  4. Gosund SP111 mit Tasmota 13.2.0 Problem mit DP
    5.2k
88 Beiträge 4 Kommentatoren 14.6k Aufrufe 2 Beobachtet
  • RalfThR Offline
    RalfThR Offline
    RalfTh
    schrieb am zuletzt editiert von RalfTh
    #72
    @ralla66 Ok, dann habe ich es richtig gemacht.
    Allerdings stimmt der Inhalt nicht und diese Meldung scheint die Ursache zu sein:
    18:34:19.588 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
    Steht auch in meinem letzten Post in der Konsolenausgabe.
    Gebe ich im Browser http://192.168.178.164/cm?cmnd=status 10 ein erhalte ich folgendes:
    {"StatusSNS":{"Time":"2023-11-15T18:37:01","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.556,"Yesterday":0.170,"Today":0.055,"Power":41,"ApparentPower":41,"ReactivePower":0,"Factor":1.00,"Voltage":229,"Current":0.181}}}
    In der Konsole sieht es folgend aus:
    18:38:48.972 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T18:38:48","Uptime":"0T12:01:26","UptimeSec":43286,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":4,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":82,"Signal":-59,"LinkCount":1,"Downtime":"0T00:00:03"}}
    18:38:48.984 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T18:38:48","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.558,"Yesterday":0.170,"Today":0.057,"Period":1,"Power":42,"ApparentPower":42,"ReactivePower":0,"Factor":1.00,"Voltage":229,"Current":0.183}}
    18:38:50.972 SCR: performs "websend [192.168.178.164] /cm?cmnd=status 10"
    18:38:56.176 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
    18:38:56.184 MQT: stat/tasmota_B8D3E7/RESULT = {"Total":0}
    18:38:56.191 MQT: stat/tasmota_B8D3E7/RESULT = {"Yesterday":0}
    18:38:56.199 MQT: stat/tasmota_B8D3E7/RESULT = {"Today":0}
    18:38:56.206 MQT: stat/tasmota_B8D3E7/RESULT = {"ApparentPower":0}
    18:38:56.213 MQT: stat/tasmota_B8D3E7/RESULT = {"ReactivePower":0.00}
    18:38:56.221 MQT: stat/tasmota_B8D3E7/RESULT = {"Power":0}
    18:38:56.228 MQT: stat/tasmota_B8D3E7/RESULT = {"Voltage":0}
    18:38:56.235 MQT: stat/tasmota_B8D3E7/RESULT = {"Current":0}
    In den ersten beiden Zeilen siehst du die JSON-Inhalte, aber ab Zeile 5 sind alle Werte 0??!!
    Ich vermute das liegt am Connection failed in Zeile 4.
    Wir haben uns verirrt, kommen aber gut voran.
    Ralla66R 1 Antwort Letzte Antwort
    • RalfThR RalfTh
      Ralla66R Offline
      Ralla66R Offline
      Ralla66
      #73
      @ralfth
      ja richtig, vermute da ist was falsch in Zeile 45 beim send
      Hattest du nicht 2 Gosund ? Dann nimm mal die andere IP
      RalfThR 1 Antwort Letzte Antwort
      • Ralla66R Ralla66
        @ralfth
        RalfThR Offline
        RalfThR Offline
        RalfTh
        #74
        @ralla66 ich habe viele. Du meinst ich soll mal die Daten einer anderen abfragen und publishen?!
        • RalfThR RalfTh
          Ralla66R Offline
          Ralla66R Offline
          Ralla66
          #75
          @ralfth
          ja zum testen ob websend rausgeht und ein Done kommt
          Nachtrag: lösch mal den Kommentar
          ; MQT: tasmota_Reserve2 = {"StatusSNS":{"Time":"2023-11-14T12:59:46","ENERGY":{"TotalStart...............................
          nicht das die Zeile zu lang ist
          • Ralla66R Ralla66
            @ralfth
            RalfThR Offline
            RalfThR Offline
            RalfTh
            #76
            @ralla66 OK, hier kommt eine DONE. allerdings werden die Die Werte nich ins Result geschrieben. Oder werden sie nicht richt gelesen?
