  4. IOB keine Weboberfläche für Zigbee oder Objekte
20 Beiträge 3 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • W wolkenloser
    Mein IOB macht wieder Probleme.
    Eigendlich läuft alles incl. VIS , aber ich kann die IOB mir weder Zigbee noch Objekte oder den Admin ansehen.
    Hier mal der Output von IOB Diag:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: microsoft
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 5.4.0-169-generic
          Architecture: x86-64
    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Docker          : false
    Virtualization  : microsoft
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     17:41:12 up 2 days, 52 min,  2 users,  load average: 1.63, 1.22, 1.16
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2024-01-08 17:41:13 CET
               Universal time: Mon 2024-01-08 16:41:13 UTC
                     RTC time: Mon 2024-01-08 16:41:14
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           5.9G        3.1G        645M        0.0K        2.2G        2.7G
    Swap:          2.0G        175M        1.8G
    Total:         7.9G        3.3G        2.4G
             5929 M total memory
             3124 M used memory
             3259 M active memory
             1574 M inactive memory
              645 M free memory
              320 M buffer memory
             1839 M swap cache
             1969 M total swap
              175 M used swap
             1794 M free swap
    *** FAILED SERVICES ***
      UNIT           LOAD   ACTIVE SUB    DESCRIPTION
    * fstrim.service loaded failed failed Discard unused blocks on filesystems from /etc/fstab
    1 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  2.9G     0  2.9G   0% /dev
    tmpfs          tmpfs     593M  1.2M  592M   1% /run
    /dev/sda2      ext4       50G   34G   14G  72% /
    tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     2.9G     0  2.9G   0% /sys/fs/cgroup
    /dev/loop1     squashfs  106M  106M     0 100% /snap/core/16091
    /dev/loop2     squashfs   56M   56M     0 100% /snap/core18/2796
    /dev/loop0     squashfs  106M  106M     0 100% /snap/core/16202
    /dev/loop3     squashfs   56M   56M     0 100% /snap/core18/2812
    /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/2015
    /dev/loop5     squashfs   64M   64M     0 100% /snap/core20/2105
    /dev/loop6     squashfs   92M   92M     0 100% /snap/lxd/23991
    /dev/loop7     squashfs   92M   92M     0 100% /snap/lxd/24061
    /dev/loop8     squashfs  128K  128K     0 100% /snap/ncdu/62
    /dev/loop9     squashfs  128K  128K     0 100% /snap/ncdu/64
    /dev/loop10    squashfs  4.3M  4.3M     0 100% /snap/tree/18
    tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
    [sudo] password for iobroker:
    [Sat Jan  6 16:49:13 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Jan  6 16:49:21 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET                SOURCE      FSTYPE   OPTIONS
    /                     /dev/sda2   ext4     rw,relatime
    |-/sys/kernel/tracing tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
    |-/snap/core/16091    /dev/loop1  squashfs ro,nodev,relatime
    |-/snap/core18/2796   /dev/loop2  squashfs ro,nodev,relatime
    |-/snap/core/16202    /dev/loop0  squashfs ro,nodev,relatime
    |-/snap/core18/2812   /dev/loop3  squashfs ro,nodev,relatime
    |-/snap/core20/2015   /dev/loop4  squashfs ro,nodev,relatime
    |-/snap/core20/2105   /dev/loop5  squashfs ro,nodev,relatime
    |-/snap/lxd/23991     /dev/loop6  squashfs ro,nodev,relatime
    |-/snap/lxd/24061     /dev/loop7  squashfs ro,nodev,relatime
    |-/snap/ncdu/62       /dev/loop8  squashfs ro,nodev,relatime
    |-/snap/ncdu/64       /dev/loop9  squashfs ro,nodev,relatime
    `-/snap/tree/18       /dev/loop10 squashfs ro,nodev,relatime
    /var:
    5.6G    /var/
    3.9G    /var/log/journal/4c4f1c196fd742fb8ea78816d6e03b15
    3.9G    /var/log
    1.5G    /var/lib
    Archived and active journals take up 3.8G in the file system.
