  4. Problem mit Sonoff Zigbee USB Stick
    6.1k
13 Beiträge 4 Kommentatoren 1.3k Aufrufe 4 Beobachtet
  • R Offline
    rsw2004
    ich habe seit ein paar Tagen den Sonoff Zigbee USB Stick -E am Raspi hängen. Hat anfänglich problemlos funktioniert.
    Nach Firmware-Update des Sticks und Raspi-Updates startet der Adapter zwar anfänglich und verbindet sich mit den Geräten allerdings wird dieser wohl fehlerbedingt neugestartet bis er in die Fehlerschleife kommt.
    Hat jemand eine Idee?
    host.raspberrypi4
    2023-12-03 11:58:54.055	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
    host.raspberrypi4
    2023-12-03 11:58:54.054	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi4
    2023-12-03 11:58:54.054	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.raspberrypi4
    2023-12-03 11:58:54.054	error	Caught by controller[1]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    host.raspberrypi4
    2023-12-03 11:58:54.054	error	Caught by controller[1]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
    host.raspberrypi4
    2023-12-03 11:58:54.053	error	Caught by controller[1]: Error: Reset error: Error: {"sequence":-1} after 10000ms
    host.raspberrypi4
    2023-12-03 11:58:54.052	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    2023-12-03 11:58:53.810	info	terminating
    zigbee.0
    2023-12-03 11:58:53.707	info	debug devices set to []
    zigbee.0
    2023-12-03 11:58:53.451	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2023-12-03 11:58:53.449	info	terminating
    zigbee.0
    2023-12-03 11:58:53.448	warn	Failed to stop zigbee during startup
    zigbee.0
    2023-12-03 11:58:53.369	info	Zigbee: disabling joining new devices.
    zigbee.0
    2023-12-03 11:58:53.308	info	cleaned everything up...
    zigbee.0
    2023-12-03 11:58:53.285	error	Reset error: Error: {"sequence":-1} after 10000ms
    zigbee.0
    2023-12-03 11:58:53.285	error	Error: Reset error: Error: {"sequence":-1} after 10000ms at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23 at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    2023-12-03 11:58:53.242	error	unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
    zigbee.0
    2023-12-03 11:58:53.242	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2023-12-03 11:58:42.795	info	Installed Version: iobroker.zigbee@1.8.24
    zigbee.0
    2023-12-03 11:58:42.482	info	Starting Zigbee npm ...
    zigbee.0
    2023-12-03 11:58:42.480	info	delete old Backup files. keep only last 10
    zigbee.0
    2023-12-03 11:58:42.373	info	starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.16
    host.raspberrypi4
    2023-12-03 11:58:37.763	info	instance system.adapter.zigbee.0 started with pid 3872
    host.raspberrypi4
    2023-12-03 11:58:07.664	info	Restart adapter system.adapter.zigbee.0 because enabled
    • R rsw2004
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      host.raspberrypi4
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      host.raspberrypi4
      host.raspberrypi4
      @rsw2004 sagte in Problem mit Sonoff Zigbee USB Stick:
      Welche Versionen?
      R 1 Antwort Letzte Antwort
        Welche Versionen?
        rsw2004
        Stick:
        SDK Version 4.3.1
        EZSP Version 7.3.1.0 build 176
        Raspi:
        Node 18.19.0
        NPM 10.2.3
        • Meister MopperM Online
          Meister Mopper
          schrieb am zuletzt editiert von Meister Mopper
          @rsw2004
          Ich glaube, gemeint ist sowas:
          Proxmox und HA ...
            @rsw2004
            rsw2004
            @meister-mopper
            @Thomas-Braun
            • R rsw2004
              @meister-mopper
              @Thomas-Braun
              rsw2004
              ls -la /dev/serial/by-id/
              total 0
              drwxr-xr-x 2 root root 60 Dec  3 19:50 .
              drwxr-xr-x 4 root root 80 Dec  3 19:50 ..
              lrwxrwxrwx 1 root root 13 Dec  3 19:50 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230831103249-if00 -> ../../ttyACM0
              • R rsw2004
                total 0
                arteckA Offline
                arteckA Offline
                arteck
                das ist kein ezsp . wie kommst du dadrauf... und deshalb startet der nicht
                • arteckA arteck
                  rsw2004
                  @arteck
                  Sollte passen, das ist der Typ E
                  Wenn ich den Raspi neustarte, läuft der Adapter problemlos hoch und der Stick verbindet sich mit den Geräten. Nach mehreren Minuten tritt aber dann ein Problem auf.
