  4. Sonoff zbbridge pro mit Tastmota und ZigBee-Adapter
30 Beiträge 6 Kommentatoren 6.6k Aufrufe 4 Beobachtet
  • arteckA arteck
    @snert sagte in Sonoff zbbridge pro mit Tastmota und ZigBee-Adapter:
    at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
    da ist ein Fehler im converter... installier mal den adapter von GIT
    und mach Debug AUS.. brauch ich nicht
    Snert
    @arteck Habe die Version 1.8.24 über GIT geladen. Ergebnis ist erstmal das selbe, aber vll. hilft es trozdem weiter.
    2023-10-26 22:17:19.749 - info: host.smarthome-VM instance system.adapter.zigbee.0 started with pid 874855
    2023-10-26 22:17:20.240 - info: admin.0 (649296) ==> Connected system.user.admin from ::ffff:192.168.178.89
    2023-10-26 22:17:22.388 - info: zigbee.0 (874855) starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
    2023-10-26 22:17:22.477 - error: zigbee.0 (874855) Serial port not selected! Go to settings page.
    2023-10-26 22:17:22.595 - info: zigbee.0 (874855) delete old Backup files. keep only last 10
    2023-10-26 22:17:22.596 - info: zigbee.0 (874855) Starting Zigbee npm ...
    2023-10-26 22:17:23.319 - error: zigbee.0 (874855) Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
    2023-10-26 22:17:23.320 - error: zigbee.0 (874855) Failed to start Zigbee
    2023-10-26 22:17:23.320 - error: zigbee.0 (874855) Error herdsman start
    2023-10-26 22:17:23.344 - info: zigbee.0 (874855) Installed Version: ioBroker/ioBroker.zigbee
    2023-10-26 22:17:33.322 - info: zigbee.0 (874855) Try to reconnect. 1 attempts left
    2023-10-26 22:17:33.324 - info: zigbee.0 (874855) Starting Zigbee npm ...
    2023-10-26 22:17:33.368 - info: zigbee.0 (874855) Installed Version: ioBroker/ioBroker.zigbee
    2023-10-26 22:17:33.733 - error: zigbee.0 (874855) Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
    2023-10-26 22:17:33.734 - error: zigbee.0 (874855) Failed to start Zigbee
    2023-10-26 22:17:33.735 - error: zigbee.0 (874855) Error herdsman start
    2023-10-26 22:18:19.826 - info: host.smarthome-VM stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2023-10-26 22:18:19.893 - info: zigbee.0 (874855) Got terminate signal TERMINATE_YOURSELF
    2023-10-26 22:18:19.904 - info: host.smarthome-VM stopInstance system.adapter.zigbee.0 send kill signal
    2023-10-26 22:18:19.894 - info: zigbee.0 (874855) cleaned everything up...
    2023-10-26 22:18:19.897 - info: zigbee.0 (874855) Zigbee: disabling joining new devices.
    2023-10-26 22:18:19.925 - warn: zigbee.0 (874855) Failed to stop zigbee during startup
    2023-10-26 22:18:19.932 - info: zigbee.0 (874855) terminating
    2023-10-26 22:18:19.933 - info: zigbee.0 (874855) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-26 22:18:20.094 - info: admin.0 (649296) <== Disconnect system.user.admin from ::ffff:192.168.178.89
    2023-10-26 22:18:20.540 - info: host.smarthome-VM instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-26 22:18:22.995 - info: host.smarthome-VM instance system.adapter.zigbee.0 started with pid 874887
    2023-10-26 22:18:26.421 - info: zigbee.0 (874887) starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
    2023-10-26 22:18:26.504 - info: zigbee.0 (874887) delete old Backup files. keep only last 10
    2023-10-26 22:18:26.506 - info: zigbee.0 (874887) Starting Zigbee npm ...
    2023-10-26 22:18:26.914 - info: zigbee.0 (874887) Installed Version: ioBroker/ioBroker.zigbee
    2023-10-26 22:18:36.915 - error: zigbee.0 (874887) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-10-26 22:18:36.916 - error: zigbee.0 (874887) unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:18:37.058 - error: zigbee.0 (874887) Error: Reset error: Error: {"sequence":-1} after 10000ms
    at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    2023-10-26 22:18:37.059 - error: zigbee.0 (874887) Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:18:37.164 - info: zigbee.0 (874887) cleaned everything up...
    2023-10-26 22:18:37.172 - info: zigbee.0 (874887) Zigbee: disabling joining new devices.
    2023-10-26 22:18:37.443 - warn: zigbee.0 (874887) Failed to stop zigbee during startup
    2023-10-26 22:18:37.444 - info: zigbee.0 (874887) terminating
    2023-10-26 22:18:37.445 - warn: zigbee.0 (874887) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-10-26 22:18:38.095 - error: host.smarthome-VM Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2023-10-26 22:18:38.095 - error: host.smarthome-VM Caught by controller[0]: Error: Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:18:38.096 - error: host.smarthome-VM Caught by controller[0]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
    2023-10-26 22:18:38.096 - error: host.smarthome-VM Caught by controller[0]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    2023-10-26 22:18:38.096 - error: host.smarthome-VM instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-10-26 22:18:38.096 - info: host.smarthome-VM Restart adapter system.adapter.zigbee.0 because enabled
    2023-10-26 22:19:08.160 - info: host.smarthome-VM instance system.adapter.zigbee.0 started with pid 874904
    2023-10-26 22:19:11.250 - info: zigbee.0 (874904) starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
    2023-10-26 22:19:11.312 - info: zigbee.0 (874904) delete old Backup files. keep only last 10
    2023-10-26 22:19:11.313 - info: zigbee.0 (874904) Starting Zigbee npm ...
