  4. Node-Red
  5. Array mit Objekten in iOBroker anlegen
    6.5k
node-red
46 Beiträge 2 Kommentatoren 5.8k Aufrufe 2 Beobachtet
  • mickymM mickym
    @hackypaddy
    Probiere doch mal wie ich gesagt habe die Partition nicht in der Node zu verwenden sondern mit der payload?
    hast Du denn das schon versucht: https://forum.iobroker.net/post/1098790
    Ich probiere parallel einen Flow zu erstellen, aber Du würdest Dir das Leben viel einfacher machen. Bitte probiere das erst aus.
    HackyPaddy
    @mickym
    hier mal mein Flow, wie ich ihn gerade verwende. Ziel wäre es, die einzelnen Bereiche nacheinander abzufragen. Erst Bereich 1, dann Bereich 2, usw.
            "id": "21ba77d9f363fc5c",
            "type": "tab",
            "label": "Secvest",
            "disabled": false,
            "info": "",
            "env": []
            "id": "7de9826e28d68b1d",
            "type": "split",
            "z": "21ba77d9f363fc5c",
            "name": "",
            "splt": "\\n",
            "spltType": "str",
            "arraySplt": 1,
            "arraySpltType": "len",
            "stream": false,
            "addname": "topic",
            "x": 690,
            "y": 220,
            "wires": [
                    "7ae37472e7b5ca96"
            "id": "7ae37472e7b5ca96",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "change",
                    "p": "payload.name",
                    "pt": "msg",
                    "from": ".",
                    "fromt": "str",
                    "to": "",
                    "tot": "str"
                    "t": "set",
                    "p": "topic",
                    "pt": "msg",
                    "to": "\"0_userdata.0.Alarm.\" & payload.id & \".\" &  payload.name",
                    "tot": "jsonata"
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.state",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 730,
            "y": 300,
            "wires": [
                    "3f9d9626684a6018"
            "id": "3f9d9626684a6018",
            "type": "ioBroker out",
            "name": "",
            "topic": "",
            "ack": "true",
            "autoCreate": "true",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 720,
            "y": 380,
            "wires": []
            "id": "736b74f1fd7dfdd5",
            "type": "Secvest Status",
            "name": "Bereich 1",
            "server": "5dc4b66ee70b8720",
            "partition": "1",
            "command": "zones",
            "x": 400,
            "y": 140,
            "wires": [
                    "7de9826e28d68b1d"
            "id": "c9f81194989a2d11",
            "type": "inject",
            "name": "Alle 45 Sek.",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": "1",
            "topic": "",
            "payload": "",
            "payloadType": "date",
            "x": 130,
            "y": 100,
            "wires": [
                    "736b74f1fd7dfdd5",
                    "3149fd696d113580",
                    "427ed92e5fcf9fa0",
                    "a7ae4222d4fc65a0"
            "id": "3149fd696d113580",
            "name": "Bereich 2",
            "partition": "2",
            "command": "zones",
            "x": 420,
            "y": 200,
            "wires": [
                    "7de9826e28d68b1d"
            "id": "427ed92e5fcf9fa0",
            "name": "Bereich 3",
            "partition": "3",
            "command": "zones",
            "x": 400,
            "y": 260,
            "wires": [
                    "7de9826e28d68b1d"
            "id": "a7ae4222d4fc65a0",
            "name": "Bereich 4",
            "partition": "4",
            "command": "zones",
            "x": 390,
            "y": 320,
            "wires": [
                    "7de9826e28d68b1d"
            "id": "5dc4b66ee70b8720",
            "type": "ABUS Secvest",
            "servername": "Secvest",
            "host": "192.168.10.121",
            "port": "4433",
            "user": "Alert",
            "password": "xxxx"
    • H HackyPaddy
      @mickym
              "type": "tab",
              "label": "Secvest",
              "disabled": false,
              "info": "",
              "env": []
              "type": "split",
              "name": "",
              "splt": "\\n",
              "spltType": "str",
              "arraySplt": 1,
              "stream": false,
              "addname": "topic",
              "x": 690,
              "y": 220,
              "wires": [
                      "7ae37472e7b5ca96"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "change",
                      "pt": "msg",
                      "from": ".",
                      "fromt": "str",
                      "to": "",
                      "tot": "str"
                      "t": "set",
                      "p": "topic",
                      "pt": "msg",
                      "tot": "jsonata"
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 730,
              "y": 300,
              "wires": [
                      "3f9d9626684a6018"
              "name": "",
              "topic": "",
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 720,
              "y": 380,
              "wires": []
              "partition": "1",
              "command": "zones",
              "x": 400,
              "y": 140,
              "wires": [
                      "7de9826e28d68b1d"
              "type": "inject",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": "1",
              "topic": "",
              "payload": "",
              "x": 130,
              "y": 100,
              "wires": [
                      "736b74f1fd7dfdd5",
                      "3149fd696d113580",
                      "427ed92e5fcf9fa0",
                      "a7ae4222d4fc65a0"
              "partition": "2",
              "command": "zones",
              "x": 420,
              "y": 200,
              "wires": [
                      "7de9826e28d68b1d"
              "partition": "3",
              "command": "zones",
              "x": 400,
              "y": 260,
              "wires": [
                      "7de9826e28d68b1d"
              "partition": "4",
              "command": "zones",
              "x": 390,
              "y": 320,
              "wires": [
                      "7de9826e28d68b1d"
              "port": "4433",
              "user": "Alert",
              "password": "xxxx"
      mickymM Offline
      mickymM Offline
      mickym
      @hackypaddy Ja trotzdem probiere es bitte -
      Nimm einfach eine von den Secvest Nodes - mach dahinter eine Debug Node und schau ob Du mit
      einer Inject Node mit einer payload die eine der 3. Partitions enthält abfragst?
