  3. Einsteigerfragen
  4. Javascript Adapter stürzt ab
    5.5k
javascript hilfe rot
38 Beiträge 8 Kommentatoren 4.9k Aufrufe 6 Beobachtet
  • D dos1973
    @dos1973
    gesamt als anhang
    diag2.txt
    			v.2023-10-10
     Static hostname: pve-iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-13-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org
    Installation: 		kvm
    Kernel: 		x86_64
    Userland: 		amd64
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		false
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
    			/usr/bin/node 		v18.19.0
    			/usr/bin/npm 		10.2.3
    			/usr/bin/npx 		10.2.3
    			/usr/bin/corepack 	0.22.0
    Recommended versions are nodejs 18.19.0 and npm 10.2.3
    MEMORY:
    Mem:             16G        4.1G         10G        577K        1.7G         12G
    Swap:           1.0G          0B        1.0G
    Total:           17G        4.1G         11G
    Active iob-Instances: 	35
    ioBroker Core: 		js-controller 		5.0.17
    			admin 			6.12.0
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : pve-iobroker                             -  enabled, port: 8081, bind: 192.168.10.6, run as: admin
    + system.adapter.web.0                    : web                   : pve-iobroker                             -  enabled, port: 8082, bind: 192.168.10.6, run as: admin
    Objects: 		47009
    States: 		45903
    Size of iob-Database:
    53M	/opt/iobroker/iobroker-data/objects.jsonl
    28M	/opt/iobroker/iobroker-data/objects.json.migrated
    28M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    59M	/opt/iobroker/iobroker-data/states.jsonl
    8.4M	/opt/iobroker/iobroker-data/states.json.migrated
    8.4M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    0	/opt/iobroker/iobroker-data/states.json.broken
    === Mark text until here for copying ===
    dos1973
    ab und an kommt diese Meldung:
    Cannot read compact mode by host "system.host.pve-iobroker": timeout
    • D dos1973
      liv-in-skyL Offline
      liv-in-skyL Offline
      @dos1973 sagte in Javascript Adapter stürzt ab:
      schau mal: https://forum.iobroker.net/topic/55373/seit-update-node-v12-v14-ständige-fehlermeldung
      • liv-in-skyL liv-in-sky
        dos1973
        schrieb am zuletzt editiert von dos1973
        @liv-in-sky
        ich hatte alle scripte deaktiviert und neu gestartet - gleicher effekt.
        edit: also iobroker neu gestartet.
        • R radiorichter
          Hallo Beisammen,
          bisher lief alles einwandfrei. nun wollte ich vom knx adapter auf den openknx adapter umsteigen, soweit so gut.
          Jetzt muss ich hierzu alle Pfade in den Skripten und VIS ändern, was an und für sich ja kein thema ist.
          Doch plötzlich stützt bei mir der Java-adapter immer ab, sobald ich die skripte öffne und ein objekt im pfad ändern möchte.
          Hab mal den Fixer laufen lassen, keine Besserung... mal eine zweite Javascript Instanz installiert, auch nichts gebracht...
          im log steht zb das hier, aber das bringt mich auch nicht wirklich weiter...
          was könnte das noch sein? ich verzweifele hier noch...
          system:
          EE-PC-2565
          Plattform
          linux
          Betriebssystem
          linux
          Architektur
          x64
          CPUs
          Geschwindigkeit
          2001 MHz
          Modell
          Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
          RAM
          7.83 GB
          System-Betriebszeit
          01:36:27
          Node.js
          v16.16.0 (Es gibt eine neuere Version: v16.19.0)
          time
          1673043675141
          timeOffset
          -60
          Anzahl der Adapter
          537
          NPM
          8.11.0
          Datenträgergröße
          118.35 GB
          freier Festplattenspeicher
          53.74 GB
          Betriebszeit
          00:43:35
          Aktive Instanzen
          37
          Weg
          /opt/iobroker/
          Hostname
          EE-PC-2565
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @radiorichter
          bitte genügend log (als text) posten, damit man den absturz des adapters auch sieht.
          oder ist es nur das skript?
          ich würde auch mal davon ausgehen, das durch das ändern du dir irgend einen fehler im skript eingehandelt hast, der eine schleife produziert oder ein heap-overflow oder sowas ähnliches.
          kannst du das skript schon einkreisen was den "absturz" verursacht? dann das hier auch für einen review posten
          Meine Adapter und Widgets
          Links im Profil
          • OliverIOO OliverIO
            @radiorichter
            dos1973
            @oliverio
            es ist kein script.
            ich kann alle scripte deaktivieren und ein neues erstellen. Der Fehler bleibt
            • D dos1973
              @oliverio
              es ist kein script.
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @dos1973
              vielen dank für die beantwortung des 2.Teils meines Posts.
