  4. Test Adapter TP-Link Tapo
    6.7k
885 Beiträge 123 Kommentatoren 404.2k Aufrufe 107 Beobachtet
  • metaxaM metaxa
    @tombox Servus und Danke!
    Ich habe jetzt über Github upgegradet auf 0.2.2.
    Folgendes finde ich beim Neustart im Log
    tapo.0
    2024-01-12 12:06:12.091	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:06:02.091	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:05:52.090	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:05:42.088	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:05:32.087	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:05:22.087	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:05:12.085	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:05:02.085	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:04:52.084	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:04:42.082	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:04:32.081	warn	Error: Unknown password encryption method
    tapo.0
    2024-01-12 12:04:32.001	info	Start first Update
    tapo.0
    2024-01-12 12:04:21.999	info	Wait for connections for non camera devices
    tapo.0
    2024-01-12 12:04:21.980	warn	No IP found for 8021314EFB57E17626EC16DBDB2A31A51E64292E put the device online or set the ip state manually
    tapo.0
    2024-01-12 12:04:21.976	error	{"error_code":-20571,"msg":"Device is offline"}
    tapo.0
    2024-01-12 12:04:21.575	info	Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
    tapo.0
    2024-01-12 12:04:21.520	info	80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.1.4 Build 230922 Rel.57957n","serialNumber":"31d87f97","hardwareId":1}
    tapo.0
    2024-01-12 12:04:21.451	info	Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.220
    tapo.0
    2024-01-12 12:04:21.244	warn	No IP found for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 put the device online or set the ip state manually
    tapo.0
    2024-01-12 12:04:21.241	error	{"error_code":-20571,"msg":"Device is offline"}
    tapo.0
    2024-01-12 12:04:20.828	info	Found 3 devices
    tapo.0
    2024-01-12 12:04:20.623	info	Login succesfull
    tapo.0
    2024-01-12 12:04:20.275	info	Login tp TAPO App
    tapo.0
    2024-01-12 12:04:20.203	info	starting. Version 0.2.2 (non-npm: TA2k/ioBroker.tapo#e1cf6255f471f8e3271408e7f2cb0c82fc7049c0) in /opt/iobroker/node_modules/iobroker.tapo, node: v18.18.2, js-controller: 5.0.17
    Wie soll das Steuern funktionieren?
    Egal welche Werte ich eingebe, die Cam bewegt sich nicht.
    Edit: Mit dem onvif funktioniert das recht gut:
    tombox
    #368
    @metaxa
    was kommt mit 0.2.3?
    metaxaM 1 Antwort Letzte Antwort
    • H HeliosFan
      @metaxa Zur Steuerung mit onvif:
      Welche App benutzt Du auf dem Handy ? Gibt im Playstore mehrere.
      Und läuft der onvif Adapter gut ?
      metaxaM Offline
      metaxaM Offline
      metaxa
      #369
      @heliosfan Servus! Ich verwende den iO-Broker Adapter onvif zum steuern. Ich will kein Handy zum Steuern verwenden, wenn dann die normale Tapo App. Aber @tombox ist sehr, sehr bemüht mir zu helfen, die Steuerung über seinen Adapter hin zu bekommen. Danke dafür!
