  4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    1.0k
    6.1k
391 Beiträge 33 Kommentatoren 105.1k Aufrufe 33 Beobachtet
  • DJMarc75D DJMarc75
    @mephisto090 Konsolentexte nicht als Bild sondern kopieren und in Codetags hier einsetzen ;)
    Mephisto090
    schrieb am zuletzt editiert von Mephisto090
    #326
    @DJMarc75
    root@iobroker:/opt/iobroker# /usr/bin/speedtest --json
        "bytes_received": 111995656,
        "bytes_sent": 43466752,
        "client": {
            "country": "DE",
            "ip": "???????",
            "isp": "Vodafone Germany DSL",
            "ispdlavg": "0",
            "isprating": "3.7",
            "ispulavg": "0",
            "lat": "11.111",
            "loggedin": "0",
            "lon": "22.222",
            "rating": "0"
        "download": 89252315.3942659,
        "ping": 26.842,
        "server": {
            "cc": "DE",
            "country": "Germany",
            "d": 5.1528760454098,
            "host": "speedeu.akesacloud.co.za:8080",
            "id": "60714",
            "lat": "52.5167",
            "latency": 26.842,
            "lon": "13.3833",
            "name": "Berlin",
            "sponsor": "Akesa IT - Europe",
            "url": "http://speedeu.akesacloud.co.za:8080/speedtest/upload.php"
        "share": null,
        "timestamp": "2023-10-20T14:47:20.708905Z",
        "upload": 34704998.6338473
    root@iobroker:/opt/iobroker# /usr/bin/speedtest -h
    usage: speedtest [-h] [--no-download] [--no-upload] [--single] [--bytes] [--share] [--simple] [--csv] [--csv-delimiter CSV_DELIMITER] [--csv-header] [--json] [--list] [--server SERVER] [--exclude EXCLUDE] [--mini MINI]
                     [--source SOURCE] [--timeout TIMEOUT] [--secure] [--no-pre-allocate] [--version]
    Command line interface for testing internet bandwidth using speedtest.net. -------------------------------------------------------------------------- https://github.com/sivel/speedtest-cli
    options:
      -h, --help            show this help message and exit
      --no-download         Do not perform download test
      --no-upload           Do not perform upload test
      --single              Only use a single connection instead of multiple. This simulates a typical file transfer.
      --bytes               Display values in bytes instead of bits. Does not affect the image generated by --share, nor output from --json or --csv
      --share               Generate and provide a URL to the speedtest.net share results image, not displayed with --csv
      --simple              Suppress verbose output, only show basic information
      --csv                 Suppress verbose output, only show basic information in CSV format. Speeds listed in bit/s and not affected by --bytes
                            Single character delimiter to use in CSV output. Default ","
      --csv-header          Print CSV headers
      --json                Suppress verbose output, only show basic information in JSON format. Speeds listed in bit/s and not affected by --bytes
      --list                Display a list of speedtest.net servers sorted by distance
      --server SERVER       Specify a server ID to test against. Can be supplied multiple times
      --exclude EXCLUDE     Exclude a server from selection. Can be supplied multiple times
      --mini MINI           URL of the Speedtest Mini server
      --source SOURCE       Source IP address to bind to
      --timeout TIMEOUT     HTTP timeout in seconds. Default 10
      --secure              Use HTTPS instead of HTTP when communicating with speedtest.net operated servers
      --no-pre-allocate     Do not pre allocate upload data. Pre allocation is enabled by default to improve upload performance. To support systems with insufficient memory, use this option to avoid a MemoryError
      --version             Show the version number and exit
    --version: Python 3.11.2 (main, Mar 13 2023, 12:18:29) [GCC 12.2.0]
    • SKBS SKB
      @mephisto090 Dann wird es laufen :)
      Mephisto090
      #327
      @skb leider nicht
      16:49:14.239	info	javascript.0 (951689) Start javascript script.js.common.Speedtest
      16:49:14.243	info	javascript.0 (951689) script.js.common.Speedtest: Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!
      16:49:14.244	info	javascript.0 (951689) script.js.common.Speedtest: Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 30 Sekunden ausgeführt!
