  3. Einsteigerfragen
  4. nach Update vom js-controler nicht mehr erreichbar
    5.5k
36 Beiträge 5 Kommentatoren 3.9k Aufrufe 5 Beobachtet
  • U Uwe96
    @codierknecht
    Habe jetzt das 9.1.1. Image genommen mit den alten Einstellungen.
    Keine Änderung. Adapter habe ich alle aktualisiert. Nur dieser geht halt nicht.
    @uwe96
    Meldungen im Log?
    U 1 Antwort Letzte Antwort
      @uwe96
      Meldungen im Log?
      U Offline
      U Offline
      Uwe96
      2024/02/20 15:07:03	stdout	Send diag info: {"uuid":"361d7d7d-5e33-4be3-9570-1d9ca75bd8f9","language":"de","country":"","hosts":[{"version":"4.0.23","platform":"Javascript/Node.js","type":"linux"}],"node":"v18.19.0","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.13.16","platform":"Javascript/Node.js"},"backitup":{"version":"2.9.8","platform":"Javascript/Node.js"},"discovery":{"version":"4.2.0","platform":"Javascript/Node.js"},"sonoff":{"version":"3.0.3","platform":"Javascript/Node.js"},"web":{"version":"6.2.3","platform":"Javascript/Node.js"},"vis":{"version":"1.5.4","platform":"Javascript/Node.js"},"shelly":{"version":"6.6.1","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-canvas-gauges":{"version":"1.0.1","platform":"Javascript/Node.js"},"vis-colorpicker":{"version":"2.0.3","platform":"Javascript/Node.js"},"vis-fancyswitch":{"version":"1.1.0","platform":"Javascript/Node.js"},"vis-history":{"version":"1.0.0","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.4.0","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.3","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-justgage":{"version":"2.1.0","platform":"Javascript/Node.js"},"vis-keyboard":{"version":"0.0.2","platform":"Javascript/Node.js"},"vis-lcars":{"version":"1.1.1","platform":"Javascript/Node.js"},"vis-map":{"version":"1.0.4","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.2.0","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7.4","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.2.0","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.2.2","platform":"Javascript/Node.js"},"material":{"version":"1.3.1","platform":"Javascript/Node.js"},"fullcalendar":{"version":"2.3.4","platform":"Javascript/Node.js"},"mqtt":{"version":"5.2.0","platform":"Javascript/Node.js"},"history":{"version":"3.0.1","platform":"Javascript/Node.js"},"flot":{"version":"1.12.0","platform":"Javascript/Node.js"},"vis-rgraph":{"version":"0.0.2","platform":"Javascript/Node.js"},"parser":{"version":"2.1.0","platform":"Javascript/Node.js"},"evcc":{"version":"0.1.1","platform":"Javascript/Node.js"},"systeminfo":{"version":"1.1.0","platform":"Javascript/Node.js"},"psa":{"version":"0.0.11","platform":"Javascript/Node.js"},"modbus":{"version":"6.1.0","platform":"Javascript/Node.js"},"javascript":{"version":"7.8.0","platform":"Javascript/Node.js"},"influxdb":{"version":"4.0.2","platform":"Javascript/Node.js"},"solaredge":{"version":"0.2.0","platform":"Javascript/Node.js"},"solarlog":{"version":"2.2.8","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"jarvis":{"version":"3.1.8","platform":"Javascript/Node.js"},"socketio":{"version":"6.6.0","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":41,"compactMode":false,"noCompactInstances":0,"model":"AMD Ryzen Embedded V1500B","cpus":8,"mem":20946313216,"ostype":"Linux","city":"","vis":794}
      2024/02/20 15:07:02	stdout	================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.solaredge.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.psa.1" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.systeminfo.1" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.evcc.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.parser.1" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.parser.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.fullcalendar.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.material.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-timeandweather.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-metro.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-material-advanced.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-map.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-lcars.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-keyboard.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-justgage.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-jqui-mfd.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-inventwo.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-hqwidgets.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-history.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-fancyswitch.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-colorpicker.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-canvas-gauges.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis-bars.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.vis.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.web.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.discovery.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.backitup.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.mqtt.1" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.modbus.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.mqtt.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.shelly.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.sonoff.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.influxdb.2" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.influxdb.1" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.influxdb.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.javascript.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.history.1" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.history.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:03	stdout	host.buanet-iobroker-1 check instance "system.adapter.admin.0" for host "buanet-iobroker-1"
      2024/02/20 15:05:01	stdout	##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
      2024/02/20 15:05:01	stdout	Starting ioBroker...
