  4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
    5.1k
126 Beiträge 9 Kommentatoren 14.5k Aufrufe 9 Beobachtet
  • H holla16
    in der ncdu bin ich doch. Wenn ich die aufrufe kommt das
    --- / ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------   30.2 MiB [  0.1%] /boot        11.5 KiB [  0.0%] /dev
        2.3 MiB [  0.0%] /etc
      421.9 MiB [  0.7%] /home
    e  16.0 KiB [  0.0%] /lost+found
    e   4.0 KiB [  0.0%] /media
    e   4.0 KiB [  0.0%] /mnt
        1.3 GiB [  2.2%] /opt
    . 245.2 KiB [  0.0%] /proc
       21.0 KiB [  0.0%] /root
        8.1 MiB [  0.0%] /run
    e   4.0 KiB [  0.0%] /srv
       45.7 MiB [  0.1%] /sys
       24.0 KiB [  0.0%] /tmp
        1.4 GiB [  2.4%] /usr
       54.7 GiB [ 94.5%] /var
    @   7.0   B [  0.0%]  bin
    @   7.0   B [  0.0%]  lib
    @   8.0   B [  0.0%]  sbin
    Wenn ich dann in den Ordner mit den 54,7gb gehe kommen mehrere Unterordner. Die Inhalte der Unterordner haben eine geringe Datengröße. Der Inhalt des größten Ordners mit den meisten Daten (>50gb) sieht dann so aus:
    ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help        --- /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------                     /..
      114.4 MiB [  0.2%] /1
      371.8 MiB [  0.7%] /10
        1.1 GiB [  2.1%] /101        1.2 GiB [  2.3%] /103
        1.2 GiB [  2.4%] /105
        1.2 GiB [  2.4%] /107
        1.3 GiB [  2.6%] /109
        1.1 GiB [  2.3%] /111
      242.6 MiB [  0.5%] /113
      413.0 MiB [  0.8%] /12
      451.9 MiB [  0.9%] /14
      492.4 MiB [  1.0%] /16
      537.8 MiB [  1.0%] /18
      588.6 MiB [  1.1%] /21
      640.5 MiB [  1.2%] /23
      691.1 MiB [  1.3%] /25
      742.8 MiB [  1.4%] /27
      794.5 MiB [  1.5%] /29
      846.0 MiB [  1.6%] /31
      897.3 MiB [  1.7%] /33
      948.1 MiB [  1.8%] /35
      861.1 MiB [  1.7%] /37
      606.0 MiB [  1.2%] /39
      265.2 MiB [  0.5%] /4
      657.4 MiB [  1.3%] /41
      708.8 MiB [  1.4%] /43
      759.9 MiB [  1.5%] /45
      811.1 MiB [  1.6%] /47
      862.6 MiB [  1.7%] /49
      913.7 MiB [  1.8%] /51
      706.9 MiB [  1.4%] /53
      750.8 MiB [  1.5%] /55
      801.5 MiB [  1.6%] /57
      852.2 MiB [  1.7%] /59
      299.9 MiB [  0.6%] /6
      903.5 MiB [  1.8%] /61
      955.4 MiB [  1.9%] /63
        1.0 GiB [  2.0%] /65
        1.0 GiB [  2.1%] /67
        1.1 GiB [  2.2%] /69
        1.1 GiB [  2.3%] /71
        1.2 GiB [  2.4%] /73
        1.2 GiB [  2.5%] /75
        1.3 GiB [  2.6%] /77
        1.3 GiB [  2.7%] /79
      335.7 MiB [  0.7%] /8
        1.4 GiB [  2.8%] /81
        1.4 GiB [  2.9%] /83
        1.5 GiB [  3.0%] /85
        1.5 GiB [  3.1%] /87
        1.6 GiB [  3.2%] /89
        1.6 GiB [  3.3%] /91
        1.2 GiB [  2.4%] /93
        1.0 GiB [  2.0%] /95
        1.0 GiB [  2.0%] /97
        1.2 GiB [  2.4%] /99
    In einem weiteren Unterbeispielordner ist dann je eine große Datei drin
    ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help        --- /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen/103 ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------                     /..
