  4. HILFE, kein Zugriff auf IOBroker
    2.9k
    5.0k
138 Beiträge 11 Kommentatoren 18.7k Aufrufe 8 Beobachtet
  • tiobbT tiobb
    @DJMarc75
    Da soll mal einer wie ich drauf kommen
    @Thomas-Braun
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     19:07:07 up 59 min,  2 users,  load average: 0.18, 0.41, 0.63
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2023-11-02 19:07:07 CET
               Universal time: Thu 2023-11-02 18:07:07 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        327M        6.6G         17M        976M        7.3G
    Swap:           99M          0B         99M
    Total:         8.0G        327M        6.7G
             7898 M total memory
              327 M used memory
              404 M active memory
              728 M inactive memory
             6594 M free memory
              150 M buffer memory
              826 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * lightdm.service loaded failed failed Light Display Manager
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   14G   15G  49% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  8.6M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M  4.0K  790M   1% /run/user/1000
    [Thu Nov  2 18:07:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:35:E0:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5168531a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Thu Nov  2 18:07:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Nov  2 18:07:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Nov  2 18:07:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET                       SOURCE         FSTYPE            OPTIONS
    /                            /dev/mmcblk0p2 ext4              rw,noatime
    |-/sys/fs/bpf                none           bpf               rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs        gvfsd-fuse     fuse.gvfsd-fuse   rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/boot                      /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    /var:
    2.8G    /var/
    2.0G    /var/cache/apt/archives
    2.0G    /var/cache/apt
    2.0G    /var/cache
    527M    /var/log
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    54M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    512M    /opt/iobroker/iobroker-data/
    337M    /opt/iobroker/iobroker-data/history
    146M    /opt/iobroker/iobroker-data/files
    29M     /opt/iobroker/iobroker-data/files/javascript.admin
    24M     /opt/iobroker/iobroker-data/files/vis
    11M     /opt/iobroker/iobroker-data/files/echarts/static/js/2.d8ebf8a2.chunk.js.map
    11M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.d8ebf8a2.chunk.js.map
    9.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
    7.4M    /opt/iobroker/iobroker-data/objects.jsonl
    7.0M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.9483ccfd.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD4A3A-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          5.1.23
    javascript:     5.2.8
    Adapters from github:   1
    Adapter State
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 5.1.23 [Updatable]
    Adapter    "alexa2"       : 3.25.2   , installed 3.9.3  [Updatable]
    Adapter    "backitup"     : 2.8.7    , installed 2.1.17 [Updatable]
    Adapter    "cloud"        : 4.4.1    , installed 4.1.0  [Updatable]
    Adapter    "discovery"    : 3.1.0    , installed 2.7.0  [Updatable]
    Adapter    "echarts"      : 1.5.1    , installed 1.0.3  [Updatable]
    Adapter    "flot"         : 1.12.0   , installed 1.10.6 [Updatable]
    Adapter    "fritzdect"    : 2.3.1    , installed 2.1.15 [Updatable]
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 3.0.1    , installed 1.9.13 [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.11.3 [Updatable]
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.0.2  [Updatable]
    Adapter    "iot"          : 1.14.5   , installed 1.8.22 [Updatable]
    Adapter    "javascript"   : 7.1.4    , installed 5.2.8  [Updatable]
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "mqtt"         : 4.1.1    , installed 2.4.0  [Updatable]
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
    Adapter    "shelly"       : 6.4.5    , installed 4.0.7  [Updatable]
    Adapter    "simple-api"   : 2.7.2    , installed 2.6.1  [Updatable]
    Adapter    "socketio"     : 6.5.5    , installed 3.1.4  [Updatable]
    Adapter    "sonoff"       : 2.5.3    , installed 2.4.5  [Updatable]
    Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
    Adapter    "telegram"     : 1.16.0   , installed 1.10.0 [Updatable]
    Adapter    "text2command" : 3.0.2    , installed 2.1.1  [Updatable]
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.14 [Updatable]