      2024/02/20 15:05:01	stdout	--------------------------------------------------------------------------------
      2024/02/20 15:05:01	stdout	-----                    Step 5 of 5: ioBroker Startup                     -----
      2024/02/20 15:05:01	stdout	For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs/).
      2024/02/20 15:05:01	stdout	Some adapters have special requirements/ settings which can be activated by the use of environment variables.
      2024/02/20 15:05:01	stdout	-----                Step 4 of 5: Applying Special Settings                -----
      2024/02/20 15:05:01	stdout	No action required.
      2024/02/20 15:05:01	stdout	Hostname in ioBroker matches the hostname of this container.
      2024/02/20 15:04:36	stdout
      2024/02/20 15:04:36	stdout	Checking database connection... Done.
      2024/02/20 15:04:24	stdout
      2024/02/20 15:04:22	stdout	(Re)setting permissions (This might take a while! Please be patient!)... Done.
      2024/02/20 15:04:21	stdout
      2024/02/20 15:04:21	stdout	--------------------------------------------------------------------------------
      2024/02/20 15:04:21	stdout	-----             Step 3 of 5: Checking ioBroker Installation              -----
      2024/02/20 15:04:20	stdout	Existing installation of ioBroker detected in "/opt/iobroker".
      2024/02/20 15:04:19	stdout
      2024/02/20 15:04:19	stdout	--------------------------------------------------------------------------------
      2024/02/20 15:04:19	stdout	-----             Step 2 of 5: Detecting ioBroker Installation             -----
      2024/02/20 15:04:19	stdout	Changing UID to "1023" and GID to "100"... Done.
      2024/02/20 15:04:18	stdout	SETUID and/ or SETGID are set to custom values.
      2024/02/20 15:04:18	stdout	--------------------------------------------------------------------------------
      2024/02/20 15:04:18	stdout	-----                   Step 1 of 5: Preparing Container                   -----
      2024/02/20 15:04:18	stdout	-----                    SETUID:              1023                         -----
      2024/02/20 15:04:18	stdout	-----                    SETGID:              100                          -----
      2024/02/20 15:04:18	stdout	-----                        Environment Variables                         -----
      2024/02/20 15:04:18	stdout	-----        -----
      2024/02/20 15:04:18	stdout	-----                    npm:                 10.2.3                       -----
      2024/02/20 15:04:17	stdout	-----                    node:                v18.19.0                     -----
      2024/02/20 15:04:17	stdout	-----                    build:               2024-02-13T23:44:30+00:00    -----
      2024/02/20 15:04:17	stdout	-----                    image:               v9.1.1                       -----
      2024/02/20 15:04:17	stdout	-----                          Version Information                         -----
      2024/02/20 15:04:17	stdout	-----        -----
      2024/02/20 15:04:17	stdout	-----                    hostname:            buanet-iobroker-1            -----
      2024/02/20 15:04:17	stdout	-----                    arch:                x86_64                       -----
      2024/02/20 15:04:17	stdout	-----                          System Information                          -----
      2024/02/20 15:04:17	stdout	--------------------------------------------------------------------------------
      2024/02/20 15:04:17	stdout	-----                          Please be patient!                          -----
      2024/02/20 15:04:17	stdout	-----                    Startupscript is now running!                     -----
      2024/02/20 15:04:17	stdout	-----              Welcome to your ioBroker Docker container!              -----
      2024/02/20 15:04:17	stdout	----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
      2024/02/20 15:04:17	stdout	----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
      2024/02/20 15:04:17	stdout	----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
      2024/02/20 15:04:17	stdout	----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
      2024/02/20 15:04:17	stdout	----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
      2024/02/20 15:04:17	stdout	----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
      2024/02/20 15:04:17	stdout	-------------------------     2024-02-20 15:04:17      -------------------------
      • U Uwe96
        @uwe96
        In CodeTags...
