  4. Vis 1 lädt nicht mehr, Loading Values
    6.1k
19 Beiträge 5 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • PamfP Pamf
    Laut Konsole nicht:
    patrick@IoBroker-auf-AMD:~$ npm -v
    10.2.5
    @pamf bitte iob diag in der Langfassung
    PamfP 1 Antwort Letzte Antwort
      PamfP Offline
      PamfP Offline
      Pamf
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: IoBroker-auf-AMD
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-15-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       21:35:30 up 10 min,  2 users,  load average: 0.57, 0.30, 0.12
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Fri 2023-12-15 21:35:31 CET
                 Universal time: Fri 2023-12-15 20:35:31 UTC
                       RTC time: Fri 2023-12-15 20:35:31
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      patrick
      /home/patrick
      patrick cdrom floppy sudo audio dip video plugdev users netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             10G        2.9G        7.0G        581K        745M        7.5G
      Swap:           1.0G          0B        1.0G
      Total:           11G        2.9G        8.1G
               9944 M total memory
               2764 M used memory
                125 M active memory
               2877 M inactive memory
               6712 M free memory
                 36 M buffer memory
                674 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  4.9G     0  4.9G   0% /dev
      tmpfs          tmpfs     995M  576K  994M   1% /run
      /dev/sda1      ext4       31G  5.9G   23G  21% /
      tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     995M     0  995M   0% /run/user/1000
      [Fri Dec 15 21:24:39 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Dec 15 21:24:39 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      519M    /var/
      297M    /var/cache
      290M    /var/cache/apt
      214M    /var/cache/apt/archives
      171M    /var/lib
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      388M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      503M    /opt/iobroker/iobroker-data/files
      95M     /opt/iobroker/iobroker-data/backup-objects
      90M     /opt/iobroker/iobroker-data/files/echarts.admin
      87M     /opt/iobroker/iobroker-data/files/vis.0
      354M    /opt/iobroker/iobroker-data/states.jsonl
      35M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2190944-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.5
      /usr/bin/npx            10.2.5
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : IoBroker-auf-AMD                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : IoBroker-auf-AMD                         -  enabled
        system.adapter.alias-manager.0          : alias-manager         : IoBroker-auf-AMD                         - disabled
      + system.adapter.backitup.0               : backitup              : IoBroker-auf-AMD                         -  enabled
      + system.adapter.backitup.1               : backitup              : Raspberry-Keller                         -  enabled
      + system.adapter.countdown.0              : countdown             : IoBroker-auf-AMD                         -  enabled
      + system.adapter.drops-weather.0          : drops-weather         : IoBroker-auf-AMD                         -  enabled
      + system.adapter.eventlist.0              : eventlist             : IoBroker-auf-AMD                         -  enabled
        system.adapter.feiertage.0              : feiertage             : IoBroker-auf-AMD                         -  enabled
        system.adapter.flot.0                   : flot                  : IoBroker-auf-AMD                         -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker-auf-AMD                         -  enabled
      + system.adapter.hue.0                    : hue                   : IoBroker-auf-AMD                         -  enabled, port: 443
      + system.adapter.influxdb.0               : influxdb              : IoBroker-auf-AMD                         -  enabled, port: 8086
      + system.adapter.jarvis.0                 : jarvis                : IoBroker-auf-AMD                         -  enabled
      + system.adapter.javascript.1             : javascript            : Raspberry-Keller                         -  enabled
      + system.adapter.javascript.2             : javascript            : IoBroker-auf-AMD                         -  enabled
      + system.adapter.logparser.0              : logparser             : IoBroker-auf-AMD                         -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker-auf-AMD                         -  enabled, port: 54321
        system.adapter.proxmox.0                : proxmox               : IoBroker-auf-AMD                         - disabled, port: 8006
      + system.adapter.simple-api.0             : simple-api            : IoBroker-auf-AMD                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.telegram.0               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.2               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.3               : telegram              : Raspberry-Keller                         -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.4               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.5               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.6               : telegram              : IoBroker-auf-AMD                         -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : IoBroker-auf-AMD                         -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker-auf-AMD                         - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : IoBroker-auf-AMD                         - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker-auf-AMD                         -  enabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : IoBroker-auf-AMD                         -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : IoBroker-auf-AMD                         -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker-auf-AMD                         - disabled
        system.adapter.vis.0                    : vis                   : IoBroker-auf-AMD                         -  enabled
      + system.adapter.web.0                    : web                   : IoBroker-auf-AMD                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yr.0                     : yr                    : IoBroker-auf-AMD                         -  enabled
      + system.adapter.zigbee.0                 : zigbee                : IoBroker-auf-AMD                         -  enabled, port: /dev/ttyACM0
      + system.adapter.zigbee.1                 : zigbee                : Raspberry-Keller                         -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "countdown"    : 2.2.0    , installed 2.2.0
      Adapter    "echarts"      : 1.5.4    , installed 1.5.4
      Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
      Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "telegram"     : 3.0.0    , installed 3.0.0
      Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        8559
      States:         6966
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1370       1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15921      548/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       18894      944/io.jarvis.0
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       676        514/iobroker.js-con
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       17409      514/iobroker.js-con
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17926      959/io.simple-api.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15948      566/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20908      1004/io.web.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1371       1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15923      548/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       20825      929/io.fullybrowser
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       15257      738/io.mihome-vacuu
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16426      402/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15620      1/init
      udp6       0      0 :::111                  :::*                                0          14552      1/init
      2023-12-15 21:26:16.936  - debug: vis.0 (989) States create User PubSub Client
      2023-12-15 21:26:16.987  - debug: vis.0 (989) States connected to redis: 0.0.0.0:9000
      2023-12-15 21:26:16.987  - silly: vis.0 (989) statesDB connected
      2023-12-15 21:26:17.013  - info: vis.0 (989) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
      2023-12-15 21:26:17.047  - silly: vis.0 (989) States system redis pmessage system.adapter.vis.0.logLevel/system.adapter.vis.0.logLevel:{"val":"silly","ack":true,"ts":1702671977019,"q":0,"from":"system.adapter.vis.0","lc":1702593049548}
      2023-12-15 21:26:17.147  - info: vis.0 (989) vis license is OK.
