  4. Test Adapter OctoPrint
adapter entwicklungadatper updatesdevelopertesten
461 Beiträge 49 Kommentatoren 146.5k Aufrufe 44 Beobachtet
  • OreiderO Oreider
    @haus-automatisierung
    Heute hab ich noch eine zweite Meldung von Octoprint bekommen kurz bevor ich das System herunterfahren wollte:
    2023-12-17 08:45:08.922 - info: daswetter.0 (398463) starting. Version 3.1.11 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.0, js-controller: 5.0.17
    2023-12-17 08:45:27.958 - info: linux-control.0 (138367) getting data from RaspiMirror (192.168.188.88:22)
    2023-12-17 08:45:31.039 - info: linux-control.0 (138367) [getConnection] Host 'RaspiMirror' (192.168.188.88:22) seems not to be online
    2023-12-17 08:45:43.890 - info: daswetter.0 (398463) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-12-17 08:45:44.406 - info: daswetter.0 (398463) cleaned everything up...
    2023-12-17 08:45:44.433 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-17 08:47:00.611 - info: octoprint.0 (138340) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
    2023-12-17 08:47:28.762 - info: admin.0 (136948) ==> Connected system.user.admin from ::ffff:192.168.188.59
    2023-12-17 08:48:23.061 - info: admin.0 (136948) ==> Connected system.user.admin from ::ffff:192.168.188.59
    2023-12-17 08:48:52.257 - info: admin.0 (136948) <== Disconnect system.user.admin from ::ffff:192.168.188.59 javascript
    2023-12-17 08:48:58.327 - error: octoprint.0 (138340) system command not allowed: core/shutdown. Choose one of:
    2023-12-17 08:50:00.031 - info: host.iobroker instance system.adapter.netatmo-crawler.0 started with pid 398649
    2023-12-17 08:50:02.709 - info: netatmo-crawler.0 (398649) Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
    2023-12-17 08:50:03.050 - info: netatmo-crawler.0 (398649) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.19.0, js-controller: 5.0.17
    2023-12-17 08:50:03.148 - info: netatmo-crawler.0 (398649) Getting data for stationid:70:ee:50:27:59:8a
    2023-12-17 08:50:04.462 - info: netatmo-crawler.0 (398649) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2023-12-17 08:50:05.008 - info: host.iobroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    Am Octoprint selbst hab ich keine Befehle eingegeben... Ging aber bis vor kurzem auch so. Das unten war standardmäßig drin:
    haus-automatisierungH Offline
    #435
    @oreider sagte in Test Adapter OctoPrint:
    Welche OctoPrint-Version ist denn installiert? Hast Du ein Update gemacht? Mit welcher Version ging es denn noch? Bisschen mehr Input wäre hilfreich :)
    📚 Meine Dokumentation
    OreiderO 1 Antwort Letzte Antwort
      OreiderO Offline
      OreiderO Offline
      Oreider
      #436
      Leider ist das schwer zu sagen ab wann es noch funktioniert hat. Ich lasse mittels Sprachbefehl den Drucker (octopi) herunterfahren und danach eine Steckdose abschalten. Hab nur durch Zufall gesehen dass octoprint nach dem Befehl noch erreichbar war und dann ins log gesehen.
      Hab die Version 1.9.3 und kann nicht sagen obs an der neuen Version liegt.
      • OreiderO Offline
        OreiderO Offline
        Oreider
        #437
        Die Abfrage von Werten klappt und auch ändern von Temperaturen funktioniert.
        Nur der Befehl zum herunterfahren will nicht mehr.
        • OreiderO Oreider
          #438
          @oreider Ohne Debug-Log kann ich auch nur raten, …
            OreiderO Offline
            OreiderO Offline
            Oreider
            #439
            Hallo nochmal. Sorry kannte das Debug Log nicht.
            Habs jetzt aktiviert und komischerweise klappte jetzt der Shutdown in drei von drei Versuchen...
            Hier das Log mit den erfolgreich ausgeführten Befehlen. Evtl. kannst du daraus etwas schließen...
            2023-12-17 10:01:03.341 - info: daswetter.0 (402035) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2023-12-17 10:01:03.856 - info: daswetter.0 (402035) cleaned everything up...
