  5. (erledigt) Blockly: switch / Case Block funktioniert nicht
    6.8k
9 Beiträge 2 Kommentatoren 551 Aufrufe 3 Beobachtet
  • ubeckerU Online
    ubeckerU Online
    ubecker
    schrieb am zuletzt editiert von ubecker
    denke ich falsch oder funktioniert der Block switch/ case nicht.
    Blockly:
    JS:
    var i;
    setState('javascript.0.Dummy2' /* Dummy2 */, 0, true);
    setState('0_userdata.0.Dummy1' /* Dummy1 */, 0, true);
    on({ id: [].concat(['javascript.0.Dummy_fuer_alles']), change: 'ne' }, async (obj) => {
      let value = obj.state.val;
      let oldValue = obj.oldState.val;
      i = (obj.state ? obj.state.val : "");
      switch (i) {
      	case i == 1:
        setState('0_userdata.0.Dummy1' /* Dummy1 */, i, true);
        console.log(('hier sollte i = 1 stehen' + String(i)));
      		break;
      	case i == 2:
        setState('javascript.0.Dummy2' /* Dummy2 */, i, true);
        console.log(('hier sollte i = 2 stehen' + String(i)));
      		break;
      	case i == 4:
        console.log(('hier sollte i = 4 stehen' + String(i)));
      		break;
      console.log(('gesamt ' + String(i)));
    Debug Output:
    27.12.2023, 22:29:44.505	[info ]: javascript.0 (1670) Stop script script.js.Tests.zum_test
    27.12.2023, 22:29:44.554	[info ]: javascript.0 (1670) Start javascript script.js.Tests.zum_test
    27.12.2023, 22:29:44.557	[info ]: javascript.0 (1670) script.js.Tests.zum_test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    27.12.2023, 22:29:52.035	[info ]: javascript.0 (1670) script.js.Tests.zum_test: gesamt 1
    27.12.2023, 22:29:53.301	[info ]: javascript.0 (1670) script.js.Tests.zum_test: gesamt 2
    27.12.2023, 22:29:54.515	[info ]: javascript.0 (1670) script.js.Tests.zum_test: gesamt 3
    27.12.2023, 22:29:55.515	[info ]: javascript.0 (1670) script.js.Tests.zum_test: gesamt 4
    Versionen:
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    /usr/bin/nodejs 	v18.19.0
    /usr/bin/node 		v18.19.0
    /usr/bin/npm 		10.2.3
    /usr/bin/npx 		10.2.3
    /usr/bin/corepack 	0.22.0
    Gruß Udo
    • ubeckerU ubecker
      Blockly:
      JS:
      var i;
        switch (i) {
        	case i == 1:
        		break;
        	case i == 2:
        		break;
        	case i == 4:
        		break;
      Debug Output:
      Versionen:
      /usr/bin/npm 		10.2.3
      /usr/bin/npx 		10.2.3
      CodierknechtC Offline
      Codierknecht
      @ubecker sagte in Blockly: switch / Case Block funktioniert nicht:
      Wenn man den richtig verwendet, funktioniert der auch ;-)
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      ubeckerU 1 Antwort Letzte Antwort
      • CodierknechtC Codierknecht
        ubeckerU Online
        ubeckerU Online
        ubecker
        @codierknecht das wäre schön.
        i ist auf dem Wert von dem Trigger. ist eine Zahl. Ich kann auch die Zahl direkt in "i" schreiben. geht trotzdem nicht.
        Gruß Udo
        • ubeckerU ubecker
          Codierknecht
          @ubecker
          Funktioniert einwandfrei!
          https://www.w3schools.com/js/js_switch.asp
            @ubecker
            ubeckerU Online
            ubeckerU Online
            ubecker
            @codierknecht
            ahhh, da darf kein Vergleich stehen.
            Könnt ihr das als Hinweis in Blockly für dummy aufnehmen.
            Gruß Udo
            • ubeckerU ubecker
              @codierknecht
              Codierknecht
              Das meinte ich mit "richtig verwenden" ;-)
              Wird umgehend ergänzt!
                ubeckerU Online
                ubeckerU Online
                ubecker
                @codierknecht super, ich war auf den Trigger fixiert. In meinem Script hab ich diesen Block erstmal durch viel "if then" ersetzt.
                Gruß Udo
                • ubeckerU ubecker
                  Codierknecht
                  @ubecker
                  Das Beispiel im "Dummy-Thread" zeigt auch bereits die korrekte Verwendung.
                  Ich habe trotzdem mal einen Hinweistext spendiert.
                    @ubecker
                    ubeckerU Online
                    ubeckerU Online
                    ubecker
                    @codierknecht hatte ich wohl schon gelesen aber der Hinweis ist richtig.
                    danke und bis demnächst 😁
                    Gruß Udo