        iob update
        iob stop
        iob upgrade self
        sagt? (Wenn das unter Docker so funktioniert, heißt das).
          @uwe96
          In CodeTags...
          iob update
          iob stop
          iob upgrade self
          U Offline
          U Offline
          Uwe96
          schrieb am zuletzt editiert von Uwe96
          Wenn ich das mache wird der Ordner Lib gelöscht und es geht nichts mehr. Wie ganz oben geschrieben
          • U Uwe96
            Ich möchte gerne den js-controler updaten. Mach das im Terminal so:
            pkill -u iobroker
            iobroker update
            iobroker upgrade self
            Scheint auch alles zu funktionieren.
            Dann iobroker stoppen und wieder starten. Danach ist iobroker nicht mehr zu erreichen. Im Protokoll steht folgender Fehler:
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
            Es gibt keinen lib Ordner mehr in iobroker/node_modules/iobroker.js-controller
            Jemand einen Tipp was ich falsch mache?
            GlasfaserG Offline
            GlasfaserG Offline
            @uwe96 sagte in nach Update vom js-controler nicht mehr erreichbar:
            pkill -u iobroker
            iobroker update
            falsch , den Container danach neu starten .
            Zeige mal bitte die ganze Logausgabe dazu ... nicht so ein Schnipsel !
            • U Uwe96
              Ok, habe es in eine Datei geleitet. Das kam dabei raus:
              Ist aber von der funktionierenden Version mit altem js-controler
              The ioBroker diag script is not specifically designed to run in Docker.
              Although it is generally safe to use, use it at your own risk.
              *** iob diag is starting up, please wait ***
              *** ioBroker Diagnosis ***
              Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
              The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
              https://forum.iobroker.net
              Just copy and paste the Summary Page, including the ``` characters at start and end.
              It helps us to help you!
              Press any key to continue
              Skript v.2023-10-10
              *** BASE SYSTEM ***
              Hardware Vendor : Synology Inc.
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v9.1.1
              Virtualization  : Docker
              Kernel          : x86_64
              Userland        : amd64
              Systemuptime and Load:
               14:14:49 up 8 days, 19:52,  0 user,  load average: 0.59, 0.68, 0.57
              CPU threads: 8
              *** Time and Time Zones ***
              Tue Feb 20 13:14:49 UTC 2024
              Tue Feb 20 14:14:49 CET 2024
              CET +0100
              Etc/UTC
              *** User and Groups ***
              root
              /root
              root
              *** X-Server-Setup ***
              X-Server: 	false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:             20G        4.6G        553M         54M         16G         16G
              Swap:            14G        1.8G         12G
              Total:           35G        6.4G         13G
                      19975 M total memory
                       4389 M used memory
                       7771 M active memory
                       8582 M inactive memory
                        527 M free memory
                        232 M buffer memory
                      15216 M swap cache
                      14035 M total swap
                       1756 M used swap
                      12279 M free swap
              *** FILESYSTEM ***
              Filesystem             Type   Size  Used Avail Use% Mounted on
              /dev/mapper/cachedev_0 btrfs   58T   42T   16T  73% /
              tmpfs                  tmpfs   64M     0   64M   0% /dev
              tmpfs                  tmpfs  9.8G     0  9.8G   0% /sys/fs/cgroup
              shm                    tmpfs   64M     0   64M   0% /dev/shm
              /dev/mapper/cachedev_0 btrfs   58T   42T   16T  73% /opt/iobroker
              /dev/mapper/cachedev_0 btrfs   58T   42T   16T  73% /etc/hosts
              tmpfs                  tmpfs  9.8G     0  9.8G   0% /proc/acpi
              tmpfs                  tmpfs  9.8G     0  9.8G   0% /proc/scsi
              tmpfs                  tmpfs  9.8G     0  9.8G   0% /sys/firmware
              TARGET             SOURCE        FSTYPE OPTIONS
              /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/a682a01588dee8edaddf8e33b44f58a147196fd9e4c4fc00ba4aa36d921d56e6]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=4258,subvol=/@syno/@docker/btrfs/subvolumes/a682a01588dee8edaddf8e33b44f58a147196fd9e4c4fc00ba4aa36d921d56e6
              |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker
              |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/7b6159f2c6712fb3b960a742c03a2c8e65139dac4cd0baa2d2844670e0687f1f/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
              |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/7b6159f2c6712fb3b960a742c03a2c8e65139dac4cd0baa2d2844670e0687f1f/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
              `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/7b6159f2c6712fb3b960a742c03a2c8e65139dac4cd0baa2d2844670e0687f1f/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
              /var:
              34M	/var/
              32M	/var/lib
              19M	/var/lib/apt/lists
              19M	/var/lib/apt
              13M	/var/lib/dpkg
              /opt/iobroker/backups:
              141M	/opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              547M	/opt/iobroker/iobroker-data/
              222M	/opt/iobroker/iobroker-data/history
              198M	/opt/iobroker/iobroker-data/files
              64M	/opt/iobroker/iobroker-data/backup-objects
              46M	/opt/iobroker/iobroker-data/files/javascript.admin
              52M	/opt/iobroker/iobroker-data/objects.jsonl
              24M	/opt/iobroker/iobroker-data/files/material/static/js/2.a95ea65c.chunk.js.map
              12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/12.1aeaa68b.chunk.js.map
              8.5M	/opt/iobroker/iobroker-data/files/vis.0/Uwe/vis-views.json
              8.5M	/opt/iobroker/iobroker-data/files/vis.0/Uwe/1573146318965-2019-11-06-vis/vis-views.json
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs 	v18.19.0
              /usr/bin/node 		v18.19.0
              /usr/bin/npm 		10.2.3
              /usr/bin/npx 		10.2.3
              /usr/bin/corepack 	0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.1-1nodesource1
                Version table:
                   18.19.1-1nodesource1 1001
                     1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                   18.19.0+dfsg-6~deb12u1 500
                      500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
               *** 18.19.0-1nodesource1 1001
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0+dfsg1-1 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller: 	4.0.23
              admin: 		5.3.8
              javascript: 	6.0.0
              Adapters from github: 	3
              Adapter State
              + system.adapter.admin.0                  : admin                 : buanet-iobroker-1                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : buanet-iobroker-1                        -  enabled
              + system.adapter.discovery.0              : discovery             : buanet-iobroker-1                        -  enabled
              + system.adapter.evcc.0                   : evcc                  : buanet-iobroker-1                        -  enabled
                system.adapter.flot.0                   : flot                  : buanet-iobroker-1                        -  enabled
              + system.adapter.fullcalendar.0           : fullcalendar          : buanet-iobroker-1                        -  enabled
              + system.adapter.history.0                : history               : buanet-iobroker-1                        -  enabled
              + system.adapter.history.1                : history               : buanet-iobroker-1                        -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : buanet-iobroker-1                        -  enabled
                system.adapter.influxdb.0               : influxdb              : buanet-iobroker-1                        -  enabled, port: 8086
                system.adapter.influxdb.1               : influxdb              : buanet-iobroker-1                        -  enabled, port: 9086
                system.adapter.influxdb.2               : influxdb              : buanet-iobroker-1                        -  enabled, port: 8086
              + system.adapter.javascript.0             : javascript            : buanet-iobroker-1                        -  enabled
                system.adapter.material.0               : material              : buanet-iobroker-1                        -  enabled
              + system.adapter.modbus.0                 : modbus                : buanet-iobroker-1                        -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : buanet-iobroker-1                        -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.mqtt.1                   : mqtt                  : buanet-iobroker-1                        -  enabled, port: 1886, bind: 0.0.0.0
                system.adapter.parser.0                 : parser                : buanet-iobroker-1                        - disabled