              Wenn du noch den 1.Teil nachlieferst erreichen wir das glücklichsein früher
              Links im Profil
                dos1973
                @oliverio
                aktuell sind alle scripte deaktiviert.
                admin.0
                2024-01-05 17:53:52.121	info	<== Disconnect system.user.admin from 192.168.10.180 javascript
                admin.0
                admin.0
                2024-01-05 17:53:51.461	info	==> Connected system.user.admin from 192.168.10.180
                admin.0
                2024-01-05 17:53:49.843	error	Alias subscription error. Please check your alias definitions: sourceId=javascript.0.lmair.temp-sensoren.channel10-wohnzimmer.temperature, sourceObj={"common":{"name":"temperature","desc":"temperature von channel10-wohnzimmer","type":"number","def":0,"role":"value","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"1000","retention":"31536000","changesRelogInterval":"300","changesMinDelta":0,"storageType":"","aliasId":"","debounceTime":0,"blockTime":1000,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"counter":false,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false},"influxdb.0":{"enabled":true,"storageType":"","aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000}}},"native":{},"type":"state","_id":"javascript.0.lmair.temp-sensoren.channel10-wohnzimmer.temperature","acl":{"object":1636,"state":1636,"ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1701654836793}
                admin.0
                2024-01-05 17:53:49.843	error	Alias subscription error. Please check your alias definitions: sourceId=javascript.0.lmair.temp-sensoren.channel10-wohnzimmer.humidity, sourceObj={"common":{"name":"humidity","desc":"humidity von channel10-wohnzimmer","type":"number","def":0,"role":"value","custom":{"sql.0":{"enabled":true,"changesOnly":true,"debounce":"1000","retention":"31536000","changesRelogInterval":"300","changesMinDelta":0,"storageType":"","aliasId":"","counter":false,"debounceTime":0,"blockTime":1000,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"customRetentionDuration":365,"maxLength":10,"enableDebugLogs":false},"influxdb.0":{"enabled":true,"changesOnly":true,"debounce":"1000","retention":"31536000","changesRelogInterval":0,"changesMinDelta":0,"storageType":"","aliasId":"","debounceTime":0,"blockTime":1000,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false}}},"native":{},"type":"state","_id":"javascript.0.lmair.temp-sensoren.channel10-wohnzimmer.humidity","acl":{"object":1636,"state":1636,"ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1701654830818}
                admin.0
                2024-01-05 17:53:49.842	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#C45BBE6C2843#1.hostname, sourceObj={"type":"state","common":{"name":{"en":"Device IP address or hostname","de":"Geräte-IP-Adresse oder Hostname","ru":"IP-адрес устройства или имя хоста","pt":"Endereço IP do dispositivo ou nome de host","nl":"IP-adres of gastnaam","fr":"Adresse IP ou nom d'hôte","it":"Indirizzo IP del dispositivo o nome host","es":"Dirección IP o nombre de host","pl":"Adres IP lub hostname","uk":"Пристрої IP адреси або ім'я користувача","zh-cn":"設備 IP 地址或主機名"},"type":"string","role":"info.ip","read":true,"write":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704473434256,"_id":"shelly.1.SHSW-25#C45BBE6C2843#1.hostname","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.842	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#C45BBE6C2843#1.Relay1.Power, sourceObj={"type":"state","common":{"name":"Power","type":"number","role":"value.power","read":true,"write":false,"def":0,"unit":"W","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":1,"start_day":0.004141953866666666,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"selectedPrice":"ElectricityDay","costs":true,"consumption":true,"meter_values":true,"basicRate":true,"valueAtDeviceInit":null,"valueAtDeviceReset":null,"cumulativeValue":0.004141953866666666}}},"native":{},"_id":"shelly.1.SHSW-25#C45BBE6C2843#1.Relay1.Power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704473433765}
                admin.0
                2024-01-05 17:53:49.842	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#C45BBE6C2843#1.Relay0.Power, sourceObj={"type":"state","common":{"name":"Power","type":"number","role":"value.power","read":true,"write":false,"def":0,"unit":"W","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":1,"start_day":0.057646663513888884,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"selectedPrice":"ElectricityDay","costs":true,"consumption":true,"meter_values":true,"basicRate":true,"valueAtDeviceInit":null,"valueAtDeviceReset":null,"cumulativeValue":0.057646663513888884}}},"native":{},"_id":"shelly.1.SHSW-25#C45BBE6C2843#1.Relay0.Power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704473433739}
                admin.0
                2024-01-05 17:53:49.842	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHHT-1#D34034#1.name, sourceObj={"type":"state","common":{"name":{"en":"Device name","de":"Bezeichnung des Geräts","ru":"Наименование устройства","pt":"Nome do dispositivo","nl":"Devicenaam","fr":"Nom du dispositif","it":"Nome del dispositivo","es":"Nombre del dispositivo","pl":"Device name","uk":"Назва пристрою","zh-cn":"证人姓名"},"type":"string","role":"info.name","read":true,"write":true,"icon":"data:image/svg+xml;base64,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"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704401099005,"_id":"shelly.1.SHHT-1#D34034#1.name","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.841	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHHT-1#D34034#1.bat.charger, sourceObj={"type":"state","common":{"name":{"en":"Charger connected","de":"Ladegerät angeschlossen","ru":"Подключенное зарядное устройство","pt":"Carregador conectado","nl":"Vertaling:","fr":"Charger connecté","it":"Caricabatterie collegato","es":"Cargador conectado","pl":"Charger join","zh-cn":"联系人"},"type":"boolean","role":"state","read":true,"write":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704401098995,"_id":"shelly.1.SHHT-1#D34034#1.bat.charger","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.841	