  4. [Neuer Adapter] Homepilot20
    1.0k
    6.1k
adapter
268 Beiträge 57 Kommentatoren 69.7k Aufrufe 51 Beobachtet
  • D DominikW
    Habe ich grade ausprobiert, leider keine Änderung.
    Hier mal das Protokoll des IOB, vielleicht hilft das?
    homepilot20.0
    2023-09-19 19:29:33.984	warn	Transmitter sensors -> Cannot connect to Homepilot: {"statusCode":404,"body":"{\"error_description\":\"GET URI not found\",\"error_code\":5002}","headers":{"server":"nginx/1.22.1","date":"Tue, 19 Sep 2023 17:29:33 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.1.117","port":80,"hostname":"192.168.1.117","hash":null,"search":"?devtype=Transmitter","query":"devtype=Transmitter","pathname":"/v4/devices","path":"/v4/devices?devtype=Transmitter","href":"http://192.168.1.117/v4/devices?devtype=Transmitter"},"method":"GET","headers":{"0":{},"1":{"Content-Type":"application/json"}}}}
    homepilot20.0
    2023-09-19 19:29:33.866	warn	Read sensors -> Cannot connect to Homepilot: {"statusCode":404,"body":"{\"error_description\":\"GET URI not found\",\"error_code\":5002}","headers":{"server":"nginx/1.22.1","date":"Tue, 19 Sep 2023 17:29:33 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.1.117","port":80,"hostname":"192.168.1.117","hash":null,"search":"?devtype=Sensor","query":"devtype=Sensor","pathname":"/v4/devices","path":"/v4/devices?devtype=Sensor","href":"http://192.168.1.117/v4/devices?devtype=Sensor"},"method":"GET","headers":{"0":{},"1":{"Content-Type":"application/json"}}}}
    homepilot20.0
    2023-09-19 19:29:30.979	warn	Transmitter sensors -> Cannot connect to Homepilot: {"statusCode":404,"body":"{\"error_description\":\"GET URI not found\",\"error_code\":5002}","headers":{"server":"nginx/1.22.1","date":"Tue, 19 Sep 2023 17:29:30 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.1.117","port":80,"hostname":"192.168.1.117","hash":null,"search":"?devtype=Transmitter","query":"devtype=Transmitter","pathname":"/v4/devices","path":"/v4/devices?devtype=Transmitter","href":"http://192.168.1.117/v4/devices?devtype=Transmitter"},"method":"GET","headers":{"0":{},"1":{"Content-Type":"application/json"}}}}
    homepilot20.0
    2023-09-19 19:29:30.867	warn	Read sensors -> Cannot connect to Homepilot: {"statusCode":404,"body":"{\"error_description\":\"GET URI not found\",\"error_code\":5002}","headers":{"server":"nginx/1.22.1","date":"Tue, 19 Sep 2023 17:29:30 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.1.117","port":80,"hostname":"192.168.1.117","hash":null,"search":"?devtype=Sensor","query":"devtype=Sensor","pathname":"/v4/devices","path":"/v4/devices?devtype=Sensor","href":"http://192.168.1.117/v4/devices?devtype=Sensor"},"method":"GET","headers":{"0":{},"1":{"Content-Type":"application/json"}}}}
    homepilot20.0
    2023-09-19 19:29:30.856	warn	Read actuator -> Cannot connect to Homepilot: {"statusCode":404,"body":"{\"error_description\":\"GET URI not found\",\"error_code\":5002}","headers":{"server":"nginx/1.22.1","date":"Tue, 19 Sep 2023 17:29:30 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.1.117","port":80,"hostname":"192.168.1.117","hash":null,"search":"?devtype=Actuator","query":"devtype=Actuator","pathname":"/v4/devices","path":"/v4/devices?devtype=Actuator","href":"http://192.168.1.117/v4/devices?devtype=Actuator"},"method":"GET","headers":{"0":{},"1":{"Content-Type":"application/json"}}}}
    homecineplexx
    #166
    @dominikw said in [Neuer Adapter] Homepilot20:
    homepilot20.0
    homepilot20.0
    homepilot20.0
    homepilot20.0
    homepilot20.0
    versuch mal http://192.168.1.117/v4/devices?devtype=Actuator
    was gibt er da aus?
    • H homecineplexx
      homepilot20.0
      homepilot20.0
      homepilot20.0
      homepilot20.0
      homepilot20.0
      was gibt er da aus?
