        670M        4.8M        1.1G        1.6G
      Swap:           104M          0B        104M
      Total:          4.1G        2.4G        775M
               3837 M total memory
               2303 M used memory
                235 M active memory
               2842 M inactive memory
                638 M free memory
                244 M buffer memory
                788 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
      1 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      219G   24G  185G  12% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
      tmpfs          tmpfs     768M  2.1M  766M   1% /run
      tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
      /dev/loop1     squashfs   43M   43M     0 100% /snap/certbot/3642
      /dev/loop2     squashfs   91M   91M     0 100% /snap/core/16207
      /dev/loop0     squashfs   42M   42M     0 100% /snap/certbot/3568
      /dev/loop4     squashfs   54M   54M     0 100% /snap/core20/2106
      /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16575
      /dev/loop5     squashfs   54M   54M     0 100% /snap/core20/2185
      /dev/sda1      vfat      253M   93M  160M  37% /boot
      tmpfs          tmpfs     384M   80K  384M   1% /run/user/1000
      [Fri Mar  8 11:41:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:4F:AC:15 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=048e52a3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles fsck.mode=force cfg80211.ieee80211_regdom=DE
      [Fri Mar  8 11:41:27 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Mar  8 11:41:27 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Fri Mar  8 11:42:02 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET                         SOURCE      FSTYPE      OPTIONS
      /                              /dev/sda2   ext4        rw,noatime
      |-/dev                         devtmpfs    devtmpfs    rw,relatime,size=1800056k,nr_inodes=84157,mode=755
      | |-/dev/shm                   tmpfs       tmpfs       rw,nosuid,nodev
      | |-/dev/pts                   devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue                mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
      |-/proc                        proc        proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc   systemd-1   autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |   `-/proc/sys/fs/binfmt_misc binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/sys                         sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security       securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup             cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/bpf                none        bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug          debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing        tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections   fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config         configfs    configfs    rw,nosuid,nodev,noexec,relatime
      |-/run                         tmpfs       tmpfs       rw,nosuid,nodev,size=785972k,nr_inodes=819200,mode=755
      | |-/run/lock                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service
      | |                            none        ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service
      | |-/run/rpc_pipefs            sunrpc      rpc_pipefs  rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service
      | `-/run/user/1000             tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=392984k,nr_inodes=98246,mode=700,uid=1000,gid=1000
      |-/snap/certbot/3642           /dev/loop1  squashfs    ro,nodev,relatime
      |-/snap/core/16207             /dev/loop2  squashfs    ro,nodev,relatime
      |-/snap/certbot/3568           /dev/loop0  squashfs    ro,nodev,relatime
      |-/snap/core20/2106            /dev/loop4  squashfs    ro,nodev,relatime
      |-/snap/core/16575             /dev/loop3  squashfs    ro,nodev,relatime
      |-/snap/core20/2185            /dev/loop5  squashfs    ro,nodev,relatime
      `-/boot                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-r
      /var:
      3.6G	/var/
      2.1G	/var/log
      1.9G	/var/log/journal/a86ff8ac034a41cc8294fe68053416f8
      1.3G	/var/lib
      Archived and active journals take up 1.8G in the file system.
