  3. Einsteigerfragen
  4. Installation
  5. [gelöst] Upgrade einer vernachlässigten ioBroker Inst.
node.js16update node jsupdate upgrade iobroker
26 Beiträge 5 Kommentatoren 2.6k Aufrufe 4 Beobachtet
  • C CoComp
    erledigt, hier das Ergebnis
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.61-v7+
          Architecture: arm
    Model           : Raspberry Pi 2 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     19:54:40 up  3:38,  1 user,  load average: 2.18, 1.94, 1.00
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2024-02-14 19:54:41 CET
               Universal time: Wed 2024-02-14 18:54:41 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            922M        494M        189M        0.0K        238M        419M
    Swap:            99M         10M         89M
    Total:          1.0G        505M        278M
              922 M total memory
              495 M used memory
              132 M active memory
              501 M inactive memory
              188 M free memory
               65 M buffer memory
              172 M swap cache
               99 M total swap
               10 M used swap
               89 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  3.1G   25G  11% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     462M     0  462M   0% /dev/shm
    tmpfs          tmpfs     185M  948K  184M   1% /run
    /dev/mmcblk0p1 vfat      255M   50M  206M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    [Wed Feb 14 16:16:39 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=6bc33173-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Feb 14 16:16:43 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Wed Feb 14 16:16:43 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Feb 14 16:16:47 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    [Wed Feb 14 16:16:53 2024] EXT4-fs (mmcblk0p2): resizing filesystem from 1873920 to 7725184 blocks
    [Wed Feb 14 16:16:54 2024] EXT4-fs (mmcblk0p2): resized filesystem to 7725184
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1014M   /var/
    682M    /var/log
    681M    /var/log/journal/21286045b254429896948513200b4631
    139M    /var/cache
    Archived and active journals take up 680.1M in the file system.
    /opt/iobroker/backups:
    38M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    68M     /opt/iobroker/iobroker-data/
    37M     /opt/iobroker/iobroker-data/backup-objects
    24M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.7M    /opt/iobroker/iobroker-data/objects.jsonl
    6.5M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.92002ca6.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.7M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.92002ca6.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A103R2XZ-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_383ea6098193eb1196abdcc77d11dc1e-if00-port0
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node           v16.18.0
    /usr/bin/npm            8.19.2
    /usr/bin/npx            8.19.2
    /usr/bin/corepack       0.14.1
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.18.0-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
     *** 16.18.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.2.23
    javascript:     "javascript" not found
    Adapters from github:   1
    Adapter State
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.jeelink.0                : jeelink               : raspberrypi                              -  enabled
    + system.adapter.loxone.0                 : loxone                : raspberrypi                              -  enabled, port: 80
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.plenticore.0             : plenticore            : raspberrypi                              -  enabled, port: 443
    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.2.23 [Updatable]
    Adapter    "backitup"     : 2.9.8    , installed 2.6.19 [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.0.5  [Updatable]
    Adapter    "influxdb"     : 4.0.2    , installed 3.1.8  [Updatable]
    Adapter    "jeelink"      : 1.2.3    , installed 1.0.3  [Updatable]
    Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
    Adapter    "loxone"       : 3.0.1    , installed 3.0.1
    Adapter    "modbus"       : 6.1.0    , installed 5.0.5  [Updatable]
    Adapter    "node-red"     : 5.1.0    , installed 4.0.0  [Updatable]
    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.3.4  [Updatable]
    Objects and States
    Objects:        2437
    States:         1741
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 140
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       30108      3008/node-red
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28454      2933/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       28461      2933/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12386      474/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       28998      2951/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          10113      474/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11429      308/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12429      561/dhcpcd
    udp        0      0 0.0.0.0:45188           0.0.0.0:*                           108        11431      308/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        11430      308/avahi-daemon: r
    udp6       0      0 :::42642                :::*                                108        11432      308/avahi-daemon: r
    2024-02-14 19:57:04.613  - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-02-14 19:57:06.755  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 3456
