  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.8k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 736.3k Aufrufe 117 Beobachtet
  • T TT-Tom
    @lucky_esa
    Was kommt den bei euch im Log wenn der Adapter neu gestartet wird bzw. auch mal auf debug stellen.
    sieht bei mir so aus
    2023-10-18 18:07:51.990 - debug: parcel.0 (1107844) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-10-18 18:07:52.059 - debug: parcel.0 (1107844) Objects client ready ... initialize now
    2023-10-18 18:07:52.063 - debug: parcel.0 (1107844) Objects create System PubSub Client
    2023-10-18 18:07:52.066 - debug: parcel.0 (1107844) Objects create User PubSub Client
    2023-10-18 18:07:52.166 - debug: parcel.0 (1107844) Objects client initialize lua scripts
    2023-10-18 18:07:52.175 - debug: parcel.0 (1107844) Objects connected to redis: 127.0.0.1:9001
    2023-10-18 18:07:52.242 - debug: parcel.0 (1107844) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-10-18 18:07:52.271 - debug: parcel.0 (1107844) States create System PubSub Client
    2023-10-18 18:07:52.272 - debug: parcel.0 (1107844) States create User PubSub Client
    2023-10-18 18:07:52.369 - debug: parcel.0 (1107844) States connected to redis: 127.0.0.1:9000
    2023-10-18 18:07:52.644 - debug: parcel.0 (1107844) Plugin sentry Initialize Plugin (enabled=true)
    2023-10-18 18:07:54.191 - info: parcel.0 (1107844) starting. Version 0.0.27 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.18.2, js-controller: 5.0.12
    2023-10-18 18:07:54.306 - info: parcel.0 (1107844) Login to DHL
    2023-10-18 18:07:55.502 - debug: parcel.0 (1107844) Please close this window to continue.
    2023-10-18 18:07:55.613 - debug: parcel.0 (1107844) (janrain.capture.ui.handleCaptureResponse)({"stat":"ok","result":{"transactionId":"IXj9Mw6dKo2roM1Rg........
    2023-10-18 18:07:57.001 - info: parcel.0 (1107844) Login to DHL successful
    2023-10-18 18:09:08.946 - error: parcel.0 (1107844) Error: read ETIMEDOUT
    2023-10-18 18:09:08.949 - debug: parcel.0 (1107844) https://www.dhl.de/int-verfolgen/data/search?piececode=&noRedirect=true&language=de&cid=app
    2023-10-18 18:09:09.863 - debug: parcel.0 (1107844) {"sendungen":[{"id":"00340434.........
    2023-10-18 18:09:09.905 - debug: parcel.0 (1107844) deleting parcel.0.dhl.sendungen01.id
    2023-10-18 18:09:11.189 - debug: parcel.0 (1107844) deleting parcel.0.dhl.sendungen02.id
    2023-10-18 18:09:12.038 - debug: parcel.0 (1107844) deleting parcel.0.dhl.sendungen03.id
    2023-10-18 18:09:13.104 - debug: parcel.0 (1107844) dhl merge provider json
    2023-10-18 18:09:13.107 - debug: parcel.0 (1107844) https://www.dhl.de/int-aviseanzeigen/advices?width=414
    2023-10-18 18:09:13.587 - debug: parcel.0 (1107844) {"currentAdvice":null,"oldAdvices":[{"date":"16.10.2023","advices":[{"image_url":"https://briefankuendigung.dhl.de/pdapp-web/image/v1.0/.......
    2023-10-18 18:09:13.904 - debug: parcel.0 (1107844) ""
    2023-10-18 18:09:15.900 - debug: parcel.0 (1107844) dhl merge provider json
    2023-10-18 18:09:15.901 - debug: parcel.0 (1107844) Write states
    Die Daten kommen trotzdem an und werden auch eingelesen. Es gibt nur regelmäßig die Error Meldung "error: parcel.0 (1107844) Error: read ETIMEDOUT"
    tombox
    #1152
    @tt-tom Bitte mal die aktuelle version via beta channel verwenden.
