  4. Gosund SP111 mit Tasmota 13.2.0 Problem mit DP
    5.2k
88 Beiträge 4 Kommentatoren 14.6k Aufrufe 2 Beobachtet
  • RalfThR RalfTh
    @ralla66 Habe jetzt dein original Script eingebunden:
    >D
    ;a valid script must start with >D in the first line
    Timer=0
    WEBQ=5
    VOL=0
    CUR=0
    POW=0
    TOT=0
    YES=0
    TOD=0
    APP=0
    RAP=0
    ; Meins
    ; MQT: tasmota_Reserve2 = {"StatusSNS":{"Time":"2023-11-14T12:59:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.424,"Yesterday":0.007,"Today":0.093,"Power":42,"ApparentPower":42,"ReactivePower":0,"Factor":1.00,"Voltage":231,"Current":0.181}}}
    >BS
    +>subscribe EA, cmnd/%topic%/Total
    +>subscribe EA, cmnd/%topic%/Yesterday
    +>subscribe EA, cmnd/%topic%/Today
    +>subscribe EA, cmnd/%topic%/Power
    +>subscribe EA, cmnd/%topic%/ApparentPower
    +>subscribe EA, cmnd/%topic%/ReactivePower
    +>subscribe EA, cmnd/%topic%/Voltage
    +>subscribe EA, cmnd/%topic%/Current
    >S
    Timer+=1
    ;Executed every second
    if Timer>10
    then
    =>websend [192.168.178.164] /cm?cmnd=status 10
    +>publish stat/%topic%/RESULT {"Total":%0TOT%}
    +>publish stat/%topic%/RESULT {"Yesterday":%0YES%}
    +>publish stat/%topic%/RESULT {"Today":%0TOD%}
    +>publish stat/%topic%/RESULT {"ApparentPower":%0APP%}
    +>publish stat/%topic%/RESULT {"ReactivePower":%RAP%}
    +>publish stat/%topic%/RESULT {"Power":%0POW%}
    +>publish stat/%topic%/RESULT {"Voltage":%0VOL%}
    +>publish stat/%topic%/RESULT {"Current":%0CUR%}
    Timer=0
    endif
    >E
    ;Executed when a Tasmota MQTT RESULT message is received
    VOL=WebQuery#StatusSNS#ENERGY#Voltage
    print Wert Volt %VOL%
    CUR=WebQuery#StatusSNS#ENERGY#Current/1000
    print Wert Current %CUR%
    POW=WebQuery#StatusSNS#ENERGY#Power
    print Wert Power %POW%
    TOT=WebQuery#StatusSNS#ENERGY#Total
    print Wert Total %TOT%
    YES=WebQuery#StatusSNS#ENERGY#Yesterday
    print Wert Yesterday %YES%
    TOD=WebQuery#StatusSNS#ENERGY#Today
    print Wert Today %TOD%
    APP=WebQuery#StatusSNS#ENERGY#ApparentPower
    print Wert Apparent Power %APP%
    RAP=WebQuery#StatusSNS#ENERGY#ReactivePower
    print Wert Reaktive Power %RAP%
    >W
    ;The lines in this section are displayed in the web UI main page
    Power{m} %2POW% W
    Volt{m} %2VOL% V
    Ampere{m} %2CUR% A
    Total{m} %2TOT%
    Yesterday{m} %YES%
    Today{m} %2TOD%
    Apparent{m} %2APP%
    Reactive{m} %2RAP%
    angepasst habe ich Zeile 21 und 45
    Im Log des ioBroker steht:
    sonoff.0
    2023-11-14 18:48:06.358	debug	[Reserve2] Received: stat/tasmota_Reserve2/RESULT = {"WebSend":"Connect failed"}
    Habe keine Ahnung woran das liegen kann.
    Nachtrag:
    Ralla66R Offline
    Ralla66R Offline
    Ralla66
    #67
    @ralfth
    was bastelst du da :-)
    RalfThR 1 Antwort Letzte Antwort
    • Ralla66R Ralla66
      @ralfth
      RalfThR Offline
      RalfThR Offline
      RalfTh
      #68
      @ralla66 So, habe jetzt alles so eingestellt wie du es mir in den Bildern gezeigt hast. Habe vorher den Adapter gestoppt und die Objekte gelöscht.
