  4. Node-Red
  5. Schrittwerk mit einer Bedingung begrenzen
    6.4k
22 Beiträge 2 Kommentatoren 2.2k Aufrufe 2 Beobachtet
  • mickymM mickym
    @hawell Schau mal, ob das tut was Du brauchst:
           "id": "4bbe3cb139220b42",
           "type": "switch",
           "z": "fbeffc2c8bcc1d00",
           "name": "",
           "property": "payload",
           "propertyType": "msg",
           "rules": [
                   "t": "gte",
                   "v": "2",
                   "vt": "num"
                   "t": "btwn",
                   "v": "-699",
                   "vt": "num",
                   "v2": "1",
                   "v2t": "num"
                   "t": "lt",
                   "v": "-700",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 3,
           "x": 330,
           "y": 400,
           "wires": [
                   "034c5314770775c6"
                   "b554f04062367f31"
                   "07f087d511c8b3e2"
           "id": "034c5314770775c6",
           "type": "change",
           "name": "-1",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "-1",
                   "tot": "num"
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "action",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 490,
           "y": 340,
           "wires": [
                   "95c9633ab4777657"
           "id": "07f087d511c8b3e2",
           "type": "change",
           "name": "+1",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "1",
                   "tot": "num"
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "action",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 490,
           "y": 460,
           "wires": [
                   "95c9633ab4777657"
           "id": "458ecde97817f777",
           "type": "inject",
           "name": "100",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "100",
           "payloadType": "num",
           "x": 110,
           "y": 360,
           "wires": [
                   "4bbe3cb139220b42"
           "id": "9a176b2bfce3c5bc",
           "type": "inject",
           "name": "-500",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "-500",
           "x": 110,
           "y": 420,
           "wires": [
                   "4bbe3cb139220b42"
           "id": "dbb92ef2ecce8bdb",
           "type": "inject",
           "name": "-2000",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "-2000",
           "x": 110,
           "y": 480,
           "wires": [
                   "4bbe3cb139220b42"
           "id": "b554f04062367f31",
           "type": "change",
           "name": "0",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "0",
                   "tot": "num"
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "action",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 490,
           "y": 400,
           "wires": [
                   "95c9633ab4777657"
           "id": "95c9633ab4777657",
           "type": "rbe",
           "name": "",
           "func": "rbe",
           "gap": "",
           "start": "",
           "inout": "out",
           "septopics": false,
           "topi": "topic",
           "x": 630,
           "y": 400,
           "wires": [
                   "85d35cf6ea80789b"
           "id": "85d35cf6ea80789b",
           "type": "trigger",
           "name": "",
           "op1": "",
           "op2": "",
           "op1type": "nul",
           "op2type": "payl",
           "duration": "5",
           "extend": true,
           "overrideDelay": false,
           "units": "s",
           "reset": "",
           "bytopic": "all",
           "topic": "topic",
           "outputs": 1,
           "x": 780,
           "y": 400,
           "wires": [
                   "712d4e4919ac7f2d"
           "id": "712d4e4919ac7f2d",
           "type": "trigger",
           "name": "",
           "op1": "",
           "op2": "0",
           "op1type": "pay",
           "op2type": "str",
           "duration": "-5",
           "extend": false,
           "units": "s",
           "reset": "0",
           "bytopic": "all",
           "topic": "topic",
           "outputs": 1,
           "x": 980,
           "y": 400,
           "wires": [
                   "f21d6c44133561ef",
                   "e16d9f5e94d3229f"
           "id": "f21d6c44133561ef",
           "type": "debug",
           "name": "action",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 970,
           "y": 460,
           "wires": []
    Falls der Energiemanager aus irgendeinem Grund gar nicht mehr tut - kannst Du das periodische Senden ja dann auch unterbinden.
    hawell
    @mickym sagte in Schrittwerk mit einer Bedingung begrenzen:
    erschreckenderweise tut es was es soll ...
    bis auf, dass es immer die gleichen Zeiten nimmt, ich konnte schneller runterschalten, als hoch.
