  4. Fehler beim Adapter installieren Code25
    6.8k
108 Beiträge 9 Kommentatoren 18.1k Aufrufe 6 Beobachtet
    @yamaha1220
    Fällt mir nichts mehr zu ein.
    Y Offline
    Y Offline
    yamaha1220
    @thomas-braun hmm. Habe alles so aufgespielt wie in deiner Anleitung und alles befolgt echt komisch das er den js-controller nicht installiert also eine älter version
    • Y yamaha1220
      @thomas-braun das kam jetzt raus
      schenk@pi32:/opt/iobroker $ schenk@pi32:~ $ cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller@4.0.24
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm ERR! code 1
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c node iobroker.js setup first
      npm ERR! Unable to subscribe to meta namespace "meta." changes: Error PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
      npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
      npm ERR!         throw e;
      npm ERR!         ^
      npm ERR!
      npm ERR! ReplyError: Error scan NOT SUPPORTED
      npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      npm ERR! Emitted 'error' event on ScanStream instance at:
      npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
      npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
      npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
      npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
      npm ERR!   command: {
      npm ERR!     name: 'scan',
      npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
      npm ERR!   }
      npm ERR! }
      npm ERR!
      npm ERR! Node.js v18.18.2
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-11-07T14_06_35_334Z-debug-0.log
      @yamaha1220 sagte in Fehler beim Adapter installieren Code25:
      logs/2023-11-07T**14_06**35_334Z-debug-0.log
      Y 1 Antwort Letzte Antwort
        @yamaha1220
        Y Offline
        Y Offline
        yamaha1220
        @thomas-braun hängt der fehler in der version ?
          Y Offline
          Y Offline
          yamaha1220
          @homoran bedeutet jetzt was?
            die in deinem output angegebene Datei ist nicht die, die du nicht findest
            Y 2 Antworten Letzte Antwort
              Y Offline
              Y Offline
              yamaha1220
              @homoran ok und was soll ich jetzt machen?
                @yamaha1220
                Y Offline
                Y Offline
                yamaha1220
                @thomas-braun das steht bei hosts
                Typ: js-controller
                Titel: JS controller
                OS: linux
                Verfügbar: 5.0.12
                Installiert: 3.1.6
                Ereignisse: ↦33 / ↦16
                  Y Offline
                  Y Offline
                  yamaha1220
                  @homoran hast du eine idee was ich jetzt machen könnte?
                  • Y yamaha1220
                    @yamaha1220
                    Du hockst ja noch auf dem ollen js-controller. Kein Wunder das damit nichts mehr funktioniert.
                      @yamaha1220
                      Y Offline
                      Y Offline
                      yamaha1220
                      @thomas-braun das ist nach dem backup gewesen was soll ich jetzt machen? beim backup hat er es übernommen
                      • Y yamaha1220
                        Hä? Wer hat was in welcher Version übernommen?
                        Du hast ein Backup in den js-controller@5 bekommen? Verwunderlich.
                          Y Offline
                          Y Offline
                          yamaha1220
                          @thomas-braun ich habe alles neu aufgesetzt wie in deiner anleitung.
                          und da denke ich das der js-controller bestimmt eine andere version hat und nach meinem backup wieder ein schlechteres js-controller version oder nicht?
                            Y Offline
                            Y Offline
                            yamaha1220
                            @thomas-braun was soll ich jetzt machen ? nochmal neu aufsetzen?
                            • Y yamaha1220
                              du solltest beim Versuch des Restores eine Meldung bekommen was du tun musst.
                              da müsste dringestanden haben dass du den Controller manuell diwngraden musst um das Backup überhaupt ei spielen zu können.
                                Y Offline
                                Y Offline
                                yamaha1220
                                @homoran leider nicht wirklich ich füge das backup mit iobroker Tool ein. sehr geiles programm aber glaube nicht das da was stand
                                • Y yamaha1220
                                  sag jetzt nicht dass es das vom Hai ist, das das gesamte Rechtegefüge verbiegt!
                                  Das ist alles andere als geil!
                                    Y Offline
                                    Y Offline
                                    yamaha1220
                                    @homoran keine ahnung von wem.
                                    kann leider kein backup ohne das einfügen. weil ich auf meinem alten den adapter backitup nicht installieren kann. und habe nichts anderes gefunden.
                                    ist das programm so schlecht?
                                      Y Offline
                                      Y Offline
                                      yamaha1220
                                      @homoran ist von elzershark das programm sogar über github.
                                      Name ioBrokerBackupInstallTool
                                      • Y yamaha1220
                                        Das ist Grütze. Finger weg von dem Murks.
                                        • Y yamaha1220
                                          wie befürchtet!
                                          dann solltest du dir auch bei dem Herrn Hilfe holen.
                                          Meister MopperM Y 2 Antworten Letzte Antwort