      Das Script ist nicht aktiviert.
      Instanz gestartet, die Objekte werden angelegt.
      Di DP's welche mit "ENERGY_" beginnen werden,wenn überhaupt nur nach einer Ewigkeit aktualisiert und das obwohl die Message ankam. Hier Auszug aus der Konsole:
      B8D3E7/POWER = ON
      07:14:16.291 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:14:16","Uptime":"0T00:36:54","UptimeSec":2214,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:03"}}
      07:14:16.302 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:14:16","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.527,"Yesterday":0.170,"Today":0.026,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.183}}
      07:14:46.290 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:14:46","Uptime":"0T00:37:24","UptimeSec":2244,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:03"}}
      07:14:46.299 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:14:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.528,"Yesterday":0.170,"Today":0.027,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.183}}
      07:15:16.280 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:15:16","Uptime":"0T00:37:54","UptimeSec":2274,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:03"}}
      07:15:16.293 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:15:16","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.528,"Yesterday":0.170,"Today":0.027,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.183}}
      07:15:46.251 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:15:46","Uptime":"0T00:38:24","UptimeSec":2304,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":64,"Signal":-68,"LinkCount":1,"Downtime":"0T00:00:03"}}
      07:15:46.262 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:15:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.528,"Yesterday":0.170,"Today":0.027,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.186}}
      07:16:16.257 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:16:16","Uptime":"0T00:38:54","UptimeSec":2334,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:03"}}
      07:16:16.267 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:16:16","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.529,"Yesterday":0.170,"Today":0.028,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.185}}
      07:16:46.256 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:16:46","Uptime":"0T00:39:24","UptimeSec":2364,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:03"}}
      07:16:46.268 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:16:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.529,"Yesterday":0.170,"Today":0.028,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.186}}
      07:17:16.261 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:17:16","Uptime":"0T00:39:54","UptimeSec":2394,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":60,"Signal":-70,"LinkCount":1,"Downtime":"0T00:00:03"}}
      07:17:16.273 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:17:16","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.530,"Yesterday":0.170,"Today":0.029,"Period":0,"Power":44,"ApparentPower":44,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.188}}
      07:17:46.275 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T07:17:46","Uptime":"0T00:40:24","UptimeSec":2424,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":1,"Downtime":"0T00:00:03"}}
      07:17:46.285 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T07:17:46","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.530,"Yesterday":0.170,"Today":0.029,"Period":0,"Power":43,"ApparentPower":43,"ReactivePower":0,"Factor":1.00,"Voltage":232,"Current":0.185}}
      Derweil im ioBroker:
      Und das, obwohl laut LOG auch hier die Informationen eintrudeln:
      Ich habe die Steckdose mittlerweile drei mal geflasht und jedesmal eine andere Konfiguration verwendet. Ich denke, ein erneutes flashen bringt da auch nicht die Lösung. Falls keine anderen Ideen mehr da sind werde ich mir einen anderen MQTT-Broker suchen und das JSON aufdröseln.
      Wir haben uns verirrt, kommen aber gut voran.
      Ralla66R 1 Antwort Letzte Antwort
      • RalfThR RalfTh
        B8D3E7/POWER = ON
        Ralla66R Offline
        Ralla66R Offline
        Ralla66
        #69
        @ralfth
        alle print des Scriptes werden in der Console nicht ausgegeben, bedeutet dein Script läuft nicht.
        Topic ist noch Reserve2 und nicht default.
        Ob deine .bin überhaupt in Ordnung ist weiß keiner.
        Daher das compilieren mit Tasmocompiler. Das ist halt viel einfacher.
        Solange die Topic / Full Topic nicht in Ordnung sind und das Script nicht läuft kann
        ich auch nicht weiter helfen. Da es ja bei mir läuft liegt das ja an deinem System.
        • Ralla66R Ralla66
          @ralfth
          RalfThR Offline
          RalfThR Offline
          RalfTh
          #70
          @ralla66 sagte in Gosund SP111 mit Tasmota 13.2.0 Problem mit DP:
          Hatte ich auch geschrieben, dass das Script nicht aktiviert ist.
