<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dash button Adapter lässt sich nicht installiert.]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">habe vor ein paar Tagen mir ein paar Dash Buttons für je 2€ gekauft und wollte jetzt den entsprechenden Adapter installieren.</p>
<p dir="auto">Doch leider schlägt das fehl. Vielleicht wir einer aus den Warnungen schlau.</p>
<p dir="auto">Ich leider überhaupt nicht.</p>
<blockquote>
<p dir="auto">! $ ./iobroker add amazon-dash<br />
! npm install iobroker.amazon-dash –production --prefix "/opt/iobroker" (System call)<br />
! npm<br />
! WARN lifecycle iobroker.amazon-dash@0.2.5~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.5 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9<br />
! ../socket_watcher.cpp: In static member function 'static void SocketWatcher::New(const Nan::FunctionCallbackInfo<a rel="nofollow ugc">v8::value</a>&amp;)':../socket_watcher.cpp:104:49: warning: 'v8::Local <a rel="nofollow ugc">v8::object</a>v8::Function::NewInstance() const' is deprecated: Use maybe version [-Wdeprecated-declarations]<br />
! info.GetReturnValue().Set(cons-&gt;NewInstance());<br />
! ^<br />
! In file included from /root/.node-gyp/6.11.4/include/node/v8.h:25:0, from /root/.node-gyp/6.11.4/include/node/node.h:42,<br />
! from ../../nan/nan.h:49,<br />
! from ../socket_watcher.hpp:8,<br />
! from ../socket_watcher.cpp:5:<br />
! /root/.node-gyp/6.11.4/include/node/v8.h:3276:52: note: declared here<br />
! V8_DEPRECATED("Use maybe version", Local &lt;object&gt;NewInstance() const);<br />
! ^<br />
! /root/.node-gyp/6.11.4/include/node/v8config.h:333:3: note: in definition of macro 'V8_DEPRECATED'<br />
! declarator <strong>attribute</strong>((deprecated(message)))<br />
! ^~~~~~~~~~<br />
! ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include &lt;pcap pcap.h=""&gt;^<br />
! compilation terminated.<br />
! make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1<br />
! gyp<br />
! ERR! build error<br />
! gyp ERR! stack Error: <code>make</code> failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)<br />
! gyp ERR! stack at emitTwo (events.js:106:13)<br />
! gyp ERR! stack at ChildProcess.emit (events.js:191:7)<br />
! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)<br />
! gyp ERR! System Linux 4.9.41-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"<br />
! gyp ERR! cwd /opt/iobroker/node_modules/pcap<br />
! gyp ERR! node -v v6.11.4<br />
! gyp ERR! node-gyp -v v3.4.0<br />
! gyp ERR! not ok<br />
! npm<br />
! ERR! Linux 4.9.41-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "–production" "--prefix" "/opt/iobroker"<br />
! npm ERR! node v6.11.4<br />
! npm ERR! npm v3.10.10<br />
! npm ERR! code ELIFECYCLE<br />
! npm<br />
! ERR! pcap@2.0.0 install: <code>node-gyp rebuild</code>npm ERR! Exit status 1<br />
! npm ERR!<br />
! npm ERR! Failed at the pcap@2.0.0 install script 'node-gyp rebuild'.<br />
! npm ERR! Make sure you have the latest version of node.js and npm installed.<br />
! npm ERR! If you do, this is most likely a problem with the pcap package,<br />
! npm ERR! not with npm itself.<br />
! npm ERR! Tell the author that this fails on your system:<br />
! npm ERR! node-gyp rebuild<br />
! npm ERR! You can get information on how to open an issue for this project with:<br />
! npm ERR! npm bugs pcap<br />
! npm ERR! Or if that isn't available, you can get their info via:npm ERR! npm owner ls pcap<br />
! npm ERR! There is likely additional logging output above.<br />
! npm ERR! Please include the following file with any support request:<br />
! npm ERR! /npm-debug.log<br />
! host.PI_ioBroker install adapter amazon-dash<br />
! npm install iobroker.amazon-dash --production --prefix "/opt/iobroker" (System call)<br />
! npm<br />
! ^<br />
! ^<br />
! ^~~~~~~~~~<br />
! gyp<br />
! ERR!<br />
! build error<br />
! gyp<br />
! ERR! stack Error: <code>make</code> failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)<br />
! gyp ERR! System Linux 4.9.41-v7+gyp<br />
! ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap<br />
! gyp ERR!<br />
! node-gyp -v v3.4.0gyp ERR! not ok<br />
! npm<br />
