  4. Conbee 2 Stick - keine Gateway Verbindung
    2.9k
    5.0k
28 Beiträge 6 Kommentatoren 4.0k Aufrufe 4 Beobachtet
    @baki074
    Schau z.B. per
    iob diag
    nach, was da evtl. auf Port 80 läuft.
    Baki074
    Unter Adapter Status scheint deConz der einzige auf Port 80 zu sein.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypiiob
           Icon name: computer
              Kernel: Linux 6.1.0-rpi4-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     16:48:36 up  1:00,  2 users,  load average: 0.35, 0.42, 0.36
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2023-11-03 16:48:37 CET
               Universal time: Fri 2023-11-03 15:48:37 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        1.1G        2.3G        1.2M        621M        2.9G
    Swap:           104M          0B        104M
    Total:          4.1G        1.1G        2.4G
             3793 M total memory
             1073 M used memory
             1117 M active memory
              363 M inactive memory
             2201 M free memory
               27 M buffer memory
              565 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4       59G  3.7G   52G   7% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Fri Nov  3 15:47:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:6D:16:BA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=f7ca60cb-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Fri Nov  3 15:47:46 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Nov  3 15:47:48 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    611M    /var/
    201M    /var/cache
    195M    /var/cache/apt
    165M    /var/lib
    145M    /var/log/journal/4903dc435a5c4bab8c999c51be278c00
    Archived and active journals take up 144.0M in the file system.
    /opt/iobroker/backups:
    1.3M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    135M    /opt/iobroker/iobroker-data/
    100M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    13M     /opt/iobroker/iobroker-data/states.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2131568-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypiiob                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspberrypiiob                           -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypiiob                           -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypiiob                           -  enabled
    + system.adapter.deconz.0                 : deconz                : raspberrypiiob                           -  enabled, port: 80
    + system.adapter.device-reminder.0        : device-reminder       : raspberrypiiob                           -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypiiob                           -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypiiob                           -  enabled
    + system.adapter.info.0                   : info                  : raspberrypiiob                           -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypiiob                           -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypiiob                           -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypiiob                           -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypiiob                           -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.yeelight-2.0             : yeelight-2            : raspberrypiiob                           -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "shelly"       : 6.4.5    , installed 6.4.5
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
    Objects and States
    Objects:        10005
    States:         9669
    W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://phoscon.de/apt/deconz bookworm InRelease
    Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16592      554/deCONZ
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11821      749/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       11781      554/deCONZ
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16603      741/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11873      741/iobroker.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11823      749/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17766      1136/io.admin.0
    udp        0      0 0.0.0.0:41507           0.0.0.0:*                           1001       18033      1423/io.broadlink2.
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       17999      1423/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16369      548/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16984      1327/io.shelly.0
    udp        0      0 0.0.0.0:56901           0.0.0.0:*                           1001       18002      1423/io.broadlink2.
    udp        0      0 0.0.0.0:59100           0.0.0.0:*                           104        16371      548/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17128      1475/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17494      554/deCONZ
    udp6       0      0 fe80::4620:2df4:eb2:546 :::*                                0          17506      664/NetworkManager
    udp6       0      0 :::49963                :::*                                104        16372      548/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        16370      548/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       17130      1475/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       17129      1475/io.deconz.0
    2023-11-03 16:37:41.374  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:38:44.444  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:38:44.445  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:39:47.516  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:39:47.517  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:40:50.588  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:40:50.589  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:41:53.660  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:41:53.661  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:42:33.369  - info: admin.0 (1136) ==> Connected system.user.admin from ::ffff:192.168.178.84
    2023-11-03 16:42:56.732  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:42:56.733  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:43:59.805  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:43:59.806  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:45:02.876  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:45:02.878  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:46:05.948  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:46:05.949  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:46:54.429  - info: admin.0 (1136) <== Disconnect system.user.admin from ::ffff:192.168.178.84
    2023-11-03 16:47:09.020  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:47:09.021  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:48:12.156  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:48:12.157  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    2023-11-03 16:49:15.228  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: connect EHOSTUNREACH 192.168.178.41:443
    2023-11-03 16:49:15.229  - warn: deconz.0 (1475) Could not connect to websocket instance of deConz/Phoscon. Error: WebSocket was closed before the connection was established
    • B Baki074
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               3793 M total memory
               1073 M used memory
               2201 M free memory
                 27 M buffer memory
                565 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      611M    /var/
      201M    /var/cache
      195M    /var/cache/apt
      165M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        10005
      States:         9669
      Pending Updates: 0
      @baki074
      Die letzten Zeilen schauen 'verdächtig' aus.
        @baki074
        Jey CeeJ Online
        Jey CeeJ Online
        Jey Cee
        @thomas-braun sagte in Conbee 2 Stick - keine Gateway Verbindung:
        Naja das ist die Logische Konsequenz daraus das deConz/Phonscon nicht erreichbar ist.
        @Baki074 gib mal im Adapter die bei IP 127.0.0.1 an.
        Das sieht doch schwer nach einem Netzwerk Problem aus.
        Persönlicher Support
        Spenden -> paypal.me/J3YC33
        • Jey CeeJ Jey Cee
          Baki074
          @jey-cee said in Conbee 2 Stick - keine Gateway Verbindung:
          Dadurch springt der Adapter auf grün! Die Phoscon App kann ich aber mit beiden IPs dennoch nicht erreichen.
