  4. ioBroker.Unifi verbindet nicht (Erstinstallation)
    6.3k
31 Beiträge 4 Kommentatoren 4.0k Aufrufe 5 Beobachtet
  • D DiMe
    @ilovegym
    Hi, hier der komplette Log.
    Über die Node-Version bin ich auch schon gestolpert.
    Habe gerade das "Lies mich" nochmals genauer durchgelesen.
    Dort wird auf eine Modul für Node hingewiesen:
    https://github.com/jens-maus/node-unifi
    Aber wie zum Kuckuck kann ich ein Nodemodul installieren.
    unifi.0
    2023-11-16 14:07:21.386	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    unifi.0
    2023-11-16 14:07:21.385	debug	Plugin sentry destroyed
    unifi.0
    2023-11-16 14:07:21.384	info	terminating
    unifi.0
    2023-11-16 14:07:21.383	info	cleaned everything up...
    unifi.0
    2023-11-16 14:07:21.381	info	Got terminate signal TERMINATE_YOURSELF
    unifi.0
    2023-11-16 14:07:21.272	error	Adapter deactivated due to missing configuration.
    unifi.0
    2023-11-16 14:07:21.271	info	UniFi adapter is ready
    unifi.0
    2023-11-16 14:07:21.229	info	starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v16.19.1, js-controller: 4.0.24
    unifi.0
    2023-11-16 14:07:20.841	debug	Plugin sentry Initialize Plugin (enabled=true)
    unifi.0
    2023-11-16 14:07:20.772	debug	States connected to redis: 127.0.0.1:9000
    unifi.0
    2023-11-16 14:07:20.702	debug	States create User PubSub Client
    unifi.0
    2023-11-16 14:07:20.700	debug	States create System PubSub Client
    unifi.0
    2023-11-16 14:07:20.686	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    unifi.0
    2023-11-16 14:07:20.656	debug	Objects connected to redis: 127.0.0.1:9001
    unifi.0
    2023-11-16 14:07:20.648	debug	Objects client initialize lua scripts
    unifi.0
    2023-11-16 14:07:20.611	debug	Objects create User PubSub Client
    unifi.0
    2023-11-16 14:07:20.610	debug	Objects create System PubSub Client
    unifi.0
    2023-11-16 14:07:20.607	debug	Objects client ready ... initialize now
    unifi.0
    2023-11-16 14:07:20.563	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    unifi.0
    @dime
    Bring das zunächst einmal auf nodejs18.
    iob stop
    iob fix
    iob nodejs-update
    Den Rest auch auf Stand bringen.
    • D DiMe
      @ilovegym
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      @dime
      das mit dem Modul node-unifi machen wir spaeter, erstmal das system updaten und den iobroker updaten.
      Dann ein Reboot der Kiste, und wenn alles ok ist, dann schauen wir weiter. Die Node-Unifi muss ja nur per Hand geaendert werden, wenn du eine UDM Pro mit Firmware hoeher 3.2.x und Netzwerk 8.x hast.
      Dazu muessen wir halt auch wissen, was du da fuern Controller und welche Unifi-Netzwerk Version du installiert hast..
      bisher braucht man viel Fantasie und ratet mal ins blaue rein, was da los sein koennte..
      Und im Forum hier eins merken:
      Immer wenn @Thomas-Braun was schreibt, mach das einfach.. der will nur helfen.. :-) und das was er an kommandos raus haut, passt.
        @dime
        DiMe
        @ilovegym @Thomas-Braun
        Vielen Dank euch, Update läuft gerade, hat mir aber von 16.19 auf 16.20.2 vorgeschlagen.
        Mal schauen was passiert wenn er fertig ist.
        ? Thomas BraunT 2 Antworten Letzte Antwort
        • D DiMe
          @dime
          wenn er damit fertig ist, schau mal ob dein System uptodate ist..
          und das Commando
          iob nodejs-update 18
          hebt dir die Version auf 18 an.
            @dime
            und das Commando
            DiMe
            @ilovegym
            Okay laut IoBroker Infos, habe ich die 18.18.2 jetzt drauf
            • D DiMe
              @ilovegym
              @dime
              bitte die Ausgabe von
              iob diag
              • D DiMe
                @dime
                Wenn der iobrokee auf Stand gebracht worden ist sollte da auch eine Empfehlung zu nodejs@18 erscheinen.
                Oder du erzwingst die 18 direkt:
                  @dime
                  iob diag
                  DiMe
                  @ilovegym
                  v.2023-10-10
                  Copy text starting here:
                                          v.2023-10-10
                     Static hostname: raspberrypi
                           Icon name: computer
                    Operating System: Raspbian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.1.19-v7l+
                        Architecture: arm
                  Kernel:                 armv7l
                  Userland:               armhf
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1000
                  X-Server:               false
                  Pending OS-Updates:     0
                  Pending iob updates:    15
                  This system needs to be REBOOTED NOW!
