  4. Frigate Adapter für ioBroker
    6.3k
383 Beiträge 48 Kommentatoren 140.7k Aufrufe 45 Beobachtet
  • Q Offline
    Q Offline
    QuesT
    #181
    Hallo wollte heute mal mit dem gotify Adapter versuchen. Bring aber folgende Fehlermeldung:
    2024-02-02 13:12:57.666 - error: gotify.0 (2275) Error while sending message to gotify:{"message":"Request failed with status code 400","name":"Error","stack":"Error: Request failed with status code 400\n at createError (/opt/iobroker/node_modules/iobroker.gotify/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/iobroker.gotify/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.gotify/node_modules/axios/lib/adapters/http.js:312:11)\n at IncomingMessage.emit (node:events:529:35)\n at endReadableNT (node:internal/streams/readable:1368:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"headers":{"Accept":"application/json, text/plain, /","Content-Type":"application/json","User-Agent":"axios/0.25.0","Content-Length":33},"method":"post","url":"http://192.168.1.2xx/message?token=Axxxxxxxx","data":"{\"extras\":{\"client::display\":{}}}"},"status":400}
    Wäre eine coole alternative.
    • Q QuesT
      tombox
      #182
      @quest Was ist genau die Frage?
      Q H 2 Antworten Letzte Antwort
      • T tombox
        Q Offline
        Q Offline
        QuesT
        #183
        @tombox
        Sorry ob man auch Gotify oder ntfy (https://github.com/sestriel/ioBroker.ntfy) unterstützen könnte. Will meine Bilder nicht aus dem internen Netz hinausgeben.
        • T tombox
          H Online
          H Online
          hagst
          #184
          @tombox
          Error: ENAMETOOLONG: name too long, unlink '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
          [viele viele Zeichen gelöscht]
          Hast Du eine Idee?
          • H hagst
            @tombox
            Hast Du eine Idee?
            tombox
            #185
            @hagst der Temp folder ist zu lang. Was ist das genau für ein System
            H 1 Antwort Letzte Antwort
            • T tombox
              H Online
              H Online
              hagst
              #186
              @tombox sagte in Frigate Adapter für ioBroker:
              Debian 12, Proxmox, LXC (Debian 12)
              • Q QuesT
                @tombox
                tombox
                #187
                @quest
                @sestriel kannst du kurz erklären wie ein sendTo Objekt aussehen muss wird aus dem code nicht ganz klar..
                Kannst du kurz ein Beispiel nennen wie man iobroker.ntfy senden muss
                • H hagst
                  tombox
                  #188
                  @hagst probier mal die GitHub version ob das da geht
                  • T tombox
                    H Online
                    H Online
                    hagst
                    #189
                    Gerade mal neu installiert, jetzt muss ich warten bis jemand vor der Kamera rumrennt, hier regnet es und ich will nicht nass werden :-)
                      tombox
                      #190
                      @hagst Bitte nochmal installieren
                      @QuesT bitte mal die GitHub installieren die könnten mit iobroker.ntfy oder iobroker.gotify funktionieren
                      Q 1 Antwort Letzte Antwort
                      • T tombox
                        H Online
                        H Online
                        hagst
                        schrieb am zuletzt editiert von hagst
                        #191
                        @tombox
                        Mir ist gerade wieder etwas aufgefallen.
                        Ich habe um den Fehler nachvollziehen zu können, nochmal die Version 1.0.0 installiert.
                        In der Version 1.0.0 wird der detaillierte Screenshot per Telegram versendet. Nach einem Update auf die 1.0.2 wird er nicht mehr gesendet.
                        Nach einem downgrade auf die 1.0.0 wird er wieder versendet. Der andere Fehler ist mit der De- und Neuinstallation verschwunden.
                        • H hagst
                          @tombox
                          tombox
                          #192
                          @hagst Danke für den Hinweis bitte nochmal GitHub version testen
                          • T tombox
                            H Online
                            H Online
                            hagst
                            #193
                            Klappt, jetzt kommt auch in der GitHub Version der detaillierte Screenshot per Telegram. Was mir noch aufgefallen ist (ich hoffe es nervt nicht). ist der Text der Meldung unter den Screenshots bei Telegram:
                            In der original Config wurde, bis auf die mqtt Einstellungen, nichts verändert.
                            Bildunterschrift bei den normalen Screenshots: "Terrasse person erkannt end 0.84375"
                            Bildunterschrift bei den detaillierte Screenshots:Terrasse person erkannt undefined undefined"
                            Bildunterschift unter den Videoclips: Terrasse person erkannt end 0.84375"
                            Vielleicht verschwindet ja das undefined, wenn der ioBroker / frigate neu gestartet wurde, mal schauen.
                            Edit:
                            Neustart vom ioBroker und frigate:
                            • H hagst
                              Edit:
                              tombox
                              #194
                              @hagst ist korrigiert
                              • T tombox
                                H Online
                                H Online
                                hagst
                                #195
                                ist korrigiert
                                Sieht gut aus.
                                • T tombox
                                  Q Offline
                                  Q Offline
                                  QuesT
                                  #196
                                  @tombox
                                  2024-02-04 11:45:40.075 - error: ntfy.0 (1189) Ntfy error: AxiosError: Request failed with status code 400
                                  2024-02-04 11:45:40.075 - error: ntfy.0 (1189) Ntfy error: {"code":40009,"http":400,"error":"invalid request: topic invalid"}
                                  2024-02-04 11:45:40.075 - error: ntfy.0 (1189) Ntfy with config: {}
                                  • Q QuesT
                                    @tombox
                                    tombox
                                    #197
                                    @quest was wäre denn eine korrekte topic
                                    • T tombox
                                      Q Offline
                                      Q Offline
                                      QuesT
                                      #198
                                      @tombox
                                      Hatte nur kein standart Topic gesetzt im Adapter. Geht nun aber es wird kein Bild mitgesendet.
                                      cam1 person erkannt end 0.80859375
                                      /tmp/8d9cb83e-3f51-44b5-b704-0af816bbcabe.jpg
                                      T T 2 Antworten Letzte Antwort
                                      • Q QuesT
                                        @tombox
                                        Tschaeens
                                        #199
                                        @tombox
                                        Erstmal danke für das Update. Bei mir läuft alles tiptop. Ich würde gern den Wert motion weiterverarbeiten. Leider geht dieser bei jedem motion auf ON. Gibt es einen state der nur auf ON geht, wenn Frigate eine Person erkennt und der Wert über meinen eingestellten Wert ist? Also dann wenn Frigate auch einen snapshot erstellt. Danke dir.
                                        • Q QuesT
                                          @tombox
                                          tombox
                                          #200
                                          @quest kann der adapter denn Bilder verarbeiten?
