  3. Einsteigerfragen
  4. Installation
  5. Troubleshooting NodeJS update
nodejs 18nodejs update
504 Beiträge 60 Kommentatoren 239.8k Aufrufe 52 Beobachtet
    austrogaucho
    #293
    "curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash -" hat funktioniert und hat mich von von 16.20.1 (nur) auf 18.7.1 gehoben (18.8.0 ist empfohlen)
    es kam aber folgende Meldung:
                               SCRIPT DEPRECATION WARNING
      This script, located at https://deb.nodesource.com/setup_X, used to
      install Node.js is deprecated now and will eventually be made inactive.
      Please visit the NodeSource distributions Github and follow the
      instructions to migrate your repo.
      https://github.com/nodesource/distributions
      The NodeSource Node.js Linux distributions GitHub repository contains
      information about which versions of Node.js and which Linux distributions
      are supported and how to install it.
    TO AVOID THIS WAIT MIGRATE THE SCRIPT
    Continuing in 60 seconds (press Ctrl-C to abort) ...
    nach 1min gehts dann weiter mit:
    ## Installing the NodeSource Node.js 18.x repo...
    ## Populating apt-get cache...
    + apt-get update
    OK:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
    OK:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
    OK:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
    OK:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
    OK:5 https://deb.nodesource.com/node_18.x focal InRelease
    ## Confirming "focal" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/focal/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x focal main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x focal main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    Ich hab dann gemäß der Anleitung mit "sudo apt install -y nodejs" weitergemacht
    dann kam
    Die folgenden NEUEN Pakete werden installiert:
      nodejs
    0 aktualisiert, 1 neu installiert, 0 zu entfernen und 14 nicht aktualisiert.
    Es müssen 28,9 MB an Archiven heruntergeladen werden.
    Nach dieser Operation werden 188 MB Plattenplatz zusätzlich benutzt.
    Holen:1 https://deb.nodesource.com/node_18.x focal/main amd64 nodejs amd64 18.17.1-deb-1nodesource1 [28,9 MB]
    Es wurden 28,9 MB in 5 s geholt (5.334 kB/s).
    Vormals nicht ausgewähltes Paket nodejs wird gewählt.
    (Lese Datenbank ... 121482 Dateien und Verzeichnisse sind derzeit installiert.)
    Vorbereitung zum Entpacken von .../nodejs_18.17.1-deb-1nodesource1_amd64.deb ...
    Entpacken von nodejs (18.17.1-deb-1nodesource1) ...
    nodejs (18.17.1-deb-1nodesource1) wird eingerichtet ...
    Trigger für man-db (2.9.1-1) werden verarbeitet ...
    ? wie komm ich nun auf die 18.8.0 ?
    • A austrogaucho
      + apt-get update
      + apt-get update
      dann kam
        nodejs
      Thomas BraunT Offline
      #294
      @austrogaucho
      Mit dem Skript aus meiner Signatur.
      Pedder007P 1 Antwort Letzte Antwort
        @austrogaucho
        Pedder007P Offline
        Pedder007P Offline
        Pedder007
        schrieb am zuletzt editiert von Pedder007
        #295
        @thomas-braun sagte in Troubleshooting NodeJS update:
        Klasse Script! Hatte 'gefühlt' alle Zustände bzgl. des 18.18.0 er Updates:
        • 1x iOMaster, dediziert auf Raspi4B, mit in Info angezeigtem Update, allerdings keine Anzeige/Update per 'sudo apt update'.
        • 4x vermeintlich gleiche iOSlaves unter Proxmox, allerdings manchmal mit angezeigtem Update in Info und manchmal nicht und dann wiederum manchmal möglichem 'sudo apt update' per Konsole, allerdings auch nicht jeweils gleich bzgl. der in Info angezeigten Updates.
        Also eine bunte Mischung, wobei Ausgangslage überall der letzte Stand mit Node 18.17.1 inkl. passendem NPM war und ich auch im Glauben war, dass ich alle Instanzen immer gleich behandelt hatte.
