    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • S SirMiker
    javascript.0 (23087) script.js.NSPANEL: TypeScript compilation failed: let name = <PageGrid>{ ^ ERROR: Conversion of type '{ type: "cardType"; heading: string; useColor: true; items: undefined[]; }' to type 'PageGrid' may be a mistake because neither type sufficiently overlaps with the other. If this was intentional, convert the expression to 'unknown' first. Type '{ type: "cardType"; heading: string; useColor: true; items: undefined[]; }' is missing the following properties from type 'PageGrid': subPage, parent, parentIcon, parentIconColor, and 9 more. let, name = <PageGrid>{ ^ ERROR: Identifier expected. 'let' is a reserved word in strict mode. Modules are automatically in strict mode. let, name = <PageGrid>{ ^ ERROR: No value exists in scope for the shorthand property 'let'. Either declare one or provide an initializer. let, name = <PageGrid>{ ^ ERROR: Did you mean to use a ':'? An '=' can only follow a property name when the containing object literal is part of a destructuring pattern. let, name = <PageGrid>{ ^ ERROR: Conversion of type '{ type: "cardType"; heading: string; useColor: true; items: undefined[]; }' to type 'PageGrid' may be a mistake because neither type sufficiently overlaps with the other. If this was intentional, convert the expression to 'unknown' first. Type '{ type: "cardType"; heading: string; useColor: true; items: undefined[]; }' is missing the following properties from type 'PageGrid': subPage, parent, parentIcon, parentIconColor, and 9 more.
    das habe ich eingefügt
               NSPanel_Service         	//Auto-Alias Service Page
    	    //Unlock_Service            //Auto-Alias Service Page (Service Pages used with cardUnlock)
        'type': 'cardType',
        'heading': 'Eckstein',
        'useColor': true,
        'items': []
        subPages: [
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #4288
    @sirmiker
    viel wichtiger ist es jetzt zu zeigen, was du überhaupt in das Script eingefügt hast. Das der Fehler kommt, hat sicherlich etwas mit den folgenden Punkten zu tun.
    • Variablendefinition falsch
    • PageItem falsch
    • Komma in der Auflistung vergessen
    • Alias nicht über Geräte-Manager erstellt
    Also mehr Input zu deinen Aktionen als zum Fehler...
    • S SirMiker
          'type': 'cardType',
          'useColor': true,
          'items': []
          subPages: [
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      #4289
      @sirmiker sagte in SONOFF NSPanel mit Lovelace UI:
          'type': 'cardType',
          'useColor': true,
          'items': []
          subPages: [
      Das ist völlig falsch...
      Die Variablendefinition einer Seite befindet sich immer im oberen Teil des Scriptes...
      Die Seite selbst wird später nur in das page-Array in der Config eingetragen...
      Sieh dir mal das Service-Menü an... Das ist im Prinzip schon eine gute Anleitung...
      Hier nochmal ein Beispiel wie es korrekt wäre:
      Im oberen Teil wird eine Seite definiert...
      im pages-Array rufe ich die Seite an der richtigen Position auf...
      Alles andere steht auch in einer richtig umfänglichen Wiki... die muss man aber lesen...
      Hier mal die wichtigsten Seiten:
      • https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)
      • https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-‐-Typen_How-2_Beispiele#how-2-page
      Und ganz viele Beispiele:
      https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen
      Der Rest ist auch nicht uninteressant...
      Jetzt noch ein kleines Beispiel für eine cardGrid:
      let Radiosender = <PageGrid>
          'type': 'cardGrid',
          'heading': 'Büro 2',
          'useColor': true,
          'items': [
              <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Bob', icon: 'radio', name: 'Radio BOB', onColor: colorRadio},
              <PageItem>{ id: 'alias.0.NSPanel_1.Countdown', icon: 'timer-outline', name: 'Timer', onColor: White}
      Das ist bei mir die "Test"-Seite Radiosender. Jedes PageItem ist ein Steuerelement und muss mit einem "nicht selbstgebauten" Alias (https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen) erstellt werden und unter "id:" im PageItem eingetragen werden. Das Script sucht sich über den Alias-Channel dann den richtigen Typen zur Darstellung raus...
