    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
    TT-Tom
    #4368
    @cluni sagte in SONOFF NSPanel mit Lovelace UI:
    Habe gerade das Skript mal neu gestartet, aber die Warnungen sind noch da. Aber das stört mich nicht wirklich - ich schaue eh von Zeit zu Zeit immer mal überall durch, ob man was auf den neusten Stand bringen kann.
    Morgen
    habe die aktuelle Scriptversion mal gestartet, ohne Probleme bzw. Warnungen. Welche Version hast du grade am laufen, kannst du mal in die Tasmota Konsole schauen, ob Daten gesendet werden. sollte so aussehen.
    09:26:38.078 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2023-11-27T09:26:38","Uptime":"8T16:15:28","UptimeSec":749728,"Heap":85,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":33,"Berry":{"HeapUsed":53,"Objects":652},"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"TomTom24","BSSId":"2C:91:AB:AF:46:A7","Channel":2,"Mode":"11n","RSSI":68,"Signal":-66,"LinkCount":14,"Downtime":"0T00:02:35"}}
    09:26:38.099 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2023-11-27T09:26:38","ANALOG":{"Temperature1":-3.6},"ESP32":{"Temperature":70.0},"TempUnit":"C"}
    09:26:46.233 MQT: SmartHome/NSPanel_1/stat/STATUS0 = {"Status":{"Module":0,"DeviceName":"NSPanelBuero","FriendlyName":["NSPanelBuero",""],"Topic":"NSPanel_1","ButtonTopic":"0","Power":3,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"8T16:15:36","StartupUTC":"2023-11-18T16:11:10","Sleep":50,"CfgHolder":4617,"BootCount":32,"BCResetTime":"2023-01-05T06:15:40","SaveCount":277},"StatusFWR":{"Version":"13.2.0(tasmota32)","BuildDateTime":"2023.10.19 09:11:03","Core":"2_0_14","SDK":"4.4.6.231011","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.0","CR":"452/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":2,"SysLog":0,"LogHost":"192.168.178.121","LogPort":514,"SSId":["TomTom24",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":1873,"Free":1006,"Heap":87,"StackLowMark":4,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["00000407","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","010A80B1"],"Drivers":"1,2,3,4,5,7,8,9,10,11,12,14,16,17,20,21,24,26,27,29,34,35,38,50,52,59,60,62,63,66,67,68,82,86,87,88","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82"},"StatusNET":{"Hostname":"NSPanelBuero","IPAddress":"192.168.178.101","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"2a02:8109:a301:a900:b2f2:8ff:fe43:c159","Mac":"7C:87:CE:C6:1B:74","IP6Global":"2a02:8109:a301:a900:7e87:ceff:fec6:1b74","IP6Local":"fe80::7e87:ceff:fec6:1b74","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.1","DNSServer2":"2a02:8109:a301:a900:b2f2:8ff:fe43:c159","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0},"StatusMQT":{"MqttHost":"192.168.178.121","MqttPort":1886,"MqttClientMask":"NSPanelBüro","MqttClient":"NSPanelBüro","MqttUser":"Iobroker","MqttCount":33,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2023-11-27T08:26:46","Local":"2023-11-27T09:26:46","StartDST":"2023-03-26T02:00:00","EndDST":"2023-10-29T03:00:00","Timezone":"+01:00","Sunrise":"08:16","Sunset":"16:58"},"StatusSNS":{"Time":"2023-11-27T09:26:46","ANALOG":{"Temperature1":-3.8},"ESP32":{"Temperature":70.0},"TempUnit":"C"},"StatusSTS":{"Time":"2023-11-27T09:26:46","Uptime":"8T16:15:36","UptimeSec":749736,"Heap":86,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":21,"MqttCount":33,"Berry":{"HeapUsed":53,"Objects":652},"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"TomTom24","BSSId":"2C:91:AB:AF:46:A7","Channel":2,"Mode":"11n","RSSI":68,"Signal":-66,"LinkCount":14,"Downtime":"0T00:02:35"}}}
    zusätzlich kannst du im Browser mal eingeben:
    http:// ip vom Panel /cm?cmnd=Status0
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    ArmilarA CluniC 2 Antworten Letzte Antwort
    • T TT-Tom
      Morgen
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #4369
      @tt-tom
      @Cluni
      Ja, wird diese Zeile sein:
      Der Datenpunkt currentVersion wird leer sein. Könnten wir noch abfangen und etwas schöner ausgeben.