      Wie gesagt es geht auch mit 4 Nodes - aber es ist einfach ÜBERFLÜSSIG, wenn der Entwickler anbietet, dass man mit einer payload die Partitionen einzeln abfragen kann.
      • mickymM mickym
        mickymM Offline
        mickymM Offline
        mickym
        @hackpaddy
        Hast Du es probiert???
        H 1 Antwort Letzte Antwort
        • mickymM mickym
          @hackpaddy
          HackyPaddy
          @mickym
          Ich bin noch dabei, aber so wie es aussieht, funktioniert das nicht...
          • H HackyPaddy
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @hackypaddy dann probiere es mal mit den beiden Inject Nodes und schau ob da was rauskommt.
            In der Node löscht Du Command und Partition bitte.
                   "id": "30a75b4cea8b0f90",
                   "type": "inject",
                   "z": "517cd16e4d7e6ae4",
                   "name": "",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "{\"command\":\"state\",\"partition\":\"3\"}",
                   "payloadType": "json",
                   "x": 830,
                   "y": 1480,
                   "wires": [
                   "id": "b886fcf335c578ce",
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "{\"command\":\"state\",\"partition\":3}",
                   "x": 830,
                   "y": 1520,
                   "wires": [
            • mickymM mickym
                     "type": "inject",
                     "name": "",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "x": 830,
                     "y": 1480,
                     "wires": [
                     "type": "inject",
                     "name": "",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "x": 830,
                     "y": 1520,
                     "wires": [
              mickymM Offline
              mickymM Offline
              mickym
              So nachdem ich von Dir leider keinen Response bekomme, und das eigentlich gehen müsste, habe ich Dir hier nun einen Flow gebastelt - der den Status abfragt und mit dem ich Deine Secvest Nodes simuliert habe
              Die Nachricht kommt nur raus, wenn der Status OK ist.
              Du musst aber vorher in der Statusermittlung die ID der Nodes in die Switch Node eintragen. Wenn Du das mal durchgespielt hast hier mit diesem Flow - dann wirst Du es auch auf den realen Flow umsetzen können:
                     "id": "c05f687368999ce5",
                     "type": "group",
                     "name": "Hauptflow",
                     "style": {
                         "fill": "#e3f3d3",
                         "label": true
                     "nodes": [
                         "edf6186f87bd29cf",
                         "43d75f1a298e4228",
                         "5c2a6fd166cadeea",
                         "1f3ca857652a6f2d",
                         "d0227b7791f129b7",
                         "4385c065f4bcf50b",
                         "2686fd64b3416b63",
                         "105628d009801c57"
                     "x": 54,
                     "y": 1559,
                     "w": 1612,
                     "h": 82
                     "id": "edf6186f87bd29cf",
                     "type": "debug",
                     "g": "c05f687368999ce5",
                     "name": "Nachricht",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "complete": "payload",
                     "targetType": "msg",
                     "statusVal": "",
                     "statusType": "auto",
                     "x": 1560,
                     "y": 1600,
                     "wires": []
                     "id": "43d75f1a298e4228",
                     "type": "link call",
                     "name": "",
                     "links": [
                         "0261bc0c575a8179"
                     "linkType": "static",
                     "timeout": "30",
                     "x": 340,
                     "y": 1600,
                     "wires": [
                             "1f3ca857652a6f2d"
                     "id": "5c2a6fd166cadeea",
                     "type": "inject",
                     "name": "trigger",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "true",
                     "payloadType": "bool",
                     "x": 150,
                     "y": 1600,
                     "wires": [
                             "43d75f1a298e4228"
                     "id": "1f3ca857652a6f2d",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "result",
                             "pt": "msg",
                             "to": "$flowContext(\"Secvest.partition.\"& next)\t",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 540,
                     "y": 1600,
                     "wires": [
                             "d0227b7791f129b7"
                     "id": "d0227b7791f129b7",
                     "type": "switch",
                     "name": "Nur wenn OK?",
                     "property": "result",
                     "propertyType": "msg",
                     "rules": [
                             "t": "cont",
                             "v": "OK",
                             "vt": "str"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 1,
                     "x": 740,
                     "y": 1600,
                     "wires": [
                             "2686fd64b3416b63"
                     "id": "4385c065f4bcf50b",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "Secvest.nextPart",
                             "pt": "flow",
                             "to": "next",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1340,
                     "y": 1600,
                     "wires": [
                             "edf6186f87bd29cf"
                     "id": "2686fd64b3416b63",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "next",
                             "pt": "msg",
                             "to": "next + 1",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 940,
                     "y": 1600,
                     "wires": [
                             "105628d009801c57"
                     "id": "105628d009801c57",
                     "type": "range",
                     "minin": "1",
                     "maxin": "5",