        Mit dem Script habe ich sie alle 'gerade' bekommen. Danke @thomas-braun
        Pedder
        All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
        Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
        Under construction: Smart-WoMo auf Raspi4
        • H Offline
          Happyuser20
          schrieb am zuletzt editiert von Happyuser20
          #296
          Hallo zusammen.
          Ich wollte auf meinem IOB Slave (Raspi 3+) NodeJS von 16 auf 18 updaten.
          Ich fürchte ich habe das Teil komplett abgeschossen. Habe jetzt einen Raspi mit IOB ohne NodeJS.
          Es lässt sich auch das erstellte Backup nicht mehr zurückspielen.
          @Thomas-Braun Dein Script knackt meine vermurkste Installation auch nicht :(
          *** nodejs is NOT correctly installed ***
          We found these nodejs versions available for installation:
          nodejs:
            Installed: (none)
            Candidate: 18.18.2-1nodesource1
            Version table:
               18.18.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          Your nodejs-Installation seems to be faulty. Shall we try to fix it?
          Press <y> to continue or any other key to quit
          Fixing your nodejs setup
          *** Deleting  ***
          rm: cannot remove '': No such file or directory
          *** Deleting  ***
          *** Deleting  ***
          Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
          ./iob_node_update: line 248: node: command not found
          You are running nodejs . Do you want to install latest version from nodejs v.18 branch?
          Trying to fix your installation now. Please be patient.
          Waiting for ioBroker to shut down - Give me a minute...
          *** Removing previous installations of nodejs
          E: Unable to locate package nodejs
          E: Unable to locate package libnode*
          E: Couldn't find any package by glob 'libnode*'
          E: Couldn't find any package by regex 'libnode*'
          E: Unable to locate package node-*
          E: Couldn't find any package by glob 'node-*'
          E: Couldn't find any package by regex 'node-*'
          *** These repos are active on your system:
          Ign:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
          Ign:2 http://raspbian.raspberrypi.org/raspbian stretch Release
          Ign:3 http://raspbian.raspberrypi.org/raspbian stretch/main all Packages
          Ign:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
          Ign:5 http://raspbian.raspberrypi.org/raspbian stretch/main Translation-en
          Ign:6 http://raspbian.raspberrypi.org/raspbian stretch/contrib all Packages
          Ign:7 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages
          Ign:8 http://raspbian.raspberrypi.org/raspbian stretch/contrib Translation-en
          Ign:9 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages
          Ign:10 http://raspbian.raspberrypi.org/raspbian stretch/non-free all Packages
          Ign:11 http://raspbian.raspberrypi.org/raspbian stretch/non-free Translation-en
          Ign:12 http://raspbian.raspberrypi.org/raspbian stretch/rpi all Packages
          Ign:13 http://raspbian.raspberrypi.org/raspbian stretch/rpi armhf Packages
          Ign:14 http://raspbian.raspberrypi.org/raspbian stretch/rpi Translation-en
          Err:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
            404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
          Reading package lists... Done
          W: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does not have a Release file.
          N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
          N: See apt-secure(8) manpage for repository creation and user configuration details.
          E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/stretch/main/binary-armhf/Packages  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
          E: Some index files failed to download. They have been ignored, or old ones used instead.
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Ign:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
          Ign:6 http://raspbian.raspberrypi.org/raspbian stretch/main Translation-en
          Ign:7 http://raspbian.raspberrypi.org/raspbian stretch/contrib all Packages
          Ign:8 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages
          Ign:9 http://raspbian.raspberrypi.org/raspbian stretch/contrib Translation-en
          Ign:11 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages
          Ign:12 http://raspbian.raspberrypi.org/raspbian stretch/non-free Translation-en
          Ign:14 http://raspbian.raspberrypi.org/raspbian stretch/rpi all Packages
          Ign:15 http://raspbian.raspberrypi.org/raspbian stretch/rpi Translation-en
          Err:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
          Installing the recommended nodejs version now!