            2023-12-17 10:01:03.877 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-12-17 10:01:09.879 - debug: octoprint.0 (401712) refreshState: started from "timeout (operational)"
            2023-12-17 10:01:09.879 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:01:09.879 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:01:09.885 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (operational): id 123454 - seconds: 30
            2023-12-17 10:01:09.936 - debug: octoprint.0 (401712) received 200 response from /api/version with content: {"api":"0.1","server":"1.9.3","text":"OctoPrint 1.9.3"}
            2023-12-17 10:01:09.936 - debug: octoprint.0 (401712) connected to OctoPrint API - online! - status: 200
            2023-12-17 10:01:09.937 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:01:09.937 - debug: octoprint.0 (401712) sending "get" request to "/api/connection" without data
            2023-12-17 10:01:09.939 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:01:09.940 - debug: octoprint.0 (401712) sending "get" request to "/api/printer" without data
            2023-12-17 10:01:10.004 - debug: octoprint.0 (401712) received 200 response from /api/printer with content: {"sd":{"ready":false},"state":{"error":"","flags":{"cancelling":false,"closedOrError":false,"error":false,"finishing":false,"operational":true,"paused":false,"pausing":false,"printing":false,"ready":true,"resuming":false,"sdReady":false},"text":"Operational"},"temperature":{"bed":{"actual":23.46,"offset":0,"target":0},"tool0":{"actual":23.77,"offset":0,"target":0}}}
            2023-12-17 10:01:10.033 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:01:10.033 - debug: octoprint.0 (401712) sending "get" request to "/api/job" without data
            2023-12-17 10:01:10.176 - debug: octoprint.0 (401712) received 200 response from /api/connection with content: {"current":{"baudrate":115200,"port":"/dev/ttyACM0","printerProfile":"_default","state":"Operational"},"options":{"baudratePreference":null,"baudrates":[250000,230400,115200,57600,38400,19200,9600],"portPreference":null,"ports":["/dev/ttyACM0"],"printerProfilePreference":"_default","printerProfiles":[{"id":"_default","name":"Sindewinder X2"}]}}
            2023-12-17 10:01:10.177 - debug: octoprint.0 (401712) updatePrinterStatus from: "Operational" -> printerOperational: true, printerPrinting: false
            2023-12-17 10:01:10.177 - debug: octoprint.0 (401712) [refreshFiles] started
            2023-12-17 10:01:10.225 - debug: octoprint.0 (401712) received 200 response from /api/job with content: {"job":{"estimatedPrintTime":null,"filament":{"length":null,"volume":null},"file":{"date":null,"name":null,"origin":null,"path":null,"size":null},"lastPrintTime":null,"user":null},"progress":{"completion":null,"filepos":null,"printTime":null,"printTimeLeft":null,"printTimeOrigin":null},"state":"Operational"}
            2023-12-17 10:01:10.288 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:01:10.289 - debug: octoprint.0 (401712) sending "get" request to "/api/files?recursive=true" without data
            2023-12-17 10:01:10.341 - debug: octoprint.0 (401712) received 200 response from /api/files?recursive=true with content: {"files":[],"free":3592359936,"total":7516811264}
            2023-12-17 10:01:10.341 - debug: octoprint.0 (401712) [refreshFiles] found 0 files
            2023-12-17 10:01:10.611 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_USB_SD_MicroSD_Card_Holder_v2_2"
            2023-12-17 10:01:10.908 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_Werra_King_steck"
            2023-12-17 10:01:11.086 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_TOP"
            2023-12-17 10:01:11.266 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_VASE"
            2023-12-17 10:01:11.461 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_X1_frontcammount"
            2023-12-17 10:01:11.655 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_20mm_cube_soft_edges"
            2023-12-17 10:01:11.875 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_6b34cc48d6759a20ffa9e5c8a10cead3"
            2023-12-17 10:01:12.103 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_V3_0_Wera_AS_55_Slotted"
            2023-12-17 10:01:12.298 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_Switch_holder"
            2023-12-17 10:01:12.477 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_Wand"
            2023-12-17 10:01:12.681 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_TS100_Bace"
            2023-12-17 10:01:12.886 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_TS100_Mount"
            2023-12-17 10:01:13.061 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_thin_bit"
            2023-12-17 10:01:13.229 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_WallBase"
            2023-12-17 10:01:13.432 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_Ulanzi_wall_mount"
            2023-12-17 10:01:13.691 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_Top_H20_Pi_Hole_SM"
            2023-12-17 10:01:13.914 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_Top_Pi_Hole_SM"
            2023-12-17 10:01:14.107 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_xbox_controller_stand_for_2"
            2023-12-17 10:01:14.252 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_wiimote_holder_4"
            2023-12-17 10:01:14.402 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_VESA_Wallmount"
            2023-12-17 10:01:14.554 - debug: octoprint.0 (401712) [refreshFiles] file deleted: "files.local_ASX1_3DBenchy"
            2023-12-17 10:01:14.604 - info: linux-control.0 (138367) getting data from RaspiMirror (192.168.188.88:22)
            2023-12-17 10:01:17.663 - info: linux-control.0 (138367) [getConnection] Host 'RaspiMirror' (192.168.188.88:22) seems not to be online
            2023-12-17 10:01:30.876 - debug: octoprint.0 (401712) sending system command: core/shutdown
            2023-12-17 10:01:30.877 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:01:30.877 - debug: octoprint.0 (401712) sending "post" request to "/api/system/commands/core/shutdown" with data: {}
            2023-12-17 10:01:30.987 - debug: octoprint.0 (401712) received 204 response from /api/system/commands/core/shutdown with content: ""