      Das Ergebnis in diesem Beispiel:
      Eine cardGrid mit einem Button um einen Radiosender zu starten und ein popupTimer
      Noch detaillierte für z.B. den Radiosender ist es hier beschrieben:
      https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen#9-alias-taste-für-auswahl-eines-radiosenders
      Wenn man das Erstellen erst einmal verstanden hat, dann geht es sehr schnell...
      • ArmilarA Armilar
        @stephan-l
        Im ioBroker ist vieles einfacher. Kein AppDaemon und kein Yaml.
        Das Script muss nicht angepasst werden, denn es lässt sich alles über die Datenpunkte steuern. Hierfür haben wir auch ein Service-Menü bereitgestellt:
        Solltest du dann doch ein Feature Request benötigen, so kannst du es wie gewohnt im Github mit dem "Tag" ioBroker machen...
        https://github.com/joBr99/nspanel-lovelace-ui/issues
        Stephan LS Offline
        Stephan LS Offline
        Stephan L
        #4290
        @armilar said in SONOFF NSPanel mit Lovelace UI:
        Ich will folgendes Format: "%A - %m/%d/%Y"
        Im Klartext (fuer USA): Saturday - 11/18/2023
        Leider finde ich keine Schalter die mir das erlauben.
        Aber: meine kleine Aenderung fuegt einen Datenpunkt hinzu der mir die Kontrolle gibt. Keine TS leider nicht genug um zu wissen ob man absolute Freiheit wie in anderen Sprachen. Daher ist mein aktuelles Format: 'Saturday, 11/1/2023'.
        FAST richtig.
        • ArmilarA Armilar
              'type': 'cardType',
              'useColor': true,
              'items': []
              subPages: [
              'type': 'cardGrid',
              'useColor': true,
              'items': [
          SirMiker
          schrieb am zuletzt editiert von SirMiker
          #4291
          @armilar
          wirklich vielen dank für die ausführliche Erklärung!
          das mit der Pages klappt null bei mir....und ich verstehe auch mit durchlesen gar nicht was ich da machen muss...sorry...denke da habe ich mir diesmal eindeutig Zuviel vor genommen :(
           pages: [
          Dort muss ich nach Pages den Namen einfügen den ich vergeben habe oder?
          • Stephan LS Offline
            Stephan LS Offline
            Stephan L
            #4292
            Ich verwende das 'alternative' screensaver Layout.
            Leider scheint das ein paar Problemchen zu haben.
            Links sind 2 Eintraege uebereinander, daneben sind 3 weitere nebeneinander.
            Problem: Der OBERE auf der linken Seite ist bei ioBroker IMMER das Wetter!
            Im Script zu finden beim Komentar (//Create Weather MainIcon)
            Mein Panel mit AppDaemon:
            Hier im Bild von AppDaemon sieht man dass ich dort was anderes hingelegt habe. Habe das aktuelle Wetter als erstes in der 3er Reihe (geht aber auch ganz ohne Wetter, meine Wahl)
            Ich ja bereits alle Werte und Infos in HA, daher verwende ich den ioBroker HA Adapter. Genial...
            Von dort kommt auch mein momentaner Stromverbrauch. Den konnte ich auch mit ioBroker anzeigen lassen. Aber warum auch immer wurde der Wert als 'String' erkannt. Und im Code gibt es dubiose logik die dann den Wert, z.B. "793" als DATUM umformatiert.
            Dafuer konnte ich einen einfachen Fix machen.
            Ein String x, der folgendes erfuellt ist KEIN Datum:
            if (parseFloat(val+"") == val)      // I have number that would fit this
                 val = parseFloat(val)
            Dann habe ich den State von 2 Lichtern (die letzten beiden in der Reihe unter dem Datum)
            Ich haette gerne wie mit AppDaemon das Icon in WEISS wenn das Licht aus ist und in Gelb wenn es an ist. Hab ich bisher nicht geschafft.