      16:49:14.246	info	javascript.0 (951689) script.js.common.Speedtest: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
      16:49:44.245	info	javascript.0 (951689) script.js.common.Speedtest: Speedtest mit Server 37316 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
      16:49:44.457	error	javascript.0 (951689) script.js.common.Speedtest: SyntaxError: Unexpected end of JSON input
      16:49:44.459	error	javascript.0 (951689) at generiere_array (script.js.common.Speedtest:182:18)
      16:49:44.459	error	javascript.0 (951689) at script.js.common.Speedtest:231:28
      16:49:44.570	error	host.iobroker Caught by controller[0]: at generiere_array (script.js.common.Speedtest:205:18)
      16:49:44.570	error	host.iobroker Caught by controller[0]: at script.js.common.Speedtest:254:28
      • SKBS SKB
        Mephisto090
        #328
        @skb habe jetzt auch mal das -s durch --server ersetzt
        17:01:04.619	info	javascript.0 (954175) Stop script script.js.common.Speedtest
        17:01:06.582	info	javascript.0 (954175) Start javascript script.js.common.Speedtest
        17:01:06.595	info	javascript.0 (954175) script.js.common.Speedtest: Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!
        17:01:06.597	info	javascript.0 (954175) script.js.common.Speedtest: Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 30 Sekunden ausgeführt!
        17:01:06.611	info	javascript.0 (954175) script.js.common.Speedtest: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
        17:01:36.598	info	javascript.0 (954175) script.js.common.Speedtest: Speedtest mit Server 37316 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
        17:01:36.935	error	javascript.0 (954175) script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest --json --server 37316 Cannot retrieve speedtest configuration ERROR: HTTP Error 403: Forbidden
        Jetzt kommt diese Meldung
        Edit: Habe jetzt den Server mit der ID rausgenommen und er führt auch den Speedtest aus. Leider passen wohl die Vars nicht mehr.
        17:07:56.335	error	javascript.0 (954175) script.js.common.Speedtest: TypeError: Cannot read properties of undefined (reading 'externalIp')
        SKBS 1 Antwort Letzte Antwort
        • M Mephisto090
          @DJMarc75
              "client": {
                  "country": "DE",
                  "ip": "???????",
                  "ispdlavg": "0",
                  "isprating": "3.7",
                  "ispulavg": "0",
                  "lat": "11.111",
                  "loggedin": "0",
                  "lon": "22.222",
                  "rating": "0"
              "ping": 26.842,
              "server": {
                  "cc": "DE",
                  "id": "60714",
                  "lat": "52.5167",
                  "latency": 26.842,
                  "lon": "13.3833",
                  "name": "Berlin",
              "share": null,
          options:
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          #329
          @mephisto090 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
          root@iobroker
          da brauchen wir nicht weitermachen ;)
          Leg Dir einen User mit Sudorechten an.
          Lehrling seit 1975 !!!
            root@iobroker
            Mephisto090
            #330
            @djmarc75 das ist docker ;) in diesem container läuft nur ein service und das ist iobroker. ich glaube da ist das egal ;) außerdem ist der nach außen hin nicht offen. ;)
            • M Mephisto090
              #331
              Das ist ja kein Grund. Angriffe können ja auch von innen heraus erfolgen. Durch heruntergeladenen Code. Und dieser Code läuft mit den Rechten des users. Bei root halt ganz schlecht.
              Aber bei Docker soll es ja auch irgendwelchen Gründen, die mir bis heute noch niemand plausibel darlegen konnte, angeblich nicht möglich sein eine ordentliche Rechteverwaltung zu haben.
              • M Mephisto090
                SKBS Offline
                SKBS Offline
                SKB
                #332
                @mephisto090 Die Variablen passen noch. Ich habe gerade die aktuelle Version des Speedtest (Speedtest by Ookla 1.2.0.84) installiert.
                Hier werden wie erwartet alle Daten gefüllt.
                  Mephisto090
                  #333
                  @skb So habe mein Fehler gefunden. Irgendwie war das falsche speedtest-cli installiert. Es funktioniert jetzt und habe mal etwas das Skript angepasst. (Gerne kannst du es auf deiner Seite aktualisieren) Ich habe ein Trigger DP als Button hinzugefügt und das Skript den Button auswerten lassen. Des Weiteren ist Max. und Min. Ping dazugekommen sowie Paket Lost für Down- und Upload. Ich habe das Skript noch mit einer der letzten Statusmeldung ergänzt.