            2023-12-17 10:01:39.885 - debug: octoprint.0 (401712) refreshState: started from "timeout (operational)"
            2023-12-17 10:01:39.885 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:01:39.886 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:01:39.890 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (operational): id 126961 - seconds: 30
            2023-12-17 10:01:41.893 - info: octoprint.0 (401712) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
            2023-12-17 10:01:41.895 - debug: octoprint.0 (401712) (version) received error - API is now offline: {"message":"timeout of 2000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 2000ms exceeded\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/adapters/http.js:643:16)\n at RedirectableRequest.emit (node:events:517:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at Timeout. (/opt/iobroker/node_modules/follow-redirects/index.js:169:12)\n at listOnTimeout (node:internal/timers:569:17)\n at processTimers (node:internal/timers:512:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Api-Key":"2902964A0F7B42F69AD1017FB5B1AE38","User-Agent":"axios/1.6.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","data":null,"baseURL":"http://192.168.188.47:80","url":"/api/version","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ECONNABORTED","status":null}
            2023-12-17 10:01:41.896 - debug: octoprint.0 (401712) API is offline
            2023-12-17 10:02:09.890 - debug: octoprint.0 (401712) refreshState: started from "timeout (operational)"
            2023-12-17 10:02:09.890 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:02:09.891 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:02:09.893 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (API not connected): id 127159 - seconds: 10
            2023-12-17 10:02:11.896 - debug: octoprint.0 (401712) timeout of 2000ms exceeded
            2023-12-17 10:02:11.898 - debug: octoprint.0 (401712) (version) received error - API is now offline: {"message":"timeout of 2000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 2000ms exceeded\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/adapters/http.js:643:16)\n at RedirectableRequest.emit (node:events:517:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at Timeout. (/opt/iobroker/node_modules/follow-redirects/index.js:169:12)\n at listOnTimeout (node:internal/timers:569:17)\n at processTimers (node:internal/timers:512:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Api-Key":"2902964A0F7B42F69AD1017FB5B1AE38","User-Agent":"axios/1.6.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","data":null,"baseURL":"http://192.168.188.47:80","url":"/api/version","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ECONNABORTED","status":null}
            2023-12-17 10:02:11.898 - debug: octoprint.0 (401712) API is offline
            2023-12-17 10:02:19.895 - debug: octoprint.0 (401712) refreshState: started from "timeout (API not connected)"
            2023-12-17 10:02:19.895 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:02:19.896 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:02:19.898 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (API not connected): id 127234 - seconds: 10
            2023-12-17 10:02:21.901 - debug: octoprint.0 (401712) timeout of 2000ms exceeded
            2023-12-17 10:02:21.903 - debug: octoprint.0 (401712) (version) received error - API is now offline: {"message":"timeout of 2000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 2000ms exceeded\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/adapters/http.js:643:16)\n at RedirectableRequest.emit (node:events:517:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at Timeout. (/opt/iobroker/node_modules/follow-redirects/index.js:169:12)\n at listOnTimeout (node:internal/timers:569:17)\n at processTimers (node:internal/timers:512:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Api-Key":"2902964A0F7B42F69AD1017FB5B1AE38","User-Agent":"axios/1.6.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","data":null,"baseURL":"http://192.168.188.47:80","url":"/api/version","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ECONNABORTED","status":null}
            2023-12-17 10:02:21.904 - debug: octoprint.0 (401712) API is offline
            2023-12-17 10:02:29.898 - debug: octoprint.0 (401712) refreshState: started from "timeout (API not connected)"
            2023-12-17 10:02:29.899 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:02:29.899 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:02:29.902 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (API not connected): id 127350 - seconds: 10
            2023-12-17 10:02:31.904 - debug: octoprint.0 (401712) timeout of 2000ms exceeded
            2023-12-17 10:02:31.906 - debug: octoprint.0 (401712) (version) received error - API is now offline: {"message":"timeout of 2000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 2000ms exceeded\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/adapters/http.js:643:16)\n at RedirectableRequest.emit (node:events:517:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at Timeout. (/opt/iobroker/node_modules/follow-redirects/index.js:169:12)\n at listOnTimeout (node:internal/timers:569:17)\n at processTimers (node:internal/timers:512:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Api-Key":"2902964A0F7B42F69AD1017FB5B1AE38","User-Agent":"axios/1.6.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","data":null,"baseURL":"http://192.168.188.47:80","url":"/api/version","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ECONNABORTED","status":null}
            2023-12-17 10:02:31.906 - debug: octoprint.0 (401712) API is offline
            2023-12-17 10:02:39.903 - debug: octoprint.0 (401712) refreshState: started from "timeout (API not connected)"
            2023-12-17 10:02:39.903 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:02:39.904 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:02:39.906 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (API not connected): id 127464 - seconds: 10
            2023-12-17 10:02:41.909 - debug: octoprint.0 (401712) timeout of 2000ms exceeded
