  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id
    3.2k
111 Beiträge 7 Kommentatoren 19.7k Aufrufe 6 Beobachtet
    @n811e
    Dann zeig mal was verwertbares...
    apt policy udev
    iob diag
    N Offline
    N Offline
    n811e
    @thomas-braun said in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
    apt policy udev
    apt policy udev
    udev:
      Installiert:           252.21-1~deb12u1
      Installationskandidat: 252.21-1~deb12u1
      Versionstabelle:
         254.5-1~bpo12+3 100
            100 http://deb.debian.org/debian bookworm-backports/main armhf Packages
     *** 252.21-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm-proposed-updates/main armhf Packages
         252.19-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main armhf Packages
    Copy text starting here:
    v.2023-10-10
    Static hostname: raspberrypi
    Icon name: computer
    Kernel: Linux 6.1.21-v7l+
    Architecture: arm
    Installation: native
    Kernel: armv7l
    Userland: armhf
    Timezone: Europe/Berlin (CET, +0100)
    User-ID: 1000
    X-Server: false
    Boot Target: graphical.target
    Pending OS-Updates: 0
    Pending iob updates: 1
    Nodejs-Installation: /usr/bin/nodejs v18.19.0
    /usr/bin/node v18.19.0
    /usr/bin/npm 10.2.3
    /usr/bin/npx 10.2.3
    /usr/bin/corepack 0.22.0
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    MEMORY:
    total used free shared buff/cache available
    Mem: 8.3G 2.4G 5.7G 1.0M 399M 5.9G
    Swap: 104M 0B 104M
    Total: 8.4G 2.4G 5.8G
    Active iob-Instances: 40
    Active repo(s): stable
    ioBroker Core: js-controller 5.0.17
    admin 6.12.0
    ioBroker Status: iobroker is running on this host.
    Objects type: jsonl
    States type: jsonl
    • system.adapter.admin.3 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects: 19630
    States: 15338
    Size of iob-Database:
    22M /opt/iobroker/iobroker-data/objects.jsonl
    12M /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    • N n811e
      apt policy udev
      apt policy udev
      udev:
        Versionstabelle:
           254.5-1~bpo12+3 100
      v.2023-10-10
      Icon name: computer
      Architecture: arm
      Kernel: armv7l
      Userland: armhf
      User-ID: 1000
      X-Server: false
      /usr/bin/npm 10.2.3
      /usr/bin/npx 10.2.3
      MEMORY:
      Swap: 104M 0B 104M
      admin 6.12.0
      Objects type: jsonl
      States type: jsonl
      Objects: 19630
      States: 15338
      @n811e sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
      bookworm-backports
      Schalt die Backports aus. Lösch die entsprechende Zeile aus der Datei
      /etc/apt/sources.list
      heraus.
      N 1 Antwort Letzte Antwort
        bookworm-backports
        heraus.
        N Offline
        N Offline
        n811e
        Welche genau meinst Du?
        deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
        deb http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware
        deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
        # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
        deb-src http://deb.debian.org/debian bookworm main contrib non-free
        deb-src http://security.debian.org/debian-security bookworm-security main contrib non-free
        deb-src http://deb.debian.org/debian bookworm-updates main contrib non-free
        • N n811e
          @n811e
          Dann ist es in einer anderen Datei drin. Schau im Verzeichnis /etc/apt/sources.list.d danach.
            @n811e
            N Offline
            N Offline
            n811e
            Da komme ich gar nicht erst hin
            pi@raspberrypi:~ $ /etc/apt/sources.list.d
            -bash: /etc/apt/sources.list.d: Ist ein Verzeichnis
            -bash: /etc/apt/sources.list.: Datei oder Verzeichnis nicht gefunden
            pi@raspberrypi:~ $
            • N n811e
              pi@raspberrypi:~ $
              @n811e
              cd /Pfad/zum/Verzeichnis
              cd = Change Directory
                @n811e
                N Offline
                N Offline
                n811e
                Ah cool, das hat schon mal geklappt.
