  4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
    5.1k
126 Beiträge 9 Kommentatoren 14.5k Aufrufe 9 Beobachtet
  • H Offline
    holla16
    schrieb am zuletzt editiert von holla16
    entschuldigt bitte meine nicht perfekten Kenntnisse: Wenn ich iob diag eingebe kommt folgendes:
    pi@raspberrypi:~ $ select all inet 192.168.178.57
    -bash: syntax error near unexpected token `inet'
    pi@raspberrypi:~ $ iob diag
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
    pi@raspberrypi:~ $
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    pi@raspberrypi:~ $
    R da_WoodyD Thomas BraunT 3 Antworten Letzte Antwort
    • H holla16
      iobroker [command]
      Commands:
      pi@raspberrypi:~ $
      Options:
      pi@raspberrypi:~ $
      Rico Sander
      schrieb am zuletzt editiert von Rico Sander
      @holla16
      Ist denn diag installiert?
      curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
      Wenns nicht geht, wie man will
      - muss mans tun, wie man kann.
      • H Offline
        holla16
        @Pi-ter : soll ich das eingeben? curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
        Wenn ich das eingebe dann passiert nichts...
        • H holla16
          iobroker [command]
          Commands:
          pi@raspberrypi:~ $
          Options:
          pi@raspberrypi:~ $
          da_WoodyD Online
          da_WoodyD Online
          @holla16 auch für dich. Log immer in Tags schreiben. So ist das unleserlich.
          • H holla16
            iobroker [command]
            Commands:
            pi@raspberrypi:~ $
            Options:
            pi@raspberrypi:~ $
            @holla16
            iob stop
            iob fix
            iob start
            Und dann
            iob diag
            • H holla16
              ich gebe in der Eingabeaufforderung in Windows ein:
              ssh pi@raspberry
              anschl. das Passwort und bin dann in der "ssh Ebene"
              Ich kann dann z.B. sudo raspi-config eingeben. Das funktioniert alles. Alles mit der IP die ich sonst immer gewählt habe um z.B. den ioBroker aufzurufen. In der Fritzbox ist der Raspi auch als aktive Verbindung:
              da_WoodyD Online
              da_WoodyD Online
              @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
              Auch möglich, aber geht einfacher mit PuTTY, oder besser mobaxterm.
              • H Offline
                holla16
                @da_Woody wie schreibe ich in Tags?
                • H holla16
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Lehrling seit 1975 !!!
                  • H Offline
                    holla16
                    @Thomas-Braun dann kommt das
                    pi@raspberrypi:~ $ iob stop
                    pi@raspberrypi:~ $ iob fix
                    library: loaded
                    Library version=2024-01-04
                        Welcome to the ioBroker installation fixer!
                        Script version: 2024-01-04
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/5)
                    Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
                    Err:1 http://deb.debian.org/debian bullseye InRelease
                      Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:65::644 80]
                    Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
                    Err:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      Error writing to file - write (28: No space left on device) [IP: 2a00:1098:82:47::2:1 80]
                    Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                    Err:3 http://security.debian.org/debian-security bullseye-security InRelease
                    Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                    Err:4 http://deb.debian.org/debian bullseye-updates InRelease
                    Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,049 B]
                    Err:5 https://repos.influxdata.com/debian bullseye InRelease
                      Error writing to file - write (28: No space left on device) [IP: 2600:9000:2315:4400:11:fe8d:7d40:93a1 443]
                    Get:6 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
                    Err:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Error writing to file - write (28: No space left on device) [IP: 2606:4700:10::ac43:acd 443]
                    Reading package lists... Error!
                    W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:65::644 80]
                    W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:65::644 80]
                    W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a04:4e42:65::644 80]
                    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2600:9000:2315:4400:11:fe8d:7d40:93a1 443]
                    W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2606:4700:10::ac43:acd 443]
                    W: Failed to fetch http://archive.raspberrypi.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a00:1098:82:47::2:1 80]
                    W: Some index files failed to download. They have been ignored, or old ones used instead.
                    E: Write error - write (28: No space left on device)
                    E: IO Error saving source cache
                    E: The package lists or status file could not be parsed or opened.
                        Checking ioBroker user and directory permissions (2/5)
                    usermod: /etc/passwd.1010: No space left on device
                    usermod: cannot lock /etc/passwd; try again later.
                    main: line 702: echo: write error: No space left on device
                    usermod: /etc/shadow.1222: No space left on device
                    usermod: cannot lock /etc/shadow; try again later.
                    usermod: /etc/shadow.1225: No space left on device
                    usermod: /etc/shadow.1228: No space left on device
                    usermod: /etc/shadow.1231: No space left on device
                    usermod: /etc/shadow.1234: No space left on device
                    usermod: /etc/passwd.1238: No space left on device
                    usermod: /etc/passwd.1241: No space left on device
                    usermod: /etc/passwd.1302: No space left on device
                        Check and cleanup npm temporary directories (3/5)
                    Done.