            2023-12-17 10:02:41.911 - debug: octoprint.0 (401712) (version) received error - API is now offline: {"message":"timeout of 2000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 2000ms exceeded\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/adapters/http.js:643:16)\n at RedirectableRequest.emit (node:events:517:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at Timeout. (/opt/iobroker/node_modules/follow-redirects/index.js:169:12)\n at listOnTimeout (node:internal/timers:569:17)\n at processTimers (node:internal/timers:512:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Api-Key":"2902964A0F7B42F69AD1017FB5B1AE38","User-Agent":"axios/1.6.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","data":null,"baseURL":"http://192.168.188.47:80","url":"/api/version","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ECONNABORTED","status":null}
            2023-12-17 10:02:41.911 - debug: octoprint.0 (401712) API is offline
            2023-12-17 10:02:49.908 - debug: octoprint.0 (401712) refreshState: started from "timeout (API not connected)"
            2023-12-17 10:02:49.908 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:02:49.908 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:02:49.911 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (API not connected): id 127539 - seconds: 10
            2023-12-17 10:02:49.916 - info: octoprint.0 (401712) error ECONNREFUSED from /api/version: connect ECONNREFUSED 192.168.188.47:80
            2023-12-17 10:02:49.918 - debug: octoprint.0 (401712) (version) received error - API is now offline: {"message":"connect ECONNREFUSED 192.168.188.47:80","name":"Error","stack":"Error: connect ECONNREFUSED 192.168.188.47:80\n at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/core/AxiosError.js:89:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/adapters/http.js:606:25)\n at RedirectableRequest.emit (node:events:529:35)\n at RedirectableRequest.emit (node:domain:489:12)\n at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)\n at ClientRequest.emit (node:events:529:35)\n at ClientRequest.emit (node:domain:489:12)\n at Socket.socketErrorListener (node:_http_client:501:9)\n at Socket.emit (node:events:517:28)\n at Socket.emit (node:domain:489:12)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Api-Key":"2902964A0F7B42F69AD1017FB5B1AE38","User-Agent":"axios/1.6.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","data":null,"baseURL":"http://192.168.188.47:80","url":"/api/version","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ECONNREFUSED","status":null}
            2023-12-17 10:02:49.919 - debug: octoprint.0 (401712) API is offline
            2023-12-17 10:02:59.911 - debug: octoprint.0 (401712) refreshState: started from "timeout (API not connected)"
            2023-12-17 10:02:59.912 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:02:59.912 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:02:59.915 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (API not connected): id 127651 - seconds: 10
            2023-12-17 10:03:01.918 - info: octoprint.0 (401712) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
            2023-12-17 10:03:01.919 - debug: octoprint.0 (401712) (version) received error - API is now offline: {"message":"timeout of 2000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 2000ms exceeded\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/adapters/http.js:643:16)\n at RedirectableRequest.emit (node:events:517:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at Timeout. (/opt/iobroker/node_modules/follow-redirects/index.js:169:12)\n at listOnTimeout (node:internal/timers:569:17)\n at processTimers (node:internal/timers:512:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Api-Key":"2902964A0F7B42F69AD1017FB5B1AE38","User-Agent":"axios/1.6.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","data":null,"baseURL":"http://192.168.188.47:80","url":"/api/version","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ECONNABORTED","status":null}
            2023-12-17 10:03:01.920 - debug: octoprint.0 (401712) API is offline
            2023-12-17 10:03:09.916 - debug: octoprint.0 (401712) refreshState: started from "timeout (API not connected)"
            2023-12-17 10:03:09.916 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:09.916 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:03:09.919 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (API not connected): id 127765 - seconds: 10
            2023-12-17 10:03:09.947 - warn: octoprint.0 (401712) received 502 response from /api/version with content: "
            502 Bad Gateway
            \nThe server returned an invalid or incomplete response.\n\n"
            2023-12-17 10:03:09.948 - debug: octoprint.0 (401712) (version) received error - API is now offline: {"message":"Request failed with status code 502","name":"AxiosError","stack":"AxiosError: Request failed with status code 502\n at settle (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/core/settle.js:19:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/adapters/http.js:585:11)\n at IncomingMessage.emit (node:events:529:35)\n at IncomingMessage.emit (node:domain:489:12)\n at endReadableNT (node:internal/streams/readable:1400:12)\n at processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Api-Key":"2902964A0F7B42F69AD1017FB5B1AE38","User-Agent":"axios/1.6.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","data":null,"baseURL":"http://192.168.188.47:80","url":"/api/version","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_RESPONSE","status":502}
            2023-12-17 10:03:09.949 - debug: octoprint.0 (401712) API is offline
            2023-12-17 10:03:19.920 - debug: octoprint.0 (401712) refreshState: started from "timeout (API not connected)"
            2023-12-17 10:03:19.920 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:19.921 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:03:19.925 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (API not connected): id 127852 - seconds: 10
            2023-12-17 10:03:20.087 - debug: octoprint.0 (401712) received 200 response from /api/version with content: {"api":"0.1","server":"1.9.3","text":"OctoPrint 1.9.3"}
            2023-12-17 10:03:20.088 - debug: octoprint.0 (401712) connected to OctoPrint API - online! - status: 200
            2023-12-17 10:03:20.089 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:20.090 - debug: octoprint.0 (401712) sending "get" request to "/api/connection" without data