    2023-10-26 22:19:11.675 - info: zigbee.0 (874904) Installed Version: ioBroker/ioBroker.zigbee
    2023-10-26 22:19:21.672 - error: zigbee.0 (874904) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-10-26 22:19:21.674 - error: zigbee.0 (874904) unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:19:21.746 - error: zigbee.0 (874904) Error: Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:19:21.747 - error: zigbee.0 (874904) Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:19:21.772 - info: zigbee.0 (874904) cleaned everything up...
    2023-10-26 22:19:21.775 - info: zigbee.0 (874904) Zigbee: disabling joining new devices.
    2023-10-26 22:19:21.980 - warn: zigbee.0 (874904) Failed to stop zigbee during startup
    2023-10-26 22:19:21.981 - info: zigbee.0 (874904) terminating
    2023-10-26 22:19:21.982 - warn: zigbee.0 (874904) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-10-26 22:19:22.603 - error: host.smarthome-VM Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2023-10-26 22:19:22.603 - error: host.smarthome-VM Caught by controller[1]: Error: Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:19:22.603 - error: host.smarthome-VM Caught by controller[1]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
    2023-10-26 22:19:22.603 - error: host.smarthome-VM Caught by controller[1]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    2023-10-26 22:19:22.604 - error: host.smarthome-VM instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-10-26 22:19:22.604 - info: host.smarthome-VM Restart adapter system.adapter.zigbee.0 because enabled
    2023-10-26 22:19:52.688 - info: host.smarthome-VM instance system.adapter.zigbee.0 started with pid 874919
    2023-10-26 22:19:55.225 - info: zigbee.0 (874919) starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
    2023-10-26 22:19:55.282 - info: zigbee.0 (874919) delete old Backup files. keep only last 10
    2023-10-26 22:19:55.283 - info: zigbee.0 (874919) Starting Zigbee npm ...
    2023-10-26 22:19:55.596 - info: zigbee.0 (874919) Installed Version: ioBroker/ioBroker.zigbee
    2023-10-26 22:20:00.074 - info: host.smarthome-VM instance system.adapter.netatmo-crawler.0 started with pid 874934
    2023-10-26 22:20:05.596 - error: zigbee.0 (874919) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-10-26 22:20:05.655 - info: host.smarthome-VM instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-26 22:20:05.598 - error: zigbee.0 (874919) unhandled promise rejection: Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:20:05.736 - error: zigbee.0 (874919) Error: Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:20:05.736 - error: zigbee.0 (874919) Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:20:05.795 - info: zigbee.0 (874919) cleaned everything up...
    2023-10-26 22:20:05.809 - info: zigbee.0 (874919) Zigbee: disabling joining new devices.
    2023-10-26 22:20:05.939 - warn: zigbee.0 (874919) Failed to stop zigbee during startup
    2023-10-26 22:20:05.940 - info: zigbee.0 (874919) terminating
    2023-10-26 22:20:05.941 - warn: zigbee.0 (874919) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-10-26 22:20:06.603 - error: host.smarthome-VM Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2023-10-26 22:20:06.604 - error: host.smarthome-VM Caught by controller[0]: Error: Reset error: Error: {"sequence":-1} after 10000ms
    2023-10-26 22:20:06.604 - error: host.smarthome-VM Caught by controller[0]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
    2023-10-26 22:20:06.604 - error: host.smarthome-VM Caught by controller[0]: at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    2023-10-26 22:20:06.604 - error: host.smarthome-VM instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-10-26 22:20:06.605 - info: host.smarthome-VM Restart adapter system.adapter.zigbee.0 because enabled
    2023-10-26 22:20:06.605 - warn: host.smarthome-VM Do not restart adapter system.adapter.zigbee.0 because restart loop detected
    @Ralla66 auch mit angepastem Template und der Rule, selbes Ergebnis. Morgen kann ich gerne nochmal mich an die andere Anleitung halten.
    Ralla66R 1 Antwort Letzte Antwort
    • S Snert
      Ralla66R Offline
      Ralla66R Offline
      Ralla66
      @snert
      auf welcher Maschine betreibst du den ZigBee-Adapter ?
      • Ralla66R Ralla66
        @snert
        Snert
        @ralla66 In einer Windows Server HyperV VM mit Ubuntu. Die VM hat 16GB Ram und die Host CPU ist ein Intel Core i5-4590 CPU @ 3.30GHz.
        • S Snert
          arteckA Offline
          arteckA Offline
          arteck
          @snert alder was ein konstrukt
          suchmal nach udev... und check das erstmal..scheint als ob der ezsp Treiber nicht geladen wird
          • arteckA arteck
            Snert
            @arteck Da noch einiges mehr auf dem Server an VMs läuft, hatte ich mich dafür entschieden den ioBroker hier zu installieren.
