  4. Error herdsman start Failed to start Zigbee
    6.1k
29 Beiträge 5 Kommentatoren 4.8k Aufrufe 6 Beobachtet
  • V varg
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Static hostname: iobrokerpi5
    Icon name: computer
    Kernel: Linux 6.1.0-rpi7-rpi-2712
    Architecture: arm64
    Model : Raspberry Pi 5 Model B Rev 1.0
    Docker : false
    Virtualization : none
    Kernel : aarch64
    Userland : arm64
    Systemuptime and Load:
    12:07:23 up 18 min, 2 users, load average: 0.07, 0.14, 0.15
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
    Local time: Fri 2024-01-05 12:07:23 CET
    Universal time: Fri 2024-01-05 11:07:23 UTC
    RTC time: Fri 2024-01-05 11:07:23
    NTP service: active
    RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: false
    Desktop:
    Terminal: tty
    Boot Target: multi-user.target
    *** MEMORY ***
    total used free shared buff/cache available
    Mem: 8.4G 1.4G 6.8G 5.2M 439M 7.1G
    Swap: 104M 0B 104M
    Total: 8.5G 1.4G 6.9G
         8053 M total memory
         1287 M used memory
         1170 M active memory
          236 M inactive memory
         6439 M free memory
           36 M buffer memory
          383 M swap cache
           99 M total swap
            0 M used swap
           99 M free swap
    Raspberry only:
    vc_gencmd_read_response returned -1
    error=1 error_msg="Command not registered"
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    Filesystem Type Size Used Avail Use% Mounted on
    udev devtmpfs 3.8G 0 3.8G 0% /dev
    tmpfs tmpfs 806M 5.0M 801M 1% /run
    /dev/mmcblk0p2 ext4 29G 3.3G 25G 12% /
    tmpfs tmpfs 4.0G 0 4.0G 0% /dev/shm
    tmpfs tmpfs 5.0M 48K 5.0M 1% /run/lock
    /dev/mmcblk0p1 vfat 510M 61M 450M 12% /boot/firmware
    tmpfs tmpfs 806M 0 806M 0% /run/user/1000
    [Fri Jan 5 11:48:26 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=D8:3A:DD:E2:FA:5E vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 console=ttyAMA10,115200 console=tty1 root=PARTUUID=c9d943cf-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Jan 5 11:48:29 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Jan 5 11:48:30 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET SOURCE FSTYPE OPTIONS
    / /dev/mmcblk0p2 ext4 rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    494M /var/
    176M /var/cache
    170M /var/cache/apt
    160M /var/lib
    132M /var/lib/apt/lists
    Archived and active journals take up 56.9M in the file system.
    /opt/iobroker/backups:
    4.0K /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    231M /opt/iobroker/iobroker-data/
    142M /opt/iobroker/iobroker-data/files
    67M /opt/iobroker/iobroker-data/files/javascript.admin
    48M /opt/iobroker/iobroker-data/files/javascript.admin/static
    47M /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    72M /opt/iobroker/iobroker-data/objects.jsonl
    33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    12M /opt/iobroker/iobroker-data/states.jsonl
    8.5M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    7.5M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs v20.10.0
    /usr/bin/node v20.10.0
    /usr/bin/npm 10.2.3
    /usr/bin/npx 10.2.3
    /usr/bin/corepack 0.22.0
    nodejs:
    Installed: 20.10.0-1nodesource1
    Candidate: 20.10.0-1nodesource1
    Version table:
    *** 20.10.0-1nodesource1 600
    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
    20.9.0-1nodesource1 600
    20.8.1-1nodesource1 600
    20.8.0-1nodesource1 600
    20.7.0-1nodesource1 600
    20.6.1-1nodesource1 600
    20.6.0-1nodesource1 600
    20.5.1-1nodesource1 600
    20.5.0-1nodesource1 600
    20.4.0-1nodesource1 600
    20.3.1-1nodesource1 600
    20.3.0-1nodesource1 600
    20.2.0-1nodesource1 600
    20.1.0-1nodesource1 600
