  4. Test Adapter Weather-Warnings
1.1k Beiträge 36 Kommentatoren 496.5k Aufrufe 41 Beobachtet
    @ticaki
    Knallt mir auch mit der neuen json auf die Füße:
    2023-11-03 22:29:29.715  - info: weather-warnings.0 (7695) starting. Version 0.4.8 (non-npm: ticaki/ioBroker.weather-warnings) in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v21.1.0, js-controller: 5.0.16
    2023-11-03 22:29:34.594  - info: weather-warnings.0 (7695) Refresh Interval: 15 minutes
    2023-11-03 22:29:34.829  - info: weather-warnings.0 (7695) DWD activated. Retrieve data.
    2023-11-03 22:29:35.279  - error: weather-warnings.0 (7695) No valid warncell found for ["DE50968"]
    2023-11-03 22:29:35.280  - info: weather-warnings.0 (7695) UWZ activated. Retrieve data.
    2023-11-03 22:29:35.292  - error: weather-warnings.0 (7695) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-11-03 22:29:35.293  - error: weather-warnings.0 (7695) unhandled promise rejection: Cannot read properties of undefined (reading 'join')
    2023-11-03 22:29:35.373  - error: weather-warnings.0 (7695) TypeError: Cannot read properties of undefined (reading 'join')
        at new BaseProvider (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:49:104)
        at new UWZProvider (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:453:9)
        at ProviderController.createProviderIfNotExist (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:763:25)
        at /opt/iobroker/node_modules/iobroker.weather-warnings/src/main.ts:505:49
        at processTicksAndRejections (node:internal/process/task_queues:95:5)
    2023-11-03 22:29:35.375  - error: weather-warnings.0 (7695) Cannot read properties of undefined (reading 'join')
    2023-11-03 22:29:35.389  - info: weather-warnings.0 (7695) terminating
    2023-11-03 22:29:35.391  - warn: weather-warnings.0 (7695) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-11-03 22:29:35.894  - info: weather-warnings.0 (7695) terminating
    2023-11-03 22:29:35.913  - error: weather-warnings.0 (7695) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-11-03 22:29:35.916  - error: weather-warnings.0 (7695) unhandled promise rejection: DB closed
    2023-11-03 22:29:35.919  - error: weather-warnings.0 (7695) Error: DB closed
        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
        at Object.onceWrapper (node:events:630:26)
        at Socket.emit (node:events:515:28)
        at TCP.<anonymous> (node:net:337:12)
    2023-11-03 22:29:35.920  - error: weather-warnings.0 (7695) DB closed
    2023-11-03 22:29:36.046  - error: host.chet instance system.adapter.weather-warnings.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-11-03 22:30:08.097  - info: weather-warnings.0 (7720) starting. Version 0.4.8 (non-npm: ticaki/ioBroker.weather-warnings) in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v21.1.0, js-controller: 5.0.16
    2023-11-03 22:30:13.006  - info: weather-warnings.0 (7720) Refresh Interval: 15 minutes
    2023-11-03 22:30:13.257  - info: weather-warnings.0 (7720) DWD activated. Retrieve data.
    2023-11-03 22:30:13.759  - error: weather-warnings.0 (7720) No valid warncell found for ["DE50968"]
    2023-11-03 22:30:13.761  - info: weather-warnings.0 (7720) UWZ activated. Retrieve data.