                Aber sehen kann ich da dann noch nichts
                pi@raspberrypi:~ $ cd /etc/apt/sources.list.d
                pi@raspberrypi:/etc/apt/sources.list.d $
                • N n811e
                  @n811e
                  ls -lAh
                  ls = LiSt
                    @n811e
                    ls -lAh
                    ls = LiSt
                    N Offline
                    N Offline
                    n811e
                    #66
                    ls -lAh
                    Ich werde noch ein Kommandozeilenprofi, wenn es so weiter geht 😊
                    pi@raspberrypi:/etc/apt/sources.list.d $ ls -lAh
                    insgesamt 20K
                    -rw-r--r-- 1 root root  57 29. Jan 17:54 backports.list
                    -rw-r--r-- 1 root root  93 29. Jan 17:54 bullseye-proposed-updates.list
                    -rw-r--r-- 1 root root 100 29. Jan 17:55 nodesource.list
                    -rw-r--r-- 1 root root  88 29. Jan 17:55 pivccu.list
                    -rw-r--r-- 1 root root 191 29. Jan 17:55 raspi.list
                    • N n811e
                      ls -lAh
                      insgesamt 20K
                      #67
                      sudo rm b*
                      cd
                      sudo apt update
                        sudo rm b*
                        cd
                        sudo apt update
                        N Offline
                        N Offline
                        n811e
                        #68
                        sudo apt update
                        diese 3 Zeilen, soll ich jetzt nacheinander eingeben?
                        • N n811e
                          sudo apt update
                          #69
                          @n811e
                          Ja, aber besser so:
                          cd
                          sudo rm /etc/apt/sources.list.d/b*
                          sudo apt update
                            @n811e
                            Ja, aber besser so:
                            cd
                            sudo apt update
                            N Offline
                            N Offline
                            n811e
                            #70
                            Ok.
                            hab ich gemacht
                            Kannst Du mir sagen was das bewirkt?
                            • N n811e
                              Ok.
                              hab ich gemacht
                              #71
                              Vielleicht. Wenn du die Ausgabe von
                              sudo apt update
                              bekannt gibst.
                                sudo apt update
                                bekannt gibst.
                                N Offline
                                N Offline
                                n811e
                                #72
                                sudo apt update
                                OK:1 http://security.debian.org/debian-security bookworm-security InRelease
                                OK:2 http://deb.debian.org/debian bookworm InRelease
                                Holen:3 http://deb.debian.org/debian bookworm-updates InRelease [52,1 kB]
                                Holen:4 http://archive.raspberrypi.org/debian bookworm InRelease [23,6 kB]
                                OK:5 https://apt.pivccu.de/piVCCU stable InRelease
                                OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Holen:7 http://archive.raspberrypi.org/debian bookworm/main armhf Packages [362 kB]
                                Es wurden 438 kB in 4 s geholt (112 kB/s).
                                Aktualisierung für 2 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                W: http://security.debian.org/debian-security/dists/bookworm-security/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                                W: http://deb.debian.org/debian/dists/bookworm/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                                W: http://deb.debian.org/debian/dists/bookworm-updates/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                                • N n811e
                                  sudo apt update
                                  #73
                                  sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                                  sudo apt update
                                  sudo apt full-upgrade
                                    sudo apt update
                                    N Offline
                                    N Offline
                                    n811e
                                    #74
                                    ok, habe ich so gemacht
                                    Zigbee bleibt aber auch nach einem Neustart Gelb 😕
                                    • N n811e
                                      #75
                                      @n811e
                                      Dann zeig mal einen Kaltstart der Instanz.
                                      Und die aktuelle Ausgabe von
                                      iob diag
                                      N 2 Antworten Letzte Antwort
                                        @n811e
                                        iob diag
                                        N Offline
                                        N Offline
                                        n811e
                                        #76
                                        iob diag
                                        da kommt folgendes raus:
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm
                                        Model           : Raspberry Pi 4 Model B Rev 1.4
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : armv7l
                                        Userland        : armhf
                                        Systemuptime and Load:
                                         21:17:24 up 52 min,  2 users,  load average: 1.87, 1.77, 1.70
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** Time and Time Zones ***
                                                       Local time: Tue 2024-01-30 21:17:25 CET
                                                   Universal time: Tue 2024-01-30 20:17:25 UTC
                                                         RTC time: Tue 2024-01-30 20:17:25
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        *** X-Server-Setup ***
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            8.3G        2.4G        5.7G        1.0M        355M        5.8G
                                        Swap:           104M          0B        104M
                                                 7898 M total memory
                                                 2320 M used memory
                                                  106 M active memory
                                                 2196 M inactive memory
                                                 5464 M free memory
                                                   32 M buffer memory
                                                  306 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4      117G  8.0G  105G   8% /
                                        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                        tmpfs          tmpfs     1.6G  912K  1.6G   1% /run
                                        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                                        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                        tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                                        [Tue Jan 30 20:24:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CB:3B:DC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4927e89a-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Tue Jan 30 20:24:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Tue Jan 30 20:24:32 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Tue Jan 30 20:24:36 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        TARGET  SOURCE         FSTYPE OPTIONS
                                        /       /dev/mmcblk0p2 ext4   rw,noatime
                                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                        /var:
                                        2.0G    /var/
                                        1.1G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
                                        1.1G    /var/log
                                        709M    /var/lib
                                        Archived and active journals take up 1.0G in the file system.