    Kommt der Fehler bei jeder Aktualisierung
    Thomas BraunT T 2 Antworten Letzte Antwort
    • T tombox
      #1153
      @tombox
      Hier weiterhin mit iobroker.parcel@0.1.5:
      2023-10-18 18:06:29.468  - error: parcel.0 (18793) Failed to get https://www.dhl.de/int-verfolgen/data/search?noRedirect=true&language=de&cid=app
      2023-10-18 18:06:29.469  - error: parcel.0 (18793) Error: read ETIMEDOUT
      2023-10-18 18:06:32.634  - info: parcel.0 (18793) Login to Amazon successful
      2023-10-18 18:31:30.653  - error: parcel.0 (18793) Failed to get https://www.dhl.de/int-verfolgen/data/search?noRedirect=true&language=de&cid=app
      2023-10-18 18:31:30.654  - error: parcel.0 (18793) Error: read ETIMEDOUT
      2023-10-18 18:31:33.933  - info: parcel.0 (18793) Login to Amazon successful
      L 1 Antwort Letzte Antwort
        @tombox
        LibertyX82
        #1154
        DHL hat seit ca 1 Woche Probleme mit Ihrer Paketverfolgung, selbst auf der Webseite wird sporadisch kein Status angezeigt.
        Der Fehler tritt immer mal wieder auf und verschwindet auch wieder.
        • T tombox
          TT-Tom
          #1155
          @tombox
          parcel.0
          2023-10-18 18:57:31.134	info	starting. Version 0.1.5 (non-npm: TA2k/ioBroker.parcel) in /opt/iobroker/node_modules/iobroker.parcel, node: v18.18.2, js-controller: 5.0.12
          parcel.0
          2023-10-18 18:57:31.238	info	Login to DHL
          parcel.0
          2023-10-18 18:57:34.456	info	Login to DHL successful
          parcel.0
          2023-10-18 18:58:46.738	error	Failed to get https://www.dhl.de/int-verfolgen/data/search?noRedirect=true&language=de&cid=app
          parcel.0
          2023-10-18 18:58:46.741	error	Error: read ETIMEDOUT
          parcel.0
          2023-10-18 19:10:00.529	error	Failed to get https://www.dhl.de/int-verfolgen/data/search?noRedirect=true&language=de&cid=app
          parcel.0
          2023-10-18 19:10:00.529	error	Error: read ETIMEDOUT
          Gruß Tom
          Public Transport
          NSPanel Adapter Wiki
          • T TT-Tom
            @tombox
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            parcel.0
            tombox
            #1156
            @tt-tom Ist die frage ob es alle 10min auftritt
            T L 2 Antworten Letzte Antwort
            • T tombox
              TT-Tom
              #1157
              @tombox
              ich lass mal 1h laufen und melde mich dann nochmal
              Gruß Tom
              Public Transport
              • T tombox
                LibertyX82
                #1158
                @tombox
                Das tritt in dem Intervall auf, der als Update Intervall im Adapter eingestellt ist, da er bei jeder Abfrage auftritt.
                • L Online
                  L Online
                  Lucky_ESA
                  #1159
                  So sieht es jetzt mit der 0.1.5 aus.
                  parcel.0	2023-10-18 19:27:50.123	error	Error: read ETIMEDOUT
                  parcel.0	2023-10-18 19:27:50.122	error	Failed to get https://www.dhl.de/int-verfolgen/data/search?noRedirect=true&language=de&cid=app
                  parcel.0	2023-10-18 19:26:38.978	info	Login to Hermes successful
                  parcel.0	2023-10-18 19:26:38.543	info	Login to Hermes
                  parcel.0	2023-10-18 19:26:38.543	info	{"Fault":{"faultcode":"Client","faultstring":"An exception has been raised as a result of client data.","detail":{"Errors":{"ErrorDetail":{"Severity":"Authentication","PrimaryErrorCode":{"Code":"250003","Description":"Invalid Access License number"},"Location":{"LocationElementName":"p2:AccessLicenseNumber"}}}}}}
                  parcel.0	2023-10-18 19:26:38.541	warn	Login to UPS failed
                  parcel.0	2023-10-18 19:26:38.232	info	Login to UPS
                  parcel.0	2023-10-18 19:26:38.223	info	Login to GLS successful
                  parcel.0	2023-10-18 19:26:37.732	info	Login to GLS
                  parcel.0	2023-10-18 19:26:37.729	info	Login to Amazon successful
                  parcel.0	2023-10-18 19:26:35.641	info	Login to Amazon
                  parcel.0	2023-10-18 19:26:35.632	info	Login to T17 User successful
                  parcel.0	2023-10-18 19:26:35.020	info	Login to T17 User
                  parcel.0	2023-10-18 19:26:34.502	info	Login to DPD successful
                  parcel.0	2023-10-18 19:26:32.142	info	Login to DPD
                  parcel.0	2023-10-18 19:26:32.015	info	Login to DHL successful
                  parcel.0	2023-10-18 19:26:29.155	info	Login to DHL
                  parcel.0	2023-10-18 19:26:29.024	info	starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.18.0, js-controller: 5.0.14
                  Gruß//Lucky
                    TT-Tom
                    #1160
                    @tombox
                    Ja, es kommt im 10 Minuten Takt.