      2023-12-15 21:26:17.908  - info: vis.0 (989) Terminated (NO_ERROR): Without reason
      2023-12-15 21:26:18.437  - info: host.IoBroker-auf-AMD instance system.adapter.vis.0 terminated while should be started once
      2023-12-15 21:26:20.568  - info: host.IoBroker-auf-AMD instance system.adapter.web.0 started with pid 1004
      2023-12-15 21:26:21.095  - info: web.0 (1004) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
      2023-12-15 21:26:21.152  - info: web.0 (1004) socket.io server listening on port 8082
      2023-12-15 21:26:21.154  - info: web.0 (1004) http server listening on port 8082
      2023-12-15 21:26:24.512  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.22
      2023-12-15 21:26:24.568  - info: host.IoBroker-auf-AMD instance system.adapter.logparser.0 started with pid 1019
      2023-12-15 21:26:24.661  - info: web.0 (1004) <== Disconnect system.user.admin from ::ffff:192.168.178.22
      2023-12-15 21:26:25.073  - info: logparser.0 (1019) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.logparser, node: v18.19.0, js-controller: 5.0.17
      2023-12-15 21:26:29.979  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.22
      2023-12-15 21:30:00.005  - info: javascript.2 (633) script.js.common.VIS_2024.Scripte_andere_Seiten.Speedtest: Speedtest gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
      2023-12-15 21:30:15.990  - info: javascript.2 (633) script.js.common.VIS_2024.Scripte_andere_Seiten.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 253.03 MBits/s | Upload: 36.18 MBits/s | Ping: 0.657ms
      2023-12-15 21:33:24.443  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.206
      2023-12-15 21:33:35.912  - info: web.0 (1004) <== Disconnect system.user.admin from ::ffff:192.168.178.206 vis.0
      2023-12-15 21:33:36.230  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.206
      2023-12-15 21:34:29.848  - info: web.0 (1004) <== Disconnect system.user.admin from ::ffff:192.168.178.22 vis.0
      2023-12-15 21:34:35.696  - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.178.22
      2023-12-15 21:34:49.356  - info: influxdb.0 (618) Store 61 buffered influxDB history points
      iob diag has finished.
      Ich habe soeben auch entdeckt, dass ich VIS öffnen kann, aber nicht mein eigentliches Projekt. Da fängt es an zu laden und friert ein.
      • PamfP Pamf
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        patrick
        /home/patrick
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           1.0G          0B        1.0G
                 9944 M total memory
                 2764 M used memory
                  125 M active memory
                 6712 M free memory
                   36 M buffer memory
                  674 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        *** FILESYSTEM ***
        /var:
        519M    /var/
        297M    /var/cache
        290M    /var/cache/apt
        171M    /var/lib
        USB-Devices by-id:
        /usr/bin/npm            10.2.5
        /usr/bin/npx            10.2.5
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.6
        Adapter State
        + instance is alive
        Objects and States
        Objects:        8559
        States:         6966
        Pending Updates: 1
        @pamf
        sudo systemctl set-default multi-user.target
        sudo usermod -a -G adm patrick
        sudo apt update
        sudo apt full-upgrade
        sudo apt install --reinstall nodejs
        sudo reboot
        Und lass die Finger von npm-Updates. Das Ding wird nicht separat angepackt.
          @pamf
          sudo apt update
          sudo reboot
          PamfP Offline
          PamfP Offline
          Pamf
          @thomas-braun Danke, zumindest die Versionen sind nun passend. Auf meine View hab ich aber leider weiterhin keinen Zugriff.