                     "minout": "1",
                     "maxout": "5",
                     "action": "roll",
                     "round": true,
                     "property": "next",
                     "name": "",
                     "x": 1110,
                     "y": 1600,
                     "wires": [
                             "4385c065f4bcf50b"
                     "id": "79474f37517badfa",
                     "type": "group",
                     "name": "Status",
                     "style": {
                         "fill": "#ffffbf",
                         "label": true
                     "nodes": [
                         "046d20801968277a",
                         "166f54f5d95776c5",
                         "967ae311bedb5398",
                         "f531134c2d277c8e",
                         "f7e0ad7f8c47e9e2",
                         "b859b6f87ebdea89",
                         "acd1fb1a37c75788"
                     "x": 54,
                     "y": 1659,
                     "w": 672,
                     "h": 222
                     "id": "046d20801968277a",
                     "type": "status",
                     "g": "79474f37517badfa",
                     "name": "",
                     "scope": [
                         "26da1e75ad50f497",
                         "77406c09f2b4935f",
                         "a36d2b0336d314d5",
                         "dca5caeebd3fa237"
                     "x": 140,
                     "y": 1780,
                     "wires": [
                             "166f54f5d95776c5",
                             "f531134c2d277c8e"
                     "id": "166f54f5d95776c5",
                     "type": "switch",
                     "name": "",
                     "property": "status.source.id",
                     "rules": [
                             "t": "eq",
                             "v": "26da1e75ad50f497",
                             "vt": "str"
                             "t": "eq",
                             "v": "77406c09f2b4935f",
                             "vt": "str"
                             "t": "eq",
                             "v": "a36d2b0336d314d5",
                             "vt": "str"
                             "t": "eq",
                             "v": "dca5caeebd3fa237",
                             "vt": "str"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 4,
                     "x": 330,
                     "y": 1760,
                     "wires": [
                             "967ae311bedb5398"
                             "f7e0ad7f8c47e9e2"
                             "b859b6f87ebdea89"
                             "acd1fb1a37c75788"
                     "id": "967ae311bedb5398",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "Secvest.partition.1",
                             "pt": "flow",
                             "to": "status.text ",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 580,
                     "y": 1700,
                     "wires": [
                     "id": "f531134c2d277c8e",
                     "type": "debug",
                     "name": "status all",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "complete": "status",
                     "statusVal": "",
                     "x": 320,
                     "y": 1840,
                     "wires": []
                     "id": "f7e0ad7f8c47e9e2",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "Secvest.partition.2",
                             "pt": "flow",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 580,
                     "y": 1740,
                     "wires": [
                     "id": "b859b6f87ebdea89",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "Secvest.partition.3",
                             "pt": "flow",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 580,
                     "y": 1780,
                     "wires": [
                     "id": "acd1fb1a37c75788",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "Secvest.partition.4",
                             "pt": "flow",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 580,
                     "y": 1820,
                     "wires": [
                     "id": "b7fe5d925d8e97e6",
                     "type": "group",
                     "name": "Abfrage",
                     "style": {
                         "fill": "#dbcbe7",
                         "label": true
                     "nodes": [
                         "678dc9ba9d8c785f",
                         "f848c65833d70071",
                         "40bce79305c4643d",
                         "26da1e75ad50f497",
                         "50b76a92e1d49815",
                         "610c1cd0aa01c457",
                         "edf0b36304b14ced",
                         "77406c09f2b4935f",
                         "b291f001e92e6035",
                         "94e0553e3cd9b288",
                         "27712704a9ab0b48",
                         "a36d2b0336d314d5",
                         "fd85b9e702df0f23",
                         "b3e5ed6bd910648d",
                         "d6c566a7f673e2bf",
                         "dca5caeebd3fa237",
                         "6203be293dd53946",
                         "77ed707586880c2f",
                         "0261bc0c575a8179",
                         "c867ec0ddf91ddf0",
                         "bf53714046156c85",
                         "de3b72e71c80a313"
                     "x": 54,
                     "y": 1899,
                     "w": 1612,
                     "h": 422
                     "id": "678dc9ba9d8c785f",
                     "type": "switch",
                     "g": "b7fe5d925d8e97e6",
                     "name": "part1",
                     "property": "$random()\t",
                     "propertyType": "jsonata",
                     "rules": [
                             "t": "lt",
                             "v": "0.5",
                             "vt": "num"
                             "t": "gte",
                             "v": "0.5",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 630,
                     "y": 1960,
                     "wires": [