    /opt/iobroker/backups:
    12M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    16G     /opt/iobroker/iobroker-data/
    15G     /opt/iobroker/iobroker-data/history
    690M    /opt/iobroker/iobroker-data/files
    155M    /opt/iobroker/iobroker-data/backup-objects
    113M    /opt/iobroker/iobroker-data/files/vis-2-beta
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.f79fb97a.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
     *** 18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.19.0~dfsg-3ubuntu1.3 500
            500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: eiscp@0.0.1 /opt/iobroker/node_modules/eiscp
    npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-08T16_42_22_423Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.easee.0                  : easee                 : iobroker                                 - disabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
      system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.8.67
    + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
      system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
    + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
    + system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      system.adapter.parser.0                 : parser                : iobroker                                 - disabled
      system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
    Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.11   , installed 3.1.12
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "easee"        : 1.0.10   , installed 1.0.10
    Adapter    "echarts"      : 1.5.4    , installed 1.5.4
    Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.6
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
    Adapter    "knx"          : 2.0.24   , installed 2.0.24
    Adapter    "lg-thinq"     : 0.3.1    , installed 0.3.1
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "openweathermap": 0.4.5   , installed 0.4.5
    Adapter    "parser"       : 2.0.7    , installed 2.0.7
    Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
    Adapter    "unifi"        : 0.6.7    , installed 0.6.7
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.9.7    , installed 1.9.5  [Updatable]
    Objects and States
    Objects:        11386
    States:         10291
    Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 11
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       126087     9520/io.shelly.0
    tcp        0      0 192.168.8.67:9093       0.0.0.0:*               LISTEN      1000       125408     9655/io.fakeroku.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       125045     9359/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       125038     9359/iobroker.js-co
    tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          28689      1062/perl
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21994      663/systemd-resolve
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25974      849/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        26244      836/influxd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       125292     9536/io.sonoff.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1000       126343     9690/io.harmony.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       126762     10203/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        28227      836/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          25976      849/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       126823     10382/io.simple-api
    tcp6       0      0 :::3000                 :::*                    LISTEN      111        26392      818/grafana-server
    udp        0      0 192.168.8.67:35335      0.0.0.0:*                           1000       204758     23136/io.knx.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       195031     20727/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       195032     20727/io.tuya.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21993      663/systemd-resolve
    udp        0      0 192.168.8.67:68         0.0.0.0:*                           100        1364760    661/systemd-network
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       126344     9690/io.harmony.0
    udp        0      0 192.168.8.67:41557      0.0.0.0:*                           1000       1814430    23136/io.knx.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       156371     15744/io.wled.0
    udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          28690      1062/perl
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       125409     9655/io.fakeroku.0
    udp6       0      0 fe80::11:32ff:fe2d::546 :::*                                100        21998      661/systemd-network
    2024-01-08 17:43:01.558  - warn: sonoff.0 (9536) Client [] has invalid password or username
    2024-01-08 17:43:37.525  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/settings/relay/0": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:37.578  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/settings": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:37.630  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/status": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:37.690  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/settings/ext_temperature/0": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:37.749  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/settings/ext_temperature/1": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:37.806  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.95 (shelly1 / shelly1-B8B540 / SHSW-1#B8B540#1) "/settings/ext_temperature/2": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:47.937  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/settings/relay/0": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:47.995  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/settings": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:48.023  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/status": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:48.969  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/settings/ext_temperature/0": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:49.015  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/settings/ext_temperature/1": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:43:49.049  - error: shelly.0 (9520) [httpIoBrokerState] HTTP request error for 192.168.8.22 (shelly1 / shelly1-769AB4 / SHSW-1#769AB4#1) "/settings/ext_temperature/2": Wrong http username or http password! Please enter user credentials for restricted login.