      654.0 KiB [  0.1%] /index
        1.2 GiB [ 99.9%]  000000094-000000002.tsm        6.0 KiB [  0.0%]  fields.idx
    #88
    @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
    das müsste mit den dicksten Verzeichnissen beginnen
    H 2 Antworten Letzte Antwort
      holla16
      #89
      ne dachte ichz auch. Das dickste Verzeichnis ist weiter unten mit 54,7gb
        holla16
        #90
        Hab es noch mal neu aufgerufen da kommt das
        ncdu 1.15.1 ~ Use the arrow keys to navigate, press ? for help        --- / ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
           54.7 GiB [##########] /var
            1.5 GiB [          ] /usr
            1.4 GiB [          ] /opt
          440.7 MiB [          ] /home
           30.5 MiB [          ] /boot
            9.1 MiB [          ] /run
            3.9 MiB [          ] /etc
           32.0 KiB [          ] /root
           24.0 KiB [          ] /tmp
        e  16.0 KiB [          ] /lost+found
        e   4.0 KiB [          ] /srv
        e   4.0 KiB [          ] /mnt
        e   4.0 KiB [          ] /media
            0.0   B [          ] /sys
        .   0.0   B [          ] /proc
            0.0   B [          ] /dev
        @   0.0   B [          ]  sbin
        @   0.0   B [          ]  lib
        @   0.0   B [          ]  bin
        • H holla16
          #91
          dann nutzt das nichts
          sollte sortiert sein
          • H holla16
                1.5 GiB [          ] /usr
                1.4 GiB [          ] /opt
              440.7 MiB [          ] /home
               30.5 MiB [          ] /boot
                9.1 MiB [          ] /run
                3.9 MiB [          ] /etc
               32.0 KiB [          ] /root
               24.0 KiB [          ] /tmp
            e   4.0 KiB [          ] /srv
            e   4.0 KiB [          ] /mnt
                0.0   B [          ] /sys
            .   0.0   B [          ] /proc
                0.0   B [          ] /dev
            @   0.0   B [          ]  sbin
            @   0.0   B [          ]  lib
            @   0.0   B [          ]  bin
            #92
            da kommt das
            geht doch!
            mach mal /opt/iobroker auf
            ausser @Thomas-Braun kann dir was aus /var empfehlen
            Thomas BraunT H 2 Antworten Letzte Antwort
              da kommt das
              geht doch!
              #93
              Die journals in /var sind ja schon verkleinert.
              Hier sollte der influx-Datenberg angepackt werden.
                da kommt das
                geht doch!
                holla16
                #94
                sorry aber wie geht /opt/iobroker?
                • H holla16
                  #95
                  @holla16 sagte in Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker:
                  2 runter 1 rechts
                  H 1 Antwort Letzte Antwort
                    2 runter 1 rechts
                    holla16
                    #96
                    OK dann kommt das
                        1.0 GiB [##########] /node_modules
                      362.7 MiB [###       ] /iobroker-data
                       41.6 MiB [          ] /log
                       26.4 MiB [          ] /backups
                        1.0 MiB [          ]  package-lock.json
                        4.0 KiB [          ]  package.json
                        4.0 KiB [          ]  INSTALLER_INFO.txt
                        4.0 KiB [          ]  .npmrc
                    @   0.0   B [          ]  iob
                        0.0   B [          ]  iobroker
                        0.0   B [          ]  diag.sh
                    • H holla16
                      OK dann kommt das
                         41.6 MiB [          ] /log
                          4.0 KiB [          ]  .npmrc
                      @   0.0   B [          ]  iob
                          0.0   B [          ]  iobroker
                          0.0   B [          ]  diag.sh
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      #97
                      @holla16
                      Wenn du nicht mehr alle InfluxDB-Daten benötigst, könntest du die Vorhaltezeit verkürzen. Hast du InfluxDB 1.x oder 2.x? Wie heißt deine Datenbank/Bucket?
                      EDIT: aber auch hierfür benötigt man ein Minimum an freiem Speicherplatz
                      • Marc BergM Marc Berg
                        @holla16
                        holla16
                        #98
                        @marc-berg
                        ich glaube 1.X aber um die Vorhaltezeit zu verkürzen muss ich ja in die Instanz. Da komme ich aktuell nicht rein.
                        • H holla16
                          @marc-berg
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          #99
                          @marc-berg
                          das geht auch auf der Kommandozeile. Wenn du 1.x hast, starte
                          influx
                          Wenn du da drin bist
                          USE <DATEBANKNAME>
                          SHOW RETENTION POLICIES
                          Und dann sehen wir weiter.