      • T tombox
        @metaxa
        metaxaM Offline
        metaxaM Offline
        metaxa
        schrieb am zuletzt editiert von metaxa
        #370
        @tombox sagte in Test Adapter TP-Link Tapo:
        @metaxa
        tapo.0
        2024-01-12 17:27:04.181	info	false
        tapo.0
        2024-01-12 17:26:32.131	error	Device 80219D887A52D32D03212C4C2DE37E4D21EC8028 has no command refresh
        tapo.0
        2024-01-12 17:26:25.552	error	Device 80219D887A52D32D03212C4C2DE37E4D21EC8028 has no command refresh
        tapo.0
        2024-01-12 17:26:12.309	info	false
        tapo.0
        2024-01-12 17:24:36.176	info	Start first Update
        tapo.0
        2024-01-12 17:24:26.175	info	Wait for connections for non camera devices
        tapo.0
        2024-01-12 17:24:26.170	warn	No IP found for 8021314EFB57E17626EC16DBDB2A31A51E64292E put the device online or set the ip state manually
        tapo.0
        2024-01-12 17:24:26.169	error	{"error_code":-20571,"msg":"Device is offline"}
        tapo.0
        2024-01-12 17:24:25.769	info	Initialized 80219D887A52D32D03212C4C2DE37E4D21EC8028
        tapo.0
        2024-01-12 17:24:25.765	info	80219D887A52D32D03212C4C2DE37E4D21EC8028 Received device info {"manufacturer":"tp-link","model":"Tapo C520WS","firmwareVersion":"1.1.4 Build 230922 Rel.57957n","serialNumber":"31d87f97","hardwareId":1}
        tapo.0
        2024-01-12 17:24:25.708	info	Init device 80219D887A52D32D03212C4C2DE37E4D21EC8028 type C520WS 1.0 with ip 192.168.0.220
        tapo.0
        2024-01-12 17:24:25.500	warn	No IP found for 8021CDA220ADD1EE6A8E7E7D0F7DFE861E649CA0 put the device online or set the ip state manually
        tapo.0
        2024-01-12 17:24:25.497	error	{"error_code":-20571,"msg":"Device is offline"}
        tapo.0
        2024-01-12 17:24:25.034	info	Found 3 devices
        tapo.0
        2024-01-12 17:24:24.793	info	Login succesfull
        tapo.0
        2024-01-12 17:24:24.306	info	Login tp TAPO App
        tapo.0
        2024-01-12 17:24:24.278	info	starting. Version 0.2.3 (non-npm: TA2k/ioBroker.tapo#bbec46cc9c1e1ab503c391c237783108d1e02785) in /opt/iobroker/node_modules/iobroker.tapo, node: v18.18.2, js-controller: 5.0.17
        Log sieht sehr unauffälliog aus, perfekt!
        Die Steuerung jedoch, da passiert gar nichts. Die Cam bleibt stur auf ihrer Position und lässt sich nur mit onvif bewegen.
          ManiacKill
          schrieb am zuletzt editiert von ManiacKill
          #371
          Moien zusammen,
          das mit der MoveMotor funktioniert ja soweit, hat jemand eine idee wie ich das ins Vis einbauen kann ? Mit einem kleinen Controller Joystick wenn es so was gibt ?
          Mit onvif kann ich meine Tapo 225 nicht steuern !
          • M ManiacKill
            Moien zusammen,
            metaxaM Offline
            metaxaM Offline
            metaxa
            #372
            @maniackill sagte in Test Adapter TP-Link Tapo:
            Was gibst du da wie und wo ein?
            Ist ja witzig, bei mir ist es genau umgekehrt.
            Fixe Positionen könntest du über ein Kreuz mit durchsichtigen Tasten an steuern. Das gefällt mir bei onvif sehr gut. Die fixen Positionen habe ich in der Tapo App gespeichert un d rufe sie dann mit " GoToPreset 'x' " an.
            • metaxaM metaxa
              ManiacKill
              #373
              @metaxa
              Ja bei moveMotorStep hab ich mal 180 eingegeben, dann ist die Kamera gefahren. Aber weiß auch nicht so richtig wie ich das einbauen soll :(
              V M 3 Antworten Letzte Antwort
              • M ManiacKill
                @metaxa
                V Offline
                V Offline
                valiumbrause
                #374
                Hallo liebe Forum-Mitglieder,
                ich wende mich mit einem Problem an euch, das ich mit meinen Tapo Cams C320WS erlebe. Speziell geht es um die Funktion des motionEvent. Nach dem Starten der Cams, zum Beispiel bei Schnee oder Regen, wird der entsprechende Datenpunkt für etwa 60 Sekunden oder weniger aktualisiert, was bedeutet, dass Bewegungen erkannt werden. Danach jedoch gibt es keine Aktualisierungen mehr.
                Ich habe bereits einige Schritte zur Fehlerbehebung unternommen, wie das Löschen der Cams aus der App und einen Reset, leider ohne Erfolg. Auf den Cams ist die aktuelle Firmware-Version 1.1.7 Build 231122 Rel.55299n installiert. Zudem nutze ich die Version 0.2.3 des Tapo Adapters von GitHub.