          • B Baki074
            tobrog
            @baki074 Mal mit http://[IP]/pwa probiert?
            • T tobrog
              Baki074
              @tobrog Ich habe nun den Router komplett den Stecker gezogen und wieder eingesteckt. Siehe da - hat geklappt! Warum und wieso - keine Ahnung :D Ich habe nun jedenfalls Zugriff auf die Phoscon App. Vielen Dank für die Hilfestellungen!
              Ist es aber normal, dass Phoscon dieselbe IP Adresse hat wie der IoBroker und sich nur durch den Port unterscheidet? In meinem Fall 192.168.178.38
              War bei mir im voherigen System (Debian Buster) nicht so.
              Zudem klappt die Übertragung neuer Sensoren von der Phoscon App zum deConz Adapter leider nicht. Auch die bestehenden Sensoren (welche vermutlich mit dem ioBroke Backup eingespielt wurden) im Adapter erhalten keine geänderten Zustände wenn ich bspw. die Fenster öffne.
              • B Baki074
                tobrog
                schrieb am zuletzt editiert von tobrog
                @baki074 Wenn beides auf dem gleichen Rechner installiert ist, haben die auch die gleiche IP. Deshalb brauchst du ja auch die ports um verschiedene Dienste unter der gleichen IP ansprechen zu können.
                Hast du denn in deConz auch eine backup eingespielt? Der deConz adapter stellt ja nur die Verbindung zu deConz her. Wenn die zigbee Geräte nicht in deConz sind, hast du logischerweise auch im iobroker keinen Zugriff darauf.
                • T tobrog
                  Baki074
                  @tobrog said in Conbee 2 Stick - keine Gateway Verbindung:
                  Leider nein. D.h. ich müsste nun jeden Sensor über die Phoscon App neu anlernen, dann via deConz Adapter in den ioBroker überspielen und auch in meinen bestehenden Skripten neu verknüpfen, oder?
                  • B Baki074
                    tobrog
                    @baki074 Ja, es sei denn du hast vorher schon aliase erstellt und die in deinen skripten genutzt.
                    Wenn du eh alles neu anlernen musst, evtl mal darüber nachdenken, deConz wieder zu deinstallieren und direkt den zigbee adapter benutzen.
                    • T tobrog
                      Baki074
                      Wenn ich im Zigbee Adapter meine Sensoren angelernt habe, kann ich diese einfach mit Backitup sichern lassen, richtig? Sprich: Bei einer möglichen Neuinstallation, kann ich über Backitup auch die Zigbee Geräte direkt wieder automatisch einbinden lassen, oder? Ist in diesem Fall auch eine Aktualisierung in den Scripten ausgeschlossen, da alles bereits richtig erkannt wird?
                      Ro75R 1 Antwort Letzte Antwort
                      • B Baki074
                        Ro75R Online
                        Ro75R Online
                        Ro75
                        @baki074 sagte in Conbee 2 Stick - keine Gateway Verbindung:
                        JA, so mache ich es auch. Aber dann musst du auch regelmäßig Backups ausführen (planen), sonst nutzt dir es auch nichts (wenn dein Backup "hundealt" ist).
                        JA, anders als beim Deconz-System bleiben die DP. Damit brauchst Du kein zwingendes Alias (zumindest nicht in diesem Bereich) oder eine sonstige Änderung von Skripten.
                        Ro75.
                        • Ro75R Ro75
                          Ro75.
                          Baki074
                          @ro75 said in Conbee 2 Stick - keine Gateway Verbindung:
                          Top, habe ich nun so umgesetzt und einige Sensoren schon angelernt. Ist auf den ersten Blick wesentlich unkomplizierter als das ganze über Phoscon und deConz zu realisieren.
                          Letzte Frage zu dem Thema: Beim BackitUp Adapter kann ich "Zigbee2MQTT" und "Zigbee Datenbank" als Backup auswählen. Bei Zigbee2MQTT erhalte ich einen Fehler (ERR_INVALID_ARG-TYPE). Ist dies für die Speicherung der angelernten Zigbee Geräte überhaupt erforderlich oder reicht der Punkt "Zigbee Datenbank" für das Backup aus?
                          • B Baki074
                            tobrog
                            @baki074 Wenn du den zigbee adapter nutzt, reicht der Punkt Zigbee Datenbank. Der andere Punkt ist nur relevant, wenn du dein Zigbee Geräte über den zigbee2mqtt Adapter verwaltest/anlernst.
                            • T tobrog
                              Baki074
                              @tobrog Beim Backup der Zigbee Datenbank wird nun auf meinem NAS ein eigener "Ordner" erstellt. Diesen kann ich dann einfach über den Backitup Adapter beim wiederherstellen einspielen lassen, oder wird dies über den Zigbee Adapter eingespielt? Eigenen Punkt dazu habe ich nicht gefunden.
                              Möchte nur sichergehen, dass mir das Ganze Thema bzgl. Backups in diesem Ausmaß nicht mehr passiert :D
                              • B Baki074
                                tobrog
                                @baki074 Wird einfach über den Backitup Adapter wieder zurückgespielt
                                • T tobrog
                                  Baki074
                                  Vielen Dank an alle für die Hilfestellungen und Anregungen!
