  4. Mein erster Adapter: Für EZcontrol XS1
    5.2k
126 Beiträge 31 Kommentatoren 26.7k Aufrufe 19 Beobachtet
    Trashman1981
    #95
    Sorry, bin irgendwie auf ne andere Seite zum Thema geleitet worden.
    adapter: XS1@1.1.0
    js-controller: 18.18
    NPM: 8.19.14
    host.raspberrypi
    2023-09-29 15:31:54.158 info Do not restart adapter system.adapter.xs1.0 because desired by instance
    host.raspberrypi
    2023-09-29 15:31:54.157 info instance system.adapter.xs1.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    xs1.0
    2023-09-29 15:31:53.596 info Terminated (ADAPTER_REQUESTED_TERMINATION): xs1 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:7433:21) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:20 at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:267:81
    xs1.0
    2023-09-29 15:31:53.207 info Finished state creation. Added totally 12 actuators or sensors
    xs1.0
    2023-09-29 15:31:52.695 warn Adapter will exit in latest 1 sec with code xs1 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:7433:21) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:20 at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:267:81!
    xs1.0
    2023-09-29 15:31:52.693 info CopyList = {}
    xs1.0
    2023-09-29 15:31:52.692 info config XS1 Addresse: http://192.168.188.50
    xs1.0
    2023-09-29 15:31:52.690 info xs1 starting main...
    xs1.0
    2023-09-29 15:31:52.688 info Adapter disconnected and stopped with dostop(xs1 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:7433:21) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:20 at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:267:81) and callback(false)
    xs1.0
    2023-09-29 15:31:52.686 error xs1 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:7433:21) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:20 at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:267:81
    xs1.0
    2023-09-29 15:31:51.914 info starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.xs1, node: v18.18.0, js-controller: 5.0.12
    host.raspberrypi
    2023-09-29 15:31:49.981 info instance system.adapter.xs1.0 started with pid 15046
    host.raspberrypi
    2023-09-29 15:31:49.916 info "system.adapter.xs1.0" enabled
    • H Offline
      Highvoltage
      schrieb am zuletzt editiert von Highvoltage
      #96
      Die gleichen Fehlermeldungen bekam ich auch, aber erst als ich den js-controller von 4.0.24 nach 5.0.12 upgedatet habe. Ein Backup zurück mit js-4.0.24 und die XS1 lief wieder. Mit alle den anderen Daten stimmen wir überein. Ob es wirklich nur an dem js-Update liegt bin ich mir nicht soo sicher.
      Raspberry Pi 3B; XS1, Schalter und Steckdosen überwiegend Intertechno, Win10 32 bit, Warema, Rademacher, Broadlink RM PRO
        descco
        #97
        Das kann ich bestätigen:
        Raspi 4 - Raspian Bullseye
        Node.js v18.17.1
        NPM 9.6.7
        Alles up to date, bis auf JS-Controller. (4.0.24)
        Keine Probleme mit dem XS1-Adapter.
        Sobald ich den JS-Controller von 4.0.24 auf 5.0.12 updatete, bekomme ich die gleichen Fehlermeldungen wie Trashman1981 und der XS1-Adapter lässt sich nicht mehr starten.
        0 1 Antwort Letzte Antwort
        • D descco
          Node.js v18.17.1
          NPM 9.6.7
          0 Offline
          0 Offline
          007Schneiderlein
          schrieb am zuletzt editiert von 007Schneiderlein
          #98
          @descco said in Mein erster Adapter: Für EZcontrol XS1:
          Servus,
          habe leider auch das gleich Problem nach einem vollständigen iobroker update..... XS1 stoppte immer wieder.
          Nach downgrade des js-controllers auf 4.0.24 funzt der adapter wieder.
          Allerbesten DANK für diesen Workaround. 🙏
          iobroker stop
          npm i iobroker.js-controller@4.0.24 --production
          iobroker start
          Grüße Stefan
          • 0 007Schneiderlein
            Servus,
            iobroker stop
            iobroker start
            Grüße Stefan
            mcm1957M Offline
            mcm1957M Offline
            mcm1957
            #99
            siehe
            https://github.com/iobroker-community-adapters/ioBroker.xs1/issues/1
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
              descco
              #100
              @mcm57 said in Mein erster Adapter: Für EZcontrol XS1:
              siehe
              Ich habe jetzt die Datei /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js nach obiger Anleitung bearbeitet.
              und JS Controller 5.0.12 installiert.
              Bei mir funktioniert jetzt alles erstmal wieder (ca. 15 devices: FS20, Intetrtechno, ...)
              BTW:
              Nach dem Update auf 5.0.12 nach Anleitung, musste ich die Datei wieder editieren, weil sie im Ursprungszustand war.
              iobroker Fix ???
              Ob es noch weitere "Nachwehen" gibt kann ich leider nicht beurteilen
              mcm1957M R 2 Antworten Letzte Antwort
              • D descco
                siehe
                BTW:
                iobroker Fix ???
                mcm1957M Offline
                mcm1957M Offline
                mcm1957
                #101
                @descco
                Super
                Danke f d info. Ichvwerd versuchen dass in den vode zu integrieren.
                Bitte verlink den beiitrag im issue. Bin unterwegs u hab keinen vernünftigen zugang zu githuv
                • D descco
                  siehe
                  BTW:
                  iobroker Fix ???
                  RandyAndy
                  schrieb am zuletzt editiert von RandyAndy
                  #102
                  @descco
                  Ich habe heute den code angepasst und nun ist der Adapter wieder stabil.
