  3. Einsteigerfragen
  4. Installation
  5. Probleme bei 4.0.23 auf 5.0.12 [gelöst]
20 Beiträge 3 Kommentatoren 1.8k Aufrufe 3 Beobachtet
  • G GerdNutzinger
    @thomas-braun sagte in Probleme bei 4.0.23 auf 5.0.12:
    iob diag
                            v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Kernel:                 aarch64
    Userland:               armhf
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               true
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/bin/node           v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            /usr/bin/corepack       0.19.0
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    MEMORY:
    Mem:            3.8G        945M        1.1G         34M        1.7G        2.7G
    Swap:            99M          0B         99M
    Total:          3.9G        945M        1.2G
    Active iob-Instances:   19
    Active repo(s): stable
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                1296
    States:                 1180
    Size of iob-Database:
    6.3M    /opt/iobroker/iobroker-data/objects.jsonl
    2.7M    /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    @gerdnutzinger
    Die Zusammenfassung zeigt die wesentlichen Punkte als i.O. an.
    • G GerdNutzinger
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Icon name: computer
      Architecture: arm64
      Model : Raspberry Pi 4 Model B Rev 1.5
      Docker : false
      Virtualization : none
      Kernel : aarch64
      Userland : armhf
      Systemuptime and Load:
      12:00:55 up 1:24, 4 users, load average: 0.74, 0.60, 0.46
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
      Local time: Wed 2023-11-01 12:00:55 CET
      Universal time: Wed 2023-11-01 11:00:55 UTC
      RTC time: n/a
      NTP service: active
      RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: true
      Desktop:
      Terminal: tty
      *** MEMORY ***
      total used free shared buff/cache available
      Mem: 3.8G 925M 1.1G 34M 1.7G 2.8G
      Swap: 99M 0B 99M
      Total: 3.9G 925M 1.2G
           3794 M total memory
            925 M used memory
           1049 M active memory
           1270 M inactive memory
           1119 M free memory
            206 M buffer memory
           1543 M swap cache
             99 M total swap
              0 M used swap
             99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      /dev/root ext4 30G 6.9G 21G 25% /
      devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
      tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
      tmpfs tmpfs 759M 920K 758M 1% /run
      tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
      /dev/mmcblk0p1 vfat 253M 51M 202M 20% /boot
      tmpfs tmpfs 380M 20K 380M 1% /run/user/1000
      [Wed Nov 1 10:36:08 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:96:8E:89 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=42e68ffd-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Wed Nov 1 10:36:09 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Nov 1 10:36:09 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Wed Nov 1 10:36:11 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/mmcblk0p2 ext4 rw,noatime
      `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.6G /var/
      908M /var/log
      905M /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
      430M /var/cache
      Archived and active journals take up 904.1M in the file system.
      /opt/iobroker/backups:
      31M /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      375M /opt/iobroker/iobroker-data/
      181M /opt/iobroker/iobroker-data/files
      153M /opt/iobroker/iobroker-data/history
      52M /opt/iobroker/iobroker-data/files/javascript.admin
      34M /opt/iobroker/iobroker-data/files/javascript.admin/static
      21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
      7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
      6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/npm 9.8.1
      /usr/bin/npx 9.8.1
      nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
      *** 18.18.2-1nodesource1 1001
      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
      18.18.1-1nodesource1 1001
      18.18.0-1nodesource1 1001
      18.17.1-1nodesource1 1001
      18.17.0-1nodesource1 1001
      18.16.1-1nodesource1 1001
      18.16.0-1nodesource1 1001
      18.15.0-1nodesource1 1001
      18.14.2-1nodesource1 1001
      18.14.1-1nodesource1 1001
      18.14.0-1nodesource1 1001
      18.13.0-1nodesource1 1001
      18.12.0-1nodesource1 1001
      18.11.0-1nodesource1 1001
      18.10.0-1nodesource1 1001
      18.9.1-1nodesource1 1001
      18.9.0-1nodesource1 1001
      18.8.0-1nodesource1 1001
      18.7.0-1nodesource1 1001
      18.6.0-1nodesource1 1001
      18.5.0-1nodesource1 1001
      18.4.0-1nodesource1 1001
      18.3.0-1nodesource1 1001
      18.2.0-1nodesource1 1001
      18.1.0-1nodesource1 1001
      18.0.0-1nodesource1 1001
      12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Core adapters versions
      js-controller: 5.0.12
      admin: 6.12.0
      javascript: 7.1.4
      Adapters from github: 0
      Adapter State
      • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.backitup.0 : backitup : raspberrypi - enabled
      • system.adapter.discovery.0 : discovery : raspberrypi - enabled
      • system.adapter.email.0 : email : raspberrypi - enabled
        system.adapter.flot.0 : flot : raspberrypi - disabled
      • system.adapter.fritzdect.0 : fritzdect : raspberrypi - enabled
        system.adapter.habpanel.0 : habpanel : raspberrypi - disabled
      • system.adapter.history.0 : history : raspberrypi - enabled
        system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled
      • system.adapter.jarvis.0 : jarvis : raspberrypi - enabled
      • system.adapter.javascript.0 : javascript : raspberrypi - enabled
      • system.adapter.net-tools.0 : net-tools : raspberrypi - enabled
      • system.adapter.ping.0 : ping : raspberrypi - enabled
      • system.adapter.sonoff.1 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0
      • system.adapter.sonoff.2 : sonoff : raspberrypi - enabled, port: 1884, bind: 0.0.0.0
      • system.adapter.terminal.0 : terminal : raspberrypi - enabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.tr-064.0 : tr-064 : raspberrypi - disabled
        system.adapter.tr-064.1 : tr-064 : raspberrypi - disabled
        system.adapter.tr-064.2 : tr-064 : raspberrypi - disabled
        system.adapter.tr-064.3 : tr-064 : raspberrypi - disabled
      • system.adapter.tuya.0 : tuya : raspberrypi - enabled
        system.adapter.vis-bars.0 : vis-bars : raspberrypi - disabled
        system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled
      • system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled
        system.adapter.vis-material-advanced.0 : vis-material-advanced : raspberrypi - disabled
        system.adapter.vis-metro.0 : vis-metro : raspberrypi - disabled
        system.adapter.vis.0 : vis : raspberrypi - enabled
      • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      • system.adapter.whatsapp-cmb.0 : whatsapp-cmb : raspberrypi - enabled
      • system.adapter.yahka.0 : yahka : raspberrypi - enabled
      • instance is alive
      ioBroker-Repositories
      stable : http://download.iobroker.net/sources-dist.json
      beta : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Used repository: stable
      Adapter "admin" : 6.12.0 , installed 6.12.0
      Adapter "backitup" : 2.8.1 , installed 2.8.1
      Adapter "discovery" : 3.1.0 , installed 3.1.0
      Adapter "email" : 1.2.0 , installed 1.2.0
      Adapter "flot" : 1.12.0 , installed 1.12.0
      Adapter "fritzdect" : 2.3.1 , installed 2.3.1
      Adapter "habpanel" : 0.5.0 , installed 0.5.0
      Adapter "history" : 3.0.1 , installed 3.0.1
      Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
      Adapter "jarvis" : 3.1.2 , installed 3.1.2
      Adapter "javascript" : 7.1.4 , installed 7.1.4
      Controller "js-controller": 5.0.12 , installed 5.0.12
      Adapter "net-tools" : 0.2.0 , installed 0.2.0
      Adapter "ping" : 1.6.2 , installed 1.6.2
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Adapter "socketio" : 6.5.5 , installed 6.5.5
      Adapter "sonoff" : 2.5.3 , installed 2.5.3
      Adapter "terminal" : 1.0.0 , installed 1.0.0
      Adapter "tr-064" : 4.2.18 , installed 4.2.18
      Adapter "tuya" : 3.14.2 , installed 3.14.2
      Adapter "vis" : 1.4.16 , installed 1.4.16
      Adapter "vis-bars" : 0.1.4 , installed 0.1.4
      Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
      Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
      Adapter "vis-material-advanced": 1.7.4, installed 1.7.4
      Adapter "vis-metro" : 1.2.0 , installed 1.2.0
      Adapter "web" : 6.1.2 , installed 6.1.2
      Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3
      Adapter "ws" : 2.5.5 , installed 2.5.5
      Adapter "yahka" : 1.0.3 , installed 1.0.3
      Objects and States
      Objects: 1296
      States: 1180
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 11965 528/cupsd
      tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 15508 567/sshd: /usr/sbin
      tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 47629 5692/iobroker.js-co
      tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 46901 5692/iobroker.js-co
      tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN 1001 50312 6025/io.jarvis.0
      tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 48033 5937/io.sonoff.2
      tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 50183 5920/io.sonoff.1
      tcp 0 0 0.0.0.0:42173 0.0.0.0:* LISTEN 1001 50085 6077/io.yahka.0
      tcp6 0 0 :::22 :::* LISTEN 0 15510 567/sshd: /usr/sbin
      tcp6 0 0 :::45069 :::* LISTEN 1001 50083 6077/io.yahka.0
      tcp6 0 0 :::8088 :::* LISTEN 1001 51424 6111/io.terminal.0
      tcp6 0 0 :::8082 :::* LISTEN 1001 51239 6010/io.web.0
      tcp6 0 0 :::8081 :::* LISTEN 1001 46930 5711/io.admin.0
      tcp6 0 0 ::1:631 :::* LISTEN 0 11964 528/cupsd
      udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 47871 5822/io.tuya.0
      udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 47872 5822/io.tuya.0
      udp 0 0 0.0.0.0:631 0.0.0.0:* 0 15590 580/cups-browsed
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11790 384/avahi-daemon: r