      /opt/iobroker/backups:
      178M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      741M	/opt/iobroker/iobroker-data/
      523M	/opt/iobroker/iobroker-data/files
      89M	/opt/iobroker/iobroker-data/files/echarts.admin
      80M	/opt/iobroker/iobroker-data/backup-objects
      57M	/opt/iobroker/iobroker-data/files/javascript.admin
      du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c3ec73ec5450fb4cac984fc867dd54eb.js': No such file or directory
      du: cannot access '/opt/iobroker/iobroker-data/files/vis-2/c351437da7e800bc3d9409c431052f9c.js': No such file or directory
      109M	/opt/iobroker/iobroker-data/states.jsonl
      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      31M	/opt/iobroker/iobroker-data/objects.jsonl
      24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/npm 		10.2.4
      /usr/bin/npx 		10.2.4
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 600
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.19.0+dfsg-6~deb12u1+rpi1 500
              500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
           18.19.0-1nodesource1 600
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.19
      admin: 		6.15.2
      javascript: 	7.8.0
      Adapters from github: 	1
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled, compact disabled
      + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled, compact disabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled, compact disabled
      + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled, compact disabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled, compact disabled
      + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled, compact disabled
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled, compact disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled, compact disabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled, compact disabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled, compact disabled
      + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled, compact disabled
      + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled, compact disabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, compact disabled, port: 80
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled, compact disabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled, compact disabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled, compact disabled
      + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, compact disabled, port: 1884
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, compact disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
        system.adapter.netatmo-crawler.1        : netatmo-crawler       : raspberrypi                              -  enabled, compact disabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled, compact disabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled, compact disabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled, compact disabled
      + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled, compact disabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled, compact disabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled, compact disabled
      + system.adapter.vesync.0                 : vesync                : raspberrypi                              -  enabled, compact disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled, compact disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled, compact disabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
        system.adapter.vis-homekittiles.0       : vis-homekittiles      : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled, compact disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled, compact disabled
        system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
        system.adapter.vis-material.0           : vis-material          : raspberrypi                              -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
        system.adapter.vis-owl.0                : vis-owl               : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled, compact disabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled, compact disabled
      + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled, compact disabled
      + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Used repository: Beta (latest)
      Adapter    "admin"        : 6.15.2   , installed 6.15.2
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "awtrix-light" : 0.15.0   , installed 0.15.0
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "device-watcher": 2.10.5  , installed 2.10.5
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "espresense"   : 0.4.4    , installed 0.4.4
      Adapter    "hmip"         : 1.22.0   , installed 1.22.0
      Adapter    "hue"          : 3.10.2   , installed 3.10.2
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "ical"         : 1.14.3   , installed 1.14.3
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
      Adapter    "snmp"         : 3.1.0    , installed 3.1.0
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "telegram"     : 3.1.0    , installed 3.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.2.0    , installed 2.3.0  [Updatable]
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "vesync"       : 0.0.7    , installed 0.0.7
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-2"        : 2.9.40   , installed 2.9.40
      Adapter    "vis-2-widgets-material": 1.3.25, installed 1.3.25
      Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
      Adapter    "vis-homekittiles": 0.0.9 , installed 0.0.9
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Objects and States
      Objects: 	21668
      States: 	14569
      Hit:1 http://linux.teamviewer.com/deb stable InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
      Hit:3 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:5 https://packages.sury.org/php buster InRelease
      Update rpimonitor Packages Status
      Reading package lists... Done
      Pending Updates: 0
      *** Listening Ports ***
      Netid          State           Recv-Q          Send-Q                                 Local Address:Port                    Peer Address:Port         Process
      udp            UNCONN          0               0                                            0.0.0.0:6666                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=37))