            Bezüglich udev, ist das nicht nur erforderlich wenn ich einen USB Stick verwenden würde?
            @Ralla66 ich habe jetzt auch per OTA geupdated, ohne weitere Verbesserungen.
            • S Snert
              arteckA Offline
              arteckA Offline
              arteck
              ja hast ja recht.. du machst es per ip..
              hmm..kein Plan.. irgendwas ist nicht so konfiguriert wie es soll.. auf der bridge
              • Ralla66R Offline
                Ralla66R Offline
                Ralla66
                @snert
                du hast diese rule in der Tasmota Console ausgeführt und neu gebootet ?
                backlog rule1 on system#boot do TCPStart 8888 endon ; rule1 1 ; TCPStart 8888
                In der Console kann mit
                TCPBaudRate
                die eingestellte Baudrate geprüft werden. Passt diese ?
                Zeige mal den Consolentext, dort steht ja ob die Bridge verbunden ist.
                  Snert
                  schrieb am zuletzt editiert von Snert
                  @ralla66 Ja, alles so durchgeführt.
                  Baudrate sollte so auch passen.
                  RESULT = {"TCPBaudrate":115200}
                  Könnt ihr mir sagen was in der Tasmota Console bei korrekter Verbindung angezeigt wird?
                  Wenn das Kind heute Abend im Bett ist, werde ich alles nochmal in Ruhe neu anfangen. Gibts ne Möglichkeit alles auf 0 zu setzen (auch den CC2652) oder geschieht das automatisch mit dem neuen flashen von Tasmota?
                  Edit:
                  00:00:00.002 HDW: ESP32-D0WD-V3 v3.0
                  00:00:00.067 UFS: FlashFS mounted with 908 kB free
                  00:00:00.081 CFG: Loaded from File, Count 59
                  00:00:00.091 QPC: Count 1
                  00:00:00.097 I2C: Bus1 using GPIO26(SCL) and GPIO25(SDA)
                  00:00:00.162 BRY: Berry initialized, RAM used=3902 bytes
                  00:00:00.174 TFS: File '.drvset003' not found
                  00:00:00.183 Project tasmota - Tasmota Version 13.2.0(zbbrdgpro)-2_0_14(2023-10-19T09:04:58)
                  00:00:00.667 WIF: Connecting to AP1 FRITZ!Box 7590 2.4 Channel 1 BSSId 2C:3A:FD:FB:F0:6E in mode 11n as tasmota-6063A4-0932...
                  00:00:02.398 WIF: Connected
                  00:00:02.656 HTP: Web server active on tasmota-6063A4-0932 with IP address 192.168.178.86
                  10:03:13.662 RSL: INFO1 = {"Info1":{"Module":"Sonoff Zigbee Pro","Version":"13.2.0(zbbrdgpro)","FallbackTopic":"cmnd/DVES_6063A4_fb/","GroupTopic":"cmnd/tasmotas/"}}
                  10:03:13.677 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-6063A4-0932","IPAddress":"192.168.178.86","IP6Global":"","IP6Local":"fe80::4222:d8ff:fe60:63a4"}}
                  10:03:13.691 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":31}}
                  10:03:13.716 RUL: SYSTEM#BOOT performs "TCPStart 8888"
                  10:03:13.718 TCP: Starting TCP server on port 8888
                  10:03:13.722 RSL: RESULT = {"TCPStart":"Done"}
                  10:03:16.964 QPC: Reset
                  10:03:17.891 RSL: STATE = {"Time":"2023-10-27T10:03:17","Uptime":"0T00:00:08","UptimeSec":8,"Heap":164,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-37,"LinkCount":1,"Downtime":"0T00:00:03"}}00:00:02.398 WIF: Connected
                  10:03:28.123 TCP: Got connection from 192.168.178.36
                  10:04:12.032 TCP: Got connection from 192.168.178.36
                  10:08:17.901 RSL: STATE = {"Time":"2023-10-27T10:08:17","Uptime":"0T00:05:08","UptimeSec":308,"Heap":160,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-38,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  10:13:08.930 APP: Serial logging disabled
                  10:13:17.936 RSL: STATE = {"Time":"2023-10-27T10:13:17","Uptime":"0T00:10:08","UptimeSec":608,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  10:18:17.912 RSL: STATE = {"Time":"2023-10-27T10:18:17","Uptime":"0T00:15:08","UptimeSec":908,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-35,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  10:23:17.896 RSL: STATE = {"Time":"2023-10-27T10:23:17","Uptime":"0T00:20:08","UptimeSec":1208,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  10:28:17.912 RSL: STATE = {"Time":"2023-10-27T10:28:17","Uptime":"0T00:25:08","UptimeSec":1508,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  10:33:17.889 RSL: STATE = {"Time":"2023-10-27T10:33:17","Uptime":"0T00:30:08","UptimeSec":1808,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  10:38:17.927 RSL: STATE = {"Time":"2023-10-27T10:38:17","Uptime":"0T00:35:08","UptimeSec":2108,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-34,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  10:43:17.922 RSL: STATE = {"Time":"2023-10-27T10:43:17","Uptime":"0T00:40:08","UptimeSec":2408,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-37,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  10:48:17.893 RSL: STATE = {"Time":"2023-10-27T10:48:17","Uptime":"0T00:45:08","UptimeSec":2708,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  10:53:17.889 RSL: STATE = {"Time":"2023-10-27T10:53:17","Uptime":"0T00:50:08","UptimeSec":3008,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-37,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  10:58:17.916 RSL: STATE = {"Time":"2023-10-27T10:58:17","Uptime":"0T00:55:08","UptimeSec":3308,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-37,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  11:03:17.910 RSL: STATE = {"Time":"2023-10-27T11:03:17","Uptime":"0T01:00:08","UptimeSec":3608,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-35,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  11:08:17.903 RSL: STATE = {"Time":"2023-10-27T11:08:17","Uptime":"0T01:05:08","UptimeSec":3908,"Heap":163,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  11:11:45.034 CMD: TCPBaudRate