    2024-02-14 19:57:11.299  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2024-02-14 19:57:11.540  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 send kill signal
    2024-02-14 19:57:12.091  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2024-02-14 19:57:12.168  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 send kill signal
    2024-02-14 19:57:12.641  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2024-02-14 19:57:12.706  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 send kill signal
    2024-02-14 19:57:13.716  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 killing pid 3456
    2024-02-14 19:57:13.819  - warn: host.raspberrypi instance system.adapter.smartmeter.0 terminated due to SIGTERM
    2024-02-14 19:57:13.822  - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code null ()
    2024-02-14 19:57:15.824  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 3469
    2024-02-14 19:57:18.335  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2024-02-14 19:57:18.511  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 send kill signal
    2024-02-14 19:57:18.698  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
    2024-02-14 19:57:18.900  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 send kill signal
    2024-02-14 19:57:19.937  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 killing pid 3469
    2024-02-14 19:57:20.041  - warn: host.raspberrypi instance system.adapter.smartmeter.0 terminated due to SIGTERM
    2024-02-14 19:57:20.043  - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code null ()
    2024-02-14 19:57:22.064  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 3620
    2024-02-14 19:57:30.659  - info: admin.0 (2951) ==> Connected system.user.admin from ::ffff:192.168.178.35
    2024-02-14 19:57:32.839  - info: smartmeter.0 (3620) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.18.0, js-controller: 4.0.23
    2024-02-14 19:57:36.539  - info: smartmeter.0 (3620) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"383ea6098193eb1196abdcc77d11dc1e","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_383ea6098193eb1196abdcc77d11dc1e-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"A103R2XZ","pnpId":"usb-FTDI_FT232R_USB_UART_A103R2XZ-if00-port0","vendorId":"0403","productId":"6001"}]
    2024-02-14 19:57:36.560  - info: smartmeter.0 (3620) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"383ea6098193eb1196abdcc77d11dc1e","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_383ea6098193eb1196abdcc77d11dc1e-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"A103R2XZ","pnpId":"usb-FTDI_FT232R_USB_UART_A103R2XZ-if00-port0","vendorId":"0403","productId":"6001"}]
    2024-02-14 19:57:39.452  - info: admin.0 (2951) <== Disconnect system.user.admin from ::ffff:192.168.178.35
    CoComp
    @cocomp
    jetzt kam noch als summary:
                            v.2023-10-10
             Icon name: computer
          Architecture: arm
    Kernel:                 armv7l
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     140
    Pending iob updates:    9
    /home/iobroker/.diag.sh: line 486: nodejs: command not found
    Nodejs-Installation:
                            /usr/bin/npm            8.19.2
                            /usr/bin/npx            8.19.2
    Recommended versions are nodejs 16.20.2 and npm 8.19.4
    Wrong installation path detected. This needs to be fixed.
    Please check
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    for more information on how to fix these errors.
    MEMORY:
    Mem:            922M        487M         89M        0.0K        345M        412M
    Swap:            99M         10M         89M
    Total:          1.0G        497M        178M
    Active iob-Instances:   12
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.2.23
    Objects type: jsonl
    States  type: jsonl
    Objects:                2437
    States:                 1741
    Size of iob-Database:
    1.1M    /opt/iobroker/iobroker-data/states.jsonl
    • C CoComp
      @cocomp
                              v.2023-10-10
               Icon name: computer
            Architecture: arm
      Kernel:                 armv7l
      Userland:               armhf
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            8.19.2
                              /usr/bin/npx            8.19.2
      Please check
      MEMORY:
      Swap:            99M         10M         89M
                              admin                   6.2.23
      Objects type: jsonl
      States  type: jsonl
      Objects:                2437
      States:                 1741
      Thomas BraunT Offline
      @cocomp sagte in Upgrade einer vernachlässigten ioBroker Installation:
      iob nodejs-update
      sudo reboot
      iob update
      iob upgrade all
      iob stop
      iob upgrade self
      iob start
      Und dann nochmal
      iob diag
      C 1 Antwort Letzte Antwort
      • C CoComp
        @cocomp
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm
        Kernel:                 armv7l
        Userland:               armhf
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            8.19.2
                                /usr/bin/npx            8.19.2
        Please check
        MEMORY:
        Swap:            99M         10M         89M
                                admin                   6.2.23
        Objects type: jsonl
        States  type: jsonl
        Objects:                2437
        States:                 1741
        @cocomp
        Bei den Instanzen würde ich überlegen die zu optimieren.
        discovery kann wohl komplett raus und ob 3 influxdb-Instanzen erforderlich sind würde ich auch überlegen.
