  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.4k
3.8k Beiträge 462 Kommentatoren 2.2m Aufrufe 410 Beobachtet
  • M Online
    M Online
    mick70
    schrieb am zuletzt editiert von mick70
    #2228
    Ich habe mit der Github-Version 0.3.6 seit 17.12.23 13:40 auch keine Aktualisierungen mehr, betrifft aber alle Datenpunkte. Die VW App funktioniert (e-Golf). Dafür gibt es Auffälligkeiten im Log (alle 20 Minuten):
    2023-12-19 07:41:17.368	info	Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
    2023-12-19 07:41:08.692	info	Server not available:{"error":{"message":"Upstream service responded with 502 Bad Gateway"}}
    2023-12-19 07:40:48.569	info	Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
    2023-12-19 07:40:39.993	info	Server not available:{"error":{"info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"retry":true,"group":2,"message":"Bad Gateway"}}
    2023-12-19 07:40:30.944	info	Server not available:{"error":{"retry":true,"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2}}
    2023-12-19 07:40:21.968	info	Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
    Bei Neustart des Adapter klappt das Login zwar:
    2023-12-19 08:02:03.677	info	Create vehicle WVWZZZAUZL*****
    2023-12-19 08:02:03.672	info	Found 1 vehicles
    2023-12-19 08:02:03.382	info	Minimum update interval is 15min for Wallcharging data, to prevent blocking
    2023-12-19 08:02:03.381	info	Wallcharging login was successfull
    2023-12-19 08:02:02.659	info	Login successful
    2023-12-19 08:02:02.652	info	Login in with id
    2023-12-19 08:02:02.651	info	Start Wallcharging login
    2023-12-19 08:02:02.650	info	History limit: 100, set to -1 to disable wallcharging login
    2023-12-19 08:02:02.649	info	ID login successfull
    Aber danach kommen sofort wieder die o.g. Serverfehler.
    Zur Fehlermeldung 4105 habe ich zwar hier im Thread schon was gefunden, kann aber keinen Zusammenhang zu meinen Einstellungen feststellen, zumal ich eigentlich nichts bewusst geändert habe. Ich musste zwischenzeitlich ein iobroker Backup einspielen (10h alt), aber das hat bisher auch noch nie Probleme mit dem Adapter verursacht.
    Tl;dr: Woran könnts liegen? Bin ich der einzige mit diesen Serverproblemen? habe ich beim Restore des Backups doch was falsch gemacht?
      BobBruni
      #2229
      Bei mir werden auch seit ca. 2 Tagen einige Werte nicht mehr aktualisiert z.B. Fuel Level Primary und Secundary Engine... Auch kann ich die Cliamtisation nicht mehr steuern. Das Log bleibt bei mir aber leer.
      • B BobBruni
        Sneak-L8
        schrieb am zuletzt editiert von Sneak-L8
        #2230
        @bobbruni Bei mir wurde seit gestern 9:09 Uhr im Adapter nichts mehr aktualisiert. In der App kommen aber noch die korrekten Werte (=> ID.3). Im Log steht nichts.
        mcBirneM B 2 Antworten Letzte Antwort
        • S Sneak-L8
          mcBirneM Offline
          mcBirneM Offline
          mcBirne
          #2231
          früher gabe es bei dem Adapter unter status den Punkt isCarLocked. bei mir gibt es unter Status eine Werte mehr. Ist der Wert jetzt an einer anderen Stelle zu finden? Ich konnte ihn bis jetzt nicht finden.
          • S Online
            S Online
            schmuh
            #2232
            Im EVCC Forum scheint der Fehler auch bekannt zu sein Link, vielleicht hilft das @tombox bei der Fehlersuche.
            • S Sneak-L8
              BobBruni
              #2233
              @sneak-l8 said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
              Bei mir ist es seit gestern 09.16 Uhr. Die App funktioniert. (VW Tiguan Hybrid)
              • B BobBruni
                BananaJoeB Online
                BananaJoeB Online
                BananaJoe
                #2234
                @bobbruni sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                Ich habe auch einen Tiguan Hybrid und bei funktioniert es, laut Log auch ohne Unterbrechungen.
                • M mick70
                  Maverick78
                  schrieb am zuletzt editiert von Maverick78
                  #2235
                  @mick70 Kann ich bestätigen bei mir ebenfalls seit Samstag
                  Betroffen bei mir sowohl der e-Golf wie auch der Audi e-tron.