                  • R rsw2004
                    @arteck
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @rsw2004
                    dann fläch mal ne andere Firmaware die 20230831 ist nicht so prikelnd
                    https://github.com/Koenkk/Z-Stack-firmware/discussions/474
                    • arteckA arteck
                      @rsw2004
                      rsw2004
                      @arteck
                      kam jetzt erst dazu den Stick zu downgraden. Habe die 6.7.10 aufgespielt, das war auch die Version die original bei Auslieferung aufgespielt war.
                      Seit einer Stunde läuft alles problemlos.
                      Ich denke der Fehler ist behoben.
                      Vielen Dank
                      R arteckA 2 Antworten Letzte Antwort
                      • R rsw2004
                        @arteck
                        Vielen Dank
                        rsw2004
                        @arteck
                        zu früh gefreut.. nach etlichen Stunden Normalbetrieb fängt schon wieder etwas an zu spinnen.. Aus dem Nichts heraus:
                        host.raspberrypi4
                        2023-12-05 17:23:49.365	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                        host.raspberrypi4
                        2023-12-05 17:23:49.365	info	Restart adapter system.adapter.zigbee.0 because enabled
                        host.raspberrypi4
                        2023-12-05 17:23:49.365	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        host.raspberrypi4
                        2023-12-05 17:23:49.365	error	Caught by controller[1]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                        host.raspberrypi4
                        2023-12-05 17:23:49.365	error	Caught by controller[1]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
                        host.raspberrypi4
                        2023-12-05 17:23:49.364	error	Caught by controller[1]: Error: Reset error: Error: {"sequence":-1} after 10000ms
                        host.raspberrypi4
                        2023-12-05 17:23:49.364	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        zigbee.0
                        2023-12-05 17:23:49.100	info	terminating
                        zigbee.0
                        2023-12-05 17:23:49.025	info	debug devices set to []
                        zigbee.0
                        2023-12-05 17:23:48.759	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        zigbee.0
                        2023-12-05 17:23:48.758	info	terminating
                        zigbee.0
                        2023-12-05 17:23:48.756	warn	Failed to stop zigbee during startup
                        zigbee.0
                        2023-12-05 17:23:48.651	info	Zigbee: disabling joining new devices.
                        zigbee.0
                        2023-12-05 17:23:48.598	info	cleaned everything up...
                        zigbee.0
                        2023-12-05 17:23:48.567	error	Reset error: Error: {"sequence":-1} after 10000ms
                        zigbee.0
                        2023-12-05 17:23:48.566	error	Error: Reset error: Error: {"sequence":-1} after 10000ms at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23 at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                        zigbee.0
                        2023-12-05 17:23:48.505	error	unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
                        zigbee.0
                        2023-12-05 17:23:48.504	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        zigbee.0
                        2023-12-05 17:23:38.040	info	Installed Version: iobroker.zigbee@1.8.24
                        zigbee.0
                        2023-12-05 17:23:37.709	info	Starting Zigbee npm ...
                        zigbee.0
                        2023-12-05 17:23:37.707	info	delete old Backup files. keep only last 10
                        zigbee.0
                        2023-12-05 17:23:37.598	info	starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.16
                        host.raspberrypi4
                        2023-12-05 17:23:33.136	info	instance system.adapter.zigbee.0 started with pid 3006
                        host.raspberrypi4
                        2023-12-05 17:23:03.085	info	Restart adapter system.adapter.zigbee.0 because enabled
                        host.raspberrypi4
                        2023-12-05 17:23:03.084	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        host.raspberrypi4
                        2023-12-05 17:23:03.084	error	Caught by controller[0]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                        host.raspberrypi4
                        2023-12-05 17:23:03.084	error	Caught by controller[0]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
                        host.raspberrypi4
                        2023-12-05 17:23:03.083	error	Caught by controller[0]: Error: Reset error: Error: {"sequence":-1} after 10000ms
                        host.raspberrypi4
                        2023-12-05 17:23:03.082	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        zigbee.0
                        2023-12-05 17:23:02.824	info	terminating
                        zigbee.0
                        2023-12-05 17:23:02.724	info	debug devices set to []
                        zigbee.0
                        2023-12-05 17:23:02.478	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        zigbee.0
                        2023-12-05 17:23:02.476	info	terminating
                        zigbee.0
                        2023-12-05 17:23:02.475	warn	Failed to stop zigbee during startup
                        zigbee.0
                        2023-12-05 17:23:02.364	info	Zigbee: disabling joining new devices.
