  4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
    5.1k
126 Beiträge 9 Kommentatoren 14.5k Aufrufe 9 Beobachtet
  • H holla16
    pi@raspberrypi:/opt/iobroker $ df -h
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/root        59G   58G     0 100% /
    devtmpfs        3.7G     0  3.7G   0% /dev
    tmpfs           3.9G     0  3.9G   0% /dev/shm
    tmpfs           1.6G  9.1M  1.6G   1% /run
    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
    /dev/mmcblk0p1  255M   31M  225M  12% /boot
    tmpfs           782M     0  782M   0% /run/user/1000
    @holla16
    cd /opt/iobroker
    du -cks * | sort -rn | head
    H 1 Antwort Letzte Antwort
      @holla16
      cd /opt/iobroker
      holla16
      @thomas-braun said in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
      pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ du -cks * | sort -rn | head
      1456376 total
      1014316 node_modules
      371380  iobroker-data
      42608   log
      27060   backups
      1004    package-lock.json
      4       package.json
      4       INSTALLER_INFO.txt
      0       iobroker
      0       iob
      • H holla16
        1456376 total
        42608   log
        27060   backups
        4       package.json
        0       iobroker
        0       iob
        @holla16
        sudo journalctl --vacuum-time=1d
          @holla16
          holla16
          pi@raspberrypi:/opt/iobroker $ sudo journalctl --vacuum-time=1d
          Journal file /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system.journal is truncated, ignoring file.
          Vacuuming done, freed 0B of archived journals from /var/log/journal.
          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf4377d-29094d0e0283d9c4.journal~ (4.0K).
          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf60270-5ed240af70674cab.journal~ (16.0K).
          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/user-1001@00060e412865f478-c67b3d07a3effefe.journal~ (0B).
          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e4311051e99-63e627a9400cfabf.journal~ (4.0K).
          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e4128666972-6cc52e4157cb0ff4.journal~ (6.8M).
          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bfd91c1-7ce41f4661306f35.journal~ (16.0K).
          Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf47993-12a2a39f85f1a43d.journal~ (16.0K).
          Vacuuming done, freed 6.9M of archived journals from /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9.
          Vacuuming done, freed 0B of archived journals from /run/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9.
          Vacuuming done, freed 0B of archived journals from /run/log/journal.
          • H holla16
            @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
            freed 6.9M
            Das ist natürlich nix.
            sudo ncdu /
            wird vermutlich nicht funktionieren.
            H HomoranH 3 Antworten Letzte Antwort
              freed 6.9M
              sudo ncdu /
              holla16
              sudo ncdu /
              Es öffnet sich ein neues "Fenster" mit diesen Infos:
                  1.5 GiB [          ] /usr
                  1.4 GiB [          ] /opt
                440.7 MiB [          ] /home
                 30.5 MiB [          ] /boot
                  9.1 MiB [          ] /run
                  3.9 MiB [          ] /etc
                 32.0 KiB [          ] /root
                 24.0 KiB [          ] /tmp
              e  16.0 KiB [          ] /lost+found
              e   4.0 KiB [          ] /srv
              e   4.0 KiB [          ] /mnt
              e   4.0 KiB [          ] /media
                  0.0   B [          ] /sys
              .   0.0   B [          ] /proc
                  0.0   B [          ] /dev
              @   0.0   B [          ]  sbin
              @   0.0   B [          ]  lib
              @   0.0   B [          ]  bin
                freed 6.9M
                sudo ncdu /
                holla16
                soll ich da wieder raus und wenn ja wie?
                • H holla16
                  @holla16
                  Nee, damit suchst du jetzt die dicken Dinger.
                    @holla16
                    holla16
                    ok und das mache ich wie?
                    • H holla16
                      @holla16
                      Mit den Pfeiltasten durch die Verzeichnisse hangeln. Die dicken haben die meisten #-Zeichen...
                      Bei mir also z. B.
                      ncdu 1.19 ~ Use the arrow keys to navigate, press ? for help
                          5.8 GiB [#################] /opt
                          2.6 GiB [#######          ] /usr
                          1.1 GiB [###              ] /var
                        906.9 MiB [##               ] /home
                        161.6 MiB [                 ] /boot
                         22.7 MiB [                 ] /tmp
                          5.5 MiB [                 ] /etc
                      Näheres dann per ?-Taste im Programm.