                  Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                          /usr/bin/node           v18.18.2
                                          /usr/bin/npm            9.8.1
                                          /usr/bin/npx            9.8.1
                                          /usr/bin/corepack       0.19.0
                  Recommended versions are nodejs 16.20.2 and npm 8.19.4
                  MEMORY:
                  Mem:            3.8G        1.1G        1.8G        0.0K        926M        2.6G
                  Swap:            99M         80M         19M
                  Total:          3.9G        1.2G        1.9G
                  Active iob-Instances:   13
                  Active repo(s): stable
                  ioBroker Core:          js-controller           4.0.24
                                          admin                   6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                3374
                  States:                 3133
                  Size of iob-Database:
                  6.8M    /opt/iobroker/iobroker-data/objects.jsonl
                  1.2M    /opt/iobroker/iobroker-data/states.jsonl
                  • D DiMe
                    @ilovegym
                    v.2023-10-10
                                            v.2023-10-10
                             Icon name: computer
                          Architecture: arm
                    Kernel:                 armv7l
                    Userland:               armhf
                    User-ID:                1000
                    X-Server:               false
                                            /usr/bin/npm            9.8.1
                                            /usr/bin/npx            9.8.1
                    MEMORY:
                    Swap:            99M         80M         19M
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                3374
                    States:                 3133
                    @dime
                    Solltest du tun.
                      @dime
                      Solltest du tun.
                      DiMe
                      schrieb am zuletzt editiert von DiMe
                      Done
                      Neuer Diag:
                                              v.2023-10-10
                               Icon name: computer
                                  Kernel: Linux 6.1.21-v7l+
                            Architecture: arm
                      Kernel:                 armv7l
                      Userland:               armhf
                      User-ID:                1000
                      X-Server:               false
                                              /usr/bin/npm            9.8.1
                                              /usr/bin/npx            9.8.1
                      MEMORY:
                      Mem:            3.8G        1.4G        1.6G        6.0M        917M        2.3G
                      Swap:            99M          0B         99M
                      Total:          3.9G        1.4G        1.7G
                                              admin                   6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                3430
                      States:                 3189
                      7.9M    /opt/iobroker/iobroker-data/objects.jsonl
                      1.9M    /opt/iobroker/iobroker-data/states.jsonl
                      • D DiMe
                        Done
                        Neuer Diag:
                                                v.2023-10-10
                                 Icon name: computer
                              Architecture: arm
                        Kernel:                 armv7l
                        Userland:               armhf
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            9.8.1
                                                /usr/bin/npx            9.8.1
                        MEMORY:
                        Swap:            99M          0B         99M
                                                admin                   6.3.5
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                3430
                        States:                 3189
                        @dime sagte in ioBroker.Unifi verbindet nicht (Erstinstallation):
                        jetzt den iobroker auf den Stand bringen..
                        und wenn du das fertig hast, sagst du uns noch die Versionen von Unifi-Controller und -Netwerk, damit wir den unifi-adapter in Gang bringen.. aber erstmal das Fundament.. mit nem Haus faengt man auch nicht am Dach an zu bauen.. :-)
                          DiMe
                          @ilovegym
                          Alles klar, mach ich. Möchte nur schnell noch ein Backup meiner SD machen, falls etwas schief gehen sollte. Ich habe da ein Händchen dafür 😁
                          • D DiMe
                            @ilovegym
                            @dime
                            Das sollte man zwischen diesen Schritten sowieso immer machen.. am besten ganze SD Karte.. die geht sowieso gern kaputt..
                            und auch vom iobroker ein Backup machen, also in der Konsole "iob backup" eingeben, und das dann irgendwohin(wo es sicher ist und man es wieder findet und einfach zurueck kopieren kann) kopieren...
                              @dime
                              DiMe
                              @ilovegym
                              SD Karten Backup mache ich eigentlich immer in einem bestimmt Turnus oder bevor ich gerade rumschraube.
                              Habe auch ein Adapter bei mir auf dem Broker wo täglich meine Daten vom Broker sichert (Grafana , Werte usw.).
                              Aber das mit dem "iob Backup" mache ich jetzt trotzdem auch noch. Lieber eine Sicherung zu viel.