          Meine .bin habe ich mit Gitpod kompiliert (Quelle: https://github.com/arendst/Tasmota) und alle von dir genannten Defines, soweit in my_user_config.h vorhanden, aktiviert. In einem Post weiter oben hatte ich das auch schon erwähnt.
          Diese .bin habe ich dann auf den Gosund geflasht.
          Das Script habe ich jetzt aktiviert und in der Konsole kommt folgende Fehlermeldung:
          17:32:38.869 SCR: performs "websend [192.168.178.164] /cm?cmnd=status 10"
          17:32:44.249 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
          17:32:44.257 MQT: stat/tasmota_B8D3E7/RESULT = {"Total":0}
          17:32:44.264 MQT: stat/tasmota_B8D3E7/RESULT = {"Yesterday":0}
          17:32:44.272 MQT: stat/tasmota_B8D3E7/RESULT = {"Today":0}
          17:32:44.279 MQT: stat/tasmota_B8D3E7/RESULT = {"ApparentPower":0}
          17:32:44.286 MQT: stat/tasmota_B8D3E7/RESULT = {"ReactivePower":0.00}
          17:32:44.293 MQT: stat/tasmota_B8D3E7/RESULT = {"Power":0}
          17:32:44.300 MQT: stat/tasmota_B8D3E7/RESULT = {"Voltage":0}
          17:32:44.307 MQT: stat/tasmota_B8D3E7/RESULT = {"Current":0}
          17:32:48.393 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T17:32:48","Uptime":"0T10:55:26","UptimeSec":39326,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":4,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:03"}}
          17:32:48.406 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T17:32:48","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.544,"Yesterday":0.170,"Today":0.043,"Period":1,"Power":42,"ApparentPower":42,"ReactivePower":0,"Factor":1.00,"Voltage":230,"Current":0.181}}
          17:32:54.371 SCR: performs "websend [192.168.178.164] /cm?cmnd=status 10"
          17:32:59.783 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
          17:32:59.792 MQT: stat/tasmota_B8D3E7/RESULT = {"Total":0}
          17:32:59.799 MQT: stat/tasmota_B8D3E7/RESULT = {"Yesterday":0}
          17:32:59.808 MQT: stat/tasmota_B8D3E7/RESULT = {"Today":0}
          17:32:59.815 MQT: stat/tasmota_B8D3E7/RESULT = {"ApparentPower":0}
          17:32:59.823 MQT: stat/tasmota_B8D3E7/RESULT = {"ReactivePower":0.00}
          Die IP für das websend ist die des ioBroker oder der Gosund?
          Hier noch mal mein Script:
          >D
          Timer=0
          WEBQ=5
          VOL=0
          CUR=0
          POW=0
          TOT=0
          YES=0
          TOD=0
          APP=0
          RAP=0
          ; Meins
          >BS
          >S
          Timer+=1
          if Timer>10
          then
          Timer=0
          endif
          >E
          >W
          Power{m} %2POW% W
          Volt{m} %2VOL% V
          Ampere{m} %2CUR% A
          Total{m} %2TOT%
          Yesterday{m} %YES%
          Today{m} %2TOD%
          Apparent{m} %2APP%
          Reactive{m} %2RAP%
          Ich habe es nochmal verglichen. Ich habe lediglich die Zeilen 21 und 45 angepasst.
          • RalfThR RalfTh
            >D
            Timer=0
            WEBQ=5
            VOL=0
            CUR=0
            POW=0
            TOT=0
            YES=0
            TOD=0
            APP=0
            RAP=0
            ; Meins
            >BS
            >S
            Timer+=1
            if Timer>10
            then
            Timer=0
            endif
            >E
            >W
            Power{m} %2POW% W
            Volt{m} %2VOL% V
            Ampere{m} %2CUR% A
            Total{m} %2TOT%
            Yesterday{m} %YES%
            Today{m} %2TOD%
            Apparent{m} %2APP%
            Reactive{m} %2RAP%
            Ralla66R Offline
            Ralla66R Offline
            Ralla66
            #71
            @ralfth sagte in Gosund SP111 mit Tasmota 13.2.0 Problem mit DP:
            vom Gosund, das sieht doch gut aus :-)
            Daten per IP websend kannst du von jedem Tasmota Gerät abfragen der die gleiche
            StatusSNS/Energy/xxx............................ hat.
