  4. InfluxDB - "Fehler" nach iobroker Neustart ?
influxdberrorwarningtimeout
15 Beiträge 4 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • SegwayS Offline
    SegwayS Offline
    Segway
    Als Ergänzung noch den Anfang ab wann es anfängt einfach so:
    2019-03-04 14:15:59.860  - info: influxdb.0 enabled logging of pollenflug.0.images.Erle.image_tomorrow, Alias=false, 2054 points now activated
    2019-03-04 14:15:59.861  - info: influxdb.0 enabled logging of pollenflug.0.images.Erle.image_dayaftertomorrow, Alias=false, 2055 points now activated
    2019-03-04 14:15:59.861  - info: influxdb.0 enabled logging of pollenflug.0.images.Roggen.image_today, Alias=false, 2056 points now activated
    2019-03-04 14:15:59.861  - info: influxdb.0 enabled logging of pollenflug.0.images.Roggen.image_tomorrow, Alias=false, 2057 points now activated
    2019-03-04 14:15:59.862  - info: influxdb.0 enabled logging of pollenflug.0.images.Roggen.image_dayaftertomorrow, Alias=false, 2058 points now activated
    2019-03-04 14:15:59.862  - info: influxdb.0 enabled logging of pollenflug.0.images.Esche.image_today, Alias=false, 2059 points now activated
    2019-03-04 14:15:59.862  - info: influxdb.0 enabled logging of pollenflug.0.images.Esche.image_tomorrow, Alias=false, 2060 points now activated
    2019-03-04 14:15:59.862  - info: influxdb.0 enabled logging of pollenflug.0.images.Esche.image_dayaftertomorrow, Alias=false, 2061 points now activated
    2019-03-04 14:15:59.863  - info: influxdb.0 enabled logging of pollenflug.0.images.Birke.image_today, Alias=false, 2062 points now activated
    2019-03-04 14:15:59.863  - info: influxdb.0 enabled logging of pollenflug.0.images.Birke.image_tomorrow, Alias=false, 2063 points now activated
    2019-03-04 14:15:59.863  - info: influxdb.0 enabled logging of pollenflug.0.images.Birke.image_dayaftertomorrow, Alias=false, 2064 points now activated
    2019-03-04 14:16:12.881  - warn: influxdb.0 Error on writePoint("{"value":"","time":"2019-03-04T13:15:59.986Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
     / "{\"error\":\"timeout\"}\n"
    2019-03-04 14:16:12.882  - info: influxdb.0 Add point that had error for hm-rpc.0.CUX2801001.5.CMD_RETS to buffer again, error-count=1
    2019-03-04 14:16:12.884  - warn: influxdb.0 Error on writePoint("{"value":"","time":"2019-03-04T13:15:59.984Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2019-03-04 14:16:12.885  - info: influxdb.0 Add point that had error for hm-rpc.0.CUX2801001.5.CMD_SETL to buffer again, error-count=1
    2019-03-04 14:16:12.886  - warn: influxdb.0 Error on writePoint("{"value":"","time":"2019-03-04T13:15:59.983Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
    2019-03-04 14:16:12.886  - info: influxdb.0 Add point that had error for hm-rpc.0.CUX2801001.5.CMD_SETS to buffer again, error-count=1
    2019-03-04 14:16:12.887  - warn: influxdb.0 Error on writePoint("{"value":"","time":"2019-03-04T13:15:59.982Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): Error: {"error":"timeout"}
    Gruß Dirk
    • apollon77A Online
      apollon77A Online
      Das heisst das es einen Timeout beim schreiben in die InfluxDB gibt. Wie geht es der DB denn so? Was sagen die influxdb Logs?
      SegwayS 1 Antwort Letzte Antwort
      • apollon77A apollon77
        SegwayS Offline
        SegwayS Offline
        Segway
        @apollon77 sagte in InfluxDB - "Fehler" nach iobroker Neustart ?:
        Tja, das versuche ich gerade im Influx Forum rauszubekommen, da in den Standardverzeichnissen KEINE Logs erzeugt werden. Ist das standardmäßig deaktiviert ?
        Da versuche ich mich gerade einzuarbeiten.
        Gruß Dirk
        • apollon77A Online
          apollon77A Online
          Bei mir landet das in /var/log/syslog
            SegwayS Offline
            SegwayS Offline
            Segway
            Also jetzt brat mir doch einer nen Hirsch ! Ich fass es nicht.
            Logs sind unauffällig, kann nicht erkennen dass da was schief läuft (@apollon77 Danke nochmal für den Tip der Logs👍 ).
            Okay dachte ich mir, was mache ich nun 🤔 🤔 🤔
            Okay dachte ich, lass die Influx nochmal starten und das Log vollschreiben, vielleicht habe ich ja etwas übersehen.
            Gesagt getan und siehe da.....keine Fehler mehr 🙄 🙄 🙄
            Das soll einer verstehen ?
            Ich lass es mal laufen, so ganz trau ich dem Braten noch nicht
            Gruß Dirk
            • apollon77A Online
              apollon77A Online
              Welche Version hast Du drauf? Es gab vor kurzem eine die kaputt war und auch bei mit gecrasht ist. Also unbedingt auf das aktuellste gehen!!
                SegwayS Offline
                SegwayS Offline
                Segway
                @apollon77
                bei mir läuft die 1.7.4
                Gruß Dirk
                blue231181B 1 Antwort Letzte Antwort
                • apollon77A Online
                  apollon77A Online
                  Dann ist das schonmal nicht die "böse" (die war glaube ich die 1.7.3)
                  • SegwayS Segway
                    @apollon77
                    blue231181B Offline
                    blue231181B Offline
                    blue231181
                    @segway Ich habe aktuell den selben Fehler. Was war deine Lösung?
                    Viele Grüße
                    W 1 Antwort Letzte Antwort
                    • blue231181B blue231181
                      Viele Grüße
                      W Offline
                      W Offline
                      Wildbill
                      @blue231181 Ich glaube nicht, dass ein fünf Jahre alter Thread noch zur Lösungsfindung beiträgt. Mach am Besten einen eigenen auf und beschreibe das Problem so genau es geht.
                      Gruss, Jürgen
                      • W Wildbill
                        Gruss, Jürgen
                        apollon77A Online
                        apollon77A Online
                        @wildbill "Timeout" bedeutet immer: schau ins influxdb log was da los ist. Der Adapte rbekommt dsann keine Antwort von der influxdb
                          W Offline
                          W Offline
                          Wildbill
                          @apollon77 Das wolltest Du vermutlich an @blue231181 richten?
                          Gruss, Jürgen
                          apollon77A blue231181B 2 Antworten Letzte Antwort
                          • W Wildbill
                            Gruss, Jürgen
                            apollon77A Online
                            apollon77A Online
                            @wildbill joo :-)
                            • W Wildbill
                              Gruss, Jürgen
                              blue231181B Offline
                              blue231181B Offline
                              blue231181
                              @wildbill das habe ich :) hier kam bisher leider wenig Resonanz.
                              https://forum.iobroker.net/topic/73007/influxdb-adapter-4-0-2-timeout
                              Nur habe ich gesehen das @Segway dasselbe Thema hatte
                              @apollon77 Danke, dann versuche ich das weiter