                  11:11:45.039 RSL: RESULT = {"TCPBaudrate":115200}
                  11:13:17.921 RSL: STATE = {"Time":"2023-10-27T11:13:17","Uptime":"0T01:10:08","UptimeSec":4208,"Heap":160,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-35,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  11:18:17.925 RSL: STATE = {"Time":"2023-10-27T11:18:17","Uptime":"0T01:15:08","UptimeSec":4508,"Heap":160,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-36,"LinkCount":1,"Downtime":"0T00:00:03"}}
                  11:21:46.024 CMD: TCPBaudRate
                  11:21:46.029 RSL: RESULT = {"TCPBaudrate":115200}
                  • S Snert
                    Edit:
                    Ralla66R Offline
                    Ralla66R Offline
                    Ralla66
                    @snert
                    TCPStart":"Done zeigt an das der TCP Server aktiv ist.
                    Wenn eine Verbindung besteht wird die IP des Client in der Console angezeigt.
                    Sollte dies sein :
                    soweit in Ordnung
                    was hängt denn an GPIO 26 und 25 ?
                    default ESP32 ist ja
                    GPIO 21 (SDA)
                    GPIO 22 (SCL)
                    S 2 Antworten Letzte Antwort
                    • Ralla66R Ralla66
                      @snert
                      Sollte dies sein :
                      soweit in Ordnung
                      GPIO 21 (SDA)
                      GPIO 22 (SCL)
                      Snert
                      @ralla66
                      Die eine LED blinkt blau bei WLAN und die andere blinkt grün bei Zigbee Verbindung.
                      • Ralla66R Ralla66
                        @snert
                        Sollte dies sein :
                        soweit in Ordnung
                        GPIO 21 (SDA)
                        GPIO 22 (SCL)
                        Snert
                        @ralla66 Ich habe jetzt alles nochmal von Grund auf neu gemacht.
                        Alles beim alten :-(
                        Was mir aufgefallen ist, ich erhalte beim flashen vom cc2652 NICHT diese Meldung:
                        22:01:25.294 RSL: RESULT = {"ZbState":{"Status":3,"Message":"Configured, starting coordinator"}}
                        22:01:31.293 RSL: RESULT = {"ZbState":{"Status":40,"NewState":9,"Message":"Started as coordinator"}}
                        22:01:31.944 RSL: RESULT = {"ZbState":{"Status":0,"Message":"Started"}}
                        Wie in der Anleitung von notenoughtech beschrieben.
                        Kann ich irgendwie prüfen welche Version auf dem Chip ist, oder was sein Status ist?
                        Das flashen ansonsten wurde jeweils mit ok quitiert.
                        • S Snert
                          Ralla66R Offline
                          Ralla66R Offline
                          Ralla66
                          @snert
                          habe das System nicht mit dem CC2652, kann nur noch theoretisch helfen.
                          hast du nach dem Ausführen dies in der Console gesehen ?
                          FLH: Starting verification of HEX file und
                          FLH: Flashing completed: OK
                          • Ralla66R Ralla66
                            @snert
                            Snert
                            @ralla66 Ja, beide Meldungen sind gekommen.
                            Ich habe auch schon vor lauter Verzweiflung mit den "Typen" im ioBroker Adapter gespielt.
                            Ebenso auch per Webinstaller den Develop Status verwendet und auch das aktuellste hex file "SonoffZBPro_coord_20230507.hex" genutzt.
                            Alles lief immer ohne Probleme durch. Einzig die oben erwähnte Meldung erhalte ich nicht.
                            Jetzt kann ich noch mit den Templates spielen, aber ob das was ändert?
                            • S Snert
                              Ralla66R Offline
                              Ralla66R Offline
                              Ralla66
                              @snert
                              die 3 Status Meldungen scheinen nur nach dem Neustart einmalig in der Console zu erscheinen.
                              Boote mal neu und schau was im Log steht.
                              Ralla66R S 2 Antworten Letzte Antwort
                              • Ralla66R Ralla66
                                @snert
                                Ralla66R Offline
                                Ralla66R Offline
                                Ralla66
                                @ralla66
                                Moin, habe das mal auf einen ESP geflasht.
                                Was geschieht denn wenn du bei Berry -> cc.flash() ausführst ?
                                Console zeigt was ?
                                • Ralla66R Ralla66
                                  @snert
                                  Snert
                                  @ralla66 Wenn ich den Auto-configuration auf Sonoff ZBPro stelle, erhalte ich nach einem Neustart auch die Meldungen.