            • RalfThR Offline
              RalfThR Offline
              RalfTh
              schrieb am zuletzt editiert von RalfTh
              #72
              @ralla66 Ok, dann habe ich es richtig gemacht.
              Allerdings stimmt der Inhalt nicht und diese Meldung scheint die Ursache zu sein:
              18:34:19.588 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
              Steht auch in meinem letzten Post in der Konsolenausgabe.
              Gebe ich im Browser http://192.168.178.164/cm?cmnd=status 10 ein erhalte ich folgendes:
              {"StatusSNS":{"Time":"2023-11-15T18:37:01","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.556,"Yesterday":0.170,"Today":0.055,"Power":41,"ApparentPower":41,"ReactivePower":0,"Factor":1.00,"Voltage":229,"Current":0.181}}}
              In der Konsole sieht es folgend aus:
              18:38:48.972 MQT: tele/tasmota_B8D3E7/STATE = {"Time":"2023-11-15T18:38:48","Uptime":"0T12:01:26","UptimeSec":43286,"Heap":20,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":4,"POWER":"ON","Wifi":{"AP":1,"SSId":"Palatina","BSSId":"5C:49:79:55:9E:DC","Channel":4,"Mode":"11n","RSSI":82,"Signal":-59,"LinkCount":1,"Downtime":"0T00:00:03"}}
              18:38:48.984 MQT: tele/tasmota_B8D3E7/SENSOR = {"Time":"2023-11-15T18:38:48","ENERGY":{"TotalStartTime":"2020-06-30T13:38:42","Total":0.558,"Yesterday":0.170,"Today":0.057,"Period":1,"Power":42,"ApparentPower":42,"ReactivePower":0,"Factor":1.00,"Voltage":229,"Current":0.183}}
              18:38:50.972 SCR: performs "websend [192.168.178.164] /cm?cmnd=status 10"
              18:38:56.176 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
              18:38:56.184 MQT: stat/tasmota_B8D3E7/RESULT = {"Total":0}
              18:38:56.191 MQT: stat/tasmota_B8D3E7/RESULT = {"Yesterday":0}
              18:38:56.199 MQT: stat/tasmota_B8D3E7/RESULT = {"Today":0}
              18:38:56.206 MQT: stat/tasmota_B8D3E7/RESULT = {"ApparentPower":0}
              18:38:56.213 MQT: stat/tasmota_B8D3E7/RESULT = {"ReactivePower":0.00}
              18:38:56.221 MQT: stat/tasmota_B8D3E7/RESULT = {"Power":0}
              18:38:56.228 MQT: stat/tasmota_B8D3E7/RESULT = {"Voltage":0}
              18:38:56.235 MQT: stat/tasmota_B8D3E7/RESULT = {"Current":0}
              In den ersten beiden Zeilen siehst du die JSON-Inhalte, aber ab Zeile 5 sind alle Werte 0??!!
              Ich vermute das liegt am Connection failed in Zeile 4.
              • RalfThR RalfTh
                Ralla66R Offline
                Ralla66R Offline
                Ralla66
                #73
                @ralfth
                ja richtig, vermute da ist was falsch in Zeile 45 beim send
                Hattest du nicht 2 Gosund ? Dann nimm mal die andere IP
                • Ralla66R Ralla66
                  @ralfth
                  RalfThR Offline
                  RalfThR Offline
                  RalfTh
                  #74
                  @ralla66 ich habe viele. Du meinst ich soll mal die Daten einer anderen abfragen und publishen?!
                  • RalfThR RalfTh
                    Ralla66R Offline
                    Ralla66R Offline
                    Ralla66
                    #75
                    @ralfth
                    ja zum testen ob websend rausgeht und ein Done kommt
                    Nachtrag: lösch mal den Kommentar
                    ; MQT: tasmota_Reserve2 = {"StatusSNS":{"Time":"2023-11-14T12:59:46","ENERGY":{"TotalStart...............................
                    nicht das die Zeile zu lang ist
                    • Ralla66R Ralla66
                      @ralfth
                      RalfThR Offline
                      RalfThR Offline
                      RalfTh
                      #76
                      @ralla66 OK, hier kommt eine DONE. allerdings werden die Die Werte nich ins Result geschrieben. Oder werden sie nicht richt gelesen?