                      H 2 Antworten Letzte Antwort
                      • H holla16
                        sudo ncdu /
                            1.5 GiB [          ] /usr
                            1.4 GiB [          ] /opt
                          440.7 MiB [          ] /home
                           30.5 MiB [          ] /boot
                            9.1 MiB [          ] /run
                            3.9 MiB [          ] /etc
                           32.0 KiB [          ] /root
                           24.0 KiB [          ] /tmp
                        e   4.0 KiB [          ] /srv
                        e   4.0 KiB [          ] /mnt
                            0.0   B [          ] /sys
                        .   0.0   B [          ] /proc
                            0.0   B [          ] /dev
                        @   0.0   B [          ]  sbin
                        @   0.0   B [          ]  lib
                        @   0.0   B [          ]  bin
                        #66
                        ist das alles?
                        du hast laut df -h 58GB voll
                          @holla16
                          Bei mir also z. B.
                              1.1 GiB [###              ] /var
                            161.6 MiB [                 ] /boot
                             22.7 MiB [                 ] /tmp
                              5.5 MiB [                 ] /etc
                          holla16
                          #67
                          hab den Fehler gefunden. Es sind influxdb Daten:
                          --- /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------                         /..
                              1.6 GiB [##########] /91
                              1.6 GiB [######### ] /89
                              1.5 GiB [######### ] /87
                              1.5 GiB [######### ] /85
                              1.4 GiB [########  ] /83
                              1.4 GiB [########  ] /81
                              1.3 GiB [########  ] /79
                              1.3 GiB [########  ] /109        1.3 GiB [#######   ] /77
                              1.2 GiB [#######   ] /75
                              1.2 GiB [#######   ] /107
                              1.2 GiB [#######   ] /105
                              1.2 GiB [#######   ] /93
                              1.2 GiB [#######   ] /99
                              1.2 GiB [#######   ] /73
                              1.2 GiB [#######   ] /103
                              1.1 GiB [######    ] /111
                              1.1 GiB [######    ] /71
                              1.1 GiB [######    ] /69
                              1.1 GiB [######    ] /101
                              1.0 GiB [######    ] /67
                              1.0 GiB [######    ] /95
                              1.0 GiB [######    ] /97
                              1.0 GiB [######    ] /65
                            955.4 MiB [#####     ] /63
                            948.1 MiB [#####     ] /35
                            913.8 MiB [#####     ] /51
                            903.5 MiB [#####     ] /61
                            897.4 MiB [#####     ] /33
                            862.6 MiB [#####     ] /49
                            861.2 MiB [#####     ] /37
                            852.2 MiB [#####     ] /59
                            846.1 MiB [#####     ] /31
                            811.1 MiB [####      ] /47
                            801.6 MiB [####      ] /57
                            794.6 MiB [####      ] /29
                            759.9 MiB [####      ] /45
                            750.9 MiB [####      ] /55
                            742.8 MiB [####      ] /27
                            708.8 MiB [####      ] /43
                            707.0 MiB [####      ] /53
                            691.2 MiB [####      ] /25
                            657.5 MiB [###       ] /41
                            640.6 MiB [###       ] /23
                            606.0 MiB [###       ] /39
                            588.6 MiB [###       ] /21
                            537.8 MiB [###       ] /18
                            492.5 MiB [##        ] /16
                            451.9 MiB [##        ] /14
                            413.1 MiB [##        ] /12
                            371.9 MiB [##        ] /10
                            335.7 MiB [##        ] /8
                            300.0 MiB [#         ] /6
                            265.2 MiB [#         ] /4
                            242.7 MiB [#         ] /113
                            114.5 MiB [          ] /1
                            @holla16
                            Bei mir also z. B.
                                1.1 GiB [###              ] /var
                              161.6 MiB [                 ] /boot
                               22.7 MiB [                 ] /tmp
                                5.5 MiB [                 ] /etc
                            holla16
                            #68
                            kann auf die influx bd. daten gern verzichten. Die liefen eh nur mit ohne, dass ich bisher damit was gemacht habe. Kann man die Löschen und wenn ja wie?
                            • H holla16
                              #69
                              @holla16
                              Bei influxdb kenne ich micht nicht aus.