    20.0.0-1nodesource1 600
    18.19.0+dfsg-6~deb12u1 500
    500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    18.13.0+dfsg1-1 500
    500 http://deb.debian.org/debian bookworm/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    Core adapters versions
    js-controller: 5.0.17
    admin: 6.12.0
    javascript: 7.1.6
    Adapters from github: 1
    Adapter State
    • system.adapter.admin.0 : admin : iobrokerpi5 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.alexa2.0 : alexa2 : iobrokerpi5 - enabled
      system.adapter.device-reminder.0 : device-reminder : iobrokerpi5 - disabled
    • system.adapter.fb-checkpresence.0 : fb-checkpresence : iobrokerpi5 - enabled
      system.adapter.ical.0 : ical : iobrokerpi5 - enabled
    • system.adapter.info.0 : info : iobrokerpi5 - enabled
    • system.adapter.iot.0 : iot : iobrokerpi5 - enabled
    • system.adapter.javascript.0 : javascript : iobrokerpi5 - enabled
      system.adapter.openweathermap.0 : openweathermap : iobrokerpi5 - enabled
    • system.adapter.ping.0 : ping : iobrokerpi5 - enabled
    • system.adapter.pushover.0 : pushover : iobrokerpi5 - enabled
    • system.adapter.shelly.0 : shelly : iobrokerpi5 - enabled, port: 1882, bind: 0.0.0.0
    • system.adapter.sonoff.0 : sonoff : iobrokerpi5 - enabled, port: 1883, bind: 0.0.0.0
    • system.adapter.tr-064.0 : tr-064 : iobrokerpi5 - enabled
    • system.adapter.trashschedule.0 : trashschedule : iobrokerpi5 - enabled
    • system.adapter.zigbee.0 : zigbee : iobrokerpi5 - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00
      system.adapter.zwave2.0 : zwave2 : iobrokerpi5 - disabled
    • instance is alive
    ioBroker-Repositories
    stable : http://iobroker.live/repo/sources-dist.json
    beta : http://iobroker.live/repo/sources-dist-latest.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter "admin" : 6.12.0 , installed 6.12.0
    Adapter "alexa2" : 3.26.3 , installed 3.26.3
    Adapter "device-reminder": 3.0.0 , installed 3.0.0
    Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter "ical" : 1.13.3 , installed 1.13.6
    Adapter "info" : 2.0.0 , installed 2.0.0
    Adapter "iot" : 2.0.11 , installed 2.0.11
    Adapter "javascript" : 7.1.6 , installed 7.1.6
    Controller "js-controller": 5.0.17 , installed 5.0.17
    Adapter "openweathermap": 0.4.5 , installed 0.4.5
    Adapter "ping" : 1.6.2 , installed 1.6.2
    Adapter "pushover" : 3.0.6 , installed 3.0.6
    Adapter "shelly" : 6.6.1 , installed 6.6.1
    Adapter "sonoff" : 3.0.3 , installed 3.0.3
    Adapter "tr-064" : 4.2.18 , installed 4.2.18
    Adapter "trashschedule": 2.3.0 , installed 3.1.3
    Adapter "zigbee" : 1.9.5 , installed 1.9.5
    Adapter "zwave2" : 3.1.0 , installed 3.1.0
    Objects and States
    Objects: 6996
    States: 6069
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 742 774/iobroker.js-con
    tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 16083 774/iobroker.js-con
    tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 15086 992/io.sonoff.0
    tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 883 977/io.shelly.0
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14865 783/sshd: /usr/sbin
    tcp6 0 0 :::8081 :::* LISTEN 1001 16543 835/io.admin.0
    tcp6 0 0 :::22 :::* LISTEN 0 14867 783/sshd: /usr/sbin
    udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 14779 668/avahi-daemon: r
    udp 0 0 0.0.0.0:55814 0.0.0.0:* 104 14781 668/avahi-daemon: r
    udp6 0 0 :::58098 :::* 104 14782 668/avahi-daemon: r
    udp6 0 0 :::5353 :::* 104 14780 668/avahi-daemon: r
    udp6 0 0 fe80::9c21:67c8:9e0:546 :::* 0 16562 744/NetworkManager
    2024-01-05 11:51:40.347 - info: zigbee.0 (1797) Try to reconnect. 1 attempts left
    2024-01-05 11:51:40.347 - info: zigbee.0 (1797) Starting Zigbee npm ...
