  4. Adapter: ioBroker.unifi
    6.3k
unifi
1.0k Beiträge 172 Kommentatoren 531.0k Aufrufe 93 Beobachtet
  • mike2507M Offline
    mike2507M Offline
    mike2507
    #893
    Hier mal ein Auszug aus meinem Log.
    Vielleicht kann jemand was damit anfangen und mir helfen.
    2024-02-01 13:30:36.842  - info: linux-control.0 (1460619) getting data from UDMse (10.1.30.1:22, Adapter start)
    2024-02-01 13:30:36.842  - debug: linux-control.0 (1460619) getting data from grafana (10.1.30.4:22) -> not enabled!
    2024-02-01 13:30:36.865  - debug: linux-control.0 (1460619) [getConnection] Host 'UDMse' (10.1.30.1:22): using sudo for authentification
    2024-02-01 13:30:36.971  - error: linux-control.0 (1460619) [getConnection] Could not establish a connection to 'UDMse' (10.1.30.1:22)!
    2024-02-01 13:30:36.975  - error: linux-control.0 (1460619) [getConnection] error: All configured authentication methods failed, stack: Error: All configured authentication methods failed
        at doNextAuth (/opt/iobroker/node_modules/ssh2/lib/client.js:865:21)
        at tryNextAuth (/opt/iobroker/node_modules/ssh2/lib/client.js:1082:7)
        at USERAUTH_FAILURE (/opt/iobroker/node_modules/ssh2/lib/client.js:430:11)
        at 51 (/opt/iobroker/node_modules/ssh2/lib/protocol/handlers.misc.js:408:16)
        at Protocol.onPayload (/opt/iobroker/node_modules/ssh2/lib/protocol/Protocol.js:2052:10)
        at AESGCMDecipherBinding.decrypt (/opt/iobroker/node_modules/ssh2/lib/protocol/crypto.js:1086:26)
        at Protocol.parsePacket [as _parse] (/opt/iobroker/node_modules/ssh2/lib/protocol/Protocol.js:2021:25)
        at Protocol.parse (/opt/iobroker/node_modules/ssh2/lib/protocol/Protocol.js:306:16)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ssh2/lib/client.js:775:21)
        at Socket.emit (node:events:514:28)
        at Socket.emit (node:domain:489:12)
        at addChunk (node:internal/streams/readable:324:12)
        at readableAddChunk (node:internal/streams/readable:297:9)
        at Socket.Readable.push (node:internal/streams/readable:234:10)
        at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
    2024-02-01 13:30:37.139  - debug: linux-control.0 (1460619) [refreshHost] UDMse (10.1.30.1:22): button 'linux-control.0.UDMse.refresh' subscribed
    • wendy2702W Offline
      wendy2702W Offline
      #894
      Dann zeig doch mal das Logfile z.B. vom Linux Control im Debug Mode wenn der versucht sich zu verbinden oder die Ausgabe von den Eingaben die du machst wenn du vom iob auf die UDM gehst.
      EDIT: Hat sich überschnitten.
      Wie sieht der Befehl in Linux Control aus bzw. wie sind die Einstellungen?
      Trotzdem noch das Log/Ausgabe wenn du es manuell machst.
      mike2507M 2 Antworten Letzte Antwort
      • wendy2702W wendy2702
        mike2507M Offline
        mike2507M Offline
        mike2507
        #895
        @wendy2702 sagte in Adapter: ioBroker.unifi:
        Einen Befehl hab ich noch gar nicht hinterlegt im Linux Control Adapter. Hab nur mal die Verbindungseinstellungen gemacht.
        Einstellungen im Adapter
        B/Users/michael/Desktop/Bildschirmfoto 2024-02-01 um 14.27.28.pngildschirmfoto 2024-02-01 um 14.18.58.png
        Hier noch mal der Log vom linux-control
        2024-02-01 14:19:09.890  - info: linux-control.0 (1490423) getting data from UDMse (10.1.30.1:22, Adapter start)
        2024-02-01 14:19:09.891  - debug: linux-control.0 (1490423) getting data from grafana (10.1.30.4:22) -> not enabled!
        2024-02-01 14:19:10.052  - error: linux-control.0 (1490423) [getConnection] Could not establish a connection to 'UDMse' (10.1.30.1:22)!
        2024-02-01 14:19:10.056  - error: linux-control.0 (1490423) [getConnection] error: All configured authentication methods failed, stack: Error: All configured authentication methods failed
        2024-02-01 14:19:10.220  - debug: linux-control.0 (1490423) [refreshHost] UDMse (10.1.30.1:22): button 'linux-control.0.UDMse.refresh' subscribed
          mike2507M Offline
          mike2507M Offline
          mike2507
          #896
          @wendy2702
          nach langen herum probieren habe ich es jetzt mit einem ssh-keygen gelöst.
          Mit diesem funktioniert es.
          • E Offline
            Einstein2002
            schrieb am zuletzt editiert von Einstein2002
            #897
            Guten Abend zusammen,
            kann ich vom IOBroker aus auf der UDMPro ein WLAN an und ausschalten wenn ich auf den Datenpunkt wlans/passendes wlan/enabled gehe und dann von true auf false wechsle.
            Anders herum also wenn ich auf die UDM unter Netzwerke WLAN gehe dann das gewünschte WLAN ausschalte, so bekomme ich unter dem o.g. Datenpunkt angezeigt das sich dieses WLAN auf false befindet.
            Hoffe ich habe mich einigermaßen ausgedrückt.
            Mein Ziel wäre folgendes:
            Von einem NSPanel mit einem virtuellem Schalter das Wlan an und auszuschalten.