                system.adapter.parser.1                 : parser                : buanet-iobroker-1                        - disabled
              + system.adapter.psa.1                    : psa                   : buanet-iobroker-1                        -  enabled
                system.adapter.shelly.0                 : shelly                : buanet-iobroker-1                        -  enabled, port: 1885, bind: 0.0.0.0
                system.adapter.solaredge.0              : solaredge             : buanet-iobroker-1                        -  enabled
              + system.adapter.sonoff.0                 : sonoff                : buanet-iobroker-1                        -  enabled, port: 1884, bind: 0.0.0.0
                system.adapter.systeminfo.1             : systeminfo            : buanet-iobroker-1                        -  enabled
                system.adapter.vis-bars.0               : vis-bars              : buanet-iobroker-1                        -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : buanet-iobroker-1                        -  enabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : buanet-iobroker-1                        -  enabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : buanet-iobroker-1                        -  enabled
                system.adapter.vis-history.0            : vis-history           : buanet-iobroker-1                        -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : buanet-iobroker-1                        -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : buanet-iobroker-1                        -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : buanet-iobroker-1                        -  enabled
                system.adapter.vis-justgage.0           : vis-justgage          : buanet-iobroker-1                        -  enabled
                system.adapter.vis-keyboard.0           : vis-keyboard          : buanet-iobroker-1                        -  enabled
                system.adapter.vis-lcars.0              : vis-lcars             : buanet-iobroker-1                        -  enabled
                system.adapter.vis-map.0                : vis-map               : buanet-iobroker-1                        -  enabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : buanet-iobroker-1                        -  enabled
                system.adapter.vis-metro.0              : vis-metro             : buanet-iobroker-1                        -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : buanet-iobroker-1                        -  enabled
                system.adapter.vis.0                    : vis                   : buanet-iobroker-1                        -  enabled
              + system.adapter.web.0                    : web                   : buanet-iobroker-1                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.13.16  , installed 5.3.8  [Updatable]
              Adapter    "backitup"     : 2.9.8    , installed 2.2.2  [Updatable]
              Adapter    "discovery"    : 4.2.0    , installed 2.7.0  [Updatable]
              Adapter    "evcc"         : 0.1.1    , installed 0.0.3  [Updatable]
              Adapter    "flot"         : 1.12.0   , installed 1.10.7 [Updatable]
              Adapter    "fullcalendar" : 2.3.4    , installed 1.1.0  [Updatable]
              Adapter    "history"      : 3.0.1    , installed 1.9.13 [Updatable]
              Adapter    "icons-mfd-svg": 1.2.0    , installed 1.0.2  [Updatable]
              Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
              Adapter    "jarvis"       : 3.1.8    , installed 2.2.1  [Updatable]
              Adapter    "javascript"   : 7.8.0    , installed 6.0.0  [Updatable]
              Controller "js-controller": 5.0.19   , installed 4.0.23 [Updatable]
              Adapter    "material"     : 1.3.1    , installed 1.0.4  [Updatable]
              Adapter    "modbus"       : 6.1.0    , installed 5.0.4  [Updatable]
              Adapter    "mqtt"         : 5.2.0    , installed 2.4.0  [Updatable]
              Adapter    "parser"       : 2.1.0    , installed 1.1.5  [Updatable]
              Adapter    "psa"          : 0.0.11   , installed 0.0.11
              Adapter    "shelly"       : 6.6.1    , installed 4.0.7  [Updatable]
              Adapter    "simple-api"   : 2.7.2    , installed 2.6.2  [Updatable]
              Adapter    "socketio"     : 6.6.0    , installed 3.1.5  [Updatable]
              Adapter    "solaredge"    : 1.2.2    , installed 0.2.0  [Updatable]
              Adapter    "solarlog"     : 2.2.8    , installed 2.2.8
              Adapter    "sonoff"       : 3.0.3    , installed 2.4.5  [Updatable]
              Adapter    "systeminfo"   : 1.1.0    , installed 0.3.1  [Updatable]