    2024-01-08 17:44:00.038  - warn: javascript.0 (11567) State "sonoff.0.WIFI-STECKDOSE-5.POWER" not found
    2024-01-08 17:44:00.041  - warn: javascript.0 (11567)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
    2024-01-08 17:44:00.042  - warn: javascript.0 (11567)     at Object.<anonymous> (script.js.Heizung.Gartenhütte_Heizung:15:5)
    2024-01-08 17:44:00.042  - warn: javascript.0 (11567)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
    2024-01-08 17:44:00.042  - warn: javascript.0 (11567)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
    2024-01-08 17:44:00.043  - warn: javascript.0 (11567)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
    2024-01-08 17:44:00.043  - warn: javascript.0 (11567)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
    2024-01-08 17:44:00.043  - warn: javascript.0 (11567)     at listOnTimeout (node:internal/timers:569:17)
    2024-01-08 17:44:00.044  - warn: javascript.0 (11567)     at processTimers (node:internal/timers:512:7)
    2024-01-08 17:44:00.044  - info: javascript.0 (11567) script.js.Heizung.Gartenhütte_Heizung: 25.2
    2024-01-08 17:44:00.044  - info: javascript.0 (11567) script.js.Heizung.Gartenhütte_Heizung: E-Heizung Gartenhütte - AUS
    2024-01-08 17:44:02.049  - warn: sonoff.0 (9536) Client [] has invalid password or username
    W Offline
    W Offline
    wolkenloser
    ich sehe schon: Admin.0 läuft nicht.
    Den konnte ich manuell starten, aber dann funktioniert er nach einem Reboot wieder nicht, oder ?
    • W wolkenloser
      GlasfaserG Offline
      GlasfaserG Offline
      @wolkenloser
      Teste es , dann kann man immer noch nach einem Fehler suchen .
      Aber dein System ... hat schon einiges hintersich und ist nicht Aktuell !
      • W wolkenloser
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                   Chassis: vm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        iobroker
        /home/iobroker
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 5929 M total memory
                 3124 M used memory
                  645 M free memory
                  320 M buffer memory
                 1839 M swap cache
                 1969 M total swap
                  175 M used swap
                 1794 M free swap
        *** FILESYSTEM ***
        /var:
        5.6G    /var/
        3.9G    /var/log
        1.5G    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        11386
        States:         10291
        Pending Updates: 11
        @wolkenloser
        Da musst du mal schauen wo die herkommen. Entweder löschen oder neuinstallieren.
        Veraltet, updaten.
        Pending Updates: 11
        Updates einspielen.
        W 1 Antwort Letzte Antwort
        • W wolkenloser
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                     Chassis: vm
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          iobroker
          /home/iobroker
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
                   5929 M total memory
                   3124 M used memory
                    645 M free memory
                    320 M buffer memory
                   1839 M swap cache
                   1969 M total swap
                    175 M used swap
                   1794 M free swap
          *** FILESYSTEM ***
          /var:
          5.6G    /var/
          3.9G    /var/log
          1.5G    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        11386
          States:         10291
          Pending Updates: 11
          GlasfaserG Offline
          GlasfaserG Offline
          @Thomas-Braun
          gesehn ... sportliche Nummer :
            @wolkenloser
            Veraltet, updaten.
            Pending Updates: 11
            Updates einspielen.
            W Offline
            W Offline
            wolkenloser
            @thomas-braun Du weist doch, wei hatten vor ca 4 Wochen mal alles geupdatet.
            Das ist doch nicht normal, das man so schnell "veraltert" ist ?
            Wenn ich sehe das Adapter ein update haben wollen, mach ich das ja schon immer sofort.
            Kürzlich habe ich den Device-Reminder für Zigbee installiert und kurz danach war wieder alles kaputt, so das ich auf ein Backup gegangen bin.
            Das war bisher eigendlich nie ein Problem, aber seit ein paar Monaten hab ich andauernd irgendwas...
            ich weiss nicht was das sein soll.... schon gar nicht, wie ich das entfernen kann
            GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
            • GlasfaserG Glasfaser
              @Thomas-Braun
              W Offline
              W Offline
              wolkenloser
              @glasfaser
              Die History benutze ich eigendlich gar nicht mehr, Mach ja ales mit informix.
              Ich lösch da erstmal altes Zeug
              • W wolkenloser
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                @wolkenloser
                ... würde auch mal schauen warum der Ordner so aufgebläht ist , 16 Gigabyte ist schon groß
                • W wolkenloser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @wolkenloser
                  einer kommt vom ( eventuell eine anhängigkeit )
                  Adapter
                  der andere sagt mir gerade nichts
                  • W wolkenloser
                    @wolkenloser
                    Man hält das Zeug ja auch laufend aktuell.
                      @wolkenloser
                      W Offline
                      W Offline
                      wolkenloser
                      Ich habe mal in meine History Ordner geschaut was da überhaupt mitgeloggt wird.