            Und zuletzt habe ich den State unter dem Icon. Auch hier konnte ich das in AppDaemon etwas schoener machen und den 1. Buchstaben mit 'capitalize' auf gross umstellen.
            Beides scheint es hier nicht zu geben?
            ArmilarA 2 Antworten Letzte Antwort
            • Stephan LS Stephan L
              FAST richtig.
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #4293
              @stephan-l
              Okay - ich denke du meinst dann wohl das
              Wir sind im ioBroker noch nicht ganz so International unterwegs... Ich werde mir für die Zukunft mal etwas überlegen.
              Damit sollte es aber funktionieren:
              const event = new Date();
              let weekday = event.toLocaleString('en-US', { weekday: 'long' });
              let day = event.toLocaleString('en-US', { year: 'numeric', month: '2-digit', day: '2-digit'});
              console.log(weekday + ' - ' + day)
              Stephan LS 1 Antwort Letzte Antwort
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                #4294
                @stephan-l sagte in SONOFF NSPanel mit Lovelace UI:
                1)
                Zu 1)
                Stimmt - mache bitte einen Feature Request:
                wir implementieren dann noch:
                ScreensaverEntityOnColor: Yellow,
                ScreensaverEntityOffColor: White
                Zu 2)
                Kannst du über den Alias verändern:
                Habe hier mal einen Datenpunkt, der "on"/"off" (klein) enthält
                Device-Manager
                unter fx:
                val.charAt(0).toUpperCase() + val.slice(1);
                Ergebnis:
                Stephan LS 2 Antworten Letzte Antwort
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #4295
                  if (parseFloat(val+"") == val)      // I have number that would fit this        val = parseFloat(val)
                  ... sehen wir uns an und machen einen Fix
                  • ArmilarA Armilar
                    @stephan-l
                    Stephan LS Offline
                    Stephan LS Offline
                    Stephan L
                    #4296
                    const dayjs = require('dayjs');
                    console.error(dayjs().format('dddd - DD/MM/YYYY'));
                    Bingo... der format-string kann dann ein Datenobjekt sein. Damit kann ich wie in anderen Sprachen das ganze komplett formatieren!
                    Siehe auch: https://day.js.org/docs/en/display/format
                    Ich bin kein Experte, habe aber wo gelesen dass 'moment' nicht mehr aktualisiert wird? Egal... DayJS kann alles was du brauchst mit minimalem Aufwand und 100% flexibel!
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #4297
                      @stephan-l
                      sieht wirklich nach einer guten Lösung aus
                      • ArmilarA Armilar
                        1)
                        Zu 1)
                        Zu 2)
                        Device-Manager
                        unter fx:
                        Ergebnis:
                        Stephan LS Offline
                        Stephan LS Offline
                        Stephan L
                        #4298
                        Zu 2)
                        Naja, dann muss ich also alles doppelt machen? Wenn ich im Panel ein anderes Licht anzeigen will, dann muss ich einen neuen Alias machen UND dann noch im TS skript das andere Licht anwaehlen. Also dopplete Arbeit? Oder hab ich was falsch verstanden?
                        • ArmilarA Armilar
                          Stephan LS Offline
                          Stephan LS Offline
                          Stephan L
                          #4299
                          Yay! Das waere Supi....
                          Ich will auf keinen Fall auf AppDaemon zurueck. NSPanel mit ioBroker ist 10000000x mehr responsive!
                          Aber.... manches geht halt nicht ;-) Aber ich hoffe wir bekommen das hin.
                          Danke fuer die super schnellen Antworten!
                          • S SirMiker
                            @armilar
                             pages: [
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #4300
                            @sirmiker
                            Gib uns mal ein Anwendungsbeispiel für einen leichten Einstieg. Was soll als erstes passieren?
                            Eine neue Seite mit einer Lampe einbinden?
                            Dann benötigen wir erst einmal einen Datenpunkt der Lampe.
                            Step by Step...
                              ArmilarA Offline
                              ArmilarA Offline
                              Armilar
                              #4301
                              Aber.... manches geht halt nicht Aber ich hoffe wir bekommen das hin.