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHHT-1#D34034#1.tmp.temperatureC, sourceObj={"type":"state","common":{"name":{"en":"Temperature","de":"Temperatur","ru":"Температура","pt":"Temperatura","nl":"Temperatuur","fr":"Température","it":"Temperatura","es":"Temperatura","pl":"Temperatura","zh-cn":"模范"},"type":"number","role":"value.temperature","read":true,"write":false,"unit":"°C"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704401099023,"_id":"shelly.1.SHHT-1#D34034#1.tmp.temperatureC","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.841	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.000858A9960D4A.4.STATE, sourceObj={"type":"state","common":{"name":"STATE","def":false,"type":"boolean","read":true,"write":true,"role":"switch"},"native":{"MIN":false,"OPERATIONS":7,"MAX":true,"FLAGS":1,"ID":"STATE","TYPE":"BOOL","DEFAULT":false,"CONTROL":"SWITCH.STATE"},"from":"system.adapter.hm-rpc.1","user":"system.user.admin","ts":1600591517383,"_id":"hm-rpc.1.000858A9960D4A.4.STATE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.841	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHMOS-01#60A423936DA2#1.sensor.vibration, sourceObj={"type":"state","common":{"name":"Vibration","type":"boolean","role":"sensor","read":true,"write":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704466794189,"_id":"shelly.1.SHMOS-01#60A423936DA2#1.sensor.vibration","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.841	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHMOS-01#60A423936DA2#1.hostname, sourceObj={"type":"state","common":{"name":{"en":"Device IP address or hostname","de":"Geräte-IP-Adresse oder Hostname","ru":"IP-адрес устройства или имя хоста","pt":"Endereço IP do dispositivo ou nome de host","nl":"IP-adres of gastnaam","fr":"Adresse IP ou nom d'hôte","it":"Indirizzo IP del dispositivo o nome host","es":"Dirección IP o nombre de host","pl":"Adres IP lub hostname","uk":"Пристрої IP адреси або ім'я користувача","zh-cn":"設備 IP 地址或主機名"},"type":"string","role":"info.ip","read":true,"write":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704465848584,"_id":"shelly.1.SHMOS-01#60A423936DA2#1.hostname","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.842	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#C45BBE6C2843#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":{"en":"Switch","de":"Schalter","ru":"Переключить","pt":"Interruptor","nl":"Vertaling:","fr":"Interrupteur","it":"Interruttore","es":"Interruptor","pl":"Switch","zh-cn":"目 录"},"role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704473438205,"_id":"shelly.1.SHSW-25#C45BBE6C2843#1.Relay0.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.842	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#C45BBE6C2843#1.Relay1.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":{"en":"Switch","de":"Schalter","ru":"Переключить","pt":"Interruptor","nl":"Vertaling:","fr":"Interrupteur","it":"Interruttore","es":"Interruptor","pl":"Switch","zh-cn":"目 录"},"role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704473438205,"_id":"shelly.1.SHSW-25#C45BBE6C2843#1.Relay1.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.842	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHSW-25#C45BBE6C2843#1.name, sourceObj={"type":"state","common":{"name":{"en":"Device name","de":"Bezeichnung des Geräts","ru":"Наименование устройства","pt":"Nome do dispositivo","nl":"Devicenaam","fr":"Nom du dispositif","it":"Nome del dispositivo","es":"Nombre del dispositivo","pl":"Device name","uk":"Назва пристрою","zh-cn":"证人姓名"},"type":"string","role":"info.name","read":true,"write":true,"icon":"data:image/svg+xml;base64,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"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704473437817,"_id":"shelly.1.SHSW-25#C45BBE6C2843#1.name","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.840	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHMOS-01#60A423936DA2#1.sensor.battery, sourceObj={"type":"state","common":{"name":{"en":"Battery capacity","de":"Batteriekapazität","ru":"Емкость батареи","pt":"Capacidade da bateria","nl":"Batterij capaciteit","fr":"Capacité de la batterie","it":"Capacità della batteria","es":"Capacidad de la batería","pl":"Pojemność baterii","zh-cn":"包 容能力"},"type":"number","role":"value.battery","read":true,"write":false,"min":0,"max":100,"unit":"%"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704466794183,"_id":"shelly.1.SHMOS-01#60A423936DA2#1.sensor.battery","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.840	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHMOS-01#60A423936DA2#1.sensor.lux, sourceObj={"type":"state","common":{"name":"Illuminance","type":"number","role":"value.brightness","read":true,"write":false,"unit":"Lux"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704466794186,"_id":"shelly.1.SHMOS-01#60A423936DA2#1.sensor.lux","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.840	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.shellyplus2pm#b48a0a22bcbc#1.hostname, sourceObj={"type":"state","common":{"name":{"en":"Device IP address or hostname","de":"Geräte-IP-Adresse oder Hostname","ru":"IP-адрес устройства или имя хоста","pt":"Endereço IP do dispositivo ou nome de host","nl":"IP-adres of gastnaam","fr":"Adresse IP ou nom d'hôte","it":"Indirizzo IP del dispositivo o nome host","es":"Dirección IP o nombre de host","pl":"Adres IP lub hostname","uk":"Пристрої IP адреси або ім'я користувача","zh-cn":"設備 IP 地址或主機名"},"type":"string","role":"info.ip","read":true,"write":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704473428961,"_id":"shelly.1.shellyplus2pm#b48a0a22bcbc#1.hostname","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.841	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHMOS-01#60A423936DA2#1.name, sourceObj={"type":"state","common":{"name":{"en":"Device name","de":"Bezeichnung des Geräts","ru":"Наименование устройства","pt":"Nome do dispositivo","nl":"Devicenaam","fr":"Nom du dispositif","it":"Nome del dispositivo","es":"Nombre del dispositivo","pl":"Device name","uk":"Назва пристрою","zh-cn":"证人姓名"},"type":"string","role":"info.name","read":true,"write":true,"icon":"data:image/svg+xml;base64,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"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704465850699,"_id":"shelly.1.SHMOS-01#60A423936DA2#1.name","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.841	