                      Ich bin irgendwie irritiert.
                      Was ist das ?
                      Ich finde keine Objekte wo die History aktiviert ist.ich hab das früher mal für Temperaturen gemacht. Das mache ich jetzt aber alles über Influx.
                      Hier ein Beispiel:
                      • W wolkenloser
                        Was ist das ?
                        Hier ein Beispiel:
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @wolkenloser sagte in IOB keine Weboberfläche für Zigbee oder Objekte:
                        Filtere danach .. was zeigt er an :
                        • W Offline
                          W Offline
                          wolkenloser
                          schrieb am zuletzt editiert von wolkenloser
                          @glasfaser
                          3.9G    /opt/iobroker/iobroker-data/
                          3.0G    /opt/iobroker/iobroker-data/history
                          hab viel gelöscht :-)
                          wegen dem NPN Error: Ich habe den Onkyo Adapter der anscheinend EISCP benutzt einmal entfernt und neu intalliert, aber das hat nichts gebracht.
                          • W wolkenloser
                            @glasfaser
                            @wolkenloser
                            cd /opt/iobroker && npm ls buffer eiscp
                              @wolkenloser
                              W Offline
                              W Offline
                              wolkenloser
                              @thomas-braun sagte in IOB keine Weboberfläche für Zigbee oder Objekte:
                              iobroker.inst@2.0.3 /opt/iobroker
                              ├─┬ iobroker.bydhvs@1.5.0
                              │ └─┬ crc@4.3.2
                              │   └── buffer@5.7.1 invalid: ">=6.0.3" from node_modules/crc
                              ├─┬ iobroker.onkyo@2.1.2
                              │ └── eiscp@0.0.1 invalid: "https://github.com/GermanBluefox/node-eiscp/tarball/master/" from node_modules/iobroker.onkyo
                              └─┬ iobroker.shelly@6.6.1
                                ├─┬ mqtt-connection@4.1.0
                                │ └─┬ mqtt-packet@6.10.0
                                │   └─┬ bl@4.1.0
                                │     └── buffer@5.7.1 deduped invalid: ">=6.0.3" from node_modules/crc
                                └─┬ shelly-iot@1.1.2
                                  └─┬ coap@0.26.0
                                    └─┬ bl@5.1.0
                                      └── buffer@6.0.3
                              npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-09T19_16_09_037Z-debug-0.log
                              • W wolkenloser
                                │ └─┬ crc@4.3.2
                                  │   └─┬ bl@4.1.0
                                    └─┬ coap@0.26.0
                                      └─┬ bl@5.1.0
                                        └── buffer@6.0.3
                                @wolkenloser
                                Da siehst du wo es klemmt.
                                • W wolkenloser
                                  │ └─┬ crc@4.3.2
                                    │   └─┬ bl@4.1.0
                                      └─┬ coap@0.26.0
                                        └─┬ bl@5.1.0
                                          └── buffer@6.0.3
                                  @wolkenloser
                                  Installier den nochmal. Hier wird der nämlich dann richtig reingeholt:
                                  │ └─┬ crc@4.3.2
                                  │   └── buffer@6.0.3
                                    @wolkenloser
                                    W Offline
                                    W Offline
                                    wolkenloser
                                    Ich versuch es mal
                                    • W wolkenloser
                                      Ich versuch es mal
                                      @wolkenloser
                                      Gleiches gilt für den:
                                      └─┬ iobroker.onkyo@2.1.2
                                        └── eiscp@0.0.1
                                        @wolkenloser
                                          └── eiscp@0.0.1
                                        W Offline
                                        W Offline
                                        wolkenloser
                                        Ich habe den BYD Adaper deinstalliert und neuinstalliert und nochmal deinstalliert, auch den Onkyo Adapter.
                                        Das Ergebnis ist folgendes
                                        :/opt/iobroker$ cd /opt/iobroker && npm ls buffer eiscp
                                          │   └─┬ bl@4.1.0
                                          │     └── buffer@5.7.1
                                            └─┬ coap@0.26.0
                                              └─┬ bl@5.1.0
                                                └── buffer@6.0.3
                                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-09T20_08_08_522Z-debug-0.log