                  2023-12-19 08:38:05.025  - info: vw-connect.0 (255684) starting. Version 0.3.6 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
                  2023-12-19 08:38:05.082  - info: vw-connect.1 (255691) starting. Version 0.3.6 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
                  2023-12-19 08:38:05.214  - info: vw-connect.0 (255684) Login in with id
                  2023-12-19 08:38:05.257  - info: vw-connect.1 (255691) Login in with audietron
                  2023-12-19 08:38:08.053  - info: vw-connect.0 (255684) ID login successfull
                  2023-12-19 08:38:08.055  - info: vw-connect.0 (255684) History limit: -1, set to -1 to disable wallcharging login
                  2023-12-19 08:38:08.056  - info: vw-connect.0 (255684) History limit is set to -1, no wall charging login
                  2023-12-19 08:38:08.059  - info: vw-connect.0 (255684) Login successful
                  2023-12-19 08:38:08.319  - info: vw-connect.1 (255691) Login successful
                  2023-12-19 08:38:10.704  - info: vw-connect.0 (255684) Found 1 vehicles
                  2023-12-19 08:38:10.714  - info: vw-connect.0 (255684) Create vehicle WVWZZZxxxxxxxxxxxxxxxxxxx
                  2023-12-19 08:38:18.593  - error: vw-connect.1 (255691) [{"message":"network timeout at: ","locations":[{"line":2,"column":3}],"path":["userVehicles"],"extensions":{"code":"INTERNAL_SERVER_ERROR","exception":{"message":"network timeout at: ","type":"request-timeout"}}}]
                  2023-12-19 08:38:18.595  - error: vw-connect.1 (255691) Get Vehicles Failed
                  2023-12-19 08:38:20.573  - info: vw-connect.0 (255684) Server not available:{"error":{"retry":true,"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2}}
                  2023-12-19 08:38:32.048  - info: vw-connect.0 (255684) Server not available:{"error":{"group":2,"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"retry":true}}
                  2023-12-19 08:38:40.378  - info: vw-connect.0 (255684) Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
                  • M Maverick78
                    jwedenig
                    #2236
                    Hi!
                    Ich habe seit 2 Tagen bei meinem ID4 auch keine Aktualisierungen mehr im Adapter und bei EVCC bekomme ich auch keinen Ladestand mehr angezeigt!
                    Das liegt sicher bei VW, oder?
                    • J jwedenig
                      Hi!
                      Maverick78
                      #2237
                      @jwedenig Da es bei EVCC einen fix gibt, scheint VAG was geändert zu haben.
                      • nik82N Offline
                        nik82N Offline
                        nik82
                        #2238
                        Das ist ja komisch, scheint aber nicht bei allen zu sein, weil bei mir funktioniert das noch wunderbar.
                        Cupra Formentor mit Type "Seat Cupra #2 Alternative".
                        • BananaJoeB BananaJoe
                          BobBruni
                          schrieb am zuletzt editiert von BobBruni
                          #2239
                          @bananajoe said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                          Verstehe ich richtig, dass du überhaupt keine Probleme hast?
                          • M Maverick78
                            jwedenig
                            #2240
                            @maverick78
                            sorry, kenn mich nicht wirklich gut aus, was muss ich jetzt machen und mit VAG meinst du VW?
                            • J jwedenig
                              @maverick78
                              Matis
                              schrieb am zuletzt editiert von Matis
                              #2241
                              Bekomme vom ID5 auf keinen Ladestand und keine Ladedauer mehr.
                              2023-12-19 10:10:14.562 - error: vw-connect.1 (29223) AxiosError: Request failed with status code 404
                              2023-12-19 10:10:14.581 - error: vw-connect.1 (29223) {"error":{"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112,"group":2,"retry":true}}
                              2023-12-19 10:10:14.853 - error: vw-connect.1 (29223) AxiosError: Request failed with status code 404
                              2023-12-19 10:10:14.854 - error: vw-connect.1 (29223) {"error":{"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112,"group":2,"retry":true}}
                              2023-12-19 10:10:15.108 - error: vw-connect.1 (29223) AxiosError: Request failed with status code 404
                              2023-12-19 10:10:15.111 - error: vw-connect.1 (29223) {"error":{"info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112,"group":2,"retry":true,"message":"Not Found"}}
                              2023-12-19 10:10:15.332 - error: vw-connect.1 (29223) AxiosError: Request failed with status code 404
                              2023-12-19 10:10:15.333 - error: vw-connect.1 (29223) {"error":{"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112,"group":2,"retry":true}}
                              • madingM mading
                                @tombox seit ein paar Tagen wird der aktuelle SoC nicht mehr aktualisiert, ich habe auch die neuste Version des Adapters von Github installiert. Alle anderen Daten stimmen (z.B. Auto fährt/ Adresse etc.)