      udp            UNCONN          0               0                                            0.0.0.0:6667                         0.0.0.0:*             users:(("io.tuya.0",pid=1804,fd=38))
      udp            UNCONN          0               0                                            0.0.0.0:5683                         0.0.0.0:*             users:(("io.shelly.0",pid=1704,fd=32))
      udp            UNCONN          0               0                                          127.0.0.1:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=11))
      udp            UNCONN          0               0                                            0.0.0.0:33903                        0.0.0.0:*             users:(("io.snmp.0",pid=2100,fd=29))
      udp            UNCONN          0               0                                            0.0.0.0:631                          0.0.0.0:*             users:(("cups-browsed",pid=1293,fd=7))
      udp            UNCONN          0               0                                    192.168.178.255:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=17))
      udp            UNCONN          0               0                                     192.168.178.51:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=16))
      udp            UNCONN          0               0                                            0.0.0.0:137                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=14))
      udp            UNCONN          0               0                                    192.168.178.255:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=19))
      udp            UNCONN          0               0                                     192.168.178.51:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=18))
      udp            UNCONN          0               0                                            0.0.0.0:138                          0.0.0.0:*             users:(("nmbd",pid=1341,fd=15))
      udp            UNCONN          0               0                                            0.0.0.0:45212                        0.0.0.0:*             users:(("connmand",pid=570,fd=21))
      udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("io.wled.0",pid=2673,fd=21))
      udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.1",pid=1762,fd=29))
      udp            UNCONN          0               0                                     192.168.178.51:5353                         0.0.0.0:*             users:(("io.tr-064.0",pid=1736,fd=30))
      udp            UNCONN          0               0                                            0.0.0.0:5353                         0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=12))
      udp            UNCONN          0               0                                            0.0.0.0:47932                        0.0.0.0:*             users:(("avahi-daemon",pid=456,fd=14))
      udp            UNCONN          0               0                                                  *:50208                              *:*             users:(("avahi-daemon",pid=456,fd=15))
      udp            UNCONN          0               0                                                  *:546                                *:*             users:(("connmand",pid=570,fd=18))
      udp            UNCONN          23616           0                        [fe80::ac64:680b:efa1:4b03]:546                                *:*             users:(("NetworkManager",pid=569,fd=24))
      udp            UNCONN          0               0                                              [::1]:53                                 *:*             users:(("connmand",pid=570,fd=12))
      udp            UNCONN          0               0                                                  *:5353                               *:*             users:(("avahi-daemon",pid=456,fd=13))
      tcp            LISTEN          0               128                                        127.0.0.1:5939                         0.0.0.0:*             users:(("teamviewerd",pid=1322,fd=12))
      tcp            LISTEN          0               4096                                         0.0.0.0:8083                         0.0.0.0:*             users:(("motion",pid=866,fd=5))
      tcp            LISTEN          0               10                                      127.0.0.1%lo:53                           0.0.0.0:*             users:(("connmand",pid=570,fd=13))
      tcp            LISTEN          0               128                                          0.0.0.0:22                           0.0.0.0:*             users:(("sshd",pid=707,fd=3))
      tcp            LISTEN          0               128                                        127.0.0.1:631                          0.0.0.0:*             users:(("cupsd",pid=617,fd=7))
      tcp            LISTEN          0               5                                            0.0.0.0:8888                         0.0.0.0:*             users:(("rpimonitord",pid=754,fd=4))
      tcp            LISTEN          0               511                                          0.0.0.0:1883                         0.0.0.0:*             users:(("io.sonoff.0",pid=1711,fd=34))
      tcp            LISTEN          0               511                                          0.0.0.0:1884                         0.0.0.0:*             users:(("io.mqtt.1",pid=1666,fd=29))
      tcp            LISTEN          0               50                                           0.0.0.0:445                          0.0.0.0:*             users:(("smbd",pid=1348,fd=31))
      tcp            LISTEN          0               128                                          0.0.0.0:8765                         0.0.0.0:*             users:(("meyectl",pid=470,fd=12))
      tcp            LISTEN          0               4096                                         0.0.0.0:7999                         0.0.0.0:*             users:(("motion",pid=866,fd=7))
      tcp            LISTEN          0               511                                        127.0.0.1:9000                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=27))
      tcp            LISTEN          0               511                                        127.0.0.1:9001                         0.0.0.0:*             users:(("iobroker.js-con",pid=1306,fd=21))
      tcp            LISTEN          0               80                                         127.0.0.1:3306                         0.0.0.0:*             users:(("mariadbd",pid=714,fd=27))