      DominikW
      #167
      @homecineplexx
      Im Browser steht folgendes:
      {"error_description":"GET URI not found","error_code":5002}
      H D 2 Antworten Letzte Antwort
      • D DominikW
        @homecineplexx
        homecineplexx
        #168
        @dominikw dann kommst aber mit http://192.168.1.117 nicht hin scheinbar
        • D DominikW
          @homecineplexx
          Daniel
          #169
          @dominikw Ich hatte das gleiche Problem: Wenn ich das richtig verstanden habe, gibt es jetzt zwei Marken: Rademacher und Homepilot. Das "Gateway Premium" von Homepilot scheint nicht mit den Iobroker-Adaptern zu funktionieren - so wie ich das verstanden habe, haben die gar keine öffentlich verfügbare API (zumindest nicht die gleiche, wie die "alten" und neuen Rademacher-Geräte) und auch kein lokales Web-Interface.
          Ich habe das noch im Widerruf-Zeitraum festgestellt und mich beim Homepilot-Support gemeldet: Die waren sehr entgegenkommend und haben mir netterweise als Austauschgerät eine "Rademacher SmartHome Box" geschickt. Interessanterweise sind die Boxen (Gateway Premium von Homepilot und SmartHome Box von Rademacher) äußerlich fast identisch. Die Rademacher-Box hat wieder ein lokales Web-Interface und auch die altbekannte API - und lässt sich wieder ohne Probleme mit dem Homepilot-Adapter verbinden.
          Besten Gruß
          Daniel
          • ? Offline
            #170
            Hey,
            ich habe heute auch einen Homepilot Gateway erhalten. Diesen habe ich versucht, mit dem Adapter zu verbinden. Im Log erhalte ich folgenden Fehler:
            2023-10-21 20:29:33.841 - info: homepilot20.0 (901675) starting. Version 0.0.43 (non-npm: homecineplexx/ioBroker.homepilot20#master) in /opt/iobroker/node_modules/iobroker.homepilot20, node: v18.18.0, js-controller: 4.0.24
            2023-10-21 20:29:34.641 - error: homepilot20.0 (901675) Login/get password-salt -> Cannot connect to Homepilot: {"statusCode":401,"body":"Unauthorized","headers":{"server":"nginx/1.22.1","date":"Sat, 21 Oct 2023 18:29:34 GMT","content-type":"text/html;charset=utf-8","transfer-encoding":"chunked","connection":"close"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"172.16.20.40","port":80,"hostname":"172.16.20.40","hash":null,"search":null,"query":null,"pathname":"/authentication/password_salt","path":"/authentication/password_salt","href":"http://172.16.20.40/authentication/password_salt"},"method":"POST","headers":{"content-length":0}}}
            2023-10-21 20:29:34.645 - error: homepilot20.0 (901675) Adapter will be stopped
            Das Passwort habe ich im Adapter gesetzt (und auch in der App nochmals getestet, dass es das richtige ist).
            http://172.16.20.40/v4/devices?devtype=Actuator
            erzeugt:
            Unauthorized
            Edit:
            Habe jetzt die lokale Passwordabfrage entfernt und lande dann bei dem gleichen Problem wie bei
            @DominikW.
            Werde auch mal den Support anschreiben
            H 1 Antwort Letzte Antwort
              Hey,
              erzeugt:
              Unauthorized
              Edit:
              @DominikW.
              homecineplexx
              #171
              @darkness_08 du hast ein gateway? welches genau?
              und zeig mal was du in den settings eingestellt hast (Foto).
              Lg
              • H homecineplexx
                Lg
                #172
                @homecineplexx
                Ich habe einen Homepilot Gateway Premium in der Softwareversion 1.0.7 und Funkversion 2.4
                "Device is Bridge" aktiviert/deaktiviert ändert nichts.
                (Jetzt ist die Instanz deaktiviert, da mir sonst das Log entsprechend groß wird)
                R H 2 Antworten Letzte Antwort
                  @homecineplexx
                  romans
                  #173
                  @darkness_08 ich habe das gleiche Problem gehabt. füge einfach "/hp" zur IP hinzu. Damit sollten zumindest die Aktoren wieder funktionieren. Die Szenen schient es jedoch nicht mehr zu geben.
                  Wenn ich mal Zeit habe schaue ich es mir nochmal genauer an.
                    @homecineplexx
                    homecineplexx
                    #174
                    @darkness_08 said in [Neuer Adapter] Homepilot20:
                    und @romans also leider habe ich dieses neue Gateway nicht, sonst könnte ich das natürlich versuchen einzubauen. allerdings könnt ihr ja mal mit den Entwicklertools von eurem Browser schauen, was alles abgeholt wird, wenn ihr euer Homepilot Gateway über den Browser öffnet
                    • chriz77C Offline
                      chriz77C Offline
                      chriz77
                      #175
                      kann mir jemand sagen, ob meine Rollomotoren mit der Version 2.0 funktionieren?
