  4. Dash button Adapter lässt sich nicht installiert.
    5.8k
5 Beiträge 3 Kommentatoren 1.1k Aufrufe
    Mr.X
    habe vor ein paar Tagen mir ein paar Dash Buttons für je 2€ gekauft und wollte jetzt den entsprechenden Adapter installieren.
    Doch leider schlägt das fehl. Vielleicht wir einer aus den Warnungen schlau.
    Ich leider überhaupt nicht.
    ! $ ./iobroker add amazon-dash
    ! npm install iobroker.amazon-dash –production --prefix "/opt/iobroker" (System call)
    ! npm
    ! WARN lifecycle iobroker.amazon-dash@0.2.5~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.5 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
    ! ../socket_watcher.cpp: In static member function 'static void SocketWatcher::New(const Nan::FunctionCallbackInfov8::value&)':../socket_watcher.cpp:104:49: warning: 'v8::Local v8::objectv8::Function::NewInstance() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
    ! info.GetReturnValue().Set(cons->NewInstance());
    ! In file included from /root/.node-gyp/6.11.4/include/node/v8.h:25:0, from /root/.node-gyp/6.11.4/include/node/node.h:42,
    ! from ../../nan/nan.h:49,
    ! from ../socket_watcher.hpp:8,
    ! from ../socket_watcher.cpp:5:
    ! /root/.node-gyp/6.11.4/include/node/v8.h:3276:52: note: declared here
    ! V8_DEPRECATED("Use maybe version", Local <object>NewInstance() const);
    ! /root/.node-gyp/6.11.4/include/node/v8config.h:333:3: note: in definition of macro 'V8_DEPRECATED'
    ! declarator attribute((deprecated(message)))
    ! ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include <pcap pcap.h="">^
    ! compilation terminated.
    ! make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1
    ! gyp
    ! ERR! build error
    ! gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    ! gyp ERR! stack at emitTwo (events.js:106:13)
    ! gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    ! gyp ERR! System Linux 4.9.41-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! cwd /opt/iobroker/node_modules/pcap
    ! gyp ERR! node -v v6.11.4
    ! gyp ERR! node-gyp -v v3.4.0
    ! gyp ERR! not ok
    ! npm
    ! ERR! Linux 4.9.41-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "–production" "--prefix" "/opt/iobroker"
    ! npm ERR! node v6.11.4
    ! npm ERR! npm v3.10.10
    ! npm ERR! code ELIFECYCLE
    ! npm
    ! ERR! pcap@2.0.0 install: node-gyp rebuildnpm ERR! Exit status 1
    ! npm ERR!
    ! npm ERR! Failed at the pcap@2.0.0 install script 'node-gyp rebuild'.
    ! npm ERR! Make sure you have the latest version of node.js and npm installed.
    ! npm ERR! If you do, this is most likely a problem with the pcap package,
    ! npm ERR! not with npm itself.
    ! npm ERR! Tell the author that this fails on your system:
    ! npm ERR! node-gyp rebuild
    ! npm ERR! You can get information on how to open an issue for this project with:
    ! npm ERR! npm bugs pcap
    ! npm ERR! Or if that isn't available, you can get their info via:npm ERR! npm owner ls pcap
    ! npm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:
    ! npm ERR! /npm-debug.log
    ! host.PI_ioBroker install adapter amazon-dash
    ! npm install iobroker.amazon-dash --production --prefix "/opt/iobroker" (System call)
    ! npm
    ! gyp
    ! ERR!
    ! build error
    ! gyp
    ! ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    ! ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap
    ! gyp ERR!
    ! node-gyp -v v3.4.0gyp ERR! not ok
    ! npm
    ! npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "–production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.4
    ! npm ERR!
    ! code ELIFECYCLE
    ! npm
    ! npm ERR!
    ! npm ERR!
    ! If you do, this is most likely a problem with the pcap package,npm ERR!
    ! not with npm itself.npm ERR! Tell the author that this fails on your system:
    ! npm ERR! npm bugs pcapnpm ERR! Or if that isn't available, you can get their info via:
    ! npm ERR! npm owner ls pcap
    ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
    ! npm
    ! from /root/.node-gyp/6.11.4/include/node/node.h:42,
    ! gyp
    ! ERR! build error
    ! gyp
    ! ERR! stack
    ! Error: make failed with exit code: 2gyp ERR!
    ! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:106:13)
    ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! not ok
    ! npm
    ! npm
    ! npm ERR!
    ! npm ERR! Make sure you have the latest version of node.js and npm installed.npm ERR! If you do, this is most likely a problem with the pcap package,
    ! ERROR: host.PI_ioBroker Cannot install amazon-dash
    ! ERROR: process exited with code 13</pcap></object></v8::object></v8::value></pcap></object></v8::object></v8::value></pcap></object></v8::object></v8::value>
    • arteckA Offline
      arteckA Offline
      arteck
      hast du die libs installiert
        Mr.X
        Hmm, weiß ich nicht.
        Werde ich abends ausprobieren.
        Vielen Dank l
          Mr.X
          Oje, zu doof, um zu lesen, dabei war ich auf der GitHub Seite.
          Danke für die Hilfe.
          • MathiasJM Offline
            MathiasJM Offline
            MathiasJ
            Hat jetzt schon jemand den Dash Button zum laufen gebracht?
            Ich komme den ersten am Samstag und würde den gerne einsetzen.
            Wenn ich das hin bekomme, sollen noch welche folgen.
            Gruß,
            Mathias
            Gesendet von meinem SM-N915FY mit Tapatalk
            IObroker auf dem NUC als VM.
