  4. ESPHome frage zu Logs
    2.6k
    4.6k
    4.0k
9 Beiträge 2 Kommentatoren 937 Aufrufe 2 Beobachtet
    tourer4778
    Hallo, ich habe vor kurzem mein Iobroker neu aufgesetzt und habe ein update von Esphome gemacht. Vermutlich seit dem, finde ich in den Log´s meiner ESP´s neue Zeilen, mit denen ich nichts anfangen kann.
    Bei einem zum Beispiel :
    [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:96.50.1 [0x454d48]
    [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:96.1.0 [0x0a01454d480000bed575]
    [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:1.8.0 [0x000000000448b783]
    [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:2.8.0 [0x0000000000145b04]
    [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:36.7.0 [0x0000005d]
    [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:56.7.0 [0x00000540]
    [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:76.7.0 [0x000000f1]
    [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:16.7.0 [0x0000068e]
    [05:59:00][W][component:214]: Component sml took a long time for an operation (0.09 s).
    [05:59:00][W][component:215]: Components should block for at most 20-30ms.
    [05:59:01][D][sensor:093]: 'evu_import_180': Sending state 7187.44385 kWh with 4 decimals of accuracy
    [05:59:01][D][sensor:093]: 'evu_export_280': Sending state 133.40199 kWh with 4 decimals of accuracy
    [05:59:01][D][sensor:093]: 'emh_leistung': Sending state 1681.00000 W with 0 decimals of accuracy
    [05:59:01][D][sml:078]: OBIS info:
    [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:96.50.1 [0x454d48]
    [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:96.1.0 [0x0a01454d480000bed575]
    [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:1.8.0 [0x000000000448b788]
    [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:2.8.0 [0x0000000000145b04]
    [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:36.7.0 [0x0000005d]
    [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:56.7.0 [0x00000544]
    [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:76.7.0 [0x000000f0]
    [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:16.7.0 [0x00000691]
    [05:59:01][W][component:214]: Component sml took a long time for an operation (0.09 s).
    [05:59:01][W][component:215]: Components should block for at most 20-30ms.
    [05:59:02][D][sensor:093]: 'evu_import_180': Sending state 7187.44482 kWh with 4 decimals of accuracy
    [05:59:02][D][sensor:093]: 'evu_export_280': Sending state 133.40199 kWh with 4 decimals of accuracy
    [05:59:02][D][sensor:093]: 'emh_leistung': Sending state 1704.00000 W with 0 decimals of accuracy
    [05:59:02][D][sml:078]: OBIS info:
    esphome:
    esp8266:
     board: d1_mini
    wifi:
     ssid: !secret wifi_ssid
     password: !secret wifi_password
    logger:
    api:
    ota:
    web_server:
     port: 80
    status_led:
     pin:
       number: D4
       inverted: true
    uart:
     - id: uart_bus
       tx_pin: D2  # Gelb
       rx_pin: D1  # Weiß
       baud_rate: 9600
       rx_buffer_size: 2048
       data_bits: 8
       stop_bits: 1
       parity: NONE
    sml:
    - id: sml_emh
      uart_id: uart_bus
    sensor:
     - platform: wifi_signal
       name: "WiFi Signal Sensor"
       update_interval: 30s
     - platform: uptime
       update_interval: 10s
     - platform: sml
       sml_id: sml_emh
       obis_code: "1-0:16.7.0"
       filters:
        - multiply: 1
       unit_of_measurement: W
       state_class: measurement
       device_class: power
     - platform: sml
       sml_id: sml_emh
       obis_code: "1-0:1.8.0"
       unit_of_measurement: kWh
       state_class: total_increasing
       device_class: energy
       filters:
        - multiply: 0.0001
       accuracy_decimals: 4
       force_update: true
     - platform: sml
       sml_id: sml_emh
       obis_code: "1-0:2.8.0"
       filters:
        - multiply: 0.0001
       force_update: true
    switch:
    # Restart
     - platform: restart
    Weiß jemand, woran das liegen könnte ?
    • T tourer4778
      esphome:
      esp8266:
       board: d1_mini
      wifi:
      logger:
      api:
      ota:
      web_server:
       port: 80
      status_led:
       pin:
         number: D4
         inverted: true
      uart:
       - id: uart_bus
         tx_pin: D2  # Gelb
         rx_pin: D1  # Weiß
         baud_rate: 9600
         data_bits: 8
         stop_bits: 1
         parity: NONE
      sml:
      - id: sml_emh
        uart_id: uart_bus
      sensor:
       - platform: uptime
       - platform: sml
         sml_id: sml_emh
         filters:
          - multiply: 1
         device_class: power
       - platform: sml
         sml_id: sml_emh
         filters:
          - multiply: 0.0001
         force_update: true
       - platform: sml
         sml_id: sml_emh
         filters:
          - multiply: 0.0001
         force_update: true
      switch:
      # Restart
       - platform: restart
      MCU
      @tourer4778 Man muss den logger level angeben?
      logger:
        level: WARNING
      DEBUG: Detaillierte Debug-Informationen
      INFO: Allgemeine Informationen
      WARNING: Warnungen
      ERROR: Fehler
      logger: -> Standard -> INFO
        tourer4778
        schrieb am zuletzt editiert von tourer4778
        @mcu
        Danke und du bist sicher, diese beiden Zeilen kommen deswegen? Die waren füher nicht da.
        • T tourer4778
          @mcu
          MCU
          @tourer4778 Ich dachte es geht um das ganze LOG. Welche 2 Zeilen sind denn neu?
          • M MCU
            tourer4778
            @mcu
            [20:28:08][W][component:214]: Component sml took a long time for an operation (0.10 s).
            [20:28:08][W][component:215]: Components should block for at most 20-30ms.
            Die ander sind für mich in Ordnung
            • T tourer4778
              @mcu
              MCU
              @tourer4778 Kommunikationsproblem?
              sml Komponente brauchte länger als normal vorgesehen (20-30ms) -> 0.1s
              Hängt also mit dem Energiemesser emh zusammen? Warum? -> keine Ahnung.
              Kommen diese Meldungen denn öfter?
              • M MCU
                tourer4778
                @mcu
                Ja, alle 1 - 2 Sekunden ...
                Wie gesagt, vor dem update war noch alle in Ornung, zumindest ist es mir nicht aufgefallen.
                • T tourer4778
                  @mcu
                  MCU
                  @tourer4778 Kann Dir da leider nicht weiter helfen.
                  Du kannst ja einmal zurückgehen und es überprüfen. Ansonsten in github zum Adapter selbst mal das Anliegen schildern.
                  https://github.com/DrozmotiX/ioBroker.esphome/issues
                  • M MCU
                    tourer4778
                    @mcu
                    Okay, danke für die Hilfe