error	Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.1.000858A9960D4A.7.ENERGY_COUNTER, sourceObj={"type":"state","common":{"name":"ENERGY_COUNTER","def":0,"type":"number","read":true,"write":false,"min":0,"max":838859.1,"unit":"Wh","role":"value.power.consumption","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":1,"start_day":0.602,"start_week":0.5535,"start_month":0.5535,"start_quarter":0.5535,"start_year":0.5535,"alias":"Flur","selectedPrice":"ElectricityDay","costs":true,"consumption":true,"meter_values":true,"basicRate":true,"valueAtDeviceReset":0,"valueAtDeviceInit":null,"cumulativeValue":0.602}}},"native":{"MIN":0,"UNIT":"Wh","OPERATIONS":5,"MAX":838859.1,"FLAGS":1,"ID":"ENERGY_COUNTER","TYPE":"FLOAT","DEFAULT":0,"CONTROL":"POWERMETER_PSM.ENERGY_COUNTER"},"_id":"hm-rpc.1.000858A9960D4A.7.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1704409200042}
                admin.0
                2024-01-05 17:53:49.841	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHHT-1#D34034#1.hum.value, sourceObj={"type":"state","common":{"name":"Relative humidity","type":"number","role":"value.humidity","read":true,"write":false,"min":0,"max":100,"unit":"%"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704401099042,"_id":"shelly.1.SHHT-1#D34034#1.hum.value","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.841	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHHT-1#D34034#1.bat.value, sourceObj={"type":"state","common":{"name":{"en":"Battery capacity","de":"Batteriekapazität","ru":"Емкость батареи","pt":"Capacidade da bateria","nl":"Batterij capaciteit","fr":"Capacité de la batterie","it":"Capacità della batteria","es":"Capacidad de la batería","pl":"Pojemność baterii","zh-cn":"包 容能力"},"type":"number","role":"value.battery","read":true,"write":false,"min":0,"max":100,"unit":"%"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704401099042,"_id":"shelly.1.SHHT-1#D34034#1.bat.value","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.841	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHHT-1#D34034#1.hostname, sourceObj={"type":"state","common":{"name":{"en":"Device IP address or hostname","de":"Geräte-IP-Adresse oder Hostname","ru":"IP-адрес устройства или имя хоста","pt":"Endereço IP do dispositivo ou nome de host","nl":"IP-adres of gastnaam","fr":"Adresse IP ou nom d'hôte","it":"Indirizzo IP del dispositivo o nome host","es":"Dirección IP o nombre de host","pl":"Adres IP lub hostname","uk":"Пристрої IP адреси або ім'я користувача","zh-cn":"設備 IP 地址或主機名"},"type":"string","role":"info.ip","read":true,"write":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704346433426,"_id":"shelly.1.SHHT-1#D34034#1.hostname","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.839	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.shellyplus2pm#b48a0a22bcbc#1.Relay1.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704473430038,"_id":"shelly.1.shellyplus2pm#b48a0a22bcbc#1.Relay1.Switch","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.840	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.shellyplus2pm#b48a0a22bcbc#1.name, sourceObj={"type":"state","common":{"name":{"en":"Device name","de":"Bezeichnung des Geräts","ru":"Наименование устройства","pt":"Nome do dispositivo","nl":"Devicenaam","fr":"Nom du dispositif","it":"Nome del dispositivo","es":"Nombre del dispositivo","pl":"Device name","uk":"Назва пристрою","zh-cn":"证人姓名"},"type":"string","role":"info.name","read":true,"write":true,"icon":"data:image/svg+xml;base64,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"},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704473429795,"_id":"shelly.1.shellyplus2pm#b48a0a22bcbc#1.name","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.840	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.SHMOS-01#60A423936DA2#1.sensor.motion, sourceObj={"type":"state","common":{"name":"Motion","type":"boolean","role":"sensor.motion","read":true,"write":false},"native":{},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704466794191,"_id":"shelly.1.SHMOS-01#60A423936DA2#1.sensor.motion","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                admin.0
                2024-01-05 17:53:49.839	error	Alias subscription error. Please check your alias definitions: sourceId=shelly.1.shellyplus2pm#b48a0a22bcbc#1.Relay1.Power, sourceObj={"type":"state","common":{"name":"Power","type":"number","role":"value.power","read":true,"write":false,"def":0,"unit":"W","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":1,"start_day":0.07416973063888896,"start_week":0.019085312833333336,"start_month":0.019085312833333336,"start_quarter":0.019085312833333336,"start_year":0.019085312833333336,"costs":true,"consumption":true,"meter_values":true,"basicRate":true,"alias":"Bad Spiegellicht","selectedPrice":"ElectricityDay","valueAtDeviceInit":null,"valueAtDeviceReset":null,"cumulativeValue":0.07416973063888896}}},"native":{},"_id":"shelly.1.shellyplus2pm#b48a0a22bcbc#1.Relay1.Power","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.shelly.1","user":"system.user.admin","ts":1704473428832}
                nur eins zum provozieren
                sobald ich die auswahl für einen DP verändere, dauert speichern ewig. die adapter werden rot.
                wenn der DP gespeichert wurde, ist alles wieder gut. Speichern klappt auch nicht immer.
                den Wert kopieren geht ohne Propleme. Einen weitere hinzufügen wieder gleiches spiel.
                • OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  hm, du bist nicht auf die idee gekommen zuerst den fehler zu beheben, der dir zig meldungen im log innerhalb von millisekunden produziert?
                  https://forum.iobroker.net/topic/42345/admin-0-alias-subscription-error?_=1704476387060
                  evtl sind das mit dem javascript adapter nur folgefehler?
                  in dem geposteten abschnitt sehe ich nix was den javascript adapter betrifft
                  Links im Profil
                    dos1973
                    @oliverio
                    sorry, ich kann dir nicht folgen.
