  4. BackitUp Problem ( Rechte? )
    6.1k
24 Beiträge 4 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • N nettworker
    Ja, es soll auf einen NFS Freigabe geschrieben werden.
    Laut Debug wird die Verbindung aber erfolgreich hergestellt.
    hier die Protokollausgabe bei den Logs:
    @nettworker sagte in BackitUp Problem ( Rechte? ):
    Bitte als Text in code-tags posten!
    EDIT:
    da scheint auch der mountversuch zu fehlen, wenn ich das richtig entziffern kann.
    Also größeren Ausschnitt bitte
    • N nettworker
      Bitte in Textform und in richtiger zeitlicher Reihenfolge.
      N 1 Antwort Letzte Antwort
        N Offline
        N Offline
        nettworker
        Started iobroker ...
        [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false}
        [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.3.244:/mnt/share/iobroker /opt/iobroker/backups"
        [DEBUG] [mount] - mount successfully completed
        [DEBUG] [mount] - done
        [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [iobroker] - host.iobroker 7693 states saved
        [DEBUG] [iobroker] - host.iobroker 8864 objects saved
        [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_03_24_backupiobroker.tar.gz'
        [ERROR] [iobroker] - host.iobroker Backup not created: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_03_24_backupiobroker.tar.gz'
        [DEBUG] [iobroker] - Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_03_24_backupiobroker.tar.gz'
        [ERROR] [iobroker] - [Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'] {
          errno: -2,
          code: 'ENOENT',
          syscall: 'open',
          path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
        [ERROR] [iobroker] - [Error: ENOENT: no such file or directory, scandir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/zigbee_0'] {
          errno: -2,
          code: 'ENOENT',
          syscall: 'scandir',
          path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/zigbee_0'
        [ERROR] [iobroker] - [Error: ENOENT: no such file or directory, scandir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files'] {
          errno: -2,
          code: 'ENOENT',
          syscall: 'scandir',
          path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files'
        [DEBUG] [iobroker] - done
        [DEBUG] [zigbee] - found zigbee database: zigbee.0
        [DEBUG] [zigbee] - done
        [ERROR] [zigbee] - Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_03_30_backupiobroker.tar.gz'
        [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" cannot created ... Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/tmpScripts'
        [ERROR] [javascripts] - script.json cannot be written: Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/tmpScripts/script.json'
        [DEBUG] [javascripts] - found Script: Ausschalttemperatur_aendern
        [DEBUG] [javascripts] - found Script: Einschalttemperatur_aendern
        [DEBUG] [javascripts] - found Script: Frostalarm_Huette
        [DEBUG] [javascripts] - found Script: Skript_1
        [DEBUG] [javascripts] - found Script: Aquara_Doppelschalter_WZ
        [DEBUG] [javascripts] - found Script: Bewegungssensor_Flur
        [DEBUG] [javascripts] - found Script: Rollaeden
        [DEBUG] [javascripts] - found Script: Taster_Rollaeden
        [DEBUG] [javascripts] - found Script: Energie_Verwerten
        [DEBUG] [javascripts] - found Script: Solarwerte_addieren
        [DEBUG] [javascripts] - found Script: Strom_verbrennen
        [DEBUG] [javascripts] - found Script: Tagesdaten_speichern
        [DEBUG] [javascripts] - found Script: Verbrauchsdaten_sichern
        [DEBUG] [javascripts] - found Script: Werte_addieren
        [DEBUG] [javascripts] - found Script: Abendlichter_Button
        [DEBUG] [javascripts] - found Script: Abendlichter_automatik
        [DEBUG] [javascripts] - found Script: Fernseher_aus
        [DEBUG] [javascripts] - found Script: HP-Server
        [DEBUG] [javascripts] - found Script: Kuehlschraenke_aus
        [DEBUG] [javascripts] - found Script: SystemCheck
        [DEBUG] [javascripts] - found Script: unifi_1
        [DEBUG] [javascripts] - javascript Backup not created
        [DEBUG] [javascripts] - done
        [DEBUG] [cifs] - used copy path: /mnt/share/iobroker
        [DEBUG] [cifs] - done
        [DEBUG] [cifs] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
        [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
        [DEBUG] [clean] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_01_10-11_03_24_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2024_01_10-11_03_30_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2024_01_10-11_03_31_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created","zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_03_30_backupiobroker.tar.gz'"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"10. Januar 2024 um 11:03 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [DEBUG] [umount] - mount activ, umount is started ...