            Oder ist dieser Adapter nur zum lesen der Daten gedacht?
            Danke jetzt schon mal.
            Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
            Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
            • E Einstein2002
              Samson71S Offline
              Samson71S Offline
              Samson71
              #898
              @einstein2002
              Ich hatte mal versucht darüber das Gäste WLAN an- und auszuschalten (USG4 Pro), habe es aber nicht zum Laufen bekommen. Die Änderung des Datenpunktes bewirkt Richtung USG/Unifi nichts.
              Markus
              Bitte beachten:
              X 1 Antwort Letzte Antwort
              • Samson71S Samson71
                @einstein2002
                X Offline
                X Offline
                xdelta
                schrieb am zuletzt editiert von xdelta
                #899
                @samson71 said in Adapter: ioBroker.unifi:
                @einstein2002
                Bei der UDM Pro kann ich über nachfolgenden dp das (Gast-)WLAN deaktieren und wieder aktivieren (false/true):
                (! Man muss aber wissen, dass sich dabei immer das gesamte WLAN kurz trennt und dann wieder verbindet !)
                unifi.0.default.wlans.SSID.enabled
                • X xdelta
                  @einstein2002
                  Samson71S Offline
                  Samson71S Offline
                  Samson71
                  #900
                  @xdelta sagte in Adapter: ioBroker.unifi:
                  Ist klar, da die AP's dann kurz neu provisioniert werden. Letzten Endes auch der Grund warum ich das auch nicht weiter verfolgt habe. Das Gäste WLAN ist jetzt halt immer aktiv. Läuft über Voucher und hier ist die Gesamtdichte an aktiven Netzen nicht ganz so schlimm.
                  Markus
                  Bitte beachten:
                    X Offline
                    X Offline
                    xdelta
                    #901
                    @samson71
                    So siehts aus! Ich habs deshalb ebenso mit Vouchern gelöst :)
                    draexlerD 1 Antwort Letzte Antwort
                    • X xdelta
                      @samson71
                      draexlerD Offline
                      draexlerD Offline
                      draexler
                      #902
                      @xdelta geht bei euch die Voucherstellung noch?
                      Samson71S X 2 Antworten Letzte Antwort
                      • draexlerD draexler
                        Samson71S Offline
                        Samson71S Offline
                        Samson71
                        #903
                        @draexler
                        Nicht über bzw. aus ioBroker heraus falls das gemeint war. Ich mache das direkt im Unifi Controller.
                        Markus
                        Bitte beachten:
                          X Offline
                          X Offline
                          xdelta
                          #904
                          @draexler said in Adapter: ioBroker.unifi:
                          Nein, das geht bei mir nur direkt aus der UDM heraus. Mit ioBroker leider nicht über den dp..
                          • draexlerD Offline
                            draexlerD Offline
                            draexler
                            #905
                            @xdelta also wenn ihr auf den Trigger „Vouchererstellung“ klickt, habt ihr auch eine Axios Fehlermeldung im Log?
                            Will nur wissen ob andere auch betroffen sind.
                              Adnim
                              #906
                              @draexler sagte in Adapter: ioBroker.unifi:
                              Mache das über das Unifi Skript von @liv-in-sky. Evtl kann es mal irgendwann in den Adapter übernommen werden. Die Vouchers über Telegram abrufen/erzeugen ist schon ziemlich cool!
                              -> https://forum.iobroker.net/topic/25066/unifi-wlan-script-2-mit-anwesenheitskontrolle?_=1707798864830
                                X Offline
                                X Offline
                                xdelta
                                #907
                                @xdelta also wenn ihr auf den Trigger „Vouchererstellung“ klickt, habt ihr auch eine Axios Fehlermeldung im Log? > Will nur wissen ob andere auch betroffen sind.
                                Ja, habe ich ebenso.
                                [createUnifiVouchers site default] error: Request failed with status code 400, stack: AxiosError: Request failed with status code 400 at settle (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:1967:12) at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/dist/node/axios.cjs:3062:11) at IncomingMessage.emit (node:events:529:35) at endReadableNT (node:internal/streams/readable:1400:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
                                • X xdelta
                                  draexlerD Offline
                                  draexlerD Offline
                                  draexler
                                  #908
                                  @xdelta Danke, also definitiv nicht Einzelfälle. GitHub Issue ist aber schon eingestellt.
                                  • W Offline
                                    W Offline
                                    warp735
                                    #909
                                    Ich warte das System eine Freundes und wurde gerade mit dieser Meldung begrüßt. Scheinbar ist der Adapter nicht mehr lange nutzbar :-(
                                    O Meister MopperM 2 Antworten Letzte Antwort
                                    • W warp735
                                      O Offline
                                      O Offline
                                      oxident
                                      #910
                                      @warp735 Hmm, aber der Adapter nutzt doch den lokalen Zugang und nicht die Cloud.
                                      Habe 2FA jetzt seit Anfang des Jahres aktiviert und keine (neuen) Probleme mit dem Adapter.
                                      W 1 Antwort Letzte Antwort
                                      • O oxident
                                        W Offline
                                        W Offline
                                        warp735
                                        #911
                                        @oxident
                                        Oh... das wusste ich nicht. "Früher"war es Bedingung 2FA zu deaktivieren und bei mir hatte es mit auch nicht funktioniert.
                                        • W warp735
                                          Meister MopperM Offline
                                          Meister Mopper
                                          #912
                                          @warp735 sagte in Adapter: ioBroker.unifi:
                                          Noch läuft bei mir beides. Ich habe einen lokalen Zugang und einen über die cloud (2FA).
                                          Proxmox und HA ...