          ./iob_node_update: line 336: [: : integer expression expected
          Exact recommended version unknown, installing a fallback!
          E: Unable to correct problems, you have held broken packages.
          Updating fallback to latest nodejs v18 release
          E: Broken packages
          ./iob_node_update: line 349: node: command not found
           has been installed! You are using the latest version now!
          ./iob_node_update: line 353: [: : integer expression expected
          Installing the recommended nodejs version!
          E: Broken packages
          We tried our best to fix your nodejs. Please run iob diag again to verify.
          *** RESTARTING ioBroker NOW! ***
           Please refresh or restart your browser in a few moments.
          Gibt es noch eine Möglichkeit das ding zu retten?
          Danke für eure Hilfe schon mal im voraus.
          • H Happyuser20
            Hallo zusammen.
            nodejs:
              Installed: (none)
              Version table:
            *** Deleting  ***
            *** Deleting  ***
            *** Deleting  ***
            Package: nodejs
            Pin-Priority: 1001
            E: Broken packages
            E: Broken packages
            #297
            @happyuser20
            Dein 'stretch' ist so tot, das stinkt nicht mal mehr. Installier da zunächst ein lebendes Betriebssystem.
            H 1 Antwort Letzte Antwort
              @happyuser20
              Happyuser20
              #298
              Komplett neu aufsetzten, richtig?
              Sorry für die doofe Frage.
              • H Happyuser20
                #299
                @happyuser20
                Röchtösch!
                  @happyuser20
                  Röchtösch!
                  Happyuser20
                  #300
                  Dann weis ich schon was ich am Feiertag mache ;)
                    Baki074
                    #301
                    ich habe mit dem Befehl sudo apt install -y nodejs Probleme.
                    Und zwar erhalte ich die Meldung "Fehlschlag beim Holen von...".
                    sudo apt-get update habe ich schon versucht. Hat für die Installation nichts gebracht - derselbe Fehler wird angezeigt.
                    Was genau muss ich machen, damit die Installation klappt?
                    Danke schonmal!
                    pi@phoscon-iob:~ $ sudo apt install -y nodejs
                      nodejs
                    0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                    Es müssen 25,9 MB an Archiven heruntergeladen werden.
                    Nach dieser Operation werden 177 MB Plattenplatz zusätzlich benutzt.
                    Fehl:1 https://deb.nodesource.com/node_18.x buster/main armhf nodejs armhf 18.17.1-deb-1nodesource1
                      404  Not Found [IP: 172.67.10.205 443]
                    E: Fehlschlag beim Holen von https://deb.nodesource.com/node_18.x/pool/main/n/nodejs/nodejs_18.17.1-deb-1nodesource1_armhf.deb 404  Not Found [IP: 172.67.10.205 443]
                    E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
                    pi@phoscon-iob:~ $ sudo apt-get update
                    OK:1 http://phoscon.de/apt/deconz buster InRelease
                    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    OK:3 http://archive.raspberrypi.org/debian buster InRelease
                    OK:4 https://deb.nodesource.com/node_18.x buster InRelease
                    • B Baki074
                      Danke schonmal!
                        nodejs
                      #302
                      @baki074
                      Buster ist tot. Muss ersetzt werden.
                      Und das Update von nodejs geht über
                      iob nodejs-update
                      (Ggfls. zuvor iob fix ausführen).
                        @baki074
                        iob nodejs-update
                        Baki074
                        #303
                        @thomas-braun Super, hat funktioniert - danke!
                        Blöde Frage: Kann ich Debian 10 easy durch 11 ersetzen bzw. gibt es vielleicht eine Schritt für Schritt Anleitung hierfür?
                        • B Baki074
                          #304
                          @baki074
                          https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                          Aktuell ist allerdings Debian 12 'Bookworm'.
