  3. Einsteigerfragen
  4. [gelöst] js-adapter startet immer wieder neu
    5.5k
54 Beiträge 4 Kommentatoren 5.4k Aufrufe 3 Beobachtet
  • fhainzF fhainz
    @homoran Ok, dann versuche ich es in mehreren Beiträgen aufzuteilen.
    Teil 1
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm
      Virtualization: oracle
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 5.15.0-91-generic
        Architecture: x86-64
     Hardware Vendor: innotek GmbH
      Hardware Model: VirtualBox
    model name	: Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
    Docker          : false
    Virtualization  : oracle
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     09:54:08 up 19 min,  2 users,  load average: 0.65, 0.59, 0.42
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Mon 2024-01-15 09:54:08 UTC
               Universal time: Mon 2024-01-15 09:54:08 UTC
                     RTC time: Mon 2024-01-15 09:54:09
                    Time zone: Etc/UTC (UTC, +0000)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    fabian
    /home/fabian
    fabian adm cdrom sudo dip plugdev lxd iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            7.9G        1.8G        5.2G        1.0M        1.0G        5.9G
    Swap:             0B          0B          0B
    Total:          7.9G        1.8G        5.2G
             7938 M total memory
             1755 M used memory
              482 M active memory
             2008 M inactive memory
             5150 M free memory
              118 M buffer memory
              914 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  794M  1.2M  793M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    18G   16G  1.4G  93% /
    tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   1.8G  252M  1.4G  16% /boot
    tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/1000
    [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
    [Mon Jan 15 09:34:20 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    TARGET              SOURCE                            FSTYPE   OPTIONS
    /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/snap/snapd/20671 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/20290 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/2015 /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/24322   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/2105 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
    `-/boot             /dev/sda2                         ext4     rw,relatime
    /var:
    8.6G	/var/
    7.2G	/var/lib
    6.5G	/var/lib/influxdb/engine/data
    Archived and active journals take up 808.3M in the file system.
    /opt/iobroker/backups:
    4.0K	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G	/opt/iobroker/iobroker-data/
    650M	/opt/iobroker/iobroker-data/files
    200M	/opt/iobroker/iobroker-data/history
    190M	/opt/iobroker/iobroker-data/backup-objects
    166M	/opt/iobroker/iobroker-data/files/vis-2
    27M	/opt/iobroker/iobroker-data/states.jsonl
    24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03188557-if00-port0
    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907AG4V-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.19.0
    /usr/bin/node 		v18.19.0
    /usr/bin/npm 		10.2.3
    /usr/bin/npx 		10.2.3
    /usr/bin/corepack 	0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.9~dfsg-1ubuntu3.3 500
            500 http://at.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://at.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
    npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: typescript@5.2.2 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
    npm ERR! extraneous: @aashutoshrathi/word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
    npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
    npm ERR! extraneous: @alcalzone/release-script-core@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
    npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
    npm ERR! extraneous: @alcalzone/release-script-plugin-exec@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
    npm ERR! extraneous: @alcalzone/release-script-plugin-git@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
    npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
    npm ERR! extraneous: @alcalzone/release-script-plugin-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
    npm ERR! extraneous: @alcalzone/release-script-plugin-package@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
    npm ERR! extraneous: @alcalzone/release-script-plugin-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
    npm ERR! extraneous: @alcalzone/release-script@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
    npm ERR! extraneous: @eslint-community/eslint-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
    npm ERR! extraneous: @eslint-community/regexpp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
    npm ERR! extraneous: @eslint/eslintrc@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrc
    npm ERR! extraneous: @eslint/js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
    npm ERR! extraneous: @humanwhocodes/config-array@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
    npm ERR! extraneous: @humanwhocodes/module-importer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
    npm ERR! extraneous: @humanwhocodes/object-schema@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
    npm ERR! extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
    npm ERR! extraneous: @iobroker/testing@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
    npm ERR! extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
    npm ERR! extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat
    npm ERR! extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walk
    npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commons
    npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
    npm ERR! extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
    npm ERR! extraneous: @sinonjs/text-encoding@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
    npm ERR! extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
    npm ERR! extraneous: @types/cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
    npm ERR! extraneous: @types/cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
    npm ERR! extraneous: @types/expect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
    npm ERR! extraneous: @types/http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
    npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker
    npm ERR! invalid: @types/node@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
    npm ERR! extraneous: @types/vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
    npm ERR! extraneous: @ungap/structured-clone@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone
    npm ERR! extraneous: abbrev@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
    npm ERR! extraneous: accepts@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
    npm ERR! extraneous: acorn-globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
    npm ERR! extraneous: acorn-jsx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
    npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
    npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv
    npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-shared
    npm ERR! extraneous: ansi-align@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
    npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
    npm ERR! extraneous: ansi-gray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
    npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
    npm ERR! extraneous: ansi-styles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
    npm ERR! extraneous: ansi-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
    npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
    npm ERR! extraneous: append-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
    npm ERR! extraneous: archy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
    npm ERR! extraneous: argparse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
    npm ERR! extraneous: arr-diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
    npm ERR! extraneous: arr-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
    npm ERR! extraneous: arr-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
    npm ERR! extraneous: arr-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
    npm ERR! extraneous: arr-union@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
    npm ERR! extraneous: array-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
    npm ERR! extraneous: array-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
    npm ERR! extraneous: array-initial@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
    npm ERR! extraneous: array-last@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
    npm ERR! extraneous: array-slice@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
    npm ERR! extraneous: array-sort@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
    npm ERR! extraneous: array-unique@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
    npm ERR! extraneous: asn1@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1
    npm ERR! extraneous: assert-plus@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus
    npm ERR! extraneous: assertion-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
    npm ERR! extraneous: assign-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
    npm ERR! extraneous: astral-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
    npm ERR! extraneous: async-done@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
    npm ERR! extraneous: async-each-series@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
    npm ERR! extraneous: async-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
    npm ERR! extraneous: async-settle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
    npm ERR! extraneous: async@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
    npm ERR! extraneous: atob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
    npm ERR! extraneous: aws-sign2@0.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2