          @cocomp
          CoComp
          schrieb am zuletzt editiert von CoComp
          @thomas-braun said in Upgrade einer vernachlässigten ioBroker Installation:
          @cocomp
          OK, die drei Influxinstanzen verweisen auf drei unterschiedliche Buckets, die brauche ich wohl...
            iob nodejs-update
            sudo reboot
            iob update
            iob upgrade all
            iob stop
            iob upgrade self
            iob start
            Und dann nochmal
            iob diag
            CoComp
            da ist nach dem ersten Schritt was schiefgelaufen, scheint es....
            ioBroker nodejs updater 2023-10-13
            Recommended nodejs-version is: 16.20.2
            Checking your installation now. Please be patient!
            Your current setup is:
            /usr/bin/npm            8.19.2
            /usr/bin/npx            8.19.2
            We found these nodejs versions available for installation:
            nodejs:
              Version table:
            Nothing to do - Your installation is using the correct paths.
            You are running nodejs v16.18.0. Do you want to install recommended version 16.20.2?
            Press <y> to continue or any other key to quit
            Trying to update your installation now. Please be patient.
            Waiting for ioBroker to shut down - Give me a minute...
            *** These repos are active on your system:
            Reading package lists... Done
            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
            (Reading database ... 53643 files and directories currently installed.)
            Preparing to unpack .../curl_7.74.0-1.3+deb11u11_armhf.deb ...
            Unpacking curl (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u3) ...
            Preparing to unpack .../libcurl4_7.74.0-1.3+deb11u11_armhf.deb ...
            Unpacking libcurl4:armhf (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u3) ...
            Setting up libcurl4:armhf (7.74.0-1.3+deb11u11) ...
            Setting up curl (7.74.0-1.3+deb11u11) ...
            Processing triggers for man-db (2.9.4-2) ...
            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
            Package: nodejs
            Pin: origin deb.nodesource.com
            Pin-Priority: 1001
            *** These repos are active after the adjustments:
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
            Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [7097 B]
            Fetched 19.2 kB in 2s (8129 B/s)
            Installing the recommended nodejs version now!
            /home/iobroker/.nodejs-update.sh: line 329: [: : integer expression expected
            /home/iobroker/.nodejs-update.sh: line 346: [: : integer expression expected
            Installing the recommended nodejs version!
            E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-libertas_20230210-5%7ebpo11%2b1%2brpt2_all.deb  Error reading from server. Remote end closed connection [IP: 46.235.230.122 80]
            E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
            We tried our best to update or fix your nodejs. Please run iob diag again to verify.
            • C CoComp
              /usr/bin/npm            8.19.2
              /usr/bin/npx            8.19.2
              nodejs:
                Version table:
              Package: nodejs
              Pin-Priority: 1001
              @cocomp
              sudo apt update
              sudo apt full-upgrade
                @cocomp
                sudo apt update
                CoComp
                @cocomp
                sudo apt update
                vor
                iob update
                iob upgrade all
                iob stop
                iob upgrade self
                iob start
                oder danach?
                • C CoComp
                  @cocomp
                  sudo apt update
                  vor
                  iob update
                  iob upgrade all
                  iob stop
                  iob upgrade self
                  iob start
                  oder danach?
                  @cocomp
                  Davor.
                    @cocomp
                    Davor.
                    CoComp
                    und danach
                    sudo reboot
                    und dann den Block komplett nochmal?
                    iob nodejs-update
                    sudo reboot
                    iob update
                    iob upgrade all
                    iob stop
                    iob upgrade self
                    iob start
                    • C CoComp
                      und danach
                      sudo reboot
                      iob nodejs-update
                      sudo reboot
                      iob update
                      iob upgrade all
                      iob stop
                      iob upgrade self
                      iob start
                      @cocomp
                      Danach sollte ein
                      iob nodejs-update
                      vermelden, dass alles i.O. ist.
                      Dann kann man sich um den ioBroker kümmern.
                        @cocomp
                        Danach sollte ein
                        iob nodejs-update
                        CoComp
                        Scheint durchgelaufen zu sein...arbeite jetzt mal die nächsten Schritte ab.
