  4. Kein Zugriff auf Vis edit runtime und flot üner interne IP
    6.1k
23 Beiträge 5 Kommentatoren 2.8k Aufrufe 5 Beobachtet
  • K Karacho
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi4-iob
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     20:56:35 up  1:10,  1 user,  load average: 0.68, 0.55, 0.72
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sun 2023-11-26 20:56:36 CET
               Universal time: Sun 2023-11-26 19:56:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.4G        2.0G        8.0M        435M        2.3G
    Swap:           99M          0B         99M
    Total:         3.9G        1.4G        2.1G
             3837 M total memory
             1396 M used memory
              292 M active memory
             1436 M inactive memory
             2006 M free memory
               93 M buffer memory
              341 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    * lightdm.service       loaded failed failed Light Display Manager
    2 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   43G   14G  77% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Sun Nov 26 19:46:10 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:61:2C:40 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Nov 26 19:46:12 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Sun Nov 26 19:46:12 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sun Nov 26 19:46:13 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.2G    /var/
    1.9G    /var/cache/apt
    1.9G    /var/cache
    1.8G    /var/cache/apt/archives
    117M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    194M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    698M    /opt/iobroker/iobroker-data/history
    278M    /opt/iobroker/iobroker-data/files
    134M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    17M     /opt/iobroker/iobroker-data/states.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   4
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
    + system.adapter.bmw.0                    : bmw                   : raspberrypi4-iob                         -  enabled
    + system.adapter.bosch-ebike.0            : bosch-ebike           : raspberrypi4-iob                         -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi4-iob                         -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi4-iob                         -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi4-iob                         -  enabled
      system.adapter.devices.0                : devices               : raspberrypi4-iob                         - disabled
    + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi4-iob                         -  enabled
    + system.adapter.easee.0                  : easee                 : raspberrypi4-iob                         -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : raspberrypi4-iob                         -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4-iob                         -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         - disabled
    + system.adapter.harmony.0                : harmony               : raspberrypi4-iob                         -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi4-iob                         -  enabled
    + system.adapter.history.0                : history               : raspberrypi4-iob                         -  enabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi4-iob                         -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4-iob                         -  enabled
      system.adapter.hs100.0                  : hs100                 : raspberrypi4-iob                         - disabled
      system.adapter.ical.0                   : ical                  : raspberrypi4-iob                         -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4-iob                         - disabled
    + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
    + system.adapter.meater.0                 : meater                : raspberrypi4-iob                         -  enabled
    + system.adapter.mercedesme.0             : mercedesme            : raspberrypi4-iob                         -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi4-iob                         -  enabled, port: 54321
      system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi4-iob                         - disabled, port: 54321
    + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi4-iob                         -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi4-iob                         -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi4-iob                         -  enabled
    + system.adapter.smartgarden.0            : smartgarden           : raspberrypi4-iob                         -  enabled
    + system.adapter.solarlog.0               : solarlog              : raspberrypi4-iob                         -  enabled, port: 80
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi4-iob                         -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-iob                         -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4-iob                         - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi4-iob                         -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi4-iob                         -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4-iob                         - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : raspberrypi4-iob                         -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iob                         -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bmw"          : 2.5.7    , installed 2.6.1
    Adapter    "bosch-ebike"  : 0.0.3    , installed 0.1.0
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "easee"        : 1.0.10   , installed 1.0.10
    Adapter    "ems-esp"      : 2.6.1    , installed 2.6.1
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hs100"        : 2.2.0    , installed 2.2.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "km200"        : 2.0.3    , installed 2.0.3
    Adapter    "meater"       : 1.0.2    , installed 1.0.2
    Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "solarlog"     : 2.2.8    , installed 2.2.8
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
    Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "wireguard"    : 1.6.1    , installed 1.6.1
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        15752
    States:         13681
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13108      628/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16274      379/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       44781      4274/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       46193      4061/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       45103      4061/iobroker.js-co
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44603      4079/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       50700      5209/io.web.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       51699      5461/io.nuki-extend
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13110      628/sshd
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          19511      622/xrdp-sesman
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16273      379/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      109        21762      641/xrdp
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       47257      4419/io.harmony.0
    udp        0      0 0.0.0.0:36381           0.0.0.0:*                           108        12730      401/avahi-daemon: r
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       47258      4419/io.harmony.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17296      614/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15254      489/cups-browsed
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       47151      4330/io.broadlink2.