                In meinem ioBroker erhalte ich folgende Fehlermeldungen:
                tapo.0
                2024-01-13 09:42:58.712 warn Error: StokRefresh: Temporary Suspension: Try again in 540 seconds
                tapo.0
                2024-01-13 09:42:28.641 warn Error: StokRefresh: Temporary Suspension: Try again in 571 seconds
                tapo.0
                2024-01-13 09:41:58.644 warn Error: StokRefresh: Temporary Suspension: Try again in 600 seconds
                Gibt es bekannte Lösungen für dieses Problem? Oder alternativ, gibt es andere Wege, um den motionEvent-Datenpunkt zu nutzen, um Bewegungen in ioBroker aufzuzeichnen?
                Ich würde mich sehr über eure Hilfe und Ratschläge freuen.
                Mit freundlichen Grüßen,
                Dirk
                ra juhaR 1 Antwort Letzte Antwort
                • V valiumbrause
                  tapo.0
                  tapo.0
                  tapo.0
                  Dirk
                  ra juhaR Offline
                  ra juhaR Offline
                  ra juha
                  schrieb am zuletzt editiert von ra juha
                  #375
                  Nun auch 0.2.3 installiert.
                  Leider keine Änderung der Zustände Steckdosen p100 der Felder setpowerstate wenn ich über dieTapo App an- und ausschalte.
                  Tut das bei Euch? Oder ist das Problem nur bei mir?
                  • ra juhaR ra juha
                    tombox
                    #376
                    @ra-juha bitte immer mit log posten
                      SaarlandUHU
                      #377
                      ich bin seit heute im Besitz einer C510W. Die Kamera taucht im Adapter auf, leider kann ich den Datenpunkt für die Bewegungserkennung nicht finden. Zuvor hatte ich eine C310 angeschlossen, dort gab es einen Datenpunkt motionevent. Ich würde die Kamera gerne zusätzlich als Bewegungsmelder nutzen, um eine Lampe einzuschalten. Ohne den Datenpunkt motionevent würde die Sache leider nicht funktionieren.
                      Vielen Dank und Grüße
                        tombox
                        #378
                        @saarlanduhu mit der v0.2.3 im debug log mode kannst du genau sehen was passiert auch wenn ein motion event auslösen sollte
                        • T tombox
                          SaarlandUHU
                          #379
                          @tombox Laut App wurde eine Bewegung um 22:18:01 Uhr erkannt.
                          Ich hab mal für den Zeitraum das Log angehängt. Ich kann da für den Zeitpunkt keine Ausgabe einer Bewegungserkennung sehen. Es sei denn ich habe sie übersehen.
                          v0.2.3 ist installiert
                          2024-01-13 22:17:55.999 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:17:56.123 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:17:56.123 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:17:56.123 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:17:56.999 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:17:57.000 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:17:57.131 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:17:57.131 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:17:57.132 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:17:58.000 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:17:58.001 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:17:58.118 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:17:58.119 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:17:58.119 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:17:59.001 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:17:59.002 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:17:59.147 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:17:59.148 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:17:59.148 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:00.002 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:18:00.003 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:18:00.130 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:18:00.131 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:18:00.131 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:01.005 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:18:01.006 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:18:01.210 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:18:01.210 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:18:01.210 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:02.007 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:18:02.007 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:18:02.134 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:18:02.135 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:18:02.135 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:03.007 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:18:03.008 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:18:03.178 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:18:03.178 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:18:03.179 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:04.008 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:18:04.008 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:18:04.141 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:18:04.142 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:18:04.142 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:05.010 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:18:05.010 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:18:05.209 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:18:05.210 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:18:05.210 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:06.010 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:18:06.011 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:18:06.157 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:18:06.157 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:18:06.157 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:07.011 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:18:07.011 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:18:07.273 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:18:07.274 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:18:07.274 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:08.012 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:18:08.012 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:18:08.156 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:18:08.156 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:18:08.157 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:09.012 - debug: tapo.0 (4427) Receive camera status
                          2024-01-13 22:18:09.015 - debug: tapo.0 (4427) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                          2024-01-13 22:18:09.304 - debug: tapo.0 (4427) API response: 200
                          2024-01-13 22:18:09.305 - debug: tapo.0 (4427) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                          2024-01-13 22:18:09.305 - debug: tapo.0 (4427) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                          2024-01-13 22:18:10.013 - debug: tapo.0 (4427) Receive camera status
                          metaxaM T 2 Antworten Letzte Antwort
                          • S SaarlandUHU
                            metaxaM Offline
                            metaxaM Offline
                            metaxa
                            #380
                            @saarlanduhu @tombox
                            Ich kann bei meiner C520WS leider auch mit der 0.2.3 keinen Event erkennen.