    2023-11-03 22:30:13.764  - error: weather-warnings.0 (7720) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-11-03 22:30:13.764  - error: weather-warnings.0 (7720) unhandled promise rejection: Cannot read properties of undefined (reading 'join')
    2023-11-03 22:30:13.866  - error: weather-warnings.0 (7720) TypeError: Cannot read properties of undefined (reading 'join')
    2023-11-03 22:30:13.867  - error: weather-warnings.0 (7720) Cannot read properties of undefined (reading 'join')
    2023-11-03 22:30:13.875  - info: weather-warnings.0 (7720) terminating
    2023-11-03 22:30:13.877  - warn: weather-warnings.0 (7720) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-11-03 22:30:14.381  - info: weather-warnings.0 (7720) terminating
    2023-11-03 22:30:14.423  - error: weather-warnings.0 (7720) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-11-03 22:30:14.424  - error: weather-warnings.0 (7720) unhandled promise rejection: DB closed
    2023-11-03 22:30:14.426  - error: weather-warnings.0 (7720) Error: DB closed
    2023-11-03 22:30:14.427  - error: weather-warnings.0 (7720) DB closed
    2023-11-03 22:30:14.540  - error: host.chet instance system.adapter.weather-warnings.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    T Nicht stören
    T Nicht stören
    ticaki
    #724
    Konfiguriere bitte UWZ neu. Da bin ich gerade dran am arbeiten, da fehlen noch ein paar "wenn da blödsinn stehe, schreibe was sinnvolles ins log" :)
    Spenden
    • T ticaki
      #725
      @ticaki
      Frechheit!! Ich geb keinen Blödsinn ein!! :-)
        @ticaki
        T Nicht stören
        T Nicht stören
        ticaki
        #726
        :) Ich hoffe es läuft jetzt.
        Zu deinem Alexa vermute ich dass deine überall gruppe nicht funktioniert, wähle die Echos aus die sprechen sollen. Oder richte deine überall gruppe ein. Wie man letzteres macht weiß ich nicht mehr, hab ich vor x Jahren gemacht.
        EDIT: und zum testen von Alexa auf das Kommando do oben ^ klicken.
        Spenden
        • T ticaki
          #727
          @ticaki sagte in Test Adapter Weather-Warnings:
          Nö, läuft nicht.
          Die ist eingerichtet.
          2023-11-03 22:40:09.023  - info: weather-warnings.0 (8460) starting. Version 0.4.8 (non-npm: ticaki/ioBroker.weather-warnings) in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v21.1.0, js-controller: 5.0.16
          2023-11-03 22:40:13.996  - info: weather-warnings.0 (8460) Refresh Interval: 15 minutes
          2023-11-03 22:40:14.180  - info: weather-warnings.0 (8460) DWD activated. Retrieve data.
          2023-11-03 22:40:14.626  - info: weather-warnings.0 (8460) UWZ activated. Retrieve data.
          2023-11-03 22:40:14.841  - info: weather-warnings.0 (8460) Got terminate signal TERMINATE_YOURSELF
          2023-11-03 22:40:14.854  - info: weather-warnings.0 (8460) terminating
          2023-11-03 22:40:14.855  - info: weather-warnings.0 (8460) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-11-03 22:40:15.357  - info: weather-warnings.0 (8460) terminating
          2023-11-03 22:40:15.468  - error: weather-warnings.0 (8460) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-03 22:40:15.469  - error: weather-warnings.0 (8460) unhandled promise rejection: DB closed
          2023-11-03 22:40:15.471  - error: weather-warnings.0 (8460) Error: DB closed
          2023-11-03 22:40:15.471  - error: weather-warnings.0 (8460) DB closed
          2023-11-03 22:40:15.475  - warn: weather-warnings.0 (8460) get state error: Connection is closed.
          2023-11-03 22:40:15.478  - error: weather-warnings.0 (8460) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-03 22:40:15.478  - error: weather-warnings.0 (8460) unhandled promise rejection: DB closed
          2023-11-03 22:40:15.706  - error: weather-warnings.0 (8460) Error: DB closed
              at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
              at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
              at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40)
              at WeatherWarnings._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7710:33)
          2023-11-03 22:40:15.706  - error: weather-warnings.0 (8460) DB closed
          2023-11-03 22:40:15.723  - warn: weather-warnings.0 (8460) Could not perform strict object check of state weather-warnings.0.provider.dwd.805315000.warning.00.ONSET: DB closed
          2023-11-03 22:40:15.726  - warn: weather-warnings.0 (8460) get state error: Connection is closed.