                                  00:00:00.003 HDW: ESP32-D0WD-V3 v3.0
                                  00:00:00.207 UFS: FlashFS mounted with 408 kB free
                                  00:00:00.239 CFG: Loaded from File, Count 39
                                  00:00:00.241 FRC: Some settings have been reset (2)
                                  00:00:00.246 I2C: Bus1 using GPIO26(SCL) and GPIO25(SDA)
                                  00:00:00.392 BRY: Berry initialized, RAM used=3932 bytes
                                  00:00:00.457 TFS: File '.drvset003' not found
                                  00:00:00.465 Project tasmota - Tasmota Version 13.2.0.1(zbbrdgpro)-2_0_14(2023-10-27T15:39:53)
                                  00:00:01.183 WIF: Connecting to AP1 FRITZ!Box 7590 2.4 Channel 1 BSSId 2C:3A:FD:FB:F0:6E in mode 11n as tasmota-6063A4-0932...
                                  00:00:03.005 WIF: Connected
                                  00:00:03.262 HTP: Web server active on tasmota-6063A4-0932 with IP address 192.168.178.86
                                  08:37:35.244 RSL: INFO1 = {"Info1":{"Module":"Sonoff Zigbee Pro","Version":"13.2.0.1(zbbrdgpro)","FallbackTopic":"cmnd/DVES_6063A4_fb/","GroupTopic":"cmnd/tasmotas/"}}
                                  08:37:35.259 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-6063A4-0932","IPAddress":"192.168.178.86","IP6Global":"","IP6Local":"fe80::4222:d8ff:fe60:63a4"}}
                                  08:37:35.273 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":19}}
                                  08:37:35.296 RUL: SYSTEM#BOOT performs "TCPStart 8888"
                                  08:37:35.299 RSL: RESULT = {"Command":"Error"}
                                  08:37:37.753 QPC: Reset
                                  08:37:39.749 RSL: STATE = {"Time":"2023-10-28T08:37:39","Uptime":"0T00:00:09","UptimeSec":9,"Heap":165,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-28,"LinkCount":1,"Downtime":"0T00:00:04"}}
                                  08:37:46.745 ZIG: rebooting ZNP device
                                  08:37:49.397 RSL: RESULT = {"ZbState":{"Status":1,"Message":"CCxxxx ZNP booted","RestartReason":"Power-up","MajorRel":2,"MinorRel":7}}
                                  08:37:49.597 RSL: RESULT = {"ZbState":{"Status":50,"MajorRel":2,"MinorRel":7,"MaintRel":1,"Revision":20230507}}
                                  08:37:49.747 RSL: RESULT = {"ZbState":{"Status":2,"Message":"Resetting configuration"}}
                                  08:37:51.997 RSL: RESULT = {"ZbState":{"Status":3,"Message":"Configured, starting coordinator"}}
                                  08:37:56.197 RSL: RESULT = {"ZbState":{"Status":40,"NewState":9,"Message":"Started as coordinator"}}
                                  08:37:56.297 RSL: RESULT = {"ZbState":{"Status":51,"IEEEAddr":"0x00124B00257B0374","ShortAddr":"0x0000","DeviceType":7,"DeviceState":9,"NumAssocDevices":0}}
                                  08:37:56.797 RSL: RESULT = {"ZbState":{"Status":0,"Message":"Started"}}
                                  08:37:56.800 ZIG: Zigbee started
                                  08:37:56.808 ZIG: No Zigbee device information
                                  08:37:56.811 ZIG: No Zigbee device data
                                  08:37:56.813 ZIG: ZbLoad '<internal_plugin>' loaded successfully
                                  Mit dier Einstellung bekomme ich aber keine Verbindung vom ioBroker zur Bridge aufgebaut.
                                  Mit der Auto-configuration Sonoff ZBPro TCP bekomme ich keinerlei Meldungen bezüglich dem Chip, dafür kann die Verbindung wieder hergestellt werden. Zumindest steht das Connect drin.
                                  00:00:00.200 UFS: FlashFS mounted with 408 kB free
                                  00:00:00.232 CFG: Loaded from File, Count 41
                                  00:00:00.233 FRC: Some settings have been reset (2)
                                  00:00:00.239 I2C: Bus1 using GPIO26(SCL) and GPIO25(SDA)
                                  00:00:00.381 BRY: Berry initialized, RAM used=3936 bytes
                                  00:00:00.450 TFS: File '.drvset003' not found
                                  00:00:00.459 Project tasmota - Tasmota Version 13.2.0.1(zbbrdgpro)-2_0_14(2023-10-27T15:39:53)
                                  00:00:01.195 WIF: Connecting to AP1 FRITZ!Box 7590 2.4 Channel 1 BSSId 2C:3A:FD:FB:F0:6E in mode 11n as tasmota-6063A4-0932...