    npm ERR! extraneous: aws4@1.12.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4
    npm ERR! invalid: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/axios
    npm ERR! extraneous: bach@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
    npm ERR! extraneous: balanced-match@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
    npm ERR! extraneous: base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
    npm ERR! extraneous: base64id@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
    npm ERR! extraneous: batch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
    npm ERR! extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf
    npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
    npm ERR! extraneous: binaryextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensions
    npm ERR! extraneous: bindings@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bindings
    npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
    npm ERR! extraneous: boxen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
    npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
    npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
    npm ERR! extraneous: browser-request@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
    npm ERR! extraneous: browser-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
    npm ERR! extraneous: browser-sync-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
    npm ERR! extraneous: browser-sync-ui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
    npm ERR! extraneous: browser-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
    npm ERR! extraneous: bs-html-injector@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector
    npm ERR! extraneous: bs-recipes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
    npm ERR! extraneous: buffer-equal@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
    npm ERR! extraneous: buffer-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
    npm ERR! extraneous: bytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
    npm ERR! extraneous: cache-base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
    npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
    npm ERR! extraneous: callsites@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
    npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
    npm ERR! extraneous: caseless@0.12.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless
    npm ERR! extraneous: chai-as-promised@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promised
    npm ERR! extraneous: chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
    npm ERR! extraneous: chalk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
    npm ERR! extraneous: check-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
    npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
    npm ERR! extraneous: class-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
    npm ERR! extraneous: cli-boxes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
    npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
    npm ERR! extraneous: clone-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
    npm ERR! extraneous: clone-stats@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
    npm ERR! extraneous: clone@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
    npm ERR! extraneous: cloneable-readable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
    npm ERR! extraneous: code-point-at@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
    npm ERR! invalid: coffeescript@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript
    npm ERR! extraneous: collection-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
    npm ERR! extraneous: collection-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visit
    npm ERR! extraneous: color-convert@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
    npm ERR! extraneous: color-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
    npm ERR! extraneous: color-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
    npm ERR! extraneous: colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
    npm ERR! extraneous: commander@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
    npm ERR! extraneous: component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
    npm ERR! extraneous: concat-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
    npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
    npm ERR! extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
    npm ERR! extraneous: connect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
    npm ERR! extraneous: content-disposition@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
    npm ERR! extraneous: content-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
    npm ERR! extraneous: convert-source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
    npm ERR! extraneous: cookie-signature@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signature
    npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
    npm ERR! extraneous: copy-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
    npm ERR! extraneous: copy-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
    npm ERR! extraneous: core-util-is@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is
    npm ERR! extraneous: cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
    npm ERR! extraneous: cron-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser
    npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
    npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
    npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
    npm ERR! extraneous: d@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
    npm ERR! extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash
    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/debug
    npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
    npm ERR! extraneous: decode-uri-component@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
    npm ERR! extraneous: deep-eql@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
    npm ERR! extraneous: deep-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
    npm ERR! extraneous: default-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
    npm ERR! extraneous: default-resolution@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
    npm ERR! extraneous: define-data-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property
    npm ERR! extraneous: define-properties@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
    npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
    npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
    npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
    npm ERR! extraneous: detect-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
    npm ERR! extraneous: dev-ip@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
    npm ERR! extraneous: diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
    npm ERR! extraneous: doctrine@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
    npm ERR! extraneous: dom-compare-temp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-temp
    npm ERR! extraneous: dom-serializer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
    npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
    npm ERR! extraneous: domhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
    npm ERR! extraneous: domutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
    npm ERR! extraneous: duplexer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
    npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
    npm ERR! extraneous: each-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
    npm ERR! extraneous: easy-extender@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
    npm ERR! extraneous: eazy-logger@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
    npm ERR! extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn
    npm ERR! extraneous: ee-first@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
    npm ERR! extraneous: emoji-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
    npm ERR! extraneous: encodeurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
    npm ERR! extraneous: end-of-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
    npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client
    npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parser
    npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
    npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
    npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
    npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
    npm ERR! extraneous: es5-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
    npm ERR! extraneous: es6-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
    npm ERR! extraneous: es6-symbol@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
    npm ERR! extraneous: es6-weak-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
    npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
    npm ERR! extraneous: escape-html@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
    npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
    npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
    npm ERR! extraneous: eslint-scope@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
    npm ERR! extraneous: eslint-visitor-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
    npm ERR! extraneous: eslint@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
    npm ERR! extraneous: espree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
    npm ERR! extraneous: esprima@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
    npm ERR! extraneous: esquery@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
    npm ERR! extraneous: esrecurse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
    npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
    npm ERR! extraneous: esutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
    npm ERR! extraneous: etag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
    npm ERR! extraneous: event-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
    npm ERR! extraneous: eventemitter3@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
