  4. Iobroker IOT Adapter bleibt gelb!
iobroker iot
26 Beiträge 5 Kommentatoren 2.4k Aufrufe 3 Beobachtet
  • Iobroker SmartiI Iobroker Smarti
    Also mit dem Link habe ich nun node und nodejs geupdatet. das passte Prima.
    Großen Dank an @apollon77 und @Thomas-Braun.
    Trotzdem besteht das Problem weiterhin. :(
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     10:31:53 up 1 day, 21:37,  1 user,  load average: 1.69, 0.72, 0.45
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2023-11-03 10:31:54 CET
               Universal time: Fri 2023-11-03 09:31:54 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    IobEG
    /home/IobEG
    IobEG adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            1.8G        735M        188M        0.0K        924M        1.0G
    Swap:            99M         20M         79M
    Total:          1.9G        755M        268M
             1848 M total memory
              735 M used memory
              753 M active memory
              613 M inactive memory
              188 M free memory
              147 M buffer memory
              776 M swap cache
               99 M total swap
               20 M used swap
               79 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
    1 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       30G  7.7G   21G  28% /
    devtmpfs       devtmpfs  667M     0  667M   0% /dev
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     370M  1.2M  369M   1% /run
    /dev/sda1      vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Wed Nov  1 12:54:25 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:35:92:92 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=0a7c123f-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Wed Nov  1 12:54:27 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Nov  1 12:54:27 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Nov  1 12:54:29 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.0G    /var/
    1.7G    /var/log/journal/ed894b9272e241f3a75f436a92573436
    1.7G    /var/log
    144M    /var/cache
    Archived and active journals take up 1.6G in the file system.
    /opt/iobroker/backups:
    239M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    511M    /opt/iobroker/iobroker-data/
    429M    /opt/iobroker/iobroker-data/files
    156M    /opt/iobroker/iobroker-data/files/vis-2-beta
    98M     /opt/iobroker/iobroker-data/files/vis-2-beta/static
    97M     /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   2
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      system.adapter.bshb.0                   : bshb                  : raspberrypi                              - disabled
      system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
    + system.adapter.euhome.0                 : euhome                : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.lovelace.0               : lovelace              : raspberrypi                              -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1886
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1889, bind: 0.0.0.0
    + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.vis-2-beta.0             : vis-2-beta            : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "bshb"         : 0.2.4    , installed 0.2.4
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "homekit-controller": 0.5.8, installed 0.5.8
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        3688
    States:         3206
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.188.20:9001     0.0.0.0:*               LISTEN      1001       96415      15252/iobroker.js-c
    tcp        0      0 192.168.188.20:9000     0.0.0.0:*               LISTEN      1001       95741      15252/iobroker.js-c
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      111        11799      501/redis-server 12
    tcp        0      0 127.0.0.1:36183         0.0.0.0:*               LISTEN      1001       98680      15856/io.yahka.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11821      542/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       95914      15439/io.mqtt.0
    tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       95915      15439/io.mqtt.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       96645      15394/io.sonoff.0
    tcp6       0      0 :::40159                :::*                    LISTEN      1001       96742      15469/io.yahka.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      111        11800      501/redis-server 12
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11823      542/sshd: /usr/sbin
    tcp6       0      0 :::8089                 :::*                    LISTEN      1001       95814      15278/io.admin.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       98051      15788/io.lovelace.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       96173      15572/io.web.0
    tcp6       0      0 :::42541                :::*                    LISTEN      1001       97142      15856/io.yahka.1
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14949      716/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14841      384/avahi-daemon: r
    udp        0      0 0.0.0.0:49715           0.0.0.0:*                           108        14843      384/avahi-daemon: r
    udp6       0      0 :::34806                :::*                                108        14844      384/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14842      384/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          11842      716/dhcpcd
    2023-11-03 10:32:40.475  - info: euhome.0 (15688) Found 1 devices
    2023-11-03 10:32:40.477  - info: euhome.0 (15688) Device: eufy (bfebf9fb52e8bcdc85ho98)
    2023-11-03 10:32:41.527  - info: host.raspberrypi instance system.adapter.yahka.1 started with pid 15856
    2023-11-03 10:32:43.831  - info: backitup.0 (15841) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.12
    2023-11-03 10:32:44.093  - info: backitup.0 (15841) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-11-03 10:32:46.809  - info: euhome.0 (15688) Found device on network with IP: undefined
    2023-11-03 10:32:46.871  - info: euhome.0 (15688) Connected to device!