      @TT-Tom liegt da schon richtig. Einfach mal den Status abrufen und in den Datenpunkt der Tasmota-Version sehen...
      Das Limit und die Warnung des 2. Fehlers kommt durch zu viele Starts des Skriptes zustande...
      Ist, obwohl ich viel am Testen war, aber ebenfalls ohne Warnungen...
      Hat aber keinen Einfluss auf die Funktionalität des NSPanels
      • T TT-Tom
        Morgen
        CluniC Offline
        CluniC Offline
        Cluni
        schrieb am zuletzt editiert von Cluni
        #4370
        @tt-tom said in SONOFF NSPanel mit Lovelace UI:
        Sieht bei mir so aus:
        11:21:05.953 MQT: SmartHome/NSPanel_Flur/tele/STATE = {"Time":"2023-11-27T11:21:05","Uptime":"0T14:00:09","UptimeSec":50409,"Heap":122,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":35,"Objects":475},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Virus4free","BSSId":"38:10:D5:04:65:36","Channel":7,"Mode":"11n","RSSI":100,"Signal":-45,"LinkCount":2,"Downtime":"0T00:00:07"}}
        11:21:05.970 MQT: SmartHome/NSPanel_Flur/tele/SENSOR = {"Time":"2023-11-27T11:21:05","ANALOG":{"Temperature1":22.6},"ESP32":{"Temperature":53.9},"TempUnit":"C"}
        11:21:26.802 MQT: SmartHome/NSPanel_Flur/stat/STATUS0 = {"Status":{"Module":0,"DeviceName":"Tasmota","FriendlyName":["Tasmota",""],"Topic":"NSPanel_Flur","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Software reset CPU","Uptime":"0T14:00:30","StartupUTC":"2023-11-26T19:20:56","Sleep":0,"CfgHolder":4617,"BootCount":59,"BCResetTime":"2023-04-12T07:44:20","SaveCount":1218},"StatusFWR":{"Version":"13.2.0(nspanel)","BuildDateTime":"2023-10-19T09:05:12","Core":"2_0_14","SDK":"4.4.6.231011","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.0","CR":"519/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":2,"SysLog":0,"LogHost":"192.168.0.88","LogPort":514,"SSId":["Virus4free","Telemeasurement"],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","20006000","00004000","00000001"]},"StatusMEM":{"ProgramSize":1872,"Free":1007,"Heap":114,"StackLowMark":3,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["00000809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","010A80B1"],"Drivers":"1,2,3,4,5,7,8,9,10,11,12,14,16,17,20,21,24,26,27,29,34,35,38,50,52,59,60,62,63,66,67,68,82,86,87,88","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82"},"StatusNET":{"Hostname":"NSPanel-Flur-0792","IPAddress":"192.168.0.126","Gateway":"192.168.0.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.0.1","DNSServer2":"2003:c9:1f1f:3d00:7642:7fff:fe22:1eae","Mac":"80:64:6F:C3:A3:18","IP6Global":"2003:c9:1f1f:3d00:8264:6fff:fec3:a318","IP6Local":"fe80::8264:6fff:fec3:a318","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.0.1","DNSServer2":"2003:c9:1f1f:3d00:7642:7fff:fe22:1eae","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0},"StatusMQT":{"MqttHost":"192.168.0.88","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_C3A318","MqttUser":"tasmota","MqttCount":2,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2023-11-27T09:21:26","Local":"2023-11-27T11:21:26","StartDST":"2023-03-26T02:00:00","EndDST":"2023-10-29T03:00:00","Timezone":"+02:00","Sunrise":"09:16","Sunset":"17:58"},"StatusSNS":{"Time":"2023-11-27T11:21:26","ANALOG":{"Temperature1":22.6},"ESP32":{"Temperature":53.9},"TempUnit":"C"},"StatusSTS":{"Time":"2023-11-27T11:21:26","Uptime":"0T14:00:30","UptimeSec":50430,"Heap":112,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":35,"Objects":475},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Virus4free","BSSId":"38:10:D5:04:65:36","Channel":7,"Mode":"11n","RSSI":100,"Signal":-45,"LinkCount":2,"Downtime":"0T00:00:07"}}}
        PS: Ich hab mal die Timezone korrigiert... 🙈
        CluniC 1 Antwort Letzte Antwort
        • CluniC Cluni
          CluniC Offline
          CluniC Offline
          Cluni
          #4371
          Mal so als allgemeine Frage - ich bin nicht ganz so firm in JS: Wäre es nicht möglich, dass man für die eigenen Konfigurationen irgendwo (vielleicht unter global) eine Datei anlegt, so dass man nicht jedes Mal bei einem Update vom Skript mühsam die Sachen hin und her kopieren muss? Dass dann auch dort in der eigenen (ich nenne sie mal) Config-Datei ggf. Anpassungen notwendig sein könnten, ist logisch. Aber das würde die Sache denke ich stark vereinfachen.