      tcp            LISTEN          0               50                                           0.0.0.0:139                          0.0.0.0:*             users:(("smbd",pid=1348,fd=32))
      tcp            LISTEN          0               511                                        127.0.0.1:6379                         0.0.0.0:*             users:(("redis-server",pid=620,fd=6))
      tcp            LISTEN          0               511                                                *:80                                 *:*             users:(("apache2",pid=799,fd=4),("apache2",pid=797,fd=4),("apache2",pid=796,fd=4),("apache2",pid=795,fd=4),("apache2",pid=794,fd=4),("apache2",pid=793,fd=4),("apache2",pid=739,fd=4))
      tcp            LISTEN          0               511                                                *:8081                               *:*             users:(("io.admin.0",pid=1419,fd=29))
      tcp            LISTEN          0               511                                                *:8082                               *:*             users:(("io.web.0",pid=2666,fd=29))
      tcp            LISTEN          0               511                                                *:8084                               *:*             users:(("io.ws.0",pid=2703,fd=28))
      tcp            LISTEN          0               10                                          [::1]%lo:53                              [::]:*             users:(("connmand",pid=570,fd=14))
      tcp            LISTEN          0               128                                             [::]:22                              [::]:*             users:(("sshd",pid=707,fd=4))
      tcp            LISTEN          0               511                                                *:8087                               *:*             users:(("io.simple-api.0",pid=2067,fd=28))
      tcp            LISTEN          0               128                                            [::1]:631                             [::]:*             users:(("cupsd",pid=617,fd=6))
      tcp            LISTEN          0               4096                                               *:3000                               *:*             users:(("grafana-server",pid=1295,fd=11))
      tcp            LISTEN          0               50                                              [::]:445                             [::]:*             users:(("smbd",pid=1348,fd=29))
      tcp            LISTEN          0               511                                            [::1]:6379                            [::]:*             users:(("redis-server",pid=620,fd=7))
      tcp            LISTEN          0               50                                              [::]:139                             [::]:*             users:(("smbd",pid=1348,fd=30))
      2024-03-08 11:46:19.657  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.humidity_value": Connection is closed.]
      2024-03-08 11:46:19.659  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.
      2024-03-08 11:46:19.660  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.pressure_value": Connection is closed.]
      2024-03-08 11:46:19.662  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.
      2024-03-08 11:46:19.664  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.clouds_value": Connection is closed.]
      2024-03-08 11:46:19.666  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.
      2024-03-08 11:46:19.667  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.snowline_value": Connection is closed.]
      2024-03-08 11:46:19.669  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.
      2024-03-08 11:46:19.671  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.windchill_value": Connection is closed.]
      2024-03-08 11:46:19.673  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.
      2024-03-08 11:46:19.675  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7.uv_index_value": Connection is closed.]
      2024-03-08 11:46:19.677  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.
      2024-03-08 11:46:19.680  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8": Connection is closed.]
      2024-03-08 11:46:19.682  - error: daswetter.0 (2725) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.
      2024-03-08 11:46:19.684  - error: daswetter.0 (2725) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8.hour_value": Connection is closed.]
      2024-03-08 11:46:20.212  - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
      2024-03-08 11:46:21.158  - info: tuya.0 (1804) bf047f0676f4973f71uyin: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.59:6668
      2024-03-08 11:46:35.239  - info: tuya.0 (1804) bf7e8a579d18ba290elhqa: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.34:6668
      2024-03-08 11:46:40.760  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
      2024-03-08 11:46:40.844  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
      2024-03-08 11:47:01.160  - error: vesync.0 (2220) {"traceId":"1709894813723","code":-11302030,"msg":"device timeout","module":null,"stacktrace":null,"result":null}
      2024-03-08 11:47:42.466  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
      2024-03-08 11:47:42.960  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
      2024-03-08 11:48:40.996  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.rx_sec" has to be stringified but received type "number"
      2024-03-08 11:48:41.296  - info: info.0 (2015) State value to set for "info.0.sysinfo.network.stats.iface0.tx_sec" has to be stringified but received type "number"
      iob diag has finished.
      Press any key for a summary
      #1374
      @virus2k12
      Hast du das per Dist-Upgrade von einer Vorversion auf 'Debian 12 - Bookworm' gebracht (bzw. es versucht?).
      Das funktioniert nicht. Neuinstallation von Null an.
      Virus2K12V 1 Antwort Letzte Antwort
        @virus2k12
        Virus2K12V Offline
        Virus2K12V Offline
        Virus2K12
        schrieb am zuletzt editiert von Virus2K12
        #1375
        @thomas-braun ja, von bullseye auf bookworm, aber schon vor ewigkeiten. Lief auch die ganze Zeit ohne Probleme.
        Zuletzt habe ich eine smb Freigabe für verschieden Verzeichnisse gemacht, kann es daran liegen zwecks Zugriffsrechte etc. ?
          #1376
          @virus2k12
          Aber nicht richtig.