    npm ERR! extraneous: execa@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
    npm ERR! extraneous: expand-brackets@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
    npm ERR! extraneous: expand-tilde@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
    npm ERR! extraneous: express@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
    npm ERR! extraneous: ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
    npm ERR! extraneous: extend@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend
    npm ERR! extraneous: extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
    npm ERR! extraneous: extsprintf@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf
    npm ERR! extraneous: fancy-log@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
    npm ERR! extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal
    npm ERR! extraneous: fast-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
    npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify
    npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshtein
    npm ERR! extraneous: fastq@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
    npm ERR! extraneous: file-entry-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cache
    npm ERR! extraneous: file-uri-to-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-uri-to-path
    npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
    npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
    npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
    npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync
    npm ERR! extraneous: fined@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined
    npm ERR! extraneous: flagged-respawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flagged-respawn
    npm ERR! extraneous: flat-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat-cache
    npm ERR! extraneous: flat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat
    npm ERR! extraneous: flatted@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flatted
    npm ERR! extraneous: flush-write-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flush-write-stream
    npm ERR! extraneous: follow-redirects@1.15.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects
    npm ERR! extraneous: for-in@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-in
    npm ERR! extraneous: for-own@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-own
    npm ERR! extraneous: forever-agent@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent
    npm ERR! extraneous: forwarded@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/forwarded
    npm ERR! extraneous: fragment-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fragment-cache
    npm ERR! extraneous: fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fresh
    npm ERR! extraneous: from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/from
    npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-extra
    npm ERR! extraneous: fs-mkdirp-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-mkdirp-stream
    npm ERR! extraneous: fs.realpath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs.realpath
    npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fsevents
    npm ERR! extraneous: function-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind
    npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-caller-file
    npm ERR! extraneous: get-func-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-func-name
    npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic
    npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-stream
    npm ERR! extraneous: get-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-value
    npm ERR! extraneous: getpass@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass
    npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-parent
    npm ERR! extraneous: glob-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream
    npm ERR! extraneous: glob-watcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher
    npm ERR! extraneous: glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
    npm ERR! extraneous: global-modules@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-modules
    npm ERR! extraneous: global-prefix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix
    npm ERR! extraneous: globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globals
    npm ERR! extraneous: globalyzer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globalyzer
    npm ERR! extraneous: globrex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globrex
    npm ERR! extraneous: glogg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glogg
    npm ERR! extraneous: gopd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gopd
    npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs
    npm ERR! extraneous: graphemer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graphemer
    npm ERR! extraneous: gulp-cli@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli
    npm ERR! extraneous: gulp-rename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
    npm ERR! extraneous: gulp-replace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
    npm ERR! extraneous: gulp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
    npm ERR! extraneous: gulplog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulplog
    npm ERR! extraneous: har-schema@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema
    npm ERR! extraneous: har-validator@5.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator
    npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-flag
    npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors
    npm ERR! extraneous: has-proto@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-proto
    npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols
    npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-value
    npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values
    npm ERR! extraneous: hasown@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/hasown
    npm ERR! extraneous: he@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/he
    npm ERR! extraneous: homedir-polyfill@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/homedir-polyfill
    npm ERR! extraneous: hosted-git-info@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/hosted-git-info
    npm ERR! extraneous: htmlparser2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2
    npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-errors
    npm ERR! extraneous: http-proxy-middleware@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy-middleware
    npm ERR! extraneous: http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy
    npm ERR! extraneous: http-signature@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature
    npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals
    npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
    npm ERR! extraneous: ignore-by-default@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore-by-default
    npm ERR! extraneous: ignore@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore
    npm ERR! extraneous: immediate@3.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate
    npm ERR! extraneous: immutable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/immutable
    npm ERR! extraneous: import-fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh
    npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash
    npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
    npm ERR! extraneous: inherits@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits
    npm ERR! extraneous: ini@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini
    npm ERR! extraneous: interpret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret
    npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv
    npm ERR! extraneous: ipaddr.js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ipaddr.js
    npm ERR! extraneous: is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute
    npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor
    npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish
    npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path
    npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer
    npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module
    npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor
    npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor
    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable
    npm ERR! extraneous: is-extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob
    npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point
    npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob
    npm ERR! extraneous: is-negated-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob
    npm ERR! extraneous: is-number-like@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number-like
    npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number
    npm ERR! extraneous: is-path-inside@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside
    npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj
    npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object
    npm ERR! extraneous: is-relative@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative
    npm ERR! extraneous: is-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-stream
    npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray
    npm ERR! extraneous: is-unc-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path
    npm ERR! extraneous: is-unicode-supported@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported
    npm ERR! extraneous: is-utf8@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8
    npm ERR! extraneous: is-valid-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob
    npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows
    npm ERR! extraneous: is-wsl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-wsl
    npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray
    npm ERR! extraneous: isexe@
    npm ERR! A complete log of this run can be found in: /home/fabian/.npm/_logs/2024-01-15T09_54_11_756Z-debug-0.log
    so geht es noch einige zeilen weiter...