              Adapter    "vis"          : 1.5.4    , installed 1.4.5  [Updatable]
              Adapter    "vis-canvas-gauges": 1.0.1, installed 0.1.5  [Updatable]
              Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
              Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.7  [Updatable]
              Adapter    "vis-inventwo" : 3.3.3    , installed 3.2.0  [Updatable]
              Adapter    "vis-justgage" : 2.1.0    , installed 1.0.2  [Updatable]
              Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
              Adapter    "vis-lcars"    : 1.1.1    , installed 1.0.4  [Updatable]
              Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
              Adapter    "vis-material-advanced": 1.7.4, installed 1.7.2 [Updatable]
              Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
              Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
              Adapter    "web"          : 6.2.3    , installed 3.4.9  [Updatable]
              Objects and States
              Objects: 	2253
              States: 	1914
              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 1
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1028       104890823  -
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1028       104893074  -
              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1028       104885792  -
              tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1028       104885917  -
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1028       104890830  -
              tcp6       0      0 :::8081                 :::*                    LISTEN      1028       104890094  -
              tcp6       0      0 :::8082                 :::*                    LISTEN      1028       104901935  -
              2024-02-20 14:03:39.820  - info: web.0 (1301) ==>Connected system.user.admin from ::ffff:172.17.0.1
              2024-02-20 14:03:39.896  - info: web.0 (1301) <==Disconnect system.user.admin from ::ffff:172.17.0.1 vis.0
              2024-02-20 14:03:40.822  - warn: web.0 (1301) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
              2024-02-20 14:03:43.774  - info: web.0 (1301) ==>Connected system.user.admin from ::ffff:172.17.0.1
              2024-02-20 14:03:44.776  - warn: web.0 (1301) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
              2024-02-20 14:06:20.003  - info: web.0 (1301) <==Disconnect system.user.admin from ::ffff:172.17.0.1 vis.0
              2024-02-20 14:06:21.005  - warn: web.0 (1301) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
              2024-02-20 14:06:42.085  - info: web.0 (1301) ==>Connected system.user.admin from ::ffff:172.17.0.1
              2024-02-20 14:06:43.087  - warn: web.0 (1301) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
              2024-02-20 14:09:13.490  - info: web.0 (1301) <==Disconnect system.user.admin from ::ffff:172.17.0.1 vis.0
              2024-02-20 14:09:14.491  - warn: web.0 (1301) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
              2024-02-20 14:09:43.681  - info: web.0 (1301) ==>Connected system.user.admin from ::ffff:172.17.0.1
              2024-02-20 14:09:43.779  - info: web.0 (1301) <==Disconnect system.user.admin from ::ffff:172.17.0.1 vis.0
              2024-02-20 14:09:44.683  - warn: web.0 (1301) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
              2024-02-20 14:10:11.905  - info: web.0 (1301) ==>Connected system.user.admin from ::ffff:172.17.0.1
              2024-02-20 14:10:12.907  - warn: web.0 (1301) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
              2024-02-20 14:12:43.968  - info: web.0 (1301) <==Disconnect system.user.admin from ::ffff:172.17.0.1 vis.0
              2024-02-20 14:12:44.970  - warn: web.0 (1301) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
              2024-02-20 14:13:14.802  - info: web.0 (1301) ==>Connected system.user.admin from ::ffff:172.17.0.1
              2024-02-20 14:13:14.910  - info: web.0 (1301) <==Disconnect system.user.admin from ::ffff:172.17.0.1 vis.0
              2024-02-20 14:13:15.803  - warn: web.0 (1301) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
              2024-02-20 14:13:29.340  - info: web.0 (1301) ==>Connected system.user.admin from ::ffff:172.17.0.1
              2024-02-20 14:13:30.342  - warn: web.0 (1301) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
              2024-02-20 14:15:00.023  - info: host.buanet-iobroker-1 instance system.adapter.solaredge.0 started with pid 13532
              2024-02-20 14:15:00.416  - error: host.buanet-iobroker-1 instance system.adapter.solaredge.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              iob diag has finished.