                   * @copyright 2020 Stephan Kreyenborg <stephan@kreyenborg.koeln>
                   * @author 2020 Stephan Kreyenborg <stephan@kreyenborg.koeln>
                   * Dieses Skript dient zur freien Verwendung in ioBroker zur Überprüfung Deiner Internetgeschwindkeit mit Hilfe von Speedtest.
                   * Jegliche Verantwortung liegt beim Benutzer. Das Skript wurde unter Berücksichtigung der bestmöglichen Nutzung
                   * und Performance entwickelt.
                   * Der Entwickler versichert, das keine böswilligen Systemeingriffe im originalen Skript vorhanden sind.
                   * Sollte das Skript wider Erwarten nicht korrekt funktionieren, so hast Du jederzeit die Möglichkeit, Dich auf
                   * https://www.kreyenborg.koeln
                   * für Unterstützung zu melden. Jedes Skript besitzt seine eigene Kommentarseite, auf der,
                   * nach zeitlicher Möglichkeit des Autors, Hilfe angeboten wird. Ein Anrecht hierauf besteht nicht!
                   * Ansprüche gegenüber Dritten bestehen nicht.
                   * Skript Name:        Speedtest
                   * Skript Version:    1.3
                   * Erstell-Datum:    29. November 2021
                  // Datenpunkte neu erstellen
                  var ueberschreiben = false;
                  // Hauptdatenpunkt unterhalb javascript
                  var datenpunkt = "Speedtest.";
                  // Favorisierter Server
                  // Liste: https://www.speedtest.net/speedtest-servers.php
                  var fav_server = 0;
                  // Speedtest Objekte
                  var objekt = ["JSON_Output",
                      "Ergebnisse.PaketLost_Download",
                      "Ergebnisse.PaketLost_Upload",
                      "Ergebnisse.Ping",
                      "Ergebnisse.Ping_Min",
                      "Ergebnisse.Ping_Max",
                      "Ergebnisse.Jitter",
                      "Ergebnisse.Download_MBit",
                      "Ergebnisse.Upload_MBit",
                      "Ergebnisse.Download_MB",
                      "Ergebnisse.Upload_MB",
                      "Ergebnisse.OriginalDownload",
                      "Ergebnisse.OriginalUpload",
                      "ISP",
                      "IP",
                      "Ergebnisse.URL",
                      "Ergebnisse.ID",
                      "Test.Server.ServerID",
                      "Test.Server.ServerIP",
                      "Test.Server.Name",
                      "Test.Server.Stadt",
                      "Test.Server.Land",
                      "Test.Server.Adresse",
                      "Test.Daten.Download",
                      "Test.Daten.Upload",
                      "Test.Daten.OriginalDownload",
                      "Test.Daten.OriginalUpload",
                      "Test.Daten.DauerDownload",
                      "Test.Daten.DauerUpload",
                      "Test.Daten.Letzter_Speedtest",
                      "Trigger",
                      "Status"
                  // Beschreibung der Objekte
                  var beschreibung = ["JSON Ausgabe der Konsole",
                      "Paketverlust in %",
                      "Ping in ms",
                      "Min. Ping in ms",
                      "Max. Ping in ms",
                      "Jitter in ms",
                      "Download Geschwindigkeit in MBit/s",
                      "Upload Geschwindigkeit in MBit/s",
                      "Download Geschwindigkeit in MB/s",
                      "Upload Geschwindigkeit in MB/s",
                      "Download Geschwindigkeit in Byte/s",
                      "Upload Geschwindigkeit in Byte/s",
                      "Internet Service Provider",
                      "externe IP",
                      "Adresse der Ergebnisse",
                      "ID der Ergebnisse",
                      "ID des getesteten Servers",
                      "IP des getesteten Servers",
                      "Anbieter des getesteten Servers",
                      "Stadt des getesteten Servers",
                      "Land des getesteten Servers",
                      "URL des getesteten Servers",
                      "Download Daten in MB",
                      "Upload Daten in MB",
                      "Download Daten in Byte",
                      "Upload Daten in Byte",
                      "Dauer des Download Test",
                      "Dauer des Upload Test",
                      "Letzter Speedtest",
                      "Startet den Speedtest",
                      "Status vom letzten Speedtest"
                  // Einheiten der Objekte
                  var einheiten = ["",
                      "ms",
                      "ms",
                      "ms",
                      "ms",
                      "MBit/s",
                      "MBit/s",
                      "MB/s",
                      "MB/s",
                      "Byte/s",
                      "Byte/s",
                      "MB",
                      "MB",
                      "Byte",
                      "Byte",
                      "s",
                      "s",
                  // Typen der Objekte
                  var typen = ["string",
                      "number",
                      "number",
                      "number",
                      "number",
                      "number",
                      "number",
                      "number",
                      "number",
                      "number",
                      "number",
                      "number",
                      "number",
                      "string",
                      "string",
                      "string",
                      "string",
                      "number",
                      "string",
                      "string",
                      "string",