    fhainzF Offline
    fhainzF Offline
    fhainz
    nach dem npm ERR! ... kommt noch das:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.17
    admin: 		6.12.0
    javascript: 	7.1.6
    Adapters from github: 	2
    Adapter State
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
      system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
    + system.adapter.govee-local.0            : govee-local           : iobroker                                 -  enabled
      system.adapter.govee.0                  : govee                 : iobroker                                 - disabled
      system.adapter.history.0                : history               : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
      system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1884
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
    + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
    + system.adapter.owfs.0                   : owfs                  : iobroker                                 -  enabled, port: 4304
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      system.adapter.pvforecast.0             : pvforecast            : iobroker                                 - disabled
      system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
    + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1887, bind: 0.0.0.0
    + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB1
    + instance is alive
    ioBroker-Repositories
    List is empty
    Installed ioBroker-Instances
    Error: Object "system.repositories" not found
    Objects and States
    Objects: 	11044
    States: 	8689
    Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        21829      660/systemd-resolve
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20100      734/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15796      1/init
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22586      799/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       22433      799/iobroker.js-con
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22666      953/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       24575      1229/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25139      1274/io.socketio.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        22198      702/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20114      734/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          15798      1/init
    udp        0      0 0.0.0.0:45390           0.0.0.0:*                           1001       25163      1259/io.govee-local
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24122      1101/io.shelly.0
    udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       25009      1259/io.govee-local
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        21828      660/systemd-resolve
    udp        0      0 10.0.100.233:68         0.0.0.0:*                           101        19831      658/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15797      1/init
    udp6       0      0 :::111                  :::*                                0          15799      1/init
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49 {
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]: }
    2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
    2024-01-15 09:54:18.187  - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-15 09:54:18.187  - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
    iob diag has finished.
    Press any key for a summary
    • fhainzF fhainz
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.12.0
      javascript: 	7.1.6
      Adapter State
      + instance is alive
      List is empty
      Objects and States
      Objects: 	11044
      States: 	8689
      Pending Updates: 0
      @fhainz hast du an den Skripten etwas verändert?
      der Adapter wird beendet, und ein modul cron-parser angemeckert.
      Hast du das zusätzlich installiert?
      startet wirklich der controller neu?
      fhainzF 1 Antwort Letzte Antwort
      • fhainzF fhainz
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.12.0
        javascript: 	7.1.6
        Adapter State
        + instance is alive
        List is empty
        Objects and States
        Objects: 	11044
        States: 	8689
        Pending Updates: 0
        @fhainz sagte in js-controller startet immer wieder neu:
        javascript
        Installier den Adapter javascript nochmal.
          fhainzF Offline
          fhainzF Offline
          fhainz
          Nein, wie gsagt, bin heute morgen auf und nichts ging mehr. Hab gestern nur an der vis-2 gebastelt. Hab auch alle Skripte, sowie den vis und den vis-2 adapter deaktiviert.
          Nein, cron-parser hab ich nicht (bewusst) installiert.
          Ja, der Javascript Adapter startet immer wieder, mit den unterstehenden Meldungen, neu.
          host.iobroker
          2024-01-15 11:26:36.598	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:26:36.598	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:26:36.597	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:26:36.354	info	instance system.adapter.javascript.0 started with pid 6146
          host.iobroker
          2024-01-15 11:26:06.287	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:26:06.287	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:26:06.287	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:26:06.287	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:26:06.287	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:26:06.287	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:26:06.287	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:26:06.286	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:26:06.078	info	instance system.adapter.javascript.0 started with pid 6139
          host.iobroker
          2024-01-15 11:25:35.947	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:25:35.947	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:25:35.947	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:25:35.946	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:25:35.945	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:25:35.945	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:25:35.945	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:25:35.945	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:25:35.749	info	instance system.adapter.javascript.0 started with pid 6132
          host.iobroker
          2024-01-15 11:25:05.702	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:25:05.702	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:25:05.701	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          2024-01-15 11:25:05.701	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:25:05.701	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:25:05.699	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:25:05.699	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:25:05.699	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:25:05.699	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:25:05.699	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:25:05.699	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:25:05.699	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:25:05.699	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:25:05.698	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:25:05.698	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:25:05.698	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:25:05.466	info	instance system.adapter.javascript.0 started with pid 6125
          host.iobroker
          2024-01-15 11:24:35.396	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:24:35.396	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:24:35.396	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:24:35.395	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:24:35.161	info	instance system.adapter.javascript.0 started with pid 6115
          host.iobroker
          2024-01-15 11:24:05.122	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:24:05.122	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:24:05.121	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:24:04.869	info	instance system.adapter.javascript.0 started with pid 6107
          host.iobroker
          2024-01-15 11:23:34.777	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:23:34.777	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:23:34.776	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:23:34.567	info	instance system.adapter.javascript.0 started with pid 6100
          host.iobroker
          2024-01-15 11:23:04.513	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:23:04.513	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:23:04.513	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:23:04.513	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:23:04.513	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:23:04.513	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:23:04.513	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:23:04.513	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:23:04.512	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:23:04.268	info	instance system.adapter.javascript.0 started with pid 6086
          host.iobroker