                            Ist der MFA Code verpflichtend? Den habe ich nie bekommen! Wann sollte der kommen?
                            E 1 Antwort Letzte Antwort
                            • S SaarlandUHU
                              tombox
                              #381
                              @saarlanduhu der start bei dem der motion event erstellt wird ist interessanter
                              S 2 Antworten Letzte Antwort
                              • T tombox
                                SaarlandUHU
                                #382
                                @tombox du meinst den Adapterstart?
                                • T tombox
                                  SaarlandUHU
                                  #383
                                  @tombox ich habe jetzt den Adapter zum erzeugen des logs jetzt nochmal gestoppt und wieder gestartet, danach ist der Datenpunkt motionevent aufgetaucht und er funktioniert auch. warum er bei den vorherigen neustarts des Adapters nicht erzeugt wurde...man weiß es nicht. Auf jeden Fall ist er jetzt da und funktioniert.
                                  Dennoch vielen Dank für die unterstützung.
                                  Der Vollständigkeit halber hier noch das Log:
                                  2024-01-13 23:25:32.944  - info: tapo.0 (8915) Initialized 80227C9387D02CB80B2A97FAA7B45D451F6DBE41
                                  2024-01-13 23:25:32.944  - debug: tapo.0 (8915) initResult 80227C9387D02CB80B2A97FAA7B45D451F6DBE41 undefined
                                  2024-01-13 23:25:33.183  - debug: tapo.0 (8915) {"hwVer":"1.0","category":"camera","model":"C510W 1.0","ssid":"wINTERNETZ_is_coming","mac":"A842A1382FE0","hwId":"FE658AE4C353452D7B112AB94C679C3D","fwId":"0C03EB093C956BD3C9F7551B5C4795C6","oemId":"CBF298FDF6A1EA18D53CCB1E4D60CCB9","fwVer":"1.1.1 Build 231107 Rel.67816n","ip":"192.168.178.104","onboardingTime":1705167105,"role":0,"deviceType":"SMART.IPCAMERA","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-01-13 23:25:33.184  - info: tapo.0 (8915) Init device 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 type C510W 1.0 with ip 192.168.178.104
                                  2024-01-13 23:25:33.186  - debug: tapo.0 (8915) Constructing Camera on host: 192.168.178.104
                                  2024-01-13 23:25:33.467  - info: tapo.0 (8915) 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 Received device info {"manufacturer":"tp-link","model":"Tapo C510W","firmwareVersion":"1.1.1 Build 231107 Rel.67816n","serialNumber":"a1382fe0","hardwareId":1}
                                  2024-01-13 23:25:33.469  - debug: tapo.0 (8915) {"manufacturer":"tp-link","model":"Tapo C510W","firmwareVersion":"1.1.1 Build 231107 Rel.67816n","serialNumber":"a1382fe0","hardwareId":1}
                                  2024-01-13 23:25:33.470  - debug: tapo.0 (8915) Init event emitter for 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24
                                  2024-01-13 23:25:33.551  - debug: tapo.0 (8915) Init event listener for "motion"
                                  2024-01-13 23:25:33.552  - info: tapo.0 (8915) Initialized 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24
                                  2024-01-13 23:25:33.553  - debug: tapo.0 (8915) initResult 8021A5C95BDC23B3A5C4ED9A6B165AB421F4DC24 undefined
                                  2024-01-13 23:25:33.759  - debug: tapo.0 (8915) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B0A7B9DD8161","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.48","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-01-13 23:25:33.770  - info: tapo.0 (8915) Init device 8022409EF7482B099F90B71629A073D31F050586 type P100 with ip 192.168.178.48
                                  2024-01-13 23:25:33.773  - debug: tapo.0 (8915) Constructing P100 on host: 192.168.178.48
                                  2024-01-13 23:25:33.910  - debug: tapo.0 (8915) Handshake P100 on host: 192.168.178.48