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       43968      4259/io.mihome-vacu
    udp        0      0 0.0.0.0:57560           0.0.0.0:*                           1001       47154      4330/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12728      401/avahi-daemon: r
    udp        0      0 0.0.0.0:41823           0.0.0.0:*                           1001       44877      4330/io.broadlink2.
    udp6       0      0 :::46088                :::*                                108        12731      401/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12729      401/avahi-daemon: r
    2023-11-26 20:49:53.431  - info: admin.0 (4079) <== Disconnect system.user.admin from ::ffff:192.168.178.44 admin
    2023-11-26 20:49:57.570  - info: admin.0 (4079) <== Disconnect system.user.admin from ::ffff:192.168.178.44 admin
    2023-11-26 20:50:00.850  - info: host.raspberrypi4-iob instance system.adapter.dwd.0 started with pid 5837
    2023-11-26 20:50:04.222  - info: dwd.0 (5837) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
    2023-11-26 20:50:06.855  - info: dwd.0 (5837) State value to set for "dwd.0.warning1.begin" has to be type "string" but received type "number"
    2023-11-26 20:50:06.861  - info: dwd.0 (5837) State value to set for "dwd.0.warning1.end" has to be type "string" but received type "number"
    2023-11-26 20:50:06.903  - info: dwd.0 (5837) State value to set for "dwd.0.warning2.begin" has to be type "string" but received type "number"
    2023-11-26 20:50:06.948  - info: dwd.0 (5837) State value to set for "dwd.0.warning2.end" has to be type "string" but received type "number"
    2023-11-26 20:50:07.001  - info: dwd.0 (5837) State value to set for "dwd.0.warning3.begin" has to be type "string" but received type "number"
    2023-11-26 20:50:07.052  - info: dwd.0 (5837) State value to set for "dwd.0.warning3.end" has to be type "string" but received type "number"
    2023-11-26 20:50:07.174  - info: dwd.0 (5837) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-26 20:50:07.721  - info: host.raspberrypi4-iob instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-26 20:50:31.425  - info: admin.0 (4079) <== Disconnect system.user.admin from ::ffff:192.168.178.44 admin
    2023-11-26 20:51:16.753  - error: easee.0 (4408) RefreshToken error
    2023-11-26 20:51:16.755  - error: easee.0 (4408) AxiosError: Request failed with status code 504
    2023-11-26 20:55:00.058  - info: host.raspberrypi4-iob instance system.adapter.dwd.0 started with pid 6034
    2023-11-26 20:55:03.262  - info: dwd.0 (6034) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
    2023-11-26 20:55:05.759  - info: dwd.0 (6034) State value to set for "dwd.0.warning1.begin" has to be type "string" but received type "number"
    2023-11-26 20:55:05.808  - info: dwd.0 (6034) State value to set for "dwd.0.warning1.end" has to be type "string" but received type "number"
    2023-11-26 20:55:05.866  - info: dwd.0 (6034) State value to set for "dwd.0.warning2.begin" has to be type "string" but received type "number"
    2023-11-26 20:55:05.918  - info: dwd.0 (6034) State value to set for "dwd.0.warning2.end" has to be type "string" but received type "number"
    2023-11-26 20:55:05.965  - info: dwd.0 (6034) State value to set for "dwd.0.warning3.begin" has to be type "string" but received type "number"
    2023-11-26 20:55:05.971  - info: dwd.0 (6034) State value to set for "dwd.0.warning3.end" has to be type "string" but received type "number"
    2023-11-26 20:55:06.058  - info: dwd.0 (6034) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-26 20:55:06.588  - info: host.raspberrypi4-iob instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    CodierknechtC Online
    Codierknecht
    @karacho
    Buster ist EOL.
    Das solltest Du dringend updaten.
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    • CodierknechtC Codierknecht
      @karacho
      Buster ist EOL.
      Karacho
      @codierknecht
      Was meinst Du? Was ist Buster?
      Thomas BraunT K 2 Antworten Letzte Antwort
      • K Karacho
        @codierknecht
        @karacho sagte in Kein Zugriff auf Vis edit runtime und flot üner interne IP:
        Was ist Buster?
        Der Releasename deines Betriebssystems.
        Ist aber abgekündigt, installier da neu in der 64Bit-Light-Version das aktuelle Release 'Bookworm'.
        • K Karacho
          @codierknecht
          Karacho
          @karacho said in Kein Zugriff auf Vis edit runtime und flot üner interne IP:
          @codierknecht
          Bin keine Experte, aber löst das mein Problem?
          Kann ich so updaten... habe externe Festplatte...
          https://www.youtube.com/watch?v=P_iq1bLFzrg
          Oder muss ich neu aufsetzen?
          • K Karacho
            @codierknecht
            @karacho
            64Bit nur per Neuinstallation.
              @karacho
              Karacho
              Kann ich erst einmal das aktuelle Problem lösen? Oder liegt das am Buster OS?