          Der Kernel ist z. B. noch aus Bullseye-Zeiten.
            Virus2K12V Offline
            Virus2K12
            #1377
            Problem gelöst. Node, npm und iob deinstalliert, Kernelupdate gemacht, node, npm und iob neu installiert und alles läuft.
              #1378
              @virus2k12
              Du hockst aber immer noch auf einer 32Bit-Version.
                Virus2K12V Offline
                Virus2K12
                #1379
                @thomas-braun ja, kann ich das einfach von 32 auf 64 updaten?
                da_WoodyD Thomas BraunT 2 Antworten Letzte Antwort
                  da_WoodyD Online
                  da_WoodyD Online
                  #1380
                  @virus2k12 ja, wie schon der Vorschlag war. Neu installieren.
                    #1381
                    @virus2k12 sagte in Test Adapter TrashSchedule:
                    Nein. Wie bereits oben gesagt: Komplette NEUINSTALLATION ist erforderlich.
                    • da_WoodyD da_Woody
                      Virus2K12V Offline
                      Virus2K12V Offline
                      Virus2K12
                      #1382
                      @da_woody nee ich hab weder Zeit noch Lust alles neu aufzusetzen.
                        Virus2K12V Offline
                        Virus2K12V Offline
                        Virus2K12
                        #1383
                        @thomas-braun nee, dann bleibt es so wie es ist.
                          #1384
                          @virus2k12
                          Dann viel Spaß in Zukunft. Das wird dir früher oder später wegkippen.
                          • Siggi0904S Offline
                            Siggi0904S Offline
                            Siggi0904
                            #1385
                            Ich hatte seit dem letzten Stable Update vergessen zu fragen,
                            wie funktioniert denn das mit den Datenpunkten "Tätigwerden" und "erledigt"?
                            Schreibt er das in den Kalender zurück?
                            Was machen diese beiden neuen Datenpunkte?
                              @virus2k12
                              Virus2K12V Offline
                              Virus2K12V Offline
                              Virus2K12
                              #1386
                              @thomas-braun sagte in Test Adapter TrashSchedule:
                              @virus2k12
                              wenn es dann mal Not ist werde ich es neu aufsetzen, im Moment fehlt mir die Zeit da. Wird eher was für den Winter
                                da_WoodyD Online
                                da_WoodyD Online
                                #1387
                                @virus2k12 dann bist du aber falsch dran mit Smart Home.
                                Das Ding ist in 15 min installiert
                                "Wird eher was für den Winter"
                                Wir haben noch Winter...
                                  Virus2K12V Offline
                                  Virus2K12V Offline
                                  Virus2K12
                                  #1388
                                  @da_woody sagte in Test Adapter TrashSchedule:
                                  Bin z.Z. viel arbeiten, 6 Tage Woche. Heute Abend geht es wieder los bis Samstag früh. Von daher keine Zeit im Moment.
                                    da_WoodyD Online
                                    da_WoodyD Online
                                    #1389
                                    @virus2k12 ist ja OK. Aber in der Zeit die du bis jetzt verschleudert hast, wäre eine Neuinstallation locker gewesen.
                                      australien
                                      #1390
                                      mein System (container in proxmox) ist seit ein paar Tagen ohne mein Zutun verrückt.
                                      Zuerst war CPU 100%, dann Speicher 100%, nach mehrmaligen reboot konnte ich die vermutlichen Sünder finden.
                                      Die Adapter fhem, telegram und vaillant liefern komische Wert oder verstopfen das System.
                                      Der Adapter trashschedule liefert diese Meldung
                                      im dazugehörenden ical ist die richtige ical datei hinterlegt.
                                      im log finde ich nichts dazu
                                      • A australien
                                        haus-automatisierungH Offline
                                        #1391
                                        @australien sagte in Test Adapter TrashSchedule:
                                        Und weiter?
                                        📚 Meine Dokumentation
                                          Und weiter?
                                          australien
                                          #1392
                                          @haus-automatisierung eben nichts weiter, nur das der adapter nicht mit dem Gerät verbunden ist und keine korrekten Werte liefert.
                                          Bis letzte Woche war alles ok.