      udp 0 0 0.0.0.0:58920 0.0.0.0:* 108 11792 384/avahi-daemon: r
      udp 0 0 0.0.0.0:68 0.0.0.0:* 0 13283 441/dhcpcd
      udp6 0 0 :::546 :::* 0 16455 441/dhcpcd
      udp6 0 0 :::44193 :::* 108 11793 384/avahi-daemon: r
      udp6 0 0 :::5353 :::* 108 11791 384/avahi-daemon: r
      2023-11-01 11:32:04.365 - info: host.raspberrypi Do not restart adapter system.adapter.tr-064.3 because disabled or deleted
      2023-11-01 11:32:11.459 - error: tr-064.2 (7611) adapter disabled
      2023-11-01 11:32:11.512 - warn: tr-064.2 (7611) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      2023-11-01 11:32:12.066 - error: host.raspberrypi instance system.adapter.tr-064.2 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      2023-11-01 11:32:12.066 - info: host.raspberrypi Do not restart adapter system.adapter.tr-064.2 because disabled or deleted
      2023-11-01 11:32:16.631 - error: tr-064.1 (7625) adapter disabled
      2023-11-01 11:32:16.687 - warn: tr-064.1 (7625) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      2023-11-01 11:32:17.242 - error: host.raspberrypi instance system.adapter.tr-064.1 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      2023-11-01 11:32:17.243 - info: host.raspberrypi Do not restart adapter system.adapter.tr-064.1 because disabled or deleted
      2023-11-01 11:37:18.989 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
      2023-11-01 11:37:18.990 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
      2023-11-01 11:42:54.301 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
      2023-11-01 11:42:54.302 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
      2023-11-01 11:45:29.193 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Connect locally to device
      2023-11-01 11:45:29.194 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj Init with IP=192.168.178.66, Key=rKNJX%q%j/9y<JKX, Version=3.4
      2023-11-01 11:46:16.458 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (1): connection timed out
      2023-11-01 11:46:39.522 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.66:6668
      2023-11-01 11:47:22.594 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.66:6668
      2023-11-01 11:48:25.666 - info: tuya.0 (5822) bf3b14a6e24938dcefsvvj: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.66:6668
      2023-11-01 11:48:29.595 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
      2023-11-01 11:48:29.596 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
      2023-11-01 11:54:04.892 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
      2023-11-01 11:54:04.893 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
      2023-11-01 11:59:40.185 - info: tuya.0 (5822) bf7485f58956be0656blvs: Connect locally to device
      2023-11-01 11:59:40.185 - info: tuya.0 (5822) bf7485f58956be0656blvs Init with IP=192.168.178.51, Key=4870bccd2069e6ff, Version=3.3
      iob diag has finished.
      @gerdnutzinger
      Kannst du mal bitte die Ausgabe von
      pgrep -f 'Xorg|ayland|X11'
      posten?
      G 1 Antwort Letzte Antwort
        @gerdnutzinger
        posten?
        GerdNutzinger
        pi@raspberrypi:~ $ pgrep -f 'Xorg|ayland|X11'
        575
        pi@raspberrypi:~ $
        • G GerdNutzinger
          575
          pi@raspberrypi:~ $
          @gerdnutzinger sagte in Probleme bei 4.0.23 auf 5.0.12:
          Danke. Bitte noch
          ps aux | grep -E 'Xorg|ayland|X11'
          G 2 Antworten Letzte Antwort
            Danke. Bitte noch
            GerdNutzinger
            ps aux
            Für was sind diese Daten die Du von mir brauchst?
              Danke. Bitte noch
              GerdNutzinger
              pi@raspberrypi:~ $ ps aux | grep -E 'Xorg|ayland|X11'
              root 575 0.0 1.3 198080 52660 tty7 Ssl+ 10:36 0:04 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
              pi 20525 0.0 0.0 7464 544 pts/0 S+ 16:13 0:00 grep --color=auto -E Xorg|ayland|X11
              • G GerdNutzinger
                ps aux
                Für das iob diag Kommando. Wollte mal sehen warum da bei dir noch was bezgl. des X-Servers gefunden wird, das dürfte eigentlich nicht mehr der Fall sein.
                Kannst du die Kiste mal komplett neustarten und dann nochmal
                bitte.
                  bitte.
                  GerdNutzinger
                  Schaut anders aus...
                  pi 1579 0.0 0.0 7464 484 pts/0 S+ 16:36 0:00 grep --color=auto -E Xorg|ayland|X11
                  pi@raspberrypi:~ $
                  • G GerdNutzinger
                    pi@raspberrypi:~ $
                    Ja, so soll es auch aussehen. Danke für die Mithilfe!
                      GerdNutzinger
                      Ich muss DANKE sagen und das sehr gerne.
                      Was muss ich machen das ich das Problem als gelöst kennzeichne?
                      • Meister MopperM Online
                        Meister Mopper
                        Deinen ersten Eintrag mit [gelöst] ergänzen.
                        Proxmox und HA ...
                        • G GerdNutzinger
                          @gerdnutzinger
                          Editiere den ersten Beitrag entsprechend.