                        Database maintenance (4/5)
                    Checking for uncompressed JSONL databases... This might take a while!
                    npm ERR! code ENOSPC
                    npm ERR! syscall write
                    npm ERR! errno -28
                    npm ERR! nospc ENOSPC: no space left on device, write
                    npm ERR! nospc There appears to be insufficient space on your system to finish.
                    npm ERR! nospc Clear up some disk space and try again.
                    npm ERR!     /home/iobroker/.npm/_logs/2024-01-06T10_14_32_048Z-debug-0.log
                    main: line 14: [: -lt: unary operator expected
                    npm ERR! errno -28
                    npm ERR!     /home/iobroker/.npm/_logs/2024-01-06T10_14_33_034Z-debug-0.log
                        Checking autostart (5/5)
                    Enabling autostart...
                    Failed to enable unit: Unit file /lib/systemd/system/iobroker.service is masked.
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    • H Offline
                      holla16
                      @DJMarc75 : Vielen Dank
                      • H holla16
                        @holla16
                        Der Datenträger ist voll.
                        • H Offline
                          holla16
                          @Thomas-Braun ok, heißt ich kann was machen? Es kann sein, dass die Backups dort gespeichert wurde. Was mich nur wundert. Ich nehme den Raspi fälschlicher Weise so vom Stromnetz, will ich wieder an machen und nichts geht mehr.
                          Einfach SD Karte raus backups löschen und loslegen?
                          da_WoodyD Thomas BraunT 2 Antworten Letzte Antwort
                          • H holla16
                            da_WoodyD Online
                            da_WoodyD Online
                            SD raus, wird dein raspi nicht mehr starten...
                            Wie groß ist die SD? abstecken, wieder anstecken macht bei meinen raspis fürs 3d drucken kein problem. bei ioB kanns knallen.
                            • H holla16
                              @holla16
                              Wenn du so grobschlächtig mit dem Ding umgehst wundert mich eigentlich nix mehr.
                              Mit
                              sudo apt clean
                              da etwas Luft verschaffen.
                              Dann nochmal wie oben.
                              H 1 Antwort Letzte Antwort
                              • da_WoodyD da_Woody
                                @da_woody sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
                                Ist auch da Mist. Nie machen, Dateisysteme IMMER sauber aushängen.
                                  @holla16
                                  Mit
                                  sudo apt clean
                                  holla16
                                  @thomas-braun Ja was ich da jetzt für einen Mist habe, werde ich das zukünftig anders machen.
                                  • H Offline
                                    holla16
                                    ich könnt abdrehen... Hab die SD Karte im Windows PC angeschaut, nicht gemacht. Dann wieder in den Raspi und dann die Befehle ausgeführt. Aber keine Reaktion:
                                    pi@raspberrypi:~ $ sudo apt clean
                                    pi@raspberrypi:~ $ iob start
                                    pi@raspberrypi:~ $
                                    Wenn ich df eingebe
                                    pi@raspberrypi:~ $ df
                                    Filesystem     1K-blocks     Used Available Use% Mounted on
                                    /dev/root       61092524 60901000         0 100% /
                                    devtmpfs         3834160        0   3834160   0% /dev
                                    tmpfs            3999920        0   3999920   0% /dev/shm
                                    tmpfs            1599972     9284   1590688   1% /run
                                    tmpfs               5120        4      5116   1% /run/lock
                                    /dev/mmcblk0p1    261108    31264    229844  12% /boot
                                    tmpfs             799984        0    799984   0% /run/user/1000
                                    pi@raspberrypi:~ $
                                    sieht man das die Partition zu 100% voll ist. Kann ich das letzte Backup nicht irgendwie sichern und den ioBroker neu aufsetzen und das Backup einspielen?
                                      da_WoodyD Online
                                      da_WoodyD Online
                                      @thomas-braun ist mir grundsätzlich klar, aber hatte seit 3 Jahren kein Problem. Vllt immer Glück gehabt. Da wird ja auch nicht dauernd auf die Karte zugegriffen.
                                      Drucker und raspi hängen an einem Shelly Plug. Ein Klick, Strom weg.
                                        Könnte auch zu 'Ein Klick, System weg' führen. Ist aber hier für den TE uninteressant, wie du deine Kisten malträtierst.
                                        • H holla16
                                          pi@raspberrypi:~ $
                                          Wenn ich df eingebe
                                          pi@raspberrypi:~ $
                                          da_WoodyD Online
                                          da_WoodyD Online
                                          @holla16 solange du noch auf den raspi kommst, geht noch was. Alte Backups löschen, dann ist wieder Luft.
                                          Wie das geht kann dir @Thomas-Braun sicher erklären.
                                          Neu, sauber aufsetzen wird kein Fehler sein...