          2024-01-15 11:22:34.229	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:22:34.229	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:22:34.229	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:22:34.229	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:22:34.228	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:22:34.227	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:22:34.022	info	instance system.adapter.javascript.0 started with pid 5942
          host.iobroker
          2024-01-15 11:22:03.982	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:22:03.982	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:22:03.982	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:22:03.981	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:22:03.980	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:22:03.980	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:22:03.980	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:22:03.980	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:22:03.980	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:22:03.980	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:22:03.711	info	instance system.adapter.javascript.0 started with pid 5935
          host.iobroker
          2024-01-15 11:21:33.652	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:21:33.652	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:21:33.652	error	Caught by controller[0]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:21:33.652	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:21:33.652	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:21:33.652	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:21:33.652	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:21:33.652	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:21:33.652	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:21:33.651	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:21:33.650	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:21:33.650	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:21:33.431	info	instance system.adapter.javascript.0 started with pid 5928
          host.iobroker
          2024-01-15 11:21:03.380	info	Restart adapter system.adapter.javascript.0 because enabled
          host.iobroker
          2024-01-15 11:21:03.380	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[1]: Node.js v18.19.0
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: }
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
          host.iobroker
          host.iobroker
          host.iobroker
          2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
          host.iobroker
          2024-01-15 11:21:03.379	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
          host.iobroker
          2024-01-15 11:21:03.379	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
          host.iobroker
          2024-01-15 11:21:03.379	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
          host.iobroker
          2024-01-15 11:21:03.379	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
          host.iobroker
          2024-01-15 11:21:03.379	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
          host.iobroker
          2024-01-15 11:21:03.379	error	Caught by controller[0]: at parse (<anonymous>)
          host.iobroker
          2024-01-15 11:21:03.379	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
          host.iobroker
          2024-01-15 11:21:03.379	error	Caught by controller[0]: ^
          host.iobroker
          2024-01-15 11:21:03.379	error	Caught by controller[0]: throw error;
          host.iobroker
          2024-01-15 11:21:03.379	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
          host.iobroker
          2024-01-15 11:21:03.174	info	instance system.adapter.javascript.0 started with pid 5921
          Die Uhrzeit passt nun plötzlich wieder.
          In den Repository-Einstellungen verschwinden nach dem Speichern beide Einträge wieder.
            javascript
            fhainzF Offline
            fhainzF Offline
            fhainz
            Hab ich getan. Leider keine Änderung.
            host.iobroker
            2024-01-15 11:30:38.294	info	Restart adapter system.adapter.javascript.0 because enabled
            host.iobroker
            2024-01-15 11:30:38.294	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: Node.js v18.19.0
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: }
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
            host.iobroker
            host.iobroker
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
            host.iobroker
            2024-01-15 11:30:38.294	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
            host.iobroker
            2024-01-15 11:30:38.293	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
            host.iobroker
            2024-01-15 11:30:38.293	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
            host.iobroker
            2024-01-15 11:30:38.293	error	Caught by controller[0]: at parse (<anonymous>)
            host.iobroker
            2024-01-15 11:30:38.293	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
            host.iobroker
            2024-01-15 11:30:38.293	error	Caught by controller[0]: ^
            host.iobroker
            2024-01-15 11:30:38.293	error	Caught by controller[0]: throw error;
            host.iobroker
            2024-01-15 11:30:38.293	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
            host.iobroker
            2024-01-15 11:30:38.058	info	instance system.adapter.javascript.0 started with pid 6221
            host.iobroker
            2024-01-15 11:30:36.470	error	cannot call visUtils: Not exists
            • fhainzF fhainz
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              @fhainz sagte in js-controller startet immer wieder neu:
              Ja, der Javascript Adapter startet immer wieder,
              aber laut Threadtitel der js-controller!!
              und danach suche ich die ganze Zeit
              fhainzF 1 Antwort Letzte Antwort
              • fhainzF fhainz
                Nein, wie gsagt, bin heute morgen auf und nichts ging mehr. Hab gestern nur an der vis-2 gebastelt. Hab auch alle Skripte, sowie den vis und den vis-2 adapter deaktiviert.
                Nein, cron-parser hab ich nicht (bewusst) installiert.
                Ja, der Javascript Adapter startet immer wieder, mit den unterstehenden Meldungen, neu.
                host.iobroker
                2024-01-15 11:26:36.598	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:26:36.598	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:26:36.597	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:26:36.354	info	instance system.adapter.javascript.0 started with pid 6146
                host.iobroker
                2024-01-15 11:26:06.287	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:26:06.287	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:26:06.287	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:26:06.287	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:26:06.287	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:26:06.287	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:26:06.287	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:26:06.286	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:26:06.078	info	instance system.adapter.javascript.0 started with pid 6139
                host.iobroker
                2024-01-15 11:25:35.947	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:25:35.947	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:25:35.947	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:25:35.946	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:25:35.945	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:25:35.945	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:25:35.945	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:25:35.945	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:25:35.749	info	instance system.adapter.javascript.0 started with pid 6132
                host.iobroker
                2024-01-15 11:25:05.702	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:25:05.702	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:25:05.701	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                2024-01-15 11:25:05.701	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:25:05.701	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:25:05.699	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:25:05.699	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:25:05.699	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:25:05.699	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:25:05.699	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:25:05.699	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:25:05.699	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:25:05.699	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:25:05.698	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:25:05.698	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:25:05.698	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:25:05.466	info	instance system.adapter.javascript.0 started with pid 6125
                host.iobroker
                2024-01-15 11:24:35.396	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:24:35.396	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:24:35.396	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:24:35.395	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:24:35.161	info	instance system.adapter.javascript.0 started with pid 6115
                host.iobroker