                                  00:00:03.020 WIF: Connected
                                  00:00:03.276 HTP: Web server active on tasmota-6063A4-0932 with IP address 192.168.178.86
                                  08:43:49.260 RSL: INFO1 = {"Info1":{"Module":"TCP ZBBridge Pro","Version":"13.2.0.1(zbbrdgpro)","FallbackTopic":"cmnd/DVES_6063A4_fb/","GroupTopic":"cmnd/tasmotas/"}}
                                  08:43:49.275 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-6063A4-0932","IPAddress":"192.168.178.86","IP6Global":"","IP6Local":"fe80::4222:d8ff:fe60:63a4"}}
                                  08:43:49.289 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":20}}
                                  08:43:49.312 RUL: SYSTEM#BOOT performs "TCPStart 8888"
                                  08:43:49.314 TCP: Starting TCP server on port 8888
                                  08:43:49.318 RSL: RESULT = {"TCPStart":"Done"}
                                  08:43:51.779 QPC: Reset
                                  08:43:53.794 RSL: STATE = {"Time":"2023-10-28T08:43:53","Uptime":"0T00:00:09","UptimeSec":9,"Heap":165,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":0,"Berry":{"HeapUsed":3,"Objects":43},"Wifi":{"AP":1,"SSId":"FRITZ!Box 7590 2.4","BSSId":"2C:3A:FD:FB:F0:6E","Channel":1,"Mode":"11n","RSSI":100,"Signal":-31,"LinkCount":1,"Downtime":"0T00:00:04"}}
                                  08:44:18.576 TCP: Got connection from 192.168.178.36
                                  Jetzt die Frage: Sollte ich in der Tasmota console Zigbee infos angezeigt bekommen, wenn die Bridge auf TCP eingestellt ist?
                                  Mir scheint ja fast, dass etwas mit den GPIO Einstellungen nicht passt. So als ob entweder eine c2652 Verbindung XOR eine TCP Verbindung aufgebaut werden kann.
                                  Hier auch nochmal der Log vom ioBroker, mit der TCP Einstellung auf der Bridge:
                                  2023-10-28 09:51:42.548 - info: zigbee.0 (14273) starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.20.2, js-controller: 5.0.12
                                  2023-10-28 09:51:42.597 - info: zigbee.0 (14273) delete old Backup files. keep only last 10
                                  2023-10-28 09:51:42.598 - info: zigbee.0 (14273) Starting Zigbee npm ...
                                  2023-10-28 09:51:42.733 - info: zigbee.0 (14273) Installed Version: ioBroker/ioBroker.zigbee
                                  2023-10-28 09:53:01.043 - info: admin.0 (6349) ==> Connected system.user.admin from ::ffff:192.168.178.89
                                  2023-10-28 09:53:01.165 - error: zigbee.0 (14273) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                  2023-10-28 09:53:01.403 - info: zigbee.0 (14273) List of port: [{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"}]
                                  2023-10-28 09:53:07.422 - info: admin.0 (6349) <== Disconnect system.user.admin from ::ffff:192.168.178.89
                                  2023-10-28 09:53:09.031 - info: host.smarthome-VM stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                  2023-10-28 09:53:09.142 - info: zigbee.0 (14273) Got terminate signal TERMINATE_YOURSELF
                                  2023-10-28 09:53:09.147 - info: host.smarthome-VM stopInstance system.adapter.zigbee.0 send kill signal
                                  2023-10-28 09:53:09.143 - info: zigbee.0 (14273) cleaned everything up...
                                  2023-10-28 09:53:09.145 - info: zigbee.0 (14273) Zigbee: disabling joining new devices.
                                  2023-10-28 09:53:09.645 - info: zigbee.0 (14273) terminating
                                  2023-10-28 09:53:09.647 - info: zigbee.0 (14273) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2023-10-28 09:53:10.154 - info: host.smarthome-VM stopInstance system.adapter.zigbee.0 killing pid 14273
                                  2023-10-28 09:53:10.272 - info: host.smarthome-VM instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-10-28 09:53:12.223 - info: host.smarthome-VM instance system.adapter.zigbee.0 started with pid 14291
                                  2023-10-28 09:53:14.780 - info: zigbee.0 (14291) starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.20.2, js-controller: 5.0.12
                                  2023-10-28 09:53:14.830 - info: zigbee.0 (14291) delete old Backup files. keep only last 10
                                  2023-10-28 09:53:14.831 - info: zigbee.0 (14291) Starting Zigbee npm ...
                                  2023-10-28 09:53:14.928 - info: zigbee.0 (14291) Installed Version: ioBroker/ioBroker.zigbee
                                  2023-10-28 09:54:09.764 - info: host.smarthome-VM instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-10-28 09:54:18.878 - info: admin.0 (6349) ==> Connected system.user.admin from ::ffff:192.168.178.89
                                  2023-10-28 09:54:19.145 - error: zigbee.0 (14291) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                  2023-10-28 09:54:19.329 - info: zigbee.0 (14291) List of port: [{"path":"/dev/ttyS10"},{"path":"/dev/ttyS11"},{"path":"/dev/ttyS12"},{"path":"/dev/ttyS13"},{"path":"/dev/ttyS14"},{"path":"/dev/ttyS15"},{"path":"/dev/ttyS16"},{"path":"/dev/ttyS17"},{"path":"/dev/ttyS18"},{"path":"/dev/ttyS19"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS20"},{"path":"/dev/ttyS21"},{"path":"/dev/ttyS22"},{"path":"/dev/ttyS23"},{"path":"/dev/ttyS24"},{"path":"/dev/ttyS25"},{"path":"/dev/ttyS26"},{"path":"/dev/ttyS27"},{"path":"/dev/ttyS28"},{"path":"/dev/ttyS29"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS30"},{"path":"/dev/ttyS31"},{"path":"/dev/ttyS4"},{"path":"/dev/ttyS5"},{"path":"/dev/ttyS6"},{"path":"/dev/ttyS7"},{"path":"/dev/ttyS8"},{"path":"/dev/ttyS9"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"}]
                                  2023-10-28 09:54:54.365 - info: zigbee.0 (14291) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
                                  2023-10-28 09:54:54.432 - info: zigbee.0 (14291) Unable to disable LED, unsupported function.