              Press any key for a summary
              GlasfaserG Offline
              GlasfaserG Offline
              gehe mal zuerst auf 4.0.24
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
              dann später mit
              pkill -u iobroker
              iobroker update
              CodierknechtC U 2 Antworten Letzte Antwort
              • GlasfaserG Glasfaser
                cd /opt/iobroker
                dann später mit
                pkill -u iobroker
                iobroker update
                CodierknechtC Online
                Codierknecht
                @glasfaser
                Sehe ich das richtig, dass der neue Container bei vorhandenen Daten auch die (eigentlich neue) Version des JS-Controllers wieder überklatscht?
                Das wäre - naja, sagen wir mal "suboptimal" 🤔
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                • CodierknechtC Codierknecht
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @codierknecht sagte in nach Update vom js-controler nicht mehr erreichbar:
                  ja , das siehst du so richtig ,
                  ist im Sinne kein Backup ( würde ioBroker sonst schon meckern beim neuen Image mit JS- 5) , sondern wie du schon schreibst die vorhandenen Daten im gemounten Ordner ... werden genutzt , wie bei Ihm 4.0.23 !
                  Wäre genauso mit einem Backup was alte Adapterstände beinhaltet , da gibt es bei js-controller auch keine ausnahme.
                  CodierknechtC ubeckerU 2 Antworten Letzte Antwort
                    Codierknecht
                    @glasfaser sagte in nach Update vom js-controler nicht mehr erreichbar:
                    Na dann kann er ja neue Container erzeugen bis er schwarz wird :-(
                    <Hier stand Quatsch>
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Es werden ja auch die neuesten Versionen der Adapter installiert und nur deren Daten übernommen.
                      ? Mhh ...
                      es wird doch nur das Image erneuert ... ( + Nodejs)
                      alle vorhandenen Adapterstände behalten den Stand X zum Zeitpunkt , warum sollen sie dann Automatich bei einem Image Wechsel auf den neusten Stand gebracht werden .
                        GlasfaserG Offline
                        GlasfaserG Offline
                          ubeckerU Offline
                          ubeckerU Offline
                          ubecker
                          @glasfaser
                          ist so, bin zwar noch nicht lange dabei, aber das Thema war schon oft.
                          Der neue JS-Controller wird nur in ein neues leeres Verzeichnis installiert. Ist ein Datenverzeichnis vorhanden wird der JS nicht mit aktualisiert.
                          siehe auch hier
                          Zitas:
                          1. Erstellen eines neuen Backups
                          2. Erstellen eines neuen, leeren Verzeichnisses für die ioBroker Daten auf dem Host
                          3. Kopieren der letzten Backup-Datei in das neue Verzeichnis
                          4. Stoppen und Löschen des alten Containers
                            5 Erstellen eines neuen Containers aus dem aktuellsten Image mit der selben Konfiguration wie zuvor, aber mit dem neuen Verzeichnis als ioBroker Datenverzeichnis
                          5. Beobachten des Container Logs beim Start des neuen Containers bis ioBroker gestartet wurde
                          6. Wiederherstellen des Backups über die Kommandozeile oder den ioBroker.backitup Adapter
                          7. Überprüfen der Installation der Adapter nach erfolgreicher Wiederherstellung
                          Gruß Udo
                          • ubeckerU ubecker
                            @glasfaser
                            siehe auch hier
                            Zitas:
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @ubecker sagte in nach Update vom js-controler nicht mehr erreichbar:
                            @glasfaser
                            ist so,
                            Ja ... das weiß ich , deshalb habe ich es auch so oben geschrieben !