            2023-12-17 10:03:20.094 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:20.094 - debug: octoprint.0 (401712) sending "get" request to "/api/printer" without data
            2023-12-17 10:03:20.269 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:20.270 - debug: octoprint.0 (401712) sending "get" request to "/api/job" without data
            2023-12-17 10:03:20.762 - debug: octoprint.0 (401712) received 200 response from /api/connection with content: {"current":{"baudrate":115200,"port":"/dev/ttyACM0","printerProfile":"_default","state":"Operational"},"options":{"baudratePreference":null,"baudrates":[250000,230400,115200,57600,38400,19200,9600],"portPreference":null,"ports":["/dev/ttyACM0"],"printerProfilePreference":"_default","printerProfiles":[{"id":"_default","name":"Sindewinder X2"}]}}
            2023-12-17 10:03:20.762 - debug: octoprint.0 (401712) updatePrinterStatus from: "Operational" -> printerOperational: true, printerPrinting: false
            2023-12-17 10:03:20.763 - debug: octoprint.0 (401712) [refreshFiles] started
            2023-12-17 10:03:20.852 - debug: octoprint.0 (401712) received 200 response from /api/printer with content: {"sd":{"ready":false},"state":{"error":"","flags":{"cancelling":false,"closedOrError":false,"error":false,"finishing":false,"operational":true,"paused":false,"pausing":false,"printing":false,"ready":true,"resuming":false,"sdReady":false},"text":"Operational"},"temperature":{"bed":{"actual":23.3,"offset":0,"target":0},"tool0":{"actual":23.63,"offset":0,"target":0}}}
            2023-12-17 10:03:20.872 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:20.873 - debug: octoprint.0 (401712) sending "get" request to "/api/files?recursive=true" without data
            2023-12-17 10:03:20.934 - debug: octoprint.0 (401712) received 200 response from /api/job with content: {"job":{"estimatedPrintTime":null,"filament":{"length":null,"volume":null},"file":{"date":null,"name":null,"origin":null,"path":null,"size":null},"lastPrintTime":null,"user":null},"progress":{"completion":null,"filepos":null,"printTime":null,"printTimeLeft":null,"printTimeOrigin":null},"state":"Operational"}
            2023-12-17 10:03:21.106 - debug: octoprint.0 (401712) received 200 response from /api/files?recursive=true with content: {"files":[],"free":3587260416,"total":7516811264}
            2023-12-17 10:03:21.106 - debug: octoprint.0 (401712) [refreshFiles] found 0 files
            2023-12-17 10:03:29.927 - debug: octoprint.0 (401712) refreshState: started from "timeout (API not connected)"
            2023-12-17 10:03:29.927 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:29.928 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:03:29.930 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (operational): id 128500 - seconds: 30
            2023-12-17 10:03:29.977 - debug: octoprint.0 (401712) received 200 response from /api/version with content: {"api":"0.1","server":"1.9.3","text":"OctoPrint 1.9.3"}
            2023-12-17 10:03:29.977 - debug: octoprint.0 (401712) connected to OctoPrint API - online! - status: 200
            2023-12-17 10:03:29.978 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:29.978 - debug: octoprint.0 (401712) sending "get" request to "/api/connection" without data
            2023-12-17 10:03:29.980 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:29.981 - debug: octoprint.0 (401712) sending "get" request to "/api/printer" without data
            2023-12-17 10:03:30.067 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:30.067 - debug: octoprint.0 (401712) sending "get" request to "/api/job" without data
            2023-12-17 10:03:30.180 - debug: octoprint.0 (401712) received 200 response from /api/connection with content: {"current":{"baudrate":115200,"port":"/dev/ttyACM0","printerProfile":"_default","state":"Operational"},"options":{"baudratePreference":null,"baudrates":[250000,230400,115200,57600,38400,19200,9600],"portPreference":null,"ports":["/dev/ttyACM0"],"printerProfilePreference":"_default","printerProfiles":[{"id":"_default","name":"Sindewinder X2"}]}}
            2023-12-17 10:03:30.180 - debug: octoprint.0 (401712) updatePrinterStatus from: "Operational" -> printerOperational: true, printerPrinting: false
            2023-12-17 10:03:30.181 - debug: octoprint.0 (401712) [refreshFiles] started
            2023-12-17 10:03:30.220 - debug: octoprint.0 (401712) received 200 response from /api/printer with content: {"sd":{"ready":false},"state":{"error":"","flags":{"cancelling":false,"closedOrError":false,"error":false,"finishing":false,"operational":true,"paused":false,"pausing":false,"printing":false,"ready":true,"resuming":false,"sdReady":false},"text":"Operational"},"temperature":{"bed":{"actual":23.42,"offset":0,"target":0},"tool0":{"actual":23.61,"offset":0,"target":0}}}
            2023-12-17 10:03:30.263 - debug: octoprint.0 (401712) received 200 response from /api/job with content: {"job":{"estimatedPrintTime":null,"filament":{"length":null,"volume":null},"file":{"date":null,"name":null,"origin":null,"path":null,"size":null},"lastPrintTime":null,"user":null},"progress":{"completion":null,"filepos":null,"printTime":null,"printTimeLeft":null,"printTimeOrigin":null},"state":"Operational"}
            2023-12-17 10:03:30.294 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:30.295 - debug: octoprint.0 (401712) sending "get" request to "/api/files?recursive=true" without data
            2023-12-17 10:03:30.354 - debug: octoprint.0 (401712) received 200 response from /api/files?recursive=true with content: {"files":[],"free":3587264512,"total":7516811264}
            2023-12-17 10:03:30.355 - debug: octoprint.0 (401712) [refreshFiles] found 0 files
            2023-12-17 10:03:59.931 - debug: octoprint.0 (401712) refreshState: started from "timeout (operational)"
            2023-12-17 10:03:59.932 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:59.932 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:03:59.935 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (operational): id 129169 - seconds: 30
            2023-12-17 10:03:59.991 - debug: octoprint.0 (401712) received 200 response from /api/version with content: {"api":"0.1","server":"1.9.3","text":"OctoPrint 1.9.3"}