                    Alle DP sind vorhanden.
                    die FM meldung kommen nicht bei restart der scripte.
                    und was ich nicht nachvollziehen kan. es gibt aktuell nicht ein Script das läuft.
                    woher kommen die meldungen? warum macht JS das?
                    • D dos1973
                      @oliverio
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @dos1973
                      lese die fehlermeldung
                      du hast mal ein alias definiert bei dem der datenpunkt nicht mehr existiert. da flipt iobroker aus. due siehst der datenpunkt liegt im javascript.0 bereich. evtl wird bei start hier was gelesen, was den fehler schon provoziert, auch ohne das ein skript läuft
                      und lese den link. da wird bei einem anderen fall ausführlich nach dem fehler gesucht. das hilft dir sicherlich weiter. ansonsten dann wieder hier
                      Links im Profil
                        @dos1973
                        dos1973
                        @oliverio sagte in Javascript Adapter stürzt ab:
                        mperature,
                        verstehe ich nicht, oder ich stehe eben total auf dem Schlauch.
                        Ziel: javascript.0.lmair.temp-sensoren.channel10-wohnzimmer.temperature
                        die Alias definition
                        "type": "state",
                          "common": {
                            "name": "Wohnzimmer_temp",
                            "role": "value",
                            "type": "number",
                            "read": true,
                            "write": true,
                            "alias": {
                              "id": "javascript.0.lmair.temp-sensoren.channel10-wohnzimmer.temperature"
                        • D dos1973
                          mperature,
                          "type": "state",
                            "common": {
                              "role": "value",
                              "type": "number",
                              "read": true,
                              "write": true,
                              "alias": {
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          @dos1973
                          bei alias bin ich jetzt nicht ganz so firm, da ich es nicht nutze. evtl weiß jemand anders hier noch bescheid.
                          im zweifen nochmal neues thread mit alias fehler im titel posten
                          Links im Profil
                            dos1973
                            @oliverio
                            Ich glaube das hat nix mit dem alias zu tun.
                            Ich hatte ja gesagt, dass ich ein 14 Tage altes backup eingespielt habe, gleicher Fehler.
                            Die Aliase hatte ich die letzen Tage eingesetzt und bei den Script Anpassungen habe ich es gemerkt.
                            Und es funktionieren ja auch alle Aliase wenn diese mal gespeichert sind. sonst würde es ja immer Fehler geben.
                            Die vorher geposteten Fehler kommen nur wenn ich in einem Script den DP ändere.
                            • D dos1973
                              @oliverio
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @dos1973
                              die fehlermeldung hat definitiv mit einem alias zu tun.
                              und wenn die fehlerserie mit absturz immer dann kommt wenn du was mit dem javascript adapter machst, dann hängt das zusammen.
                              Links im Profil
                                @dos1973
                                dos1973
                                @oliverio
                                das sind meine Fehler nach einem komplett system neustart.
                                es müssten dch hier bereits Fehler auftreten wenn es mit Scripten /alias sschwierigkeiten gäbe.
                                host.pve-iobroker
                                2024-01-05 20:16:16.672	error	instance system.adapter.linux-control.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                linux-control.0
                                2024-01-05 20:16:15.936	error	linux-control.0 already running
                                host.pve-iobroker
                                2024-01-05 20:16:12.413	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                backitup.0
                                2024-01-05 20:16:11.825	error	backitup.0 already running
                                host.pve-iobroker
                                2024-01-05 20:16:08.969	error	instance system.adapter.sourceanalytix.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                sourceanalytix.0
                                2024-01-05 20:16:08.372	error	sourceanalytix.0 already running
                                host.pve-iobroker
                                2024-01-05 20:16:05.142	error	instance system.adapter.linkeddevices.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                linkeddevices.0
                                2024-01-05 20:16:04.380	error	linkeddevices.0 already running
                                host.pve-iobroker
                                2024-01-05 20:16:01.033	error	instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                vis-inventwo.0
                                2024-01-05 20:16:00.376	error	vis-inventwo.0 already running
                                host.pve-iobroker
                                2024-01-05 20:15:56.922	error	instance system.adapter.proxmox.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                proxmox.0
                                2024-01-05 20:15:56.333	error	proxmox.0 already running
                                host.pve-iobroker
                                2024-01-05 20:15:52.504	error	instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                yahka.0
                                2024-01-05 20:15:51.920	error	yahka.0 already running
                                • D dos1973
                                  @oliverio
                                  host.pve-iobroker
                                  linux-control.0
                                  host.pve-iobroker
                                  backitup.0
                                  host.pve-iobroker
                                  sourceanalytix.0
                                  host.pve-iobroker
                                  linkeddevices.0
                                  host.pve-iobroker
                                  vis-inventwo.0
                                  host.pve-iobroker
                                  proxmox.0
                                  host.pve-iobroker
                                  yahka.0
                                  dos1973
                                  @Thomas-Braun
                                  Hast du noch ideen, oder muss ich den server neu aufsetzen?
                                  Ich habe keine ideen mehr.
                                  Habe sogar alle
                                  • skripte gelöscht
                                  • Alle aliase gelöscht
                                  Habe zwar dann keine fehler mehr im log aber das ändern einen DP in Blockly dauert 10 sekunden. Manchmal gehts manchmal kommt instanz deaktiviert
                                  • D dos1973
                                    @Thomas-Braun
                                    Habe sogar alle
                                    • skripte gelöscht
                                    dos1973
                                    Ok, gehe dann eine Neuinstallation an.