    2023-11-03 10:32:46.911  - info: euhome.0 (15688) [object Object]
    2023-11-03 10:32:47.250  - info: yahka.1 (15856) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.yahka, node: v18.18.2, js-controller: 5.0.12
    2023-11-03 10:32:47.362  - info: yahka.1 (15856) adapter ready, checking config
    2023-11-03 10:32:47.397  - info: yahka.1 (15856) adding Flur Licht with UUID: c6996353-1ce9-41d9-b833-0b9d2768dfbf
    2023-11-03 10:32:47.420  - info: yahka.1 (15856) adding Nähmaschine Licht with UUID: 36d4edfe-0ce2-4432-80b5-ecfd53dc89ed
    2023-11-03 10:32:47.429  - info: yahka.1 (15856) adding Fernseher  with UUID: ce6acb78-025e-4247-a929-b5a13623843b
    2023-11-03 10:32:47.436  - info: yahka.1 (15856) adding Warmwasser with UUID: dc76cca4-e842-40e2-9e2e-7572ec7b165a
    2023-11-03 10:32:47.444  - info: yahka.1 (15856) adding Waschmaschine with UUID: faf79c24-e973-4a0e-84c1-2008a0dbe55d
    2023-11-03 10:32:47.450  - info: yahka.1 (15856) adding Trockner with UUID: 2ac39dd9-d7b2-470d-8aaf-ed7bf45e9deb
    2023-11-03 10:32:47.457  - info: yahka.1 (15856) publishing bridge Yahka-1 on 0.0.0.0 using avahi
    2023-11-03 10:32:53.728  - error: iot.0 (15677) Error by device connection: "getaddrinfo ENOTFOUND @pro_iobroker.smart@gmail.com_.......5f1"
    2023-11-03 10:32:53.732  - error: iot.0 (15677) Error by device connection: "getaddrinfo ENOTFOUND @pro_iobroker.smart@gmail.com_956d...........ffb-53b7b19615f1"
    2023-11-03 10:32:53.734  - info: iot.0 (15677) Connection changed: disconnect
    2023-11-03 10:32:57.448  - info: alexa2.0 (15365) Subscribing to states...
    2023-11-03 10:32:59.248  - info: alexa2.0 (15365) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-11-03 10:33:11.122  - info: alexa2.0 (15365) Initialization Done ...
    2023-11-03 10:33:13.686  - info: euhome.0 (15688) All devices in the network: [{"id":"bfebf9fb52e8bcdc85ho98","ip":"192.168.188.43"}]
    2023-11-03 10:33:17.316  - info: euhome.0 (15688) [object Object]
    @iobroker-smarti
    systemctl status influxdb.service
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      IobEG
      /home/IobEG
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         20M         79M
               1848 M total memory
                735 M used memory
                753 M active memory
                188 M free memory
                147 M buffer memory
                776 M swap cache
                 99 M total swap
                 20 M used swap
                 79 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      2.0G    /var/
      1.7G    /var/log
      144M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        3688
      States:         3206
      Pending Updates: 0
      @iobroker-smarti sagte in Iobroker IOT Adapter bleibt gelb!:
      Moin,
      zum einen, das was @Thomas-Braun schon nachgefragt hat, dazu noch mein Hinweis, wenn Du auf der kleinen Kiste 2 GB RAM auch noch influxDB betreibst, dann bekommst Du über kurz oder lang, Probleme mit selbigen!