                                  2024-01-13 23:25:36.975  - error: tapo.0 (8915) connect EHOSTUNREACH 192.168.178.48:80
                                  2024-01-13 23:25:36.976  - error: tapo.0 (8915) 52 - Get Device Info failed
                                  2024-01-13 23:25:36.976  - info: tapo.0 (8915) Initialized 8022409EF7482B099F90B71629A073D31F050586
                                  2024-01-13 23:25:36.976  - debug: tapo.0 (8915) initResult 8022409EF7482B099F90B71629A073D31F050586 undefined
                                  2024-01-13 23:25:37.152  - debug: tapo.0 (8915) {"hwVer":"1.20.0","category":"plug","model":"P100","ssid":"d0lOVEVSTkVUWl9pc19jb21pbmc=","mac":"B4B024E5C6FD","hwId":"9994A0A7D5B29645B8150C392284029D","fwId":"1D18AD293A25ABDE41405B20C6F98816","oemId":"D7C5ADFD37188938BA82FD0FE208D1E7","fwVer":"1.5.5 Build 20230927 Rel. 40646","ip":"192.168.178.85","onboardingTime":1,"role":0,"deviceType":"SMART.TAPOPLUG","pcSameRegion":false,"pcAppServerUrl":"https://n-euw1-wap.tplinkcloud.com"}
                                  2024-01-13 23:25:37.153  - info: tapo.0 (8915) Init device 8022F09FD11B3954491C051CBA331E321F6E863A type P100 with ip 192.168.178.85
                                  2024-01-13 23:25:37.155  - debug: tapo.0 (8915) Constructing P100 on host: 192.168.178.85
                                  2024-01-13 23:25:37.351  - debug: tapo.0 (8915) Handshake P100 on host: 192.168.178.85
                                  2024-01-13 23:25:38.941  - info: daswetter.1 (8891) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                  2024-01-13 23:25:39.527  - info: daswetter.1 (8891) cleaned everything up...
                                  2024-01-13 23:25:39.552  - info: host.raspberrypi instance system.adapter.daswetter.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-01-13 23:25:40.430  - error: tapo.0 (8915) connect EHOSTUNREACH 192.168.178.85:80
                                  2024-01-13 23:25:40.431  - error: tapo.0 (8915) 52 - Get Device Info failed
                                  2024-01-13 23:25:40.432  - info: tapo.0 (8915) Initialized 8022F09FD11B3954491C051CBA331E321F6E863A
                                  2024-01-13 23:25:40.432  - debug: tapo.0 (8915) initResult 8022F09FD11B3954491C051CBA331E321F6E863A undefined
                                  2024-01-13 23:25:40.478  - info: tapo.0 (8915) Wait for connections for non camera devices
                                  2024-01-13 23:25:50.480  - info: tapo.0 (8915) Start first Update
                                  2024-01-13 23:25:50.482  - debug: tapo.0 (8915) Receive camera status
                                  2024-01-13 23:25:50.484  - debug: tapo.0 (8915) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                  2024-01-13 23:25:50.651  - debug: tapo.0 (8915) {"size":0,"timeout":0}
                                  2024-01-13 23:25:50.656  - debug: tapo.0 (8915) isSecureConnection response :>> 200[object Object]
                                  2024-01-13 23:25:50.658  - debug: tapo.0 (8915) StokRefresh: Using secure connection
                                  2024-01-13 23:25:50.813  - debug: tapo.0 (8915) StokRefresh: Login response :>> 200{"result":{"data":{"code":-40401,"time":8,"max_time":10,"encrypt_type":["3"],"key":"MFwwDQYJKoZIhvcNAQEBBQADSwAwSAJBALf3HOqgCbEl58R8KxobE+QF6aC4fYBgFAR0Rko2NeUr1+i9ZJ3jvZqxwN+q1yMSt6G7VHKsmW8LAFieLHuL8RMCAwEAAQ==","nonce":"E80CEFF784371D31","device_confirm":"03A68326AC9437CB8EBC251DA490CBF4CA13B87D3DC046340144E7BFF57CE6C6E80CEFF784371D3126A07297E4FDC85E"}},"error_code":-40413}
                                  2024-01-13 23:25:50.954  - debug: tapo.0 (8915) StokRefresh: Start_seq response :>>
                                  2024-01-13 23:25:50.955  - debug: tapo.0 (8915) StokRefresh: Success :>>OW66BO6rCjC.613B8E6DDAXNjUAXC5Tv
                                  2024-01-13 23:25:51.098  - debug: tapo.0 (8915) API response: 200