    Adapter    "trashschedule": 2.2.0    , installed 1.2.0  [Updatable]
    Adapter    "vis"          : 1.4.16   , installed 1.4.3  [Updatable]
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.7  [Updatable]
    Adapter    "vis-material-advanced": 1.7.4, installed 1.7.0 [Updatable]
    Adapter    "web"          : 6.1.2    , installed 3.4.7  [Updatable]
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.0  [Updatable]
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.0.3  [Updatable]
    Adapter    "zigbee"       : 1.8.23   , installed 1.6.3  [Updatable]
    Objects and States
    Objects:        134
    States:         96
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15330      520/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17433      374/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50954      6217/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50947      6217/iobroker.js-co
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       53250      6238/io.admin.0
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          17799      521/xrdp-sesman
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15332      520/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17432      374/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      115        16320      535/xrdp
    udp        0      0 0.0.0.0:55790           0.0.0.0:*                           108        17424      366/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18085      438/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18520      497/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17422      366/avahi-daemon: r
    udp6       0      0 :::60395                :::*                                108        17425      366/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          19804      438/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        17423      366/avahi-daemon: r
    2023-11-02 18:38:21.599  - info: host.raspberrypi ip addresses: 192.168.178.75 fd00::cfc7:3047:144a:2a06 2a02:f90:e586:4700:9886:797:4456:5ccf fe80::2b27:87ea:3c74:2b60 192.168.178.76 fd00::3d89:1fee:ee4c:21d8 2a02:f90:e586:4700:86fe:be6c:37ae:bcf4 fe80::fa01:3136:8d9d:4ffd
    2023-11-02 18:38:21.914  - info: host.raspberrypi connected to Objects and States
    2023-11-02 18:38:21.943  - info: host.raspberrypi added notifications configuration of host
    2023-11-02 18:38:21.950  - info: host.raspberrypi Node.js version has changed from unknown to 18.18.2
    2023-11-02 18:38:22.010  - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-11-02 18:38:22.603  - info: host.raspberrypi 3 instances found
    2023-11-02 18:38:22.612  - info: host.raspberrypi starting 3 instances
    2023-11-02 18:38:22.685  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 6238
    2023-11-02 18:38:25.875  - info: admin.0 (6238) starting. Version 5.1.23 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
    2023-11-02 18:38:25.934  - info: admin.0 (6238) requesting all states
    2023-11-02 18:38:25.936  - info: admin.0 (6238) requesting all objects
    2023-11-02 18:38:26.132  - info: admin.0 (6238) received all objects
    2023-11-02 18:38:26.148  - warn: admin.0 (6238) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
    2023-11-02 18:38:26.153  - warn: admin.0 (6238) Object admin.0.info.lastUpdateCheck is invalid: Default value has to be type "number" but received type "string"
    2023-11-02 18:38:26.154  - warn: admin.0 (6238) This object will not be created in future versions. Please report this to the developer.
    2023-11-02 18:38:26.391  - info: admin.0 (6238) http server listening on port 8081
    2023-11-02 18:38:26.391  - info: admin.0 (6238) Use link "http://localhost:8081" to configure.
    2023-11-02 18:38:26.484  - info: admin.0 (6238) State value to set for "admin.0.info.lastUpdateCheck" has to be type "number" but received type "string"
    2023-11-02 18:38:26.493  - warn: admin.0 (6238) Repository cannot be read
    2023-11-02 18:38:26.653  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 6253
    2023-11-02 18:38:26.718  - error: admin.0 (6238) Cannot update news: TypeError: newNews.forEach is not a function
    2023-11-02 18:38:29.313  - info: discovery.0 (6253) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.18.2, js-controller: 5.0.12
    2023-11-02 18:38:30.661  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 6268
    2023-11-02 18:38:33.396  - info: backitup.0 (6268) starting. Version 2.1.17 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.12
    2023-11-02 18:38:33.472  - info: backitup.0 (6268) [iobroker] backup was activated at 02:40 every 1 day(s)
    iob diag has finished.