          T ArmilarA 2 Antworten Letzte Antwort
          • CluniC Cluni
            TT-Tom
            #4372
            @cluni
            Möglich ist fast alles, nur der Aufwand ist da sehr groß und steht nicht in Relation zum Nutzen. Der Support würde auch steigen, der zu leisten wäre. Was dieser Thread auch zeigt. Wir haben den Bereich auch schon zusammengefasst und optimiert, damit ein Update nicht so kompliziert ist. Und so oft muss ja nicht mit gezogen werden, nur weil wir etwas anpassen. Erst wenn es deine Konstellation betrifft oder wir ein Breaking Change machen müssen.
            Ps sind deine Daten jetzt eigentlich da oder bekommst du immer noch Fehlermeldungen?
            Gruß Tom
            Public Transport
            • CluniC Cluni
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #4373
              Muss auch nicht... Die paar Variablen im Config-Bereich kann man sicher mit Hilfe der Wiki erstellen. Den Rest muss eigentlich niemand anfassen und das steht ja auch explizit drin ;-)
              Updates bedeutet eigentlich nur Copy/Paste des unteren Teils und dauert je Panel ca. 1-2 Minuten...
              Nein - da die TypeScript - Typenprüfung dann nicht mehr stattfinden kann und das wird massive Probleme im Support erzeugen, da jede fehlerhafte Variablendefinition zur Stecknadel im Heuhaufen wird...
              • T TT-Tom
                @cluni
                CluniC Offline
                CluniC Offline
                Cluni
                #4374
                @tt-tom Beide Warnings kommen nach wie vor. Aber damit kann ich leben. So richtig den Unterschied sehe ich nicht in den Ausgaben bei dir und bei mir in der Tasmota Konsole. Oder habe ich was übersehen?
                @Armilar Ok, das ist dann natürlich ein guter Grund. War ja auch nur so eine Idee.
                  TT-Tom
                  #4375
                  @cluni
                  also auspacken tut das Panel die Info
                  wie sieht den dein Zweig von Tasmota aus??
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    @cluni
                    CluniC Offline
                    CluniC Offline
                    Cluni
                    #4376
                    Ja, da sehen die Infos dürftig aus:
                    • T TT-Tom
                      @cluni
                      CluniC Offline
                      CluniC Offline
                      Cluni
                      #4377
                      @tt-tom gibt es denn einen bestimmten Grund, warum du die "normale", deutsche Version von Tasmota benutzt und nicht die Version extra fürs NSPanel?
                      Dein OTA-Link: http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin
                      Mein OTA-Link: http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin
                      Wo genau liegt denn der Unterschied in den Versionen?
                      • CluniC Cluni
                        TT-Tom
                        #4378
                        @cluni
                        Ist bei dir in der Java Instanz die SetObject Option aktiviert???
                        Gruß Tom
                        Public Transport
                        • T TT-Tom
                          @cluni
                          CluniC Offline
                          CluniC Offline
                          Cluni
                          #4379
                          @tt-tom jops
                          • CluniC Cluni
                            TT-Tom
                            #4380
                            @cluni
                            Warum es damals für das Panel eine Extra Version gab, kann ich dir nicht hundertprozentig sagen. Aber aktuell ist es egal welche Variante du einsetzt. Ich habe auf meinen Panels auch unterschiedliche Varianten. Stell aber keine Unterschiede fest.