                      "string",
                      "string",
                      "number",
                      "number",
                      "number",
                      "number",
                      "number",
                      "number",
                      "string",
                      "boolean",
                      "string"
                  // Rollen der Objekte
                  var rolle = ["json",
                      "value",
                      "value",
                      "value",
                      "value",
                      "value",
                      "value",
                      "value",
                      "value",
                      "value",
                      "value",
                      "value",
                      "value",
                      "text",
                      "text",
                      "text",
                      "text",
                      "value",
                      "text",
                      "text",
                      "text",
                      "text",
                      "text",
                      "value",
                      "value",
                      "value",
                      "value",
                      "value",
                      "value",
                      "text",
                      "button",
                      "text"
                  // Schreibe Werte des JSON String in ein Array
                  function generiere_array(json_array) {
                      var j = JSON.parse(json_array);
                      var array_werte = [json_array,
                          parseFloat((j.download.elapsed * 100 / j.download.bytes).toFixed(2)),
                          parseFloat((j.upload.elapsed * 100 / j.upload.bytes).toFixed(2)),
                          j.ping.latency,
                          j.ping.low,
                          j.ping.high,
                          j.ping.jitter,
                          parseFloat((j.download.bandwidth / 125000).toFixed(2)),
                          parseFloat((j.upload.bandwidth / 125000).toFixed(2)),
                          parseFloat((j.download.bandwidth / (1024 * 1024)).toFixed(2)),
                          parseFloat((j.upload.bandwidth / (1024 * 1024)).toFixed(2)),
                          j.download.bandwidth,
                          j.upload.bandwidth,
                          j.isp,
                          j.interface.externalIp,
                          j.result.url,
                          j.result.id,
                          j.server.id,
                          j.server.ip,
                          j.server.name,
                          j.server.location,
                          j.server.country,
                          j.server.host,
                          parseFloat((j.download.bytes / (1024 * 1024)).toFixed(2)),
                          parseFloat((j.upload.bytes / (1024 * 1024)).toFixed(2)),
                          j.download.bytes,
                          j.upload.bytes,
                          parseFloat((j.download.elapsed / 1000).toFixed(2)),
                          parseFloat((j.upload.elapsed / 1000).toFixed(2)),
                          hole_datum(),
                          false,
                          "Speedtest wird durchgeführt"
                      return array_werte;
                  function speedtest() {
                      // temporäre Variable für das Array
                      var tmp_json;
                      // Kommando für den Speedtest
                      setStatus("Speedtest wird durchgeführt");
                      var kommando = "/usr/bin/speedtest -f json --accept-license --accept-gdpr";
                      if (fav_server > 0) {
                          kommando = kommando + " -s " + fav_server;
                          log("Speedtest mit Server " + fav_server + " gestartet! Der Test dauert zwischen 10 - 20 Sekunden!");
                      } else {
                          log("Speedtest gestartet! Der Test dauert zwischen 10 - 20 Sekunden!");
                      exec(kommando,
                          function (error, stdout) {
                              if (error) {
                                  log('Speedtest konnte nicht ausgeführt werden! ' + error, 'error');
                                  setState(datenpunkt + "Status", "Fehler", true);
                                  setStatus("Speedtest fehlerhaft");
                                  return;
                              } else {
                                  tmp_json = generiere_array(stdout);
                                  aktualisiere_datenpunkt(tmp_json);
                                  setStatus("Speedtest erfolgreich durchgeführt");
                                  log('Speedtest durchgeführt. Ergebnisse: Download: ' + tmp_json[7] + ' MBits/s | Upload: ' + tmp_json[8] + ' MBits/s | Ping: ' + tmp_json[3] + 'ms');
                  function setStatus(text) {
                      setState(datenpunkt + "Status", text, true);
                  function aktualisiere_datenpunkt(werte) {
                      for (let i = 0; i < objekt.length; i++) {
                          setState(datenpunkt + objekt[i], werte[i], true);
                  // Erstelle die benötigten Datenpunkte
                  function datenpunkte_erstellen() {
                      for (var i = 0; i < objekt.length; i++) {
                          createState(datenpunkt + objekt[i], "", ueberschreiben, {
                              desc: beschreibung[i],
                              type: typen[i],
                              role: rolle[i],
                              unit: einheiten[i]
                          setStatus("Datenpunkte erfolgreich erstellt");
                      // Alle Datenpunkte erstellt. Führe ersten Speedtest aus!