          2023-11-03 22:40:15.729  - error: weather-warnings.0 (8460) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-03 22:40:15.729  - error: weather-warnings.0 (8460) unhandled promise rejection: DB closed
          2023-11-03 22:40:15.731  - error: weather-warnings.0 (8460) Error: DB closed
              at runNextTicks (node:internal/process/task_queues:60:5)
              at processImmediate (node:internal/timers:449:9)
          2023-11-03 22:40:15.731  - error: weather-warnings.0 (8460) DB closed
          2023-11-03 22:40:15.732  - error: weather-warnings.0 (8460) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-03 22:40:15.732  - error: weather-warnings.0 (8460) unhandled promise rejection: DB closed
          2023-11-03 22:40:15.733  - error: weather-warnings.0 (8460) Error: DB closed
          2023-11-03 22:40:15.733  - error: weather-warnings.0 (8460) DB closed
          2023-11-03 22:40:19.756  - info: weather-warnings.0 (8482) starting. Version 0.4.8 (non-npm: ticaki/ioBroker.weather-warnings) in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v21.1.0, js-controller: 5.0.16
          2023-11-03 22:40:24.665  - info: weather-warnings.0 (8482) Refresh Interval: 15 minutes
          2023-11-03 22:40:24.844  - info: weather-warnings.0 (8482) DWD activated. Retrieve data.
          2023-11-03 22:40:25.440  - info: weather-warnings.0 (8482) UWZ activated. Retrieve data.
          2023-11-03 22:41:47.190  - info: weather-warnings.0 (8482) Got terminate signal TERMINATE_YOURSELF
          2023-11-03 22:41:47.193  - info: weather-warnings.0 (8482) terminating
          2023-11-03 22:41:47.194  - info: weather-warnings.0 (8482) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-11-03 22:41:47.696  - info: weather-warnings.0 (8482) terminating
          2023-11-03 22:41:52.138  - info: weather-warnings.0 (8614) starting. Version 0.4.8 (non-npm: ticaki/ioBroker.weather-warnings) in /opt/iobroker/node_modules/iobroker.weather-warnings, node: v21.1.0, js-controller: 5.0.16
          2023-11-03 22:41:57.103  - info: weather-warnings.0 (8614) Refresh Interval: 15 minutes
          2023-11-03 22:41:57.323  - info: weather-warnings.0 (8614) DWD activated. Retrieve data.
          2023-11-03 22:41:57.813  - info: weather-warnings.0 (8614) UWZ activated. Retrieve data.
            Nö, läuft nicht.
            T Nicht stören
            T Nicht stören
            ticaki
            #728
            Ich installiere es gerade mal selbst auf dem echten iobroker. Nicht dass das wieder so ein dev-server != echter server dinges ist.
            Spenden
            • T ticaki
              #729
              @ticaki
              Keine Ahnung was das Ding jetzt wieder hat...
              2023-11-03 22:46:42.452  - warn: admin.0 (959) weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","textSendTo","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                @ticaki
                T Nicht stören
                T Nicht stören
                ticaki
                #730
                Das hab ich oben beantwortet. Das ist ein ADMIN Fehler.
                Bei mir läufts... Kannst du deinen iob mal neustartet? Oder den Adapter auf Debug stellen und starten. Die Fehler die du hattest lassen sich vom Code nicht wirklich erklären... Oder mal adapter upload... halt was du all den leuten räts wenn ein adapter spinnt.
                Spenden
                • T ticaki
                  #731
                  @ticaki
                  Neustart, Upload, alles durch. Funktioniert nicht. Ich bekomme keine Nachricht, weder über Whatsapp noch über die Alexa.