    2024-01-05 11:51:40.354 - info: zigbee.0 (1797) Installed Version: iobroker.zigbee@1.9.5
    2024-01-05 11:51:40.483 - error: zigbee.0 (1797) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00'"
    2024-01-05 11:51:40.484 - error: zigbee.0 (1797) Failed to start Zigbee
    2024-01-05 11:51:40.484 - error: zigbee.0 (1797) Error herdsman start
    2024-01-05 11:53:47.209 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.178.55
    2024-01-05 11:53:47.253 - error: zigbee.0 (1797) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-01-05 11:53:47.341 - info: zigbee.0 (1797) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
    2024-01-05 11:54:19.105 - info: sonoff.0 (992) Client [H801-09] reconnected. Old secret 1704451755348_1275. New secret 1704452059105_1488
    2024-01-05 11:57:36.056 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.178.55
    2024-01-05 11:59:39.697 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.178.55
    2024-01-05 11:59:39.765 - error: zigbee.0 (1797) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-01-05 11:59:39.865 - info: zigbee.0 (1797) List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
    2024-01-05 11:59:43.074 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.178.55
    2024-01-05 12:00:00.017 - info: host.iobrokerpi5 instance system.adapter.ical.0 started with pid 1940
    2024-01-05 12:00:00.833 - info: ical.0 (1940) starting. Version 1.13.6 in /opt/iobroker/node_modules/iobroker.ical, node: v20.10.0, js-controller: 5.0.17
    2024-01-05 12:00:01.353 - info: ical.0 (1940) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/74136c8244b022bb0b5d97fdfdee2fe0673eff82bd6842020c2e12bf6c7b489f%40group.calendar.google.com/private-0f8560b829f811ff6c358361c50e5091/basic.ics
    2024-01-05 12:00:01.403 - info: ical.0 (1940) processing URL: Getränkelieferung https://calendar.google.com/calendar/ical/d6sfsku6srbsv5hqp4ane444p8%40group.calendar.google.com/private-573cc39705cb099fd04bbf245c705fea/basic.ics
    2024-01-05 12:00:01.478 - info: trashschedule.0 (1734) Setting "actionNeeded" flag for type.biomüll.actionNeeded to true (???)
    2024-01-05 12:00:06.445 - info: ical.0 (1940) Terminated (NO_ERROR): Without reason
    2024-01-05 12:00:06.967 - info: host.iobrokerpi5 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2024-01-05 12:03:18.582 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.178.55
    2024-01-05 12:03:18.611 - error: zigbee.0 (1797) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2024-01-05 12:03:18.692 - info: zigbee.0 (1797) List of port: [{"path":"/dev/ttyAMA10"}]
    Copy text starting here:
                            v.2023-10-10
           Icon name: computer
        Architecture: arm64
    Kernel:                 aarch64
    Userland:               arm64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v20.10.0
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:            8.4G        1.4G        6.3G        5.4M        760M        7.0G
    Swap:           104M          0B        104M
    Total:          8.5G        1.4G        6.4G
    Active iob-Instances:   14
    ioBroker Core:          js-controller           5.0.17
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobrokerpi5                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    Objects:                6996
    States:                 6069
    Size of iob-Database:
    80M     /opt/iobroker/iobroker-data/objects.jsonl
    1.5M    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    @varg
    Per
    iob nodejs-update 18
    das Ding auf die empfohlene Version drücken.
    V 3 Antworten Letzte Antwort
      @varg
      Per
      V Offline
      V Offline
      varg
      schrieb am zuletzt editiert von varg
      @thomas-braun said in Error herdsman start Failed to start Zigbee:
      ioBroker nodejs updater 2023-10-13
      You requested to intall latest version from nodejs v18 tree.
      Your current setup is:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      We found these nodejs versions available for installation:
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Nothing to do - Your installation is using the correct paths.
      You are running nodejs v20.10.0. Do you want to install latest version from nodejs v.18 tree?
      Press <y> to continue or any other key to quit
      Trying to update your installation now. Please be patient.
      Waiting for ioBroker to shut down - Give me a minute...
      *** These repos are active on your system:
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Reading package lists... Done
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Get:6 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [6656 B]
      Get:7 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [6613 B]
      Fetched 25.4 kB in 1s (45.4 kB/s)
      Installing the recommended nodejs version now!
      Exact recommended version unknown, installing a fallback!
      dpkg: warning: downgrading nodejs from 20.10.0-1nodesource1 to 18.0.0-1nodesource1
      (Reading database ... 68077 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.0.0-1nodesource1_arm64.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (18.0.0-1nodesource1) over (20.10.0-1nodesource1) ...