! ERR! Linux 4.9.41-v7+<br />
! npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.amazon-dash" "–production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.4<br />
! npm ERR!<br />
! npm<br />
! npm ERR!<br />
! npm ERR!<br />
! If you do, this is most likely a problem with the pcap package,npm ERR!<br />
! not with npm itself.npm ERR! Tell the author that this fails on your system:<br />
! npm ERR! npm bugs pcapnpm ERR! Or if that isn't available, you can get their info via:<br />
! npm ERR! npm owner ls pcap<br />
! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log<br />
! npm<br />
! ^<br />
! In file included from /root/.node-gyp/6.11.4/include/node/v8.h:25:0,<br />
! from /root/.node-gyp/6.11.4/include/node/node.h:42,<br />
! ^<br />
! ^~~~~~~~~~<br />
! gyp<br />
! gyp<br />
! ERR! stack<br />
! Error: <code>make</code> failed with exit code: 2gyp ERR!<br />
! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:106:13)<br />
! gyp ERR! System Linux 4.9.41-v7+<br />
! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"<br />
! npm<br />
! npm<br />
! npm ERR!<br />
! npm ERR! Make sure you have the latest version of node.js and npm installed.npm ERR! If you do, this is most likely a problem with the pcap package,<br />
! npm ERR! Or if that isn't available, you can get their info via:<br />
! ERROR: host.PI_ioBroker Cannot install amazon-dash<br />
! ERROR: process exited with code 13&lt;/pcap&gt;&lt;/object&gt;&lt;/v8::object&gt;&lt;/v8::value&gt;&lt;/pcap&gt;&lt;/object&gt;&lt;/v8::object&gt;&lt;/v8::value&gt;&lt;/pcap&gt;&lt;/object&gt;&lt;/v8::object&gt;&lt;/v8::value&gt;</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/topic/8748/dash-button-adapter-lässt-sich-nicht-installiert</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 02:03:06 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/8748.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Nov 2017 15:22:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Dash button Adapter lässt sich nicht installiert. on Thu, 14 Dec 2017 18:11:18 GMT]]></title><description><![CDATA[<p dir="auto">Hat jetzt schon jemand den Dash Button zum laufen gebracht?</p>
<p dir="auto">Ich komme den ersten am Samstag und würde den gerne einsetzen.</p>
<p dir="auto">Wenn ich das hin bekomme, sollen noch welche folgen.</p>
<p dir="auto">Gruß,</p>
<p dir="auto">Mathias</p>
<p dir="auto">Gesendet von meinem SM-N915FY mit Tapatalk</p>
]]></description><link>https://forum.iobroker.net/post/113294</link><guid isPermaLink="true">https://forum.iobroker.net/post/113294</guid><dc:creator><![CDATA[MathiasJ]]></dc:creator><pubDate>Thu, 14 Dec 2017 18:11:18 GMT</pubDate></item><item><title><![CDATA[Reply to Dash button Adapter lässt sich nicht installiert. on Sun, 26 Nov 2017 20:21:41 GMT]]></title><description><![CDATA[<p dir="auto">Oje, zu doof, um zu lesen, dabei war ich auf der GitHub Seite.</p>
<p dir="auto">Danke für die Hilfe.</p>
]]></description><link>https://forum.iobroker.net/post/109332</link><guid isPermaLink="true">https://forum.iobroker.net/post/109332</guid><dc:creator><![CDATA[Mr.X]]></dc:creator><pubDate>Sun, 26 Nov 2017 20:21:41 GMT</pubDate></item><item><title><![CDATA[Reply to Dash button Adapter lässt sich nicht installiert. on Sat, 25 Nov 2017 11:36:29 GMT]]></title><description><![CDATA[<p dir="auto">Hmm, weiß ich nicht.</p>
<p dir="auto">Werde ich abends ausprobieren.</p>
<p dir="auto">Vielen Dank l</p>
]]></description><link>https://forum.iobroker.net/post/108967</link><guid isPermaLink="true">https://forum.iobroker.net/post/108967</guid><dc:creator><![CDATA[Mr.X]]></dc:creator><pubDate>Sat, 25 Nov 2017 11:36:29 GMT</pubDate></item><item><title><![CDATA[Reply to Dash button Adapter lässt sich nicht installiert. on Sat, 25 Nov 2017 11:09:33 GMT]]></title><description><![CDATA[<p dir="auto">hast du die libs installiert</p>
<p dir="auto">apt-get install libpcap-dev</p>
]]></description><link>https://forum.iobroker.net/post/108959</link><guid isPermaLink="true">https://forum.iobroker.net/post/108959</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Sat, 25 Nov 2017 11:09:33 GMT</pubDate></item></channel></rss>