                2024-01-15 11:24:05.122	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:24:05.122	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:24:05.121	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:24:04.869	info	instance system.adapter.javascript.0 started with pid 6107
                host.iobroker
                2024-01-15 11:23:34.777	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:23:34.777	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:23:34.776	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:23:34.567	info	instance system.adapter.javascript.0 started with pid 6100
                host.iobroker
                2024-01-15 11:23:04.513	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:23:04.513	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:23:04.513	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:23:04.513	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:23:04.513	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:23:04.513	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:23:04.513	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:23:04.513	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:23:04.512	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:23:04.268	info	instance system.adapter.javascript.0 started with pid 6086
                host.iobroker
                2024-01-15 11:22:34.229	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:22:34.229	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:22:34.229	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:22:34.229	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:22:34.228	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:22:34.227	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:22:34.022	info	instance system.adapter.javascript.0 started with pid 5942
                host.iobroker
                2024-01-15 11:22:03.982	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:22:03.982	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:22:03.982	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:22:03.981	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:22:03.980	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:22:03.980	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:22:03.980	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:22:03.980	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:22:03.980	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:22:03.980	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:22:03.711	info	instance system.adapter.javascript.0 started with pid 5935
                host.iobroker
                2024-01-15 11:21:33.652	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:21:33.652	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:21:33.652	error	Caught by controller[0]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:21:33.652	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:21:33.652	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:21:33.652	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:21:33.652	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:21:33.652	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:21:33.652	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:21:33.651	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:21:33.650	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:21:33.650	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:21:33.431	info	instance system.adapter.javascript.0 started with pid 5928
                host.iobroker
                2024-01-15 11:21:03.380	info	Restart adapter system.adapter.javascript.0 because enabled
                host.iobroker
                2024-01-15 11:21:03.380	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[1]: Node.js v18.19.0
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: }
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                host.iobroker
                host.iobroker
                host.iobroker
                2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                host.iobroker
                2024-01-15 11:21:03.379	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                host.iobroker
                2024-01-15 11:21:03.379	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                host.iobroker
                2024-01-15 11:21:03.379	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                host.iobroker
                2024-01-15 11:21:03.379	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                host.iobroker
                2024-01-15 11:21:03.379	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                host.iobroker
                2024-01-15 11:21:03.379	error	Caught by controller[0]: at parse (<anonymous>)
                host.iobroker
                2024-01-15 11:21:03.379	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                host.iobroker
                2024-01-15 11:21:03.379	error	Caught by controller[0]: ^
                host.iobroker
                2024-01-15 11:21:03.379	error	Caught by controller[0]: throw error;
                host.iobroker
                2024-01-15 11:21:03.379	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                host.iobroker
                2024-01-15 11:21:03.174	info	instance system.adapter.javascript.0 started with pid 5921
                Die Uhrzeit passt nun plötzlich wieder.
                In den Repository-Einstellungen verschwinden nach dem Speichern beide Einträge wieder.
                auch den Javascript Adapter?
                  fhainzF Offline
                  fhainzF Offline
                  fhainz
                  Entschuldigung.. Wusste nicht das es einen Unterscheid gibt. Hab die formulierung anscheinend aus dieser Fehlermeldung übernommen.
                  2024-01-15 11:30:38.294	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.iobroker
                  Da steht auch JS_CONTROLLER
                  • fhainzF fhainz
                    host.iobroker
                    @fhainz
                    Frisches
                    iob diag
                    bitte.
                      fhainzF Offline
                      fhainzF Offline
                      fhainz
                      Nein, der ist aktiv und Rot markiert.
                      • fhainzF fhainz
                        host.iobroker
                        der js-controller ist das Herzstück von iobroker und regelt alles
                        deswegen stoppt der controller auch den javascript-Adapter, weil der anscheinend ein Problem hat.
                        dann stop ihn
                          @fhainz
                          Frisches
                          iob diag
                          bitte.
                          fhainzF Offline
                          fhainzF Offline
                          fhainz
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                           Static hostname: iobroker
                                 Icon name: computer-vm
                                   Chassis: vm
                            Virtualization: oracle
                          Operating System: Ubuntu 22.04.3 LTS
                                    Kernel: Linux 5.15.0-91-generic
                              Architecture: x86-64
                           Hardware Vendor: innotek GmbH
                            Hardware Model: VirtualBox
                          model name	: Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
                          Docker          : false
                          Virtualization  : oracle
                          Kernel          : x86_64
                          Userland        : amd64
                          Systemuptime and Load:
                           10:36:59 up  1:02,  2 users,  load average: 1.68, 1.01, 0.68
                          CPU threads: 2
                          *** Time and Time Zones ***
                                         Local time: Mon 2024-01-15 10:36:59 UTC
                                     Universal time: Mon 2024-01-15 10:36:59 UTC
                                           RTC time: Mon 2024-01-15 10:36:59
                                          Time zone: Etc/UTC (UTC, +0000)
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          fabian
                          /home/fabian
                          fabian adm cdrom sudo dip plugdev lxd iobroker
                          *** X-Server-Setup ***
                          X-Server: 	false
                          Desktop:
                          Terminal: 	tty
                          Boot Target: 	graphical.target
                          *** MEMORY ***
                          Mem:            7.9G        1.9G        5.0G        1.0M        1.1G        5.8G
                          Swap:             0B          0B          0B
                          Total:          7.9G        1.9G        5.0G
                                   7938 M total memory
                                   1913 M used memory
                                    511 M active memory
                                   2158 M inactive memory
                                   4957 M free memory
                                    145 M buffer memory
                                    921 M swap cache
                                      0 M total swap
                                      0 M used swap
                                      0 M free swap
                          *** FAILED SERVICES ***
                          0 loaded units listed.