            18:57:45.317 SCR: performs "websend [192.168.178.151] /cm?cmnd=status 10"
            18:57:45.391 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Done"}
            18:57:45.398 MQT: stat/tasmota_B8D3E7/RESULT = {"Total":0}
            18:57:45.404 MQT: stat/tasmota_B8D3E7/RESULT = {"Yesterday":0}
            18:57:45.408 MQT: stat/tasmota_B8D3E7/RESULT = {"Today":0}
            18:57:45.412 MQT: stat/tasmota_B8D3E7/RESULT = {"ApparentPower":0}
            18:57:45.416 MQT: stat/tasmota_B8D3E7/RESULT = {"ReactivePower":0.00}
            18:57:45.421 MQT: stat/tasmota_B8D3E7/RESULT = {"Power":0}
            18:57:45.425 MQT: stat/tasmota_B8D3E7/RESULT = {"Voltage":0}
            18:57:45.429 MQT: stat/tasmota_B8D3E7/RESULT = {"Current":0}
            Hier läuft übrigens eine .bin 13.2.0 DE ganz normal von der Tasmota-Seite.
            @ralfth sagte in Gosund SP111 mit Tasmota 13.2.0 Problem mit DP:
            Die folgenden defines sind nicht mehr Bestandteil my_user_config.h
            #define USE_SCRIPT_GLOBVARS
            #define USE_SCRIPT_STATUS
            #define USE_SCRIPT_FULL_JSON_PARSER
            #define USE_SCRIPT_JSON_EXPORT
            #define USE_SCRIPT_WEB_DISPLAY
            #define USE_SCRIPT_SERIAL
            #define USE_SML_M
            Damit steht es nicht in Zusammenhang. Hatte ich weiter oben schon geschrieben.
            • RalfThR RalfTh
              #define USE_SML_M
              Ralla66R Offline
              Ralla66R Offline
              Ralla66
              #77
              192.168.178.151
              geprüft im Browser ?
              Topic ist default ?
              • Ralla66R Ralla66
                192.168.178.151
                Topic ist default ?
                RalfThR Offline
                RalfThR Offline
                RalfTh
                #78
                @ralla66 sagte in Gosund SP111 mit Tasmota 13.2.0 Problem mit DP:
                192.168.178.151
                Topic ist default ?
                Ja und Ja
                Browser-Antwort:
                {"StatusSNS":{"Time":"2023-11-15T19:10:25","ENERGY":{"TotalStartTime":"2020-01-10T16:35:26","Total":196.003,"Yesterday":0.483,"Today":0.467,"Power":84,"ApparentPower":104,"ReactivePower":61,"Factor":0.81,"Voltage":226,"Current":0.459}}}
                • RalfThR RalfTh
                  192.168.178.151
                  Topic ist default ?
                  Ja und Ja
                  Browser-Antwort:
                  Ralla66R Offline
                  Ralla66R Offline
                  Ralla66
                  #79
                  @ralfth
                  den langen kommentar hast du gelöscht ?
                  Telemetrie steht bei mir auf 10
                  • Ralla66R Ralla66
                    @ralfth
                    RalfThR Offline
                    RalfThR Offline
                    RalfTh
                    #80
                    @ralla66 Beides Ja, allerdings immer noch:
                    19:19:27.382 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
                    Ich verstehe das nicht, wenn ich das im Webbrowser aufrufe funktioniert es doch!!!!
                    Das ist allerdings neu:
                    19:21:50.738 var not found: WebQuery#StatusSNS#ENERGY#Voltage
                    19:21:50.740 Wert Volt 0.00
                    19:21:50.742 var not found: WebQuery#StatusSNS#ENERGY#Current/1000
                    19:21:50.743 Wert Current 0.00
                    19:21:50.745 var not found: WebQuery#StatusSNS#ENERGY#Power
                    19:21:50.746 Wert Power 0.00
                    19:21:50.748 var not found: WebQuery#StatusSNS#ENERGY#Total
                    19:21:50.750 Wert Total 0.00
                    19:21:50.751 var not found: WebQuery#StatusSNS#ENERGY#Yesterday
                    19:21:50.753 Wert Yesterday 0.00
                    19:21:50.755 var not found: WebQuery#StatusSNS#ENERGY#Today
                    19:21:50.756 Wert Today 0.00
                    19:21:50.758 var not found: WebQuery#StatusSNS#ENERGY#ApparentPower
                    19:21:50.759 Wert Apparent Power 0.00
                    19:21:50.761 var not found: WebQuery#StatusSNS#ENERGY#ReactivePower
                    19:21:50.763 Wert Reaktive Power 0.00
                    • RalfThR RalfTh
                      Ralla66R Offline
                      Ralla66R Offline
                      Ralla66
                      #81
                      @ralfth
                      der Parser zerlegt die Antwort vom websend der Anfrage in Today, Voltage usw.