                  Sicherlich wäre es gut dies in den Adpater mit einer neuen Version zu integrieren und dann zu releasen.
                  Ich stelle mich auch gerne als Tester zur Verfügung.
                  • R RandyAndy
                    @descco
                    mcm1957M Offline
                    mcm1957M Offline
                    mcm1957
                    #103
                    @randyandy
                    War grad beim Schreiben :-)
                    Ich hab die Korrektur und einige Anpassungen an der Umgebung (damit ein normaler Releasebau geht) nun umgesetzt. Ab sofort steht zunächst NUR auf Github und npm eine Testversion 1.1.1-alpha.0 zur Verfügung.
                    Wer mag UND EIN BACKUP SEINES Systems hat (bzw. ein Testsystem) bitte die Github Version mal testen. Mangel passender Umgebung kann ich da nichts testen.
                    Sobald ich einige (wenige) positive Rückmeldungen habe, stell ich die 1.1.1 normal ins Latest Repository für den Beta Test.
                    D R 3 Antworten Letzte Antwort
                    • mcm1957M mcm1957
                      @randyandy
                      descco
                      #104
                      Hallo mcm57,
                      ich habe gerade aus GitHub die Alpha-Version installiert.
                      Bei mir läuft alles einwandfrei.
                      • mcm1957M mcm1957
                        @randyandy
                        RandyAndy
                        #105
                        @mcm57
                        Ist seit ein paar Minuten drauf. Mal sehen ob nun alle Aktoren wieder angesteuert werden.
                        Der Adapter ist nun erst mal wieder aktiv.
                        Ich melde mich dann morgen, dann weiß ich mehr.
                        • mcm1957M mcm1957
                          @randyandy
                          RandyAndy
                          #106
                          @mcm57
                          ist nun seit gestern Nacht in der neuen Version am Laufen und alles ist so wie es sein soll.
                          Andreas
                          • R RandyAndy
                            @mcm57
                            Andreas
                            mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            #107
                            V1.1.2 sollte ab morgen im LATEST Repo verfügbar sein.
                            Code ist ident zur 1.1.1-alpha.0, allerdings wurden noch die diversen Dependencies aktualisiert.
                            R T 2 Antworten Letzte Antwort
                            • mcm1957M mcm1957
                              RandyAndy
                              #108
                              @mcm57
                              Sobald der Adapter verfügbar ist, würde ich Ihn dann aufspielen.
                              Andreas
                              R 1 Antwort Letzte Antwort
                              • R RandyAndy
                                @mcm57
                                Andreas
                                RandyAndy
                                #109
                                @mcm57
                                bei mir läuft der Adapter nun seit ein paar Tagen in der Version 1.1.2 ohne Probleme. Vielen Dank für die Anpassung.
                                Andreas
                                mcm1957M H 2 Antworten Letzte Antwort
                                • R RandyAndy
                                  @mcm57
                                  Andreas
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  #110
                                  @randyandy
                                  DANKE fürs feedback sag ich.
                                  • mcm1957M mcm1957
                                    Trashman1981
                                    schrieb am zuletzt editiert von Trashman1981
                                    #111
                                    @mcm57 Vielen Dank für Deine Unterstützung. Der Adapter läuft wieder.
                                    Allerdings bekomme ich jetzt die Meldung, das meine 12 actuators ge-added wurde, kann diese dann aber nicht sehen.
                                    Vielleicht bin ich gerade etwas übermüdet nach 15h Autofahrt, aber irgendwie komme ich nicht weiter...
                                    xs1.0 2023-10-15 14:27:24.023 info Finished state creation. Added totally 12 actuators or sensors
                                    Wenn ich die dann schalte (per XS1 direkt), kommt folgendes:
                                    xs1.0 2023-10-15 14:43:09.741 warn State "xs1.0.Actuators.Schlafzimmer" has no existing object, this might lead to an error in future versions
                                    Gruss, Trashman1981
                                    • T Trashman1981
                                      Gruss, Trashman1981
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      #112
                                      @trashman1981
                                      Mach bitte ein issue auf
                                      Damit ist chance geringer dass es ganz untergeht.
                                      Kann aber nichts versprechen Adapter ist uralt u schwer wartbar. Und ich hab auch keine passende Umgebung ...
                                      • C Cineman40
                                        Also schalten mit Alexa geht auf jeden Fall.
                                        Habe auch einen Xs1 und einen Windows Rechner mit iobroker laufen.
                                        Ich brauche nur sagen : Küche einschalten und das Licht geht an. Alexa bestätigt dann noch mit ok.
                                        Würde mir gerne die Temperatur Daten vorlesen lassen aus dem Xs1, aber keine Ahnung wie das gehen
                                        Könnte.
                                        Danke fsjoke es geht jetzt.hatte Watchdog nicht in die Liste eingefügt.
                                        Highvoltage
                                        #113
                                        @cineman40 Temperaturensensoren habe ich 3 Stück, die natürlich unter Alexageräte erfasst sein müssen. Ich frage jetzt nur "Alexa, wie ist die Temperatur von Badezimmer", schon bekomme ich sie genannt.
                                        • R RandyAndy
                                          @mcm57
                                          Andreas
                                          Highvoltage
                                          #114
                                          @randyandy Ist der 1.1.2 denn schon im Stable? Denn dort finde ich ihn nicht.
                                          Sonst warte ich bis er im Stable auftaucht. habe noch keine Eile!