                          *** FILESYSTEM ***
                          Filesystem                        Type   Size  Used Avail Use% Mounted on
                          tmpfs                             tmpfs  794M  1.2M  793M   1% /run
                          /dev/mapper/ubuntu--vg-ubuntu--lv ext4    18G   16G  1.4G  93% /
                          tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
                          tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                          /dev/sda2                         ext4   1.8G  252M  1.4G  16% /boot
                          tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/1000
                          [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                          [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
                          [Mon Jan 15 09:34:20 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                          TARGET              SOURCE                            FSTYPE   OPTIONS
                          /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
                          |-/snap/snapd/20671 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
                          |-/snap/snapd/20290 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
                          |-/snap/core20/2015 /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
                          |-/snap/lxd/24322   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
                          |-/snap/core20/2105 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
                          `-/boot             /dev/sda2                         ext4     rw,relatime
                          /var:
                          8.6G	/var/
                          7.2G	/var/lib
                          6.5G	/var/lib/influxdb/engine/data
                          Archived and active journals take up 816.3M in the file system.
                          /opt/iobroker/backups:
                          4.0K	/opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          1.1G	/opt/iobroker/iobroker-data/
                          650M	/opt/iobroker/iobroker-data/files
                          200M	/opt/iobroker/iobroker-data/history
                          190M	/opt/iobroker/iobroker-data/backup-objects
                          166M	/opt/iobroker/iobroker-data/files/vis-2
                          24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                          24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                          23M	/opt/iobroker/iobroker-data/states.jsonl
                          23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                          22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
                          USB-Devices by-id:
                          /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03188557-if00-port0
                          /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907AG4V-if00-port0
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs 	v18.19.0
                          /usr/bin/node 		v18.19.0
                          /usr/bin/npm 		10.2.3
                          /usr/bin/npx 		10.2.3
                          /usr/bin/corepack 	0.22.0
                          nodejs:
                            Installed: 18.19.0-1nodesource1
                            Candidate: 18.19.0-1nodesource1
                            Version table:
                           *** 18.19.0-1nodesource1 500
                                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                               18.18.2-1nodesource1 500
                               18.18.1-1nodesource1 500
                               18.18.0-1nodesource1 500
                               18.17.1-1nodesource1 500
                               18.17.0-1nodesource1 500
                               18.16.1-1nodesource1 500
                               18.16.0-1nodesource1 500
                               18.15.0-1nodesource1 500
                               18.14.2-1nodesource1 500
                               18.14.1-1nodesource1 500
                               18.14.0-1nodesource1 500
                               18.13.0-1nodesource1 500
                               18.12.0-1nodesource1 500
                               18.11.0-1nodesource1 500
                               18.10.0-1nodesource1 500
                               18.9.1-1nodesource1 500
                               18.9.0-1nodesource1 500
                               18.8.0-1nodesource1 500
                               18.7.0-1nodesource1 500
                               18.6.0-1nodesource1 500
                               18.5.0-1nodesource1 500
                               18.4.0-1nodesource1 500
                               18.3.0-1nodesource1 500
                               18.2.0-1nodesource1 500
                               18.1.0-1nodesource1 500
                               18.0.0-1nodesource1 500
                               12.22.9~dfsg-1ubuntu3.3 500
                                  500 http://at.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                                  500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                               12.22.9~dfsg-1ubuntu3 500
                                  500 http://at.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                          No problems detected
                          Anschließend kommen hunderte Zeilen ala
                          Errors in npm tree:
                          npm ERR! code ELSPROBLEMS
                          npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless
                          npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request
                          npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie
                          Dann geht es wieder mit:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          js-controller: 	5.0.17
                          admin: 		6.12.0
                          javascript: 	7.1.6
                          Adapters from github: 	2
                          Adapter State
                            system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
                            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                            system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                            system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
                          + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                          + system.adapter.govee-local.0            : govee-local           : iobroker                                 -  enabled
                            system.adapter.govee.0                  : govee                 : iobroker                                 - disabled
                            system.adapter.history.0                : history               : iobroker                                 - disabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                            system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
                            system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                            system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                          + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                          + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                          + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
                          + system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
                          + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1884
                          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                            system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
                          + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                          + system.adapter.owfs.0                   : owfs                  : iobroker                                 -  enabled, port: 4304
                            system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                            system.adapter.pvforecast.0             : pvforecast            : iobroker                                 - disabled
                            system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                          + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
                          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                          + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                            system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1887, bind: 0.0.0.0
                          + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
                          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                            system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                            system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB1
                          + instance is alive
                          ioBroker-Repositories
                          List is empty
                          Installed ioBroker-Instances
                          Error: Object "system.repositories" not found
                          Objects and States
                          Objects: 	10841
                          States: 	8517
                          Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease
                          Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