      Dann mal zum eigentlichen Anliegen,
      Du hast da etwas konfiguriert, was so wohl nicht korrekt ist, was Du da gemacht hast, solltest Du uns auch noch zeigen!
      Wie sieht die Konfiguration des Adapters aus?
      Bernd
      • Iobroker SmartiI Offline
        Iobroker Smarti
        @dp20eic Also ich nutze kein InfluxDB ich hatte das mal Probeweise drauf, aber schnell gemerkt das Der "kleine" an seine Grenzen kommt.
        Habe geschaut soweit ist eigentlich keine Installation mehr von Influx DB und Grafana mehr vorhanden.
        Was meinst du mit Konfiguration ?
        In dem Code Ausgabe habe ich nur die zahlen durch punkte ersetz. da es ja ein Key ist. (Vielleicht auch übervorsichtig
        Mit freundlichen Grü........
        Iobroker Fan :). Endlich eine Plattform ohne Kommerz. Bitte Unterstützt die ganzen Jungs und Mädels. Daumen hoch !!!!
        ? 2 Antworten Letzte Antwort
          Moin,
          ja und bei dieser Anmeldung, woran auch immer, geht was schief!
          Also, hier mein Beispiel, und da in der Konfiguration hast Du ein Fehler!
          Bernd
            Moin,
            dann solltest Du mal schauen
            # sudo systemctl status influxdb.service
            Taucht da noch irgendwie enabled auf, dann
            # sudo systemctl disable influxdb.service
            Dann kann man schauen, wo die Servicedatei abgelegt ist und diese dann von Hand löschen.
            Bernd
            Iobroker SmartiI 1 Antwort Letzte Antwort
            • Thomas BraunT Online
              @dp20eic
              Bzw
              sudo systemctl hide influxdb.service
                Iobroker Smarti
                @dp20eic Ok Also
                Habe es noch einmal probiert mit Iobroker Pro und Iobroker Net
                keinen Erfolg im Log habe ich nun
                Looks like your connection certificates are invalid. Please renew them via configuration dialog.
                Zertifikate neu angefordert aber weiter keinen Erfolg.
                P.S Alexa App Skill Neu Verbunden nur dort steh immer wieder Verknüpfung zwischen den Konten ist abgelaufen.....
                -1
                  Moin,
                  Bernd
                  Iobroker Smarti
                  @dp20eic said in Iobroker IOT Adapter bleibt gelb!:
                  Moin,
                  Bernd
                  ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                       Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor preset: enabled)
                       Active: failed (Result: exit-code) since Fri 2023-11-03 10:31:09 CET; 1h 9min ago
                         Docs: https://docs.influxdata.com/influxdb/
                          CPU: 2ms
                  Nov 03 10:31:09 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                  Nov 03 10:31:09 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                  Nov 03 10:31:09 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                  Nov 03 10:31:09 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                  Nov 03 10:31:09 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                    @dp20eic Ok Also
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @iobroker-smarti
                    Welchen Skill benutzt Du denn?
                    • haselchenH haselchen
                      @iobroker-smarti
                      Iobroker Smarti
                      @haselchen said in Iobroker IOT Adapter bleibt gelb!:
                      @iobroker-smarti
                      Iobroker Iot
                        Moin,
                        Bernd
                                CPU: 2ms
                        Moin,
                        da wird noch was gestartet
                        Auflisten, ob noch was von _influxDB_ da ist
                        # sudo apt list --installed | fgrep influ
                        Wenn, ja, dann löschen, außer es ist `influxDB2-cli/influxdb-client`, das braucht der `ioBroker - influxdb Adapter`
                        # sudo systemctl stop influxdb.service
                        # sudo systemctl daemon-reload
                        Wie hast Du das damals installiert, per Paketquelle oder hast Du ein deb Paket heruntergeladen und Installiert?
                        Bernd
                          @iobroker-smarti
                          Iobroker Iot
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @iobroker-smarti
                          Alles so durchgeführt?