                        zigbee.0
                        2023-12-05 17:23:02.321	info	cleaned everything up...
                        zigbee.0
                        2023-12-05 17:23:02.296	error	Reset error: Error: {"sequence":-1} after 10000ms
                        zigbee.0
                        2023-12-05 17:23:02.296	error	Error: Reset error: Error: {"sequence":-1} after 10000ms at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23 at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                        zigbee.0
                        2023-12-05 17:23:02.252	error	unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
                        zigbee.0
                        2023-12-05 17:23:02.251	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        zigbee.0
                        2023-12-05 17:22:52.234	info	Installed Version: iobroker.zigbee@1.8.24
                        zigbee.0
                        2023-12-05 17:22:51.467	info	Starting Zigbee npm ...
                        zigbee.0
                        2023-12-05 17:22:51.464	info	delete old Backup files. keep only last 10
                        zigbee.0
                        2023-12-05 17:22:51.355	info	starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.16
                        host.raspberrypi4
                        2023-12-05 17:22:46.800	info	instance system.adapter.zigbee.0 started with pid 2990
                        host.raspberrypi4
                        2023-12-05 17:22:16.705	info	Restart adapter system.adapter.zigbee.0 because enabled
                        host.raspberrypi4
                        2023-12-05 17:22:16.705	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        host.raspberrypi4
                        2023-12-05 17:22:16.704	error	Caught by controller[0]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                        host.raspberrypi4
                        2023-12-05 17:22:16.704	error	Caught by controller[0]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
                        host.raspberrypi4
                        2023-12-05 17:22:16.704	error	Caught by controller[0]: Error: Reset error: Error: {"sequence":-1} after 10000ms
                        host.raspberrypi4
                        2023-12-05 17:22:16.702	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                        zigbee.0
                        2023-12-05 17:22:16.305	info	terminating
                        zigbee.0
                        2023-12-05 17:22:16.118	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        zigbee.0
                        2023-12-05 17:22:16.116	info	terminating
                        zigbee.0
                        2023-12-05 17:22:16.115	error	Failed to stop zigbee (Error: Connection not initialized at Ezsp.execCommand (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:551:19) at Ezsp.version (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:349:35) at EZSPAdapterBackup.createBackup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/backup.ts:21:56) at EZSPAdapter.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:609:31) at Controller.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:328:47) at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:308:9) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:456:13) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:908:17))
                        zigbee.0
                        2023-12-05 17:22:15.841	info	Zigbee: disabling joining new devices.
                        zigbee.0
                        2023-12-05 17:22:15.804	info	cleaned everything up...
                        zigbee.0
                        2023-12-05 17:22:15.769	error	Reset error: Error: {"sequence":-1} after 10000ms
                        zigbee.0
                        2023-12-05 17:22:15.768	error	Error: Reset error: Error: {"sequence":-1} after 10000ms at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23 at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
                        zigbee.0
                        2023-12-05 17:22:15.710	error	unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
                        zigbee.0
                        2023-12-05 17:22:15.709	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        • R rsw2004
                          @arteck
                          Vielen Dank
                          arteckA Offline
                          arteckA Offline
                          arteck
                          ?????????????????????????? was denn für 6.7.10 ?
                          • arteckA arteck
                            rsw2004
                            @arteck
                            Ich weiß gerade nicht so genau was du von mir hören möchtest..
                            Aber das ist die Firmware-Version, welche bei der Auslieferung auf dem Stick war.. 6.7.10.
                            Es ist der Typ -E nicht -P..
                            Ich versuche es gleich noch mit der 6.10.3., meine letzte Hoffnung.
                            Ansonsten geht das Teil halt zurück.
