  4. BackitUp Problem ( Rechte? )
    6.1k
24 Beiträge 4 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • N nettworker
    also für das Verzeichnis share die Rechte noch ändern?
    bzw. Eigentümer / Gruppe?
    @nettworker sagte in BackitUp Problem ( Rechte? ):
    Ja, auf die gleiche uid/gid die iobroker:iobroker hat.
    N 1 Antwort Letzte Antwort
      N Offline
      N Offline
      nettworker
      schrieb am zuletzt editiert von nettworker
      dieter@nfs-svr:/mnt$ ls -la
      insgesamt 12
      drwxr-xr-x  3 root   root    4096  9. Jan 17:01 .
      drwxr-xr-x 18 root   root    4096  9. Jan 16:47 ..
      drwxrwxrwx 10 nobody nogroup 4096  9. Jan 13:15 share
      Started iobroker ...
      [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false}
      [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.3.244:/mnt/share/iobroker /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.iobroker 7693 states saved
      [DEBUG] [iobroker] - host.iobroker 8864 objects saved
      [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz'
      [ERROR] [iobroker] - host.iobroker Backup not created: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz'
      [DEBUG] [iobroker] - Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz'
      [ERROR] [iobroker] - [Error: ENOENT: no such file or directory, scandir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files'] {
        errno: -2,
        code: 'ENOENT',
        syscall: 'scandir',
        path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files'
      [ERROR] [iobroker] - [Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'] {
        errno: -2,
        code: 'ENOENT',
        syscall: 'open',
        path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
      [ERROR] [iobroker] - [Error: ENOENT: no such file or directory, scandir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/zigbee_0'] {
        errno: -2,
        code: 'ENOENT',
        syscall: 'scandir',
        path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/zigbee_0'
      [DEBUG] [iobroker] - done
      [DEBUG] [zigbee] - found zigbee database: zigbee.0
      [DEBUG] [zigbee] - done
      [ERROR] [zigbee] - Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz'
      [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" cannot created ... Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/tmpScripts'
      [ERROR] [javascripts] - script.json cannot be written: Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/tmpScripts/script.json'
      [DEBUG] [javascripts] - found Script: Ausschalttemperatur_aendern
      [DEBUG] [javascripts] - found Script: Einschalttemperatur_aendern
      [DEBUG] [javascripts] - found Script: Frostalarm_Huette
      [DEBUG] [javascripts] - found Script: Skript_1
      [DEBUG] [javascripts] - found Script: Aquara_Doppelschalter_WZ
      [DEBUG] [javascripts] - found Script: Bewegungssensor_Flur
      [DEBUG] [javascripts] - found Script: Rollaeden
      [DEBUG] [javascripts] - found Script: Taster_Rollaeden
      [DEBUG] [javascripts] - found Script: Energie_Verwerten
      [DEBUG] [javascripts] - found Script: Solarwerte_addieren
      [DEBUG] [javascripts] - found Script: Strom_verbrennen
      [DEBUG] [javascripts] - found Script: Tagesdaten_speichern
      [DEBUG] [javascripts] - found Script: Verbrauchsdaten_sichern
      [DEBUG] [javascripts] - found Script: Werte_addieren
      [DEBUG] [javascripts] - found Script: Abendlichter_Button
      [DEBUG] [javascripts] - found Script: Abendlichter_automatik
      [DEBUG] [javascripts] - found Script: Fernseher_aus
      [DEBUG] [javascripts] - found Script: HP-Server
      [DEBUG] [javascripts] - found Script: Kuehlschraenke_aus
      [DEBUG] [javascripts] - found Script: SystemCheck
      [DEBUG] [javascripts] - found Script: unifi_1
      [DEBUG] [javascripts] - javascript Backup not created
      [DEBUG] [javascripts] - done
      [DEBUG] [cifs] - used copy path: /mnt/share/iobroker
      [DEBUG] [cifs] - done
      [DEBUG] [cifs] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2024_01_10-11_49_21_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created","zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz'"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"10. Januar 2024 um 11:49 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [umount] - mount activ, umount is started ...
      [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2024_01_10-11_49_21_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created","zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz'"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"10. Januar 2024 um 11:49 Uhr"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [umount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
      [DEBUG] [umount] - umount successfully completed
      [DEBUG] [umount] - done
      [EXIT] 1
      • N nettworker
        insgesamt 12
          errno: -2,
          code: 'ENOENT',
          syscall: 'scandir',
          errno: -2,
          code: 'ENOENT',
          syscall: 'open',
          errno: -2,
          code: 'ENOENT',
          syscall: 'scandir',
        [EXIT] 1
        @nettworker
        Du sollst die uid und gid umstellen und nicht die Rechte vermurksen.
          @nettworker
          N Offline
          N Offline
          nettworker
          GruppenID und UserID hab ich doch angepasst
          • N nettworker
            @nettworker
            nobody:nogroup
            Ist nicht iobroker:iobroker
              @nettworker
              nobody:nogroup
              N Offline
              N Offline
              nettworker
              auf dem NFS Server gibts keinen User iobroker.
              • N nettworker
                und das ist das Problem
                  N Offline
                  N Offline
                  nettworker
                  und das kapiere ich halt nicht so ganz.
                  Die Proxmox Backups werden ja auch da gespeichert ohne das ich speziell einen User dafür angelegt habe.
                  -rwxr-xr-x  1 nobody nogroup        2518  7. Jan 18:27 vzdump-qemu-105-2023_12_11-08_50_11.log
                  -rwxr-xr-x  1 nobody nogroup  1145697023  7. Jan 18:42 vzdump-qemu-105-2023_12_11-08_50_11.vma.zst
                  -rwxr-xr-x  1 nobody nogroup          12  7. Jan 18:27 vzdump-qemu-105-2023_12_11-08_50_11.vma.zst.notes
                  -rwxr-xr-x  1 nobody nogroup        2052  7. Jan 18:42 vzdump-qemu-105-2024_01_03-18_46_51.log
                  -rwxr-xr-x  1 nobody nogroup  1190898808  7. Jan 19:19 vzdump-qemu-105-2024_01_03-18_46_51.vma.zst
                  -rwxr-xr-x  1 nobody nogroup           7  7. Jan 19:40 vzdump-qemu-105-2024_01_03-18_46_51.vma.zst.notes
                  -rw-r--r--  1 nobody nogroup        2049 10. Jan 14:46 vzdump-qemu-105-2024_01_10-14_46_04.log
                  -rw-r--r--  1 nobody nogroup  1191175949 10. Jan 14:46 vzdump-qemu-105-2024_01_10-14_46_04.vma.zst
                  -rw-r--r--  1 nobody nogroup           7 10. Jan 14:46 vzdump-qemu-105-2024_01_10-14_46_04.vma.zst.notes
                  • N nettworker
                    Da ist aber auch kein Export via NFS im Spiel.
                      N Offline
                      N Offline
                      nettworker
                      Doch, ist das gleiche freigegebene Verzeichnis / Export auf dem NFS Server und als NFS Storage in PM eingerichtet.
                      • N nettworker
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @nettworker Proxmox legt die im Standard mit dem root User ab... Und den gibt es auf dem NAS.
                        iobroker gibt es allerdings nicht als User
                        • Besuche meine Github Seite
                        • HowTo Restore ioBroker