      Setting up nodejs (18.0.0-1nodesource1) ...
      Processing triggers for man-db (2.11.2-2) ...
      Updating fallback to latest nodejs v18 release
      (Reading database ... 68299 files and directories currently installed.)
      Preparing to unpack .../nodejs_18.19.0-1nodesource1_arm64.deb ...
      Unpacking nodejs (18.19.0-1nodesource1) over (18.0.0-1nodesource1) ...
      Setting up nodejs (18.19.0-1nodesource1) ...
      v18.19.0 has been installed! You are using the latest version now!
      Installing the recommended nodejs version!
      We tried our best to update or fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
      pi@iobrokerpi5:~ $
      moment ich check ob sich was geändert hat und danke schonmal für den Beistand
      Node.js v18.19.0
      pi@iobrokerpi5:~ $ nodejs -v
      v18.19.0
      pi@iobrokerpi5:~ $ node -v
      v18.19.0
      pi@iobrokerpi5:~ $ npm -v
      10.2.3
      pi@iobrokerpi5:~ $
        @varg
        Per
        V Offline
        V Offline
        varg
        zigbee.0
        2024-01-05 12:17:42.424	error	Error herdsman start
        zigbee.0
        2024-01-05 12:17:42.423	error	Failed to start Zigbee
        zigbee.0
        2024-01-05 12:17:42.423	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        zigbee.0
        2024-01-05 12:17:42.303	info	Installed Version: iobroker.zigbee@1.9.5
        zigbee.0
        2024-01-05 12:17:42.297	info	Starting Zigbee npm ...
        zigbee.0
        2024-01-05 12:17:42.297	info	Try to reconnect. 1 attempts left
        zigbee.0
        2024-01-05 12:17:32.294	error	Error herdsman start
        zigbee.0
        2024-01-05 12:17:32.293	error	Failed to start Zigbee
        zigbee.0
        2024-01-05 12:17:32.293	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        pi@iobrokerpi5:~ $ ls -ls /dev/serial/by-id/
        total 0
        0 lrwxrwxrwx 1 root root 13 Jan  5 12:15 usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00 -> ../../ttyACM0
        0 lrwxrwxrwx 1 root root 13 Jan  5 12:15 usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03 -> ../../ttyACM1
        zigbee.0
        2024-01-05 12:19:29.585	error	Error herdsman start
        zigbee.0
        2024-01-05 12:19:29.584	error	Failed to start Zigbee
        zigbee.0
        2024-01-05 12:19:29.584	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        zigbee.0
        2024-01-05 12:19:29.459	info	Installed Version: iobroker.zigbee@1.9.5
        zigbee.0
        2024-01-05 12:19:29.451	info	Starting Zigbee npm ...
        zigbee.0
        2024-01-05 12:19:29.450	info	Try to reconnect. 1 attempts left
        zigbee.0
        2024-01-05 12:19:19.447	error	Error herdsman start
        zigbee.0
        2024-01-05 12:19:19.447	error	Failed to start Zigbee
        zigbee.0
        2024-01-05 12:19:19.447	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
        zigbee.0
        2024-01-05 12:19:19.376	error	Re-commissioning your network will require re-pairing of all devices!
        zigbee.0
        2024-01-05 12:19:19.375	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
        zigbee.0
        2024-01-05 12:19:19.375	error	Please update configuration to prevent further issues.
        zigbee.0
        2024-01-05 12:19:19.375	error	- Channel List: configured=11, adapter=11
        zigbee.0
        2024-01-05 12:19:19.374	error	- Network Key: configured=ffffffffffffffffaaaaaaaaaaaaaaaa, adapter=ffffffffffffffffbbbbbbbbbbbbbbbb
        zigbee.0
        2024-01-05 12:19:19.374	error	- Extended PAN ID: configured=ffffffffaaaaaaaa, adapter=ddddddddaaaaaaaa
        zigbee.0
        2024-01-05 12:19:19.374	error	- PAN ID: configured=6754, adapter=6754
        zigbee.0
        2024-01-05 12:19:19.373	error	Configuration is not consistent with adapter state/backup!