                            @marc-berg
                            influx
                            USE <DATEBANKNAME>
                            holla16
                            schrieb am zuletzt editiert von holla16
                            #100
                            @marc-berg
                            wenn ich influx eingebe kommt das
                            pi@raspberrypi:~ $ influx
                            NAME:
                               influx - Influx Client
                            USAGE:
                               influx [command]
                            HINT: If you are looking for the InfluxQL shell from 1.x, run "influx v1 shell"
                            COMMANDS:
                               version              Print the influx CLI version
                               write                Write points to InfluxDB
                               bucket               Bucket management commands
                               completion           Generates completion scripts
                               query                Execute a Flux query
                               config               Config management commands
                               org, organization    Organization management commands
                               delete               Delete points from InfluxDB
                               user                 User management commands
                               task                 Task management commands
                               telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
                               dashboards           List Dashboard(s).
                               export               Export existing resources as a template
                               secret               Secret management commands
                               v1                   InfluxDB v1 management commands
                               auth, authorization  Authorization management commands
                               apply                Apply a template to manage resources
                               stacks               List stack(s) and associated templates. Subcommands manage stacks.
                               template             Summarize the provided template
                               bucket-schema        Bucket schema management commands
                               scripts              Scripts management commands
                               ping                 Check the InfluxDB /health endpoint
                               setup                Setup instance with initial user, org, bucket
                               backup               Backup database
                               restore              Restores a backup directory to InfluxDB
                               remote               Remote connection management commands
                               replication          Replication stream management commands
                               server-config        Display server config
                               help, h              Shows a list of commands or help for one command
                            was muss ich als Name eingeben?
                            • H holla16
                              @marc-berg
                              NAME:
                              USAGE:
                                 influx [command]
                              COMMANDS:
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              #101
                              Dann ist es keine 1.x, sondern 2.x
                              Kommst Du auf die Weboberfläche der DB?
                              http://<IP des RASPI>:8086
                                holla16
                                #102
                                @marc-berg
                                ne auf die Weboberfläche geht mit der Ip und dem Port nicht.
                                • H holla16
                                  @marc-berg
                                  Marc BergM Offline
                                  Marc BergM Offline
                                  Marc Berg
                                  #103
                                  Hast du die DB noch gestoppt?
                                  @thomas-braun sagte in Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker:
                                  sudo systemctl stop influxd*
                                  dann wieder starten.
                                  sudo systemctl start influxd*
                                    holla16
                                    #104
                                    @marc-berg
                                    ist ausgeführt:
                                    pi@raspberrypi:~ $ sudo systemctl start influxd*
                                    Warning: systemctl start called with a glob pattern.
                                    Hint: unit globs expand to loaded units, so start will usually have no effect.
                                          Passing --all will also load units which are pulled in by other units.
                                          See systemctl(1) for more details.
                                    Job for influxdb.service failed because the control process exited with error code.
                                    See "systemctl status influxdb.service" and "journalctl -xe" for details.
                                    pi@raspberrypi:~ $
                                    auf die Weboberfläche komme ich aber noch nicht
                                    Marc BergM 2 Antworten Letzte Antwort
                                    • H holla16
                                      @marc-berg
                                      ist ausgeführt:
                                      pi@raspberrypi:~ $
                                      Marc BergM Offline
                                      Marc BergM Offline
                                      Marc Berg
                                      #105
                                      Ich denke, die DB kann wegen deines Speicherproblems nicht gestartet werden. Puh ...
                                      • H holla16
                                        @marc-berg
                                        ist ausgeführt:
                                        pi@raspberrypi:~ $
                                        Marc BergM Offline
                                        Marc BergM Offline
                                        Marc Berg
                                        #106
                                        @holla16
                                        Ich glaube, jetzt hilft nur noch der Holzhammer. Wenn die Daten nicht zu wichtig sind, dann einfach einen Shard löschen:
                                        sudo rm -r /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen/1
                                        Den Raspi neu starten und schauen, ob die DB wieder hoch kommt. Dann auf die Oberfläche und die Vorhaltezeit verkürzen.
                                          @holla16
                                          holla16
                                          #107
                                          @marc-berg
                                          geht auch nicht
                                          pi@raspberrypi:~ $ sudo rm -r /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen/1
                                          rm: cannot remove '/var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen/1': No such file or directory
                                          pi@raspberrypi:~ $
