  4. [Gelöst] BackItUp Adapter Error
10 Beiträge 3 Kommentatoren 845 Aufrufe 2 Beobachtet
    Stephan1966
    schrieb am zuletzt editiert von Stephan1966
    Ist mein Backup fehlgeschlagen (die letzte Zeile "Access to home directory not allowed" irritiert mich)?
    Was bedeutet das?
    Started iobroker ...
    [DEBUG] [iobroker] - host.raspberrypismarthome 1761 states saved
    [DEBUG] [iobroker] - host.raspberrypismarthome 2069 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_12_23-20_14_15_backupiobroker.tar.gz
    [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
    [DEBUG] [iobroker] - done
    [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - found Script: EG_Flurlampe_über_Lichtsensor
    [DEBUG] [javascripts] - found Script: EG_Flurlampe_über_Zeitschaltung
    [DEBUG] [javascripts] - found Script: EG_Stehlampe_Wohnzimmer_über_Lichtsensor
    [DEBUG] [javascripts] - found Script: Luftfeuchtigkeit_Sahra_s_Zimmer
    [DEBUG] [javascripts] - found Script: Temperatur_Sahra_s_Zimmer
    [DEBUG] [javascripts] - found Script: Temperatur_Spielzimmer
    [DEBUG] [javascripts] - found Script: Luftfeuchtigkeit_Spielzimmer
    [DEBUG] [javascripts] - found Script: Wasserarlarm_mit_Alexa
    [DEBUG] [javascripts] - found Script: Wasseralarm
    [DEBUG] [javascripts] - found Script: Batteriealarm
    [DEBUG] [javascripts] - found Script: _Luftfeuchtigkeit_Sahra_s_Zimmer
    [DEBUG] [javascripts] - found Script: Temperatur_u__Luftfeuchtigkeit_Spielzimmer
    [DEBUG] [javascripts] - found Script: Skript_1
    [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2023_12_23-20_14_23_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [ERROR] [ftp] - Error: Access to home directory not allowed.
    Beste Grüße,
    Stephan
    Iobroker Nutzer seit 2022
    • S Stephan1966
      Was bedeutet das?
      @stephan1966 sagte in BackItUp Adapter Error:
      Was bedeutet das?
      das der Zugriff auf das homedirectory nicht passt.
      was hast du denn bei ftp konfiguriert?
        Was bedeutet das?
        Stephan1966
        Beste Grüße,
        Stephan
        • S Stephan1966
          @stephan1966 und der Nutzer hat Zugriff auf das Rootverzeichnis des Servers?
          S 2 Antworten Letzte Antwort
            Stephan1966
            Da bin ich gerade überfragt!
            Die Konfiguration ist schon lange her!
            Beste Grüße,
            Stephan
              Stephan1966
              @homoran sagte in BackItUp Adapter Error:
              Ich melde mich ja als admin im ioBroker an!
              Beste Grüße,
              Stephan
              HomoranH DuffyD 2 Antworten Letzte Antwort
              • S Stephan1966
                ja und?
                backitup soll sich als backup iobroker und zugehörigem Kennwort im Rootverzeichnis des ftp-Servers anmelden.
                Wobei ein Leerzeichen im Usernamen auch nicht sinnvoll ist
                • S Stephan1966
                  DuffyD Offline
                  DuffyD Offline
                  Duffy
                  @stephan1966
                  Ist der ftp auf der Fritzbox?
                  Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                  Node.js: v22.23.2
                  NPM: 10.9.4
                  js-controller 7.1.2
                  Linux: Trixie
                  • DuffyD Duffy
                    @stephan1966
                    Stephan1966
                    @duffy
                    Ja FTP ist auf der Fritzbox!
                    Ich habe den Fehler soeben gefunden:
                    Die externe Festplatte welche an meiner FB hängt hatte ich vor kurzem unbenannt.
                    Diese Änderung habe ich aber nicht dem ioBroker mitgeteilt so das dieser keinen gültigen Pfad mehr in den Einstellungen hatte. Das habe ich jetzt angepasst und die Backups werden wieder auf die externe Festplatte geschrieben!
                    Beste Grüße,
                    Stephan
                    DuffyD 1 Antwort Letzte Antwort
                    • S Stephan1966
                      @duffy
                      DuffyD Offline
                      DuffyD Offline
                      Duffy
                      @stephan1966
                      Klasse 👍🏻
                      Node.js: v22.23.2
                      NPM: 10.9.4
                      js-controller 7.1.2
                      Linux: Trixie