                      log('Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 30 Sekunden ausgeführt!');
                      setTimeout(speedtest, 30000);
                  // Datum
                  function hole_datum() {
                      let datum = new Date();
                      let tag = '0' + datum.getDate();
                      let monat = '0' + (datum.getMonth() + 1);
                      let jahr = datum.getFullYear();
                      let stunde = '0' + datum.getHours();
                      let minute = '0' + datum.getMinutes();
                      let sekunde = '0' + datum.getSeconds();
                      return tag.substr(-2) + '.' + monat.substr(-2) + '.' + jahr + ' ' + stunde.substr(-2) + ':' + minute.substr(-2) + ':' + sekunde.substr(-2);
                  function speedtest_erster_start() {
                      log("Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!");
                      // Datenpunkte werden erstellt
                      datenpunkte_erstellen();
                  // Erster Start und Initialisierung
                  speedtest_erster_start();
                  // Alle 60 Minuten einen Speedtest ausführen
                  schedule('0,30 * * * *', speedtest);
                  // Script ausführen wenn Datenpunkt "Speedtest-Trigger" = true
                  on({ id: "javascript.0.Speedtest.Trigger", change: "any" }, function (obj) {
                      if (obj.state.val===true) {
                          speedtest ();
                  P 1 Antwort Letzte Antwort
                  • M Mephisto090
                    var fav_server = 0;
                        "Ergebnisse.Ping",
                        "ISP",
                        "IP",
                        "Ergebnisse.URL",
                        "Ergebnisse.ID",
                        "Test.Server.Name",
                        "Test.Server.Land",
                        "Trigger",
                        "Status"
                        "Ping in ms",
                        "Min. Ping in ms",
                        "Max. Ping in ms",
                        "Jitter in ms",
                        "externe IP",
                        "ms",
                        "ms",
                        "ms",
                        "ms",
                        "MBit/s",
                        "MBit/s",
                        "MB/s",
                        "MB/s",
                        "Byte/s",
                        "Byte/s",
                        "MB",
                        "MB",
                        "Byte",
                        "Byte",
                        "s",
                        "s",
                        "number",
                        "number",
                        "number",
                        "number",
                        "number",
                        "number",
                        "number",
                        "number",
                        "number",
                        "number",
                        "number",
                        "number",
                        "string",
                        "string",
                        "string",
                        "string",
                        "number",
                        "string",
                        "string",
                        "string",
                        "string",
                        "string",
                        "number",
                        "number",
                        "number",
                        "number",
                        "number",
                        "number",
                        "string",
                        "boolean",
                        "string"
                        "value",
                        "value",
                        "value",
                        "value",
                        "value",
                        "value",
                        "value",
                        "value",
                        "value",
                        "value",
                        "value",
                        "value",
                        "text",
                        "text",
                        "text",
                        "text",
                        "value",
                        "text",
                        "text",
                        "text",
                        "text",
                        "text",
                        "value",
                        "value",
                        "value",
                        "value",
                        "value",
                        "value",
                        "text",
                        "button",
                        "text"
                            j.ping.latency,
                            j.ping.low,
                            j.ping.high,
                            j.ping.jitter,
                            j.upload.bandwidth,
                            j.isp,
                            j.result.url,
                            j.result.id,
                            j.server.id,
                            j.server.ip,
                            j.server.name,
                            j.server.location,
                            j.server.country,
                            j.server.host,
                            j.download.bytes,
                            j.upload.bytes,
                            hole_datum(),
                            false,
                        return array_werte;
                        var tmp_json;
                        } else {
                        exec(kommando,
                                if (error) {
                                    return;
                                } else {
                                type: typen[i],
                                role: rolle[i],
                                unit: einheiten[i]
                    // Datum
                            speedtest ();
                    PatrickFro
                    #334
                    Moin,
                    bei mir funktioniert das Script aus welchem Grunde auch immer nicht - bin leider sonst kein Linux-Nutzer-
                    Anzeige im Javascript-Adapter:
                    error	javascript.1 (10238) script.js.common.VIS_2024.Scripte_andere_Seiten.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest -f json --accept-license --accept-gdpr /bin/sh: 1: /usr/bin/speedtest: not found
                    /etc/speedtest# type -p speedtest
                    /usr/bin/speedtest
                    Gebe ich in der Konsole
                    /usr/bin/speedtest -f json --accept-license --accept-gdpr -s 28602
                    ein, funktioniert der Speedtest.
