  4. iobroker zeschossen
    6.8k
iobroker zeschossen
175 Beiträge 9 Kommentatoren 48.7k Aufrufe 7 Beobachtet
    @krisiun sagte in iobroker zeschossen:
    Bin doch nur ein Anfänger
    Der dann in einer root-shell genau Null verloren hat.
    sudo apt update
    apt policy nodejs
    liefert?
    KrisiunK Offline
    KrisiunK Offline
    Krisiun
    #68
    moment ich kann den editor nicht verlassen
    • KrisiunK Krisiun
      #69
      Du solltest den echo...-Kram ja gerade NICHT in den Editor knallen, sondern in dein Terminal.
      Strg-X schließt nano.
        sudo apt update
        apt policy nodejs
        liefert?
        KrisiunK Offline
        KrisiunK Offline
        Krisiun
        #70
        krisiun@Marek2:/root$ sudo apt update
        Get:1 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
        Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
        Get:4 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
        Get:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
        Err:1 https://dl.yarnpkg.com/debian stable InRelease
          The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
        Get:6 http://archive.ubuntu.com/ubuntu jammy-backports InRelease [109 kB]
        Err:2 https://deb.nodesource.com/node_18.x nodistro InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
        Fetched 355 kB in 4s (94.6 kB/s)
        Reading package lists... Done
        1 package can be upgraded. Run 'apt list --upgradable' to see it.
        N: Ignoring file 'nodesource.listy' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_18.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
        W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
        W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        krisiun@Marek2:/root$ apt policy nodejs
        nodejs:
          Installed: 12.22.9~dfsg-1ubuntu3
          Candidate: 18.18.0-1nodesource1
          Version table:
             18.18.0-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
         *** 12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        • KrisiunK Krisiun
          nodejs:
            Version table:
          #71
          Kerl...
          Du musst auch schon tun, was man dir einflüstert....
          Die Datei ist zu viel, lösch die.
          sudo rm /etc/apt/sources.list./nodesource.listy
          KrisiunK bahnuhrB 2 Antworten Letzte Antwort
            Kerl...
            KrisiunK Offline
            KrisiunK Offline
            Krisiun
            #72
            OK dann nochmal editor und dann den inhalt löschen?
              Kerl...
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              #73
              @thomas-braun sagte in iobroker zeschossen:
              da fehlt noch ein "d" hinter list.
              Danke.
              • KrisiunK Krisiun
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                #74
                Bevor Thomas ganz verrückt wird:
                Du sollte auf der Konsole !!! -> nicht im Editor dies eingeben:
                sudo rm /etc/apt/sources.list.d/nodesource.listy
                Danke.
                KrisiunK 1 Antwort Letzte Antwort
                • bahnuhrB bahnuhr
                  KrisiunK Offline
                  KrisiunK Offline
                  Krisiun
                  #75
                  @bahnuhr
                  Habe ich doch
                  • bahnuhrB bahnuhr
                    #76
                    @bahnuhr sagte in iobroker zeschossen:
                    Stimmt.
                    also.
                    • KrisiunK Krisiun
                      @bahnuhr
                      Habe ich doch
                      #77
                      @krisiun
                      Und wo wir gerade dabei sind:
                      sudo rm /etc/apt/sources.list.d/yar*
                      KrisiunK 2 Antworten Letzte Antwort
                        @krisiun
                        KrisiunK Offline
                        KrisiunK Offline
                        Krisiun
                        #78
                        Hab alles gemacht
                        • KrisiunK Krisiun
                          Hab alles gemacht
                          #79
                          @krisiun
                          Dann sollte bei
                          sudo apt update
                          nur noch der fehlende Schlüssel für nodesource angemeckert werden.
                            @krisiun
                            KrisiunK Offline
                            KrisiunK Offline
                            Krisiun
                            #80
                            Kann aber trotzdem den iob nicht starten. Gleiche Fehler.
                            krisiun@Marek2:/root$ iobroker start
                            /usr/bin/node: 1: cannot create : Permission denied
                            /usr/bin/node: 2: : not found
                            /usr/bin/node: 4: Syntax error: Unterminated quoted string
                            • KrisiunK Krisiun
                              #81
                              @krisiun
                              NICHT SO SCHNELL!
                              Du bist ja auch noch nicht fertig...
                              sudo apt update
                              cd
                              sagt?
                                @krisiun
                                NICHT SO SCHNELL!
                                sudo apt update
                                cd
                                sagt?
                                KrisiunK Offline
                                KrisiunK Offline
                                Krisiun
                                #82
                                Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
                                Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                                Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
                                Get:4 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
                                Hit:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
                                Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Err:4 https://dl.yarnpkg.com/debian stable InRelease
                                Err:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Fetched 17.1 kB in 4s (4719 B/s)
                                • KrisiunK Krisiun
                                  #83
                                  @krisiun
                                  Du solltest doch yarn löschen...
                                    @krisiun
                                    KrisiunK Offline
                                    KrisiunK Offline
                                    Krisiun
                                    #84
                                    Dann sag mir bitte, bitte wie? Sorry aber das ist mir auch schon unangenehm dass ich das nicht schnalle
                                    • KrisiunK Krisiun
                                      #85
                                      @krisiun
                                      Dann
                                      sudo rm `sudo find / -name nodesource.gpg`
                                      sudo rm `sudo find / -name nodesource.key`
                                      sudo apt install -y ca-certificates curl gnupg
                                      sudo mkdir -p /etc/apt/keyrings
                                      curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
                                      sudo apt update
                                      • KrisiunK Krisiun
                                        #86
                                        Steht doch da.
                                          Steht doch da.
                                          KrisiunK Offline
                                          KrisiunK Offline
                                          Krisiun
                                          #87
                                          Ich bin dabei aber ich kanns nicht finden
                                          Thomas BraunT bahnuhrB 2 Antworten Letzte Antwort