                                Hier eine Debug Ausgabe beim Start des Adapters. Es gibt keine Fehler/ Warnings
                                Zeit
                                Nachricht
                                vw-connect.0
                                	2023-12-19 07:40:29.785	debug	No update lat ts 1702968024740 <-> lc 1702926256478, long ts 1702968024654 <-> lc 1702926256477
                                vw-connect.0
                                	2023-12-19 07:40:29.699	debug	No update lat ts 1702968024740 <-> lc 1702926256478, long ts 1702968024654 <-> lc 1702926256477
                                vw-connect.0
                                	2023-12-19 07:40:28.984	debug	{"place_id":60049425,"licence":"Data © OpenStreetMap contributors, ODbL 1.0. http://osm.org/copyright","osm_type":"way","osm_id":,"lat":".","lon":"9.","class":"building","type":"house","place_rank":30,"importance":0.00000999999999995449,"addresstype":"building","name":"","display_name":"h, Verwaltungsgemeinschaft Konstanz, Landkreis , Baden-Württemberg, , Deutschland","address":{"house_number":"1","road":"Im Garten","residential":"","village":"","municipality":"Verwaltungsgemeinschaft ","county":"Landkreis ","state":"Baden-Württemberg","ISO3166-2-lvl4":"DE-BW","postcode":"","country":"Deutschland","country_code":"de"},"boundingbox":[""]}
                                vw-connect.0
                                	2023-12-19 07:40:28.984	debug	reverse pos received
                                vw-connect.0
                                	2023-12-19 07:40:28.822	debug	reverse pos started
                                vw-connect.0
                                	2023-12-19 07:40:28.776	debug	No update lat ts 1702968024740 <-> lc 1702926256478, long ts 1702968024654 <-> lc 1702926256477
                                vw-connect.0
                                	2023-12-19 07:40:24.648	debug	Skip last trip check because of last check was less than 15min ago
                                vw-connect.0
                                	2023-12-19 07:40:24.648	debug	{"data":{"lon":975,"carCapturedTimestamp":"2023-12-18T19:03:27Z"}}
                                vw-connect.0
                                	2023-12-19 07:40:23.864	info	No last shorterm trips found. Please check if your car supports shortterm trips.
                                vw-connect.0
                                	2023-12-19 07:40:23.723	debug	{"data":{"lon":9.080263,"lat":47.746975,"carCapturedTimestamp":"2023-12-18T19:03:27Z"}}
                                vw-connect.0
                                	2023-12-19 07:40:23.429	debug	{}
                                vw-connect.0
                                	2023-12-19 07:40:23.427	debug	WVGZZZE2ZNxxx: set default homeregion
                                vw-connect.0
                                	2023-12-19 07:40:23.423	debug	{}
                                vw-connect.0
                                	2023-12-19 07:40:23.321	debug	getHomeRegion
                                vw-connect.0
                                	2023-12-19 07:40:23.318	info	Create vehicle WVGZZZE2ZNxxx
                                vw-connect.0
                                	2023-12-19 07:40:23.317	info	Found 1 vehicles
                                vw-connect.0
                                	2023-12-19 07:40:23.317	debug	{"data":[{"vin":"WVGZZZE2ZNP025704","role":"PRIMARY_USER","userRoleStatus":"ENABLED","enrollmentStatus":"COMPLETED","brandCode":"V","model":"ID.4","nickname":"ID4","capabilities":[{"id":"webApp","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"automation","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"batteryChargingCare","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"batteryColdWarning","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"batterySupport","userDisablingAllowed":false},{"id":"charging","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"chargingProfiles","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":false},{"id":"chargingStations","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"climatisation","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"climatisationTimers","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":false},{"id":"cubicNetwork","userDisablingAllowed":false},{"id":"dealerAppointment","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"destinations","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"fuelStatus","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":false},{"id":"ignition","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":false},{"id":"mapUpdate","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"measurements","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"onlineSpeech","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"parkingBrake","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"parkingInformation","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"parkingPosition","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"personalizationOnline","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"plugAndCharge","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"poiSearch","