                              Löschen mit
                              sudo apt purge influxdb*
                              Edit: Wrong command... :-)
                                @holla16
                                Löschen mit
                                #70
                                @thomas-braun sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                                @holla16
                                Löschen mit
                                sudo apt prune influxdb*
                                löscht aber die Daten nicht
                                kenne mich mit dem Influx Adapter nicht aus, aber ggf. kann man da auch die Aufbewahrungszeit reduzieren, dann werden alte Daten gelöscht
                                Thomas BraunT H 2 Antworten Letzte Antwort
                                  @holla16
                                  Löschen mit
                                  #71
                                  @homoran sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                                  Hast recht.
                                    @holla16
                                    Löschen mit
                                    holla16
                                    #72
                                    das kann ich ja gerne versuchen, ich komme in den iobroker aber nicht rein. Kein Zugriff per ip Adresse. nur über das Terminal. Heißt den Adapter kann ich aktuell wegen dem vollen speicher nicht konfigurieren. Heißt da müssen daten weg. Nur wie und welche?
                                    • H holla16
                                      #73
                                      logdateien in /opt/iobroker/logs
                                      leider zeigst du nicht alles.
                                      Hab vorhin schon nachgefragt
                                        holla16
                                        #74
                                        das sind alle 57 gb daten: Und daher die Frage ob man die löschen kann? Dann wäre die Hoffnung wieder per IP Adresse auf den ioBroker zugreifen zu können und dann würde ich den Adapter neu konfigurieren.
                                          114.4 MiB [  0.2%] /1
                                          371.8 MiB [  0.7%] /10
                                            1.1 GiB [  2.1%] /101
                                            1.2 GiB [  2.3%] /103
                                            1.2 GiB [  2.4%] /105
                                            1.2 GiB [  2.4%] /107
                                            1.3 GiB [  2.6%] /109
                                            1.1 GiB [  2.3%] /111
                                          242.6 MiB [  0.5%] /113
                                          413.0 MiB [  0.8%] /12
                                          451.9 MiB [  0.9%] /14
                                          492.4 MiB [  1.0%] /16
                                          537.8 MiB [  1.0%] /18
                                          588.6 MiB [  1.1%] /21
                                          640.5 MiB [  1.2%] /23
                                          691.1 MiB [  1.3%] /25
                                          742.8 MiB [  1.4%] /27
                                          794.5 MiB [  1.5%] /29
                                          846.0 MiB [  1.6%] /31
                                          897.3 MiB [  1.7%] /33
                                          948.1 MiB [  1.8%] /35
                                          861.1 MiB [  1.7%] /37
                                          606.0 MiB [  1.2%] /39
                                          265.2 MiB [  0.5%] /4
                                          657.4 MiB [  1.3%] /41
                                          708.8 MiB [  1.4%] /43
                                          759.9 MiB [  1.5%] /45
                                          811.1 MiB [  1.6%] /47
                                          862.6 MiB [  1.7%] /49
                                          913.7 MiB [  1.8%] /51
                                          706.9 MiB [  1.4%] /53
                                          750.8 MiB [  1.5%] /55
                                          801.5 MiB [  1.6%] /57
                                          852.2 MiB [  1.7%] /59
                                          299.9 MiB [  0.6%] /6
                                          903.5 MiB [  1.8%] /61
                                          955.4 MiB [  1.9%] /63
                                            1.0 GiB [  2.0%] /65
                                            1.0 GiB [  2.1%] /67
                                            1.1 GiB [  2.2%] /69
                                            1.1 GiB [  2.3%] /71
                                            1.2 GiB [  2.4%] /73
                                            1.2 GiB [  2.5%] /75
                                            1.3 GiB [  2.6%] /77        1.3 GiB [  2.7%] /79
                                          335.7 MiB [  0.7%] /8
                                            1.4 GiB [  2.8%] /81
                                            1.4 GiB [  2.9%] /83
                                            1.5 GiB [  3.0%] /85
                                            1.5 GiB [  3.1%] /87
                                            1.6 GiB [  3.2%] /89
                                            1.6 GiB [  3.3%] /91
                                            1.2 GiB [  2.4%] /93
                                            1.0 GiB [  2.0%] /95
                                            1.0 GiB [  2.0%] /97
                                            1.2 GiB [  2.4%] /9
                                          ist das alles?
                                          #75
                                          ist das alles?
                                          und wie sehen die 58GB in ncdu aus?
                                          aber unsortiert!