                             "f848c65833d70071"
                             "40bce79305c4643d"
                     "id": "f848c65833d70071",
                     "type": "change",
                     "name": "Ergebnis Ok",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "[{\"id\":\"109\",\"name\":\"Kontakt\",\"state\":\"closed\"},{\"id\":\"110\",\"name\":\"BW Fen. R.\",\"state\":\"closed\"}]",
                             "tot": "json"
                             "t": "set",
                             "p": "topic",
                             "pt": "msg",
                             "to": "part1",
                             "tot": "str"
                             "t": "set",
                             "p": "status",
                             "pt": "msg",
                             "to": "{\"fill\":\"green\",\"shape\":\"dot\",\"text\":\"OK\"}",
                             "tot": "json"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 830,
                     "y": 1940,
                     "wires": [
                             "26da1e75ad50f497"
                     "id": "40bce79305c4643d",
                     "type": "change",
                     "name": "Ergebnis Nicht Ok",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "[{\"id\":\"109\",\"name\":\"Kontakt\",\"state\":\"closed\"}]",
                             "tot": "json"
                             "t": "set",
                             "p": "topic",
                             "pt": "msg",
                             "to": "part1",
                             "tot": "str"
                             "t": "set",
                             "p": "status",
                             "pt": "msg",
                             "to": "{\"fill\":\"red\",\"shape\":\"dot\",\"text\":\"Error\"}",
                             "tot": "json"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 810,
                     "y": 1980,
                     "wires": [
                             "26da1e75ad50f497"
                     "id": "26da1e75ad50f497",
                     "type": "function",
                     "name": "Simuliere Secvest Command - Partition 1",
                     "func": "var newMsg;\nnode.status(msg.status);\nnewMsg = {topic:msg.topic, payload:msg.payload}\nreturn msg;",
                     "outputs": 1,
                     "noerr": 0,
                     "initialize": "",
                     "finalize": "",
                     "libs": [],
                     "x": 1120,
                     "y": 1960,
                     "wires": [
                             "de3b72e71c80a313"
                     "id": "50b76a92e1d49815",
                     "type": "switch",
                     "name": "part2",
                     "rules": [
                             "t": "lt",
                             "v": "0.5",
                             "vt": "num"
                             "t": "gte",
                             "v": "0.5",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 630,
                     "y": 2060,
                     "wires": [
                             "610c1cd0aa01c457"
                             "edf0b36304b14ced"
                     "id": "610c1cd0aa01c457",
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "json"
                             "t": "set",
                             "p": "topic",
                             "pt": "msg",
                             "to": "part2",
                             "tot": "str"
                             "t": "set",
                             "p": "status",
                             "pt": "msg",
                             "tot": "json"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 830,
                     "y": 2040,
                     "wires": [
                             "77406c09f2b4935f"
                     "id": "edf0b36304b14ced",
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "json"
                             "t": "set",
                             "p": "topic",
                             "pt": "msg",
                             "to": "part2",
                             "tot": "str"
                             "t": "set",
                             "p": "status",
                             "pt": "msg",
                             "tot": "json"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 810,
                     "y": 2080,
                     "wires": [
                             "77406c09f2b4935f"
                     "id": "77406c09f2b4935f",
                     "type": "function",
                     "name": "Simuliere Secvest Command - Partition 2",
                     "outputs": 1,
                     "noerr": 0,
                     "initialize": "",
                     "finalize": "",
                     "libs": [],
                     "x": 1120,
                     "y": 2060,
                     "wires": [
                             "de3b72e71c80a313"
                     "id": "b291f001e92e6035",
                     "type": "switch",
                     "name": "part3",
                     "rules": [
                             "t": "lt",
                             "v": "0.5",
                             "vt": "num"
                             "t": "gte",
                             "v": "0.5",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 630,
                     "y": 2160,
                     "wires": [
                             "94e0553e3cd9b288"
                             "27712704a9ab0b48"
                     "id": "94e0553e3cd9b288",
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "json"
                             "t": "set",
                             "p": "topic",
                             "pt": "msg",
                             "to": "part3",
                             "tot": "str"
                             "t": "set",
                             "p": "status",
                             "pt": "msg",
                             "tot": "json"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 830,
                     "y": 2140,
                     "wires": [
                             "a36d2b0336d314d5"