                                    Werden dann die Scripte bereinigen und vielleicht finde ich ja unterwegs etwas was den Fehler verursacht.
                                    • D dos1973
                                      dos1973
                                      ich hab den IOB server komplett neu installiert und habe dabei ordentlich in den scripten und Adapter aufgeräumt und viele Spielereien weggelassen. War sowieso mal notwendig da dieses Setup schon diverse Hosts miterlebt hat.
                                      Hat zwar einige Stunden gedauert, aber dafür jetzt clean und schnell wie der Blitz.
                                      Habe allerdings erstmal auf die Aliase Verzichtet :-)
                                      • R Offline
                                        Rushmed
                                        schrieb am zuletzt editiert von Rushmed
                                        ich möchte mich hier anschließen.
                                        Auch bei mir kommt es seit einigen Tagen beim Speichern geänderter Scripte vor, dass im Script Editor "Instanz deaktiviert" angezeigt wird, fast alle Adapter neu starten, das Log mit
                                        geflutet wird und die Scriptänderungen nicht übernommen werden.
                                        Die Alias Erros im Log sind ja schon länger ein Thema aber zeigten zumindest bei mir bis auf die Logeinträge keine weiteren Sympthome. Die Alias Ziele existieren und die Aliase funktionieren.
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                         Static hostname: Smartazamba
                                               Icon name: computer
                                                  Kernel: Linux 6.1.0-rpi7-rpi-v8
                                            Architecture: arm64
                                        Model           : Raspberry Pi 4 Model B Rev 1.4
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : arm64
                                        Systemuptime and Load:
                                         20:23:42 up 22:41,  2 users,  load average: 1.70, 1.39, 1.56
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** Time and Time Zones ***
                                                       Local time: Sat 2024-01-27 20:23:42 CET
                                                   Universal time: Sat 2024-01-27 19:23:42 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** User and Groups ***
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        *** X-Server-Setup ***
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:            8.2G        3.9G        759M         10M        3.7G        4.3G
                                        Swap:             0B          0B          0B
                                        Total:          8.2G        3.9G        759M
                                                 7810 M total memory
                                                 3753 M used memory
                                                 4366 M active memory
                                                 2148 M inactive memory
                                                  723 M free memory
                                                  288 M buffer memory
                                                 3207 M swap cache
                                                    0 M total swap
                                                    0 M used swap
                                                    0 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FAILED SERVICES ***
                                          UNIT                LOAD   ACTIVE SUB    DESCRIPTION
                                        * nut-monitor.service loaded failed failed Network UPS Tools - power device monitor and shutdown controller
                                        1 loaded units listed.
                                        *** FILESYSTEM ***
                                        /dev/root      ext4      110G   20G   87G  19% /
                                        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                        tmpfs          tmpfs     1.6G  9.6M  1.6G   1% /run
                                        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                                        /dev/sdc       ext4      5.5T  3.4T  1.8T  66% /media/HDD2
                                        /dev/sda1      vfat      253M   42M  211M  17% /boot/firmware
                                        /dev/sdb1      ext4      4.6T  3.4T  951G  79% /media/HDD1
                                        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                                        [Fri Jan 26 21:42:20 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:E2:C4:A5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=5bc7cbe7-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Fri Jan 26 21:42:23 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Fri Jan 26 21:42:23 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                        [Fri Jan 26 21:42:26 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                        [Fri Jan 26 21:42:28 2024] EXT4-fs (sdc): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Fri Jan 26 21:42:29 2024] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Quota mode: none.
                                        TARGET           SOURCE    FSTYPE OPTIONS
                                        /                /dev/sda2 ext4   rw,noatime
                                        |-/media/HDD2    /dev/sdc  ext4   rw,nosuid,nodev,noexec,relatime
                                        |-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                        `-/media/HDD1    /dev/sdb1 ext4   rw,nosuid,nodev,noexec,relatime
                                        /var:
                                        6.5G    /var/
                                        3.5G    /var/log
                                        2.3G    /var/log/journal/3dd7c02f298247188f8650087c821e8c
                                        584M    /var/cache
                                        Archived and active journals take up 2.2G in the file system.