                          Hit:3 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease
                          Hit:4 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease
                          Hit:5 https://repos.influxdata.com/debian stable InRelease
                          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        21829      660/systemd-resolve
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20100      734/sshd: /usr/sbin
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15796      1/init
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22586      799/iobroker.js-con
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       22433      799/iobroker.js-con
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22666      953/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       24575      1229/io.web.0
                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25139      1274/io.socketio.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      998        22198      702/influxd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          20114      734/sshd: /usr/sbin
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          15798      1/init
                          udp        0      0 0.0.0.0:45390           0.0.0.0:*                           1001       25163      1259/io.govee-local
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24122      1101/io.shelly.0
                          udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       25009      1259/io.govee-local
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        21828      660/systemd-resolve
                          udp        0      0 10.0.100.233:68         0.0.0.0:*                           101        19831      658/systemd-network
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15797      1/init
                          udp6       0      0 :::111                  :::*                                0          15799      1/init
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49 {
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[0]: }
                          2024-01-15 10:37:33.662  - error: host.iobroker Caught by controller[1]: Node.js v18.19.0
                          2024-01-15 10:37:33.662  - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2024-01-15 10:37:33.662  - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
                          			v.2023-10-10
                                   Chassis: vm
                          Installation: 		oracle
                          Kernel: 		x86_64
                          Userland: 		amd64
                          Timezone: 		Etc/UTC (UTC, +0000)
                          User-ID: 		1000
                          X-Server: 		false
                          Pending OS-Updates: 	0
                          Pending iob updates: 	0
                          Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
                          			/usr/bin/npm 		10.2.3
                          			/usr/bin/npx 		10.2.3
                          Recommended versions are nodejs 18.19.0 and npm 10.2.3
                          MEMORY:
                          Mem:            7.9G        1.9G        4.9G        1.0M        1.1G        5.7G
                          Swap:             0B          0B          0B
                          Total:          7.9G        1.9G        4.9G
                          Active iob-Instances: 	21
                          List is empty
                          ioBroker Core: 		js-controller 		5.0.17
                          			admin 			6.12.0
                          ioBroker Status: 	iobroker is running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                          Objects: 		10841
                          States: 		8517
                          Size of iob-Database:
                          13M	/opt/iobroker/iobroker-data/objects.jsonl
                          24M	/opt/iobroker/iobroker-data/states.jsonl
                            @fhainz sagte in js-controller startet immer wieder neu:
                            Hab ich getan
                            wie genau durchgeführt?
                            wo ist der Konsolenoutput dazu?
                            waren da H7nweise?
                            fhainzF 1 Antwort Letzte Antwort
                              Hab ich getan
                              waren da H7nweise?
                              fhainzF Offline
                              fhainzF Offline
                              fhainz
                              Ich hab in den Instanzen den JS-Adapter ausgeklappt und auf das Müll Symbol geklickt. Anschließend unter Adapter den JS-Adapter gesucht und nochmals installiert.
                              Kein Konsolen-Output, Keine Hinweise.
                              • fhainzF fhainz
                                dann hast du nur die Instanz entfernt und wieder angekegt, aber nicht den Adapter neu installiert!
                                • fhainzF Offline
                                  fhainzF Offline
                                  fhainz
                                  Eigenartig finde ich auch diese Meldungen.
                                  iobroker
                                  2024-01-15 11:44:51.083	error	cannot call visUtils: Not exists
                                  host.iobroker
                                  2024-01-15 10:44:45.734	error	cannot call visUtils: Not exists
                                  Mal passt die Zeit, mal nicht. vis Adapter sind deaktiviert.
                                  • fhainzF fhainz
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Chassis: vm
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    CPU threads: 2
                                                  NTP service: active
                                              RTC in local TZ: no
                                    fabian
                                    /home/fabian
                                    X-Server: 	false
                                    Desktop:
                                    Terminal: 	tty
                                    *** MEMORY ***
                                    Swap:             0B          0B          0B
                                             7938 M total memory
                                             1913 M used memory
                                              511 M active memory
                                             4957 M free memory
                                              145 M buffer memory
                                              921 M swap cache
                                                0 M total swap
                                                0 M used swap
                                                0 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    8.6G	/var/
                                    7.2G	/var/lib
                                    USB-Devices by-id:
                                    /usr/bin/npm 		10.2.3
                                    /usr/bin/npx 		10.2.3
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin: 		6.12.0
                                    javascript: 	7.1.6
                                    Adapter State
                                    + instance is alive
                                    List is empty
                                    Objects and States
                                    Objects: 	10841
                                    States: 	8517
                                    Pending Updates: 0
                                    			v.2023-10-10
                                             Chassis: vm
                                    Kernel: 		x86_64
                                    Userland: 		amd64
                                    User-ID: 		1000
                                    X-Server: 		false
                                    			/usr/bin/npm 		10.2.3
                                    			/usr/bin/npx 		10.2.3
                                    MEMORY:
                                    Swap:             0B          0B          0B
                                    List is empty
                                    			admin 			6.12.0
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects: 		10841
                                    States: 		8517
                                    @fhainz
                                    sudo timedatectl set-timezone Europe/Berlin
                                    sudo systemctl set-default multi-user.target
                                    iob update
                                    Edit: Kommando korrigiert.
                                      fhainzF Offline
                                      fhainzF Offline
                                      fhainz
                                      Ich denke ich hab den Adapter jetzt gelöscht. Klick auf das Müll-Zeichen in Adapter.
                                      Vermutlich weil meine Repositories leer sind kann ich keine Adapter neu installieren? Habs schon mehrfach händisch eingetragen bzw auf "Repositories auf Standart herstellen" geklickt. Nach dem speichern ist die Liste immer wieder leer.
                                      • fhainzF fhainz
                                        @fhainz
                                        iob repo list
                                        • fhainzF fhainz
                                          gezeigt hast du das aber auch noch nicht
                                          bitte unbedingt lesen und beachten
                                          Den Threadtitel bitte korrigieren!