                            @iobroker-smarti
                            Iobroker Smarti
                            @haselchen Moin,
                            habe das wie du beschrieben gemacht eben gerade sogar mit einer neuen mail Adresse usw. leider keinen erfolg
                              @haselchen Moin,
                              Moin,
                              Schritt für Schritt, zeigen, nicht nacherzählen ;)
                              Dann, ob es hilft, keine Ahnung, den ioT Adapter mal auf Debug stellen und schauen, ob zusätzliche Informationen kommen, oder weil mir nichts Besseres einfällt, mal die Browserkonsole F12 öffnen und schauen was passiert.
                              Irgendwelche FW, pihols, oä. am Start?
                              Bernd
                                Moin,
                                Bernd
                                Iobroker Smarti
                                Habe deine Befehle und Anweisungen gefolgt leider immer wieder bei
                                     Active: failed (Result: exit-code) since Fri 2023-11-03 13:28:06 CET; 5min ago
                                        CPU: 1ms
                                Nov 03 13:28:05 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                                Nov 03 13:28:06 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                                Nov 03 13:28:06 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                Nov 03 13:28:06 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                                Nov 03 13:28:06 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                                Nov 03 13:28:06 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                                Aber ich denke daran sollte es nicht liegen war ja vorher auch soweit unverändert.
                                Das Thema sollte evlt in einen extra Thread rein. :)
                                          CPU: 1ms
                                  Moin,
                                  ja, denke ich auch, kam eben auch schon durch einender :(
                                  Bernd
                                  P.S.: frag mal nett bei @Homoran nach, ob er die zwei/drei Postest inflixdb.services betreffend in einen eigenen Thread schieben kann.
                                    Moin,
                                    Bernd
                                    @dp20eic sagte in Iobroker IOT Adapter bleibt gelb!:
                                    welche genau?
                                      welche genau?
                                      @homoran sagte in Iobroker IOT Adapter bleibt gelb!:
                                      welche genau?
                                      Moin,
                                      die, die sich mit dem Thema influxdb.service beschäftigen
                                      • https://forum.iobroker.net/topic/69801/iobroker-iot-adapter-bleibt-gelb/6?page=1
                                      • https://forum.iobroker.net/topic/69801/iobroker-iot-adapter-bleibt-gelb/11?page=1
                                      • https://forum.iobroker.net/topic/69801/iobroker-iot-adapter-bleibt-gelb/12?page=1
                                      • https://forum.iobroker.net/topic/69801/iobroker-iot-adapter-bleibt-gelb/13?page=1
                                      • https://forum.iobroker.net/topic/69801/iobroker-iot-adapter-bleibt-gelb/17?page=1
                                      • https://forum.iobroker.net/topic/69801/iobroker-iot-adapter-bleibt-gelb/20?page=1
                                      Denke, dass das alle sind.
                                      Danke und schönes Wochenende
                                      Bernd
                                        welche genau?
                                        Moin,
                                        Bernd
                                        @dp20eic DANKE! aber....
                                        der erste von Thomas ist schon eine Antwort auf den Post davor.
                                        Ein abtrennen der genannten Posts zerreisst teilweise den Kontext in diesem und im abgespaltenen Thread.
                                        Da müssen wir jetzt durch.
                                        Allerdings könnte @Iobroker-Smarti wenigstens jetzt einen neuen Thread zum Thema influxdb.service aufmachen wenn noch nötig.
                                        Iobroker SmartiI 2 Antworten Letzte Antwort
                                          Iobroker Smarti
                                          Also vielen Lieben Dank erst einmal an Alle! beosnders an @dp20eic
                                          Ich habe den Fehler gefunden. Wichtig ist das bei dem Adapter "KEINE" Cloud Url steht.
                                          Ich habe dies gemacht um Geofence zu Testen....... Manchmal sind es die kleinen Dinge die einen den Tag versauen.
                                          Allerdings bin ich um Welten schlauer geworden. Ich hoffe Ihr nehmt es mir nicht übel :)