            2023-12-17 10:03:59.991 - debug: octoprint.0 (401712) connected to OctoPrint API - online! - status: 200
            2023-12-17 10:03:59.992 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:59.992 - debug: octoprint.0 (401712) sending "get" request to "/api/connection" without data
            2023-12-17 10:03:59.994 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:03:59.994 - debug: octoprint.0 (401712) sending "get" request to "/api/printer" without data
            2023-12-17 10:04:00.093 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:04:00.093 - debug: octoprint.0 (401712) sending "get" request to "/api/job" without data
            2023-12-17 10:04:00.230 - debug: octoprint.0 (401712) received 200 response from /api/connection with content: {"current":{"baudrate":115200,"port":"/dev/ttyACM0","printerProfile":"_default","state":"Operational"},"options":{"baudratePreference":null,"baudrates":[250000,230400,115200,57600,38400,19200,9600],"portPreference":null,"ports":["/dev/ttyACM0"],"printerProfilePreference":"_default","printerProfiles":[{"id":"_default","name":"Sindewinder X2"}]}}
            2023-12-17 10:04:00.230 - debug: octoprint.0 (401712) updatePrinterStatus from: "Operational" -> printerOperational: true, printerPrinting: false
            2023-12-17 10:04:00.231 - debug: octoprint.0 (401712) [refreshFiles] started
            2023-12-17 10:04:00.280 - debug: octoprint.0 (401712) received 200 response from /api/printer with content: {"sd":{"ready":false},"state":{"error":"","flags":{"cancelling":false,"closedOrError":false,"error":false,"finishing":false,"operational":true,"paused":false,"pausing":false,"printing":false,"ready":true,"resuming":false,"sdReady":false},"text":"Operational"},"temperature":{"bed":{"actual":23.3,"offset":0,"target":0},"tool0":{"actual":23.69,"offset":0,"target":0}}}
            2023-12-17 10:04:00.321 - debug: octoprint.0 (401712) received 200 response from /api/job with content: {"job":{"estimatedPrintTime":null,"filament":{"length":null,"volume":null},"file":{"date":null,"name":null,"origin":null,"path":null,"size":null},"lastPrintTime":null,"user":null},"progress":{"completion":null,"filepos":null,"printTime":null,"printTimeLeft":null,"printTimeOrigin":null},"state":"Operational"}
            2023-12-17 10:04:00.347 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:04:00.347 - debug: octoprint.0 (401712) sending "get" request to "/api/files?recursive=true" without data
            2023-12-17 10:04:00.409 - debug: octoprint.0 (401712) received 200 response from /api/files?recursive=true with content: {"files":[],"free":3583709184,"total":7516811264}
            2023-12-17 10:04:00.410 - debug: octoprint.0 (401712) [refreshFiles] found 0 files
            2023-12-17 10:04:10.865 - debug: octoprint.0 (401712) sending system command: core/shutdown
            2023-12-17 10:04:10.866 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:04:10.867 - debug: octoprint.0 (401712) sending "post" request to "/api/system/commands/core/shutdown" with data: {}
            2023-12-17 10:04:10.947 - debug: octoprint.0 (401712) received 204 response from /api/system/commands/core/shutdown with content: ""
            2023-12-17 10:04:29.936 - debug: octoprint.0 (401712) refreshState: started from "timeout (operational)"
            2023-12-17 10:04:29.937 - debug: octoprint.0 (401712) [buildServiceRequest] starting service request
            2023-12-17 10:04:29.937 - debug: octoprint.0 (401712) sending "get" request to "/api/version" without data
            2023-12-17 10:04:29.940 - debug: octoprint.0 (401712) refreshStateTimeout: re-created refresh timeout (operational): id 129910 - seconds: 30
            2023-12-17 10:04:31.860 - info: admin.0 (136948) ==> Connected system.user.admin from ::ffff:192.168.188.59
            2023-12-17 10:04:31.944 - info: octoprint.0 (401712) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
            2023-12-17 10:04:31.946 - debug: octoprint.0 (401712) (version) received error - API is now offline: {"message":"timeout of 2000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 2000ms exceeded\n at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.octoprint/node_modules/axios/lib/adapters/http.js:643:16)\n at RedirectableRequest.emit (node:events:517:28)\n at RedirectableRequest.emit (node:domain:489:12)\n at Timeout. (/opt/iobroker/node_modules/follow-redirects/index.js:169:12)\n at listOnTimeout (node:internal/timers:569:17)\n at processTimers (node:internal/timers:512:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":2000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Api-Key":"2902964A0F7B42F69AD1017FB5B1AE38","User-Agent":"axios/1.6.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","data":null,"baseURL":"http://192.168.188.47:80","url":"/api/version","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ECONNABORTED","status":null}
            2023-12-17 10:04:31.947 - debug: octoprint.0 (401712) API is offline
            2023-12-17 10:04:36.259 - info: admin.0 (136948) <== Disconnect system.user.admin from ::ffff:192.168.188.59 javascript
            • da_WoodyD Online
              da_WoodyD Online
              #440
              @haus-automatisierung anderes, altes Problem
              . Thumbnail URL manchmal kommt sie bei Druckbeginn, manchmal erst nach Druckbeendigung.
              Liegt nicht an Sonderzeichen im Namen. Vorgestern Tab.gcode und Wall.gcode gedruckt. Bei einem Druck war das tumbnail bei Druckbeginn in den Objekten, beim anderen erst danach.
              Irgendwie verstehe ich das nicht mehr.
              • da_WoodyD da_Woody
                #441
                @da_woody sagte in Test Adapter OctoPrint:
                Habe das Thema länger nicht angeschaut. Kannst Du mir (nochmal) eine Datei mit integriertem Thumbnail zur Verfügung stellen? Ich nutze das Feature halt überhaupt nicht :) Daher fällt mir das nicht auf, wenn es damit Probleme gibt
                da_WoodyD 2 Antworten Letzte Antwort
                  da_WoodyD Online
                  da_WoodyD Online
                  #442
                  @haus-automatisierung na klar. Das Thumbnail wird in Cura ja immer erstellt. Dann wird der gcode direkt an den ender3v2 geschickt.
                  Im Moment noch beim Frühschoppen, irgendwo hab ich sicher noch deine Mail Adresse...