          Jemand noch eine Idee? Ich habe hier gestern nur Widgets erstellt (kopiert aus einem schon vorher bestehendem und inhaltlich angepasst) und seitdem hab ich keinen Zugriff mehr
          • PamfP Pamf
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Chassis: vm 🖴
              Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
                          NTP service: active
                      RTC in local TZ: no
            patrick
            /home/patrick
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           1.0G          0B        1.0G
                     9944 M total memory
                     2764 M used memory
                      125 M active memory
                     6712 M free memory
                       36 M buffer memory
                      674 M swap cache
                      974 M total swap
                        0 M used swap
                      974 M free swap
            *** FILESYSTEM ***
            /var:
            519M    /var/
            297M    /var/cache
            290M    /var/cache/apt
            171M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.2.5
            /usr/bin/npx            10.2.5
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        8559
            States:         6966
            Pending Updates: 1
            @pamf sagte in Vis 1 lädt nicht mehr, Loading Values:
            Im Log steht dazu?
              Im Log steht dazu?
              @thomas-braun sagte in Vis 1 lädt nicht mehr, Loading Values:
              Im Log steht dazu?
              @Pamf
              oder in der Browserkonsole (f12)
                Im Log steht dazu?
                @Pamf
                PamfP Offline
                PamfP Offline
                Pamf
                im Log steht gar nichts, in der Browserkonsole u.a. (sorry, ich konnte es nicht als Text herauskopieren):
                • PamfP Pamf
                  Glaube ich nicht.
                  • PamfP Pamf
                    das ist nicht die Konsole.
                    Das wäre der nächste Reiter
                    • PamfP Pamf
                      Systemdata Bitte Ausfüllen
                      Hardwaresystem: Mini PC Ryzen 7 AMD R7 5700U mit Proxmox
                      Arbeitsspeicher: 12 GB
                      Festplattenart: SSD
                      Betriebssystem: Debian
                      Node-Version: v18.19.0
                      Nodejs-Version: v18.19.0
                      NPM-Version: 9.8.1
                      Installationsart: Skript
                      Image genutzt: Nein
                      Moin, ich habe gerade meine View in Vis 1 bearbeitet (per VPN verbunden), nach ca. 30 Min brach die Verbindung zur VIS ab, nicht jedoch zu IoBroker an sich. Seitdem kann ich sowohl die Bearbeitung als auch die Anzeige der View nicht mehr öffnen, es bleibt bei Loading Values hängen.
                      Bis zu dem Zeitpunkt hatte ich nichts im System geändert. Als VIS nicht mehr lief habe ich den js-Controller auf 5.0.17 upgedatet, keine Änderung. Neustart von Vis, IoBroker komplett, von der VM auf der IoBroker läuft, alles keine Änderung. Durch das Update des js-Controllers ist ja auch ein Fix durchgelaufen. Alle meine Adapter sind aktuell, Repo ist Stable.
                      Ich habe Backups von gestern, diese würde ich aber ungern nutzen wegen meinen heutigen Änderungen.
                      Was mir beim Ausfüllen hier aufgefallen ist: unter Host wird mir die Node.js Version
                      v18.18.2 angezeigt, bei Abfrage per Konsole wird aber v18.19.0 ausgegeben.
                      Hilfe!! ;-)
                      Ro75R Offline
                      Ro75R Offline
                      Ro75
                      schrieb am zuletzt editiert von Ro75
                      @pamf Hast du auf dieser View Objekte/Widgets gruppiert, kopiert? Wenn ja ist das der Auslöser. Wenn dem so ist, Backup der VIS einspielem.
                      Ro75.
                      PamfP mcm1957M 2 Antworten Letzte Antwort
                        Glaube ich nicht.
                        PamfP Offline
                        PamfP Offline
                        Pamf
                        @thomas-braun Du hast recht, im Log steht etwas, aber nicht dazu. VIS, Web etc. haben nichts im Log eingetragen.
                        @Ro75 genau das habe ich gemacht, nach langer Zeit ohne Nutzung der Möglichkeit des Kopierens dieses mal wieder gemacht. Danke! Bin gerade beim Einspielen der Sicherung.
                        • Ro75R Ro75
                          Ro75.
                          PamfP Offline
                          PamfP Offline
                          Pamf
                          @ro75 Geht wieder, vielen Dank!!
                          • Ro75R Ro75
                            Ro75.
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            @ro75 said in Vis 1 lädt nicht mehr, Loading Values:
                            Ro75.
                            Ist dir dazu ein Issue im Adapter Repo bekannt?
                            Offenbar gibt es hier ein bekanntes Problem. Ich konnte mal auf die Schnelle kein passendes Issue entdecken.
                            Wenn dir auch keines bekannt ist, erstell dich du (oder sonst wer hier) ein passended Issue im Repo (https://github.com/ioBroker/ioBroker.vis/issues).
                            Da ich vis nicht gut kenne, kann ich nicht sinnvoll beschreiben welche Aktion wie das Problem auslöst und welche Symptome da genau ausgelöst werden.
                            DANKE
                            Support Repositoryverwaltung.
                            LESEN - gute Forenbeitrage