                    Ich nutze Debian-Linux Bookworm und habe die automatische Installation genutzt:
                    sudo apt-get install curl
                    curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
                    sudo apt-get install speedtest```
                    • P PatrickFro
                      Moin,
                      /usr/bin/speedtest
                      #335
                      @patrickfro
                      sudo apt update
                      apt policy speedtest*
                      sagt?
                      • P Offline
                        PatrickFro
                        #336
                        @thomas-braun said in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                        Folgendes:
                        root@VM-IoBroker:/etc/speedtest# sudo apt update
                        OK:1 http://security.debian.org/debian-security bookworm-security InRelease
                        OK:2 http://deb.debian.org/debian bookworm InRelease
                        OK:3 http://deb.debian.org/debian bookworm-updates InRelease
                        OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                        OK:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                        Alle Pakete sind aktuell.
                        root@VM-IoBroker:/etc/speedtest# apt policy speedtest*
                        speedtest:
                          Installiert:           1.2.0.84-1.ea6b6773cf
                          Installationskandidat: 1.2.0.84-1.ea6b6773cf
                          Versionstabelle:
                         *** 1.2.0.84-1.ea6b6773cf 500
                                500 https://packagecloud.io/ookla/speedtest-cli/debian bookworm/main amd64 Packages
                        speedtest-cli:
                          Installiert:           (keine)
                          Installationskandidat: 2.1.3-2
                          Versionstabelle:
                             2.1.3-2 500
                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                        • P PatrickFro
                          Folgendes:
                          speedtest:
                            Versionstabelle:
                          speedtest-cli:
                            Versionstabelle:
                               2.1.3-2 500
                          #337
                          @patrickfro sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                          root@
                          KEIN root-Login!
                          Meld dich als user an, verdammte Hacke...
                            root@
                            KEIN root-Login!
                            PatrickFro
                            #338
                            @thomas-braun Schande über mein Haupt. Ist ne neue Installation und der normale User hat noch keine sudo-Rechte. Daher der Weg. Aber nun wirds klar, root hat wohl kein usr-Verzeichnis.
                            • P PatrickFro
                              #339
                              Und das ist das erste und letzte, was man als root in einem neuen System tut. Bzw. man installiert sein Debian gleich von vorneherein OHNE root-Passwort.
                              usr steht NICHT für user, wenn du das vermuten solltest sondern für UnixSystemRessources. Du meinst vermultich home-Verzeichnisse. Das vom root findet sich unter /root
                                PatrickFro
                                schrieb am zuletzt editiert von PatrickFro
                                #340
                                ich habe es nun als root deinstalliert
                                sudo apt-get update
                                sudo apt-get remove speedtest
                                meinem normalen user sudo gegeben, mich als normaler user angemeldet, neu installiert, selber Fehler wie oben.
                                patrick@VM-IoBroker:~$ sudo apt update
                                patrick@VM-IoBroker:~$ apt policy speedtest*
                                speedtest:
                                  Versionstabelle:
                                        500 https://packagecloud.io/ookla/speedtest-cli/debian bookworm/main amd        64 Packages
                                speedtest-cli:
                                  Versionstabelle:
                                     2.1.3-2 500
                                Ich sehe in diesem Ergebnis leider auch keine Änderung. Du hast doch sicherlich noch eine Idee, oder?