        Zeit
        debug
        Nachricht
        zigbee.0
        2024-01-05 12:22:15.518	error	Error herdsman start
        zigbee.0
        2024-01-05 12:22:15.518	error	Failed to start Zigbee
        zigbee.0
        2024-01-05 12:22:15.517	error	Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
        admin.0
        2024-01-05 12:22:13.107	info	<== Disconnect system.user.admin from ::ffff:192.168.178.55
        admin.0
        zigbee.0
        2024-01-05 12:22:04.147	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
        zigbee.0
        2024-01-05 12:22:04.051	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        admin.0
        2024-01-05 12:22:03.973	info	==> Connected system.user.admin from ::ffff:192.168.178.55
        admin.0
        2024-01-05 12:22:02.099	info	<== Disconnect system.user.admin from ::ffff:192.168.178.55
        zigbee.0
        2024-01-05 12:21:58.972	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
        zigbee.0
        2024-01-05 12:21:58.878	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
        ich installier den adapter mal neu
          @varg
          Per
          V Offline
          V Offline
          varg
          will leider nicht
          zigbee.0
          2024-01-05 12:32:22.961	error	Error herdsman start
          zigbee.0
          2024-01-05 12:32:22.961	error	Failed to start Zigbee
          zigbee.0
          2024-01-05 12:32:22.961	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          zigbee.0
          2024-01-05 12:32:22.824	info	Installed Version: iobroker.zigbee@1.9.5
          zigbee.0
          2024-01-05 12:32:22.816	info	Starting Zigbee npm ...
          zigbee.0
          2024-01-05 12:32:22.815	info	Try to reconnect. 1 attempts left
          admin.0
          2024-01-05 12:32:18.198	info	<== Disconnect system.user.admin from ::ffff:192.168.178.55
          admin.0
          zigbee.0
          2024-01-05 12:32:12.812	error	Error herdsman start
          zigbee.0
          2024-01-05 12:32:12.812	error	Failed to start Zigbee
          zigbee.0
          2024-01-05 12:32:12.812	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
          zigbee.0
          2024-01-05 12:32:05.356	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100VGY","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100VGY-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA10"}]
          zigbee.0
          2024-01-05 12:32:05.235	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
          V 1 Antwort Letzte Antwort
          • V varg
            will leider nicht
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            admin.0
            admin.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            V Offline
            V Offline
            varg
            Ich vermute es hat was mit der neuen TI Platine zu tun.
            Wenn ich den alten Stick von Arteck anschliesse funzt es auch nach Neustart.
            @arteck hast Du eine Idee wie ich das Board richtig einbinde. Geflasht wurde es wie oben beschrieben
            Ich kann nur so viel sagen dass ich mit dem TI Board nach jedem neustart ein port problem bekomme
            • V varg
              @varg
              Ich kenne das Ding nicht, wie wird das denn angebunden? Über einen Seriellen Port?
              V Meister MopperM 2 Antworten Letzte Antwort
                @varg
                V Offline
                V Offline
                varg
                ich sag einfach mal ja hab aber wenig ahnung.
                vor 2 Jahren konnte ich die platine noch in nem anderen system ohne probleme einbinden.
                die neuere revision eben nicht
                youtube
                  @varg
                  Meister MopperM Online
                  Meister Mopper
                  Ich denke, hier ist der Wurm drin, oder?
                       18.13.0+dfsg1-1 500
                  Proxmox und HA ...
                         18.13.0+dfsg1-1 500
                    @meister-mopper
                    Das ist bereits geändert worden:
                    • V varg
                      youtube
                      @varg
                      Mach zur Sicherheit noch:
                      echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
                      sudo apt update
                      iob stop
                      sudo apt install nodejs=18.19.0-1nodesource1
                      iob start
                        @varg
                        sudo apt update
                        iob stop
                        iob start
                        V Offline
                        V Offline
                        varg
                        Ich hab das System nochmal komplett neu mit nodejs18 aufgesetzt und den alten Stick in Betrieb genommen.
                        Vielleicht hat noch jemand die neuere ti Platine mit der config und kann was dazu sagen.
                        Ich teste das Teil die Tage mal an einem PI4 mit buster und schau ob's damit läuft
                        Würde mich dann nochmal melden. Danke Euch
                          BigChris
                          schrieb am zuletzt editiert von BigChris
                          Bist du weitergekommen?
                          Gleiches Problem bei mir, nach Update vom Zigbee Adapter und nodejs funtioniert der Zigbee Adapter nicht mehr.