                                        /opt/iobroker/backups:
                                        93M     /opt/iobroker/backups/
                                        4.0K    /opt/iobroker/backups/redistmp
                                        /opt/iobroker/iobroker-data:
                                        477M    /opt/iobroker/iobroker-data/
                                        317M    /opt/iobroker/iobroker-data/files
                                        102M    /opt/iobroker/iobroker-data/backup-objects
                                        67M     /opt/iobroker/iobroker-data/files/javascript.admin
                                        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        34M     /opt/iobroker/iobroker-data/objects.jsonl
                                        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                        27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
                                        25M     /opt/iobroker/iobroker-data/states.jsonl
                                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_46f93a68f7d8eb11893d0815b9da5f8b-if00-port0
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Installed: 18.19.0-1nodesource1
                                          Candidate: 18.19.0-1nodesource1
                                          Version table:
                                             18.19.0+dfsg-6~deb12u1 500
                                                500 http://security.debian.org/debian-security bookworm-security/main armhf Packages
                                         *** 18.19.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                             18.18.2-1nodesource1 1001
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0+dfsg1-1 500
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                        No problems detected
                                        Errors in npm tree:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller:  5.0.17
                                        admin:          6.12.0
                                        javascript:     7.1.6
                                        Adapters from github:   1
                                        Adapter State
                                        + system.adapter.admin.3                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                        + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
                                        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
                                        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                                        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                                        + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                        + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                                        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                        + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                                        + system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
                                        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                                        + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
                                        + system.adapter.omada.0                  : omada                 : raspberrypi                              -  enabled, port: 443
                                        + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                                        + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                                        + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
                                        + system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi                              -  enabled, port: 8002
                                        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                                        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
                                        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                                        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                        + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                          system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
                                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                                          system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                                        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                                        + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                                        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_46f93a68f7d8eb11893d0815b9da5f8b-if00-port0
                                          system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
                                        + instance is alive
                                        ioBroker-Repositories
                                        Installed ioBroker-Instances
                                        Used repository: stable
                                        Adapter    "admin"        : 6.13.15  , installed 6.12.0 [Updatable]
                                        Adapter    "alexa2"       : 3.26.4   , installed 3.26.3 [Updatable]
                                        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                                        Adapter    "device-watcher": 2.9.6   , installed 2.9.6
                                        Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                                        Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
                                        Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                                        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                        Adapter    "hm-rpc"       : 1.16.0   , installed 1.15.19 [Updatable]
                                        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                                        Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                        Controller "js-controller": 5.0.17   , installed 5.0.17
                                        Adapter    "klf200"       : 1.1.2    , installed 1.1.2
                                        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                                        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                                        Adapter    "onvif"        : 1.1.1    , installed 1.1.1
                                        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                                        Adapter    "samsung_tizen": 1.0.0    , installed 1.0.0
                                        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                        Adapter    "synology"     : 3.0.1    , installed 3.0.1
                                        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                        Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                                        Adapter    "web"          : 6.2.3    , installed 6.1.10 [Updatable]
                                        Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                        Adapter    "worx"         : 2.3.4    , installed 2.3.4
                                        Adapter    "ws"           : 2.5.10   , installed 2.5.8  [Updatable]
                                        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                                        Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
                                        Objects and States
                                        Objects:        19613
                                        States:         15311
                                        Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