                                  2024-01-13 23:25:51.098  - debug: tapo.0 (8915) getStatus json: {"result":{"responses":[{"method":"getAlertConfig","result":{"msg_alarm":{"chn1_msg_alarm_info":{"enabled":"off","light_alarm_enabled":"on","alarm_mode":["sound","light"],"alarm_type":"0","light_type":"1","sound_alarm_enabled":"on","alarm_volume":"high","alarm_duration":"0"}}},"error_code":0},{"method":"getLensMaskConfig","result":{"lens_mask":{"lens_mask_info":{"enabled":"off"}}},"error_code":0},{"method":"getForceWhitelampState","result":{},"error_code":-40210}]},"error_code":0}
                                  2024-01-13 23:25:51.099  - debug: tapo.0 (8915) {"alert":false,"lensMask":false,"forceWhiteLamp":false}
                                  2024-01-13 23:25:52.101  - debug: tapo.0 (8915) Receive camera status
                                  2024-01-13 23:25:52.101  - debug: tapo.0 (8915) API new request: {"method":"multipleRequest","params":{"requests":[{"method":"getAlertConfig","params":{"msg_alarm":{"name":"chn1_msg_alarm_info"}}},{"method":"getLensMaskConfig","params":{"lens_mask":{"name":"lens_mask_info"}}},{"method":"getForceWhitelampState","params":{"image":{"name":"switch"}}}]}}
                                  2024-01-13 23:25:52.300  - debug: tapo.0 (8915) API response: 200
                                  • metaxaM metaxa
                                    Einstein67
                                    schrieb am zuletzt editiert von Einstein67
                                    #384
                                    @metaxa said in Test Adapter TP-Link Tapo:
                                    Nein ist nicht verpflichtend, solange du in der Tapo-App die "2 Schritt Verifizierung" nicht aktivierst.
                                    Bei mir läuft der Tapo-Adapter - mit C110 und C310 Kameras - ohne MFA-Code problemlos.
                                    • M ManiacKill
                                      @metaxa
                                      ManiacKill
                                      #385
                                      @maniackill said in Test Adapter TP-Link Tapo:
                                      @metaxa
                                      Hat jemand eine Idee wie man das ins Vis einbaut ? Ich hätte gerne so einen 360° Controller, aber bis jetzt nix gefunden !
                                      • T tombox
                                        ra juhaR Offline
                                        ra juhaR Offline
                                        ra juha
                                        #386
                                        @tombox heißt das, nur ich hab das Problem? Mist.
                                        Mir ist nicht ganz klar ab wann ich debug Posten soll.
                                        Was mir auffällt, die Farbe des Eintrags setpowerstate ist anders, als hätte iob hier keine Berechtigung oder Zugriff. Beim ersten scan wird alles richtig ausgelesen. Danach leider nicht mehr. Es hat auch früher funktioniert. Mist
                                        Was auch komisch ist, kann den Wert manuell nicht mehr überschreiben
                                        • ra juhaR ra juha
                                          ra juhaR Offline
                                          ra juhaR Offline
                                          ra juha
                                          #387
                                          Bin einen Schritt weiter. Habe alles neu aufgesetzt. Sogar IOB.
                                          Die P100 tun wieder, Zustand bei Änderung über TAPO-App wird gemeldet.
                                          Nur mein P115 macht Probleme. Aus Tapo gelöscht und neu dazu hat leider nichts gebracht. Zustandsänderungen werden nicht angezeigt :-(
                                          Hat jemand den P115 wo das tut? Danke
                                          @tombox Soll ich Dir auf den P115 Zugriff geben?