                              Kurze Frage mit dem IOBroker update, kann ich den einfach mit
                              iob upgrade self
                              starten oder gibt es noch etwas zu beachten, ich frage für ein Freund 😆
                              • D DiMe
                                @ilovegym
                                iob upgrade self
                                @dime
                                iob update
                                iob upgrade all
                                iob stop
                                iob fix
                                iob upgrade self
                                iob start
                                  @dime
                                  iob update
                                  iob upgrade all
                                  iob stop
                                  iob fix
                                  iob upgrade self
                                  iob start
                                  DiMe
                                  @thomas-braun @ilovegym
                                  So alles erledigt und noch ein Diag gemacht
                                                          v.2023-10-10
                                           Icon name: computer
                                        Architecture: arm
                                  Kernel:                 armv7l
                                  Userland:               armhf
                                  User-ID:                1000
                                  X-Server:               false
                                  Pending iob updates:    0
                                                          /usr/bin/npm            9.8.1
                                                          /usr/bin/npx            9.8.1
                                  Recommended versions are nodejs 18.18.2 and npm 9.8.1
                                  MEMORY:
                                  Mem:            3.8G        1.4G        1.5G        6.0M        1.0G        2.3G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        1.4G        1.6G
                                  ioBroker Core:          js-controller           5.0.16
                                                          admin                   6.12.0
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                3548
                                  States:                 3267
                                  6.9M    /opt/iobroker/iobroker-data/objects.jsonl
                                  1.1M    /opt/iobroker/iobroker-data/states.jsonl
                                  Danke für die Codes
                                  Thomas BraunT ? 2 Antworten Letzte Antwort
                                  • D DiMe
                                                            v.2023-10-10
                                             Icon name: computer
                                          Architecture: arm
                                    Kernel:                 armv7l
                                    Userland:               armhf
                                    User-ID:                1000
                                    X-Server:               false
                                                            /usr/bin/npm            9.8.1
                                                            /usr/bin/npx            9.8.1
                                    MEMORY:
                                    Swap:            99M          0B         99M
                                                            admin                   6.12.0
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                3548
                                    States:                 3267
                                    Danke für die Codes
                                    @dime
                                    Ja, jetzt ist die Basis auf aktuellem Stand.
                                    • D DiMe
                                                              v.2023-10-10
                                               Icon name: computer
                                            Architecture: arm
                                      Kernel:                 armv7l
                                      Userland:               armhf
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            9.8.1
                                                              /usr/bin/npx            9.8.1
                                      MEMORY:
                                      Swap:            99M          0B         99M
                                                              admin                   6.12.0
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                3548
                                      States:                 3267
                                      Danke für die Codes
                                      @dime
                                      Jetzt mal den Unifi Adapter starten und das komplette log vom start bis zur Fehlermeldung posten, bitte..
                                        @dime
                                        DiMe
                                        @ilovegym
                                        Geht klar
                                        unifi.0
                                        2023-11-16 16:13:58.862	info	terminating
                                        unifi.0
                                        2023-11-16 16:13:58.358	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        unifi.0
                                        2023-11-16 16:13:58.357	debug	Plugin sentry destroyed
                                        unifi.0
                                        2023-11-16 16:13:58.355	info	terminating
                                        unifi.0
                                        2023-11-16 16:13:58.354	info	cleaned everything up...
                                        unifi.0
                                        2023-11-16 16:13:58.351	info	Got terminate signal TERMINATE_YOURSELF
                                        unifi.0
                                        2023-11-16 16:13:58.200	error	Adapter deactivated due to missing configuration.
                                        unifi.0
                                        2023-11-16 16:13:58.198	info	UniFi adapter is ready
                                        unifi.0
                                        2023-11-16 16:13:58.142	info	starting. Version 0.6.6 in /opt/iobroker/node_modules/iobroker.unifi, node: v18.18.2, js-controller: 5.0.16
                                        unifi.0
                                        2023-11-16 16:13:57.357	debug	Plugin sentry Initialize Plugin (enabled=true)
                                        unifi.0
                                        2023-11-16 16:13:57.269	debug	States connected to redis: 127.0.0.1:9000
                                        unifi.0
                                        2023-11-16 16:13:57.193	debug	States create User PubSub Client
                                        unifi.0
                                        2023-11-16 16:13:57.191	debug	States create System PubSub Client
                                        unifi.0
                                        2023-11-16 16:13:57.174	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                        unifi.0
                                        2023-11-16 16:13:57.134	debug	Objects connected to redis: 127.0.0.1:9001
                                        unifi.0
                                        2023-11-16 16:13:57.122	debug	Objects client initialize lua scripts
                                        unifi.0
                                        2023-11-16 16:13:57.076	debug	Objects create User PubSub Client
                                        unifi.0
                                        2023-11-16 16:13:57.065	debug	Objects create System PubSub Client
                                        unifi.0
                                        2023-11-16 16:13:57.060	debug	Objects client ready ... initialize now
                                        unifi.0
                                        2023-11-16 16:13:56.985	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        • D DiMe
                                          @ilovegym
                                          Geht klar
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          unifi.0
                                          Ich würde mal in die Einstellungen des Adapters schauen. Da fehlt offenbar irgendwas.