        [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_01_10-11_03_24_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2024_01_10-11_03_30_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2024_01_10-11_03_31_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created","zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_03_30_backupiobroker.tar.gz'"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"10. Januar 2024 um 11:03 Uhr"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
        [DEBUG] [umount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
        [DEBUG] [umount] - umount successfully completed
        [DEBUG] [umount] - done
        [EXIT] 1
        • N nettworker
            errno: -2,
            code: 'ENOENT',
            syscall: 'open',
            errno: -2,
            code: 'ENOENT',
            syscall: 'scandir',
            errno: -2,
            code: 'ENOENT',
            syscall: 'scandir',
          [EXIT] 1
          @nettworker
          Zeig mal die Einstellungen aus dem Adapter. Da scheint mir irgendwas durcheinander zu sein.
          • N nettworker
              errno: -2,
              code: 'ENOENT',
              syscall: 'open',
              errno: -2,
              code: 'ENOENT',
              syscall: 'scandir',
              errno: -2,
              code: 'ENOENT',
              syscall: 'scandir',
            [EXIT] 1
            smb":"vers=1.0"
            Cifs oder nfs???
            wenn cifs, dann könnte die smb version zu niedrig sein
              smb":"vers=1.0"
              Cifs oder nfs???
              N Offline
              N Offline
              nettworker
              @homoran CFIS war mal, alles umgestellt auf NFS
              • N nettworker
                @nettworker
                Und die Rechte an /mnt/share/iobroker auf dem NFS-Server sehen wie aus?
                  @nettworker
                  N Offline
                  N Offline
                  nettworker
                  dieter@nfs-svr:/mnt/share$ ls -la
                  insgesamt 60
                  drwxrwxrwx 10 root   root     4096  9. Jan 13:15 .
                  drwxr-xr-x  3 root   root     4096  9. Jan 17:01 ..
                  drwxr-xr-x  4 nobody nogroup  4096  7. Jan 18:18 backup
                  drwxr-xr-x  4 nobody nogroup 12288  7. Jan 19:40 dump
                  drwxr-xr-x  2 nobody nogroup  4096  5. Jan 13:39 images
                  drwxr-xr-x  2 nobody nogroup  4096  9. Jan 13:18 iobroker
                  drwx------  2 nobody nogroup 16384  7. Jan 17:34 lost+found
                  drwxr-xr-x  2 nobody nogroup  4096 13. Sep 18:58 private
                  drwxr-xr-x  2 nobody nogroup  4096 13. Sep 18:58 snippets
                  drwxr-xr-x  4 nobody nogroup  4096  7. Jan 17:50 template
                  • N nettworker
                    insgesamt 60
                    @nettworker
                    Falsche user/gruppe.
                    Bei NFS werden die auf den Mountpunkt weitergereicht und dann kann der user 'iobroker' da nicht reinschreiben.
                      @nettworker
                      N Offline
                      N Offline
                      nettworker
                      schrieb am zuletzt editiert von nettworker
                      also für das Verzeichnis share die Rechte noch ändern?
                      bzw. Eigentümer / Gruppe?
                      • N nettworker
                        Ja, auf die gleiche uid/gid die iobroker:iobroker hat.