                        iob update
                        iob upgrade all
                        iob stop
                        iob upgrade self
                        iob start
                        • C CoComp
                          iob update
                          iob upgrade all
                          iob stop
                          iob upgrade self
                          iob start
                          CoComp
                          @cocomp
                          So, scheint erfolgreich durchgelaufen zu sein. Nur der Smartmeter-Adapter steht auf gelb, weil er keine Verbindung zum Lesekopf zu haben scheint. War kurz auf grün und dann wieder auf gelb....
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                      Kernel: Linux 6.1.21-v7+
                                Architecture: arm
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : armhf
                           21:14:18 up 23 min,  1 user,  load average: 6.49, 3.85, 2.97
                          CPU threads: 4
                          Current issues:
                                         Local time: Wed 2024-02-14 21:14:19 CET
                                     Universal time: Wed 2024-02-14 20:14:19 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            921M        514M        150M        0.0K        256M        347M
                          Swap:            99M         17M         82M
                          Total:          1.0G        532M        232M
                                    921 M total memory
                                    514 M used memory
                                    141 M active memory
                                    548 M inactive memory
                                    150 M free memory
                                     38 M buffer memory
                                    218 M swap cache
                                     99 M total swap
                                     17 M used swap
                                     82 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/root      ext4       29G  3.6G   25G  13% /
                          tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                          tmpfs          tmpfs     185M  940K  184M   1% /run
                          /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                          [Wed Feb 14 20:51:00 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=6bc33173-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Wed Feb 14 20:51:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Wed Feb 14 20:51:04 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Wed Feb 14 20:51:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                          /var:
                          1.3G    /var/
                          707M    /var/log
                          705M    /var/log/journal/21286045b254429896948513200b4631
                          377M    /var/cache
                          Archived and active journals take up 704.1M in the file system.
                          99M     /opt/iobroker/iobroker-data/
                          46M     /opt/iobroker/iobroker-data/files
                          31M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
                          22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                          11M     /opt/iobroker/iobroker-data/objects.jsonl
                          8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
                          4.7M    /opt/iobroker/iobroker-data/states.jsonl
                          USB-Devices by-id:
                          /usr/bin/nodejs         v18.19.0
                          /usr/bin/node           v18.19.0
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          /usr/bin/corepack       0.22.0
                          nodejs:
                            Installed: 18.19.0-1nodesource1
                            Candidate: 18.19.0-1nodesource1
                            Version table:
                           *** 18.19.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                               18.18.2-1nodesource1 1001
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          js-controller:  5.0.17
                          admin:          6.13.16
                          Adapters from github:   0
                          Adapter State
                          + instance is alive
                          Adapter    "admin"        : 6.13.16  , installed 6.13.16
                          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                          Adapter    "jeelink"      : 1.2.3    , installed 1.2.3
                          Controller "js-controller": 5.0.17   , installed 5.0.17
                          Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                          Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                          Objects and States
                          Objects:        2443
                          States:         1742
                          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18352      2444/node-red
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18626      2382/iobroker.js-co
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18062      2382/iobroker.js-co
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1861       475/sshd: /usr/sbin
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18743      2400/io.admin.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          1863       475/sshd: /usr/sbin
                          udp        0      0 0.0.0.0:33645           0.0.0.0:*                           108        597        354/avahi-daemon: r
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12487      533/dhcpcd
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        595        354/avahi-daemon: r
                          udp6       0      0 :::45120                :::*                                108        598        354/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                108        596        354/avahi-daemon: r
                          2024-02-14 21:14:15.898  - info: plenticore.0 (2560) Configured Wp of panel(s) is 0
                          2024-02-14 21:14:15.911  - info: plenticore.0 (2560) [INFO] Configured polling interval: 20000
                          2024-02-14 21:14:16.778  - info: loxone.0 (2503) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.loxone, node: v18.19.0, js-controller: 5.0.17
                          2024-02-14 21:14:17.749  - info: backitup.0 (2525) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
                          2024-02-14 21:14:18.400  - info: smartmeter.0 (2491) Received 14 values, 14 updated
                          2024-02-14 21:14:18.608  - info: backitup.0 (2525) [iobroker] backup will be activated at 02:40 every 1 day(s)
                          2024-02-14 21:14:20.229  - info: loxone.0 (2503) Trying to connect
                          2024-02-14 21:14:22.354  - info: loxone.0 (2503) got structure file; last modified on 2024-02-12 17:02:50
                          2024-02-14 21:14:22.773  - info: plenticore.0 (2560) Not enabling forecast data.