                                        /opt/iobroker/backups:
                                        1.9G    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        534M    /opt/iobroker/iobroker-data/
                                        196M    /opt/iobroker/iobroker-data/files
                                        160M    /opt/iobroker/iobroker-data/backup-objects
                                        106M    /opt/iobroker/iobroker-data/esphome.0/.esphome
                                        43M     /opt/iobroker/iobroker-data/objects.jsonl
                                        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                        31M     /opt/iobroker/iobroker-data/states.jsonl
                                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                        16M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/ibeacon-mondeo/.pioenvs/ibeacon-mondeo/firmware.elf
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0
                                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
                                        /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0
                                        *** NodeJS-Installation ***
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Installed: 18.19.0-1nodesource1
                                          Candidate: 18.19.0-1nodesource1
                                          Version table:
                                             18.19.0+dfsg-6~deb12u1 500
                                                500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                                         *** 18.19.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                             18.18.2-1nodesource1 1001
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0+dfsg1-1 500
                                                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                        No problems detected
                                        Errors in npm tree:
                                        npm ERR! code ELSPROBLEMS
                                        npm ERR! missing: node-mihome@^0.0.32, required by iobroker.javascript@7.1.6
                                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-27T19_23_59_219Z-debug-0.log
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Core adapters versions
                                        js-controller:  5.0.17
                                        admin:          6.12.0
                                        javascript:     7.1.6
                                        Adapters from github:   0
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : Smartazamba                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.alexa2.0                 : alexa2                : Smartazamba                              -  enabled
                                        + system.adapter.awtrix-light.0           : awtrix-light          : Smartazamba                              -  enabled
                                        + system.adapter.awtrix-light.1           : awtrix-light          : Smartazamba                              -  enabled
                                        + system.adapter.backitup.0               : backitup              : Smartazamba                              -  enabled
                                        + system.adapter.denon.0                  : denon                 : Smartazamba                              -  enabled
                                        + system.adapter.device-watcher.0         : device-watcher        : Smartazamba                              -  enabled
                                        + system.adapter.deyeidc.0                : deyeidc               : Smartazamba                              -  enabled, port: 8899
                                          system.adapter.esphome.0                : esphome               : Smartazamba                              - disabled
                                          system.adapter.habpanel.0               : habpanel              : Smartazamba                              - disabled
                                        + system.adapter.hue.0                    : hue                   : Smartazamba                              -  enabled, port: 443
                                          system.adapter.ical.0                   : ical                  : Smartazamba                              -  enabled
                                        + system.adapter.influxdb.0               : influxdb              : Smartazamba                              -  enabled, port: 8086
                                        + system.adapter.info.0                   : info                  : Smartazamba                              -  enabled
                                        + system.adapter.iot.0                    : iot                   : Smartazamba                              -  enabled
                                        + system.adapter.javascript.0             : javascript            : Smartazamba                              -  enabled
                                        + system.adapter.kodi.0                   : kodi                  : Smartazamba                              -  enabled, port: 9090
                                        + system.adapter.logparser.0              : logparser             : Smartazamba                              -  enabled
                                        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
                                        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
                                        + system.adapter.mqtt.0                   : mqtt                  : Smartazamba                              -  enabled, port: 1883, bind: 0.0.0.0
                                          system.adapter.onvif.0                  : onvif                 : Smartazamba                              - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
                                        + system.adapter.philips-tv.0             : philips-tv            : Smartazamba                              -  enabled
                                        + system.adapter.ping.0                   : ping                  : Smartazamba                              -  enabled
                                        + system.adapter.pixelit.0                : pixelit               : Smartazamba                              -  enabled
                                          system.adapter.pixelit.1                : pixelit               : Smartazamba                              - disabled
                                          system.adapter.pixelit.2                : pixelit               : Smartazamba                              - disabled
                                        + system.adapter.shelly.0                 : shelly                : Smartazamba                              -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.shuttercontrol.0         : shuttercontrol        : Smartazamba                              -  enabled
                                        + system.adapter.simple-api.0             : simple-api            : Smartazamba                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                        + system.adapter.smartmeter.0             : smartmeter            : Smartazamba                              -  enabled
                                        + system.adapter.smartmeter.1             : smartmeter            : Smartazamba                              -  enabled
                                        + system.adapter.sonoff.0                 : sonoff                : Smartazamba                              -  enabled, port: 1884, bind: 0.0.0.0
                                        + system.adapter.sourceanalytix.0         : sourceanalytix        : Smartazamba                              -  enabled
                                        + system.adapter.telegram.0               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.telegram.1               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.unifi.0                  : unifi                 : Smartazamba                              -  enabled
                                          system.adapter.weatherunderground.0     : weatherunderground    : Smartazamba                              -  enabled
                                        + system.adapter.web.0                    : web                   : Smartazamba                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + system.adapter.windows-control.0        : windows-control       : Smartazamba                              -  enabled
                                          system.adapter.wiobrowser.0             : wiobrowser            : Smartazamba                              - disabled, port: 5000
                                        + system.adapter.wled.0                   : wled                  : Smartazamba                              -  enabled
                                        + system.adapter.ws.0                     : ws                    : Smartazamba                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                        + system.adapter.zigbee.0                 : zigbee                : Smartazamba                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
                                        + system.adapter.zigbee.1                 : zigbee                : Smartazamba                              -  enabled, port: tcp://192.168.178.4:6638
                                        + instance is alive
                                        ioBroker-Repositories
                                        Stable (default): http://download.iobroker.net/sources-dist.json
                                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                        latest live   : http://iobroker.live/repo/sources-dist-latest.json
                                        Installed ioBroker-Instances
                                        Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                        Adapter    "awtrix-light" : 0.11.0   , installed 0.11.0
                                        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                        Adapter    "denon"        : 1.15.4   , installed 1.15.4
                                        Adapter    "device-watcher": 2.9.6   , installed 2.10.1
                                        Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
                                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                        Adapter    "hue"          : 3.10.2   , installed 3.10.2
                                        Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                        Adapter    "info"         : 2.0.0    , installed 2.0.0
                                        Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                        Controller "js-controller": 5.0.17   , installed 5.0.17
                                        Adapter    "kodi"         : 3.0.0    , installed 3.0.0
                                        Adapter    "logparser"    : 2.2.1    , installed 2.2.1
                                        Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
                                        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                                        Adapter    "onvif"        : 1.1.1    , installed 1.1.1
                                        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                                        Adapter    "pixelit"      : 1.1.3    , installed 1.1.3
                                        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                        Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
                                        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                        Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                                        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                        Adapter    "unifi"        : 0.6.7    , installed 0.6.7
                                        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                        Adapter    "web"          : 6.1.10   , installed 6.1.10
                                        Adapter    "windows-control": 0.1.5  , installed 0.1.5
                                        Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                                        Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                        Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                                        Objects and States
                                        Objects:        20314
                                        States:         14664
                                        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                        Hit:4 https://repos.influxdata.com/debian stable InRelease
                                        Hit:5 http://archive.raspberrypi.org/debian bookworm InRelease
                                        Hit:6 https://apt.grafana.com stable InRelease
                                        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       16423      830/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       15408      830/iobroker.js-con
                                        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          16394      819/smbd
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12153      615/sshd: /usr/sbin
                                        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          16395      819/smbd
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       15207      1045/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       16309      1084/io.shelly.0
                                        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       16933      1146/io.sonoff.0
                                        tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       4709176    1222788/nc
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      109        16435      829/grafana
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1002       20710      1463/io.web.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1002       14461      873/io.admin.0
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1002       20651      1436/io.simple-api.