                    Gruß Tom
                    Public Transport
                    • T TT-Tom
                      @tombox
                      tombox
                      #1161
                      @tt-tom bitte mal 0.1.6 testen
                      O Chris76eC Thomas BraunT T haselchenH 5 Antworten Letzte Antwort
                      • T tombox
                        O Offline
                        O Offline
                        oFbEQnpoLKKl6mbY5e13
                        #1162
                        Kein Fehler mehr mit 0.1.6.
                        • T tombox
                          Chris76eC Offline
                          Chris76eC Offline
                          Chris76e
                          #1163
                          @tombox
                          bis jetzt keine Fehler mehr bei DHL mit der 0.1.6
                          • T tombox
                            #1164
                            @tombox
                            Hier ist mit der 0.1.6 auch Ruhe im Log eingekehrt.
                            TTBerlinT 1 Antwort Letzte Antwort
                            • T tombox
                              TT-Tom
                              #1165
                              @tombox
                              Bei mir auch alles okay, danke.
                              Gruß Tom
                              Public Transport
                              OmnedonO 1 Antwort Letzte Antwort
                              • T TT-Tom
                                @tombox
                                OmnedonO Offline
                                OmnedonO Offline
                                Omnedon
                                #1166
                                @tombox
                                Bei mir geht es ebenfalls. Keine Fehler im Log.
                                Vielen Dank!
                                  @tombox
                                  TTBerlinT Offline
                                  TTBerlinT Offline
                                  TTBerlin
                                  #1167
                                  @thomas-braun kann ich nur bestätigen. Alles ruhig mit 0.1.6. Sehr schön, vielen Dank!
                                  iobroker unter Debian Trixiea uf Dell Optiplex 9020 micro
                                  Node.js v22.19.0
                                  NPM 10.9.3
                                  js-controller 7.07
                                  JavaScript 8.9.2
                                  Admin 7.7.2
                                  • T tombox
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    #1168
                                    @tombox
                                    Bekomme immer noch (wahllos) eine Meldung
                                    parcel.0	2023-10-19 14:28:05.205	info	Login to Amazon successful
                                    Ob Info oder Warn oder Error, es ist halt eine Meldung, wo ich nicht weiss, warum die erscheint.
                                    Den Adapter habe ich vor Stunden auf 0.1.6 upgedatet und alle Login liefen durch.
                                    Jetzt kommt aufmal diese Info....
                                    Edit:
                                    gerade gesehen, dass passierte öfters in den letzten Stunden
                                    parcel.0
                                    parcel.0
                                    	2023-10-19 14:01:04.711	info	Login to Amazon successful
                                    parcel.0
                                    	2023-10-19 13:34:04.443	info	Login to Amazon successful
                                    parcel.0
                                    	2023-10-19 13:07:08.256	info	Login to Amazon successful
                                    • haselchenH haselchen
                                      @tombox
                                      Edit:
                                      parcel.0
                                      parcel.0
                                      parcel.0
                                      parcel.0
                                      #1169
                                      @haselchen sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                      Die kommt schon ewig. Halt bei jedem Login bei Amazon. Ich hab das LogLevel auf Warn gesetzt.
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        #1170
                                        Ich logge mich aber nicht alle 30min bei Amazon ein.
                                        Muss ja nen Grund geben, warum diese Meldung ausgelöst wird.
                                        Mit Warn wegsehen ist nicht die Lösung ;)
                                          #1171
                                          @haselchen
                                          Du nicht. Aber der Adapter!