                          2024-02-14 21:14:22.783  - info: plenticore.0 (2560) Not enabling MinSoC forecast data.
                          2024-02-14 21:14:29.736  - info: loxone.0 (2503) Unsupported device control CarCharger
                          2024-02-14 21:14:33.278  - info: loxone.0 (2503) Unsupported device control IRoomController
                          2024-02-14 21:14:35.286  - info: loxone.0 (2503) Unsupported device control IRoomController
                          2024-02-14 21:14:37.782  - info: loxone.0 (2503) Unsupported device control IRoomController
                          2024-02-14 21:14:46.993  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
                          2024-02-14 21:14:49.187  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
                          2024-02-14 21:14:49.674  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
                          2024-02-14 21:14:59.027  - info: loxone.0 (2503) Unsupported device control IRoomController
                          2024-02-14 21:15:00.877  - info: loxone.0 (2503) Unsupported device control IRoomController
                          2024-02-14 21:15:07.012  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
                          2024-02-14 21:15:09.131  - info: loxone.0 (2503) Unsupported device control EFM
                          2024-02-14 21:15:09.810  - info: loxone.0 (2503) Unsupported device control EnergyManager2
                          2024-02-14 21:15:29.582  - info: loxone.0 (2503) State value to set for "loxone.0.10998e53-004d-364a-ffff145cea42a008.sceneList" has to be stringified but received type "object"
                          2024-02-14 21:16:21.871  - info: smartmeter.0 (2491) Error: No or too long answer from Serial Device after last request.
                          2024-02-14 21:16:21.875  - warn: smartmeter.0 (2491) No or too long answer from Serial Device after last request.
                          und hier die Summary
                                                  v.2023-10-10
                                   Icon name: computer
                                Architecture: arm
                          Kernel:                 armv7l
                          Userland:               armhf
                          User-ID:                1000
                          X-Server:               false
                          Pending OS-Updates:     0
                          Pending iob updates:    0
                          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                  /usr/bin/npm            10.2.3
                                                  /usr/bin/npx            10.2.3
                          Recommended versions are nodejs  and npm
                          MEMORY:
                          Mem:            921M        488M        135M        0.0K        298M        372M
                          Swap:            99M         65M         34M
                          Total:          1.0G        553M        169M
                          ioBroker Core:          js-controller           5.0.17
                                                  admin                   6.13.16
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                2443
                          States:                 1742
                          12M     /opt/iobroker/iobroker-data/objects.jsonl
                          5.4M    /opt/iobroker/iobroker-data/states.jsonl
                          Fällt dir etwas "krummes" auf?
                          node.js scheint jetzt auf 18.19 zu sein.
                          wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                          • C CoComp
                            @cocomp
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm
                            Docker          : false
                            Kernel          : armv7l
                            Userland        : armhf
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:            99M         17M         82M
                                      921 M total memory
                                      514 M used memory
                                      141 M active memory
                                      150 M free memory
                                       38 M buffer memory
                                      218 M swap cache
                                       99 M total swap
                                       17 M used swap
                                       82 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            1.3G    /var/
                            707M    /var/log
                            377M    /var/cache
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.13.16
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        2443
                            States:         1742
                            Pending Updates: 0
                                                    v.2023-10-10
                                     Icon name: computer
                                  Architecture: arm
                            Kernel:                 armv7l
                            Userland:               armhf
                            User-ID:                1000
                            X-Server:               false
                                                    /usr/bin/npm            10.2.3
                                                    /usr/bin/npx            10.2.3
                            MEMORY:
                            Swap:            99M         65M         34M
                                                    admin                   6.13.16
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                2443
                            States:                 1742
                            wendy2702W Offline
                            wendy2702W Offline
                            @cocomp schau mal beim Smartmeter Adapter nach dem Pfad zum Lesekopf ob der noch passt.
                            • wendy2702W wendy2702
                              CoComp
                              @wendy2702
                              Merkwürdig, dass der Adapter eine Zeitlang auf "grün" steht, bevor er dann auf "gelb" wechselt.Smartmeteradapter.png
                              Ich habe den Raspi jetzt mal physisch neu gestartet - und er geht wieder auf gelb...