                    @ticaki
                    T Nicht stören
                    T Nicht stören
                    ticaki
                    #732
                    1. Aber der Adapter hat jetzt keine Fehler mehr?
                    2. ging whatsapp schon mal?
                    3. Alexa geht bei mir.
                    bist du in der telegramm gruppe? Weil das hier ist eher ein chat als forum :)
                    Spenden
                    Thomas BraunT NegaleinN 3 Antworten Letzte Antwort
                    • T ticaki
                      #733
                      @ticaki
                      Irgendwie immer noch Schweigen im Walde.
                      Aber im Log steht nix mehr.
                      • T ticaki
                        #734
                        Nope.
                          Nope.
                          T Nicht stören
                          T Nicht stören
                          ticaki
                          #735
                          ging whatsapp mit der beta?
                          Spenden
                          • T ticaki
                            #736
                            @ticaki
                            Nein, ich hab noch nie irgendeine Nachricht über irgendeinen Kanal erhalten.
                            • T ticaki
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              #737
                              telegramm gruppe
                              Sorry für OT.
                              Welche TG-Gruppe ist das? Hast einen Einladungslink?
                              ° Fixer ---> iob fix
                              • NegaleinN Negalein
                                telegramm gruppe
                                Sorry für OT.
                                T Nicht stören
                                T Nicht stören
                                ticaki
                                #738
                                @negalein sagte in Test Adapter Weather-Warnings:
                                telegramm gruppe
                                Sorry für OT.
                                https://t.me/+RQ07FM39J0E4YWUy
                                Spenden
                                  @ticaki
                                  T Nicht stören
                                  T Nicht stören
                                  ticaki
                                  #739
                                  @thomas-braun sagte in Test Adapter Weather-Warnings:
                                  @ticaki
                                  Alexa:
                                  • Ändere mal in meinem Adapter das Ausgabe gerät und benutze dann: weather-warnings.0.command.alexa2
                                  • Überprüfe ob alle eingestellten Vorlagen existieren
                                  • Gehe zu folgendem State: alexa2.0.Echo-Devices.G023535435641J8R.Commands.speak - wobei die Zahl da in der Mitte eine Seriennummer ist, nimm den wo in der Namenspalte überall steht und schreibe irgendwas in das Feld. Dieser Adapter hier schreibt genau in dieses Feld.
                                  whatsapp:
                                  • drücke auf: weather-warnings.0.command.whatsapp
                                  • Erstelle ein Javascript mit diesem Code und führe es aus - dann berichten:
                                  sendTo('whatsapp-cmb.0', 'send', {text: 'test'});
                                  • überprüfe ob dein Whatsapp richtig eingerichtet ist.
                                  Spenden
                                  • T ticaki
                                    @ticaki
                                    Alexa:
                                    whatsapp:
                                    #740
                                    Stumm.
                                    Da hab ich nix angepackt.
                                    Da quasseln alle Alexen los.
                                    • T ticaki
                                      @ticaki
                                      Alexa:
                                      whatsapp:
                                      #741
                                      whatsapp:
                                      Passiert nix.
                                      Text kommt an.
                                      Ist es.
                                        whatsapp:
                                        Passiert nix.
                                        Text kommt an.
                                        Ist es.
                                        T Nicht stören
                                        T Nicht stören
                                        ticaki
                                        #742
                                        Das Whatsapp problem liegt an falschen Vorlagen. Ich hab die mal geänderte gehabt. Klicke mal auf Vorlagen wiederherstellen, speichern & schließen und dann stelle es so ein:
                                        Geht nur um die unteren Vorlagen
                                        EDIT: Das Alexaproblem lösen wir morgen abend oder am Sonntag, das sieht alles richtig in deiner Konfiguration aus. Vielleicht bekomme ich noch nen Geistesblitz.
                                        Spenden
                                        • T ticaki
                                          #743
                                          @ticaki
                                          WhatsApp funktioniert jetzt. Hab gerade eine Entwarnung! erhalten.