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @tiobb Desktop immer noch aktiv 👎
    Lehrling seit 1975 !!!
    • tiobbT tiobb
      @DJMarc75
      @Thomas-Braun
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           99M          0B         99M
               7898 M total memory
                327 M used memory
                404 M active memory
               6594 M free memory
                150 M buffer memory
                826 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      2.8G    /var/
      2.0G    /var/cache/apt
      2.0G    /var/cache
      527M    /var/log
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          5.1.23
      javascript:     5.2.8
      Adapter State
      + instance is alive
      Objects and States
      Objects:        134
      States:         96
      Pending Updates: 0
      @tiobb
      iob update
      iob upgrade all -y
      tiobbT 1 Antwort Letzte Antwort
        @tiobb
        iob update
        iob upgrade all -y
        tiobbT Offline
        tiobbT Offline
        tiobb
        So, habe wieder Zugriff auf den iobroker, leider ist aber alles weg, außer die installierten Adapter sind noch da. Keine Objekte, keine Scripte usw.
        Trotzdem Danke für die Hilfe
        Raspberry Pi 4 8gb
        • tiobbT tiobb
          @tiobb
          Hätte eigentlich erwartet das die wieder auftauchen.
          Offenbar waren die dir ja aber auch nicht soooooooo wichtig, sonst gäbe es ja ein Backup dieser Daten.
          Kannst aber mal nach dem Skript von fastfoot schauen. Vielleicht funktioniert das.
          • tiobbT tiobb
            @tiobb
            Mit dem frisch restaurierten ioBroker kannst du ja jetzt auf ein frisches, noch lebendiges Betriebssystem umziehen. Der 'Buster' (Debian 10) ist tot.
            Wo es hinführt, wenn man die Dinge versumpfen lässt haste ja heute gesehen.
              @tiobb
              tiobbT Offline
              tiobbT Offline
              tiobb
              Doch, die Scripte waren mir sehr sehr wichtig, da es für mich eine Ewigkeit gedauert hat diese zu schreiben, alles mit Hilfe von Foren usw, da ich absolut keine Ahnung davon habe. Erstellt habe ich die Scripte mit Blockly. Besonders das Script für meine Heizungssteuereung mit Störungsmeldung per Telegram war echt Gold wert mit meiner alten Ölheizung. Nun werde ich Wochen brauchen das wieder zum laufen zu bringen. Und alles nur weil der blöde Elektriker nicht Bescheid gegeben hat das er den Strom abschaltet.
              Raspberry Pi 4 8gb
              • tiobbT tiobb
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @tiobb sagte in HILFE, kein Zugriff auf IOBroker:
                Und der ist daran schuld dass DU keine Backups gemacht hast und Dein System versumpft hast ? Das ist nicht grade fair !
                tiobbT DuffyD 2 Antworten Letzte Antwort
                • DJMarc75D DJMarc75
                  tiobbT Offline
                  tiobbT Offline
                  tiobb
                  @djmarc75
                  Die fehlenden Backups sind mein Problem, aber der Elektriker ist verpflichtet Bescheid zu geben wenn er den Strom abschalten muss, zum Glück haben die 3 PC´s die hier liefen keinen Schaden genommen. Streng genommen könnte ich den Elektriker haftbar machen, tue ich aber nicht, und das finde ich fair.
                  Raspberry Pi 4 8gb
                  • ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    Most Active Forum Testing
                    @tiobb
                    mit dem nächsten Fehlerstrom (FI fliegt) oder Stromausfall wäre das ebenfalls passiert... Hat dich halt nur früher getroffen... Wen machst du dann verantwortlich? Den Hersteller des FI oder deinen Energieversorger?
