  4. Test Adapter telegram-menu v.1.6.x
    6.3k
1.9k Beiträge 65 Kommentatoren 987.3k Aufrufe 63 Beobachtet
  • liv-in-skyL liv-in-sky
    @michael-roling
    funktioniert nicht:
    {json;Datum:"Datum",VerbrauchMonat:"VerbrauchMonat";Monatlich;TextTable}
    funktioniert
    {json;Datum:"Datum",VerbrauchMonat:"VerbrauchMonat";Monatlich;}
    json:
    [{"Datum":"September 2022","VerbrauchMonat":223.9,"AbgelesenerWert":"28358.5","Timestamp":1664775852614,"Preis":87.32},{"Datum":"Oktober 2022","VerbrauchMonat":224.3,"AbgelesenerWert":"28582.8","Timestamp":1667300421755,"Preis":87.48},{"Datum":"November 2022","VerbrauchMonat":261.9,"AbgelesenerWert":"28844.7","Timestamp":1669903566000,"Preis":102.14},{"Datum":"Dezember 2022","VerbrauchMonat":261.9,"AbgelesenerWert":"29106.6","Timestamp":1672668552453,"Preis":102.14},{"Datum":"Januar 2023","VerbrauchMonat":280.3,"AbgelesenerWert":"29386.9","Timestamp":1675421471419,"Preis":109.32},{"Datum":"Februar 2023","VerbrauchMonat":237.1,"AbgelesenerWert":"29624","Timestamp":1677744743862,"Preis":92.47},{"Datum":"März 2023","VerbrauchMonat":251.5,"AbgelesenerWert":"29875.5","Timestamp":1680346864191,"Preis":98.09},{"Datum":"April 2023","VerbrauchMonat":236.5,"AbgelesenerWert":"30112","Timestamp":1682947332764,"Preis":92.24},{"Datum":"Mai 2023","VerbrauchMonat":211.2,"AbgelesenerWert":"30323.2","Timestamp":1685626973080,"Preis":82.37},{"Datum":"Juni 2023","VerbrauchMonat":180.4,"AbgelesenerWert":"30503.6","Timestamp":1688269740617,"Preis":70.36},{"Datum":"Juli 2023","VerbrauchMonat":190.4,"AbgelesenerWert":"30694","Timestamp":1690876602270,"Preis":74.26},{"Datum":"August 2023","VerbrauchMonat":256,"AbgelesenerWert":"30950","Timestamp":1693553124358,"Preis":99.84},{"Datum":"September 2023","VerbrauchMonat":216.6,"AbgelesenerWert":"31166.6","Timestamp":1696138938435,"Preis":84.47},{"Datum":"Oktober 2023","VerbrauchMonat":228,"AbgelesenerWert":"31394.6","Timestamp":1698862602796,"Preis":88.92},{"Datum":"November 2023","VerbrauchMonat":246.4,"AbgelesenerWert":"31641","Timestamp":1701533149450,"Preis":96.1}]
    Michael RolingM Offline
    Michael Roling
    #1048
    @liv-in-sky Vielen Dank für deine Arbeit
    • Michael RolingM Michael Roling
      liv-in-skyL Offline
      liv-in-skyL Offline
      #1049
      @michael-roling gerne - hast du das format auch in den helper texten angeglichen ?
      Michael RolingM 1 Antwort Letzte Antwort
        Michael Roling
        schrieb am zuletzt editiert von Michael Roling
        #1050
        @liv-in-sky das steht doch da so drin
        text: "{json;[value-1-inJSON:NameTH-Col1,value-2-inJSON:NameTH-Col1];Header;}",
        info: "Creats a table from a JSON as Inline-keyboard. The first value is one key of the JSON ,behind it is the name of the column. You can use more than two values.The header must be filled in.",
        text: "{json;[value-1-inJSON:NameTH-Col1,value-2-inJSON:NameTH-Col1];Header;TextTable;}",
        info: "!!! To use it, parseMode must not be active !!! Creats a table from a JSON as Text-Table. The first value is one key of the JSON ,behind it is the name of the column. You can use more than two values.The header must be filled in. Don´t change TextTable.",
          liv-in-skyL Offline
          liv-in-skyL Offline
          #1051
          @michael-roling alles gut - habe irgendwo wurm im lesen gehabt - paßt so und funktioniert jetzt auch
            Michael Roling
            #1052
            @liv-in-sky ich gucke gerade das man einfach das deutsche in englische übersetzen kann ohne selbst hand an zu legen
              liv-in-skyL Offline
              liv-in-skyL Offline
              #1053
              @michael-roling das wäre cool
                Michael Roling
                #1054
                @liv-in-sky das funktioniert jetzt auch soweit
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #1055
                  @michael-roling
                  bedeutet: wenn ich in deutsch was ändere/hinzufüge muss ich nicht mehr an dem englischen text arbeiten - das geht dann automatisch
                    @michael-roling
                    Michael Roling
                    #1056
                    @liv-in-sky ja genau, man muss nur aufpassen das man evtl einen <br> vor und hinter jedes Bild macht, weil sonst beim translate etwas dumm aussieht, aber das kann man schnell anpassen. Theoretisch kann man auch direkt noch in andere Sprachen übersetzen lassen.