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"readiness","userDisablingAllowed":false},{"id":"routing","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"state","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"trafficInformation","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"vehicleHealth","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"vehicleHealthInspection","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"vehicleHealthWarnings","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"vehicleLights","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"vehicleWakeUpTrigger","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"webRadio","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true}],"images":{},"coUsers":[],"devicePlatform":"WCAR","tags":[]}]}
                                vw-connect.0
                                	2023-12-19 07:40:22.858	info	Login successful
                                vw-connect.0
                                	2023-12-19 07:40:22.857	info	History limit is set to -1, no wall charging login
                                vw-connect.0
                                	2023-12-19 07:40:22.857	info	History limit: -1, set to -1 to disable wallcharging login
                                vw-connect.0
                                	2023-12-19 07:40:22.857	info	ID login successfull
                                vw-connect.0
                                	2023-12-19 07:40:22.674	debug	Error: Invalid protocol: weconnect:
                                vw-connect.0
                                	2023-12-19 07:40:22.285	debug	{"date":"Tue, 19 Dec 2023 06:40:22 GMT","content-length":"0","connection":"close","apigw-requestid":"QLYhfgORFiAEJ6g=","x-content-type-options":"nosniff","x-xss-protection":"0","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","strict-transport-security":"max-age=31536000; includeSubDomains; preload","x-frame-options":"DENY","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=a24fba63-34b3-4d43-b181-942111e6bda8@apps_vw-dilab_com&relayState=2cb09e33a8c21b41b7516fb0b7e85f9654fbefe1&userId=aed7f161-5d05-4d8c-9e55-1d1df2ca88af&HMAC=1e6d1436d17c622efd394c8cada6b80a07f5d54251478f0a683300eb755aaba3","content-language":"en-US"}
                                vw-connect.0
                                	2023-12-19 07:40:22.285	debug	""
                                vw-connect.0
                                	2023-12-19 07:40:21.976	debug	emailPasswordForm2
                                vw-connect.0
                                	2023-12-19 07:40:21.702	debug	parseEmailForm
                                vw-connect.0
                                	2023-12-19 07:40:21.175	info	Login in with id
                                vw-connect.0
                                	2023-12-19 07:40:21.166	info	starting. Version 0.3.6 (non-npm: TA2k/ioBroker.vw-connect#a336d6b81048cf5cbdb5233d0a03862ce510a94b) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
                                vw-connect.0
                                	2023-12-19 07:40:21.029	debug	Plugin sentry Initialize Plugin (enabled=true)
                                vw-connect.0
                                	2023-12-19 07:40:21.005	debug	States connected to redis: 127.0.0.1:9000
                                vw-connect.0
                                	2023-12-19 07:40:20.933	debug	States create User PubSub Client
                                vw-connect.0
                                	2023-12-19 07:40:20.932	debug	States create System PubSub Client
                                vw-connect.0
                                	2023-12-19 07:40:20.916	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                vw-connect.0
                                	2023-12-19 07:40:20.885	debug	Objects connected to redis: 127.0.0.1:9001
                                vw-connect.0
                                	2023-12-19 07:40:20.882	debug	Objects client initialize lua scripts
                                vw-connect.0
                                	2023-12-19 07:40:20.833	debug	Objects create User PubSub Client
                                vw-connect.0
                                	2023-12-19 07:40:20.832	debug	Objects create System PubSub Client
                                vw-connect.0
                                	2023-12-19 07:40:20.831	debug	Objects client ready ... initialize now
                                vw-connect.0
                                	2023-12-19 07:40:20.804	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                vw-connect.0
                                	2023-12-19 07:40:17.734	info	terminating
                                vw-connect.0
                                	2023-12-19 07:40:17.234	debug	Plugin sentry destroyed
                                vw-connect.0
                                	2023-12-19 07:40:17.233	info	terminating
                                vw-connect.0
                                	2023-12-19 07:40:17.234	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                vw-connect.0
                                	2023-12-19 07:40:17.233	info	cleaned everything up...