                      Der Parser wird zwingend benötigt.
                      RalfThR 2 Antworten Letzte Antwort
                      • Ralla66R Ralla66
                        @ralfth
                        RalfThR Offline
                        RalfThR Offline
                        RalfTh
                        #82
                        @ralla66 OK, dann mach ich mich erst mal da dran un compiliere eine neue .bin
                        Melde mich dann wieder. Und vielen Dank für Deine Unterstützung.
                        • Ralla66R Ralla66
                          @ralfth
                          RalfThR Offline
                          RalfThR Offline
                          RalfTh
                          #83
                          @ralla66 Dieses define steht in der my_user_config.h ??
                          • RalfThR RalfTh
                            Ralla66R Offline
                            Ralla66R Offline
                            Ralla66
                            #84
                            @ralfth
                            und nimm bitte alle define USE_xxxxx
                            Auf git liefen meine .bin auch nicht,erst die mit Tasmocompiler erstellten
                            liefen dann. Probiers mal.
                            • Ralla66R Ralla66
                              @ralfth
                              RalfThR Offline
                              RalfThR Offline
                              RalfTh
                              #85
                              @ralla66 Meinst du den GitPod oder ist der Tasmotacompiler noch was anderes. GitPod ist so ne Browsererweiterung auf Basis VSC
                              Hier ein Auszug aus der my_user_config.h nach der Suche nach dem Wort Script:
                              // -- Rules or Script  ----------------------------
                              // Select none or only one of the below defines USE_RULES or USE_SCRIPT
                              #define USE_RULES                                // Add support for rules (+8k code)
                              //  #define USE_EXPRESSION                         // Add support for expression evaluation in rules (+3k2 code, +64 bytes mem)
                              //    #define SUPPORT_IF_STATEMENT                 // Add support for IF statement in rules (+4k2 code, -332 bytes mem)
                              //  #define USER_RULE1 "<Any rule1 data>"          // Add rule1 data saved at initial firmware load or when command reset is executed
                              //  #define USER_RULE2 "<Any rule2 data>"          // Add rule2 data saved at initial firmware load or when command reset is executed
                              //  #define USER_RULE3 "<Any rule3 data>"          // Add rule3 data saved at initial firmware load or when command reset is executed
                              //#define USE_SCRIPT                               // Add support for script (+17k code)
                              //  #define USE_SCRIPT_FATFS 4                     // Script: Add FAT FileSystem Support
                              //  #define SUPPORT_MQTT_EVENT                     // Support trigger event with MQTT subscriptions (+3k5 code)
                              Und weiter unten:
                              #if defined(USE_RULES) && defined(USE_SCRIPT)
                                #error "Select either USE_RULES or USE_SCRIPT. They can't both be used at the same time"
                              #endif
                              Diese Defines stehen nicht in der aktuellen my_user_config.h . Soll ich die einfach mal in die user_config-override.h eintragen??
                              • RalfThR RalfTh
                                Und weiter unten:
                                #endif
                                Ralla66R Offline
                                Ralla66R Offline
                                Ralla66
                                #86
                                @ralfth
                                keine Ahnung von my_user_config.h
                                die:
                                #define USE_TIMERS
                                #define USE_SCRIPT
                                #define USE_WEBSEND_RESPONSE
                                #define USE_SML_M
                                • Ralla66R Ralla66
                                  @ralfth
                                  die:
                                  #define USE_TIMERS
                                  #define USE_SCRIPT
                                  #define USE_SML_M
                                  RalfThR Offline
                                  RalfThR Offline
                                  RalfTh
                                  #87
                                  @ralla66 bin gerade völlig überfordert. wie komme ich denn an den Tasmocompiler??
                                  • RalfThR RalfTh
                                    Ralla66R Offline
                                    Ralla66R Offline
                                    Ralla66
                                    #88
                                    @ralfth
                                    Link