                  Bin schon gespannt, was ich mit dem creality K1 so erleben werde. Da ist Klipper drauf... :)
                    da_WoodyD Online
                    da_WoodyD Online
                    #443
                    @haus-automatisierung mail an info@ ist raus... 👍
                      #444
                      @da_woody Danke, ist angekommen. Gucke ich mir mal in einer ruhigen Minute an. Aber wenn Du eh zu Klipper wechselst, ... :)
                        da_WoodyD Online
                        da_WoodyD Online
                        #445
                        @haus-automatisierung kein stress! nope, der ender3v2 bleibt ja wie er ist. der wird nicht umgebaut. klipper ist dann der K1!
                        hätte aber einen sapphire pro abzugeben, den ich mit klipper nicht zum laufen brachte... :D
                        irgend ein kack in der config.
                          Aktuelle Test Version 2.0.0
                          Veröffentlichungsdatum 04.11.2021
                          Github Link https://github.com/klein0r/ioBroker.octoprint
                          Nach dem letzten Video zu OctoPrint, hatte ich mal wieder Lust am Adapter weiter zu arbeiten, damit der endlich mal Stable wird. Daher hier die Bitte, den Adapter in der letzten Version einfach mal zu testen.
                          Da der Adapter bereits im latest Repository enthalten ist, einfach darüber installieren - NICHT über GitHub, sonst sprechen wir ständig von anderen / undefinierten Versionen
                          Video: https://www.youtube.com/watch?v=NiTXB4lZv0A
                          Was alles aktuell gehen sollte:
                          Information
                          • Get version information
                          • Get printer information
                          • Get current print job information
                          • Get file list information
                          Temperatures
                          • Set tool temperature
                          • Set bed temperature
                          Commands
                          • Printer: Connect, disconnect and home
                          • Job: Start, Cancel, Restart
                          • SD-Card: Init, Refresh, Release
                          • Custom Printer Commands
                          • System Commands
                          • Jog X, Y and Z axis
                          gelberlemmyG Offline
                          gelberlemmy
                          #446
                          Hallo in die Runde,
                          ich bin aktuell auf der Suche nach einem Workaround für meinen Octoprint Adapter.
                          Ich habe folgendes vor:
                          Auf Jarvis möchte ich Eingabefenster haben, um einfach eine Layerzahl einzugeben. Wenn der Datenpunkt der Layerzahl diesen Wert erreicht hat, möchte ich eine Benachrichtigung auf Telegramm, Pushover etc haben. Quasi ein Blockly für die Nachricht. Und die Zahlenwerte werden dann über die Eingabefenster in Jarvis in dieses eingetragen.
                          Folgender Hintergrund:
                          Ich möchte bei meinem 3D Drucker die Farbe von Hand wechseln. Dafür muss ich passend bei einem Layer an meinem Drucker sein, da dieser einen wichtigen Befehl nicht kann. Daher gibt es dort schon ein Workaround mit einem bestimmten Zeitfenster, wo ich das Filament wechseln kann.
                          Hat da jemand zufällig schon einmal so etwas gemacht ?
                          Gruß und schönes Wochenende André
                          da_WoodyD joergeliJ 2 Antworten Letzte Antwort
                          • ESP8266E Offline
                            ESP8266E Offline
                            ESP8266
                            schrieb am zuletzt editiert von ESP8266
                            #447
                            @gelberlemmy , ich glaube du bist hier falsch. Hier ist ein Adapter Support.
                            Wenn ich da jetzt drüber nachdenke, lässt sich das durchaus mit VIS und ein paar Scripts realisieren
                            Die Datenpunkte wären ja da.
                            Aber halt hier OT
                            gelberlemmyG 1 Antwort Letzte Antwort
                            • ESP8266E ESP8266
                              Aber halt hier OT
                              gelberlemmy
                              #448
                              @esp8266 Ich hatte gehofft, dass jemand mit dem Octoprint Adapter eventuell sich so etwas schon gebaut hat.
                              Ich verschiebe das ganze mal 7n ein eigenes Thema
                              • gelberlemmyG gelberlemmy
                                Hallo in die Runde,
                                da_WoodyD Online
                                da_WoodyD Online
                                #449
                                @gelberlemmy brutal gesagt, du willst in den gcode eingreifen.
                                Wie soll das über den Adapter klappen? Das geht nicht mal mit Klipper.
                                Nimm Notepad++, und du kannst fummeln.
                                haus-automatisierungH gelberlemmyG 2 Antworten Letzte Antwort
                                  #450
                                  @da_woody Warum sollte das nicht gehen? Druck stoppen und einfach einen Custom Command senden via OctoPrint-Instanz
                                    gelberlemmy
                                    schrieb am zuletzt editiert von gelberlemmy
                                    #451
                                    @da_woody nein möchte ich nicht. Aber ich möchte einfach bei einer gewissen Layerhöhe eine Nachricht bekommen. Die Layerhöhe greife ich ja über den Adapter ab. Und dafür brauche einen Script, wo ich über die Jarvis Oberfläche einfach die Layerhöhe eingeben kann, wann ich über Pushsafer ne Meldung bekomme. Damit ich rechtzeitig beim Drucker bin um das Filmamt zu wechseln. Ist ein Anycubic Kobra 2 Drucker. Dieser kann leider den M600 Befehl nicht. Er hat auch die aktuell Firmware. Somit habe ich für Filament Wechsel eine Pause eingebaut, damit ich Zeit habe dies zu tauschen. Nur muss ich dann auch beim Drucker sein... Und ich hatte gehofft, dass jemand mit dem Octoprint Adapter so etwas schon einmal gemacht hat.😎
                                      Hallo in die Runde,
                                      joergeliJ Offline
                                      joergeliJ Offline
                                      joergeli
                                      schrieb am zuletzt editiert von joergeli
                                      #452
                                      @gelberlemmy
                                      ... Antwort nur in Kurzform, da ich momentan etwas im Stress bin 😊 :
                                      Ich lasse mir in VIS den aktuellen Layer anzeigen, dazu muss in Octoprint das Plugin "Display Layer Progress" installiert werden.