                     "id": "27712704a9ab0b48",
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "json"
                             "t": "set",
                             "p": "topic",
                             "pt": "msg",
                             "to": "part3",
                             "tot": "str"
                             "t": "set",
                             "p": "status",
                             "pt": "msg",
                             "tot": "json"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 810,
                     "y": 2180,
                     "wires": [
                             "a36d2b0336d314d5"
                     "id": "a36d2b0336d314d5",
                     "type": "function",
                     "name": "Simuliere Secvest Command - Partition 3",
                     "outputs": 1,
                     "noerr": 0,
                     "initialize": "",
                     "finalize": "",
                     "libs": [],
                     "x": 1120,
                     "y": 2160,
                     "wires": [
                             "de3b72e71c80a313"
                     "id": "fd85b9e702df0f23",
                     "type": "switch",
                     "name": "part4",
                     "rules": [
                             "t": "lt",
                             "v": "0.5",
                             "vt": "num"
                             "t": "gte",
                             "v": "0.5",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 2,
                     "x": 630,
                     "y": 2260,
                     "wires": [
                             "b3e5ed6bd910648d"
                             "d6c566a7f673e2bf"
                     "id": "b3e5ed6bd910648d",
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "json"
                             "t": "set",
                             "p": "topic",
                             "pt": "msg",
                             "to": "part4",
                             "tot": "str"
                             "t": "set",
                             "p": "status",
                             "pt": "msg",
                             "tot": "json"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 830,
                     "y": 2240,
                     "wires": [
                             "dca5caeebd3fa237"
                     "id": "d6c566a7f673e2bf",
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "json"
                             "t": "set",
                             "p": "topic",
                             "pt": "msg",
                             "to": "part4",
                             "tot": "str"
                             "t": "set",
                             "p": "status",
                             "pt": "msg",
                             "tot": "json"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 810,
                     "y": 2280,
                     "wires": [
                             "dca5caeebd3fa237"
                     "id": "dca5caeebd3fa237",
                     "type": "function",
                     "name": "Simuliere Secvest Command - Partition 4",
                     "outputs": 1,
                     "noerr": 0,
                     "initialize": "",
                     "finalize": "",
                     "libs": [],
                     "x": 1120,
                     "y": 2260,
                     "wires": [
                             "de3b72e71c80a313"
                     "id": "6203be293dd53946",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "next",
                             "pt": "msg",
                             "to": "$exists($flowContext(\"Secvest.nextPart\")) ? $flowContext(\"Secvest.nextPart\") : 1\t\t",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 220,
                     "y": 2100,
                     "wires": [
                             "77ed707586880c2f"
                     "id": "77ed707586880c2f",
                     "type": "switch",
                     "name": "",
                     "property": "next",
                     "rules": [
                             "t": "eq",
                             "v": "1",
                             "vt": "num"
                             "t": "eq",
                             "v": "2",
                             "vt": "num"
                             "t": "eq",
                             "v": "3",
                             "vt": "num"
                             "t": "eq",
                             "v": "4",
                             "vt": "num"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 4,
                     "x": 430,
                     "y": 2100,
                     "wires": [
                             "678dc9ba9d8c785f"
                             "50b76a92e1d49815"
                             "b291f001e92e6035"
                             "fd85b9e702df0f23"
                     "id": "0261bc0c575a8179",
                     "type": "link in",
                     "name": "queryPartition",
                     "links": [],
                     "x": 95,
                     "y": 2100,
                     "wires": [
                             "6203be293dd53946"
                     "id": "c867ec0ddf91ddf0",
                     "type": "link out",
                     "name": "queryResponse",
                     "mode": "return",
                     "links": [],
                     "x": 1625,
                     "y": 2100,
                     "wires": []
                     "id": "bf53714046156c85",
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "delete",
                             "p": "status",
                             "pt": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1490,
                     "y": 2100,
                     "wires": [
                             "c867ec0ddf91ddf0"
                     "id": "de3b72e71c80a313",
                     "type": "junction",
                     "x": 1360,
                     "y": 2100,
                     "wires": [
                             "bf53714046156c85"
              Vorerst ist das Thema aber für mich damit erst mal abgeschlossen.