                          Bei mir mit dem raspbee als Aufsteckplatine.
                          			v.2023-10-10
                           Static hostname: pi-iobroker
                                 Icon name: computer
                          Operating System: Raspbian GNU/Linux 12 (bookworm)
                                    Kernel: Linux 6.1.0-rpi4-rpi-v8
                              Architecture: arm64
                          Kernel: 		aarch64
                          Userland: 		armhf
                          User-ID: 		1000
                          X-Server: 		false
                          Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
                          			/usr/bin/node 		v18.19.0
                          			/usr/bin/npm 		10.2.3
                          			/usr/bin/npx 		10.2.3
                          MEMORY:
                          Mem:            8.2G        749M        7.1G        1.2M        477M        7.4G
                          Swap:           104M          0B        104M
                          Total:          8.3G        749M        7.2G
                          Active iob-Instances: 	9
                          			admin 			6.12.0
                          ioBroker Status: 	iobroker is running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                          + system.adapter.admin.0                  : admin                 : pi-iobroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          Objects: 		1713
                          States: 		1506
                          19M	/opt/iobroker/iobroker-data/objects.jsonl
                          2.7M	/opt/iobroker/iobroker-data/states.jsonl
                          Was mich wundert ist das hier:
                          USB-Devices by-id:
                          Irgendwie wird die Platine nicht mehr erkannt. Das passiert bei zwei Systemen bei mir, jeweils Rasperry Pi 3 und raspbee.
                          • B BigChris
                            			v.2023-10-10
                                   Icon name: computer
                                Architecture: arm64
                            Kernel: 		aarch64
                            Userland: 		armhf
                            User-ID: 		1000
                            X-Server: 		false
                            			/usr/bin/npm 		10.2.3
                            			/usr/bin/npx 		10.2.3
                            MEMORY:
                            Swap:           104M          0B        104M
                            			admin 			6.12.0
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		1713
                            States: 		1506
                            USB-Devices by-id:
                            @bigchris sagte in Error herdsman start Failed to start Zigbee:
                            An der Stelle dürfte die noch nie erkannt worden sein. Da tauchen nur USB-Geräte auf. Du hast doch da ein IP-basiertes Ding laufen, oder?
                              MartinPM Online
                              MartinPM Online
                              MartinP
                              @thomas-braun Im ersten Logging finde ich "/dev/ttyACM0" das deutet doch auf USB hin, oder?
                              Braille-Reader Service?
                              • MartinPM MartinP
                                Gerade über 'raspbee' gestolpert...
                                @BigChris : Hast du in
                                sudo raspi-config
                                auch die Serielle Schnittstelle freigeschaltet?
                                MartinPM B 2 Antworten Letzte Antwort
                                  sudo raspi-config
                                  MartinPM Online
                                  MartinPM Online
                                  MartinP
                                  @thomas-braun Für solche Sachen bin ich auch Spezialist - solche "Unterbau-Vorbereitungen", die man vor Urzeiten mal gemacht hat vergesse ich auch regelmäßig bei Umzügen ...
                                  • MartinPM MartinP
                                    @martinp
                                    Es gibt Leute, die führen Buch über Änderungen / Ergänzungen am System.
                                      sudo raspi-config
                                      BigChris
                                      @thomas-braun sagte in Error herdsman start Failed to start Zigbee:
                                      sudo raspi-config
                                      Ja habe ich auch noch mal gemacht.
                                      Ich habe im Verdacht, dass das apt update / upgrade ein defekt eingespielt hat beim wechsel zu bookworm.
                                      Die Geräte an dem GPIO werden offensichtlich nicht mehr im System erkannt.
                                      • B BigChris
                                        sudo raspi-config
                                        @bigchris
                                        Gib uns mal die Langfassung von
                                        iob diag
                                          @martinp
                                          MartinPM Online
                                          MartinPM Online
                                          MartinP
                                          @martinp
                                          Gute Vorsätze fürs neue Jahr ... die Logbücher von Januar und Februar sind dann regelmäßig auch zumindest annähernd vollständig ;-)
                                          Wenn die Laufschuhe wieder im Schrank versauern, wird auch das Logbuch nicht mehr geführt, und in der gesparten Zeit werden wieder Kartoffelchips gefuttert ;-)