              • K Karacho
                @karacho
                Keine Ahnung. Aber das Betriebssystem ist abgekündigt, muss ersetzt werden. Das schau ich mir doch gar nicht weiter an.
                  @karacho
                  Karacho
                  Für Dich mag das ja easy sein... Aber ich bin Anwender und bin froh, dass ich im Iobroker eine VIS erstellen kann...
                  Raspberry neu aufsetzen ist heftig für mich... keine Ahnung wie ich dann wieder an meine iobroker "progammierung" komme, geschweige denn ein Backup von der VIS wieder einspiele....
                  Keine Chance wieder an meine lokale Vis zu kommen?
                  • K Karacho
                    @karacho
                    Den Backitup-Adapter kennst du?
                      @karacho
                      Karacho
                      schrieb am zuletzt editiert von Karacho
                      Ja, ich sichere BackUps auf NAS und OneDrive zigbee, java, history ioborker
                      Wenn ich den neue aufsetze, dann brauche ich eine Kochrezept. vor allem weil ich mit externer Festplatte und nicht SD Card arbeite
                      • K Karacho
                        @karacho
                        Nimm den Raspberry OS Imager.
                          @karacho
                          Karacho
                          Kurze blöde Frage:
                          In mehreren Beiträgen ist in BackitUp Instanz ein Folder wiederherstellen. Bei mir finde ich keinen....
                          • K Karacho
                            Kurze blöde Frage:
                            Was meinst du genau?
                              Karacho
                              wir kann ich mit dem BackitUp Adapter eine frühere Version einspielen? Bei anderen Screenshots war der da...
                              Oder wie kann ich eine BackUp wiederherstellen bzw auf einen früheren Stand?
                              Wo ist der Folder "wiederherstellen"?
                              • K Karacho
                                Codierknecht
                                @karacho
                                Nicht in den Instanzeinstellungen, sondern über das Menü links.
                                • K Karacho
                                  ich kann über meine interne IP http://192.168.178.x weder auf vis editor, vis runtime noch flot zugreifen.
                                  Über iobroker.pro kann ich auf alles zugreifen.
                                  Über http://192.168.178.x:8082/ funktioniert nur Admin.
                                  Kann mir jemand weiterhelfen?
                                  Danke.
                                  Gruss
                                  Karacho
                                  lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  @karacho und ich kann kein vis edit mehr aufrufen. Gleicher Fehler mit "no connection". Es funktioniert aber vis normal und flot.
                                  Eigentlich bin ich up-to-date.
                                  Zuletzt gab es paar Updates... ich meine der web-Adapter... und ich habe mal testweise vis2 installiert...
                                  Host: NUC8i3 mit Proxmox:
                                  • Slave: Pi4
                                  • lobomauL lobomau
                                    Karacho
                                    @lobomau
                                    ich habe heute mal einen alten Stand eingespielt....
                                    jetzt funktioniert wieder alles...
                                    folgende Adapter sind jetzt nicht aktuell.... einer von diesen muss es sein....
                                    Bereite mich jetzt mal vor Bullseye zu installieren......
                                    lobomauL 2 Antworten Letzte Antwort
                                    • K Karacho
                                      @lobomau
                                      lobomauL Offline
                                      lobomauL Offline
                                      lobomau
                                      @karacho ok, also ich habe von den Adaptern nur Script Engine und justGage Widgets.
                                      Ich habe nun ein ganz anderes Problem... wegen des oberen Problems habe ich den proxmox neugestartet und nun geht gar nix mehr 😖 ... aber das hat mit dem Thema hier nix zu tun...
                                      • Slave: Pi4
                                      • K Karacho
                                        @lobomau
                                        lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        schrieb am zuletzt editiert von lobomau
                                        @karacho bin wieder am Start :-)
                                        Also... justGage Widget war es nicht bei mir.... bin auf 2.0.0. ohne Verbesserung.
                                        Dann bin ich mit vis auf Version 1.4.12. Und es geht wieder :-D
                                        Vorher hatte ich die 1.4.16.
                                        Edit.: bin nun wieder auf 1.4.16 und es funktioniert wieder.
                                        • Slave: Pi4
                                        • werner2000xW Offline
                                          werner2000x
                                          Ich kann mit meinem Android Tablet mit Chrome nicht mehr auf VIS Runtime und Edit zugreifen. Die Seiten sind leer. Auf meinem PC geht das in Chrome. In Android klappt alles auch mit allen anderen Browsern.Was kann das sein?
                                          Raspi4 8 GB mit Aqara Zigbee USB, iob
                                          Innogy Smarthome
                                          Bosch Bridge 2
                                          HUE Bridge
                                          OpenWB Wallbox mit EVU Kit
                                          Google Nest Pro Hub
                                          HA auf uGreen dxp4800