                          https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                            @baki074
                            marian.t
                            #305
                            Habe nach einem Update auf node.js 18.18.2 iobroker bis auf lovelace-UI am laufen.
                            Lovelace-UI bricht wiederkehrend ab (wird terminated).
                            Das betrifft sowohl node.js update auf buster als auch eine komplette Neuinstallation von iobroker auf bookworm und einem anderem raspi. Logs und weitere Details unter
                            https://github.com/ioBroker/ioBroker.lovelace/issues/476.
                            Hier Logeintrag vom Host:
                            „States 127.0.0.1:37204 Error from InMemDB: Error: The pattern "typeof window.socketLoadedHandler === 'function' && window.socketLoadedHandler()" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StatesInMemoryServer.handleSubscribe (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:324:59) at StatesInMemoryServer._subscribeForClient (/opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:258:14) at RedisHandler. (/opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:395:26) at RedisHandler.emit (node:events:517:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:209:37) at processImmediate (node:internal/timers:476:21)“
                            Kann ich es korrigieren? Falls ja wo/wie? Oder hilft ein Downgrade von nod.js auf 16.x?
                            • M marian.t
                              #306
                              @marian-t sagte in Troubleshooting NodeJS update:
                              Da nodejs@16 jenseits des EndOfLife ist: Nein.
                              Poste das mal beim js-controller, könnte auch von dort kommen.
                              • W Offline
                                W Offline
                                Wednesday13
                                #307
                                Hi zusammen!
                                ich komme mit meinem längst fälligen Update auch nicht weiter... folgende Fehlermeldung wird mir ausgeworfen:
                                pi@raspberrypi3iOb:~ $ curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                                • apt-get update
                                  Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                                  OK:2 https://deb.nodesource.com/node_14.x buster InRelease
                                  Holen:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                  E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »o ldoldstable« geändert.
                                  N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
                                  E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wurde der »Suite«-Wert von »stable« in »oldoldstable« geändert.
                                  Error executing command, exiting
                                könnt ihr mir sagen wie ich jetzt weiterkomme?
                                Danke euch!
                                DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
                                • W Wednesday13
                                  Hi zusammen!
                                  • apt-get update
                                  Danke euch!
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  #308
                                  @wednesday13 sagte in Troubleshooting NodeJS update:
                                  zu erst solltest Du den uns unbekannten Übersetzer ausschalten. Linux ist und bleibt englisch ;)
                                  Zweitens bitte alles an Text hier in Codetags einbinden.
                                  Das ist oben der </> Button.
                                  Lehrling seit 1975 !!!
                                  W 1 Antwort Letzte Antwort
                                  • W Wednesday13
                                    Hi zusammen!
                                    • apt-get update
                                    Danke euch!
                                    #309
                                    Mit dem Kommando
                                    iob nodejs-update
                                    Dein buster ist aber tot. Installier da was lebendiges. Und mach regelmäßig Updates...
                                    Kann ja nicht sein, dass dein Suite von 'stable' auf 'oldoldstable' springt. Dann hast du ja nie was gemacht...
                                      Mit dem Kommando
                                      iob nodejs-update
                                      W Offline
                                      W Offline
                                      Wednesday13
                                      #310
                                      @thomas-braun Danke dir für die Antwort. Ich bin absolut froh, dass ich das Dingen so zum laufen bekommen habe vor einiger Zeit. 🙄 Bin da absolut kein Profi drin. Kannst du mir das genauer erklären was ich machen muss?
                                      • DJMarc75D DJMarc75
                                        W Offline
                                        W Offline
                                        Wednesday13
                                        #311
                                        @djmarc75 Ich hab da gar nichts an... das hat mir Putty so ausgeworfen. Du merkst es, noob und so... 😁
                                        • W Wednesday13
                                          #312
                                          @wednesday13
                                          Installier es neu...
                                          Raspberry OS 12 'Bookworm' in der 64bit Version 'Lite' und lass die Sprache auf Englisch.