                            Gruß Tom
                            Public Transport
                            • CluniC Cluni
                              @tt-tom jops
                              TT-Tom
                              #4381
                              @cluni
                              Kannst du bitte den Debug Modus vom Panel aktivieren und das Script nochmals starten und das log dann posten.
                              Gruß Tom
                              Public Transport
                              • T TT-Tom
                                @cluni
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #4382
                                @tt-tom
                                Verzeichnisse löschen und anlegen lassen...
                                Die tasmota32-nspanel Version wurde entwickelt, da es einen Bug gab, der das Panel in einen Boot-Loop brachte und zur Nutzung des optionale RAM. Ist aber mittlerweile in den regulären Versionen ebenfalls enthalten.
                                • ArmilarA Armilar
                                  @tt-tom
                                  CluniC Offline
                                  CluniC Offline
                                  Cluni
                                  #4383
                                  @armilar said in SONOFF NSPanel mit Lovelace UI:
                                  Soll ich den kompletten NSPanel-Zweig im Userbereich vor dem Start des Panels löschen, oder was meinst du?
                                  • CluniC Cluni
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #4384
                                    @cluni
                                    Nein, Alle Verzeichnisse (Datenpunkte) in 0_userdata.0 und alias.0, die das NSPanel automatisch angelegt hat löschen...
                                    Dann das Script neu starten und erneut anlegen lassen... Dann sollte auch alles gefüllt sein...
                                    CluniC ArmilarA 2 Antworten Letzte Antwort
                                    • ArmilarA Armilar
                                      @cluni
                                      CluniC Offline
                                      CluniC Offline
                                      Cluni
                                      #4385
                                      @cluni
                                      Das hat nichts geändert.
                                      Hier das LOG:
                                      16:12:46.069	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: compiling TypeScript source...
                                      16:12:47.598	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: source code did not change, using cached compilation result...
                                      16:12:47.937	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: setObjects enabled - create Alias Channels possible
                                      16:12:47.968	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: weather alias for accuweather.0. already exists
                                      16:12:48.104	warn	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: error at function check_updates: Cannot read properties of null (reading 'split')
                                      16:12:48.105	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: registered 30 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      16:12:48.843	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Desired TFT Firmware: 53 / v4.3.3
                                      16:12:48.844	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Installed TFT Firmware: 53 / v4.3.3
                                      16:12:49.139	warn	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: error setState in function get_tasmota_status0Cannot read properties of undefined (reading 'Version')
                                      16:12:49.154	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Debug mode activated
                                      16:12:49.395	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: get_current_tasmota_ip_address: 192.168.0.126
                                      16:12:49.814	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting tasmota firmware version
                                      16:12:49.819	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting current berry driver version
                                      16:12:49.820	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: get_current_tasmota_ip_address: 192.168.0.126
                                      16:12:49.822	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting online berry driver version
                                      16:12:49.823	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting online TFT version
                                      16:12:49.825	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Requesting online firmware version
                                      16:12:50.192	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online display firmware version => 53
                                      16:12:50.310	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online TFT firmware version => 4.3.3
                                      16:12:50.334	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: current berry driver version => undefined
                                      16:12:50.417	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online berry driver version => 9
                                      16:12:50.509	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: online tasmota firmware version => 13.2.0
                                      16:12:53.489	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: Start MQTT-Port-Check -------------------------------------
                                      16:12:53.490	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- admin.0 - 8081
                                      16:12:53.490	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- hm-rpc.0 - 0
                                      16:12:53.491	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- hue.0 - 443
                                      16:12:53.491	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- influxdb.0 - 8086
                                      16:12:53.491	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- mihome-vacuum.0 - 5432
                                      16:12:53.492	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- mqtt.0 - 1883
                                      16:12:53.492	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- shelly.0 - 1882
                                      16:12:53.492	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- telegram.0 - 8443
                                      16:12:53.493	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- web.0 - 8082
                                      16:12:53.493	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: -- zigbee.0 - /dev
                                      16:12:53.493	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1883
                                      16:12:53.494	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: End MQTT-Port-Check ---------------------------------------
                                      16:12:59.307	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: moments.js --> Datum 2023-11-27T08:10:00+01:00 valid?: true
                                      16:12:59.310	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: HandleScreensaverUpdate payload: weatherUpdate~~~~25407~~4.5 °C~~~~65363~Sonne~08:10~~~~26095~Wind~4.7m/s~~~~34351~Böen~9.5m/s~~~~65535~Windr.~180°~
                                      16:12:59.315	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: HandleMessage -> sleepReached
                                      16:13:00.039	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: moments.js --> Datum 2023-11-27T08:10:00+01:00 valid?: true
                                      16:13:00.042	info	javascript.0 (1030239) script.js.NSPanels.Panel_Flur: HandleScreensaverUpdate payload: weatherUpdate~~~~25407~~4.5 °C~~~~65363~Sonne~08:10~~~~26095~Wind~4.7m/s~~~~34351~Böen~9.5m/s~~~~65535~Windr.~180°~
                                      • CluniC Cluni
                                        @cluni
                                        Hier das LOG:
                                        CluniC Offline
                                        CluniC Offline
                                        Cluni
                                        #4386
                                        Liegt das am Berry driver?