                      18:57:45.317 SCR: performs "websend [192.168.178.151] /cm?cmnd=status 10"
                      18:57:45.391 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Done"}
                      18:57:45.398 MQT: stat/tasmota_B8D3E7/RESULT = {"Total":0}
                      18:57:45.404 MQT: stat/tasmota_B8D3E7/RESULT = {"Yesterday":0}
                      18:57:45.408 MQT: stat/tasmota_B8D3E7/RESULT = {"Today":0}
                      18:57:45.412 MQT: stat/tasmota_B8D3E7/RESULT = {"ApparentPower":0}
                      18:57:45.416 MQT: stat/tasmota_B8D3E7/RESULT = {"ReactivePower":0.00}
                      18:57:45.421 MQT: stat/tasmota_B8D3E7/RESULT = {"Power":0}
                      18:57:45.425 MQT: stat/tasmota_B8D3E7/RESULT = {"Voltage":0}
                      18:57:45.429 MQT: stat/tasmota_B8D3E7/RESULT = {"Current":0}
                      Hier läuft übrigens eine .bin 13.2.0 DE ganz normal von der Tasmota-Seite.
                      Die folgenden defines sind nicht mehr Bestandteil my_user_config.h
                      #define USE_SCRIPT_GLOBVARS
                      #define USE_SCRIPT_STATUS
                      #define USE_SCRIPT_FULL_JSON_PARSER
                      #define USE_SCRIPT_JSON_EXPORT
                      #define USE_SCRIPT_WEB_DISPLAY
                      #define USE_SCRIPT_SERIAL
                      #define USE_SML_M
                      Damit steht es nicht in Zusammenhang. Hatte ich weiter oben schon geschrieben.
                      • RalfThR RalfTh
                        #define USE_SML_M
                        Ralla66R Offline
                        Ralla66R Offline
                        Ralla66
                        #77
                        192.168.178.151
                        geprüft im Browser ?
                        Topic ist default ?
                        • Ralla66R Ralla66
                          192.168.178.151
                          Topic ist default ?
                          RalfThR Offline
                          RalfThR Offline
                          RalfTh
                          #78
                          192.168.178.151
                          Topic ist default ?
                          Ja und Ja
                          Browser-Antwort:
                          {"StatusSNS":{"Time":"2023-11-15T19:10:25","ENERGY":{"TotalStartTime":"2020-01-10T16:35:26","Total":196.003,"Yesterday":0.483,"Today":0.467,"Power":84,"ApparentPower":104,"ReactivePower":61,"Factor":0.81,"Voltage":226,"Current":0.459}}}
                          • RalfThR RalfTh
                            192.168.178.151
                            Topic ist default ?
                            Ja und Ja
                            Browser-Antwort:
                            Ralla66R Offline
                            Ralla66R Offline
                            Ralla66
                            #79
                            @ralfth
                            den langen kommentar hast du gelöscht ?
                            Telemetrie steht bei mir auf 10
                            • Ralla66R Ralla66
                              @ralfth
                              RalfThR Offline
                              RalfThR Offline
                              RalfTh
                              #80
                              @ralla66 Beides Ja, allerdings immer noch:
                              19:19:27.382 MQT: stat/tasmota_B8D3E7/RESULT = {"WebSend":"Connect failed"}
                              Ich verstehe das nicht, wenn ich das im Webbrowser aufrufe funktioniert es doch!!!!