                                • P PatrickFro
                                  sudo apt-get update
                                  speedtest:
                                    Versionstabelle:
                                  speedtest-cli:
                                    Versionstabelle:
                                       2.1.3-2 500
                                  #341
                                  @patrickfro
                                  sudo -u iobroker speedtest -f json --accept-license --accept-gdpr
                                    @patrickfro
                                    PatrickFro
                                    #342
                                    patrick@VM-IoBroker:~$ sudo -u iobroker speedtest -f json --accept-license --accept-gdpr
                                    {"type":"result","timestamp":"2023-10-22T17:35:33Z","ping":{"jitter":0.318,"latency":1.630,"low":1.274,"high":1.954},"download":{"bandwidth":10028954,"bytes":55169840,"elapsed":5603,"latency":{"iqm":1.419,"low":0.692,"high":207.800,"jitter":18.722}},"upload":{"bandwidth":4651107,"bytes":16764520,"elapsed":3608,"latency":{"iqm":119.987,"low":0.858,"high":317.042,"jitter":40.296}},"packetLoss":0,"isp":"wilhelm.tel","interface":{"internalIp":"...7d8f:6950","name":"ens18","macAddr":"...AE","isVpn":false,"externalIp":"...4950"},"server":{"id":4087,"host":"speedtest.wtnet.de","port":8080,"name":"wilhelm.tel","location":"Norderstedt","country":"Germany","ip":"...3:2"},"result":{"id":"fea91c99-07ee-4ff1-ae4d-8cd14483123","url":"https://www.speedtest.net/result/c/fea91c99-07ee-4ff1-ae4d-8cd144333823","persisted":true}}
                                    • P PatrickFro
                                      #343
                                      @patrickfro
                                      Hast du das Skript vollständig und richtig kopiert?
                                        @patrickfro
                                        PatrickFro
                                        #344
                                        Eigentlich schon
                                        patrick@VM-IoBroker:~$ sudo apt-get install curl
                                        [sudo] Passwort für patrick:
                                        curl ist schon die neueste Version (7.88.1-10+deb12u4).
                                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                        patrick@VM-IoBroker:~$ curl -s https://packagecloud.io/install/repositories/ookl        a/speedtest-cli/script.deb.sh | sudo bash
                                        Detected operating system as debian/bookworm.
                                        Checking for curl...
                                        Detected curl...
                                        Checking for gpg...
                                        Detected gpg...
                                        Detected apt version as 2.6.1
                                        Running apt-get update... done.
                                        Installing debian-archive-keyring which is needed for installing
                                        apt-transport-https on many Debian systems.
                                        Installing apt-transport-https... done.
                                        Installing /etc/apt/sources.list.d/ookla_speedtest-cli.list...done.
                                        Importing packagecloud gpg key... Packagecloud gpg key imported to /etc/apt/keyr        ings/ookla_speedtest-cli-archive-keyring.gpg
                                        done.
                                        The repository is setup! You can now install packages.
                                        patrick@VM-IoBroker:~$ sudo apt-get install speedtest
                                        Die folgenden NEUEN Pakete werden installiert:
                                          speedtest
                                        0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                        Es müssen noch 0 B von 1.106 kB an Archiven heruntergeladen werden.
                                        Nach dieser Operation werden 2.628 kB Plattenplatz zusätzlich benutzt.
                                        Vormals nicht ausgewähltes Paket speedtest wird gewählt.
                                        (Lese Datenbank ... 167253 Dateien und Verzeichnisse sind derzeit installiert.)
                                        Vorbereitung zum Entpacken von .../speedtest_1.2.0.84-1.ea6b6773cf_amd64.deb ...
                                        Entpacken von speedtest (1.2.0.84-1.ea6b6773cf) ...
                                        speedtest (1.2.0.84-1.ea6b6773cf) wird eingerichtet ...
                                        Trigger für man-db (2.11.2-2) werden verarbeitet ...
                                        Da ich kein Raspberry hab, konnte ich nicht das komplette Script von Kreyenborg nutzen, sondern musste auf https://www.speedtest.net/de/apps/cli ausweichen.
                                        • P PatrickFro
                                          Eigentlich schon
                                          Detected curl...
                                          Checking for gpg...
                                          Detected gpg...
                                          done.
                                            speedtest
                                          #345
                                          Heh? Versteh ich nicht.
                                          Hast du das Skript kopiert, im javaskript-Adapter als Java-Skript angelegt und die erforderlichen Änderungen getätigt?