                                        Den habe ich aber auch gestern noch auf den neusten Stand gebracht über den Befehl:
                                        Backlog UrlFetch https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be; Restart 1
                                        • ArmilarA Armilar
                                          @cluni
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #4387
                                          Update v4.3.3.14
                                          Was ist passiert?
                                          Der Sonos-Media-Player hat ne Menge Funktionalität bekommen und hat sich zu einem richtig coolen Player entwickelt...
                                          • anlegen von Playlists jetzt Möglich
                                          • automatisches Abgreifen der Tracklist
                                          • Favoritenliste wird angezeigt (und kann natürlich auch bedient werden)
                                          • Equalizer kann alternativ zur Favoritenliste genutzt werden
                                          • kleinere Fixes zu den Funktionen von gestern (Die anderen Player)
                                          Tester gesucht:
                                          Da ich leider nur eine der ersten Sonos One habe, ist ein umfänglicher Sonos Test natürlich nicht einfach. Daher würde ich die Sonos-User unter euch kurz um ein Feedback bitten...
                                          Was ist neu an der Seitenvariable?
                                          Player mit Favoriten:
                                          let Sonos = <PageMedia>
                                              'type': 'cardMedia',
                                              'heading': 'Sonos',
                                              'useColor': true,
                                              'items': [<PageItem>{
                                                          id: AliasPath + 'Media.PlayerSonos',
                                                          adapterPlayerInstance: 'sonos.0.',
                                                          mediaDevice: '192_168_1_212',
                                                          speakerList: ['Terrasse'],
                                                          playList: ['Hartmann','Armilars Playlist'],
                                                          colorMediaIcon: colorSonos,
                                                          colorMediaArtist: Yellow,
                                                          colorMediaTitle: Yellow,
                                                          alwaysOnDisplay: true,
                                                          autoCreateALias: true
                                          Player mit Equalizer:
                                              'heading': 'Sonos',
                                              'useColor': true,
                                                          equalizerList: ['Bassboost','Klassik','Dance', 'Deep', 'Electronic', 'Flat', 'Hip-Hop', 'Rock',
        'Metal', 'Jazz', 'Latin', 'Tonstärke', 'Lounge', 'Piano'],
                                          wie gestern im Update schon verfügbar, gibt es die Funktion alwaysOnDisplay: true,. Damit bekommt der Player noch einmal einen richtigen Schub...
                                          Da es kein verfügbares Sonos-Logo gibt, habe ich mal einen Kreis mit einem "S" verwendet und die aktuellen Sonosfarben benutzt.
                                          const colorSonos:       RGB = { red: 216, green: 161, blue:  88 };
                                          einfach irgendwo zwischen den Konstanten einfügen, falls ihr die Farbe nutzen möchtet:
                                          So und das wars auch schon wieder...
                                          Viel Spaß beim ausprobieren.
                                          LG
                                          @TT-Tom & Armilar 😊
                                          P.S: Den Rest der Woche habt ihr jetzt "Release-Ruhe" von meiner Seite ;-)
                                          EDIT: Das NSPanelTs.ts bekommt ihr natürlich wie immer hier:
                                          https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
                                          Es reicht, den unteren Teil ab:
                                          zu tauschen.