                              Das ist allerdings neu:
                              19:21:50.738 var not found: WebQuery#StatusSNS#ENERGY#Voltage
                              19:21:50.740 Wert Volt 0.00
                              19:21:50.742 var not found: WebQuery#StatusSNS#ENERGY#Current/1000
                              19:21:50.743 Wert Current 0.00
                              19:21:50.745 var not found: WebQuery#StatusSNS#ENERGY#Power
                              19:21:50.746 Wert Power 0.00
                              19:21:50.748 var not found: WebQuery#StatusSNS#ENERGY#Total
                              19:21:50.750 Wert Total 0.00
                              19:21:50.751 var not found: WebQuery#StatusSNS#ENERGY#Yesterday
                              19:21:50.753 Wert Yesterday 0.00
                              19:21:50.755 var not found: WebQuery#StatusSNS#ENERGY#Today
                              19:21:50.756 Wert Today 0.00
                              19:21:50.758 var not found: WebQuery#StatusSNS#ENERGY#ApparentPower
                              19:21:50.759 Wert Apparent Power 0.00
                              19:21:50.761 var not found: WebQuery#StatusSNS#ENERGY#ReactivePower
                              19:21:50.763 Wert Reaktive Power 0.00
                              • RalfThR RalfTh
                                Ralla66R Offline
                                Ralla66R Offline
                                Ralla66
                                #81
                                @ralfth
                                der Parser zerlegt die Antwort vom websend der Anfrage in Today, Voltage usw.
                                Der Parser wird zwingend benötigt.
                                RalfThR 2 Antworten Letzte Antwort
                                • Ralla66R Ralla66
                                  @ralfth
                                  RalfThR Offline
                                  RalfThR Offline
                                  RalfTh
                                  #82
                                  @ralla66 OK, dann mach ich mich erst mal da dran un compiliere eine neue .bin
                                  Melde mich dann wieder. Und vielen Dank für Deine Unterstützung.
                                  • Ralla66R Ralla66
                                    @ralfth
                                    RalfThR Offline
                                    RalfThR Offline
                                    RalfTh
                                    #83
                                    @ralla66 Dieses define steht in der my_user_config.h ??
                                    • RalfThR RalfTh
                                      Ralla66R Offline
                                      Ralla66R Offline
                                      Ralla66
                                      #84
                                      @ralfth
                                      und nimm bitte alle define USE_xxxxx
                                      Auf git liefen meine .bin auch nicht,erst die mit Tasmocompiler erstellten
                                      liefen dann. Probiers mal.
                                      • Ralla66R Ralla66
                                        @ralfth
                                        RalfThR Offline
                                        RalfThR Offline
                                        RalfTh
                                        #85
                                        @ralla66 Meinst du den GitPod oder ist der Tasmotacompiler noch was anderes. GitPod ist so ne Browsererweiterung auf Basis VSC
                                        Hier ein Auszug aus der my_user_config.h nach der Suche nach dem Wort Script:
                                        // -- Rules or Script  ----------------------------
                                        // Select none or only one of the below defines USE_RULES or USE_SCRIPT
                                        #define USE_RULES                                // Add support for rules (+8k code)
                                        //  #define USE_EXPRESSION                         // Add support for expression evaluation in rules (+3k2 code, +64 bytes mem)
                                        //    #define SUPPORT_IF_STATEMENT                 // Add support for IF statement in rules (+4k2 code, -332 bytes mem)
                                        //  #define USER_RULE1 "<Any rule1 data>"          // Add rule1 data saved at initial firmware load or when command reset is executed
                                        //  #define USER_RULE2 "<Any rule2 data>"          // Add rule2 data saved at initial firmware load or when command reset is executed
                                        //  #define USER_RULE3 "<Any rule3 data>"          // Add rule3 data saved at initial firmware load or when command reset is executed
                                        //#define USE_SCRIPT                               // Add support for script (+17k code)
                                        //  #define USE_SCRIPT_FATFS 4                     // Script: Add FAT FileSystem Support
                                        //  #define SUPPORT_MQTT_EVENT                     // Support trigger event with MQTT subscriptions (+3k5 code)
                                        Und weiter unten:
                                        #if defined(USE_RULES) && defined(USE_SCRIPT)
                                          #error "Select either USE_RULES or USE_SCRIPT. They can't both be used at the same time"
                                        #endif
                                        Diese Defines stehen nicht in der aktuellen my_user_config.h . Soll ich die einfach mal in die user_config-override.h eintragen??
                                        • RalfThR RalfTh
                                          Und weiter unten:
                                          #endif
                                          Ralla66R Offline
                                          Ralla66R Offline
                                          Ralla66
                                          #86
                                          @ralfth
                                          keine Ahnung von my_user_config.h
                                          die:
                                          #define USE_TIMERS
                                          #define USE_SCRIPT
                                          #define USE_WEBSEND_RESPONSE
                                          #define USE_SML_M