                                  2023-10-28 09:54:54.498 - info: zigbee.0 (14291) --> transmitPower : normal
                                  2023-10-28 09:54:54.849 - info: zigbee.0 (14291) Currently no devices.
                                  2023-10-28 09:54:54.849 - info: zigbee.0 (14291) Zigbee started
                                  2023-10-28 09:54:54.853 - error: zigbee.0 (14291) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
                                  2023-10-28 09:54:54.890 - info: host.smarthome-VM stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                  2023-10-28 09:54:54.972 - info: zigbee.0 (14291) Got terminate signal TERMINATE_YOURSELF
                                  2023-10-28 09:54:54.980 - info: host.smarthome-VM stopInstance system.adapter.zigbee.0 send kill signal
                                  2023-10-28 09:54:54.972 - info: zigbee.0 (14291) cleaned everything up...
                                  2023-10-28 09:54:54.973 - info: zigbee.0 (14291) Zigbee: disabling joining new devices.
                                  2023-10-28 09:54:54.999 - info: zigbee.0 (14291) debug devices set to []
                                  2023-10-28 09:54:55.474 - info: zigbee.0 (14291) terminating
                                  2023-10-28 09:54:55.475 - info: zigbee.0 (14291) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2023-10-28 09:54:55.981 - info: host.smarthome-VM stopInstance system.adapter.zigbee.0 killing pid 14291
                                  2023-10-28 09:54:56.008 - info: host.smarthome-VM instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2023-10-28 09:54:58.063 - info: host.smarthome-VM instance system.adapter.zigbee.0 started with pid 14322
                                  2023-10-28 09:55:00.927 - info: zigbee.0 (14322) starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.20.2, js-controller: 5.0.12
                                  2023-10-28 09:55:01.017 - info: zigbee.0 (14322) delete old Backup files. keep only last 10
                                  2023-10-28 09:55:01.019 - info: zigbee.0 (14322) Starting Zigbee npm ...
                                  2023-10-28 09:55:01.209 - info: zigbee.0 (14322) Installed Version: ioBroker/ioBroker.zigbee
                                  2023-10-28 09:55:20.906 - error: zigbee.0 (14322) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                  2023-10-28 09:55:20.907 - error: zigbee.0 (14322) Failed to start Zigbee
                                  2023-10-28 09:55:20.907 - error: zigbee.0 (14322) Error herdsman start
                                  2023-10-28 09:55:30.911 - info: zigbee.0 (14322) Try to reconnect.
                                  2023-10-28 09:55:30.912 - info: zigbee.0 (14322) Starting Zigbee npm ...
                                  2023-10-28 09:55:30.924 - info: zigbee.0 (14322) Installed Version: ioBroker/ioBroker.zigbee
                                  2023-10-28 09:55:48.615 - info: admin.0 (6349) <== Disconnect system.user.admin from ::ffff:192.168.178.89
                                  2023-10-28 09:55:49.971 - error: zigbee.0 (14322) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                  2023-10-28 09:55:49.973 - error: zigbee.0 (14322) Failed to start Zigbee
                                  2023-10-28 09:55:49.974 - error: zigbee.0 (14322) Error herdsman start
                                  2023-10-28 09:55:59.976 - info: zigbee.0 (14322) Try to reconnect.
                                  2023-10-28 09:55:59.977 - info: zigbee.0 (14322) Starting Zigbee npm ...
                                  2023-10-28 09:55:59.992 - info: zigbee.0 (14322) Installed Version: ioBroker/ioBroker.zigbee
                                  2023-10-28 09:56:19.054 - error: zigbee.0 (14322) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                  2023-10-28 09:56:19.056 - error: zigbee.0 (14322) Failed to start Zigbee
                                  2023-10-28 09:56:19.056 - error: zigbee.0 (14322) Error herdsman start
                                  2023-10-28 09:56:29.061 - info: zigbee.0 (14322) Try to reconnect.
                                  2023-10-28 09:56:29.063 - info: zigbee.0 (14322) Starting Zigbee npm ...
                                  2023-10-28 09:56:29.073 - info: zigbee.0 (14322) Installed Version: ioBroker/ioBroker.zigbee
                                  2023-10-28 09:56:48.128 - error: zigbee.0 (14322) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                                  2023-10-28 09:56:48.131 - error: zigbee.0 (14322) Failed to start Zigbee
                                  2023-10-28 09:56:48.131 - error: zigbee.0 (14322) Error herdsman start
                                  2023-10-28 09:56:58.134 - info: zigbee.0 (14322) Try to reconnect.
                                  2023-10-28 09:56:58.134 - info: zigbee.0 (14322) Starting Zigbee npm ...