                    • ArmilarA Armilar
                      @tiobb
                      tiobbT Offline
                      tiobbT Offline
                      tiobb
                      @armilar ich wohne seit 16 Jahren hier und es gab noch nie Probleme. Ich möchte Euch sehen wenn der Elektriker bei Euch in der Wohnung oder im Haus einfach dem Strom abschaltet und Euch der PC abraucht, oder habt ihr auch dafür ein Backup? Aber ich sehe schon, das macht hier keinen Sinn darüber zu diskutieren, wer den Schaden hat...
                      Raspberry Pi 4 8gb
                      Thomas BraunT DJMarc75D ArmilarA HomoranH 4 Antworten Letzte Antwort
                      • tiobbT tiobb
                        Ja, ich habe Backups der wichtigen Daten. Werden jede Nacht automatisch gesichert und an zwei Orten deponiert.
                        Und eine USV läuft hier auch für wichtige Systeme. Da kann der Elektriker machen was er will.
                        • tiobbT tiobb
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          juckt mich nicht da ich meine wichtige "EDV" im Büro habe und diese per USV absichere. Aber das wir jetzt OT ;)
                          • tiobbT tiobb
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            @tiobb
                            Meine Server hängen an eine USV, die hätten das nicht gemerkt oder wären irgendwann sauber heruntergefahren. Über regelmäßige Backups hätte ich es wieder einspielen können. Über Script-Spiegelungen wieder herstellen... Ich denke ich hätte nicht mal ansatzweise gemerkt, dass der Strom weg war (höchstens an Todeslinien im Grafana)...
                            Versuche mal über WinSCP im ioBroker Verzeichnis etwas zu finden, das wie eines deiner Scripte aussieht:
                            • tiobbT tiobb
                              natürlich!
                              und eine USV
                                natürlich!
                                und eine USV
                                tiobbT Offline
                                tiobbT Offline
                                tiobb
                                @DJMarc75
                                @Thomas-Braun
                                Ich denke da seid ihr ihr eher die Ausnahme.
                                @armilar sagte in HILFE, kein Zugriff auf IOBroker:
                                @tiobb
                                Ich habe da wirklich einen Ordner mit meinen Scripten gefunden. /opt/iobroker/iobroker-data/scripts
                                Kann ich die irgendwie in iobroker wieder einbinden, das wäre der Hammer?
                                Raspberry Pi 4 8gb
                                Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                                • ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  @tiobb
                                  Liegen in der Regel als JS vor. Auf Windows ziehen und als js neu anlegen.
                                  • ArmilarA Armilar
                                    @tiobb
                                    tiobbT Offline
                                    tiobbT Offline
                                    tiobb
                                    @armilar
                                    Sorry für die blöden Fragen, ich bin, was das angeht, wirklich nicht der hellste, ich bin Handwerker und auf dem Gebiet ein echter newbee mit 53 Jahren. Wie bekomme ich die Scripte dann wieder in den iobroker eingebunden? Und gibt es auch irgendwo einen Ordner mit den ganzen Instanzen und dessen Einstellungen? Ich hoffe ich drücke mich verständlich aus.
                                    Raspberry Pi 4 8gb
                                    ArmilarA 2 Antworten Letzte Antwort
                                    • tiobbT tiobb
                                      @armilar
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      @tiobb
                                      Als Blockly bekommst du die nicht wieder - aber als JS-Script
                                      Bearbeiten: Script kopieren
                                      JS anklicken (dat gelbe!!!)
                                      Script einfügen und starten...
                                      Auch wenns kein Blockly mehr ist, so laufen dennoch deine Scripte...
                                      • tiobbT tiobb
                                        @DJMarc75
                                        @Thomas-Braun
                                        @tiobb
                                        Womit? Mit Backups oder mit einer USV?
                                        Zum Thema:
                                        https://forum.iobroker.net/topic/62160/skript-wiederherstellen-und-auflisten-von-skripten?_=1698958391426
                                        • tiobbT tiobb
                                          @armilar
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          Die hätten bei der heute beschriebenen Vorgehensweise eigentlich nicht verloren gehen dürfen. Die Scripte aber auch nicht... Mal einen kompletten reboot versucht?