                                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                                        Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
                                        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       19220      2620/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19188      2568/io.shelly.1
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21636      2483/io.sonoff.0
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17641      964/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17653      964/iobroker.js-con
                                        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14899      1035/dnsmasq
                                        tcp        0      0 192.168.2.113:9292      0.0.0.0:*               LISTEN      1001       18414      2281/io.hm-rpc.2
                                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       24624      2907/io.jarvis.0
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17410      1024/sshd: /usr/sbi
                                        tcp        0      0 192.168.2.113:12010     0.0.0.0:*               LISTEN      1001       17407      2232/io.hm-rpc.1
                                        tcp        0      0 192.168.2.113:12001     0.0.0.0:*               LISTEN      1001       19532      2200/io.hm-rpc.0
                                        tcp6       0      0 :::8095                 :::*                    LISTEN      1001       23137      3015/io.onvif.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21252      2795/io.web.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17072      1811/io.admin.3
                                        tcp6       0      0 :::8000                 :::*                    LISTEN      1001       25799      2868/io.upnp.0
                                        tcp6       0      0 :::46799                :::*                    LISTEN      1001       20335      2808/io.yahka.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          17412      1024/sshd: /usr/sbi
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23644      2949/io.wled.0
                                        udp        0      0 192.168.2.113:5353      0.0.0.0:*                           1001       20016      2512/io.tr-064.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12028      403/avahi-daemon: r
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21502      2868/io.upnp.0
                                        udp        0      0 0.0.0.0:35724           0.0.0.0:*                           1001       23568      2868/io.upnp.0
                                        udp        0      0 0.0.0.0:40457           0.0.0.0:*                           108        12030      403/avahi-daemon: r
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21897      2633/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21898      2633/io.tuya.0
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       20629      2412/io.shelly.0
                                        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14898      1035/dnsmasq
                                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14895      1035/dnsmasq
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          909        846/dhclient
                                        udp6       0      0 :::51412                :::*                                108        12031      403/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                108        12029      403/avahi-daemon: r
                                        2024-01-30 21:14:11.605  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
                                        2024-01-30 21:14:11.628  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
                                        2024-01-30 21:14:39.489  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
                                        2024-01-30 21:15:06.296  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
                                        2024-01-30 21:15:06.325  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
                                        2024-01-30 21:15:09.499  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
                                        2024-01-30 21:15:15.639  - info: tr-064.0 (2512) forEachConfiguredDevice: in GetSpecificHostEntry 13(fritz.box/08:96:D7:8B:8C:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                        2024-01-30 21:15:39.543  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
                                        2024-01-30 21:16:02.990  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
                                        2024-01-30 21:16:03.009  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
                                        2024-01-30 21:16:09.575  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
                                        2024-01-30 21:16:39.565  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
                                        2024-01-30 21:16:47.975  - info: tr-064.0 (2512) forEachConfiguredDevice: in GetSpecificHostEntry 13(fritz.box/08:96:D7:8B:8C:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                        2024-01-30 21:16:59.510  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
                                        2024-01-30 21:16:59.532  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
                                        2024-01-30 21:17:09.594  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
                                        2024-01-30 21:17:39.602  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
                                        2024-01-30 21:17:56.062  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
                                        2024-01-30 21:17:56.088  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
                                        2024-01-30 21:18:09.613  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
                                        2024-01-30 21:18:19.159  - info: tr-064.0 (2512) forEachConfiguredDevice: in GetSpecificHostEntry 13(fritz.box/08:96:D7:8B:8C:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                        2024-01-30 21:18:39.618  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
                                        2024-01-30 21:18:55.875  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
                                        2024-01-30 21:18:55.894  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
                                        2024-01-30 21:19:09.575  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
                                        iob diag has finished.
                                        Press any key for a summary
                                          @n811e
                                          iob diag
                                          N Offline
                                          N Offline
                                          n811e
                                          #77
        v.2023-10-10
                                                 Icon name: computer
                                              Architecture: arm
                                          Kernel:                 armv7l
                                          Userland:               armhf
                                          User-ID:                1000
                                          X-Server:               false
                                          Pending iob updates:    5
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
                                          MEMORY:
                                          Mem:            8.3G        2.5G        5.6G        1.0M        472M        5.8G
                                          Swap:           104M          0B        104M
                                          Total:          8.4G        2.5G        5.7G
        admin                   6.12.0
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                19613
                                          States:                 15311
                                          4.1M    /opt/iobroker/iobroker-data/states.jsonl