                                  2023-10-28 09:56:58.142 - info: zigbee.0 (14322) Installed Version: ioBroker/ioBroker.zigbee
                                  • S Snert
                                    Ralla66R Offline
                                    Ralla66R Offline
                                    Ralla66
                                    @snert
                                    langsam, was passiert nach cc.flash()
                                    habe da Time Out
                                    bei dir sollte stehen:
                                    21:47:07.140 FLH: Verification of HEX file OK
                                    21:49:06.780 FLH: cc2652_flasher rx=23 tx=19 rst=15 bsl=22
                                    21:49:06.828 FLH: Flashing started (takes 5 minutes during which Tasmota is unresponsive)
                                    21:54:43.835 FLH: Flashing completed: OK
                                    21:54:43.948 FLH: Flash crc32 0x000000 - 0x2FFFF = bytes('1598929A')
                                    • Ralla66R Ralla66
                                      @snert
                                      habe da Time Out
                                      Ralla66R Offline
                                      Ralla66R Offline
                                      Ralla66
                                      @ralla66
                                      lass mal Autoconfig , IO, TCP sein, gehe strikt nach Anleitung vor.
                                      Console meldet ja:
                                      Also wird das Device ja nicht von der Bridge gefunden.
                                      Ota flashen ist immer kritisch da Reste im Speicher verbleiben können.
                                      Besser ist flashen mit FTDI per Kabel und Erase des Speicher.
                                      Das Gerät wird wohl gefunden als
                                      schau mal ob die Addr vom ZB Device passt.
                                      • Ralla66R Ralla66
                                        @ralla66
                                        Console meldet ja:
                                        Snert
                                        @ralla66 Jetzt langsam verstehe ich es nicht mehr.
                                        Ich hatte zuletzt folgendes gemacht:
                                        • Auto-configuration auf "Sonoff ZBPro TCP" gestellt (Restart danach)
                                          Info am Rande, das Template steht auf:
                                        {"NAME":"TCP ZBBridge Pro","GPIO":[0,0,576,0,480,0,0,0,0,1,1,5792,0,0,0,5472,0,320,5793,5504,0,640,608,32,0,0,0,0,0,1,0,0,0,0,0,0],"FLAG":0,"BASE":1}
                                        • Tasmota wer per web installer (mit FTDI) auf development -> Tasmota32 Sonoff-ZigbeeBridgePro -> All, in der Version 13.2.0.1 geflashed worden.
                                        • Danach bin ich der Anleitung zum flashen der coordinater Firmware von hier https://notenoughtech.com/home-automation/tasmota-on-sonoff-zb-bridge-pro/#flash gefolgt. Dies wird auch von https://zigbee.blakadder.com/Sonoff_ZBBridge-P.html empfohlen. Allerdings habe ich nicht die SonoffZBPro_coord_20220219.hex Firmware, sondern die SonoffZBPro_coord_20230507.hex hochgeladen und verwendet.
                                        • Der Flashvorgang wurde auch in der Console mit ok bestätigt, jedoch habe ich zu diesem Zeitpunkt nie folgende Meldungen bekommen:
                                        • Der ZigBee-Adapter ist wie folgt konfiguriert:
                                        Dann musste ich mich eben um mein Kind kümmern und war weg vom PC. Ebenfalls musste ich den Bosch Smart Home Controller II kurzzeitig vom Strom nehmen. (Nur als Info, kp ob das was zu bedeuten hat?!)
                                        Als ich eben an den PC zurück bin, lief der Adapter und ich kann die ZigBee Geräte anlernen.
                                        WTF, ich verstehe die Welt nicht mehr.
                                        Falls noch weitere Infos benötigt werden, um evtl. meine Dummheit oder einen Fehler zu belegen, gerne Bescheid geben.
                                        EDIT:
                                        Ich habe eben mal kurz die Erweiterte Pan ID umstellen wollen, danach lief der Adapter nicht mehr. Mit 16x D ging er direkt wieder auf Grün.
                                        Ralla66R P 2 Antworten Letzte Antwort
                                        • S Snert
                                          EDIT:
                                          Ralla66R Offline
                                          Ralla66R Offline
                                          Ralla66
                                          @snert
                                          läuft, ist doch prima :-)
                                          möglich das bei Erst Installation ein Suchlauf der Geräte durchgeführt wird.
                                          Das kann ja 3 bis 5 Minten dauern.
                                          Bei Adaptern ist es meist so das erst ein Triggern diesen grün werden läßt.
                                          Sowas wie ZB Fenster auf / zu oder Reboot des Devices.
                                          Die 3 Statusmeldungen sagen ja nur aus das der Coordinator nach reboot aktiv ist und somit
                                          ist die Bridge richtig eingerichtet. Halt nicht ob der Cxxxx der richtige ist.
                                          Das steht ja in der coord.
                                          Na ja der Typ vor dem Bildschirm, meist Besserwissend und hält sich nicht an Vorlagen
                                          gepaart mit Unwissenheit beim Adapterstart.
                                          Geht mir aber auch so, um so länger versucht um so mehr verrannt.
                                          Was ist denn ->Mit 16x D ?
                                          Edit, stelle mal bitte ein Log File hier ein damit andere User sehen können welche
                                          Schritte beim booten in der Console angezeigt werden.