                      RADEMACHER RTFM 10/16 Z DuoFern Funk Rolladenmotor (26601065)
                      RADEMACHER RTFS 10/16 Z DuoFern Funk Rolladenmotor (26401065)
                      Momentan steuere ich sie über FHEM und einem DuoFern Stick, bez. auch über MQTT und Loxone, was leider nicht so richtig toll läuft. In Zukunft würde ich sie aber lieber über ioBroker steuern, da ich mittelfristig von FHEM weg möchte. Vermutlich es es egal, ob ich mir gebraucht den Homepilot 2 oder 3 hole oder?
                      Danke und viele Grüße
                      Chris
                      • chriz77C chriz77
                        Chris
                        homecineplexx
                        #176
                        @chriz77 said in [Neuer Adapter] Homepilot20:
                        MQTT und Loxone,
                        Hallo
                        also ich kann dir nur sagen dass ich den homepilot-3 habe mit der Version 5.7.15 und da läuft es. Sollten deine Rolladenmotoren noch nicht im Adapter inkludiert sein, kann ich dir das machen, aber dazu brauch ich deine Hilfe.
                        Schreib mich einfach an.
                        lg chris
                        chriz77C 1 Antwort Letzte Antwort
                        • H homecineplexx
                          MQTT und Loxone,
                          Hallo
                          lg chris
                          chriz77C Offline
                          chriz77C Offline
                          chriz77
                          schrieb am zuletzt editiert von chriz77
                          #177
                          Hi Chris,
                          super, vielen Dank für die Info! 👍
                          Chris
                          • F Offline
                            Funkfrettchen
                            #178
                            Moin ...
                            ich hab heute mal mein Gurtwickler (10251530) angebaut und eine Smart2Smart Bridge installiert. Die Kommunikation läuft auch.
                            Den Homepilot20 zu installieren lief auch smooth durch.
                            Allerdings wird der Gurtwickler nicht als Objekt aufgelistet. Heißt das das 10251530 Gurtwickler RolloTron pure smart schlichtweg noch nicht eingepflegt ist?
                            Gruß Micha
                            Output:
                            http://192.168.178.174/v4/devices?devtype=Actuator
                            {"response":"get_visible_devices","devices":[{"description":"Ihre Gerätebeschreibung","deviceGroup":2,"did":1,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset8"},"messages":[],"name":"Schlafzimmer","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"10251530","uid":"4025fa_1","voiceControlledBy":"Alexa,Google","origin":"HomePilot"}]}
                            • F Funkfrettchen
                              Moin ...
                              Gruß Micha
                              Output:
                              homecineplexx
                              schrieb am zuletzt editiert von homecineplexx
                              #179
                              @funkfrettchen hallo
                              könntest du mir unter git ein issue anlegen, dann kann ich mir das anschauen.
                              https://github.com/homecineplexx/ioBroker.homepilot20
                              und bitte versuch das auch noch und schreibs ins ticket:
                              http://192.168.178.174/devices/1
                              lg
                              F 1 Antwort Letzte Antwort
                              • H homecineplexx
                                lg
                                Funkfrettchen
                                #180
                                @homecineplexx
                                Moin .. wird gemacht :)
                                Gruß Micha
                                • F Funkfrettchen
                                  @homecineplexx
                                  Gruß Micha
                                  Funkfrettchen
                                  #181
                                  @homecineplexx
                                  scheint zu funktionieren .. Dank Dir
                                  • F Funkfrettchen
                                    @homecineplexx
                                    homecineplexx
                                    #182
                                    @funkfrettchen bitteschön..hab dir eine private message hier geschickt!
                                    • H homecineplexx
                                      Funkfrettchen
                                      #183
                                      Moin ...
                                      moin .. noch ein kleines Feedback. Also zumindest für meinen Gurtwickler läuft es sauber und stabil. Zum anderen ist es damit möglich die Rademacher Geräte auch, wie in meinem Fall, ins HomeKit zu integrieren.
                                      Gruß und Danke Micha
                                      • F Funkfrettchen
                                        Moin ...
                                        homecineplexx
                                        #184
                                        @funkfrettchen said in [Neuer Adapter] Homepilot20:
                                        Moin ...
                                        Guten Morgen
                                        Was meinst du damit? meinst du mit der Implementierung oder fehlt dir noch etwas?
                                        glg chris
                                        • chriz77C chriz77
                                          Hi Chris,
                                          Chris
                                          chriz77C Offline
                                          chriz77C Offline
                                          chriz77
                                          #185
                                          Hi Chris,
                                          Chris
                                          Hi Chris,
                                          kurze Rückmeldung, meine Rollos vom Typ 26601065 und 26401065 laufen einwandfrei mit deinem Adapter. Vielen Dank für deine Arbeit!
                                          LG
                                          Chris