              • mickymM mickym
                       "type": "group",
                       "style": {
                           "fill": "#e3f3d3",
                           "label": true
                       "nodes": [
                           "edf6186f87bd29cf",
                           "43d75f1a298e4228",
                           "5c2a6fd166cadeea",
                           "1f3ca857652a6f2d",
                           "d0227b7791f129b7",
                           "4385c065f4bcf50b",
                           "2686fd64b3416b63",
                           "105628d009801c57"
                       "x": 54,
                       "y": 1559,
                       "w": 1612,
                       "h": 82
                       "type": "debug",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1560,
                       "y": 1600,
                       "wires": []
                       "name": "",
                       "links": [
                           "0261bc0c575a8179"
                       "timeout": "30",
                       "x": 340,
                       "y": 1600,
                       "wires": [
                               "1f3ca857652a6f2d"
                       "type": "inject",
                       "name": "trigger",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "true",
                       "x": 150,
                       "y": 1600,
                       "wires": [
                               "43d75f1a298e4228"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "result",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 540,
                       "y": 1600,
                       "wires": [
                               "d0227b7791f129b7"
                       "type": "switch",
                       "rules": [
                               "t": "cont",
                               "v": "OK",
                               "vt": "str"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 1,
                       "x": 740,
                       "y": 1600,
                       "wires": [
                               "2686fd64b3416b63"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "pt": "flow",
                               "to": "next",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1340,
                       "y": 1600,
                       "wires": [
                               "edf6186f87bd29cf"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "next",
                               "pt": "msg",
                               "to": "next + 1",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 940,
                       "y": 1600,
                       "wires": [
                               "105628d009801c57"
                       "type": "range",
                       "minin": "1",
                       "maxin": "5",
                       "minout": "1",
                       "maxout": "5",
                       "action": "roll",
                       "round": true,
                       "property": "next",
                       "name": "",
                       "x": 1110,
                       "y": 1600,
                       "wires": [
                               "4385c065f4bcf50b"
                       "type": "group",
                       "name": "Status",
                       "style": {
                           "fill": "#ffffbf",
                           "label": true
                       "nodes": [
                           "046d20801968277a",
                           "166f54f5d95776c5",
                           "967ae311bedb5398",
                           "f531134c2d277c8e",
                           "f7e0ad7f8c47e9e2",
                           "b859b6f87ebdea89",
                           "acd1fb1a37c75788"
                       "x": 54,
                       "y": 1659,
                       "w": 672,
                       "h": 222
                       "type": "status",
                       "name": "",
                       "scope": [
                           "26da1e75ad50f497",
                           "77406c09f2b4935f",
                           "a36d2b0336d314d5",
                           "dca5caeebd3fa237"
                       "x": 140,
                       "y": 1780,
                       "wires": [
                               "166f54f5d95776c5",
                               "f531134c2d277c8e"
                       "type": "switch",
                       "name": "",
                       "rules": [
                               "t": "eq",
                               "vt": "str"
                               "t": "eq",
                               "vt": "str"
                               "t": "eq",
                               "vt": "str"
                               "t": "eq",
                               "vt": "str"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 4,
                       "x": 330,
                       "y": 1760,
                       "wires": [
                               "967ae311bedb5398"
                               "f7e0ad7f8c47e9e2"
                               "b859b6f87ebdea89"
                               "acd1fb1a37c75788"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "pt": "flow",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 580,
                       "y": 1700,
                       "wires": [
                       "type": "debug",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 320,
                       "y": 1840,
                       "wires": []
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "pt": "flow",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 580,
                       "y": 1740,
                       "wires": [
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "pt": "flow",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 580,
                       "y": 1780,
                       "wires": [
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "pt": "flow",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 580,
                       "y": 1820,
                       "wires": [
                       "type": "group",
                       "name": "Abfrage",
                       "style": {
                           "fill": "#dbcbe7",
                           "label": true
                       "nodes": [
                           "678dc9ba9d8c785f",
                           "f848c65833d70071",