                                      Dann taucht im ioBroker-Objektbaum unter octoprint.0.plugins.displayLayerProgress.layer.current der aktuelle Layer auf (steht bei mir momentan auf 0, da ich momentan nichts drucke), s.Screenshot:
                                      Diesen Datenpunkt könnte man in JavaScript/Blockly verwursteln, daß wenn Layer xx erreicht wurde, z.B. eine Nachricht versendet , oder ein Sound abgespielt wird.
                                      Bitte hab' Verständnis, daß ich im Moment keine Zeit habe, um ein entspr. Script zu schreiben, aber evtl könnte das - wenn Du es selbst nicht kannst - ein anderer User übernehmen?
                                      Noch ein Tip:
                                      Ich habe ebenfalls vor kurzem mal mit 2 Farben gespielt und dazu unter Cura das Script "Pause at height" verwendet, welches auch soweit funktioniert und den Druckkopf an eine "unkritische Stelle" zum manuellen Filamentwechsel fährt.
                                      Habe lange gesucht, um anschließend den manuellen Filamentwechsel durchzuführen --> Es geht bei mir (AnyCubic Vyper) nur, wenn ich in Octoprint --> Steuerung --> Tool (E) zum Filament entladen den Button "Retract" mehfach betätige. Die maximale Retraction ist - soweit ich weiß - auf 150 mm begrenzt , deshalb muss ich mehrfach betätigen, weil bei mir ca. 40 cm Filament herausgezogen werden müssen.
                                      Das Einziehen des andersfarbigen Filaments erfolgt dann analog mit dem Button"Extrude".
                                      (Hinweis: Jegliche manuellen Eingaben direkt am Touchscreen des Druckers zum Filamentwechsel haben zum Abbruch des Druckes geführt!)
                                      Ich habe auch irgendwo gelesen, daß der Filamentwechsel recht zügig erfolgen sollte, da sonst das Bauteil auf der Druckplatte u.U. zu sehr abkühlt und anschl. beim Weiterdrucken mit der neuen Farbe an der Nahtstelle Probleme auftauchen könnten.
                                      Sieht doch ganz witzig aus, oder?:
                                      Jörg
                                      Nachtrag:
                                      @gelberlemmy sagte in Test Adapter OctoPrint:
                                      .... dafür brauche einen Script, wo ich über die Jarvis Oberfläche einfach die Layerhöhe eingeben kann
                                      Warum willst Du die Layerhöhe manuell in Jarvis eingeben?
                                      Im Cura-Plugin muss man doch sowieso die Layerhöhe eingeben, wo der Druck zum Filamentwechsel unterbrochen wird, oder verwendest Du einen anderen Slicer?
                                      In ioBroker könnte man dann doch direkt bei Erreichen von octoprint.0.plugins.displayLayerProgress.layer.current = xx ein entspr. Script triggern, welches dann die entspr. Benachrichtigung versendet.
                                      gelberlemmyG E 2 Antworten Letzte Antwort
                                      • joergeliJ joergeli
                                        @gelberlemmy
                                        Noch ein Tip:
                                        Jörg
                                        Nachtrag:
                                        gelberlemmy
                                        #453
                                        @joergeli danke für die Antwort. Das habe ich schon alles drin mit dem Display Layer Progress etc. Ich habe auch ein Blockly gebaut, was funktioniert. Nur möchte ich einfach über die Visualisierung Jarvis da eine Layerhöhe eintragen, damit ich eine Nachricht bekomme. Um mehr geht es gar nicht. Ich möchte nicht immer in IOBroker rein und dann dies im Blockly ändern. Ich habe in meinem Slicer schon unter Farbwechsel den korrekten Workaround drinne. Nur habe ich ca 30 sek Zeit mein Filmset zu wechseln. Wenn ich das verpenne druckt er mit ursprünglichen Farbe weiter. Ja das mit Anycunic ist so ein Problem.
                                          da_WoodyD Online
                                          da_WoodyD Online
                                          #454
                                          @haus-automatisierung klar, sind wir aber wieder bei dem problem, ohne blockly/js geht gar nix. :)
                                          wie ja weiter zu lesen ist, ohne eingriff in octoprint geht mal gar nix... (auch bei klipper brauchts dann ein macro)
                                          bis dann eine nachricht kommt,
                                          ist es zu spät.
                                          das braucht man nicht lesen, es ist einfach so. noch dazu, wenn das andere filament eventuell andere temperaturen braucht. ok, man kann die temps halten, aber nicht über den adapter.
                                          ergo, eingriff direkt in den gcode.
                                          hab am anfang mit dem anycubic mega-s auch rumgespielt. auge x daumen, filament abgeknipst, anderes dann nachgeschoben.
                                          alles nicht böse gemeint, IMHO nur realistisch betrachtet. :)