                              und das sagt das Protokoll:
                              smartmeter.0
                              2024-02-14 21:32:18.164	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              2024-02-14 21:32:18.162	info	Error: No or too long answer from Serial Device after last request.
                              smartmeter.0
                              2024-02-14 21:30:03.148	warn	No or too long answer from Serial Device after last request.
                              smartmeter.0
                              2024-02-14 21:30:03.140	info	Error: No or too long answer from Serial Device after last request.
                              smartmeter.0
                              2024-02-14 21:28:22.511	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"383ea6098193eb1196abdcc77d11dc1e","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_383ea6098193eb1196abdcc77d11dc1e-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"A103R2XZ","pnpId":"usb-FTDI_FT232R_USB_UART_A103R2XZ-if00-port0","vendorId":"0403","productId":"6001"}]
                              • C CoComp
                                @cocomp
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm
                                Docker          : false
                                Kernel          : armv7l
                                Userland        : armhf
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M         17M         82M
                                          921 M total memory
                                          514 M used memory
                                          141 M active memory
                                          150 M free memory
                                           38 M buffer memory
                                          218 M swap cache
                                           99 M total swap
                                           17 M used swap
                                           82 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                1.3G    /var/
                                707M    /var/log
                                377M    /var/cache
                                USB-Devices by-id:
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.13.16
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        2443
                                States:         1742
                                Pending Updates: 0
                                                        v.2023-10-10
                                         Icon name: computer
                                      Architecture: arm
                                Kernel:                 armv7l
                                Userland:               armhf
                                User-ID:                1000
                                X-Server:               false
                                                        /usr/bin/npm            10.2.3
                                                        /usr/bin/npx            10.2.3
                                MEMORY:
                                Swap:            99M         65M         34M
                                                        admin                   6.13.16
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                2443
                                States:                 1742
                                Nein, passt.
                                  Nein, passt.
                                  CoComp
                                  Zunächst mal 1000 Dank, nach einem physischen Neustart scheint alles zu laufen und auch der Smartmeteradapter tut, was er soll.
                                  Soll ich an node.js nochmal ran? Läuft jetzt auf Version 18.19.0
                                  Plattform: linux
                                  Betriebssystem: linux
                                  Architektur: arm
                                  CPUs: 4
                                  Geschwindigkeit: 900 MHz
                                  Modell: ARMv7 Processor rev 5 (v7l)
                                  RAM: 921.9 MB
                                  System-Betriebszeit: 00:06:52
                                  Node.js: v18.19.0
                                  time: 1707944060753
                                  timeOffset: -60
                                  NPM: 10.2.3
                                  Adapter-Anzahl: 531
                                  Datenträgergröße: 29.0 GB
                                  Freier Festplattenspeicher: 25.4 GB
                                  Aktive Instanzen: 10
                                  Pfad: /opt/iobroker/
                                  Betriebszeit: 00:07:55
                                  aktiv:
                                  • C CoComp
                                    Plattform: linux
                                    Architektur: arm
                                    CPUs: 4
                                    RAM: 921.9 MB
                                    Node.js: v18.19.0
                                    time: 1707944060753
                                    timeOffset: -60
                                    NPM: 10.2.3
                                    Adapter-Anzahl: 531
                                    aktiv:
                                    Warum? v18 ist genau richtig.
                                    Halt die Kiste dann künftig egenständig aktuell. Im Sommer ist spätestens ein Wechsel auf 'Bookworm' erforderlich, besser aber jetzt schon mal in Angriff nehmen.
                                      CoComp
                                      Ok, das bedeutet dann aber
                                      1.) ioBroker und alle Adapter auf Stand bringen
                                      2.) ioBroker Backup
                                      3.) vollständige Neuinstallation anstatt Upgrade
                                      4. ioBroker BackUp zurückspielen?
                                      Thomas BraunT da_WoodyD 2 Antworten Letzte Antwort
                                      • wendy2702W Offline
                                        wendy2702W Offline
                                        @cocomp sagte in [Upgrade einer vernachlässigten ioBroker Installation](/post/1128870
                                        Also zweimal neu gestartet?
                                        Zunächst mal 1000 Dank, nach einem physischen Neustart scheint alles zu laufen und auch der Smartmeteradapter tut, was er soll..
                                        • C CoComp
                                          2.) ioBroker Backup
                                          @cocomp
                                          Ja, im wesentlichen genau so.