                           "40bce79305c4643d",
                           "26da1e75ad50f497",
                           "50b76a92e1d49815",
                           "610c1cd0aa01c457",
                           "edf0b36304b14ced",
                           "77406c09f2b4935f",
                           "b291f001e92e6035",
                           "94e0553e3cd9b288",
                           "27712704a9ab0b48",
                           "a36d2b0336d314d5",
                           "fd85b9e702df0f23",
                           "b3e5ed6bd910648d",
                           "d6c566a7f673e2bf",
                           "dca5caeebd3fa237",
                           "6203be293dd53946",
                           "77ed707586880c2f",
                           "0261bc0c575a8179",
                           "c867ec0ddf91ddf0",
                           "bf53714046156c85",
                           "de3b72e71c80a313"
                       "x": 54,
                       "y": 1899,
                       "w": 1612,
                       "h": 422
                       "type": "switch",
                       "name": "part1",
                       "rules": [
                               "t": "lt",
                               "v": "0.5",
                               "vt": "num"
                               "t": "gte",
                               "v": "0.5",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 630,
                       "y": 1960,
                       "wires": [
                               "f848c65833d70071"
                               "40bce79305c4643d"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "part1",
                               "tot": "str"
                               "t": "set",
                               "p": "status",
                               "pt": "msg",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 830,
                       "y": 1940,
                       "wires": [
                               "26da1e75ad50f497"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "part1",
                               "tot": "str"
                               "t": "set",
                               "p": "status",
                               "pt": "msg",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 810,
                       "y": 1980,
                       "wires": [
                               "26da1e75ad50f497"
                       "type": "function",
                       "outputs": 1,
                       "noerr": 0,
                       "initialize": "",
                       "finalize": "",
                       "libs": [],
                       "x": 1120,
                       "y": 1960,
                       "wires": [
                               "de3b72e71c80a313"
                       "type": "switch",
                       "name": "part2",
                       "rules": [
                               "t": "lt",
                               "v": "0.5",
                               "vt": "num"
                               "t": "gte",
                               "v": "0.5",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 630,
                       "y": 2060,
                       "wires": [
                               "610c1cd0aa01c457"
                               "edf0b36304b14ced"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "part2",
                               "tot": "str"
                               "t": "set",
                               "p": "status",
                               "pt": "msg",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 830,
                       "y": 2040,
                       "wires": [
                               "77406c09f2b4935f"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "part2",
                               "tot": "str"
                               "t": "set",
                               "p": "status",
                               "pt": "msg",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 810,
                       "y": 2080,
                       "wires": [
                               "77406c09f2b4935f"
                       "type": "function",
                       "outputs": 1,
                       "noerr": 0,
                       "initialize": "",
                       "finalize": "",
                       "libs": [],
                       "x": 1120,
                       "y": 2060,
                       "wires": [
                               "de3b72e71c80a313"
                       "type": "switch",
                       "name": "part3",
                       "rules": [
                               "t": "lt",
                               "v": "0.5",
                               "vt": "num"
                               "t": "gte",
                               "v": "0.5",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 630,
                       "y": 2160,
                       "wires": [
                               "94e0553e3cd9b288"
                               "27712704a9ab0b48"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "part3",
                               "tot": "str"
                               "t": "set",
                               "p": "status",
                               "pt": "msg",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 830,
                       "y": 2140,
                       "wires": [
                               "a36d2b0336d314d5"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "part3",
                               "tot": "str"
                               "t": "set",
                               "p": "status",
                               "pt": "msg",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 810,
                       "y": 2180,
                       "wires": [
                               "a36d2b0336d314d5"
                       "type": "function",
                       "outputs": 1,
                       "noerr": 0,
                       "initialize": "",
                       "finalize": "",
                       "libs": [],
                       "x": 1120,
                       "y": 2160,
                       "wires": [
                               "de3b72e71c80a313"
                       "type": "switch",
                       "name": "part4",
                       "rules": [
                               "t": "lt",
                               "v": "0.5",