                              Wie soll das gehen?
                              Wie soll was gehen?
                              Einen Container muss man nicht selbst updaten, wenn das der Maintainer regelmäßig macht.
                              Und bei den Images von buanet kannst Du eigentlich immer mit aktuellen Updates rechnen.
                              Du hast ein externes Verzeichnis auf der Synology auf /opt/iobroker/ des Containers gemappt?
                              Dann ist ein Update eigentlich trivial:
                              • Container stoppen (und umbenennen oder löschen)
                                Vorher die Adapter auf möglichst aktuellen Stand bringen
                              • aktuelle Version des Image holen
                                Nicht unbedingt "latest", sondern eine aktuelle stable-Version
                              • neuen Container mit identischen Einstellungen erzeugen und starten
                              • warten ... warten ... voilá
                              ubeckerU Offline
                              ubeckerU Offline
                              ubecker
                              schrieb am zuletzt editiert von ubecker
                              @codierknecht said in nach Update vom js-controler nicht mehr erreichbar:
                              nicht ganz, wenn man das liest bleibt das alte Datenverzeichnis erhalten. Dann wir kein neuer JS installiert.
                              Deshalb mach ich das immer so
                              Container stoppen. gemaptes Verzeichnis umbenennen, (damit hab ich immer noch den alten Stand)
                              neues Verzeichnis wie vorher anlegen
                              Container löschen
                              neuen Container erstellen.
                              Backup rein und gut ist.
                              Gruß Udo
                              • ubeckerU ubecker
                                Container löschen
                                GlasfaserG Offline
                                GlasfaserG Offline
                                nicht ganz,
                                Alles gut ... @Codierknecht hat es schon verstanden !
                                Einmal reicht ;)
                                ubeckerU 1 Antwort Letzte Antwort
                                  nicht ganz,
                                  Einmal reicht ;)
                                  ubeckerU Offline
                                  ubeckerU Offline
                                  ubecker
                                  @glasfaser
                                  das er das weiss ist mir klar, aber Uwe96 wohl nicht.
                                  Gruß Udo
                                  • ubeckerU ubecker
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    du hast @Codierknecht angesprochen ... aber Egal ...
                                    • CodierknechtC Online
                                      Codierknecht
                                      Ja ... das weiß ich
                                      Ich jetzt auch.
                                      Werde mir das mal endlich hinter die Ohren schreiben.
                                      Im "Normalfall" funzt meine einfache Vorgehensweise ja. Also wenn man seine Installation aktuell gehalten hat.
                                      Bei einem Update-Stau (oder wenn selbiges nicht funktioniert) muss die von @ubecker beschriebene - etwas aufwändigere - Vorgehensweise verwendet werden.
                                      @Uwe96 Sorry dass ich Dich da zunächst auf die falsche Fährte geschickt habe.
                                        Ja ... das weiß ich
                                        Ich jetzt auch.
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Geht im Moment nicht , da er mit JS 4 Probleme hat bzw. mit seinem Container / Mount !
                                        Bei einem neuen Image mit JS 5 und einem Backup mit JS 4 was er nur hat , muß er erst die 5 auf 4 bringen im neuen Image , dann kann erst das Backup eingespielt werden !
                                          Codierknecht
                                          Bei einem neuen Image mit JS 5 und einem Backup mit JS 4 was er nur hat , muß er erst die 5 auf 4 bringen im neuen Image , dan kann erst das Backup eingespielt werden !
                                          Stimmt auch wieder.
                                          War ich auch schon mal drauf reingefallen.