                                vw-connect.0
                                	2023-12-19 07:40:17.233	info	Got terminate signal TERMINATE_YOURSELF
                                juggi1962
                                #2242
                                @mading sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                Ich habe das selbe Problem, seit mindestens Gestern keine Aktualisierung mehr.
                                Der Adapter ist grün und keine Fehler im Log.
                                • J juggi1962
                                  Maverick78
                                  #2243
                                  Habe gerade gesehen das im GitHub v0.4.0 liegt. Damit geht die Aktualisierung des SoC wieder.
                                  Allerdings bekomme ich weiterhin einige Fehler gemeldet:
                                  2023-12-19 15:28:38.455  - info: vw-connect.0 (288986) starting. Version 0.4.0 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
                                  2023-12-19 15:28:38.530  - info: vw-connect.1 (288992) starting. Version 0.4.0 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
                                  2023-12-19 15:28:38.637  - info: vw-connect.0 (288986) Login in with id
                                  2023-12-19 15:28:38.702  - info: vw-connect.1 (288992) Login in with audietron
                                  2023-12-19 15:28:41.259  - info: vw-connect.0 (288986) ID login successfull
                                  2023-12-19 15:28:41.262  - info: vw-connect.0 (288986) History limit: -1, set to -1 to disable wallcharging login
                                  2023-12-19 15:28:41.263  - info: vw-connect.0 (288986) History limit is set to -1, no wall charging login
                                  2023-12-19 15:28:41.266  - info: vw-connect.0 (288986) Login successful
                                  2023-12-19 15:28:41.764  - info: vw-connect.1 (288992) Login successful
                                  2023-12-19 15:28:42.350  - info: vw-connect.0 (288986) Found 1 vehicles
                                  2023-12-19 15:28:42.360  - info: vw-connect.0 (288986) Create vehicle WVWZZZxxxxxxxxxxxx
                                  2023-12-19 15:28:43.571  - info: vw-connect.1 (288992) Found 1 vehicles
                                  2023-12-19 15:28:47.113  - info: vw-connect.0 (288986) Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
                                  2023-12-19 15:28:47.357  - info: vw-connect.0 (288986) Server not available:{"error":{"code":4105,"group":2,"retry":true,"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support."}}
                                  2023-12-19 15:28:47.686  - info: vw-connect.0 (288986) Server not available:{"error":{"info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true,"message":"Bad Gateway"}}
                                  2023-12-19 15:28:48.226  - info: vw-connect.1 (288992) Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
                                  2023-12-19 15:28:48.655  - info: vw-connect.1 (288992) Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
                                  2023-12-19 15:28:48.860  - info: vw-connect.1 (288992) Server not available:{"error":{"message":"Bad Gateway","info":"Looks like your service has expired. Please update your service subscription.","code":4104,"group":4,"retry":false}}
                                  • M Maverick78
                                    Sneak-L8
                                    #2244
                                    @maverick78 Ja, mit der github-Version bekomem ich auch wieder Daten.
                                    Nachdem ich wie im Log empfohlen die Trip-Daten deativiert habe, kommen (fast) keine Fehler mehr. Nur dieser:
                                    @tombox Es wird gemeldet, dass mit der aktuellen Version kein compact mode mehr geht:
                                    host.raspberrypi.compactgroup2
                                    	2023-12-19 16:15:43.447	info	instance system.adapter.vw-connect.0 started with pid 8369
                                    	2023-12-19 16:15:43.386	error	undefined
                                    	2023-12-19 16:15:43.386	error	Cannot start vw-connect.0 in compact mode. Fallback to normal start: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vw-connect/node_modules/axios/index.js'
                                    • J Offline
                                      jwedenig
                                      #2245
                                      Version 0.4.0 funkt wieder
                                      • S Sneak-L8
                                        Maverick78
                                        #2246
                                        @sneak-l8 Danke, nach dem abschalten der Trip Daten ist die Fehlermeldung weg
                                        • M Online
                                          M Online
                                          mick70
                                          #2247
                                          0.4.2 auf Github verfügbar, jetzt gibts hier auch keine Server-Fehlermeldungen mehr. Vielen Dank dafür! Die Tripdaten ziehe ich auch weiterhin.