                    Und was auch nicht so schön ist , ist wenn du etwas abc. ABC wird das nach dem übersetzen zu abc.ABC, also das Leerzeichen wird entfernt, warum auch immer
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #1057
                      @michael-roling
                      Macht es viel einfacher
                      • B BobBruni
                        @michael-roling Läuft ;-)
                        Michael Roling
                        #1058
                        @bobbruni ich lade das jetzt mal hoch, ich weiss absolut nicht ob das dann funktioniert, ich habe kein echarts, probiere einfach mal
                        Ne da ist auf jeden Fall noch ein Fehler drin
                        Sollte alles gehen
                          Sollte alles gehen
                          BobBruni
                          schrieb am zuletzt editiert von BobBruni
                          #1059
                          @michael-roling
                          Hi Michael, kann mit "Search-ID" kein Preset auswählen, da mir keines anzeigt wird. Er zeigt mir nur den Echarts Ordner samt Unterordnern an - alle Leer. Wenn ich das Chart "echarts.0.Ertrag miniPV" händisch einfüge, bekomme ich nur den Text "echarts-temp-photo.jpg" zurück.
                          Besten Dank!
                          • B BobBruni
                            @michael-roling
                            Besten Dank!
                            Michael Roling
                            #1060
                            @bobbruni ja genau ich kann unter searchID auch noch kein preset auswählen. aber schicken kann ich die charts. Du musst auch in den Einstellungen einen pfad angeben wo die dateien gespeichert werden, dieser pfad muss volle schreibrechte haben
                            Bei mir läuft es jetzt einwandfrei
                              BobBruni
                              #1061
                              @michael-roling said in Test Adapter telegram-menu v.0.9.x:
                              Perfekt, es läuft! Der Pfad war noch falsch!
                              Top Feature, vielen Dank fürs einbauen 👍
                              • B BobBruni
                                Michael Roling
                                #1062
                                @liv-in-sky man kann ein Leerzeichen erzwingen indem man &nbsp; eingibt, dann sieht es auch sauber aus. Ich passe da schon mal was an
                                  Rene55R Offline
                                  Rene55R Offline
                                  Rene55
                                  schrieb am zuletzt editiert von Rene55
                                  #1063
                                  @michael-roling Ich gehe davon aus, dass du für das Memory-Problem noch keine Lösung hast. Ich habe eben die 1.5.0 versucht einzuspielen. Vermutlich beim Erzeugen der 'index.js.map' geht es gehörig nach oben.
                                  Nach Reboot der lxc sehe ich dann in 'Instanzen/Einstellung' nur noch:
                                  Dann habe ich diese Version im Expertenmodus noch einmal installiert, das ging dann ratz-fatz.
                                  Vielleicht hilft die Beobachtung in Verbindung mit der Verwendung von react.
                                  • Rene55R Rene55
                                    Michael Roling
                                    #1064
                                    @rene55 dazu gibt es ein Issue im js-Controller. Da habe ich keinen Einfluss drauf
                                    Okay. Werde ich selbst mal ausprobieren
                                      Rene55R Offline
                                      Rene55R Offline
                                      Rene55
                                      #1065
                                      @michael-roling Ja ist mir bekannt. Haben denn die anderen Mitstreiter soviel mehr RAM, dass das bei denen nicht ins Gewicht fällt?
                                      Übrigens die Grafik oben war von der CPU-Auslastung - Memory und Swap am Anschlag.
                                      • Rene55R Rene55
                                        Michael Roling
                                        #1066
                                        @rene55 kann sein. Ich selbst habe 32 Gig ram für iob glaube ich max 16
                                          Rene55R Offline
                                          Rene55R Offline
                                          Rene55
                                          #1067
                                          @michael-roling Ich habe gerade mal die neue Funktion 'Events' testen wollen. Dazu habe ich mal die Zeile (blauäugig) so angelegt.
                                          Adapter startet neu aber nix passiert, wenn ich den ID-Datenpunkt ändere. Ist die Bedingung falsch oder arbeitet der nur auf numerische Werte?