                               "vt": "num"
                               "t": "gte",
                               "v": "0.5",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 630,
                       "y": 2260,
                       "wires": [
                               "b3e5ed6bd910648d"
                               "d6c566a7f673e2bf"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "part4",
                               "tot": "str"
                               "t": "set",
                               "p": "status",
                               "pt": "msg",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 830,
                       "y": 2240,
                       "wires": [
                               "dca5caeebd3fa237"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "tot": "json"
                               "t": "set",
                               "p": "topic",
                               "pt": "msg",
                               "to": "part4",
                               "tot": "str"
                               "t": "set",
                               "p": "status",
                               "pt": "msg",
                               "tot": "json"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 810,
                       "y": 2280,
                       "wires": [
                               "dca5caeebd3fa237"
                       "type": "function",
                       "outputs": 1,
                       "noerr": 0,
                       "initialize": "",
                       "finalize": "",
                       "libs": [],
                       "x": 1120,
                       "y": 2260,
                       "wires": [
                               "de3b72e71c80a313"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "next",
                               "pt": "msg",
                               "tot": "jsonata"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 220,
                       "y": 2100,
                       "wires": [
                               "77ed707586880c2f"
                       "type": "switch",
                       "name": "",
                       "property": "next",
                       "rules": [
                               "t": "eq",
                               "v": "1",
                               "vt": "num"
                               "t": "eq",
                               "v": "2",
                               "vt": "num"
                               "t": "eq",
                               "v": "3",
                               "vt": "num"
                               "t": "eq",
                               "v": "4",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 4,
                       "x": 430,
                       "y": 2100,
                       "wires": [
                               "678dc9ba9d8c785f"
                               "50b76a92e1d49815"
                               "b291f001e92e6035"
                               "fd85b9e702df0f23"
                       "type": "link in",
                       "links": [],
                       "x": 95,
                       "y": 2100,
                       "wires": [
                               "6203be293dd53946"
                       "type": "link out",
                       "mode": "return",
                       "links": [],
                       "x": 1625,
                       "y": 2100,
                       "wires": []
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "delete",
                               "p": "status",
                               "pt": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1490,
                       "y": 2100,
                       "wires": [
                               "c867ec0ddf91ddf0"
                       "type": "junction",
                       "x": 1360,
                       "y": 2100,
                       "wires": [
                               "bf53714046156c85"
                HackyPaddy
                @mickym
                Wow, danke.
                Ich bin grad unterwegs, deshalb kann ich das nicht so schnell durchtesten...
                Wenn ich nachher zuhause bin, schau ich mir Deinen Flow mal an und versuche den zu verstehen.
                Wahnsinn, vielen Dank für deine Arbeit!
                • H HackyPaddy
                  @mickym
                  Wow, danke.
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @hackypaddy Wie gesagt, wenn Du das mit der payload und den Einzelabrufen in einer Node machen kannst, dann hätte ich mir diese Arbeit sparen können.
                  • mickymM mickym
                    HackyPaddy
                    @mickym
                    Ne das geht ja nicht, also in einer Node.
                    • H HackyPaddy
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @hackypaddy Lt. Beschreibung muss das aber gehen.
                      H 2 Antworten Letzte Antwort
                      • mickymM mickym
                        HackyPaddy
                        @mickym
                        ich bekomm da nichts raus.
                        Hab mir gerade mal Dein Konstrukt angeschaut (auf dem Handy). Meine Herren, mir raucht der Kopf. Ich setz mich da nachher mal ran und versuch das alles irgendwie zu verstehen.
                        • mickymM mickym
                          HackyPaddy
                          @mickym
                          Ich hab jetzt 3 Stunden probiert, und es funktioniert nicht. Und dann fiel es mir wie Schuppen von den Augen, als ich die Beschreibung nochmal genau durchgelesen hab...
                          Du hast den Command Baustein gemeint. Ja, diesen kannst per payload steuern und dort auch die einzelnen Partitionen abgeben. Aber diesen Baustein nutze ich nicht. Mit diesem Baustein steuert man die Anlage (scharf, unscharf, teilscharf).
                          Ich nutze nur den Status-Baustein. Dieser ließt die einzelnen Partitionen aus, gibt dann die Zonen aus und dort den Status (auf / zu).
                          Deshalb hat das vorhin auch nicht funktioniert.
                          • H HackyPaddy
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @hackypaddy Ok dann kannst Du Dir ja meinen Flow im Genauen anschauen. Kurzfristig kannst Du die Nodes ja hintereinanderschalten und ggf. einfach noch eine delay Node dazwischen machen - wenn Dir meine Lösung zu kompliziert ist.