    • H hawell
      mickymM Offline
      mickymM Offline
      mickym
      @hawell Ja gut - die Zyklik bleibt gleich - aber Du könntest ja in der Switch Node noch andere Werte einsetzen, um schneller hoch und runter zu schalten.
      Sobald Du an der Rändern bist - wird ja durch die hintere filter Node die Nachrichtenanzahl beschränkt.
      Aber soweit ich verstanden habe - kommt aus dem Energiemanager ja alle Sekunden ein trigger - insofern ist es ja egal, ob Du einen eigenen Taktgeber verwendest und nicht den vom Energiemanager.
      Aber ist ja nur ein Alternativvorschlag. Deines hat ja funktioniert.
      H 1 Antwort Letzte Antwort
      • H hawell
        mickymM Offline
        mickymM Offline
        mickym
        @hawell Wenn Du den Takt vom Energiemanager behalten willst - dann kannst Du dieses Mal auch eine function Node verwenden. Ich mach Dir mal einen Vorschlag.
        • mickymM mickym
          hawell
          @mickym
          das skalieren mit größeren Schritten hatte ich schon getestet das geht super.
          zwei Sachen verstehe ich aber nicht.
          wieso sendet der letzte Trigger nur bei Zahlen außer "0" alle 5 sek ? und bei 0 Macht er nichts ??
          und leider gibt der Trigger den Wert aus, welcher "auf den Weg bebracht wurde", auch wenn sich schon die Richtung geändert wurde.
          also wenn +1 wiederholt wird, und dann auch 0 umspringt, wird trotzdem noch einmal hochgeschaltet und dann erst gestoppt.
          man müsste den laufenden Tigger bei Wertänderung unterbrechen.
          und zwei unterschiedliche zeitliche Trigger paralell laufen lassen (einen fürs hochschalten und einen fürs runter Schalten.
          • H hawell
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            @hawell sagte in Schrittwerk mit einer Bedingung begrenzen:
            @mickym
            Na das hatte ich aus Deinem alten Flow so verstanden, da alles rückgesetzt wurde - das dann nichts mehr gesendet werden soll.
            Nun ja - da musst aber mal logisch überlegen - dass ja EXTRA eine Zeit abgewartet wird, bis eine Änderung registriert wird.
            In dem Fall werde ich Dir mal mit einer function Node helfen, die Du dann wieder nur vom Energiemanager getriggert wird und nur bei +1 oder -1
            Nein das ergibt Chaos.
            • mickymM mickym
              @mickym
              hawell
              @mickym
              das ist auch richtig, aber wieso macht die Node das - ich ich finde die entsprechende Einstellung nicht. oder liegt es am dem Befehl "0" dieser Stoppt den Trigger?
              geht das nicht so ? 0 hat immer Priorität und setzt die Laufenden Trigger zurück?
              • H hawell
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                gelöscht
                • mickymM Offline
                  mickymM Offline
                  mickym
                  Na ich glaube Du behälst Deinen ursprünglichen Flow.
                  H 2 Antworten Letzte Antwort
                  • mickymM mickym
                    hawell
                    @mickym
                    ich schau mir das morgen mal genauer an.
                    aber der letzte flox ist buggy, der gibt teilweise nur 1 aus egal was man drückt (mit oder ohne warten; mit oder ohne 0 drücken)
                    • H hawell
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @mickym
                      Ja bleib bei dem ursprünglichen Flow - ich glaube das ist wahrscheinlich am Besten.
                      • mickymM mickym
                        hawell
                        gar nicht so einfach .. ;-)
                        ich finde deinen ansatz mit der vereinfachten Form gut, evtl bau ich mir da was draus.
                        aber heut nicht mehr -> morgen wieder ..
                        ich danke dir vielmals für die Unterstützung !!!