                              Klar bekommen wir das hin 😊
                              Am Besten aber in einen Feature Request auf Github. Dann geht es nicht so schnell verloren wie in diesem Thread...
                              Du bist dann der erste "Test-Amerikaner" für das NSPanel im ioBroker ;-)
                              Kannst natürlich auch "Pull Requests" machen, falls die Lösung schon bekannt ist...
                              • ArmilarA Armilar
                                1)
                                Zu 1)
                                Zu 2)
                                Device-Manager
                                unter fx:
                                Ergebnis:
                                Stephan LS Offline
                                Stephan LS Offline
                                Stephan L
                                #4302
                                https://github.com/joBr99/nspanel-lovelace-ui/issues/1045
                                • ArmilarA Armilar
                                  Stephan LS Offline
                                  Stephan LS Offline
                                  Stephan L
                                  #4303
                                  Ich denke das liegt daran dass doch einiges auf Deutsch dokumentiert ist ;-) Sowohl online als auch im Code.
                                  Nach 15+ Jahren USA ist Englisch eigentlich fuer mich inzwischen einfacher hahaha. Zumindest gefuehlt ;-)
                                  Aber 30 Jahre Deutsch vergisst man dann ja doch nicht so schnell....
                                  Ich mache gerne PullRequest wenn es da nicht so viele Huerden gibt.
                                  In manchen Projekten ist das mega unkompliziert und in manchen eher das Gegenteil.
                                  Wenn es OK ist wuerde ich den Datumsfix machen, so als tester.
                                  Passt das? Ich wuerde dafuer gerne ein DatenObjekt nehmen das, wenn es exisitiert die UI Schalter ignoriert. Und es waere gut wenn eine Aenderung am DatenObjekt direkt erkannt wird und dann ein neues Datum rausgeschickt wird.
                                  Geht das? Wenn ja, wie?
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #4304
                                    Passt das?
                                    Ja, natürlich
                                    Habe ich noch nicht ganz verstanden. Meinst du als Daten-Objekt einen Datenpunkt unter 0_userdata.0. das durch das Script inoitial erstellt wird?
                                    • ArmilarA Armilar
                                      @stephan-l
                                      Stephan LS Offline
                                      Stephan LS Offline
                                      Stephan L
                                      #4305
                                      Habe PR erstellt (https://github.com/joBr99/nspanel-lovelace-ui/pull/1046)
                                      • ArmilarA Armilar
                                        Passt das?
                                        Ja, natürlich
                                        Stephan LS Offline
                                        Stephan LS Offline
                                        Stephan L
                                        #4306
                                        Ja und nein... Datenpunkt unter dem panel basis pfad (.Config.Dateformat.customFormat)
                                        Der soll aber ja optional sein. Der user kann das anlegen und es wird verwendet. Der user loescht es wieder und die UI toggles gehen wieder.
                                        Was ich gemerkt habe, wenn ich in der UI die Locale einstelle passiert nix bis ich das TS Skript neu starte!
                                        Grund: die Locale wird ganz am Anfang gesetzt:
                                        const parseFormat = require('moment-parseformat');
                                        moment.locale(getState(NSPanel_Path + 'Config.locale').val);
                                        Der neue dayjs macht das jetzt genau gleich.
                                        Selbst Panel neustart hilft daher nicht.
                                        Was fehlt ist code der Locale change erkennt und dann
                                        moment.locale(getState(NSPanel_Path + 'Config.locale').val); ausfuehrt.
                                        Und mit meiner Aenderung dann auch dayjs.locale(getDayjsLocale());
                                          Stephan LS Offline
                                          Stephan LS Offline
                                          Stephan L
                                          #4307
                                          @stephan-l
                                          Also sowas wie
                                          on({id: [].concat(NSPanel_Path + 'Config.Locale'), change: "ne"}, async function (obj) {
                                          Da ich den syntax hier nicht kenne ist das kein fertiger Code, nur die Erklaerung was ich meine.