                          N Offline
                          N Offline
                          nettworker
                          dieter@nfs-svr:/mnt$ ls -la
                          insgesamt 12
                          drwxr-xr-x 18 root   root    4096  9. Jan 16:47 ..
                          drwxrwxrwx 10 nobody nogroup 4096  9. Jan 13:15 share
                          [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz'
                          [ERROR] [iobroker] - host.iobroker Backup not created: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz'
                          [DEBUG] [iobroker] - Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz'
                            errno: -2,
                            code: 'ENOENT',
                            syscall: 'scandir',
                            errno: -2,
                            code: 'ENOENT',
                            syscall: 'open',
                            errno: -2,
                            code: 'ENOENT',
                            syscall: 'scandir',
                          [ERROR] [zigbee] - Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz'
                          [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2024_01_10-11_49_21_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created","zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz'"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"10. Januar 2024 um 11:49 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                          [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2024_01_10-11_49_21_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created","zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz'"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"10. Januar 2024 um 11:49 Uhr"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                          [EXIT] 1
                          • N nettworker
                            insgesamt 12
                              errno: -2,
                              code: 'ENOENT',
                              syscall: 'scandir',
                              errno: -2,
                              code: 'ENOENT',
                              syscall: 'open',
                              errno: -2,
                              code: 'ENOENT',
                              syscall: 'scandir',
                            [EXIT] 1
                            @nettworker
                            Du sollst die uid und gid umstellen und nicht die Rechte vermurksen.
                              @nettworker
                              N Offline
                              N Offline
                              nettworker
                              GruppenID und UserID hab ich doch angepasst
                              • N nettworker
                                @nettworker
                                nobody:nogroup
                                Ist nicht iobroker:iobroker
                                  @nettworker
                                  nobody:nogroup
                                  N Offline
                                  N Offline
                                  nettworker
                                  auf dem NFS Server gibts keinen User iobroker.
                                  • N nettworker
                                    und das ist das Problem
                                      N Offline
                                      N Offline
                                      nettworker
                                      und das kapiere ich halt nicht so ganz.
                                      Die Proxmox Backups werden ja auch da gespeichert ohne das ich speziell einen User dafür angelegt habe.
                                      -rwxr-xr-x  1 nobody nogroup        2518  7. Jan 18:27 vzdump-qemu-105-2023_12_11-08_50_11.log
                                      -rwxr-xr-x  1 nobody nogroup  1145697023  7. Jan 18:42 vzdump-qemu-105-2023_12_11-08_50_11.vma.zst
                                      -rwxr-xr-x  1 nobody nogroup          12  7. Jan 18:27 vzdump-qemu-105-2023_12_11-08_50_11.vma.zst.notes
                                      -rwxr-xr-x  1 nobody nogroup        2052  7. Jan 18:42 vzdump-qemu-105-2024_01_03-18_46_51.log
                                      -rwxr-xr-x  1 nobody nogroup  1190898808  7. Jan 19:19 vzdump-qemu-105-2024_01_03-18_46_51.vma.zst
                                      -rwxr-xr-x  1 nobody nogroup           7  7. Jan 19:40 vzdump-qemu-105-2024_01_03-18_46_51.vma.zst.notes
                                      -rw-r--r--  1 nobody nogroup        2049 10. Jan 14:46 vzdump-qemu-105-2024_01_10-14_46_04.log
                                      -rw-r--r--  1 nobody nogroup  1191175949 10. Jan 14:46 vzdump-qemu-105-2024_01_10-14_46_04.vma.zst
                                      -rw-r--r--  1 nobody nogroup           7 10. Jan 14:46 vzdump-qemu-105-2024_01_10-14_46_04.vma.zst.notes
                                      • N nettworker
                                        Da ist aber auch kein Export via NFS im Spiel.
                                          N Offline
                                          N Offline
                                          nettworker
                                          Doch, ist das gleiche freigegebene Verzeichnis / Export auf dem NFS Server und als NFS Storage in PM eingerichtet.