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        15373      740/influxd
                                        tcp6       0      0 :::8084                 :::*                    LISTEN      1002       20209      1563/io.ws.0
                                        tcp6       0      0 :::445                  :::*                    LISTEN      0          16392      819/smbd
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          12155      615/sshd: /usr/sbin
                                        tcp6       0      0 :::21                   :::*                    LISTEN      0          13110      600/vsftpd
                                        tcp6       0      0 :::139                  :::*                    LISTEN      0          16393      819/smbd
                                        udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13257      796/nmbd
                                        udp        0      0 192.168.178.20:137      0.0.0.0:*                           0          13256      796/nmbd
                                        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13244      796/nmbd
                                        udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13259      796/nmbd
                                        udp        0      0 192.168.178.20:138      0.0.0.0:*                           0          13258      796/nmbd
                                        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13245      796/nmbd
                                        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1002       14324      1030/io.mihome-vacu
                                        udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1002       20011      1257/io.mihome-vacu
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       20523      1494/io.wled.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3728       413/avahi-daemon: r
                                        udp        0      0 0.0.0.0:34303           0.0.0.0:*                           108        3730       413/avahi-daemon: r
                                        udp6       0      0 :::33806                :::*                                108        3731       413/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                108        3729       413/avahi-daemon: r
                                        2024-01-27 20:22:31.249  - info: host.Smartazamba instance system.adapter.denon.0 started with pid 1220168
                                        2024-01-27 20:22:31.272  - info: host.Smartazamba instance system.adapter.kodi.0 started with pid 1220182
                                        2024-01-27 20:22:39.659  - info: kodi.0 (1220182) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.kodi, node: v18.19.0, js-controller: 5.0.17
                                        2024-01-27 20:22:40.663  - info: denon.0 (1220168) starting. Version 1.15.4 in /opt/iobroker/node_modules/iobroker.denon, node: v18.19.0, js-controller: 5.0.17
                                        2024-01-27 20:22:40.717  - info: denon.0 (1220168) [START] Starting DENON AVR adapter
                                        2024-01-27 20:22:40.723  - info: denon.0 (1220168) [CONNECT] Trying to connect to 192.168.178.40:23
                                        2024-01-27 20:22:43.793  - warn: denon.0 (1220168) AVR unreachable, check the Network Config of your AVR
                                        2024-01-27 20:22:44.900  - info: kodi.0 (1220182) KODI connected
                                        2024-01-27 20:22:59.107  - info: mqtt.0 (1045) Client [cam_11] Received pubrel for unknown message ID: 15999
                                        2024-01-27 20:22:59.131  - info: mqtt.0 (1045) Client [cam_11] Received pubrel for unknown message ID: 16003
                                        2024-01-27 20:23:13.797  - info: denon.0 (1220168) [CONNECT] Trying to connect to 192.168.178.40:23
                                        2024-01-27 20:23:13.802  - warn: denon.0 (1220168) Connection refused, make sure that there is no other Telnet connection
                                        2024-01-27 20:23:28.785  - info: javascript.0 (903) script.js.Lampen.Ambilight: Ambilight eingeschaltet bei Sonnenstrahlung 0.
                                        2024-01-27 20:23:31.436  - info: mqtt.0 (1045) Client [cam_11] Received pubrel for unknown message ID: 16043
                                        2024-01-27 20:23:43.804  - info: denon.0 (1220168) [CONNECT] Trying to connect to 192.168.178.40:23
                                        2024-01-27 20:23:43.810  - info: denon.0 (1220168) [CONNECT] Adapter connected to DENON-AVR: 192.168.178.40:23
                                        2024-01-27 20:24:24.310  - info: mqtt.0 (1045) Client [cam_10] Received pubrel for unknown message ID: 7641
                                        2024-01-27 20:24:29.030  - info: mqtt.0 (1045) Client [cam_11] Received pubrel for unknown message ID: 16095
                                        2024-01-27 20:24:35.061  - info: mqtt.0 (1045) Client [cam_11] Received pubrel for unknown message ID: 16101
                                        2024-01-27 20:25:00.286  - info: host.Smartazamba instance system.adapter.weatherunderground.0 started with pid 1222790
                                        2024-01-27 20:25:01.178  - info: mqtt.0 (1045) Client [cam_11] Received pubrel for unknown message ID: 16129
                                        2024-01-27 20:25:06.216  - info: weatherunderground.0 (1222790) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v18.19.0, js-controller: 5.0.17
                                        2024-01-27 20:25:17.455  - info: mqtt.0 (1045) Client [cam_11] Received pubrel for unknown message ID: 16142
                                        2024-01-27 20:25:18.233  - info: weatherunderground.0 (1222790) Terminated (NO_ERROR): Without reason
                                        2024-01-27 20:25:18.789  - info: host.Smartazamba instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
